[mapguide-commits] r4976 - in trunk/Installer/Support/Web/x64: . Php Php/dev Php/ext
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Jun 26 10:06:52 EDT 2010
Author: trevorwekel
Date: 2010-06-26 14:06:52 +0000 (Sat, 26 Jun 2010)
New Revision: 4976
Added:
   trunk/Installer/Support/Web/x64/Php/
   trunk/Installer/Support/Web/x64/Php/INSTALL
   trunk/Installer/Support/Web/x64/Php/LICENSE
   trunk/Installer/Support/Web/x64/Php/NEWS
   trunk/Installer/Support/Web/x64/Php/README.REDIST.BINS
   trunk/Installer/Support/Web/x64/Php/dev/
   trunk/Installer/Support/Web/x64/Php/dev/php5ts.lib
   trunk/Installer/Support/Web/x64/Php/ext/
   trunk/Installer/Support/Web/x64/Php/ext/php_bz2.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_curl.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_exif.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_fileinfo.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_gd2.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_gettext.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_gmp.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_imap.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_intl.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_ldap.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_mbstring.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_mysql.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_mysqli.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_openssl.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_pdo_mysql.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_pdo_odbc.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_pdo_pgsql.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_pdo_sqlite.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_pgsql.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_shmop.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_soap.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_sockets.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_sqlite.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_sqlite3.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_tidy.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_xmlrpc.dll
   trunk/Installer/Support/Web/x64/Php/ext/php_xsl.dll
   trunk/Installer/Support/Web/x64/Php/php-cgi.exe
   trunk/Installer/Support/Web/x64/Php/php-win.exe
   trunk/Installer/Support/Web/x64/Php/php.exe
   trunk/Installer/Support/Web/x64/Php/php.gif
   trunk/Installer/Support/Web/x64/Php/php.ini
   trunk/Installer/Support/Web/x64/Php/php.ini-development
   trunk/Installer/Support/Web/x64/Php/php.ini-production
   trunk/Installer/Support/Web/x64/Php/php5apache2_2.dll
   trunk/Installer/Support/Web/x64/Php/php5apache2_2_filter.dll
   trunk/Installer/Support/Web/x64/Php/php5isapi.dll
   trunk/Installer/Support/Web/x64/Php/php5ts.dll
   trunk/Installer/Support/Web/x64/Php/snapshot
Ticket #1387 Support 64 bit Web Extensions on Windows
Add PHP 5.3.1 64 bit binaries to installer tree.
Added: trunk/Installer/Support/Web/x64/Php/INSTALL
--- trunk/Installer/Support/Web/x64/Php/INSTALL	                        (rev 0)
+++ trunk/Installer/Support/Web/x64/Php/INSTALL	2010-06-26 14:06:52 UTC (rev 4976)
@@ -0,0 +1,2053 @@
+Installing PHP
+     __________________________________________________________________
+   Table of Contents
+   Preface
+   1. General Installation Considerations
+   2. Installation on Unix systems
+        Apache 1.3.x on Unix systems
+        Apache 2.0 on Unix systems
+        Caudium
+        fhttpd related notes
+        Sun, iPlanet and Netscape servers on Sun Solaris
+        CGI and command line setups
+        HP-UX specific installation notes
+        OpenBSD installation notes
+        Solaris specific installation tips
+        Debian GNU/Linux installation notes
+   3. Installation on Mac OS X
+        Using Packages
+        Using the bundled PHP
+        Compiling for OS X Server
+        Compiling for MacOS X Client
+   4. Installation of PECL extensions
+        Introduction to PECL Installations
+        Downloading PECL extensions
+        PECL for Windows users
+        Compiling shared PECL extensions with the pecl command
+        Compiling shared PECL extensions with phpize
+        Compiling PECL extensions statically into PHP
+   5. Problems?
+        Read the FAQ
+        Other problems
+        Bug reports
+   6. Runtime Configuration
+        The configuration file
+        How to change configuration settings
+   7. Installation FAQ
+Preface
+   These installation instructions were generated from the HTML version of
+   the PHP Manual so formatting and linking have been altered. See the
+   online and updated version at: http://php.net/install.unix
+Chapter 1. General Installation Considerations
+   Before starting the installation, first you need to know what do you
+   want to use PHP for. There are three main fields you can use PHP, as
+   described in the What can PHP do? section:
+     * Websites and web applications (server-side scripting)
+     * Command line scripting
+     * Desktop (GUI) applications
+   For the first and most common form, you need three things: PHP itself,
+   a web server and a web browser. You probably already have a web
+   browser, and depending on your operating system setup, you may also
+   have a web server (e.g. Apache on Linux and MacOS X; IIS on Windows).
+   You may also rent webspace at a company. This way, you don't need to
+   set up anything on your own, only write your PHP scripts, upload it to
+   the server you rent, and see the results in your browser.
+   In case of setting up the server and PHP on your own, you have two
+   choices for the method of connecting PHP to the server. For many
+   servers PHP has a direct module interface (also called SAPI). These
+   servers include Apache, Microsoft Internet Information Server, Netscape
+   and iPlanet servers. Many other servers have support for ISAPI, the
+   Microsoft module interface (OmniHTTPd for example). If PHP has no
+   module support for your web server, you can always use it as a CGI or
+   FastCGI processor. This means you set up your server to use the CGI
+   executable of PHP to process all PHP file requests on the server.
+   If you are also interested to use PHP for command line scripting (e.g.
+   write scripts autogenerating some images for you offline, or processing
+   text files depending on some arguments you pass to them), you always
+   need the command line executable. For more information, read the
+   section about writing command line PHP applications. In this case, you
+   need no server and no browser.
+   With PHP you can also write desktop GUI applications using the PHP-GTK
+   extension. This is a completely different approach than writing web
+   pages, as you do not output any HTML, but manage Windows and objects
+   within them. For more information about PHP-GTK, please visit the site
+   dedicated to this extension. PHP-GTK is not included in the official
+   PHP distribution.
+   From now on, this section deals with setting up PHP for web servers on
+   Unix and Windows with server module interfaces and CGI executables. You
+   will also find information on the command line executable in the
+   following sections.
+   PHP source code and binary distributions for Windows can be found at
+   http://www.php.net/downloads.php. We recommend you to choose a mirror
+   nearest to you for downloading the distributions.
+Chapter 2. Installation on Unix systems
+   This section will guide you through the general configuration and
+   installation of PHP on Unix systems. Be sure to investigate any
+   sections specific to your platform or web server before you begin the
+   process.
+   As our manual outlines in the General Installation Considerations
+   section, we are mainly dealing with web centric setups of PHP in this
+   section, although we will cover setting up PHP for command line usage
+   as well.
+   There are several ways to install PHP for the Unix platform, either
+   with a compile and configure process, or through various pre-packaged
+   methods. This documentation is mainly focused around the process of
+   compiling and configuring PHP. Many Unix like systems have some sort of
+   package installation system. This can assist in setting up a standard
+   configuration, but if you need to have a different set of features
+   (such as a secure server, or a different database driver), you may need
+   to build PHP and/or your web server. If you are unfamiliar with
+   building and compiling your own software, it is worth checking to see
+   whether somebody has already built a packaged version of PHP with the
+   features you need.
+   Prerequisite knowledge and software for compiling:
+     * Basic Unix skills (being able to operate "make" and a C compiler)
+     * An ANSI C compiler
+     * flex: Version 2.5.4
+     * bison: Version 1.28 (preferred), 1.35, or 1.75
+     * A web server
+     * Any module specific components (such as gd, pdf libs, etc.)
+   The initial PHP setup and configuration process is controlled by the
+   use of the command line options of the configure script. You could get
+   a list of all available options along with short explanations running
+   ./configure --help. Our manual documents the different options
+   separately. You will find the core options in the appendix, while the
+   different extension specific options are descibed on the reference
+   pages.
+   When PHP is configured, you are ready to build the module and/or
+   executables. The command make should take care of this. If it fails and
+   you can't figure out why, see the Problems section.
+Apache 1.3.x on Unix systems
+   This section contains notes and hints specific to Apache installs of
+   PHP on Unix platforms. We also have instructions and notes for Apache 2
+   on a separate page.
+   You can select arguments to add to the configure on line 10 below from
+   the list of core configure options and from extension specific options
+   described at the respective places in the manual. The version numbers
+   have been omitted here, to ensure the instructions are not incorrect.
+   You will need to replace the 'xxx' here with the correct values from
+   your files.
+   Example 2-1. Installation Instructions (Apache Shared Module Version)
+   for PHP
+1.  gunzip apache_xxx.tar.gz
+2.  tar -xvf apache_xxx.tar
+3.  gunzip php-xxx.tar.gz
+4.  tar -xvf php-xxx.tar
+5.  cd apache_xxx
+6.  ./configure --prefix=/www --enable-module=so
+7.  make
+8.  make install
+9.  cd ../php-xxx
+10. Now, configure your PHP.  This is where you customize your PHP
+    with various options, like which extensions will be enabled.  Do a
+    ./configure --help for a list of available options.  In our example
+    we'll do a simple configure with Apache 1 and MySQL support.  Your
+    path to apxs may differ from our example.
+      ./configure --with-mysql --with-apxs=/www/bin/apxs
+11. make
+12. make install
+    If you decide to change your configure options after installation,
+    you only need to repeat the last three steps. You only need to
+    restart apache for the new module to take effect. A recompile of
+    Apache is not needed.
+    Note that unless told otherwise, 'make install' will also install PEAR,
+    various PHP tools such as phpize, install the PHP CLI, and more.
+13. Setup your php.ini file:
+    PHP will use the built-in default values if no php.ini file was
+    placed in the configuration directory. The default location is
+    /usr/local/lib, if you prefer your php.ini in another location, use
+    --with-config-file-path=/some/path in step 10.
+    The PHP distribution provides two sample php.ini files, you can use them
+    by
+      cp php.ini-development /usr/local/lib/php.ini
+    or
+      cp php.ini-production  /usr/local/lib/php.ini
+    If you choose one of these php.ini files be certain to read the list
+    of changes within, as they affect how PHP behaves.
+14. Edit your httpd.conf to load the PHP module.  The path on the right hand
+    side of the LoadModule statement must point to the path of the PHP
+    module on your system.  The make install from above may have already
+    added this for you, but be sure to check.
+    For PHP 4:
+      LoadModule php4_module libexec/libphp4.so
+    For PHP 5:
+      LoadModule php5_module libexec/libphp5.so
+15. And in the AddModule section of httpd.conf, somewhere under the
+    ClearModuleList, add this:
+    For PHP 4:
+      AddModule mod_php4.c
+    For PHP 5:
+      AddModule mod_php5.c
+16. Tell Apache to parse certain extensions as PHP.  For example,
+    let's have Apache parse the .php extension as PHP.  You could
+    have any extension(s) parse as PHP by simply adding more, with
+    each separated by a space.  We'll add .phtml to demonstrate.
+      AddType application/x-httpd-php .php .phtml
+    It's also common to setup the .phps extension to show highlighted PHP
+    source, this can be done with:
+      AddType application/x-httpd-php-source .phps
+17. Use your normal procedure for starting the Apache server. (You must
+    stop and restart the server, not just cause the server to reload by
+    using a HUP or USR1 signal.)
+   Alternatively, to install PHP as a static object:
+   Example 2-2. Installation Instructions (Static Module Installation for
+   Apache) for PHP
+1.  gunzip -c apache_1.3.x.tar.gz | tar xf -
+2.  cd apache_1.3.x
+3.  ./configure
+4.  cd ..
+5.  gunzip -c php-5.x.y.tar.gz | tar xf -
+6.  cd php-5.x.y
+7.  ./configure --with-mysql --with-apache=../apache_1.3.x
+8.  make
+9.  make install
+10. cd ../apache_1.3.x
+11. ./configure --prefix=/www --activate-module=src/modules/php5/libphp5.a
+    (The above line is correct! Yes, we know libphp5.a does not exist at this
+    stage. It isn't supposed to. It will be created.)
+12. make
+    (you should now have an httpd binary which you can copy to your Apache bin d
+ir if
+    it is your first install then you need to "make install" as well)
+13. cd ../php-5.x.y
+14. cp php.ini-dist /usr/local/lib/php.ini
+15. You can edit /usr/local/lib/php.ini file to set PHP options.
+    Edit your httpd.conf or srm.conf file and add:
+     Note: Replace php-5 by php-4 and php5 by php4 in PHP 4.
+   Depending on your Apache install and Unix variant, there are many
+   possible ways to stop and restart the server. Below are some typical
+   lines used in restarting the server, for different apache/unix
+   installations. You should replace /path/to/ with the path to these
+   applications on your systems.
+   Example 2-3. Example commands for restarting Apache
+1. Several Linux and SysV variants:
+/etc/rc.d/init.d/httpd restart
+2. Using apachectl scripts:
+/path/to/apachectl stop
+/path/to/apachectl start
+3. httpdctl and httpsdctl (Using OpenSSL), similar to apachectl:
+/path/to/httpsdctl stop
+/path/to/httpsdctl start
+4. Using mod_ssl, or another SSL server, you may want to manually
+stop and start:
+/path/to/apachectl startssl
+   The locations of the apachectl and http(s)dctl binaries often vary. If
+   your system has locate or whereis or which commands, these can assist
+   you in finding your server control programs.
+   Different examples of compiling PHP for apache are as follows:
+   ./configure --with-apxs --with-pgsql
+   This will create a libphp5.so (or libphp4.so in PHP 4) shared library
+   that is loaded into Apache using a LoadModule line in Apache's
+   httpd.conf file. The PostgreSQL support is embedded into this library.
+   ./configure --with-apxs --with-pgsql=shared
+   This will create a libphp4.so shared library for Apache, but it will
+   also create a pgsql.so shared library that is loaded into PHP either by
+   using the extension directive in php.ini file or by loading it
+   explicitly in a script using the dl() function.
+   ./configure --with-apache=/path/to/apache_source --with-pgsql
+   This will create a libmodphp5.a library, a mod_php5.c and some
+   accompanying files and copy this into the src/modules/php5 directory in
+   the Apache source tree. Then you compile Apache using
+   --activate-module=src/modules/php5/libphp5.a and the Apache build
+   system will create libphp5.a and link it statically into the httpd
+   binary (replace php5 by php4 in PHP 4). The PostgreSQL support is
+   included directly into this httpd binary, so the final result here is a
+   single httpd binary that includes all of Apache and all of PHP.
+   ./configure --with-apache=/path/to/apache_source --with-pgsql=shared
+   Same as before, except instead of including PostgreSQL support directly
+   into the final httpd you will get a pgsql.so shared library that you
+   can load into PHP from either the php.ini file or directly using dl().
+   When choosing to build PHP in different ways, you should consider the
+   advantages and drawbacks of each method. Building as a shared object
+   will mean that you can compile apache separately, and don't have to
+   recompile everything as you add to, or change, PHP. Building PHP into
+   apache (static method) means that PHP will load and run faster. For
+   more information, see the Apache web page on DSO support.
+     Note: Apache's default httpd.conf currently ships with a section
+     that looks like this:
+User nobody
+Group "#-1"
+     Unless you change that to "Group nogroup" or something like that
+     ("Group daemon" is also very common) PHP will not be able to open
+     files.
+     Note: Make sure you specify the installed version of apxs when using
+     --with-apxs=/path/to/apxs. You must NOT use the apxs version that is
+     in the apache sources but the one that is actually installed on your
+     system.
+Apache 2.0 on Unix systems
+   This section contains notes and hints specific to Apache 2.0 installs
+   of PHP on Unix systems.
+   Warning
+   We do not recommend using a threaded MPM in production with Apache2.
+   Use the prefork MPM instead, or use Apache1. For information on why,
+   read the related FAQ entry on using Apache2 with a threaded MPM
+   You are highly encouraged to take a look at the Apache Documentation to
+   get a basic understanding of the Apache 2.0 Server.
+     PHP and Apache 2.0.x compatibility notes: The following versions of
+     PHP are known to work with the most recent version of Apache 2.0.x:
+     * PHP 4.3.0 or later available at http://www.php.net/downloads.php.
+     * the latest stable development version. Get the source code
+       http://snaps.php.net/php5-latest.tar.gz or download binaries for
+       Windows http://snaps.php.net/win32/php5-win32-latest.zip.
+     * a prerelease version downloadable from http://qa.php.net/.
+     * you have always the option to obtain PHP through SVN.
+     These versions of PHP are compatible to Apache 2.0.40 and later.
+     Apache 2.0 SAPI-support started with PHP 4.2.0. PHP 4.2.3 works with
+     Apache 2.0.39, don't use any other version of Apache with PHP 4.2.3.
+     However, the recommended setup is to use PHP 4.3.0 or later with the
+     most recent version of Apache2.
+     All mentioned versions of PHP will work still with Apache 1.3.x.
+   Download the most recent version of Apache 2.0 and a fitting PHP
+   version from the above mentioned places. This quick guide covers only
+   the basics to get started with Apache 2.0 and PHP. For more information
+   read the Apache Documentation. The version numbers have been omitted
+   here, to ensure the instructions are not incorrect. You will need to
+   replace the 'NN' here with the correct values from your files.
+   Example 2-4. Installation Instructions (Apache 2 Shared Module Version)
+1.  gzip -d httpd-2_0_NN.tar.gz
+2.  tar xvf httpd-2_0_NN.tar
+3.  gunzip php-NN.tar.gz
+4.  tar -xvf php-NN.tar
+5.  cd httpd-2_0_NN
+6.  ./configure --enable-so
+7.  make
+8.  make install
+    Now you have Apache 2.0.NN available under /usr/local/apache2,
+    configured with loadable module support and the standard MPM prefork.
