[mapguide-commits] r4963 - trunk/Installer/livedvd
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Jun 21 17:44:12 EDT 2010
Author: trevorwekel
Date: 2010-06-21 21:44:12 +0000 (Mon, 21 Jun 2010)
New Revision: 4963
Added:
   trunk/Installer/livedvd/install_mapguide.sh
Removed:
   trunk/Installer/livedvd/mglivedvdinst.sh
Ticket #1295 Improve build scripts for 2.2 release cycle
- Add preliminary LiveDVD install script
Added: trunk/Installer/livedvd/install_mapguide.sh
--- trunk/Installer/livedvd/install_mapguide.sh	                        (rev 0)
+++ trunk/Installer/livedvd/install_mapguide.sh	2010-06-21 21:44:12 UTC (rev 4963)
@@ -0,0 +1,98 @@
+#!/bin/bash
+#  Copyright (C) 2010 by Autodesk, Inc.
+#  This library is free software; you can redistribute it and/or
+#  modify it under the terms of version 2.1 of the GNU Lesser
+#  General Public License as published by the Free Software Foundation.
+#  This library is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+#  Lesser General Public License for more details.
+#  You should have received a copy of the GNU Lesser General Public
+#  License along with this library; if not, write to the Free Software
+#  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+# About:
+# This script will install MapGuide
+# Running:
+# sudo ./install_mapguide.sh
+TEMPDIR=/tmp/build_mapguide
+URL="http://download.osgeo.org/mapguide/releases/2.2.0/Beta"
+FDOVER=3.5.0-5460_i386
+MGVER=2.2.0-4898_i386
+MAESTROVER=2.0.0-4650_i386
+# Create temporary download directory
+mkdir -p ${TEMPDIR}
+pushd ${TEMPDIR}
+# Install required packages
+apt-get -y install libexpat1 libssl0.9.8 odbcinst1debian1 unixodbc libcurl3 libxslt1.1
+apt-get -y install mono-runtime libmono-winforms2.0-cil
+# Resolve CentOS 5.4 / Ubuntu 9.10 shared lib differences with symlinks
+if [ ! -e /lib/libcrypto.so.6 ]; then
+  ln -s /lib/libcrypto.so.0.9.8 /lib/libcrypto.so.6
+fi
+if [ ! -e /lib/libssl.so.6 ]; then
+  ln -s /lib/libssl.so.0.9.8 /lib/libssl.so.6
+fi
+if [ ! -e /lib/libexpat.so.0 ]; then
+  ln -s /lib/libexpat.so.1.5.2 /lib/libexpat.so.0
+fi
+if [ ! -e /usr/lib/libldap-2.3.so.0 ]; then
+  ln -s /usr/lib/libldap-2.4.so.2 /usr/lib/libldap-2.3.so.0
+fi
+if [ ! -e /usr/lib/liblber-2.3.so.0 ]; then
+  ln -s /usr/lib/liblber-2.4.so.2 /usr/lib/liblber-2.3.so.0
+fi
+if [ ! -d /var/lock/mgserver ]; then
+  mkdir /var/lock/mgserver
+fi
+# Download Ubuntu packages for FDO
+for file in core gdal kingoracle ogr postgis sdf shp sqlite wfs wms
+do
+  wget -N ${URL}/fdo-${file}_${FDOVER}.deb
+done
+# Download Ubuntu packages for MapGuide
+for file in common server webextensions httpd
+do
+  wget -N ${URL}/mapguideopensource-${file}_${MGVER}.deb
+done
+# Download Ubuntu package for Maestro
+wget -N ${URL}/mapguideopensource-maestro_${MAESTROVER}.deb
+# Install Ubuntu packages for FDO
+do
+  dpkg -E -G --install fdo-${file}_${FDOVER}.deb
+done
+# Install Ubuntu packages for MapGuide
+do
+  dpkg -E -G --install mapguideopensource-${file}_${MGVER}.deb
+done
+# Install Ubuntu Package for Maestro
+dpkg -E -G --install mapguideopensource-maestro_${MAESTROVER}.deb
+popd
Property changes on: trunk/Installer/livedvd/install_mapguide.sh
___________________________________________________________________
Added: svn:executable
Deleted: trunk/Installer/livedvd/mglivedvdinst.sh
--- trunk/Installer/livedvd/mglivedvdinst.sh	2010-06-18 20:34:19 UTC (rev 4962)
+++ trunk/Installer/livedvd/mglivedvdinst.sh	2010-06-21 21:44:12 UTC (rev 4963)
@@ -1,90 +0,0 @@
-#!/bin/bash
-#  Copyright (C) 2010 by Autodesk, Inc.
