[mapguide-commits] r5061 - in sandbox/maestro-3.0: Maestro.Login
MaestroAPITests OSGeo.MapGuide.MaestroAPI
svn_mapguide at osgeo.org
Fri Jul 30 07:59:06 EDT 2010
Author: jng
Date: 2010-07-30 11:59:06 +0000 (Fri, 30 Jul 2010)
New Revision: 5061
sandbox/maestro-3.0/Maestro.Login/LoginDialog.cs
sandbox/maestro-3.0/MaestroAPITests/HttpConnectionTests.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ConnectionProviderRegistry.cs
Port r5060 submission to sandbox
Modified: sandbox/maestro-3.0/Maestro.Login/LoginDialog.cs
--- sandbox/maestro-3.0/Maestro.Login/LoginDialog.cs 2010-07-30 11:46:03 UTC (rev 5060)
+++ sandbox/maestro-3.0/Maestro.Login/LoginDialog.cs 2010-07-30 11:59:06 UTC (rev 5061)
@@ -148,12 +148,19 @@
if (_selectedIndex == 0) //HTTP
- string format = "Url={0};Username={1};Password={2};Locale={3};AllowUntestedVersion={4}";
- string connStr = string.Format(format, _http.Server, _http.Username, _http.Password, _http.Language, true);
+ //string format = "Url={0};Username={1};Password={2};Locale={3};AllowUntestedVersion={4}";
+ //string connStr = string.Format(format, _http.Server, _http.Username, _http.Password, _http.Language, true);
+ System.Data.Common.DbConnectionStringBuilder builder = new System.Data.Common.DbConnectionStringBuilder();
+ builder["Url"] = _http.Server;
+ builder["Username"] = _http.Username;
+ builder["Password"] = _http.Password;
+ builder["Locale"] = _http.Language;
+ builder["AllowUntestedVersion"] = true;
string agent = "MapGuide Maestro v" + System.Reflection.Assembly.GetExecutingAssembly().GetName().Version.ToString();
- _conn = ConnectionProviderRegistry.CreateConnection("Maestro.Http", connStr);
+ _conn = ConnectionProviderRegistry.CreateConnection("Maestro.Http", builder.ToString());
_conn.SetCustomProperty("UserAgent", agent);
//Update preferred site entry if it exists
@@ -209,9 +216,12 @@
else //Native
- string format = "WebConfig={0};Username={1};Password={2};Locale={3}";
- string connStr = string.Format(format, _local.WebConfigPath, _local.Username, _local.Password, System.Globalization.CultureInfo.CurrentCulture.TwoLetterISOLanguageName);
- _conn = ConnectionProviderRegistry.CreateConnection("Maestro.LocalNative", connStr);
+ builder["WebConfig"] = _local.WebConfigPath;
+ builder["Username"] = _local.Username;
+ builder["Password"] = _local.Password;
+ builder["Locale"] = System.Globalization.CultureInfo.CurrentCulture.TwoLetterISOLanguageName;
+ _conn = ConnectionProviderRegistry.CreateConnection("Maestro.LocalNative", builder.ToString());
_conn.AutoRestartSession = true;
Modified: sandbox/maestro-3.0/MaestroAPITests/HttpConnectionTests.cs
--- sandbox/maestro-3.0/MaestroAPITests/HttpConnectionTests.cs 2010-07-30 11:46:03 UTC (rev 5060)
+++ sandbox/maestro-3.0/MaestroAPITests/HttpConnectionTests.cs 2010-07-30 11:59:06 UTC (rev 5061)
@@ -30,6 +30,24 @@
public class HttpConnectionTests
[Test]
+ public void TestConnectionString()
+ builder["Foo"] = "sdfjkg";
+ builder["Bar"] = "skgjuksdf";
+ builder["Snafu"] = "asjdgjh;sdgj"; //Note the ; in the value
+ builder["Whatever"] = "asjd=gjh;sdgj"; //Note the ; and = in the value
+ var values = ConnectionProviderRegistry.ParseConnectionString(builder.ToString());
+ Assert.AreEqual(values.Count, 4);
+ Assert.AreEqual(builder["Foo"].ToString(), values["Foo"]);
+ Assert.AreEqual(builder["Bar"].ToString(), values["Bar"]);
+ Assert.AreEqual(builder["Snafu"].ToString(), values["Snafu"]);
+ Assert.AreEqual(builder["Whatever"].ToString(), values["Whatever"]);
+ [Test]
public void TestCustomProperties()
var builder = new RequestBuilder(new Uri("http://tempuri.org"), "en");
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ConnectionProviderRegistry.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ConnectionProviderRegistry.cs 2010-07-30 11:46:03 UTC (rev 5060)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ConnectionProviderRegistry.cs 2010-07-30 11:59:06 UTC (rev 5061)
@@ -97,18 +97,16 @@
- private static NameValueCollection ParseConnectionString(string connectionString)
+ internal static NameValueCollection ParseConnectionString(string connectionString)
+ builder.ConnectionString = connectionString;
NameValueCollection values = new NameValueCollection();
- string[] tokens = connectionString.Split(';');
- foreach (string tok in tokens)
- string[] nameValue = tok.Split('=');
- if (nameValue.Length == 2)
- values.Add(nameValue[0], nameValue[1]);
+ foreach (string key in builder.Keys)
+ values.Add(key, builder[key].ToString());
return values;
More information about the mapguide-commits