+    To test the installation use your normal procedure for starting
+    the Apache server, e.g.:
+    /usr/local/apache2/bin/apachectl start
+    and stop the server to go on with the configuration for PHP:
+    /usr/local/apache2/bin/apachectl stop.
+9.  cd ../php-NN
+    we'll do a simple configure with Apache 2 and MySQL support.  Your
+    path to apxs may differ, in fact, the binary may even be named apxs2 on
+    your system.
+      ./configure --with-apxs2=/usr/local/apache2/bin/apxs --with-mysql
+11. make
+12. make install
+    cp php.ini-dist /usr/local/lib/php.ini
+    You may edit your .ini file to set PHP options.  If you prefer having
+    php.ini in another location, use --with-config-file-path=/some/path in
+    step 10.
+    If you instead choose php.ini-recommended, be certain to read the list
+    For PHP 4:
+      LoadModule php4_module modules/libphp4.so
+    For PHP 5:
+      LoadModule php5_module modules/libphp5.so
+15. Tell Apache to parse certain extensions as PHP.  For example,
+16. Use your normal procedure for starting the Apache server, e.g.:
+   Following the steps above you will have a running Apache 2.0 with
+   support for PHP as SAPI module. Of course there are many more
+   configuration options available for both, Apache and PHP. For more
+   information use ./configure --help in the corresponding source tree. In
+   case you wish to build a multithreaded version of Apache 2.0 you must
+   overwrite the standard MPM-Module prefork either with worker or
+   perchild. To do so append to your configure line in step 6 above either
+   the option --with-mpm=worker or --with-mpm=perchild. Take care about
+   the consequences and understand what you are doing. For more
+   information read the Apache documentation about the MPM-Modules.
+     Note: If you want to use content negotiation, read the Apache
+     MultiViews FAQ.
+     Note: To build a multithreaded version of Apache your system must
+     support threads. This also implies to build PHP with experimental
+     Zend Thread Safety (ZTS). Therefore not all extensions might be
+     available. The recommended setup is to build Apache with the
+     standard prefork MPM-Module.
+Caudium
+   PHP 4 can be built as a Pike module for the Caudium webserver. Note
+   that this is not supported with PHP 3. Follow the simple instructions
+   below to install PHP 4 for Caudium.
+   Example 2-5. Caudium Installation Instructions
+1.  Make sure you have Caudium installed prior to attempting to
+    install PHP 4. For PHP 4 to work correctly, you will need Pike
+    7.0.268 or newer. For the sake of this example we assume that
+    Caudium is installed in /opt/caudium/server/.
+2.  Change directory to php-x.y.z (where x.y.z is the version number).
+3.  ./configure --with-caudium=/opt/caudium/server
+4.  make
+5.  make install
+6.  Restart Caudium if it's currently running.
+7.  Log into the graphical configuration interface and go to the
+    virtual server where you want to add PHP 4 support.
+8.  Click Add Module and locate and then add the PHP 4 Script Support module.
+9.  If the documentation says that the 'PHP 4 interpreter isn't
+    available', make sure that you restarted the server. If you did
+    check /opt/caudium/logs/debug/default.1 for any errors related to
+    <filename>PHP4.so</filename>. Also make sure that
+    <filename>caudium/server/lib/[pike-version]/PHP4.so</filename>
+    is present.
+10. Configure the PHP Script Support module if needed.
+   You can of course compile your Caudium module with support for the
+   various extensions available in PHP 4. See the reference pages for
+   extension specific configure options.
+     Note: When compiling PHP 4 with MySQL support you must make sure
+     that the normal MySQL client code is used. Otherwise there might be
+     conflicts if your Pike already has MySQL support. You do this by
+     specifying a MySQL install directory the --with-mysql option.
+fhttpd related notes
+   To build PHP as an fhttpd module, answer "yes" to "Build as an fhttpd
+   module?" (the --with-fhttpd=DIR option to configure) and specify the
+   fhttpd source base directory. The default directory is
+   /usr/local/src/fhttpd. If you are running fhttpd, building PHP as a
+   module will give better performance, more control and remote execution
+   capability.
+     Note: Support for fhttpd is no longer available as of PHP 4.3.0.
+Sun, iPlanet and Netscape servers on Sun Solaris
+   This section contains notes and hints specific to Sun Java System Web
+   Server, Sun ONE Web Server, iPlanet and Netscape server installs of PHP
+   on Sun Solaris.
+   From PHP 4.3.3 on you can use PHP scripts with the NSAPI module to
+   generate custom directory listings and error pages. Additional
+   functions for Apache compatibility are also available. For support in
+   current web servers read the note about subrequests.
+   You can find more information about setting up PHP for the Netscape
+   Enterprise Server (NES) here:
+   http://benoit.noss.free.fr/php/install-php4.html
+   To build PHP with Sun JSWS/Sun ONE WS/iPlanet/Netscape web servers,
+   enter the proper install directory for the --with-nsapi=[DIR] option.
+   The default directory is usually /opt/netscape/suitespot/. Please also
+   read /php-xxx-version/sapi/nsapi/nsapi-readme.txt.
+    1. Install the following packages from http://www.sunfreeware.com/ or
+       another download site:
+       autoconf-2.13
+       automake-1.4
+       bison-1_25-sol26-sparc-local
+       flex-2_5_4a-sol26-sparc-local
+       gcc-2_95_2-sol26-sparc-local
+       gzip-1.2.4-sol26-sparc-local
+       m4-1_4-sol26-sparc-local
+       make-3_76_1-sol26-sparc-local
+       mysql-3.23.24-beta (if you want mysql support)
+       perl-5_005_03-sol26-sparc-local
+       tar-1.13 (GNU tar)
+    2. Make sure your path includes the proper directories
+       PATH=.:/usr/local/bin:/usr/sbin:/usr/bin:/usr/ccs/bin and make it
+       available to your system export PATH.
+    3. gunzip php-x.x.x.tar.gz (if you have a .gz dist, otherwise go to
+       4).
+    4. tar xvf php-x.x.x.tar
+    5. Change to your extracted PHP directory: cd ../php-x.x.x
+    6. For the following step, make sure /opt/netscape/suitespot/ is where
+       your netscape server is installed. Otherwise, change to the correct
+       path and run:
+./configure --with-mysql=/usr/local/mysql \
+--with-nsapi=/opt/netscape/suitespot/ \
+--enable-libgcc
+    7. Run make followed by make install.
+   After performing the base install and reading the appropriate readme
+   file, you may need to perform some additional configuration steps.
+   Configuration Instructions for Sun/iPlanet/Netscape. Firstly you may
+   need to add some paths to the LD_LIBRARY_PATH environment for the
+   server to find all the shared libs. This can best done in the start
+   script for your web server. The start script is often located in:
+   /path/to/server/https-servername/start. You may also need to edit the
+   configuration files that are located in:
+   /path/to/server/https-servername/config/.
+    1. Add the following line to mime.types (you can do that by the
+       administration server):
+type=magnus-internal/x-httpd-php exts=php
+    2. Edit magnus.conf (for servers >= 6) or obj.conf (for servers < 6)
+       and add the following, shlib will vary depending on your system, it
+       will be something like /opt/netscape/suitespot/bin/libphp4.so. You
+       should place the following lines after mime types init.
+Init fn="load-modules" funcs="php4_init,php4_execute,php4_auth_trans" shlib="/op
+t/netscape/suitespot/bin/libphp4.so"
+Init fn="php4_init" LateInit="yes" errorString="Failed to initialize PHP!" [php_
+ini="/path/to/php.ini"]
+       (PHP >= 4.3.3) The php_ini parameter is optional but with it you
+       can place your php.ini in your web server config directory.
+    3. Configure the default object in obj.conf (for virtual server
+       classes [version 6.0+] in their vserver.obj.conf):
+<Object name="default">
+.#NOTE this next line should happen after all 'ObjectType' and before all 'AddLo
+g' lines
+Service fn="php4_execute" type="magnus-internal/x-httpd-php" [inikey=value inike
+y=value ...]
+</Object>
+       (PHP >= 4.3.3) As additional parameters you can add some special
+       php.ini-values, for example you can set a
+       docroot="/path/to/docroot" specific to the context php4_execute is
+       called. For boolean ini-keys please use 0/1 as value, not
+       "On","Off",... (this will not work correctly), e.g.
+       zlib.output_compression=1 instead of zlib.output_compression="On"
+    4. This is only needed if you want to configure a directory that only
+       consists of PHP scripts (same like a cgi-bin directory):
+<Object name="x-httpd-php">
+ObjectType fn="force-type" type="magnus-internal/x-httpd-php"
+Service fn=php4_execute [inikey=value inikey=value ...]
+</Object>
+       After that you can configure a directory in the Administration
+       server and assign it the style x-httpd-php. All files in it will
+       get executed as PHP. This is nice to hide PHP usage by renaming
+       files to .html.
+    5. Setup of authentication: PHP authentication cannot be used with any
+       other authentication. ALL AUTHENTICATION IS PASSED TO YOUR PHP
+       SCRIPT. To configure PHP Authentication for the entire server, add
+       the following line to your default object:
+AuthTrans fn=php4_auth_trans
+</Object>
+    6. To use PHP Authentication on a single directory, add the following:
+<Object ppath="d:\path\to\authenticated\dir\*">
+</Object>
+     Note: The stacksize that PHP uses depends on the configuration of
+     the web server. If you get crashes with very large PHP scripts, it
+     is recommended to raise it with the Admin Server (in the section
+     "MAGNUS EDITOR").
+CGI environment and recommended modifications in php.ini
+   Important when writing PHP scripts is the fact that Sun JSWS/Sun ONE
+   WS/iPlanet/Netscape is a multithreaded web server. Because of that all
+   requests are running in the same process space (the space of the web
+   server itself) and this space has only one environment. If you want to
+   get CGI variables like PATH_INFO, HTTP_HOST etc. it is not the correct
+   way to try this in the old PHP 3.x way with getenv() or a similar way
+   (register globals to environment, $_ENV). You would only get the
+   environment of the running web server without any valid CGI variables!
+     Note: Why are there (invalid) CGI variables in the environment?
+     Answer: This is because you started the web server process from the
+     admin server which runs the startup script of the web server, you
+     wanted to start, as a CGI script (a CGI script inside of the admin
+     server!). This is why the environment of the started web server has
+     some CGI environment variables in it. You can test this by starting
+     the web server not from the administration server. Use the command
+     line as root user and start it manually - you will see there are no
+     CGI-like environment variables.
+   Simply change your scripts to get CGI variables in the correct way for
+   PHP 4.x by using the superglobal $_SERVER. If you have older scripts
+   which use $HTTP_HOST, etc., you should turn on register_globals in
+   php.ini and change the variable order too (important: remove "E" from
+   it, because you do not need the environment here):
+variables_order = "GPCS"
+register_globals = On
+Special use for error pages or self-made directory listings (PHP >= 4.3.3)
+   You can use PHP to generate the error pages for "404 Not Found" or
+   similar. Add the following line to the object in obj.conf for every
+   error page you want to overwrite:
+Error fn="php4_execute" code=XXX script="/path/to/script.php" [inikey=value inik
+ey=value...]
+   where XXX is the HTTP error code. Please delete any other Error
+   directives which could interfere with yours. If you want to place a
+   page for all errors that could exist, leave the code parameter out.
+   Your script can get the HTTP status code with $_SERVER['ERROR_TYPE'].
+   Another possibility is to generate self-made directory listings. Just
+   create a PHP script which displays a directory listing and replace the
+   corresponding default Service line for type="magnus-internal/directory"
+   in obj.conf with the following:
+Service fn="php4_execute" type="magnus-internal/directory" script="/path/to/scri
+pt.php" [inikey=value inikey=value...]
+   For both error and directory listing pages the original URI and
+   translated URI are in the variables $_SERVER['PATH_INFO'] and
+   $_SERVER['PATH_TRANSLATED'].
+Note about nsapi_virtual() and subrequests (PHP >= 4.3.3)
+   The NSAPI module now supports the nsapi_virtual() function (alias:
+   virtual()) to make subrequests on the web server and insert the result
+   in the web page. This function uses some undocumented features from the
+   NSAPI library. On Unix the module automatically looks for the needed
+   functions and uses them if available. If not, nsapi_virtual() is
+   disabled.
+     Note: But be warned: Support for nsapi_virtual() is EXPERIMENTAL!!!
+CGI and command line setups
+   The default is to build PHP as a CGI program. This creates a command
+   line interpreter, which can be used for CGI processing, or for
+   non-web-related PHP scripting. If you are running a web server PHP has
+   module support for, you should generally go for that solution for
+   performance reasons. However, the CGI version enables users to run
+   different PHP-enabled pages under different user-ids.
+   Warning
+   By using the CGI setup, your server is open to several possible
+   attacks. Please read our CGI security section to learn how to defend
+   yourself from those attacks.
+   As of PHP 4.3.0, some important additions have happened to PHP. A new
+   SAPI named CLI also exists and it has the same name as the CGI binary.
+   What is installed at {PREFIX}/bin/php depends on your configure line
+   and this is described in detail in the manual section named Using PHP
+   from the command line. For further details please read that section of
+   the manual.
+Testing
+   If you have built PHP as a CGI program, you may test your build by
+   typing make test. It is always a good idea to test your build. This way
+   you may catch a problem with PHP on your platform early instead of
+   having to struggle with it later.
+Benchmarking
+   If you have built PHP 3 as a CGI program, you may benchmark your build
+   by typing make bench. Note that if safe mode is on by default, the
+   benchmark may not be able to finish if it takes longer then the 30
+   seconds allowed. This is because the set_time_limit() can not be used
+   in safe mode. Use the max_execution_time configuration setting to
+   control this time for your own scripts. make bench ignores the
+   configuration file.
+     Note: make bench is only available for PHP 3.
+Using Variables
+   Some server supplied environment variables are not defined in the
+   current CGI/1.1 specification. Only the following variables are defined
+   there: AUTH_TYPE, CONTENT_LENGTH, CONTENT_TYPE, GATEWAY_INTERFACE,
+   PATH_INFO, PATH_TRANSLATED, QUERY_STRING, REMOTE_ADDR, REMOTE_HOST,
+   REMOTE_IDENT, REMOTE_USER, REQUEST_METHOD, SCRIPT_NAME, SERVER_NAME,
+   SERVER_PORT, SERVER_PROTOCOL, and SERVER_SOFTWARE. Everything else
+   should be treated as 'vendor extensions'.
+HP-UX specific installation notes
+   This section contains notes and hints specific to installing PHP on
+   HP-UX systems.
+   There are two main options for installing PHP on HP-UX systems. Either
+   compile it, or install a pre-compiled binary.
+   Official pre-compiled packages are located here:
+   http://software.hp.com/
+   Until this manual section is rewritten, the documentation about
+   compiling PHP (and related extensions) on HP-UX systems has been
+   removed. For now, consider reading the following external resource:
+   Building Apache and PHP on HP-UX 11.11
+OpenBSD installation notes
+   OpenBSD 3.6.
+Using Binary Packages
+   Using binary packages to install PHP on OpenBSD is the recommended and
+   simplest method. The core package has been separated from the various
+   modules, and each can be installed and removed independently from the
+   others. The files you need can be found on your OpenBSD CD or on the
+   FTP site.
+   The main package you need to install is php4-core-4.3.8.tgz, which
+   contains the basic engine (plus gettext and iconv). Next, take a look
+   at the module packages, such as php4-mysql-4.3.8.tgz or
+   php4-imap-4.3.8.tgz. You need to use the phpxs command to activate and
+   deactivate these modules in your php.ini.
+   Example 2-6. OpenBSD Package Install Example
+# pkg_add php4-core-4.3.8.tgz
+# /usr/local/sbin/phpxs -s
+# cp /usr/local/share/doc/php4/php.ini-recommended /var/www/conf/php.ini
+  (add in mysql)
+# pkg_add php4-mysql-4.3.8.tgz
+# /usr/local/sbin/phpxs -a mysql
+  (add in imap)
+# pkg_add php4-imap-4.3.8.tgz
+# /usr/local/sbin/phpxs -a imap
+  (remove mysql as a test)
+# pkg_delete php4-mysql-4.3.8
+# /usr/local/sbin/phpxs -r mysql
+  (install the PEAR libraries)
+# pkg_add php4-pear-4.3.8.tgz
+   Read the packages(7) manual page for more information about binary
+   packages on OpenBSD.
+Using Ports
+   You can also compile up PHP from source using the ports tree. However,
+   this is only recommended for users familiar with OpenBSD. The PHP 4
+   port is split into two sub-directories: core and extensions. The
+   extensions directory generates sub-packages for all of the supported
+   PHP modules. If you find you do not want to create some of these
+   modules, use the no_* FLAVOR. For example, to skip building the imap
+   module, set the FLAVOR to no_imap.
+Common Problems
+     * The default install of Apache runs inside a chroot(2) jail, which
+       will restrict PHP scripts to accessing files under /var/www. You
+       will therefore need to create a /var/www/tmp directory for PHP
+       session files to be stored, or use an alternative session backend.
+       In addition, database sockets need to be placed inside the jail or
+       listen on the localhost interface. If you use network functions,
+       some files from /etc such as /etc/resolv.conf and /etc/services
+       will need to be moved into /var/www/etc. The OpenBSD PEAR package
+       automatically installs into the correct chroot directories, so no
+       special modification is needed there. More information on the
+       OpenBSD Apache is available in the OpenBSD FAQ.
