[mapguide-commits] r4934 - trunk/Tools/Maestro/MaestroAPI
svn_mapguide at osgeo.org
Fri Jun 4 08:10:20 EDT 2010
Author: jng
Date: 2010-06-04 08:10:18 -0400 (Fri, 04 Jun 2010)
New Revision: 4934
trunk/Tools/Maestro/MaestroAPI/XmlFeatureSetReader.cs
Change XmlFeatureSetReader to handle post #708 SELECTFEATURES output
Modified: trunk/Tools/Maestro/MaestroAPI/XmlFeatureSetReader.cs
--- trunk/Tools/Maestro/MaestroAPI/XmlFeatureSetReader.cs 2010-06-04 00:06:46 UTC (rev 4933)
+++ trunk/Tools/Maestro/MaestroAPI/XmlFeatureSetReader.cs 2010-06-04 12:10:18 UTC (rev 4934)
@@ -124,7 +124,7 @@
protected override void CloseInternal()
- throw new NotImplementedException();
public override int Depth
@@ -159,64 +159,72 @@
throw new Exception("Bad document, multiple: " + p["Name"].InnerText + " values in a single feature");
m_nulls[ordinal] = false;
- if (parent.Columns[ordinal].Type == typeof(string) || parent.Columns[ordinal].Type == Utility.UnmappedType)
- m_items[ordinal] = p["Value"].InnerText;
- else if (parent.Columns[ordinal].Type == typeof(int))
- m_items[ordinal] = XmlConvert.ToInt32(p["Value"].InnerText);
- else if (parent.Columns[ordinal].Type == typeof(long))
- m_items[ordinal] = XmlConvert.ToInt64(p["Value"].InnerText);
- else if (parent.Columns[ordinal].Type == typeof(short))
- m_items[ordinal] = XmlConvert.ToInt16(p["Value"].InnerText);
- else if (parent.Columns[ordinal].Type == typeof(double))
- m_items[ordinal] = XmlConvert.ToDouble(p["Value"].InnerText);
- else if (parent.Columns[ordinal].Type == typeof(bool))
- m_items[ordinal] = XmlConvert.ToBoolean(p["Value"].InnerText);
- else if (parent.Columns[ordinal].Type == typeof(DateTime))
+ XmlNode valueNode = p["Value"];
+ if (valueNode == null)
- try
+ m_nulls[ordinal] = true;
+ else
+ if (parent.Columns[ordinal].Type == typeof(string) || parent.Columns[ordinal].Type == Utility.UnmappedType)
+ m_items[ordinal] = valueNode.InnerText;
+ else if (parent.Columns[ordinal].Type == typeof(int))
+ m_items[ordinal] = XmlConvert.ToInt32(valueNode.InnerText);
+ else if (parent.Columns[ordinal].Type == typeof(long))
+ m_items[ordinal] = XmlConvert.ToInt64(valueNode.InnerText);
+ else if (parent.Columns[ordinal].Type == typeof(short))
+ m_items[ordinal] = XmlConvert.ToInt16(valueNode.InnerText);
+ else if (parent.Columns[ordinal].Type == typeof(double))
+ m_items[ordinal] = XmlConvert.ToDouble(valueNode.InnerText);
+ else if (parent.Columns[ordinal].Type == typeof(bool))
+ m_items[ordinal] = XmlConvert.ToBoolean(valueNode.InnerText);
+ else if (parent.Columns[ordinal].Type == typeof(DateTime))
- //Fix for broken ODBC provider
- string v = p["Value"].InnerText;
+ try
+ //Fix for broken ODBC provider
+ string v = valueNode.InnerText;
- if (v.Trim().ToUpper().StartsWith("TIMESTAMP"))
- v = v.Trim().Substring("TIMESTAMP".Length).Trim();
- else if (v.Trim().ToUpper().StartsWith("DATE"))
- v = v.Trim().Substring("DATE".Length).Trim();
- else if (v.Trim().ToUpper().StartsWith("TIME"))
- v = v.Trim().Substring("TIME".Length).Trim();
+ if (v.Trim().ToUpper().StartsWith("TIMESTAMP"))
+ v = v.Trim().Substring("TIMESTAMP".Length).Trim();
+ else if (v.Trim().ToUpper().StartsWith("DATE"))
+ v = v.Trim().Substring("DATE".Length).Trim();
+ else if (v.Trim().ToUpper().StartsWith("TIME"))
+ v = v.Trim().Substring("TIME".Length).Trim();
- if (v != p["Value"].InnerText)
- if (v.StartsWith("'"))
- v = v.Substring(1);
- if (v.EndsWith("'"))
- v = v.Substring(0, v.Length - 1);
+ if (v != valueNode.InnerText)
+ if (v.StartsWith("'"))
+ v = v.Substring(1);
+ if (v.EndsWith("'"))
+ v = v.Substring(0, v.Length - 1);
- m_items[ordinal] = DateTime.Parse(v, System.Globalization.CultureInfo.InvariantCulture, System.Globalization.DateTimeStyles.NoCurrentDateDefault);
+ m_items[ordinal] = DateTime.Parse(v, System.Globalization.CultureInfo.InvariantCulture, System.Globalization.DateTimeStyles.NoCurrentDateDefault);
+ else
+ m_items[ordinal] = XmlConvert.ToDateTime(v, XmlDateTimeSerializationMode.Unspecified);
- else
- m_items[ordinal] = XmlConvert.ToDateTime(v, XmlDateTimeSerializationMode.Unspecified);
+ catch (Exception ex)
+ //Unfortunately FDO supports invalid dates, such as the 30th feb
+ m_items[ordinal] = ex;
- catch (Exception ex)
+ else if (parent.Columns[ordinal].Type == Utility.GeometryType)
- //Unfortunately FDO supports invalid dates, such as the 30th feb
- m_nulls[ordinal] = true;
- m_items[ordinal] = ex;
+ if (string.IsNullOrEmpty(valueNode.InnerText))
+ m_items[ordinal] = null;
+ else
+ m_lazyloadGeometry[ordinal] = true;
- else if (parent.Columns[ordinal].Type == Utility.GeometryType)
- if (string.IsNullOrEmpty(p["Value"].InnerText))
- m_items[ordinal] = null;
else
- m_lazyloadGeometry[ordinal] = true;
+ throw new Exception("Unknown type: " + parent.Columns[ordinal].Type.FullName);
- else
- throw new Exception("Unknown type: " + parent.Columns[ordinal].Type.FullName);
More information about the mapguide-commits
