[mapguide-commits] r4942 - in sandbox/maestro-2.5: Maestro.Base/UI Maestro.Editors Maestro.Editors/Common Maestro.Editors/Generic Maestro.Editors/Properties Maestro.Login Maestro.Shared.UI OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Exceptions OSGeo.MapGuide.MaestroAPI.Http
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Jun 15 06:34:05 EDT 2010
Author: jng
Date: 2010-06-15 10:34:05 +0000 (Tue, 15 Jun 2010)
New Revision: 4942
Added:
   sandbox/maestro-2.5/Maestro.Shared.UI/DialogFactory.cs
   sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Exceptions/NestedExceptionMessageProcessor.cs
   sandbox/maestro-2.5/Maestro.Base/UI/MessageViewer.cs
   sandbox/maestro-2.5/Maestro.Editors/Common/ResourceDataCtrl.cs
   sandbox/maestro-2.5/Maestro.Editors/Generic/XmlEditorCtrl.cs
   sandbox/maestro-2.5/Maestro.Editors/Maestro.Editors.csproj
   sandbox/maestro-2.5/Maestro.Editors/Properties/Resources.Designer.cs
   sandbox/maestro-2.5/Maestro.Editors/Properties/Resources.resx
   sandbox/maestro-2.5/Maestro.Login/HttpLoginCtrl.cs
   sandbox/maestro-2.5/Maestro.Login/ILoginCtrl.cs
   sandbox/maestro-2.5/Maestro.Login/LocalNativeLoginCtrl.cs
   sandbox/maestro-2.5/Maestro.Login/LoginDialog.cs
   sandbox/maestro-2.5/Maestro.Login/Maestro.Login.csproj
   sandbox/maestro-2.5/Maestro.Shared.UI/Maestro.Shared.UI.csproj
   sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
   sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
This submission includes the following changes:
 - (forward)port the nested exception message processing code from Maestro 2.1
 - (forward)port r4933 to 2.5 sandbox
 - Add a DialogFactory helper class to work around an ANNOYING bug (feature?) where changing directories in a OpenFileDialog/SaveFileDialog will actually mess up the current working directory, causing file/assembly loading using relative paths to fail.
Modified: sandbox/maestro-2.5/Maestro.Base/UI/MessageViewer.cs
--- sandbox/maestro-2.5/Maestro.Base/UI/MessageViewer.cs	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/Maestro.Base/UI/MessageViewer.cs	2010-06-15 10:34:05 UTC (rev 4942)
@@ -26,6 +26,7 @@
 using System.Windows.Forms;
 using ICSharpCode.Core;
 using System.IO;
+using Maestro.Shared.UI;
 namespace Maestro.Base.UI
@@ -65,7 +66,7 @@
         private void btnSave_Click(object sender, EventArgs e)
-            using (var save = new SaveFileDialog())
+            using (var save = DialogFactory.SaveFile())
                 save.Filter = "*.log|*.log";
                 if (save.ShowDialog() == DialogResult.OK)
Modified: sandbox/maestro-2.5/Maestro.Editors/Common/ResourceDataCtrl.cs
--- sandbox/maestro-2.5/Maestro.Editors/Common/ResourceDataCtrl.cs	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/Maestro.Editors/Common/ResourceDataCtrl.cs	2010-06-15 10:34:05 UTC (rev 4942)
@@ -28,6 +28,7 @@
 using OSGeo.MapGuide.ObjectModels.Common;
 using System.IO;
+using OSGeo.MapGuide.MaestroAPI.Exceptions;
 namespace Maestro.Editors.Common
@@ -135,7 +136,7 @@
         private void btnAdd_Click(object sender, EventArgs e)
-            using (var open = new OpenFileDialog())
+            using (var open = DialogFactory.OpenFile())
                 if (open.ShowDialog() == DialogResult.OK)
@@ -152,7 +153,7 @@
                         catch (Exception ex)
-                            MessageBox.Show(ex.Message);
+                            MessageBox.Show(NestedExceptionMessageProcessor.GetFullMessage(ex), Properties.Resources.TitleError, MessageBoxButtons.OK, MessageBoxIcon.Error);
@@ -182,7 +183,7 @@
@@ -194,7 +195,7 @@
             var item = this.SelectedItem;
             if (item != null)
@@ -209,7 +210,7 @@
Modified: sandbox/maestro-2.5/Maestro.Editors/Generic/XmlEditorCtrl.cs
--- sandbox/maestro-2.5/Maestro.Editors/Generic/XmlEditorCtrl.cs	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/Maestro.Editors/Generic/XmlEditorCtrl.cs	2010-06-15 10:34:05 UTC (rev 4942)
@@ -30,6 +30,7 @@
 using System.IO;
 using OSGeo.MapGuide.MaestroAPI.ObjectModels;
 using OSGeo.MapGuide.MaestroAPI.Resource;