-#  This library is free software; you can redistribute it and/or
-#  modify it under the terms of version 2.1 of the GNU Lesser
-#  General Public License as published by the Free Software Foundation.
-#  This library is distributed in the hope that it will be useful,
-#  but WITHOUT ANY WARRANTY; without even the implied warranty of
-#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-#  Lesser General Public License for more details.
-#  You should have received a copy of the GNU Lesser General Public
-#  License along with this library; if not, write to the Free Software
-#  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
-TEMPDIR=/tmp/build_mapguide
-URL="http://download.osgeo.org/mapguide/releases/2.2.0/Beta"
-FDOVER=3.5.0-5460_i386
-MGVER=2.2.0-4898_i386
-MAESTROVER=2.0.0-4650_i386
-# Create temporary download directory
-mkdir -p ${TEMPDIR}
-pushd ${TEMPDIR}
-# Install required packages
-apt-get -y install libexpat1 libssl0.9.8 odbcinst1debian1 unixodbc libcurl3 libxslt1.1
-apt-get -y install mono-runtime libmono-winforms2.0-cil
-# Resolve CentOS 5.4 / Ubuntu 9.10 shared lib differences with symlinks
-if [ ! -e /lib/libcrypto.so.6 ]; then
-  ln -s /lib/libcrypto.so.0.9.8 /lib/libcrypto.so.6
-fi
-if [ ! -e /lib/libssl.so.6 ]; then
-  ln -s /lib/libssl.so.0.9.8 /lib/libssl.so.6
-fi
-if [ ! -e /lib/libexpat.so.0 ]; then
-  ln -s /lib/libexpat.so.1.5.2 /lib/libexpat.so.0
-fi
-if [ ! -e /usr/lib/libldap-2.3.so.0 ]; then
-  ln -s /usr/lib/libldap-2.4.so.2 /usr/lib/libldap-2.3.so.0
-fi
-if [ ! -e /usr/lib/liblber-2.3.so.0 ]; then
-  ln -s /usr/lib/liblber-2.4.so.2 /usr/lib/liblber-2.3.so.0
-fi
-if [ ! -d /var/lock/mgserver ]; then
-  mkdir /var/lock/mgserver
-fi
-# Download Ubuntu packages for FDO
-for file in core gdal kingoracle ogr postgis sdf shp sqlite wfs wms
-do
-  wget -N ${URL}/fdo-${file}_${FDOVER}.deb
-done
-# Download Ubuntu packages for MapGuide
-for file in common server webextensions httpd
-do
-  wget -N ${URL}/mapguideopensource-${file}_${MGVER}.deb
-done
-# Download Ubuntu package for Maestro
-wget -N ${URL}/mapguideopensource-maestro_${MAESTROVER}.deb
-# Install Ubuntu packages for FDO
-do
-  dpkg -E -G --install fdo-${file}_${FDOVER}.deb
-done
-# Install Ubuntu packages for MapGuide
-do
-  dpkg -E -G --install mapguideopensource-${file}_${MGVER}.deb
-done
-# Install Ubuntu Package for Maestro
-dpkg -E -G --install mapguideopensource-maestro_${MAESTROVER}.deb
-popd
More information about the mapguide-commits mailing list