+     * The OpenBSD 3.6 package for the gd extension requires XFree86 to be
+       installed. If you do not wish to use some of the font features that
+       require X11, install the php4-gd-4.3.8-no_x11.tgz package instead.
+Older Releases
+   Older releases of OpenBSD used the FLAVORS system to compile up a
+   statically linked PHP. Since it is hard to generate binary packages
+   using this method, it is now deprecated. You can still use the old
+   stable ports trees if you wish, but they are unsupported by the OpenBSD
+   team. If you have any comments about this, the current maintainer for
+   the port is Anil Madhavapeddy (avsm at openbsd dot org).
+Solaris specific installation tips
+   Solaris systems.
+Required software
+   Solaris installs often lack C compilers and their related tools. Read
+   this FAQ for information on why using GNU versions for some of these
+   tools is necessary. The required software is as follows:
+     * gcc (recommended, other C compilers may work)
+     * make
+     * flex
+     * bison
+     * m4
+     * autoconf
+     * automake
+     * perl
+     * gzip
+     * tar
+     * GNU sed
+   In addition, you will need to install (and possibly compile) any
+   additional software specific to your configuration, such as Oracle or
+   MySQL.
+Using Packages
+   You can simplify the Solaris install process by using pkgadd to install
+   most of your needed components.
+Debian GNU/Linux installation notes
+   Debian GNU/Linux.
+Using APT
+   While you can just download the PHP source and compile it yourself,
+   using Debian's packaging system is the simplest and cleanest method of
+   installing PHP. If you are not familiar with building software on
+   Linux, this is the way to go.
+   The first decision you need to make is whether you want to install
+   Apache 1.3.x or Apache 2.x. The corresponding PHP packages are
+   respectively named libapache-mod-php* and libapache2-mod-php*. The
+   steps given below will use Apache 1.3.x. Please note that, as of this
+   writing, there is no official Debian packages of PHP 5. Then the steps
+   given below will install PHP 4.
+   PHP is available in Debian as CGI or CLI flavour too, named
+   respectively php4-cgi and php4-cli. If you need them, you'll just have
+   to reproduce the following steps with the good package names. Another
+   special package you'd want to install is php4-pear. It contains a
+   minimal PEAR installation and the pear commandline utility.
+   If you need more recent packages of PHP than the Debian's stable ones
+   or if some PHP modules lacks the Debian official repository, perhaps
+   you should take a look at http://www.apt-get.org/. One of the results
+   found should be Dotdeb. This unofficial repository is maintained by
+   Guillaume Plessis and contains Debian packages of the most recent
+   versions of PHP 4 and PHP 5. To use it, just add the to following two
+   lines to your /etc/apt/sources.lists and run apt-get update :
+   Example 2-7. The two Dotdeb related lines
+deb http://packages.dotdeb.org stable all
+deb-src http://packages.dotdeb.org stable all
+   The last thing to consider is whether your list of packages is up to
+   date. If you have not updated it recently, you need to run apt-get
+   update before anything else. This way, you will be using the most
+   recent stable version of the Apache and PHP packages.
+   Now that everything is in place, you can use the following example to
+   install Apache and PHP:
+   Example 2-8. Debian Install Example with Apache 1.3
+   # apt-get install libapache-mod-php4
+   APT will automatically install the PHP 4 module for Apache 1.3, and all
+   its dependencies and then activate it. If you're not asked to restart
+   Apache during the install process, you'll have to do it manually :
+   Example 2-9. Stopping and starting Apache once PHP 4 is installed
+# /etc/init.d/apache stop
+# /etc/init.d/apache start
+Better control on configuration
+   In the last section, PHP was installed with only core modules. This may
+   not be what you want and you will soon discover that you need more
+   activated modules, like MySQL, cURL, GD, etc.
+   When you compile PHP from source yourself, you need to activate modules
+   via the configure command. With APT, you just have to install
+   additional packages. They're all named 'php4-*' (or 'php5-*' if you
+   installed PHP 5 from a third party repository).
+   Example 2-10. Getting the list of PHP additional packages
+   # dpkg -l 'php4-*'
+   As you can see from the last output, there's a lot of PHP modules that
+   you can install (excluding the php4-cgi, php4-cli or php4-pear special
+   packages). Look at them closely and choose what you need. If you choose
+   a module and you do not have the proper libraries, APT will
+   automatically install all the dependencies for you.
+   If you choose to add the MySQL, cURL and GD support to PHP the command
+   will look something like this:
+   Example 2-11. Install PHP with MySQL, cURL and GD
+   # apt-get install php4-mysql php4-curl php4-gd
+   APT will automatically add the appropriate lines to your different
+   php.ini (/etc/php4/apache/php.ini, /etc/php4/cgi/php.ini, etc).
+   Example 2-12. These lines activate MySQL, cURL and GD into PHP
+extension=mysql.so
+extension=curl.so
+extension=gd.so
+   You'll only have to stop/start Apache as previously to activate the
+   modules.
+Common Problems
+     * If you see the PHP source instead of the result the script should
+       produce, APT has probably not included /etc/apache/conf.d/php4 in
+       your Apache 1.3 configuration. Please ensure that the following
+       line is present in your /etc/apache/httpd.conf file then stop/start
+       Apache:
+   Example 2-13. This line activates PHP 4 into Apache
+# Include /etc/apache/conf.d/
+     * If you installed an additional module and if its functions are not
+       available in your scripts, please ensure that the appropriate line
+       is present in your php.ini, as seen before. APT may fail during the
+       installation of the additional module, due to a confusing debconf
+       configuration.
+Chapter 3. Installation on Mac OS X
+   This section contains notes and hints specific to installing PHP on Mac
+   OS X. There are two slightly different versions of Mac OS X, Client and
+   Server, our manual deals with installing PHP on both systems. Note that
+   PHP is not available for MacOS 9 and earlier versions.
+Using Packages
+   There are a few pre-packaged and pre-compiled versions of PHP for Mac
+   OS X. This can help in setting up a standard configuration, but if you
+   need to have a different set of features (such as a secure server, or a
+   different database driver), you may need to build PHP and/or your web
+   server yourself. If you are unfamiliar with building and compiling your
+   own software, it's worth checking whether somebody has already built a
+   packaged version of PHP with the features you need.
+   The following resources offer easy to install packages and precompiled
+   binaries for PHP on Mac OS:
+     * Darwin: http://darwinports.opendarwin.org/
+     * Entropy: http://www.entropy.ch/software/macosx/php/
+     * Fink: http://fink.sourceforge.net/
+Using the bundled PHP
+   PHP has come standard with Macs since OS X version 10.0.0. Enabling PHP
+   with the default web server requires uncommenting a few lines in the
+   Apache configuration file httpd.conf whereas the CGI and/or CLI are
+   enabled by default (easily accessible via the Terminal program).
+   Enabling PHP using the instructions below is meant for quickly setting
+   up a local development environment. It's highly recommended to always
+   upgrade PHP to the newest version. Like most live software, newer
+   versions are created to fix bugs and add features and PHP being is no
+   different. See the appropriate MAC OS X installation documentation for
+   further details. The following instructions are geared towards a
+   beginner with details provided for getting a default setup to work. All
+   users are encouraged to compile, or install a new packaged version.
+   The standard installation type is using mod_php, and enabling the
+   bundled mod_php on Mac OS X for the Apache web server (the default web
+   server, that is accessible via System Preferences) involves the
+   following steps:
+    1. Locate and open the Apache configuration file. By default, the
+       location is as follows: /etc/httpd/httpd.conf
+       Using Finder or Spotlight to find this file may prove difficult as
+       by default it's private and owned by the root user.
+     Note: One way to open this is by using a Unix based text editor in
+     the Terminal, for example nano, and because the file is owned by
+     root we'll use the sudo command to open it (as root) so for example
+     type the following into the Terminal Application (after, it will
+     prompt for a password): sudo nano /etc/httpd/httpd.conf
+     Noteworthy nano commands: ^w (search), ^o (save), and ^x (exit)
+     where ^ represents the Ctrl key.
+    2. With a text editor, uncomment the lines (by removing the #) that
+       look similar to the following (these two lines are often not
+       together, locate them both in the file):
+# LoadModule php4_module libexec/httpd/libphp4.so
+# AddModule mod_php4.c
+       Notice the location/path. When building PHP in the future, the
+       above files should be replaced or commented out.
+    3. Be sure the desired extensions will parse as PHP (examples: .php
+       .html and .inc)
+       Due to the following statement already existing in httpd.conf (as
+       of Mac Panther), once PHP is enabled the .php files will
+       automatically parse as PHP.
+<IfModule mod_php4.c>
+    # If php is turned on, we respect .php and .phps files.
+    # Since most users will want index.php to work we
+    # also automatically enable index.php
+    <IfModule mod_dir.c>
+        DirectoryIndex index.html index.php
+    </IfModule>
+</IfModule>
+    4. Be sure the DirectoryIndex loads the desired default index file
+       This is also set in httpd.conf. Typically index.php and index.html
+       are used. By default index.php is enabled because it's also in the
+       PHP check shown above. Adjust accordingly.
+    5. Set the php.ini location or use the default
+       A typical default location on Mac OS X is /usr/local/php/php.ini
+       and a call to phpinfo() will reveal this information. If a php.ini
+       is not used, PHP will use all default values. See also the related
+       FAQ on finding php.ini.
+    6. Locate or set the DocumentRoot
+       This is the root directory for all the web files. Files in this
+       directory are served from the web server so the PHP files will
+       parse as PHP before outputting them to the browser. A typical
+       default path is /Library/WebServer/Documents but this can be set to
+       anything in httpd.conf. Alternatively, the default DocumentRoot for
+       individual users is /Users/yourusername/Sites
+    7. Create a phpinfo() file
+       The phpinfo() function will display information about PHP. Consider
+       creating a file in the DocumentRoot with the following PHP code:
+<?php phpinfo(); ?>
+    8. Restart Apache, and load the PHP file created above
+       To restart, either execute sudo apachectl graceful in the shell or
+       stop/start the "Personal Web Server" option in the OS X System
+       Preferences. By default, loading local files in the browser will
+       have an URL like so: http://localhost/info.php Or using the
+       DocumentRoot in the user directory is another option and would end
+       up looking like: http://localhost/~yourusername/info.php
+   The CLI (or CGI in older versions) is appropriately named php and
+   likely exists as /usr/bin/php. Open up the terminal, read the command
+   line section of the PHP manual, and execute php -v to check the PHP
+   version of this PHP binary. A call to phpinfo() will also reveal this
+   information.
+Compiling for OS X Server
+   Mac OS X Server install.
+    1. Get the latest distributions of Apache and PHP.
+    2. Untar them, and run the configure program on Apache like so.
+./configure --exec-prefix=/usr \
+--localstatedir=/var \
+--mandir=/usr/share/man \
+--libexecdir=/System/Library/Apache/Modules \
+--iconsdir=/System/Library/Apache/Icons \
+--includedir=/System/Library/Frameworks/Apache.framework/Versions/1.3/Headers \
+--enable-shared=max \
+--enable-module=most \
+--target=apache
+    3. If you want the compiler to do some optimization, you may also want
+       to add this line:
+setenv OPTIM=-O2
+    4. Next, go to the PHP 4 source directory and configure it.
+./configure --prefix=/usr \
+    --sysconfdir=/etc \
+    --localstatedir=/var \
+    --mandir=/usr/share/man \
+    --with-xml \
+    --with-apache=/src/apache_1.3.12
+       If you have any other additions (MySQL, GD, etc.), be sure to add
+       them here. For the --with-apache string, put in the path to your
+       apache source directory, for example /src/apache_1.3.12.
+    5. Type make and make install. This will add a directory to your
+       Apache source directory under src/modules/php4.
+    6. Now, reconfigure Apache to build in PHP 4.
+--target=apache \
+--activate-module=src/modules/php4/libphp4.a
+       You may get a message telling you that libmodphp4.a is out of date.
+       If so, go to the src/modules/php4 directory inside your Apache
+       source directory and run this command: ranlib libmodphp4.a. Then go
+       back to the root of the Apache source directory and run the above
+       configure command again. That'll bring the link table up to date.
+       Run make and make install again.
+    7. Copy and rename the php.ini-dist file to your bin directory from
+       your PHP 4 source directory: cp php.ini-dist /usr/local/bin/php.ini
+       or (if your don't have a local directory) cp php.ini-dist
+       /usr/bin/php.ini.
+Compiling for MacOS X Client
+   The following instructions will help you install a PHP module for the
+   Apache web server included in MacOS X. This version includes support
+   for the MySQL and PostgreSQL databases. These instructions are
+   graciously provided by Marc Liyanage.
+   Warning
+   Be careful when you do this, you could screw up your Apache web server!
+   Do this to install:
+    1. Open a terminal window.
+    2. Type wget
+       http://www.diax.ch/users/liyanage/software/macosx/libphp4.so.gz,
+       wait for the download to finish.
+    3. Type gunzip libphp4.so.gz.
+    4. Type sudo apxs -i -a -n php4 libphp4.so
+    5. Now type sudo open -a TextEdit /etc/httpd/httpd.conf. TextEdit will
+       open with the web server configuration file. Locate these two lines
+       towards the end of the file: (Use the Find command)
+#AddType application/x-httpd-php .php
+#AddType application/x-httpd-php-source .phps
+       Remove the two hash marks (#), then save the file and quit
+       TextEdit.
+    6. Finally, type sudo apachectl graceful to restart the web server.
+   PHP should now be up and running. You can test it by dropping a file
+   into your Sites folder which is called test.php. Into that file, write
+   this line: <?php phpinfo() ?>.
+   Now open up 127.0.0.1/~your_username/test.php in your web browser. You
+   should see a status table with information about the PHP module.
+Chapter 4. Installation of PECL extensions
+Introduction to PECL Installations
+   PECL is a repository of PHP extensions that are made available to you
+   via the PEAR packaging system. This section of the manual is intended
+   to demonstrate how to obtain and install PECL extensions.
+   These instructions assume /your/phpsrcdir/ is the path to the PHP
+   source distribution, and that extname is the name of the PECL
+   extension. Adjust accordingly. These instructions also assume a
+   familiarity with the pear command. The information in the PEAR manual
+   for the pear command also applies to the pecl command.
+   To be useful, a shared extension must be built, installed, and loaded.
+   The methods described below provide you with various instructions on
+   how to build and install the extensions, but they do not automatically
+   load them. Extensions can be loaded by adding an extension directive.
+   To this php.ini file, or through the use of the dl() function.
+   When building PHP modules, it's important to have known-good versions
+   of the required tools (autoconf, automake, libtool, etc.) See the
+   SVN Instructions for details on the required tools, and required
+   versions.
+Downloading PECL extensions
+   There are several options for downloading PECL extensions, such as:
+     * http://pecl.php.net
+       The PECL web site contains information about the different
+       extensions that are offered by the PHP Development Team. The
+       information available here includes: ChangeLog, release notes,
+       requirements and other similar details.
+     * pecl download extname
+       PECL extensions that have releases listed on the PECL web site are
+       available for download and installation using the pecl command.
+       Specific revisions may also be specified.
+     * SVN
+       All PECL files reside in SVN. A web-based view may be seen at
+       http://svn.php.net/pecl/. To download straight from SVN, use:
+$ svn co http://svn.php.net/repository/pecl/<extname>/trunk <extname>
+     * Windows downloads
+       Windows users may find compiled PECL binaries by downloading the
+       Collection of PECL modules from the PHP Downloads page, or by
+       retrieving a PECL Snapshot or an extension DLL on PECL4WIN. To
+       compile PHP under Windows, read the appropriate chapter.
+PECL for Windows users
+   As with any other PHP extension DLL, installation is as simple as
+   copying the PECL extension DLLs into the extension_dir folder and
+   loading them from php.ini. For example, add the following line to your
+   php.ini:
+   extension=php_extname.dll
+   After doing this, restart the web server.
+Compiling shared PECL extensions with the pecl command
+   PECL makes it easy to create shared PHP extensions. Using the pecl
+   command, do the following:
+   $ pecl install extname
+   This will download the source for extname, compile, and install
+   extname.so into your extension_dir. extname.so may then be loaded via
+   php.ini
+   By default, the pecl command will not install packages that are marked
+   with the alpha or beta state. If no stable packages are available, you
+   may install a beta package using the following command:
+   $ pecl install extname-beta
+   You may also install a specific version using this variant:
+   $ pecl install extname-0.1
+Compiling shared PECL extensions with phpize
+   Sometimes, using the pecl installer is not an option. This could be
+   because you're behind a firewall, or it could be because the extension
+   you want to install is not available as a PECL compatible package, such
+   as unreleased extensions from SVN. If you need to build such an
+   extension, you can use the lower-level build tools to perform the build
+   manually.
+   The phpize command is used to prepare the build environment for a PHP
+   extension. In the following sample, the sources for an extension are in
+   a directory named extname:
+$ cd extname
+$ phpize
+$ ./configure
+$ make
+# make install
+   A successful install will have created extname.so and put it into the
+   PHP extensions directory. You'll need to and adjust php.ini and add an
+   extension=extname.so line before you can use the extension.
+   If the system is missing the phpize command, and precompiled packages
+   (like RPM's) are used, be sure to also install the appropriate devel
+   version of the PHP package as they often include the phpize command
+   along with the appropriate header files to build PHP and its
+   extensions.
+   Execute phpize --help to display additional usage information.
+Compiling PECL extensions statically into PHP
+   You might find that you need to build a PECL extension statically into
+   your PHP binary. To do this, you'll need to place the extension source
+   under the php-src/ext/ directory and tell the PHP build system to
+   regenerate its configure script.
