[mapguide-commits] r4965 - trunk/MgDev
svn_mapguide at osgeo.org
Mon Jun 21 17:50:07 EDT 2010
Author: trevorwekel
Date: 2010-06-21 21:50:07 +0000 (Mon, 21 Jun 2010)
New Revision: 4965
Added:
trunk/MgDev/build64.bat
Ticket #1295 Improve build scripts for 2.2 release cycle
- Add preliminary build/install work for 64 bit Windows
Added: trunk/MgDev/build64.bat
--- trunk/MgDev/build64.bat (rev 0)
+++ trunk/MgDev/build64.bat 2010-06-21 21:50:07 UTC (rev 4965)
@@ -0,0 +1,525 @@
+ at echo off
+rem MapGuide build script for windows
+rem
+rem Author: Jackie Ng (jumpinjackie at gmail.com)
+rem
+rem This script will build all the MapGuide components, if the output path is specified
+rem it will also copy all binaries to the output path. Otherwise it will use the default
+rem value of MG_OUTPUT defined in this file
+rem
+rem Before you start, please make sure you have done the following:
+rem
+rem 1) Build the FDO source and place the files in \Oem\FDO (or alternatively download and extract the latest FDO 3.4 binary sdk)
+rem with the following structure:
+rem - Bin\%CONFIG% (where %CONFIG% is debug or release)
+rem - Inc
+rem - Lib
+rem
+rem 2) Download and install the following:
+rem - Java SDK (http://java.sun.com)
+rem - ant (http://ant.apache.org)
+rem - doxygen (http://www.doxygen.org)
+rem
+rem 3) Change the values of JAVA_HOME, ANT_HOME and DOXYGEN to match the paths of your Java SDK, Apache Ant and Doxygen installations respectively
+rem
+rem For a "cleaner" build experience, run this script from an exported copy of the
+rem MapGuide source code (ie. without subversion folders).
+rem
+rem Usage:
+rem
+rem build.bat [-h]
+rem [-v]
+rem [-c=BuildType]
+rem [-w=Component]
+rem [-a=Action]
+rem [-o=OutputDirectory]
+rem
+rem BuildType: Release(default), Debug, Release64, Debug64
+rem Component: all(default), oem, server, web, doc, common
+rem Action: build(default), install, clean
+rem OutputDirectory: The directory where files will be copied to if -a=install, if -o=default or -o=def then
+rem files will be copied to %MG_DEFAULT_INSTALLDIR%
+rem
+rem Please note that -a=install does nothing if -w=oem
+rem ==================================================
+rem Top-level vars
+SET OLDPATH=%PATH%
+SET TYPEACTION=build
+SET TYPEBUILD=Release64
+SET CONFIGURATION=Release
+SET PLATFORM=x64
+SET TYPECOMPONENT=all
+rem MapGuide vars
+SET MG_DEV=%CD%
+SET MG_OEM=%MG_DEV%\Oem
+SET MG_COMMON=%MG_DEV%\Common
+SET MG_SERVER=%MG_DEV%\Server
+SET MG_WEB=%MG_DEV%\Web
+SET MG_WEB_SRC=%MG_WEB%\src
+SET MG_WEB_BIN=%MG_WEB%\bin
+SET MG_UNIT_TEST=%MG_DEV%\UnitTest
+SET MG_FUSION=%MG_OEM%\Fusion
+SET MG_DOC=%MG_DEV%\Doc
+SET MG_DOC_OUTPUT=%MG_DOC%\MgOpensource_WebAPIReference
+SET MG_DOC_DEVGUIDE_SAMPLES=%MG_DOC%\samples\phpsamples
+SET MG_BUILD_TEMP=%MG_DEV%\BuildTemp
+SET MG_OUTPUT=%MG_DEV%\%TYPEBUILD%
+SET MG_OUTPUT_SERVER=%MG_OUTPUT%\Server
+SET MG_OUTPUT_WEB=%MG_OUTPUT%\Web
+SET MG_OUTPUT_CSMAP=%MG_OUTPUT%\CS-Map
+SET MG_BUILD_COMPONENT=
+SET MG_DEFAULT_INSTALLDIR=C:\Program Files\MapGuideOpenSource2.0
+SET MG_ERROR=0
+rem Extra tool paths
+rem
+rem Your paths may be different, adjust accordingly or
+rem set the appropriate environment variables before
+rem running
+IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files\Java\jdk1.5.0_18
+IF "%DOXYGEN%" == "" SET DOXYGEN=%MG_DEV%\BuildTools\doxygen
+IF "%GNUWIN32%" == "" SET GNUWIN32=C:\Program Files\GnuWin32\bin
+IF "%SEVENZ%" == "" SET SEVENZ=%MG_DEV%\BuildTools\WebTools\7-Zip
+IF "%ANT_HOME%" == "" SET ANT_HOME=%MG_DEV%\BuildTools\apache-ant-1.7.1
+SET PATH=%PATH%;%DOXYGEN%;%GNUWIN32%;%SEVENZ%;%ANT_HOME%\bin
+rem MSBuild Settings
+rem If the NUMBER_OF_PROCESSORS environment variable is wrong for any reason. Change this value.
