[mapguide-commits] r5058 - trunk/MgDev/Web/src/HttpHandler
svn_mapguide at osgeo.org
Tue Jul 27 22:50:54 EDT 2010
Author: liuar
Date: 2010-07-28 02:50:54 +0000 (Wed, 28 Jul 2010)
New Revision: 5058
trunk/MgDev/Web/src/HttpHandler/OgcWmsException.cpp
trunk/MgDev/Web/src/HttpHandler/OgcWmsException.h
trunk/MgDev/Web/src/HttpHandler/OgcWmsServer.cpp
trunk/MgDev/Web/src/HttpHandler/OgcWmsServer.h
Ticket #1392
This submission added the validation of version parameter in GetMap and GetFeatureInfo operation.
Modified: trunk/MgDev/Web/src/HttpHandler/OgcWmsException.cpp
--- trunk/MgDev/Web/src/HttpHandler/OgcWmsException.cpp 2010-07-28 02:48:32 UTC (rev 5057)
+++ trunk/MgDev/Web/src/HttpHandler/OgcWmsException.cpp 2010-07-28 02:50:54 UTC (rev 5058)
@@ -37,6 +37,7 @@
CPSZ MgOgcWmsException::kpszMissingBoundingBox = _("MissingBoundingBox");
CPSZ MgOgcWmsException::kpszInvalidBoundingBox = _("InvalidBoundingBox");
CPSZ MgOgcWmsException::kpszMissingInfoFormat = _("MissingInfoFormat");
+CPSZ MgOgcWmsException::kpszMissingVersion = _("MissingVersion");
// A catch-all for the innards being really unhealthy!
CPSZ MgOgcException::kpszInternalError = _("InternalError");
Modified: trunk/MgDev/Web/src/HttpHandler/OgcWmsException.h
--- trunk/MgDev/Web/src/HttpHandler/OgcWmsException.h 2010-07-28 02:48:32 UTC (rev 5057)
+++ trunk/MgDev/Web/src/HttpHandler/OgcWmsException.h 2010-07-28 02:50:54 UTC (rev 5058)
@@ -55,6 +55,9 @@
OperationNotSupported Request is for an optional operation that is not supported by the
server.
MissingBoundingBox Request does not contain a required bounding box parameter.
+InvalidBoundingBox Request contains an invalid bounding box value.
+MissingInfoFormat Request does not contain a required info format parameter.
+MissingVersion Request does not contain a required version parameter.
static CPSZ kpszInvalidFormat;
@@ -74,6 +77,7 @@
static CPSZ kpszMissingBoundingBox;
static CPSZ kpszInvalidBoundingBox;
static CPSZ kpszMissingInfoFormat;
+ static CPSZ kpszMissingVersion;
#endif//_OgcWmsException_h
Modified: trunk/MgDev/Web/src/HttpHandler/OgcWmsServer.cpp
--- trunk/MgDev/Web/src/HttpHandler/OgcWmsServer.cpp 2010-07-28 02:48:32 UTC (rev 5057)
+++ trunk/MgDev/Web/src/HttpHandler/OgcWmsServer.cpp 2010-07-28 02:50:54 UTC (rev 5058)
@@ -86,6 +86,7 @@
CPSZ kpszExceptionMessageInvalidImageFormat = _("The request uses an unsupported image format. (Found FORMAT=&Request.format;)"); // Localize
CPSZ kpszExceptionMessageMissingImageFormat = _("The request must contain a FORMAT parameter to specify the required image format."); // Localize
CPSZ kpszExceptionMessageMissingInfoFormat = _("The request must contain an INFO_FORMAT parameter to specify the format of feature information (MIME type)."); // Localize
+CPSZ kpszExceptionMessageMissingVersion = _("The request must contain a VERSION parameter to specify the WMS version."); // Localize
// END LOCALIZATION
CPSZ kpszPiEnumLayers = _("EnumLayers");
@@ -350,37 +351,49 @@
bool bValid = true;
+ // Search for a VERSION= parameter
+ STRING version = GetRequestVersion();
+ if(version.empty())
+ ServiceExceptionReportResponse(MgOgcWmsException(MgOgcWmsException::kpszMissingVersion,
+ kpszExceptionMessageMissingVersion));
+ bValid = false;
// Search for a FORMAT= parameter, and verify that its value is supported.