+$ cd /your/phpsrcdir/ext
+$ pecl download extname
+$ gzip -d < extname.tgz | tar -xvf -
+$ mv extname-x.x.x extname
+   This will result in the following directory:
+   /your/phpsrcdir/ext/extname
+   From here, force PHP to rebuild the configure script, and then build
+   PHP as normal:
+$ rm configure
+$ ./buildconf --force
+$ ./configure --help
+$ ./configure --with-extname --enable-someotherext --with-foobar
+$ make
+$ make install
+     Note: To run the 'buildconf' script you need autoconf 2.13 and
+     automake 1.4+ (newer versions of autoconf may work, but are not
+     supported).
+   Whether --enable-extname or --with-extname is used depends on the
+   extension. Typically an extension that does not require external
+   libraries uses --enable. To be sure, run the following after buildconf:
+   $ ./configure --help | grep extname
+Chapter 5. Problems?
+Read the FAQ
+   Some problems are more common than others. The most common ones are
+   listed in the PHP FAQ, part of this manual.
+Other problems
+   If you are still stuck, someone on the PHP installation mailing list
+   may be able to help you. You should check out the archive first, in
+   case someone already answered someone else who had the same problem as
+   you. The archives are available from the support page on
+   http://www.php.net/support.php. To subscribe to the PHP installation
+   mailing list, send an empty mail to
+   php-install-subscribe at lists.php.net. The mailing list address is
+   php-install at lists.php.net.
+   If you want to get help on the mailing list, please try to be precise
+   and give the necessary details about your environment (which operating
+   system, what PHP version, what web server, if you are running PHP as
+   CGI or a server module, safe mode, etc...), and preferably enough code
+   to make others able to reproduce and test your problem.
+Bug reports
+   If you think you have found a bug in PHP, please report it. The PHP
+   developers probably don't know about it, and unless you report it,
+   chances are it won't be fixed. You can report bugs using the
+   bug-tracking system at http://bugs.php.net/. Please do not send bug
+   reports in mailing list or personal letters. The bug system is also
+   suitable to submit feature requests.
+   Read the How to report a bug document before submitting any bug
+   reports!
+Chapter 6. Runtime Configuration
+The configuration file
+   The configuration file (called php3.ini in PHP 3, and simply php.ini as
+   of PHP 4) is read when PHP starts up. For the server module versions of
+   PHP, this happens only once when the web server is started. For the CGI
+   and CLI version, it happens on every invocation.
+   php.ini is searched in these locations (in order):
+     * SAPI module specific location (PHPIniDir directive in Apache 2, -c
+       command line option in CGI and CLI, php_ini parameter in NSAPI,
+       PHP_INI_PATH environment variable in THTTPD)
+     * The PHPRC environment variable. Before PHP 5.2.0 this was checked
+       after the registry key mentioned below.
+     * As of PHP 5.2.0, the following registry locations are searched in
+       order: HKEY_LOCAL_MACHINE\SOFTWARE\PHP\x.y.z\IniFilePath,
+       HKEY_LOCAL_MACHINE\SOFTWARE\PHP\x.y\IniFilePath and
+       HKEY_LOCAL_MACHINE\SOFTWARE\PHP\x\IniFilePath, where x, y and z
+       mean the PHP major, minor and release versions.
+     * HKEY_LOCAL_MACHINE\SOFTWARE\PHP\IniFilePath (Windows Registry
+       location)
+     * Current working directory (except CLI)
+     * The web server's directory (for SAPI modules), or directory of PHP
+       (otherwise in Windows)
+     * Windows directory (C:\windows or C:\winnt) (for Windows), or
+       --with-config-file-path compile time option
+   If php-SAPI.ini exists (where SAPI is used SAPI, so the filename is
+   e.g. php-cli.ini or php-apache.ini), it's used instead of php.ini. SAPI
+   name can be determined by php_sapi_name().
+     Note: The Apache web server changes the directory to root at startup
+     causing PHP to attempt to read php.ini from the root filesystem if
+     it exists.
+   The php.ini directives handled by extensions are documented
+   respectively on the pages of the extensions themselves. The list of the
+   core directives is available in the appendix. Probably not all PHP
+   directives are documented in the manual though. For a complete list of
+   directives available in your PHP version, please read your well
+   commented php.ini file. Alternatively, you may find the the latest
+   php.ini from SVN helpful too.
+   Example 6-1. php.ini example
+; any text on a line after an unquoted semicolon (;) is ignored
+[php] ; section markers (text within square brackets) are also ignored
+; Boolean values can be set to either:
+;    true, on, yes
+; or false, off, no, none
+register_globals = off
+track_errors = yes
+; you can enclose strings in double-quotes
+include_path = ".:/usr/local/lib/php"
+; backslashes are treated the same as any other character
+include_path = ".;c:\php\lib"
+   Since PHP 5.1.0, it is possible to refer to existing .ini variables
+   from within .ini files. Example: open_basedir = ${open_basedir}
+   ":/new/dir".
+How to change configuration settings
+Running PHP as an Apache module
+   When using PHP as an Apache module, you can also change the
+   configuration settings using directives in Apache configuration files
+   (e.g. httpd.conf) and .htaccess files. You will need "AllowOverride
+   Options" or "AllowOverride All" privileges to do so.
+   With PHP 4 and PHP 5, there are several Apache directives that allow
+   you to change the PHP configuration from within the Apache
+   configuration files. For a listing of which directives are PHP_INI_ALL,
+   PHP_INI_PERDIR, or PHP_INI_SYSTEM, have a look at the List of php.ini
+   directives appendix.
+     Note: With PHP 3, there are Apache directives that correspond to
+     each configuration setting in the php3.ini name, except the name is
+     prefixed by "php3_".
+   php_value name value
+          Sets the value of the specified directive. Can be used only with
+          PHP_INI_ALL and PHP_INI_PERDIR type directives. To clear a
+          previously set value use none as the value.
+     Note: Don't use php_value to set boolean values. php_flag (see
+     below) should be used instead.
+   php_flag name on|off
+          Used to set a boolean configuration directive. Can be used only
+          with PHP_INI_ALL and PHP_INI_PERDIR type directives.
+   php_admin_value name value
+          Sets the value of the specified directive. This can not be used
+          in .htaccess files. Any directive type set with php_admin_value
+          can not be overridden by .htaccess or virtualhost directives. To
+          clear a previously set value use none as the value.
+   php_admin_flag name on|off
+          Used to set a boolean configuration directive. This can not be
+          used in .htaccess files. Any directive type set with
+          php_admin_flag can not be overridden by .htaccess or virtualhost
+          directives.
+   Example 6-2. Apache configuration example
+<IfModule mod_php5.c>
+  php_value include_path ".:/usr/local/lib/php"
+  php_admin_flag safe_mode on
+</IfModule>
+</IfModule>
+<IfModule mod_php3.c>
+  php3_include_path ".:/usr/local/lib/php"
+  php3_safe_mode on
+</IfModule>
+   Caution
+   PHP constants do not exist outside of PHP. For example, in httpd.conf
+   you can not use PHP constants such as E_ALL or E_NOTICE to set the
+   error_reporting directive as they will have no meaning and will
+   evaluate to 0. Use the associated bitmask values instead. These
+   constants can be used in php.ini
+     __________________________________________________________________
+Changing PHP configuration via the Windows registry
+   When running PHP on Windows, the configuration values can be modified
+   on a per-directory basis using the Windows registry. The configuration
+   values are stored in the registry key HKLM\SOFTWARE\PHP\Per Directory
+   Values, in the sub-keys corresponding to the path names. For example,
+   configuration values for the directory c:\inetpub\wwwroot would be
+   stored in the key HKLM\SOFTWARE\PHP\Per Directory
+   Values\c\inetpub\wwwroot. The settings for the directory would be
+   active for any script running from this directory or any subdirectory
+   of it. The values under the key should have the name of the PHP
+   configuration directive and the string value. PHP constants in the
+   values are not parsed. However, only configuration values changeable in
+   PHP_INI_USER can be set this way, PHP_INI_PERDIR values can not.
+Other interfaces to PHP
+   Regardless of how you run PHP, you can change certain values at runtime
+   of your scripts through ini_set(). See the documentation on the
+   ini_set() page for more information.
+   If you are interested in a complete list of configuration settings on
+   your system with their current values, you can execute the phpinfo()
+   function, and review the resulting page. You can also access the values
+   of individual configuration directives at runtime using ini_get() or
+   get_cfg_var().
+Chapter 7. Installation FAQ
+   This section holds common questions about the way to install PHP. PHP
+   is available for almost any OS (except maybe for MacOS before OSX), and
+   almost any web server.
+   To install PHP, follow the instructions in Installing PHP.
+   1. Why shouldn't I use Apache2 with a threaded MPM in a production
+          environment?
+   2. Unix/Windows: Where should my php.ini file be located?
+   3. Unix: I installed PHP, but every time I load a document, I get the
+          message 'Document Contains No Data'! What's going on here?
+   4. Unix: I installed PHP using RPMS, but Apache isn't processing the
+          PHP pages! What's going on here?
+   5. Unix: I installed PHP 3 using RPMS, but it doesn't compile with the
+          database support I need! What's going on here?
+   6. Unix: I patched Apache with the FrontPage extensions patch, and
+          suddenly PHP stopped working. Is PHP incompatible with the
+          Apache FrontPage extensions?
+   7. Unix/Windows: I have installed PHP, but when I try to access a PHP
+          script file via my browser, I get a blank screen.
+   8. Unix/Windows: I have installed PHP, but when try to access a PHP
+          script file via my browser, I get a server 500 error.
+   9. Some operating systems: I have installed PHP without errors, but
+          when I try to start apache I get undefined symbol errors:
+[mybox:user /src/php4] root# apachectl configtest
+ apachectl: /usr/local/apache/bin/httpd Undefined symbols:
+  _compress
+  _uncompress
+   10. Windows: I have installed PHP, but when I to access a PHP script
+          file via my browser, I get the error:
+cgi error:
+ The specified CGI application misbehaved by not
+ returning a complete set of HTTP headers.
+ The headers it did return are:
+   11. Windows: I've followed all the instructions, but still can't get
+          PHP and IIS to work together!
+   12. When running PHP as CGI with IIS, PWS, OmniHTTPD or Xitami, I get
+          the following error: Security Alert! PHP CGI cannot be accessed
+          directly..
+   13. How do I know if my php.ini is being found and read? It seems like
+          it isn't as my changes aren't being implemented.
+   14. How do I add my PHP directory to the PATH on Windows?
+   15. How do I make the php.ini file available to PHP on windows?
+   16. Is it possible to use Apache content negotiation (MultiViews
+          option) with PHP?
+   17. Is PHP limited to process GET and POST request methods only?
+   environment?
+   PHP is glue. It is the glue used to build cool web applications by
+   sticking dozens of 3rd-party libraries together and making it all
+   appear as one coherent entity through an intuitive and easy to learn
+   language interface. The flexibility and power of PHP relies on the
+   stability and robustness of the underlying platform. It needs a working
+   OS, a working web server and working 3rd-party libraries to glue
+   together. When any of these stop working PHP needs ways to identify the
+   problems and fix them quickly. When you make the underlying framework
+   more complex by not having completely separate execution threads,
+   completely separate memory segments and a strong sandbox for each
+   request to play in, feet of clay are introduced into PHP's system.
+   If you feel you have to use a threaded MPM, look at a FastCGI
+   configuration where PHP is running in its own memory space.
+   And finally, this warning against using a threaded MPM is not as strong
+   for Windows systems because most libraries on that platform tend to be
+   threadsafe.
+   By default on Unix it should be in /usr/local/lib which is
+   <install-path>/lib. Most people will want to change this at
+   compile-time with the --with-config-file-path flag. You would, for
+   example, set it with something like:
+   --with-config-file-path=/etc
+   And then you would copy php.ini-dist from the distribution to
+   /etc/php.ini and edit it to make any local changes you want.
+   --with-config-file-scan-dir=PATH
+   On Windows the default path for the php.ini file is the Windows
+   directory. If you're using the Apache webserver, php.ini is first
+   searched in the Apaches install directory, e.g. c:\program files\apache
+   group\apache. This way you can have different php.ini files for
+   different versions of Apache on the same machine.
+   See also the chapter about the configuration file.
+   This probably means that PHP is having some sort of problem and is
+   core-dumping. Look in your server error log to see if this is the case,
+   and then try to reproduce the problem with a small test case. If you
+   know how to use 'gdb', it is very helpful when you can provide a
+   backtrace with your bug report to help the developers pinpoint the
+   problem. If you are using PHP as an Apache module try something like:
+     * Stop your httpd processes
+     * gdb httpd
+     * > run -X -f /path/to/httpd.conf
+     * Then fetch the URL causing the problem with your browser
+     * If you are getting a core dump, gdb should inform you of this now
+     * type: bt
+     * You should include your backtrace in your bug report. This should
+       be submitted to http://bugs.php.net/
+   If your script uses the regular expression functions (ereg() and
+   friends), you should make sure that you compiled PHP and Apache with
+   the same regular expression package. This should happen automatically
+   with PHP and Apache 1.3.x
+   Assuming you installed both Apache and PHP from RPM packages, you need
+   to uncomment or add some or all of the following lines in your
+   httpd.conf file:
+# Extra Modules
+AddModule mod_php.c
+AddModule mod_php3.c
+AddModule mod_perl.c
+# Extra Modules
+LoadModule php_module         modules/mod_php.so
+LoadModule php3_module        modules/libphp3.so     # for PHP 3
+LoadModule php4_module        modules/libphp4.so     # for PHP 4
+LoadModule perl_module        modules/libperl.so
+   And add:
+AddType application/x-httpd-php3 .php3    # for PHP 3
+AddType application/x-httpd-php .php      # for PHP 4
+   ... to the global properties, or to the properties of the VirtualDomain
+   you want to have PHP support added to.
+   Due to the way PHP 3 built, it is not easy to build a complete flexible
+   PHP RPM. This issue is addressed in PHP 4. For PHP 3, we currently
+   suggest you use the mechanism described in the INSTALL.REDHAT file in
+   the PHP distribution. If you insist on using an RPM version of PHP 3,
+   read on...
+   The RPM packagers are setting up the RPMS to install without database
+   support to simplify installations and because RPMS use /usr/ instead of
+   the standard /usr/local/ directory for files. You need to tell the RPM
+   spec file which databases to support and the location of the top-level
+   of your database server.
+   This example will explain the process of adding support for the popular
+   MySQL database server, using the mod installation for Apache.
+   Of course all of this information can be adjusted for any database
+   server that PHP supports. We will assume you installed MySQL and Apache
+   completely with RPMS for this example as well.
+     * First remove mod_php3 :
+rpm -e mod_php3
+     * Then get the source rpm and INSTALL it, NOT --rebuild
+rpm -Uvh mod_php3-3.0.5-2.src.rpm
+     * Then edit the /usr/src/redhat/SPECS/mod_php3.spec file
+       In the %build section add the database support you want, and the
+       path.
+       For MySQL you would add --with-mysql=/usr The %build section will
+       look something like this:
+--with-apxs=/usr/sbin/apxs \
+--with-config-file-path=/usr/lib \
+--enable-debug=no \
+--enable-safe-mode \
+--with-exec-dir=/usr/bin \
+--with-mysql=/usr \
+--with-system-regex
+     * Once this modification is made then build the binary rpm as
+       follows:
+rpm -bb /usr/src/redhat/SPECS/mod_php3.spec
+     * Then install the rpm
+rpm -ivh /usr/src/redhat/RPMS/i386/mod_php3-3.0.5-2.i386.rpm
+   Make sure you restart Apache, and you now have PHP 3 with MySQL support
+   using RPM's. Note that it is probably much easier to just build from
+   the distribution tarball of PHP 3 and follow the instructions in
+   INSTALL.REDHAT found in that distribution.
+   suddenly PHP stopped working. Is PHP incompatible with the Apache
+   FrontPage extensions?
+   No, PHP works fine with the FrontPage extensions. The problem is that
+   the FrontPage patch modifies several Apache structures, that PHP relies
+   on. Recompiling PHP (using 'make clean ; make') after the FP patch is
+   applied would solve the problem.
+   Do a 'view source' in the web browser and you will probably find that
+   you can see the source code of your PHP script. This means that the web
+   server did not send the script to PHP for interpretation. Something is
+   wrong with the server configuration - double check the server
+   configuration against the PHP installation instructions.
+   Something went wrong when the server tried to run PHP. To get to see a
+   sensible error message, from the command line, change to the directory
+   containing the PHP executable (php.exe on Windows) and run php -i. If
+   PHP has any problems running, then a suitable error message will be
+   displayed which will give you a clue as to what needs to be done next.
+   If you get a screen full of HTML codes (the output of the phpinfo()
+   function) then PHP is working, and your problem may be related to your
+   server configuration which you should double check.
+  _compress
+  _uncompress
+   This has actually nothing to do with PHP, but with the MySQL client
+   libraries. Some need --with-zlib, others do not. This is also covered
+   in the MySQL FAQ.
+cgi error:
+   This error message means that PHP failed to output anything at all. To
+   get to see a sensible error message, from the command line, change to
+   the directory containing the PHP executable (php.exe on Windows) and
+   run php -i. If PHP has any problems running, then a suitable error
+   message will be displayed which will give you a clue as to what needs
+   to be done next. If you get a screen full of HTML codes (the output of
+   the phpinfo() function) then PHP is working.
+   Once PHP is working at the command line, try accessing the script via
+   the browser again. If it still fails then it could be one of the
+   following:
+     * File permissions on your PHP script, php.exe, php4ts.dll, php.ini
+       or any PHP extensions you are trying to load are such that the
+       anonymous internet user ISUR_<machinename> cannot access them.