+rem Multi core builds seem to be broken
+rem SET CPU_CORES=%NUMBER_OF_PROCESSORS%
+SET CPU_CORES=1
+rem Uncomment the line below to enable msbuild logging
+rem SET MSBUILD_LOG=/l:FileLogger,Microsoft.Build.Engine;logfile=Build.log;verbosity=diagnostic
+SET MSBUILD_VERBOSITY=/v:q
+rem Command aliases
+rem SET XCOPY=xcopy /E /Y /I /F
+SET XCOPY=xcopy /E /Y /I /Q
+SET XCOPY_SINGLE=xcopy /Y /I /Q
+SET MSBUILD=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%CONFIGURATION% /p:Platform=%PLATFORM% %MSBUILD_VERBOSITY% %MSBUILD_LOG%
+SET MSBUILD_CLEAN=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%CONFIGURATION% /p:Platform=%PLATFORM% /t:Clean %MSBUILD_VERBOSITY%
+SET ANT=ant
+rem Parameter Handling
+:study_params
+if (%1)==() goto pre_build_check
+if "%1"=="-help" goto help_show
+if "%1"=="-h" goto help_show
+if "%1"=="-c" goto get_conf
+if "%1"=="-config" goto get_conf
+if "%1"=="-a" goto get_action
+if "%1"=="-action" goto get_action
+if "%1"=="-w" goto get_component
+if "%1"=="-with" goto get_component
+if "%1"=="-v" goto get_verbose
+if "%1"=="-o" goto get_output
+goto custom_error
+:next_param
+shift
+shift
+goto study_params
+:get_verbose
+SET MSBUILD_VERBOSITY=/v:d
+goto next_param
+:get_output
+SET MG_OUTPUT=%2
+if "%2" == "default" SET MG_OUTPUT=%MG_DEFAULT_INSTALLDIR%
+if "%2" == "def" SET MG_OUTPUT=%MG_DEFAULT_INSTALLDIR%
+goto next_param
+:get_conf
+SET TYPEBUILD=%2
+SET CONFIGURATION=invalid
+SET PLATFORM=invalid
+IF "%2"=="Release" (
+SET PLATFORM=Win32
+IF "%2"=="Release64" (
+SET PLATFORM=x64
+if "%2"=="Debug" (
+SET CONFIGURATION=Debug
+SET PLATFORM=Win32
+if "%2"=="Debug64" (
+SET PLATFORM=x64
+if NOT %CONFIGURATION%=="invalid" goto next_param
+SET ERRORMSG=Unrecognised configuration: %2
+goto custom_error
+:get_action
+SET TYPEACTION=%2
+if "%2"=="build" goto next_param
+if "%2"=="clean" goto next_param
+if "%2"=="install" goto next_param
+SET ERRORMSG=Unrecognised action: %2
+goto custom_error
+:get_component
+SET TYPECOMPONENT=%2
+if "%2"=="oem" goto next_param
+if "%2"=="common" goto next_param
+if "%2"=="server" goto next_param
+if "%2"=="web" goto next_param
+if "%2"=="doc" goto next_param
+if "%2"=="all" goto next_param
+if "%2"=="allnodoc" goto next_param
+SET ERRORMSG=Unrecognised component: %2
+goto custom_error
+rem Check Environment Vars
+:pre_build_check
+:check_java
+if exist "%JAVA_HOME%" goto check_ant
+SET ERRORMSG=Unable to find java sdk installation. Please install the java sdk and set the JAVA_HOME environment variable
+goto custom_error_no_help
+:check_ant
+if exist "%ANT_HOME%" goto check_fdo
+SET ERRORMSG=Unable to find Apache ant installation. Please install apache ant and set the ANT_HOME environment variable
+:check_fdo
+:check_fdo_bin
+if exist "%MG_OEM%\FDO\Bin\%TYPEBUILD%" goto check_fdo_inc
+SET ERRORMSG=Unable to find FDO binaries. Copy the FDO binaries %MG_OEM%\FDO\Bin\%TYPEBUILD%
+:check_fdo_inc
+if exist "%MG_OEM%\FDO\Bin\%TYPEBUILD%" goto check_fdo_lib
+SET ERRORMSG=Unable to find FDO headers. Copy the FDO headers into %MG_OEM%\Inc
+:check_fdo_lib
+if exist "%MG_OEM%\FDO\Bin\%TYPEBUILD%" goto start_build
+SET ERRORMSG=Unable to find FDO lib files. Copy the FDO lib files into %MG_OEM%\Lib
+:start_build