 namespace Maestro.Editors.Generic
@@ -245,7 +246,7 @@
             if (!string.IsNullOrEmpty(content))
Modified: sandbox/maestro-2.5/Maestro.Editors/Maestro.Editors.csproj
--- sandbox/maestro-2.5/Maestro.Editors/Maestro.Editors.csproj	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/Maestro.Editors/Maestro.Editors.csproj	2010-06-15 10:34:05 UTC (rev 4942)
@@ -3,7 +3,7 @@
   <PropertyGroup>
     <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
     <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
-    <ProductVersion>9.0.30729</ProductVersion>
+    <ProductVersion>9.0.21022</ProductVersion>
     <SchemaVersion>2.0</SchemaVersion>
     <ProjectGuid>{5AD2CDBA-952E-4148-98A1-31D2E0D540D5}</ProjectGuid>
     <OutputType>Library</OutputType>
@@ -517,9 +517,11 @@
     </EmbeddedResource>
     <EmbeddedResource Include="LayerDefinition\DrawingLayerEditorCtrl.resx">
       <DependentUpon>DrawingLayerEditorCtrl.cs</DependentUpon>
+      <SubType>Designer</SubType>
     </EmbeddedResource>
     <EmbeddedResource Include="LayerDefinition\Drawing\DrawingLayerSettingsCtrl.resx">
       <DependentUpon>DrawingLayerSettingsCtrl.cs</DependentUpon>
     </EmbeddedResource>
     <EmbeddedResource Include="LayerDefinition\LayerPropertiesSectionCtrl.resx">
       <DependentUpon>LayerPropertiesSectionCtrl.cs</DependentUpon>
@@ -804,4 +806,4 @@
   <Target Name="AfterBuild">
   </Target>
-</Project>
+</Project>
\ No newline at end of file
Modified: sandbox/maestro-2.5/Maestro.Editors/Properties/Resources.Designer.cs
--- sandbox/maestro-2.5/Maestro.Editors/Properties/Resources.Designer.cs	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/Maestro.Editors/Properties/Resources.Designer.cs	2010-06-15 10:34:05 UTC (rev 4942)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:2.0.50727.4927
+//     Runtime Version:2.0.50727.3053
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -448,6 +448,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Error.
+        /// </summary>
+        internal static string TitleError {
+            get {
+                return ResourceManager.GetString("TitleError", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Transparent.
         /// </summary>
         internal static string TransparentName {
Modified: sandbox/maestro-2.5/Maestro.Editors/Properties/Resources.resx
--- sandbox/maestro-2.5/Maestro.Editors/Properties/Resources.resx	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/Maestro.Editors/Properties/Resources.resx	2010-06-15 10:34:05 UTC (rev 4942)
@@ -288,4 +288,7 @@
   <data name="TestConnectionNoErrors" xml:space="preserve">
     <value>Provider reported no errors</value>
   </data>
+  <data name="TitleError" xml:space="preserve">
+    <value>Error</value>
+  </data>
 </root>
Modified: sandbox/maestro-2.5/Maestro.Login/HttpLoginCtrl.cs
--- sandbox/maestro-2.5/Maestro.Login/HttpLoginCtrl.cs	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/Maestro.Login/HttpLoginCtrl.cs	2010-06-15 10:34:05 UTC (rev 4942)
@@ -76,7 +76,7 @@
                 cmbLanguage.SelectedIndex = selected;
             _loading = false;
-            UpdateButtonStatus();
+            UpdateLoginStatus();
         public PreferedSite[] GetSites()
@@ -142,17 +142,9 @@
         private void txtPassword_TextChanged(object sender, EventArgs e)
-        private void UpdateButtonStatus()
-            if (this.Username.Trim().Length > 0 && this.Server.Trim().Length > 0)
-                EnableOk(this, EventArgs.Empty);
-            else
-                DisabledOk(this, EventArgs.Empty);
         public PreferedSiteList SiteList
             get;
@@ -204,5 +196,13 @@
             CheckSavedPassword(this, EventArgs.Empty);
+        public void UpdateLoginStatus()
+            if (this.Username.Trim().Length > 0 && this.Server.Trim().Length > 0)
+                EnableOk(this, EventArgs.Empty);
+            else
+                DisabledOk(this, EventArgs.Empty);
Modified: sandbox/maestro-2.5/Maestro.Login/ILoginCtrl.cs