+     * The script file does not exist (or possibly isn't where you think
+       it is relative to your web root directory). Note that for IIS you
+       can trap this error by ticking the 'check file exists' box when
+       setting up the script mappings in the Internet Services Manager. If
+       a script file does not exist then the server will return a 404
+       error instead. There is also the additional benefit that IIS will
+       do any authentication required for you based on the NTLanMan
+       permissions on your script file.
+   Make sure any user who needs to run a PHP script has the rights to run
+   php.exe! IIS uses an anonymous user which is added at the time IIS is
+   installed. This user needs rights to php.exe. Also, any authenticated
+   user will also need rights to execute php.exe. And for IIS4 you need to
+   tell it that PHP is a script engine. Also, you will want to read this
+   faq.
+   directly..
+   You must set the cgi.force_redirect directive to 0. It defaults to 1 so
+   be sure the directive isn't commented out (with a ;). Like all
+   directives, this is set in php.ini
+   Because the default is 1, it's critical that you're 100% sure that the
+   correct php.ini file is being read. Read this faq for details.
+   To be sure your php.ini is being read by PHP, make a call to phpinfo()
+   and near the top will be a listing called Configuration File (php.ini).
+   This will tell you where PHP is looking for php.ini and whether or not
+   it's being read. If just a directory PATH exists than it's not being
+   read and you should put your php.ini in that directory. If php.ini is
+   included within the PATH than it is being read.
+   If php.ini is being read and you're running PHP as a module, then be
+   sure to restart your web server after making changes to php.ini
+   On Windows NT, 2000, XP and 2003:
+     * Go to Control Panel and open the System icon (Start -> Settings ->
+       Control Panel -> System, or just Start -> Control Panel -> System
+       for Windows XP/2003)
+     * Go to the Advanced tab
+     * Click on the 'Environment Variables' button
+     * Look into the 'System Variables' pane
+     * Find the Path entry (you may need to scroll to find it)
+     * Double click on the Path entry
+     * Enter your PHP directory at the end, including ';' before (e.g.
+       ;C:\php)
+     * Press OK and restart your computer
+   On Windows 98/Me you need to edit the autoexec.bat file:
+     * Open the Notepad (Start -> Run and enter notepad)
+     * Open the C:\autoexec.bat file
+     * Locate the line with PATH=C:\WINDOWS;C:\WINDOWS\COMMAND;..... and
+       add: ;C:\php to the end of the line
+     * Save the file and restart your computer
+     Note: Be sure to reboot after following the steps above to ensure
+     that the PATH changes are applied.
+   The PHP manual used to promote the copying of files into the Windows
+   system directory, this is because this directory (C:\Windows, C:\WINNT,
+   etc.) is by default in the systems PATH. Copying files into the Windows
+   system directory has long since been deprecated and may cause problems.
+   There are several ways of doing this. If you are using Apache, read
+   their installation specific instructions (Apache 1, Apache 2),
+   otherwise you must set the PHPRC environment variable:
+     * Look into the 'System variables' pane
+     * Click on 'New' and enter 'PHPRC' as the variable name and the
+       directory where php.ini is located as the variable value (e.g.
+       C:\php)
+     * Add a new line to the end of the file: set PHPRC=C:\php (replace
+       C:\php with the directory where php.ini is located). Please note
+       that the path cannot contain spaces. For instance, if you have
+       installed PHP in C:\Program Files\PHP, you would enter
+       C:\PROGRA~1\PHP instead.
+   option) with PHP?
+   If links to PHP files include extension, everything works perfect. This
+   FAQ is only for the case when links to PHP files don't include
+   extension and you want to use content negotiation to choose PHP files
+   from URL with no extension. In this case, replace the line AddType
+   application/x-httpd-php .php with:
+# PHP 4
+AddHandler php-script php
+AddType text/html php
+# PHP 5
+AddHandler php5-script php
+   This solution doesn't work for Apache 1 as PHP module doesn't catch
+   php-script.
+   No, it is possible to handle any request method, e.g. CONNECT. Proper
+   response status can be sent with header(). If only GET and POST methods
+   should be handled, it can be achieved with this Apache configuration:
+<LimitExcept GET POST>
+Deny from all
+</LimitExcept>
Added: trunk/Installer/Support/Web/x64/Php/LICENSE
--- trunk/Installer/Support/Web/x64/Php/LICENSE	                        (rev 0)
+++ trunk/Installer/Support/Web/x64/Php/LICENSE	2010-06-26 14:06:52 UTC (rev 4976)
@@ -0,0 +1,68 @@
+                  The PHP License, version 3.01
+Copyright (c) 1999 - 2009 The PHP Group. All rights reserved.
+Redistribution and use in source and binary forms, with or without
+modification, is permitted provided that the following conditions
+are met:
+  1. Redistributions of source code must retain the above copyright
+     notice, this list of conditions and the following disclaimer.
+  2. Redistributions in binary form must reproduce the above copyright
+     notice, this list of conditions and the following disclaimer in
+     the documentation and/or other materials provided with the
+     distribution.
+  3. The name "PHP" must not be used to endorse or promote products
+     derived from this software without prior written permission. For
+     written permission, please contact group at php.net.
+  4. Products derived from this software may not be called "PHP", nor
+     may "PHP" appear in their name, without prior written permission
+     from group at php.net.  You may indicate that your software works in
+     conjunction with PHP by saying "Foo for PHP" instead of calling
+     it "PHP Foo" or "phpfoo"
+  5. The PHP Group may publish revised and/or new versions of the
+     license from time to time. Each version will be given a
+     distinguishing version number.
+     Once covered code has been published under a particular version
+     of the license, you may always continue to use it under the terms
+     of that version. You may also choose to use such covered code
+     under the terms of any subsequent version of the license
+     published by the PHP Group. No one other than the PHP Group has
+     the right to modify the terms applicable to covered code created
+     under this License.
+  6. Redistributions of any form whatsoever must retain the following
+     acknowledgment:
+     "This product includes PHP software, freely available from
+     <http://www.php.net/software/>".
+THIS SOFTWARE IS PROVIDED BY THE PHP DEVELOPMENT TEAM ``AS IS'' AND
+ANY EXPRESSED OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
+THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
+PARTICULAR PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE PHP
+DEVELOPMENT TEAM OR ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
+INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
+(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
+SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
+STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
+OF THE POSSIBILITY OF SUCH DAMAGE.
+This software consists of voluntary contributions made by many
+individuals on behalf of the PHP Group.
+The PHP Group can be contacted via Email at group at php.net.
+For more information on the PHP Group and the PHP project,
+please see <http://www.php.net>.
+PHP includes the Zend Engine, freely available at
+<http://www.zend.com>.
Added: trunk/Installer/Support/Web/x64/Php/NEWS
--- trunk/Installer/Support/Web/x64/Php/NEWS	                        (rev 0)
+++ trunk/Installer/Support/Web/x64/Php/NEWS	2010-06-26 14:06:52 UTC (rev 4976)
@@ -0,0 +1,4774 @@
+PHP        NEWS
+19 Nov 2009, PHP 5.3.1
+- Added "max_file_uploads" INI directive, which can be set to limit the
+  number of file uploads per-request to 20 by default, to prevent possible
+  DOS via temporary file exhaustion. (Ilia)
+- Added missing sanity checks around exif processing. (Ilia)
+- Added error constant when json_encode() detects an invalid UTF-8 sequence.
+  (Scott)
+- Added support for ACL on Windows for thread safe SAPI (Apache2 for example)
+  and fix its support on NTS. (Pierre)
+- Upgraded bundled sqlite to version 3.6.19. (Scott)
+- Updated timezone database to version 2009.17 (2009q). (Derick)
+- Fixed crash in com_print_typeinfo when an invalid typelib is given. (Pierre)
+- Fixed a safe_mode bypass in tempnam() identified by Grzegorz Stachowiak.
+  (Rasmus)
+- Fixed a open_basedir bypass in posix_mkfifo() identified by Grzegorz
+  Stachowiak.  (Rasmus)
+- Fixed certificate validation inside php_openssl_apply_verification_policy
+  (Ryan Sleevi, Ilia)
+- Fixed crash in SQLiteDatabase::ArrayQuery() and SQLiteDatabase::SingleQuery()
+  when calling using Reflection. (Felipe)
+- Fixed crash when instantiating PDORow and PDOStatement through Reflection.
+  (Felipe)
+- Fixed sanity check for the color index in imagecolortransparent. (Pierre)
+- Fixed scandir/readdir when used mounted points on Windows. (Pierre)
+- Fixed zlib.deflate compress filter to actually accept level parameter. (Jani)
+- Fixed leak on error in popen/exec (and related functions) on Windows.
+  (Pierre)
+- Fixed possible bad caching of symlinked directories in the realpath cache
+  on Windows. (Pierre)
+- Fixed atime and mtime in stat related functions on Windows. (Pierre)
+- Fixed spl_autoload_unregister/spl_autoload_functions wrt. Closures and
+  Functors. (Christian Seiler)
+- Fixed open_basedir circumvention for "mail.log" ini directive.
+  (Maksymilian Arciemowicz, Stas)
+- Fixed signature generation/validation for zip archives in ext/phar. (Greg)
+- Fixed memory leak in stream_is_local(). (Felipe, Tony)
+- Fixed BC break in mime_content_type(), removes the content encoding. (Scott)
+- Changed ini file directives [PATH=](on Win32) and [HOST=](on all) to be case
+  insensitive (garretts)
+- Restored shebang line check to CGI sapi (not checked by scanner anymore).
+  (Jani)
+- Improve symbolic, mounted volume and junctions support for realpath on
+  Windows. (Pierre)
+- Improved readlink on Windows, suppress \??\ and use the drive syntax only.
+  (Pierre)
+- Improved dns_get_record() AAAA support on windows. Always available when
+  IPv6 is support is installed, format is now the same than on unix. (Pierre)
+- Improved the DNS functions on OSX to use newer APIs, also use Bind 9 API
+  where available on other platforms. (Scott)
+- Improved shared extension loading on OSX to use the standard Unix dlopen()
+  API. (Scott)
+- Fixed bug #50063 (safe_mode_include_dir fails). (Johannes, christian at
+  elmerot dot se)
+- Fixed bug #50052 (Different Hashes on Windows and Linux on wrong Salt size).
+  (Pierre)
+- Fixed bug #49910 (no support for ././@LongLink for long filenames in phar
+  tar support). (Greg)
+- Fixed bug #49908 (throwing exception in __autoload crashes when interface
+  is not defined). (Felipe)
+- Fixed bug #49847 (exec() fails to return data inside 2nd parameter, given
+  output lines >4095 bytes). (Ilia)
+- Fixed bug #49809 (time_sleep_until() is not available on OpenSolaris). (Jani)
+- Fixed bug #49757 (long2ip() can return wrong value in a multi-threaded
+  applications). (Ilia, Florian Anderiasch)
+- Fixed bug #49738 (calling mcrypt after mcrypt_generic_deinit crashes).
+  (Sriram Natarajan)
+- Fixed bug #49732 (crashes when using fileinfo when timestamp conversion
+  fails). (Pierre)
+- Fixed bug #49698 (Unexpected change in strnatcasecmp()). (Rasmus)
+- Fixed bug #49630 (imap_listscan function missing). (Felipe)
+- Fixed bug #49572 (use of C++ style comments causes build failure).
+- Fixed bug #49531 (CURLOPT_INFILESIZE sometimes causes warning "CURLPROTO_FILE
+  cannot be set"). (Felipe)
+- Fixed bug #49517 (cURL's CURLOPT_FILE prevents file from being deleted after
+  fclose). (Ilia)
+- Fixed bug #49470 (FILTER_SANITIZE_EMAIL allows disallowed characters).
+  (Ilia)
+- Fixed bug #49447 (php engine need to correctly check for socket API
+  return status on windows). (Sriram Natarajan)
+- Fixed bug #49391 (ldap.c utilizing deprecated ldap_modify_s). (Ilia)
+- Fixed bug #49361 (wordwrap() wraps incorrectly on end of line boundaries).
+  (Ilia, code-it at mail dot ru)
+- Fixed bug #49372 (segfault in php_curl_option_curl). (Pierre)
+- Fixed bug #49306 (inside pdo_mysql default socket settings are ignored).
+  (Ilia)
+- Fixed bug #49289 (bcmath module doesn't compile with phpize configure).
+  (Jani)
+- Fixed bug #49286 (php://input (php_stream_input_read) is broken). (Jani)
+- Fixed bug #49269 (Ternary operator fails on Iterator object when used inside
+  foreach declaration). (Etienne, Dmitry)
+- Fixed bug #49236 (Missing PHP_SUBST(PDO_MYSQL_SHARED_LIBADD)). (Jani)
+- Fixed bug #49223 (Inconsistency using get_defined_constants). (Garrett)
+- Fixed bug #49193 (gdJpegGetVersionString() inside gd_compact identifies
+  wrong type in declaration). (Ilia)
+- Fixed bug #49183 (dns_get_record does not return NAPTR records). (Pierre)
+- Fixed bug #49144 (Import of schema from different host transmits original
+  authentication details). (Dmitry)
+- Fixed bug #49142 (crash when exception thrown from __tostring()).
+  (David Soria Parra)
+- Fixed bug #49986 (Missing ICU DLLs on windows package). (Pierre)
+- Fixed bug #49132 (posix_times returns false without error).
+  (phpbugs at gunnu dot us)
+- Fixed bug #49125 (Error in dba_exists C code). (jdornan at stanford dot edu)
+- Fixed bug #49122 (undefined reference to mysqlnd_stmt_next_result on compile
+  with --with-mysqli and MySQL 6.0). (Jani)
+- Fixed bug #49108 (2nd scan_dir produces segfault). (Felipe)
+- Fixed bug #49098 (mysqli segfault on error). (Rasmus)
+- Fixed bug #49095 (proc_get_status['exitcode'] fails on win32). (Felipe)
+- Fixed bug #49092 (ReflectionFunction fails to work with functions in fully
+  qualified namespaces). (Kalle, Jani)
+- Fixed bug #49074 (private class static fields can be modified by using
+  reflection). (Jani)
+- Fixed bug #49072 (feof never returns true for damaged file in zip). (Pierre)
+- Fixed bug #49065 ("disable_functions" php.ini option does not work on
+  Zend extensions). (Stas)
+- Fixed bug #49064 (--enable-session=shared does not work: undefined symbol:
+  php_url_scanner_reset_vars). (Jani)
+- Fixed bug #49056 (parse_ini_file() regression in 5.3.0 when using non-ASCII
+  strings as option keys). (Jani)
+- Fixed bug #49052 (context option headers freed too early when using
+  --with-curlwrappers). (Jani)
+- Fixed bug #49047 (The function touch() fails on directories on Windows).
+  (Pierre)
+- Fixed bug #49032 (SplFileObject::fscanf() variables passed by reference).
+  (Jani)
+- Fixed bug #49027 (mysqli_options() doesn't work when using mysqlnd). (Andrey)
+- Fixed bug #49026 (proc_open() can bypass safe_mode_protected_env_vars
+  restrictions). (Ilia)
+- Fixed bug #49012 (phar tar signature algorithm reports as Unknown (0) in
+  getSignature() call). (Greg)
+- Fixed bug #49020 (phar misinterprets ustar long filename standard).
+  (Greg)
+- Fixed bug #49018 (phar tar stores long filenames wit prefix/name reversed).
+  (Greg)
+- Fixed bug #49014 (dechunked filter broken when serving more than 8192 bytes
+  in a chunk). (andreas dot streichardt at globalpark dot com, Ilia)
+- Fixed bug #49000 (PHP CLI in Interactive mode (php -a) crashes
+  when including files from function). (Stas)
+- Fixed bug #48994 (zlib.output_compression does not output HTTP headers when
+  set to a string value). (Jani)
+- Fixed bug #48980 (Crash when compiling with pdo_firebird). (Felipe)
+- Fixed bug #48962 (cURL does not upload files with specified filename).
+  (Ilia)
+- Fixed bug #48929 (Double \r\n after HTTP headers when "header" context
+  option is an array). (David Zülke)
+- Fixed bug #48913 (Too long error code strings in pdo_odbc driver).
+  (naf at altlinux dot ru, Felipe)
+- Fixed bug #48912 (Namespace causes unexpected strict behaviour with
+  extract()). (Dmitry)
+- Fixed bug #48909 (Segmentation fault in mysqli_stmt_execute()). (Andrey)
+- Fixed bug #48899 (is_callable returns true even if method does not exist in
+  parent class). (Felipe)
+- Fixed bug #48893 (Problems compiling with Curl). (Felipe)
+- Fixed bug #48872 (string.c: errors: duplicate case values). (Kalle)
+- Fixed bug #48854 (array_merge_recursive modifies arrays after first one).
+  (Felipe)
+- Fixed bug #48805 (IPv6 socket transport is not working). (Ilia)
+- Fixed bug #48802 (printf() returns incorrect outputted length). (Jani)
+- Fixed bug #48880 (Random Appearing open_basedir problem). (Rasmus, Gwynne)
+- Fixed bug #48791 (open office files always reported as corrupted). (Greg)
+- Fixed bug #48788 (RecursiveDirectoryIterator doesn't descend into symlinked
+  directories). (Ilia)
+- Fixed bug #48783 (make install will fail saying phar file exists). (Greg)
+- Fixed bug #48774 (SIGSEGVs when using curl_copy_handle()).