+echo ===================================================
+echo Configuration is [%TYPEBUILD%, "%CONFIGURATION%|%PLATFORM%"]
+echo Action is [%TYPEACTION%] on [%TYPECOMPONENT%]
+echo Deployment Directory for Server: %MG_OUTPUT_SERVER%
+echo Deployment Directory for Web: %MG_OUTPUT_WEB%
+echo CPU cores: %CPU_CORES%
+if "%TYPEACTION%"=="build" goto build
+if "%TYPEACTION%"=="clean" goto clean
+if "%TYPEACTION%"=="install" goto install
+:clean
+if "%TYPECOMPONENT%"=="oem" goto clean_oem
+if "%TYPECOMPONENT%"=="common" goto clean_common
+if "%TYPECOMPONENT%"=="server" goto clean_server
+if "%TYPECOMPONENT%"=="web" goto clean_web
+if "%TYPECOMPONENT%"=="doc" goto clean_doc
+:clean_oem
+echo [clean]: Clean Oem
+%MSBUILD_CLEAN% %MG_OEM%\Oem.sln
+echo [clean]: Clean Oem - CS-Map
+%MSBUILD_CLEAN% %MG_OEM%\CSMap\OpenSource.sln
+if not "%TYPECOMPONENT%"=="all" goto quit
+:clean_common
+echo [clean]: Clean Common
+%MSBUILD_CLEAN% %MG_COMMON%\Common.sln
+:clean_server
+echo [clean]: Clean Server
+%MSBUILD_CLEAN% %MG_SERVER%\Server.sln
+:clean_web
+echo [clean]: Clean Web
+%MSBUILD_CLEAN% %MG_WEB_SRC%\WebTier.sln
+echo [clean]: Clean fusion
+%ANT% clean -f %MG_OEM%\fusion\build.xml
+:clean_doc
+echo [clean]: Clean Doc
+if exist %MG_DOC_OUTPUT% rd /S /Q %MG_DOC_OUTPUT%
+goto quit
+rem =======================================================
+rem Build Targets.... the all targets just carry on
+:build
+if "%TYPECOMPONENT%"=="oem" goto build_oem
+if "%TYPECOMPONENT%"=="common" goto build_common
+if "%TYPECOMPONENT%"=="server" goto build_server
+if "%TYPECOMPONENT%"=="web" goto build_web
+if "%TYPECOMPONENT%"=="doc" goto build_doc
+if "%TYPECOMPONENT%"=="all" goto build_oem
+if "%TYPECOMPONENT%"=="allnodoc" goto build_oem
+SET ERRORMSG=Unrecognised component: %TYPECOMPONENT%
+goto custom_error
+:build_oem
+echo [build]: Building Oem
+%MSBUILD% %MG_OEM%\Oem.sln
+if "%errorlevel%"=="1" goto error
+rem CsMap is not in Oem.sln, so we need to build that separately
+echo [build]: Building Oem - CSMap
+%MSBUILD% %MG_OEM%\CsMap\OpenSource.sln
+if "%TYPECOMPONENT%"=="oem" goto quit
+if "%TYPECOMPONENT%"=="common" goto quit
+if "%TYPECOMPONENT%"=="server" goto quit
+if "%TYPECOMPONENT%"=="web" goto quit
+if "%TYPECOMPONENT%"=="doc" goto quit
+:build_common
+echo [build]: Building Common
+%MSBUILD% %MG_COMMON%\Common.sln
+:build_server
+echo [build]: Building Server
+%MSBUILD% %MG_SERVER%\Server.sln
+:build_web
+echo [build]: Building Web Tier
+%MSBUILD% %MG_WEB_SRC%\WebTier.sln
+if "%TYPECOMPONENT%"=="allnodoc" goto quit
+rem this is left out with component allnodoc
+:build_doc
+echo [build]: Building Doc
+pushd %MG_DOC%
+call MgOpenSource_run_doxygen.bat
+popd
+goto quit
+rem INSTALL Targets.... the all targets just carry on
+:install
+if "%TYPECOMPONENT%"=="all" goto install_server
+if "%TYPECOMPONENT%"=="allnodoc" goto install_server
+if "%TYPECOMPONENT%"=="server" goto install_server
+if "%TYPECOMPONENT%"=="web" goto install_web
+if "%TYPECOMPONENT%"=="doc" goto install_doc
+goto custom_error
+:install_server
+echo [install]: Server
+echo [install]: Server - Binaries
+%XCOPY_SINGLE% "%MG_SERVER%\bin\%TYPEBUILD%" "%MG_OUTPUT_SERVER%\bin" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Server - FDO