CPSZ imageFormat = RequestParameter(kpszQueryStringFormat);
- if(imageFormat != NULL && szlen(imageFormat) > 0)
+ if(bValid)
- // We're expecting a supported formats definition. There's a hard-coded
- // default, but the templates can also define one.
- CPSZ pszMap = this->Definition(kpszDefineSupportedFormats);
- if(pszMap) {
- MgXmlParser Xml(pszMap);
- STRING sTo;
- if(!MapValue(Xml,imageFormat,sTo) || sTo.length() == 0) {
- ServiceExceptionReportResponse(MgOgcWmsException(MgOgcWmsException::kpszInvalidFormat,
- kpszExceptionMessageInvalidImageFormat));
+ if(imageFormat != NULL && szlen(imageFormat) > 0)
+ // We're expecting a supported formats definition. There's a hard-coded
+ // default, but the templates can also define one.
+ CPSZ pszMap = this->Definition(kpszDefineSupportedFormats);
+ if(pszMap) {
+ MgXmlParser Xml(pszMap);
+ STRING sTo;
+ if(!MapValue(Xml,imageFormat,sTo) || sTo.length() == 0) {
+ ServiceExceptionReportResponse(MgOgcWmsException(MgOgcWmsException::kpszInvalidFormat,
+ kpszExceptionMessageInvalidImageFormat));
+ bValid = false;
+ else {
+ this->m_pTopOfDefinitions->AddDefinition(kpszDefinitionInitServerError,kpszDefineSupportedFormats);
+ InternalError(kpszInternalErrorMissingDefinition);
bValid = false;
- else {
- this->m_pTopOfDefinitions->AddDefinition(kpszDefinitionInitServerError,kpszDefineSupportedFormats);
- InternalError(kpszInternalErrorMissingDefinition);
+ else
+ // The required FORMAT parameter is missing
+ kpszExceptionMessageMissingImageFormat));
bValid = false;
- else
- // The required FORMAT parameter is missing
- kpszExceptionMessageMissingImageFormat));
- bValid = false;
// Look for the LAYERS= parameter and parse its value into the comma-separates list of values.
@@ -557,9 +570,8 @@
else
- STRING sVersion = RequestParameter(kpszQueryStringVersion);
STRING sBBox(bbox);
- if(sVersion >= _("1.3.0"))
+ if(version >= _("1.3.0"))
CPSZ crs = RequestParameter(kpszQueryStringCrs);
if(crs == NULL || szlen(crs) == 0)
@@ -631,9 +643,9 @@
if(bValid)
// INFO_FORMAT becomes a mandatory parameter since WMS1.3.0
// Note: lexical comparison, not numerical one;
- if(!sVersion.empty() && sVersion >= _("1.3.0"))
+ if(!version.empty() && version >= _("1.3.0"))
CPSZ pszFormat = RequestParameter(kpszQueryStringInfoFormat);
if(pszFormat == NULL)
@@ -822,3 +834,18 @@
m_pLayers = SAFE_ADDREF(pLayerDefs);
+// Get WMS request version
+STRING MgOgcWmsServer::GetRequestVersion()
+ CPSZ version = RequestParameter(kpszQueryStringVersion);
+ if(version == NULL)
+ // In WMS version 1.0.0, the name of this parameter was "WMTVER".
+ // That name is now deprecated, but for backwards compatibility and
+ // version negotiation a post-1.0.0 server should accept
+ // either form without issuing a Service Exception.
+ version = RequestParameter(kpszQueryStringVersion);
+ return STRING(version? version : _(""));
Modified: trunk/MgDev/Web/src/HttpHandler/OgcWmsServer.h
--- trunk/MgDev/Web/src/HttpHandler/OgcWmsServer.h 2010-07-28 02:48:32 UTC (rev 5057)
+++ trunk/MgDev/Web/src/HttpHandler/OgcWmsServer.h 2010-07-28 02:50:54 UTC (rev 5058)
@@ -93,6 +93,9 @@
bool ValidateGetFeatureInfoParameters();
bool ValidateMapParameters();
bool ValidateMapParameters(MgStringCollection* queryableLayers);
+ // Hetp method to get WMS request version
+ STRING GetRequestVersion();
CPSZ ServiceExceptionReportElement();
More information about the mapguide-commits