+- Fixed bug #48771 (rename() between volumes fails and reports no error on
+  Windows). (Pierre)
+- Fixed bug #48768 (parse_ini_*() crash with INI_SCANNER_RAW). (Jani)
+- Fixed bug #48763 (ZipArchive produces corrupt archive). (dani dot church at
+  gmail dot com, Pierre)
+- Fixed bug #48762 (IPv6 address filter still rejects valid address). (Felipe)
+- Fixed bug #48757 (ReflectionFunction::invoke() parameter issues). (Kalle)
+- Fixed bug #48754 (mysql_close() crash php when no handle specified).
+  (Johannes, Andrey)
+- Fixed bug #48752 (Crash during date parsing with invalid date). (Pierre)
+- Fixed bug #48746 (Unable to browse directories within Junction Points).
+  (Pierre, Kanwaljeet Singla)
+- Fixed bug #48745 (mysqlnd: mysql_num_fields returns wrong column count for
+  mysql_list_fields). (Andrey)
+- Fixed bug #48740 (PHAR install fails when INSTALL_ROOT is not the final
+  install location). (james dot cohen at digitalwindow dot com, Greg)
+- Fixed bug #48733 (CURLOPT_WRITEHEADER|CURLOPT_FILE|CURLOPT_STDERR warns on
+  files that have been opened with r+). (Ilia)
+- Fixed bug #48719 (parse_ini_*(): scanner_mode parameter is not checked for
+  sanity). (Jani)
+- Fixed bug #48718 (FILTER_VALIDATE_EMAIL does not allow numbers in domain
+  components). (Ilia)
+- Fixed bug #48681 (openssl signature verification for tar archives broken).
+  (Greg)
+- Fixed bug #48660 (parse_ini_*(): dollar sign as last character of value
+  fails). (Jani)
+- Fixed bug #48645 (mb_convert_encoding() doesn't understand hexadecimal
+  html-entities). (Moriyoshi)
+- Fixed bug #48637 ("file" fopen wrapper is overwritten when using
+- Fixed bug #48608 (Invalid libreadline version not detected during configure).
+  (Jani)
+- Fixed bug #48400 (imap crashes when closing stream opened with
+  OP_PROTOTYPE flag). (Jani)
+- Fixed bug #48377 (error message unclear on converting phar with existing
+  file). (Greg)
+- Fixed bug #48247 (Infinite loop and possible crash during startup with
+  errors when errors are logged). (Jani)
+- Fixed bug #48198 error: 'MYSQLND_LLU_SPEC' undeclared. Cause for #48780 and
+  #46952 - both fixed too. (Andrey)
+- Fixed bug #48189 (ibase_execute error in return param). (Kalle)
+- Fixed bug #48182 (ssl handshake fails during asynchronous socket connection).
+- Fixed bug #48116 (Fixed build with Openssl 1.0). (Pierre,
+  Al dot Smith at aeschi dot ch dot eu dot org)
+- Fixed bug #48057 (Only the date fields of the first row are fetched, others
+  are empty). (info at programmiernutte dot net)
+- Fixed bug #47481 (natcasesort() does not sort extended ASCII characters
+  correctly). (Herman Radtke)
+- Fixed bug #47351 (Memory leak in DateTime). (Derick, Tobias John)
+- Fixed bug #47273 (Encoding bug in SoapServer->fault). (Dmitry)
+- Fixed bug #46682 (touch() afield returns different values on windows).
+  (Pierre)
+- Fixed bug #46614 (Extended MySQLi class gives incorrect empty() result).
+  (Andrey)
+- Fixed bug #46020 (with Sun Java System Web Server 7.0 on HPUX, #define HPUX).
+  (Uwe Schindler)
+- Fixed bug #45905 (imagefilledrectangle() clipping error).
+  (markril at hotmail dot com, Pierre)
+- Fixed bug #45554 (Inconsistent behavior of the u format char). (Derick)
+- Fixed bug #45141 (setcookie will output expires years of >4 digits). (Ilia)
+- Fixed bug #44683 (popen crashes when an invalid mode is passed). (Pierre)
+- Fixed bug #43510 (stream_get_meta_data() does not return same mode as used
+  in fopen). (Jani)
+- Fixed bug #42434 (ImageLine w/ antialias = 1px shorter). (wojjie at gmail dot
+  com, Kalle)
+- Fixed bug #40013 (php_uname() does not return nodename on Netware (Guenter
+  Knauf)
+- Fixed bug #38091 (Mail() does not use FQDN when sending SMTP helo).
+  (Kalle, Rick Yorgason)
+- Fixed bug #28038 (Sent incorrect RCPT TO commands to SMTP server) (Garrett)
+- Fixed bug #27051 (Impersonation with FastCGI does not exec process as
+  impersonated user). (Pierre)
+- Fixed PECL bug #16842 (oci_error return false when NO_DATA_FOUND is raised).
+  (Chris Jones)
+30 Jun 2009, PHP 5.3.0
+- Upgraded bundled PCRE to version 7.9. (Nuno)
+- Upgraded bundled sqlite to version 3.6.15. (Scott)
+- Moved extensions to PECL (Derick, Lukas, Pierre, Scott):
+  . ext/dbase
+  . ext/fbsql
+  . ext/fdf
+  . ext/ncurses
+  . ext/mhash (BC layer is now entirely within ext/hash)
+  . ext/ming
+  . ext/msql
+  . ext/sybase (not maintained anymore, sybase_ct has to be used instead)
+- Removed the experimental RPL (master/slave) functions from mysqli. (Andrey)
+- Removed zend.ze1_compatibility_mode. (Dmitry)
+- Removed all zend_extension_* php.ini directives. Zend extensions are now
+  always loaded using zend_extension directive. (Derick)
+- Removed special treatment of "/tmp" in sessions for open_basedir.
+  Note: This undocumented behaviour was introduced in 5.2.2. (Alexey)
+- Removed shebang line check from CGI sapi (checked by scanner). (Dmitry)
+- Changed PCRE, Reflection and SPL extensions to be always enabled. (Marcus)
+- Changed md5() to use improved implementation. (Solar Designer, Dmitry)
+- Changed HTTP stream wrapper to accept any code between and including
+  200 to 399 as successful. (Mike, Noah Fontes)
+- Changed __call() to be invoked on private/protected method access, similar to
+  properties and __get(). (Andrei)
+- Changed dl() to be disabled by default. Enabled only when explicitly
+  registered by the SAPI. Currently enabled with cli, cgi and embed SAPIs.
+  (Dmitry)
+- Changed opendir(), dir() and scandir() to use default context when no context
+  argument is passed. (Sara)
+- Changed open_basedir to allow tightening in runtime contexts. (Sara)
+- Changed PHP/Zend extensions to use flexible build IDs. (Stas)
+- Changed error level E_ERROR into E_WARNING in Soap extension methods
+  parameter validation. (Felipe)
+- Changed openssl info to show the shared library version number. (Scott)
+- Changed floating point behaviour to consistently use double precision on all
+  platforms and with all compilers. (Christian Seiler)
+- Changed round() to act more intuitively when rounding to a certain precision
+  and round very large and very small exponents correctly. (Christian Seiler)
+- Changed session_start() to return false when session startup fails. (Jani)
+- Changed property_exists() to check the existence of a property independent of
+  accessibility (like method_exists()). (Felipe)
+- Changed array_reduce() to allow mixed $initial (Christian Seiler)
+- Improved PHP syntax and semantics:
+  . Added lambda functions and closures. (Christian Seiler, Dmitry)
+  . Added "jump label" operator (limited "goto"). (Dmitry, Sara)
+  . Added NOWDOC syntax. (Gwynne Raskind, Stas, Dmitry)
+  . Added HEREDOC syntax with double quotes. (Lars Strojny, Felipe)
+  . Added support for using static HEREDOCs to initialize static variables and
+    class members or constants. (Matt)
+  . Improved syntax highlighting and consistency for variables in double-quoted
+    strings and literal text in HEREDOCs and backticks. (Matt)
+  . Added "?:" operator. (Marcus)
+  . Added support for namespaces. (Dmitry, Stas, Gregory, Marcus)
+  . Added support for Late Static Binding. (Dmitry, Etienne Kneuss)
+  . Added support for __callStatic() magic method. (Sara)
+  . Added forward_static_call(_array) to complete LSB. (Mike Lively)
+  . Added support for dynamic access of static members using $foo::myFunc().
+    (Etienne Kneuss)
+  . Improved checks for callbacks. (Marcus)
+  . Added __DIR__ constant. (Lars Strojny)
+  . Added new error modes E_USER_DEPRECATED and E_DEPRECATED.
+    E_DEPRECATED is used to inform about stuff being scheduled for removal
+    in future PHP versions. (Lars Strojny, Felipe, Marcus)
+  . Added "request_order" INI variable to control specifically $_REQUEST
+    behavior. (Stas)
+  . Added support for exception linking. (Marcus)
+  . Added ability to handle exceptions in destructors. (Marcus)
+- Improved PHP runtime speed and memory usage:
+  . Substitute global-scope, persistent constants with their values at compile
+    time. (Matt)
+  . Optimized ZEND_SIGNED_MULTIPLY_LONG(). (Matt)
+  . Removed direct executor recursion. (Dmitry)
+  . Use fastcall calling convention in executor on x86. (Dmitry)
+  . Use IS_CV for direct access to $this variable. (Dmitry)
+  . Use ZEND_FREE() opcode instead of ZEND_SWITCH_FREE(IS_TMP_VAR). (Dmitry)
+  . Lazy EG(active_symbol_table) initialization. (Dmitry)
+  . Optimized ZEND_RETURN opcode to not allocate and copy return value if it is
+    not used. (Dmitry)
+  . Replaced all flex based scanners with re2c based scanners.
+    (Marcus, Nuno, Scott)
+  . Added garbage collector. (David Wang, Dmitry).
+  . Improved PHP binary size and startup speed with GCC4 visibility control.
+    (Nuno)
+  . Improved engine stack implementation for better performance and stability.
+    (Dmitry)
+  . Improved memory usage by moving constants to read only memory.
+    (Dmitry, Pierre)
+  . Changed exception handling. Now each op_array doesn't contain
+    ZEND_HANDLE_EXCEPTION opcode in the end. (Dmitry)
+  . Optimized require_once() and include_once() by eliminating fopen(3) on
+    second usage. (Dmitry)
+  . Optimized ZEND_FETCH_CLASS + ZEND_ADD_INTERFACE into single
+    ZEND_ADD_INTERFACE opcode. (Dmitry)
+  . Optimized string searching for a single character.
+    (Michal Dziemianko, Scott)
+  . Optimized interpolated strings to use one less opcode. (Matt)
+- Improved php.ini handling: (Jani)
+  . Added ".htaccess" style user-defined php.ini files support for CGI/FastCGI.
+  . Added support for special [PATH=/opt/httpd/www.example.com/] and
+    [HOST=www.example.com] sections. Directives set in these sections can
+    not be overridden by user-defined ini-files or during runtime.
+  . Added better error reporting for php.ini syntax errors.
+  . Allowed using full path to load modules using "extension" directive.
+  . Allowed "ini-variables" to be used almost everywhere ini php.ini files.
+  . Allowed using alphanumeric/variable indexes in "array" ini options.
+  . Added 3rd optional parameter to parse_ini_file() to specify the scanning
+    mode of INI_SCANNER_NORMAL or INI_SCANNER_RAW. In raw mode option values
+    and section values are treated as-is.
+  . Fixed get_cfg_var() to be able to return "array" ini options.
+  . Added optional parameter to ini_get_all() to only retrieve the current
+    value. (Hannes)
+- Improved Windows support:
+  . Update all libraries to their latest stable version. (Pierre, Rob, Liz,
+    Garrett).
+  . Added Windows support for stat(), touch(), filemtime(), filesize() and
+    related functions. (Pierre)
+  . Re-added socket_create_pair() for Windows in sockets extension. (Kalle)
+  . Added inet_pton() and inet_ntop() also for Windows platforms.
+    (Kalle, Pierre)
+  . Added mcrypt_create_iv() for Windows platforms. (Pierre)
+  . Added ACL Cache support on Windows.
+    (Kanwaljeet Singla, Pierre, Venkat Raman Don)
+  . Added constants based on Windows' GetVersionEx information.
+    PHP_WINDOWS_VERSION_* and PHP_WINDOWS_NT_*. (Pierre)
+  . Added support for ACL (is_writable, is_readable, reports now correct
+    results) on Windows. (Pierre, Venkat Raman Don, Kanwaljeet Singla)
+  . Added support for fnmatch() on Windows. (Pierre)
+  . Added support for time_nanosleep() and time_sleep_until() on Windows.
+    (Pierre)
+  . Added support for symlink(), readlink(), linkinfo() and link() on Windows.
+    They are available only when the running platform supports them. (Pierre)
+  . the GMP extension now relies on MPIR instead of the GMP library. (Pierre)
+  . Added Windows support for stream_socket_pair(). (Kalle)
+  . Drop all external dependencies for the core features. (Pierre)
+  . Drastically improve the build procedure (Pierre, Kalle, Rob):
+    . VC9 (Visual C++ 2008) or later support
+    . Initial experimental x64 support
+  . MSI installer now supports all recent Windows versions, including
+    Windows 7. (John, Kanwaljeet Singla)
+- Improved and cleaned CGI code:
+  . FastCGI is now always enabled and cannot be disabled.
+    See sapi/cgi/CHANGES for more details. (Dmitry)
+  . Added CGI SAPI -T option which can be used to measure execution
+    time of script repeated several times. (Dmitry)
+- Improved streams:
+  . Fixed confusing error message on failure when no errors are logged. (Greg)
+  . Added stream_supports_lock() function. (Benjamin Schulz)
+  . Added context parameter for copy() function. (Sara)
+  . Added "glob://" stream wrapper. (Marcus)
+  . Added "params" as optional parameter for stream_context_create(). (Sara)
+  . Added ability to use stream wrappers in include_path. (Gregory, Dmitry)
+- Improved DNS API
+  . Added Windows support for dns_check_record(), dns_get_mx(), checkdnsrr() and
+    getmxrr(). (Pierre)
+  . Added support for old style DNS functions (supports OSX and FBSD). (Scott)
+  . Added a new "entries" array in dns_check_record() containing the TXT
+    elements. (Felipe, Pierre)
+- Improved hash extension:
+  . Changed mhash to be a wrapper layer around the hash extension. (Scott)
+  . Added hash_copy() function. (Tony)
+  . Added sha224 hash algorithm to the hash extension. (Scott)
+- Improved IMAP support (Pierre):
+  . Added imap_gc() to clear the imap cache
+  . Added imap_utf8_to_mutf7() and imap_mutf7_to_utf8()
+- Improved mbstring extension:
+  . Added "mbstring.http_output_conv_mimetypes" INI directive that allows
+    common non-text types such as "application/xhtml+xml" to be converted
+    by mb_output_handler(). (Moriyoshi)
+- Improved OCI8 extension (Chris Jones/Oracle Corp.):
+  . Added Database Resident Connection Pooling (DRCP) and Fast
+    Application Notification (FAN) support.
+  . Added support for Oracle External Authentication (not supported
+    on Windows).
+  . Improve persistent connection handling of restarted DBs.
+  . Added SQLT_AFC (aka CHAR datatype) support to oci_bind_by_name.
+  . Fixed bug #45458 (Numeric keys for associative arrays are not
+    handled properly)
+  . Fixed bug #41069 (Segmentation fault with query over DB link).
+  . Fixed define of SQLT_BDOUBLE and SQLT_BFLOAT constants with Oracle
+    10g ORACLE_HOME builds.
+  . Changed default value of oci8.default_prefetch from 10 to 100.
+  . Fixed PECL Bug #16035 (OCI8: oci_connect without ORACLE_HOME defined causes
+    segfault) (Chris Jones/Oracle Corp.)
+  . Fixed PECL Bug #15988 (OCI8: sqlnet.ora isn't read with older Oracle
+    libraries) (Chris Jones/Oracle Corp.)
+  . Fixed PECL Bug #14268 (Allow "pecl install oci8" command to "autodetect" an
+    Instant Client RPM install) (Chris Jones/Oracle Corp.)
+  . Fixed PECL bug #12431 (OCI8 ping functionality is broken).
+  . Allow building (e.g from PECL) the PHP 5.3-based OCI8 code with
+    PHP 4.3.9 onwards.
+  . Provide separate extensions for Oracle 11g and 10g on Windows.
+    (Pierre, Chris)
+- Improved OpenSSL extension:
+  . Added support for OpenSSL digest and cipher functions. (Dmitry)
+  . Added access to internal values of DSA, RSA and DH keys. (Dmitry)
+  . Fixed a memory leak on openssl_decrypt(). (Henrique)
+  . Fixed segfault caused by openssl_pkey_new(). (Henrique)
+  . Fixed bug caused by uninitilized variables in openssl_pkcs7_encrypt() and
+    openssl_pkcs7_sign(). (Henrique)
+  . Fixed error message in openssl_seal(). (Henrique)
+- Improved pcntl extension: (Arnaud)
+  . Added pcntl_signal_dispatch().
+  . Added pcntl_sigprocmask().
+  . Added pcntl_sigwaitinfo().
+  . Added pcntl_sigtimedwait().
+- Improved SOAP extension:
+  . Added support for element names in context of XMLSchema's <any>. (Dmitry)
+  . Added ability to use Traversable objects instead of plain arrays.