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\FDO" "%MG_OUTPUT_SERVER%\FDO" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Server - Logs
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Logs" "%MG_OUTPUT_SERVER%\Logs" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Server - Packages
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Packages" "%MG_OUTPUT_SERVER%\Packages" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Server - Repositories
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Repositories" "%MG_OUTPUT_SERVER%\Repositories" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Server - Resources
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Resources" "%MG_OUTPUT_SERVER%\Resources" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Server - Schema
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Schema" "%MG_OUTPUT_SERVER%\Schema" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Server - Temp
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\Temp" "%MG_OUTPUT_SERVER%\Temp" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Server - WFS
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\wfs" "%MG_OUTPUT_SERVER%\wfs" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Server - WMS
+%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\wms" "%MG_OUTPUT_SERVER%\wms" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Server - DBXML
+copy /Y "%MG_OEM%\dbxml-2.3.10\db-4.5.20\build_windows\%TYPEBUILD%\*.exe" "%MG_OUTPUT_SERVER%\bin"
+copy /Y "%MG_OEM%\dbxml-2.3.10\bin64\*.exe" "%MG_OUTPUT_SERVER%\bin"
+echo [install]: Server - RepositoryAdmin
+%XCOPY% "%MG_SERVER%\RepositoryAdmin" "%MG_OUTPUT_SERVER%\RepositoryAdmin" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: CsMap Dictionaries
+%XCOPY% "%MG_OEM%\CsMap\Dictionaries" "%MG_OUTPUT_CSMAP%\Dictionaries" /EXCLUDE:svn_excludes.txt+csmap_excludes.txt+%CONFIGURATION%_excludes.txt
+:install_web
+echo [install]: web Tier
+echo [install]: Web Tier - localized
+%XCOPY% "%MG_WEB_SRC%\localized" "%MG_OUTPUT_WEB%\www\localized" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - mapadmin
+%XCOPY% "%MG_WEB_SRC%\mapadmin" "%MG_OUTPUT_WEB%\www\mapadmin" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - mapagent
+%XCOPY% "%MG_WEB_SRC%\mapagent64" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:svn_excludes.txt+mapagent_excludes.txt+%CONFIGURATION%_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - MapGuide API unmanaged binaries
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+java_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - mapagent test forms
+%XCOPY% "%MG_UNIT_TEST%\WebTier\MapAgent\MapAgentForms" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - stdicons
+%XCOPY% "%MG_WEB_SRC%\stdicons" "%MG_OUTPUT_WEB%\www\stdicons" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - viewerfiles
+%XCOPY% "%MG_WEB_SRC%\viewerfiles" "%MG_OUTPUT_WEB%\www\viewerfiles" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - schemareport
+%XCOPY% "%MG_WEB_SRC%\schemareport" "%MG_OUTPUT_WEB%\www\schemareport" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - webconfig.ini
+copy /Y "%MG_WEB_SRC%\webconfig.ini" "%MG_OUTPUT_WEB%\www"
+echo [install]: Web Tier - mapviewerphp