--- sandbox/maestro-2.5/Maestro.Login/ILoginCtrl.cs	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/Maestro.Login/ILoginCtrl.cs	2010-06-15 10:34:05 UTC (rev 4942)
@@ -28,6 +28,8 @@
         string Username { get; }
         string Password { get; }
+        void UpdateLoginStatus();
         event EventHandler EnableOk;
         event EventHandler DisabledOk;
         event EventHandler CheckSavedPassword;
Modified: sandbox/maestro-2.5/Maestro.Login/LocalNativeLoginCtrl.cs
--- sandbox/maestro-2.5/Maestro.Login/LocalNativeLoginCtrl.cs	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/Maestro.Login/LocalNativeLoginCtrl.cs	2010-06-15 10:34:05 UTC (rev 4942)
@@ -25,6 +25,7 @@
 using System.Text;
 using System.IO;
 namespace Maestro.Login
@@ -68,6 +69,11 @@
         private void txtWebConfig_TextChanged(object sender, EventArgs e)
             if (this.WebConfigPath.Trim().Length > 0 && File.Exists(this.WebConfigPath))
             else
@@ -76,8 +82,11 @@
         private void btnBrowse_Click(object sender, EventArgs e)
-            using (var dlg = new OpenFileDialog())
+            using (var dlg = DialogFactory.OpenFile())
+                //WTF does this default to false??? Does MS not realize that changing directories
+                //via this dialog absolutely screws up file/assembly loading from relative paths?
+                dlg.RestoreDirectory = true;
                 dlg.Filter = "*.ini|*.ini";
                 if (dlg.ShowDialog() == DialogResult.OK)
Modified: sandbox/maestro-2.5/Maestro.Login/LoginDialog.cs
--- sandbox/maestro-2.5/Maestro.Login/LoginDialog.cs	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/Maestro.Login/LoginDialog.cs	2010-06-15 10:34:05 UTC (rev 4942)
@@ -25,6 +25,7 @@
 using System.Text;
 using OSGeo.MapGuide.MaestroAPI;
@@ -124,19 +125,17 @@
         private void rdHttp_CheckedChanged(object sender, EventArgs e)
-            _selectedIndex = 0;
-            SetLoginControl((Control)_controls[_selectedIndex]);
+            UpdateLoginControl();
         private void rdTcpIp_CheckedChanged(object sender, EventArgs e)
-            _selectedIndex = 1;
         private void btnCancel_Click(object sender, EventArgs e)
+            this.DialogResult = DialogResult.Cancel;
         private void btnOK_Click(object sender, EventArgs e)
@@ -205,7 +204,7 @@
-                            string s = ex.Message;
                     else //Native
@@ -225,9 +224,21 @@
-					MessageBox.Show(this, string.Format(Strings.FormLogin.ConnectionFailedError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+                    string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
+					MessageBox.Show(this, string.Format(Strings.FormLogin.ConnectionFailedError, msg), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+        private void UpdateLoginControl()
+            if (rdHttp.Checked)
+                _selectedIndex = 0;
+            else
+                _selectedIndex = 1;
+            SetLoginControl((Control)_controls[_selectedIndex]);
+            _controls[_selectedIndex].UpdateLoginStatus();
Modified: sandbox/maestro-2.5/Maestro.Login/Maestro.Login.csproj
--- sandbox/maestro-2.5/Maestro.Login/Maestro.Login.csproj	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/Maestro.Login/Maestro.Login.csproj	2010-06-15 10:34:05 UTC (rev 4942)
@@ -87,6 +87,10 @@
     </EmbeddedResource>
   </ItemGroup>
   <ItemGroup>
+    <ProjectReference Include="..\Maestro.Shared.UI\Maestro.Shared.UI.csproj">
+      <Project>{CFD19053-2172-41D3-8460-0FD2123A1E88}</Project>
+      <Name>Maestro.Shared.UI</Name>
+    </ProjectReference>
     <ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI\OSGeo.MapGuide.MaestroAPI.csproj">
       <Project>{80FA3158-8B5F-48D1-A393-0378AFE48A7E}</Project>
       <Name>OSGeo.MapGuide.MaestroAPI</Name>
Added: sandbox/maestro-2.5/Maestro.Shared.UI/DialogFactory.cs
--- sandbox/maestro-2.5/Maestro.Shared.UI/DialogFactory.cs	                        (rev 0)
+++ sandbox/maestro-2.5/Maestro.Shared.UI/DialogFactory.cs	2010-06-15 10:34:05 UTC (rev 4942)