+    (Joshua Reese, Dmitry)
+  . Fixed possible crash bug caused by an uninitialized value. (Zdash Urf)
+- Improved SPL extension:
+  . Added SPL to list of standard extensions that cannot be disabled. (Marcus)
+  . Added ability to store associative information with objects in
+    SplObjectStorage. (Marcus)
+  . Added ArrayAccess support to SplObjectStorage. (Marcus)
+  . Added SplDoublyLinkedList, SplStack, SplQueue classes. (Etienne)
+  . Added FilesystemIterator. (Marcus)
+  . Added GlobIterator. (Marcus)
+  . Added SplHeap, SplMinHeap, SplMaxHeap, SplPriorityQueue classes. (Etienne)
+  . Added new parameter $prepend to spl_autoload_register(). (Etienne)
+  . Added SplFixedArray. (Etienne, Tony)
+  . Added delaying exceptions in SPL's autoload mechanism. (Marcus)
+  . Added RecursiveTreeIterator. (Arnaud, Marcus)
+  . Added MultipleIterator. (Arnaud, Marcus, Johannes)
+- Improved Zend Engine:
+  . Added "compact" handler for Zend MM storage. (Dmitry)
+  . Added "+" and "*" specifiers to zend_parse_parameters(). (Andrei)
+  . Added concept of "delayed early binding" that allows opcode caches to
+    perform class declaration (early and/or run-time binding) in exactly
+    the same order as vanilla PHP. (Dmitry)
+- Improved crypt() function: (Pierre)
+  . Added Blowfish and extended DES support. (Using Blowfish implementation
+    from Solar Designer).
+  . Made crypt features portable by providing our own implementations
+    for crypt_r and the algorithms which are used when OS does not provide
+    them. PHP implementations are always used for Windows builds.
+- Deprecated session_register(), session_unregister() and
+  session_is_registered(). (Hannes)
+- Deprecated define_syslog_variables(). (Kalle)
+- Deprecated ereg extension. (Felipe)
+- Added new extensions:
+  . Added Enchant extension as a way to access spell checkers. (Pierre)
+  . Added fileinfo extension as replacement for mime_magic extension. (Derick)
+  . Added intl extension for Internationalization. (Ed B., Vladimir I.,
+    Dmitry L., Stanislav M., Vadim S., Kirti V.)
+  . Added mysqlnd extension as replacement for libmysql for ext/mysql, mysqli
+    and PDO_mysql. (Andrey, Johannes, Ulf)
+  . Added phar extension for handling PHP Archives. (Greg, Marcus, Steph)
+  . Added SQLite3 extension. (Scott)
+- Added new date/time functionality: (Derick)
+  . date_parse_from_format(): Parse date/time strings according to a format.
+  . date_create_from_format()/DateTime::createFromFormat(): Create a date/time
+    object by parsing a date/time string according to a given format.
+  . date_get_last_errors()/DateTime::getLastErrors(): Return a list of warnings
+    and errors that were found while parsing a date/time string through:
+    . strtotime() / new DateTime
+    . date_create_from_format() / DateTime::createFromFormat()
+    . date_parse_from_format().
+  . support for abbreviation and offset based timezone specifiers for
+    the 'e' format specifier, DateTime::__construct(), DateTime::getTimeZone()
+    and DateTimeZone::getName().
+  . support for selectively listing timezone identifiers by continent or
+    country code through timezone_identifiers_list() /
+    DateTimezone::listIdentifiers().
+  . timezone_location_get() / DateTimezone::getLocation() for retrieving
+    location information from timezones.
+  . date_timestamp_set() / DateTime::setTimestamp() to set a Unix timestamp
+    without invoking the date parser. (Scott, Derick)
+  . date_timestamp_get() / DateTime::getTimestamp() to retrieve the Unix
+    timestamp belonging to a date object.
+  . two optional parameters to timezone_transitions_get() /
+    DateTimeZone::getTranstions() to limit the range of transitions being
+    returned.
+  . support for "first/last day of <month>" style texts.
+  . support for date/time strings returned by MS SQL.
+  . support for serialization and unserialization of DateTime objects.
+  . support for diffing date/times through date_diff() / DateTime::diff().
+  . support for adding/subtracting weekdays with strtotime() and
+    DateTime::modify().
+  . DateInterval class to represent the difference between two date/times.
+  . support for parsing ISO intervals for use with DateInterval.
+  . date_add() / DateTime::add(), date_sub() / DateTime::sub() for applying an
+    interval to an existing date/time.
+  . proper support for "this week", "previous week"/"last week" and "next week"
+    phrases so that they actually mean the week and not a seven day period
+    around the current day.
+  . support for "<xth> <weekday> of" and "last <weekday> of" phrases to be used
+    with months - like in "last saturday of februari 2008".
+  . support for "back of <hour>" and "front of <hour>" phrases that are used in
+    Scotland.
+  . DatePeriod class which supports iterating over a DateTime object applying
+    DateInterval on each iteration, up to an end date or limited by maximum
+    number of occurences.
+- Added compatibility mode in GD, imagerotate, image(filled)ellipse
+  imagefilter, imageconvolution and imagecolormatch are now always enabled.
+  (Pierre)
+- Added array_replace() and array_replace_recursive() functions. (Matt)
+- Added ReflectionProperty::setAccessible() method that allows non-public
+  property's values to be read through ::getValue() and set through
+  ::setValue(). (Derick, Sebastian)
+- Added msg_queue_exists() function to sysvmsg extension. (Benjamin Schulz)
+- Added Firebird specific attributes that can be set via PDO::setAttribute()
+  to control formatting of date/timestamp columns: PDO::FB_ATTR_DATE_FORMAT,
+  PDO::FB_ATTR_TIME_FORMAT and PDO::FB_ATTR_TIMESTAMP_FORMAT. (Lars W)
+- Added gmp_testbit() function. (Stas)
+- Added icon format support to getimagesize(). (Scott)
+- Added LDAP_OPT_NETWORK_TIMEOUT option for ldap_set_option() to allow
+  setting network timeout (FR #42837). (Jani)
+- Added optional escape character parameter to fgetcsv(). (David Soria Parra)
+- Added an optional parameter to strstr() and stristr() for retrieval of either
+  the part of haystack before or after first occurrence of needle.
+  (Johannes, Felipe)
+- Added xsl->setProfiling() for profiling stylesheets. (Christian)
+- Added long-option feature to getopt() and made getopt() available also on
+  win32 systems by adding a common getopt implementation into core.
+  (David Soria Parra, Jani)
+- Added support for optional values, and = as separator, in getopt(). (Hannes)
+- Added lcfirst() function. (David C)
+- Added PREG_BAD_UTF8_OFFSET_ERROR constant. (Nuno)
+- Added native support for asinh(), acosh(), atanh(), log1p() and expm1().
+  (Kalle)
+- Added LIBXML_LOADED_VERSION constant (libxml2 version currently used). (Rob)
+- Added JSON_FORCE_OBJECT flag to json_encode(). (Scott, Richard Quadling)
+- Added timezone_version_get() to retrieve the version of the used timezone
+  database. (Derick)
+- Added 'n' flag to fopen to allow passing O_NONBLOCK to the underlying
+  open(2) system call. (Mikko)
+- Added "dechunk" filter which can decode HTTP responses with chunked
+  transfer-encoding. HTTP streams use this filter automatically in case
+  "Transfer-Encoding: chunked" header is present in response. It's possible to
+  disable this behaviour using "http"=>array("auto_decode"=>0) in stream
+  context. (Dmitry)
+- Added support for CP850 encoding in mbstring extension.
+  (Denis Giffeler, Moriyoshi)
+- Added stream_cast() and stream_set_options() to user-space stream wrappers,
+  allowing stream_select(), stream_set_blocking(), stream_set_timeout() and
+  stream_set_write_buffer() to work with user-space stream wrappers. (Arnaud)
+- Added header_remove() function. (chsc at peytz dot dk, Arnaud)
+- Added stream_context_get_params() function. (Arnaud)
+- Added optional parameter "new" to sybase_connect(). (Timm)
+- Added parse_ini_string() function. (grange at lemonde dot fr, Arnaud)
+- Added str_getcsv() function. (Sara)
+- Added openssl_random_pseudo_bytes() function. (Scott)
+- Added ability to send user defined HTTP headers with SOAP request.
+  (Brian J.France, Dmitry)
+- Added concatenation option to bz2.decompress stream filter.
+  (Keisial at gmail dot com, Greg)
+- Added support for using compressed connections with PDO_mysql. (Johannes)
+- Added the ability for json_decode() to take a user specified depth. (Scott)
+- Added support for the mysql_stmt_next_result() function from libmysql.
+  (Andrey)
+- Added function preg_filter() that does grep and replace in one go. (Marcus)
+- Added system independent realpath() implementation which caches intermediate
+  directories in realpath-cache. (Dmitry)
+- Added optional clear_realpath_cache and filename parameters to
+  clearstatcache(). (Jani, Arnaud)
+- Added litespeed SAPI module. (George Wang)
+- Added ext/hash support to ext/session's ID generator. (Sara)
+- Added quoted_printable_encode() function. (Tony)
+- Added stream_context_set_default() function. (Davey Shafik)
+- Added optional "is_xhtml" parameter to nl2br() which makes the function
+  output <br> when false and <br /> when true (FR #34381). (Kalle)
+- Added PHP_MAXPATHLEN constant (maximum length of a path). (Pierre)
+- Added support for SSH via libssh2 in cURL. (Pierre)
+- Added support for gray levels PNG image with alpha in GD extension. (Pierre)
+- Added support for salsa hashing functions in HASH extension. (Scott)
+- Added DOMNode::getLineNo to get line number of parsed node. (Rob)
+- Added table info to PDO::getColumnMeta() with SQLite. (Martin Jansen, Scott)
+- Added mail logging functionality that allows logging of mail sent via
+  mail() function. (Ilia)
+- Added json_last_error() to return any error information from json_decode().
+  (Scott)
+- Added gethostname() to return the current system host name. (Ilia)
+- Added shm_has_var() function. (Mike)
+- Added depth parameter to json_decode() to lower the nesting depth from the
+  maximum if required. (Scott)
+- Added pixelation support in imagefilter(). (Takeshi Abe, Kalle)
+- Added SplObjectStorage::addAll/removeAll. (Etienne)
+- Implemented FR #41712 (curl progress callback: CURLOPT_PROGRESSFUNCTION).
+  (sdteffen[at]gmail[dot].com, Pierre)
+- Implemented FR #47739 (Missing cURL option do disable IPv6). (Pierre)
+- Implemented FR #39637 (Missing cURL option CURLOPT_FTP_FILEMETHOD). (Pierre)
+- Fixed an issue with ReflectionProperty::setAccessible().
+  (Sebastian, Roman Borschel)
+- Fixed html_entity_decode() incorrectly converting numeric html entities
+  to different characters with cp1251 and cp866. (Scott)
+- Fixed an issue in date() where a : was printed for the O modifier after a P
+  modifier was used. (Derick)
+- Fixed exec() on Windows to not eat the first and last double quotes. (Scott)
+- Fixed readlink on Windows in thread safe SAPI (apache2.x etc.). (Pierre)
+- Fixed a bug causing miscalculations with the "last <weekday> of <n> month"
+  relative time string. (Derick)
+- Fixed bug causing the algorithm parameter of mhash() to be modified. (Scott)
+- Fixed invalid calls to free when internal fileinfo magic file is used. (Scott)
+- Fixed memory leak inside wddx_add_vars() function. (Felipe)
+- Fixed check in recode extension to allow builing of recode and mysql
+  extensions when using a recent libmysql. (Johannes)
+- Fixed PECL bug #12794 (PDOStatement->nextRowset() doesn't work). (Johannes)
+- Fixed PECL bug #12401 (Add support for ATTR_FETCH_TABLE_NAMES). (Johannes)
+- Fixed bug #48696 (ldap_read() segfaults with invalid parameters). (Felipe)
+- Fixed bug #48643 (String functions memory issue). (Dmitry)
+- Fixed bug #48641 (tmpfile() uses old parameter parsing).
+  (crrodriguez at opensuse dot org)
+- Fixed bug #48624 (.user.ini never gets parsed). (Pierre)
+- Fixed bug #48620 (X-PHP-Originating-Script assumes no trailing CRLF in
+  existing headers). (Ilia)
+- Fixed bug #48578 (Can't build 5.3 on FBSD 4.11). (Rasmus)
+- Fixed bug #48535 (file_exists returns false when impersonate is used).
+  (Kanwaljeet Singla, Venkat Raman Don)
+- Fixed bug #48493 (spl_autoload_register() doesn't work correctly when
+  prepending functions). (Scott)
+- Fixed bug #48215 (Calling a method with the same name as the parent class
+  calls the constructor). (Scott)
+- Fixed bug #48200 (compile failure with mbstring.c when
+  --enable-zend-multibyte is used). (Jani)
+- Fixed bug #48188 (Cannot execute a scrollable cursors twice with PDO_PGSQL).
+  (Matteo)
+- Fixed bug #48185 (warning: value computed is not used in
+  pdo_sqlite_stmt_get_col line 271). (Matteo)
+- Fixed bug #48087 (call_user_method() invalid free of arguments). (Felipe)
+- Fixed bug #48060 (pdo_pgsql - large objects are returned as empty). (Matteo)
+- Fixed bug #48034 (PHP crashes when script is 8192 (8KB) bytes long). (Dmitry)
+- Fixed bug #48004 (Error handler prevents creation of default object). (Dmitry)
+- Fixed bug #47880 (crashes in call_user_func_array()). (Dmitry)
+- Fixed bug #47856 (stristr() converts needle to lower-case). (Ilia)
+- Fixed bug #47851 (is_callable throws fatal error). (Dmitry)
+- Fixed bug #47816 (pcntl tests failing on NetBSD). (Matteo)
+- Fixed bug #47779 (Wrong value for SIG_UNBLOCK and SIG_SETMASK constants).
+  (Matteo)
+- Fixed bug #47771 (Exception during object construction from arg call calls
+  object's destructor). (Dmitry)
+- Fixed bug #47767 (include_once does not resolve windows symlinks or junctions)
+- Fixed bug #47757 (rename JPG to JPEG in phpinfo). (Pierre)
+- Fixed bug #47745 (FILTER_VALIDATE_INT doesn't allow minimum integer). (Dmitry)
+- Fixed bug #47714 (autoloading classes inside exception_handler leads to
+  crashes). (Dmitry)
+- Fixed bug #47671 (Cloning SplObjectStorage instances). (Etienne)
+- Fixed bug #47664 (get_class returns NULL instead of FALSE). (Dmitry)
+- Fixed bug #47662 (Support more than 127 subpatterns in preg_match). (Nuno)
+- Fixed bug #47596 (Bus error on parsing file). (Dmitry)
+- Fixed bug #47572 (Undefined constant causes segmentation fault). (Felipe)
+- Fixed bug #47560 (explode()'s limit parameter odd behaviour). (Matt)
+- Fixed bug #47549 (get_defined_constants() return array with broken array
+  categories). (Ilia)
+- Fixed bug #47535 (Compilation failure in ps_fetch_from_1_to_8_bytes()).
+  (Johannes)
+- Fixed bug #47534 (RecursiveDiteratoryIterator::getChildren ignoring
+  CURRENT_AS_PATHNAME). (Etienne)
+- Fixed bug #47443 (metaphone('scratch') returns wrong result). (Felipe)
+- Fixed bug #47438 (mysql_fetch_field ignores zero offset). (Johannes)
+- Fixed bug #47398 (PDO_Firebird doesn't implements quoter correctly). (Felipe)
+- Fixed bug #47390 (odbc_fetch_into - BC in php 5.3.0). (Felipe)
+- Fixed bug #47359 (Use the expected unofficial mimetype for bmp files). (Scott)
+- Fixed bug #47343 (gc_collect_cycles causes a segfault when called within a
+  destructor in one case). (Dmitry)
+- Fixed bug #47320 ($php_errormsg out of scope in functions). (Dmitry)
+- Fixed bug #47318 (UMR when trying to activate user config). (Pierre)
+- Fixed bug #47243 (OCI8: Crash at shutdown on Windows) (Chris Jones/Oracle
+  Corp.)
+- Fixed bug #47231 (offsetGet error using incorrect offset). (Etienne)
+- Fixed bug #47229 (preg_quote() should escape the '-' char). (Nuno)
+- Fixed bug #47165 (Possible memory corruption when passing return value by
+  reference). (Dmitry)
+- Fixed bug #47087 (Second parameter of mssql_fetch_array()). (Felipe)
+- Fixed bug #47085 (rename() returns true even if the file in PHAR does not
+  exist). (Greg)
+- Fixed bug #47050 (mysqli_poll() modifies improper variables). (Johannes)
+- Fixed bug #47045 (SplObjectStorage instances compared with ==). (Etienne)
+- Fixed bug #47038 (Memory leak in include). (Dmitry)
+- Fixed bug #47031 (Fix constants in DualIterator example). (Etienne)
+- Fixed bug #47021 (SoapClient stumbles over WSDL delivered with
+  "Transfer-Encoding: chunked"). (Dmitry)
+- Fixed bug #46994 (OCI8: CLOB size does not update when using CLOB IN OUT param
+  in stored procedure) (Chris Jones/Oracle Corp.)
+- Fixed bug #46979 (use with non-compound name *has* effect). (Dmitry)
+- Fixed bug #46957 (The tokenizer returns deprecated values). (Felipe)
+- Fixed bug #46944 (UTF-8 characters outside the BMP aren't encoded correctly).
+  (Scott)
+- Fixed bug #46897 (ob_flush() should fail to flush unerasable buffers).
+  (David C.)