+%XCOPY% "%MG_WEB_SRC%\mapviewerphp" "%MG_OUTPUT_WEB%\www\mapviewerphp" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - Tomcat - MapGuide API unmanaged binaries
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Tomcat\bin"/EXCLUDE:java_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - php - MapGuide API unmanaged binaries
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php"/EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - php ext - MapGuide API unmanaged binaries
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php\ext" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - mapviewernet
+%XCOPY% "%MG_WEB_SRC%\mapviewernet" "%MG_OUTPUT_WEB%\www\mapviewernet" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - mapviewernet - MapGuide API unmanaged binaries
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapviewernet\bin" /EXCLUDE:dotnet_excludes.txt+%CONFIGURATION%_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - mapviewerjava
+%XCOPY% "%MG_WEB_SRC%\mapviewerjava" "%MG_OUTPUT_WEB%\www\mapviewerjava" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - mapviewerjava - WEB-INF
+%XCOPY% "%MG_WEB_SRC%\WEB-INF" "%MG_OUTPUT_WEB%\www\WEB-INF" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - fusion templates
+%XCOPY% "%MG_OEM%\fusionMG" "%MG_OUTPUT_WEB%\www\fusion" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Web Tier - Apache module
+if not exist "%MG_OUTPUT_WEB%\Apache2\modules" mkdir "%MG_OUTPUT_WEB%\Apache2\modules"
+%XCOPY% /F "%MG_WEB_SRC%\mapagent\mod_mgmapagent.so" "%MG_OUTPUT_WEB%\Apache2\modules"
+call %ANT% deploy -Ddeploy.home="%MG_OUTPUT_WEB%\www\fusion" -f "%MG_OEM%\fusion\build.xml"
+:install_doc
+echo [install]: Documentation
+%XCOPY% "%MG_DOC_OUTPUT%" "%MG_OUTPUT_WEB%\www\help\webapi" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Developer's Guide Sample Code
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%" "%MG_OUTPUT_WEB%\www\devguide" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [install]: Viewer API documentation
+%XCOPY% "%MG_DOC%\viewerapi" "%MG_OUTPUT_WEB%\www\help\viewerapi" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+goto quit
+:error
+echo [ERROR]: There was an error building the component
+exit /B 1
+:custom_error_no_help
+echo [ERROR]: %ERRORMSG%
+SET ERRORMSG=
+exit /B 1
+:custom_error
+SET ERRORMSG=
+echo Please use the format:
+:help_show
+echo ************************************************************************
+echo build.bat [-h]
+echo [-v]
+echo [-c=BuildType]
+echo [-w=Component]
+echo [-a=Action]
+echo [-o=OutputDirectory]
+echo Help: -h[elp]
+echo Verbose: -v
+echo BuildType: -c[onfig]=Release(default), Debug, Release64, Debug64
+echo Action: -a[ction]=build(default),
+echo install,
+echo clean,
+echo Component: -w[ith]=all(default),
+echo oem,
+echo common,
+echo server,
+echo web,
+echo doc
+:quit
+SET TYPEACTION=
+SET TYPEBUILD=
+SET MG_OUTPUT=
+SET MG_DEV=
+SET MG_INSTALLER=
+SET MG_OEM=
+SET MG_SERVER=
+SET MG_WEB=
+SET MG_WEB_SRC=
+SET MG_WEB_BIN=
+SET MG_UNIT_TEST=
+SET MG_FUSION=
+SET MG_DOC=
+SET MG_DOC_OUTPUT=
+SET MG_ERROR=
+SET MSBUILD_LOG=
+SET XCOPY=
+SET MSBUILD=
+SET PATH=%OLDPATH%
More information about the mapguide-commits