@@ -0,0 +1,87 @@
+using System;
+using System.Collections.Generic;
+using System.Text;
+using System.Windows.Forms;
+using System.IO;
+namespace Maestro.Shared.UI
+    /// <summary>
+    /// Helper class to overcome some of the bad default values assigned to the <see cref="OpenFileDialog"/> and <see cref="SaveFileDialog"/>
+    /// It is preferable to use this class instead of creating the <see cref="OpenFileDialog"/> or <see cref="SaveFileDialog"/> yourself.
+    /// </summary>
+    public static class DialogFactory
+        static string _lastOpenDir;
+        static string _lastSaveDir;
+        /// <summary>
+        /// Creates an <see cref="OpenFileDialog"/> with sensible default values
+        /// </summary>
+        /// <returns></returns>
+        public static OpenFileDialog OpenFile()
+            var dlg = new OpenFileDialog();
+            // I guess someone at MSFT must've went over the wrong side of the ballmer peak
+            // because RestoreDirectory should not default to false. Defaulting to false
+            // means that attempting to load files/assemblies using relative paths
+            // will most likely fail because for some reason, using this dialog will
+            // actually modify the current working directory!
+            // So we set this to true, but to preserve the existing behaviour, we store
+            // the directory of the selected file in a static variable on dialog close (OK),
+            // and assign this dir to the InitialDirectory property on each dialog request,
+            // effectively replicating the old behaviour (w/o the nasty side effects)
+            // Or maybe my usage scenario does not qualify as a common use case.
+            if (Directory.Exists(_lastOpenDir))
+                dlg.InitialDirectory = _lastOpenDir;
+            dlg.FileOk += (sender, e) =>
+                _lastOpenDir = Path.GetDirectoryName(dlg.FileName);
+            return dlg;
+        /// <summary>
+        /// Creates a <see cref="SaveFileDialog"/> with sensible default values
+        /// </summary>
+        public static SaveFileDialog SaveFile()
+            var dlg = new SaveFileDialog();
+            if (Directory.Exists(_lastSaveDir))
+                dlg.InitialDirectory = _lastSaveDir;
+                _lastSaveDir = Path.GetDirectoryName(dlg.FileName);
+            return dlg;
Modified: sandbox/maestro-2.5/Maestro.Shared.UI/Maestro.Shared.UI.csproj
--- sandbox/maestro-2.5/Maestro.Shared.UI/Maestro.Shared.UI.csproj	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/Maestro.Shared.UI/Maestro.Shared.UI.csproj	2010-06-15 10:34:05 UTC (rev 4942)
@@ -3,7 +3,7 @@
   <PropertyGroup>
     <ProjectGuid>{CFD19053-2172-41D3-8460-0FD2123A1E88}</ProjectGuid>
@@ -44,6 +44,7 @@
     <Compile Include="CollapsiblePanel.designer.cs">
       <DependentUpon>CollapsiblePanel.cs</DependentUpon>
     </Compile>
+    <Compile Include="DialogFactory.cs" />
     <Compile Include="Properties\AssemblyInfo.cs" />
     <Compile Include="Properties\Resources.Designer.cs">
       <AutoGen>True</AutoGen>
Added: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Exceptions/NestedExceptionMessageProcessor.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Exceptions/NestedExceptionMessageProcessor.cs	                        (rev 0)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Exceptions/NestedExceptionMessageProcessor.cs	2010-06-15 10:34:05 UTC (rev 4942)
@@ -0,0 +1,53 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Text;
+namespace OSGeo.MapGuide.MaestroAPI.Exceptions
+    /// <summary>
+    /// Helper class to process exception messages for exceptions that may contain one or more nested inner exceptions
+    /// </summary>
+    public static class NestedExceptionMessageProcessor
+        /// <summary>
+        /// Returns a formatted string containing the main exception message and all messages within the <see cref="InnerException"/> properties
+        /// </summary>
+        /// <param name="error"></param>
