[mapguide-commits] r5054 - trunk/MgDev/Server/src/Wms
svn_mapguide at osgeo.org
Sun Jul 25 23:22:23 EDT 2010
Author: liuar
Date: 2010-07-26 03:22:22 +0000 (Mon, 26 Jul 2010)
New Revision: 5054
trunk/MgDev/Server/src/Wms/1.3.0.xml.awd
trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd
In WMS 1.3.0 specification section 7.3.3.11 defines the Exceptions in WMS
service.
There are 3 kinds of exception formats defined in this section: XML, INIMAGE and
BLANK. The XML is a mandatory format and the other two are optional. The default
value is "XML" if this parameter is absent from the request.
XML (mandatory)
Errors are reported using service exception XML. This is the default exception
format if none is specified in the request. The remaining exception formats are
optional. A server may issue a service exception in the default XML format if
a request specifies a different exception format not supported by the server.
INIMAGE (optional)
If the EXCEPTIONS parameter is set to INIMAGE, the WMS shall, upon detecting an
error, return an object of the MIME type specified in the FORMAT parameter whose
content includes text describing the nature of the error. In the case of a
picture format, the error message shall be drawn on the returned picture. In the
case of a graphic element format, the text of the error message shall be
rendered in the manner that text is normally represented in that format.
BLANK (optional)
If the EXCEPTIONS parameter is set to BLANK, the WMS shall, upon detecting an
error, return an object of the type specified in FORMAT whose content is
uniformly ?\226?\128?\156off?\226?\128?\157. In the case of a picture format, that response shall be
an image containing only pixels of one color (the background color). In the case
of a picture format supporting transparency, if TRANSPARENT=TRUE is specified
the pixels shall all be transparent.
NONE: MapGuide only support XML currently.
Modified: trunk/MgDev/Server/src/Wms/1.3.0.xml.awd
--- trunk/MgDev/Server/src/Wms/1.3.0.xml.awd 2010-07-23 14:39:21 UTC (rev 5053)
+++ trunk/MgDev/Server/src/Wms/1.3.0.xml.awd 2010-07-26 03:22:22 UTC (rev 5054)
@@ -396,7 +396,7 @@
Exception format - XML
-<Response request="Exception" content-type="text/xml">
+<Response request="Exception" content-type="XML">
<ServiceExceptionReport version="&TemplateVersion;">
<ServiceException code="&Exception.Type;">
&Exception.message;
Modified: trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd
--- trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd 2010-07-23 14:39:21 UTC (rev 5053)
+++ trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd 2010-07-26 03:22:22 UTC (rev 5054)
@@ -190,6 +190,10 @@
<item>application/vnd.ogc.se_blank</item>
<item>text/html</item>
<item>text/plain</item>
+ <item>XML</item>
+ <item>INIMAGE</item>
+ <item>BLANK</item>
</Define>
More information about the mapguide-commits