+        public static string GetFullMessage(Exception error)
+            if (error == null)
+                return string.Empty;
+            Exception ex = error;
+            string innerPrefix = Environment.NewLine + "\t";
+            StringBuilder sb = new StringBuilder();
+            while (ex.InnerException != null)
+                sb.Append(innerPrefix + ex.Message);
+                ex = ex.InnerException;
+            return sb.ToString();
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj	2010-06-15 10:34:05 UTC (rev 4942)
@@ -166,6 +166,7 @@
     <Compile Include="Commands\ICommand.cs" />
     <Compile Include="Exceptions\CustomPropertyNotFoundException.cs" />
     <Compile Include="Exceptions\MaestroException.cs" />
+    <Compile Include="Exceptions\NestedExceptionMessageProcessor.cs" />
     <Compile Include="Exceptions\ResourceConversionException.cs" />
     <Compile Include="Exceptions\SerializationException.cs" />
     <Compile Include="Exceptions\UnsupportedResourceTypeException.cs" />
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs	2010-06-14 22:50:23 UTC (rev 4941)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs	2010-06-15 10:34:05 UTC (rev 4942)
@@ -128,7 +128,7 @@
                 catch { }
                 if (!ok) //Report original error
-                    throw new Exception("Failed to connect, perhaps session is expired?\nExtended error info: " + ex.Message, ex);
+                    throw new Exception("Failed to connect, perhaps session is expired?\nExtended error info: " + NestedExceptionMessageProcessor.GetFullMessage(ex), ex);
             if (!allowUntestedVersion)
                 ValidateVersion(sv);
@@ -156,7 +156,7 @@
-                throw new Exception("Failed to connect, please check network connection and login information.\nExtended error info: " + ex.Message, ex);
+                throw new Exception("Failed to connect, please check network connection and login information.\nExtended error info: " + NestedExceptionMessageProcessor.GetFullMessage(ex), ex);
@@ -266,27 +266,29 @@
 			catch (WebException wex)
-				if (wex.Response != null)
-					try
-						string result = "";
-						using(System.IO.MemoryStream ms = new System.IO.MemoryStream())
-							Utility.CopyStream(wex.Response.GetResponseStream(), ms);
-							result = System.Text.Encoding.UTF8.GetString(ms.ToArray(), 0, (int)ms.Length);
+                if (wex.Response != null)
+                    try
+                        string result = "";
+                        using (System.IO.MemoryStream ms = new System.IO.MemoryStream())
+                            Utility.CopyStream(wex.Response.GetResponseStream(), ms);
+                            result = System.Text.Encoding.UTF8.GetString(ms.ToArray(), 0, (int)ms.Length);
-						if (result.ToLower().IndexOf("<body>") > 0)
-							result = result.Substring(result.ToLower().IndexOf("<body>") + 6);
+                        if (result.ToLower().IndexOf("<body>") > 0)
+                            result = result.Substring(result.ToLower().IndexOf("<body>") + 6);
-						if (result.ToLower().IndexOf("</body>") > 0)
-							result = result.Substring(0, result.ToLower().IndexOf("</body>"));
+                        if (result.ToLower().IndexOf("</body>") > 0)
+                            result = result.Substring(0, result.ToLower().IndexOf("</body>"));
-						return result;
-					catch
+                        return result;
+                    catch
 				if (wex.InnerException == null)
 					return wex.Message;
@@ -295,7 +297,7 @@
-				return ex.Message;
+                return NestedExceptionMessageProcessor.GetFullMessage(ex);
@@ -317,27 +319,29 @@
-					try
+                    try
-						return result;
-					catch
+                        return result;
+                    catch
 					return wex.Message;
@@ -346,7 +350,7 @@
@@ -1185,7 +1189,7 @@
 					if (!ok)
 						if (throwException) //Report original error
 						else
 							return false;
More information about the mapguide-commits mailing list