+- Fixed bug #46849 (Cloning DOMDocument doesn't clone the properties). (Rob)
+- Fixed bug #46847 (phpinfo() is missing some settings). (Hannes)
+- Fixed bug #46844 (php scripts or included files with first line starting
+  with # have the 1st line missed from the output). (Ilia)
+- Fixed bug #46817 (tokenizer misses last single-line comment (PHP 5.3+, with
+  re2c lexer)). (Matt, Shire)
+- Fixed bug #46811 (ini_set() doesn't return false on failure). (Hannes)
+- Fixed bug #46763 (mb_stristr() wrong output when needle does not exist).
+  (Henrique M. Decaria)
+- Fixed bug #46755 (warning: use statement with non-compound name). (Dmitry)
+- Fixed bug #46746 (xmlrpc_decode_request outputs non-suppressable error when
+  given bad data). (Ilia)
+- Fixed bug #46738 (Segfault when mb_detect_encoding() fails). (Scott)
+- Fixed bug #46731 (Missing validation for the options parameter of the
+  imap_fetch_overview() function). (Ilia)
+- Fixed bug #46711 (cURL curl_setopt leaks memory in foreach loops). (magicaltux
+  [at] php [dot] net)
+- Fixed bug #46701 (Creating associative array with long values in the key fails
+  on 32bit linux). (Shire)
+- Fixed bug #46681 (mkdir() fails silently on PHP 5.3). (Hannes)
+- Fixed bug #46653 (can't extend mysqli). (Johannes)
+- Fixed bug #46646 (Restrict serialization on some internal classes like Closure
+  and SplFileInfo using exceptions). (Etienne)
+- Fixed bug #46623 (OCI8: phpinfo doesn't show compile time ORACLE_HOME with
+  phpize) (Chris Jones/Oracle Corp.)
+- Fixed bug #46578 (strip_tags() does not honor end-of-comment when it
+  encounters a single quote). (Felipe)
+- Fixed bug #46546 (Segmentation fault when using declare statement with
+  non-string value). (Felipe)
+- Fixed bug #46542 (Extending PDO class with a __call() function doesn't work as
+  expected). (Johannes)
+- Fixed bug #46421 (SplFileInfo not correctly handling /). (Etienne)
+- Fixed bug #46347 (parse_ini_file() doesn't support * in keys). (Nuno)
+- Fixed bug #46268 (DateTime::modify() does not reset relative time values).
+  (Derick)
+- Fixed bug #46241 (stacked error handlers, internal error handling in general).
+  (Etienne)
+- Fixed bug #46238 (Segmentation fault on static call with empty string method).
+  (Felipe)
+- Fixed bug #46192 (ArrayObject with objects as storage serialization).
+  (Etienne)
+- Fixed bug #46185 (importNode changes the namespace of an XML element). (Rob)
+- Fixed bug #46178 (memory leak in ext/phar). (Greg)
+- Fixed bug #46160 (SPL - Memory leak when exception is thrown in offsetSet).
+  (Felipe)
+- Fixed Bug #46147 (after stream seek, appending stream filter reads incorrect
+  data). (Greg)
+- Fixed bug #46127 (php_openssl_tcp_sockop_accept forgets to set context on
+  accepted stream) (Mark Karpeles, Pierre)
+- Fixed bug #46115 (Memory leak when calling a method using Reflection).
+  (Dmitry)
+- Fixed bug #46110 (XMLWriter - openmemory() and openuri() leak memory on
+  multiple calls). (Ilia)
+- Fixed bug #46108 (DateTime - Memory leak when unserializing). (Felipe)
+- Fixed bug #46106 (Memory leaks when using global statement). (Dmitry)
+- Fixed bug #46099 (Xsltprocessor::setProfiling - memory leak). (Felipe, Rob).
+- Fixed bug #46087 (DOMXPath - segfault on destruction of a cloned object).
+  (Ilia)
+- Fixed bug #46048 (SimpleXML top-level @attributes not part of iterator).
+  (David C.)
+- Fixed bug #46044 (Mysqli - wrong error message). (Johannes)
+- Fixed bug #46042 (memory leaks with reflection of mb_convert_encoding()).
+  (Ilia)
+- Fixed bug #46039 (ArrayObject iteration is slow). (Arnaud)
+- Fixed bug #46033 (Direct instantiation of SQLite3stmt and SQLite3result cause
+  a segfault.) (Scott)
+- Fixed bug #45991 (Ini files with the UTF-8 BOM are treated as invalid).
+  (Scott)
+- Fixed bug #45989 (json_decode() doesn't return NULL on certain invalid
+  strings). (magicaltux, Scott)
+- Fixed bug #45976 (Moved SXE from SPL to SimpleXML). (Etienne)
+- Fixed bug #45928 (large scripts from stdin are stripped at 16K border).
+  (Christian Schneider, Arnaud)
+- Fixed bug #45911 (Cannot disable ext/hash). (Arnaud)
+- Fixed bug #45907 (undefined reference to 'PHP_SHA512Init'). (Greg)
+- Fixed bug #45826 (custom ArrayObject serialization). (Etienne)
+- Fixed bug #45820 (Allow empty keys in ArrayObject). (Etienne)
+- Fixed bug #45791 (json_decode() doesn't convert 0e0 to a double). (Scott)
+- Fixed bug #45786 (FastCGI process exited unexpectedly). (Dmitry)
+- Fixed bug #45757 (FreeBSD4.11 build failure: failed include; stdint.h).
+  (Hannes)
+- Fixed bug #45743 (property_exists fails to find static protected member in
+  child class). (Felipe)
+- Fixed bug #45717 (Fileinfo/libmagic build fails, missing err.h and getopt.h).
+  (Derick)
+- Fixed bug #45706 (Unserialization of classes derived from ArrayIterator
+  fails). (Etienne, Dmitry)
+- Fixed bug #45696 (Not all DateTime methods allow method chaining). (Derick)
+- Fixed bug #45682 (Unable to var_dump(DateInterval)). (Derick)
+- Fixed bug #45447 (Filesystem time functions on Vista and server 2008).
+  (Pierre)
+- Fixed bug #45432 (PDO: persistent connection leak). (Felipe)
+- Fixed bug #45392 (ob_start()/ob_end_clean() and memory_limit). (Ilia)
+- Fixed bug #45384 (parse_ini_file will result in parse error with no trailing
+  newline). (Arnaud)
+- Fixed bug #45382 (timeout bug in stream_socket_enable_crypto). (vnegrier at
+  optilian dot com, Ilia)
+- Fixed bug #45044 (relative paths not resolved correctly). (Dmitry)
+- Fixed bug #44861 (scrollable cursor don't work with pgsql). (Matteo)
+- Fixed bug #44842 (parse_ini_file keys that start/end with underscore).
+  (Arnaud)
+- Fixed bug #44575 (parse_ini_file comment # line problems). (Arnaud)
+- Fixed bug #44409 (PDO::FETCH_SERIALIZE calls __construct()). (Matteo)
+- Fixed bug #44173 (PDO->query() parameter parsing/checking needs an update).
+  (Matteo)
+- Fixed bug #44154 (pdo->errorInfo() always have three elements in the returned
+  array). (David C.)
+- Fixed bug #44153 (pdo->errorCode() returns NULL when there are no errors).
+  (David C.)
+- Fixed bug #44135 (PDO MySQL does not support CLIENT_FOUND_ROWS). (Johannes,
+  chx1975 at gmail dot com)
+- Fixed bug #44100 (Inconsistent handling of static array declarations with
+  duplicate keys). (Dmitry)
+- Fixed bug #43831 ($this gets mangled when extending PDO with persistent
+  connection). (Felipe)
+- Fixed bug #43817 (opendir() fails on Windows directories with parent directory
+  unaccessible). (Dmitry)
+- Fixed bug #43069 (SoapClient causes 505 HTTP Version not supported error
+  message). (Dmitry)
+- Fixed bug #43008 (php://filter uris ignore url encoded filternames and can't
+  handle slashes). (Arnaud)
+- Fixed bug #42362 (HTTP status codes 204 and 304 should not be gzipped).
+  (Scott, Edward Z. Yang)
+- Fixed bug #41874 (separate STDOUT and STDERR in exec functions). (Kanwaljeet
+  Singla, Venkat Raman Don, Pierre)
+- Fixed bug #41534 (SoapClient over HTTPS fails to reestablish connection).
+  (Dmitry)
+- Fixed bug #38802 (max_redirects and ignore_errors). (patch by
+  datibbaw at php.net)
+- Fixed bug #35980 (touch() works on files but not on directories). (Pierre)
+17 Jun 2009, PHP 5.2.10
+- Updated timezone database to version 2009.9 (2009i) (Derick)
+- Added "ignore_errors" option to http fopen wrapper. (David Zulke, Sara)
+- Added new CURL options CURLOPT_REDIR_PROTOCOLS, CURLOPT_PROTOCOLS,
+  and CURLPROTO_* for redirect fixes in CURL 7.19.4. (Yoram Bar Haim, Stas)
+- Added support for Sun CC (FR #46595 and FR #46513). (David Soria Parra)
+- Changed default value of array_unique()'s optional sorting type parameter
+  back to SORT_STRING to fix backwards compatibility breakage introduced in
+  PHP 5.2.9. (Moriyoshi)
+- Fixed memory corruptions while reading properties of zip files. (Ilia)
+- Fixed memory leak in ob_get_clean/ob_get_flush. (Christian)
+- Fixed segfault on invalid session.save_path. (Hannes)
+- Fixed leaks in imap when a mail_criteria is used. (Pierre)
+- Fixed missing erealloc() in fix for Bug #40091 in spl_autoload_register. (Greg)
+- Fixed bug #48562 (Reference recursion causes segfault when used in
+  wddx_serialize_vars()). (Felipe)
+- Fixed bug #48557 (Numeric string keys in Apache Hashmaps are not cast to
+  integers). (David Zuelke)
+- Fixed bug #48518 (curl crashes when writing into invalid file handle). (Tony)
+- Fixed bug #48514 (cURL extension uses same resource name for simple and
+  multi APIs). (Felipe)
+- Fixed bug #48469 (ldap_get_entries() leaks memory on empty search
+  results). (Patrick)
+- Fixed bug #48456 (CPPFLAGS not restored properly in phpize.m4). (Jani,
+  spisek at kerio dot com)
+- Fixed bug #48448 (Compile failure under IRIX 6.5.30 building cast.c).
+  (Kalle)
+- Fixed bug #48441 (ldap_search() sizelimit, timelimit and deref options
+  persist). (Patrick)
+- Fixed bug #48434 (Improve memory_get_usage() accuracy). (Arnaud)
+- Fixed bug #48416 (Force a cache limit in ereg() to stop excessive memory
+  usage). (Scott)
+- Fixed bug #48409 (Crash when exception is thrown while passing function
+  arguments). (Arnaud)
+  files). (Pierre)
+- Fixed bug #48359 (Script hangs on snmprealwalk if OID is not increasing).
+  (Ilia, simonov at gmail dot com)
+- Fixed bug #48336 (ReflectionProperty::getDeclaringClass() does not work
+  with redeclared property).
+  (patch by Markus dot Lidel at shadowconnect dot com)
+- Fixed bug #48326 (constant MSG_DONTWAIT not defined). (Arnaud)
+- Fixed bug #48313 (fgetcsv() does not return null for empty rows). (Ilia)
+- Fixed bug #48309 (stream_copy_to_stream() and fpasstru() do not update
+  stream position of plain files). (Arnaud)
+- Fixed bug #48307 (stream_copy_to_stream() copies 0 bytes when $source is a
+  socket). (Arnaud)
+- Fixed bug #48273 (snmp*_real_walk() returns SNMP errors as values).
+  (Ilia, lytboris at gmail dot com)
+- Fixed bug #48256 (Crash due to double-linking of history.o).
+  (tstarling at wikimedia dot org)
+- Fixed bug #48248 (SIGSEGV when access to private property via &__get).
+  (Felipe)
+- Fixed bug #48247 (Crash on errors during startup). (Stas)
+- Fixed bug #48240 (DBA Segmentation fault dba_nextkey). (Felipe)
+- Fixed bug #48224 (Incorrect shuffle in array_rand). (Etienne)
+- Fixed bug #48221 (memory leak when passing invalid xslt parameter).
+  (Felipe)
+- Fixed bug #48207 (CURLOPT_(FILE|WRITEHEADER options do not error out when
+  working with a non-writable stream). (Ilia)
+- Fixed bug #48206 (Iterating over an invalid data structure with
+  RecursiveIteratorIterator leads to a segfault). (Scott)
+- Fixed bug #48204 (xmlwriter_open_uri() does not emit warnings on invalid
+  paths). (Ilia)
+- Fixed bug #48203 (Crash when CURLOPT_STDERR is set to regular file). (Jani)
+- Fixed bug #48202 (Out of Memory error message when passing invalid file
+  path) (Pierre)
+- Fixed bug #48156 (Added support for lcov v1.7). (Ilia)
+- Fixed bug #48132 (configure check for curl ssl support fails with
+  --disable-rpath). (Jani)
+- Fixed bug #48131 (Don't try to bind ipv4 addresses to ipv6 ips via bindto).
+  (Ilia)
+- Fixed bug #48070 (PDO_OCI: Segfault when using persistent connection).
+  (Pierre, Matteo, jarismar dot php at gmail dot com)
+- Fixed bug #48058 (Year formatter goes wrong with out-of-int range). (Derick)
+- Fixed bug #48038 (odbc_execute changes variables used to form params array).
+  (Felipe)
+- Fixed bug #47997 (stream_copy_to_stream returns 1 on empty streams). (Arnaud)
+- Fixed bug #47991 (SSL streams fail if error stack contains items). (Mikko)
+- Fixed bug #47981 (error handler not called regardless). (Hannes)
+- Fixed bug #47969 (ezmlm_hash() returns different values depend on OS). (Ilia)
+- Fixed bug #47946 (ImageConvolution overwrites background). (Ilia)
+- Fixed bug #47940 (memory leaks in imap_body). (Pierre, Jake Levitt)
+- Fixed bug #47937 (system() calls sapi_flush() regardless of output
+  buffering). (Ilia)
+- Fixed bug #47903 ("@" operator does not work with string offsets). (Felipe)
+- Fixed bug #47893 (CLI aborts on non blocking stdout). (Arnaud)
+- Fixed bug #47849 (Non-deep import loses the namespace). (Rob)
+- Fixed bug #47845 (PDO_Firebird omits first row from query). (Lars W)
+- Fixed bug #47836 (array operator [] inconsistency when the array has
+  PHP_INT_MAX index value). (Matt)
+- Fixed bug #47831 (Compile warning for strnlen() in main/spprintf.c).
+  (Ilia, rainer dot jung at kippdata dot de)
+- Fixed bug #47828 (openssl_x509_parse() segfaults when a UTF-8 conversion
+  fails). (Scott, Kees Cook, Pierre)
+- Fixed bug #47818 (Segfault due to bound callback param). (Felipe)
+- Fixed bug #47801 (__call() accessed via parent:: operator is provided
+  incorrect method name). (Felipe)
+- Fixed bug #47769 (Strange extends PDO). (Felipe)
+  (Dmitry)
+- Fixed bug #47721 (Alignment issues in mbstring and sysvshm extension).
+  (crrodriguez at opensuse dot org, Ilia)
+- Fixed bug #47704 (PHP crashes on some "bad" operations with string
+  offsets). (Dmitry)
+- Fixed bug #47695 (build error when xmlrpc and iconv are compiled against
+  different iconv versions). (Scott)
+- Fixed bug #47667 (ZipArchive::OVERWRITE seems to have no effect).
+  (Mikko, Pierre)
+- Fixed bug #47644 (Valid integers are truncated with json_decode()). (Scott)
+- Fixed bug #47639 (pg_copy_from() WARNING: nonstandard use of \\ in a
+  string literal). (Ilia)
+- Fixed bug #47616 (curl keeps crashing). (Felipe)
+- Fixed bug #47598 (FILTER_VALIDATE_EMAIL is locale aware). (Ilia)
+- Fixed bug #47566 (pcntl_wexitstatus() returns signed status).
+  (patch by james at jamesreno dot com)
+- Fixed bug #47564 (unpacking unsigned long 32bit bit endian returns wrong
+  result). (Ilia)
+- Fixed bug #47487 (performance degraded when reading large chunks after
+  fix of bug #44607). (Arnaud)
+- Fixed bug #47468 (enable cli|cgi-only extensions for embed sapi). (Jani)
+- Fixed bug #47435 (FILTER_FLAG_NO_PRIV_RANGE does not work with ipv6
+  addresses in the filter extension). (Ilia)
+- Fixed bug #47430 (Errors after writing to nodeValue parameter of an absent
+  previousSibling). (Rob)
+- Fixed bug #47365 (ip2long() may allow some invalid values on certain 64bit
+   systems). (Ilia)
+- Fixed bug #47254 (Wrong Reflection for extends class). (Felipe)
+- Fixed bug #47042 (cgi sapi is incorrectly removing SCRIPT_FILENAME).
+  (Sriram Natarajan, David Soria Parra)
+- Fixed bug #46882 (Serialize / Unserialize misbehaviour under OS with
+  different bit numbers). (Matt)
+- Fixed bug #46812 (get_class_vars() does not include visible private variable
+  looking at subclass). (Arnaud)
+- Fixed bug #46386 (Digest authentication with SOAP module fails against MSSQL
+  SOAP services). (Ilia, lordelph at gmail dot com)
+- Fixed bug #46109 (Memory leak when mysqli::init() is called multiple times).
+  (Andrey)
+- Fixed bug #45997 (safe_mode bypass with exec/system/passthru (windows only)).
+  (Pierre)
+- Fixed bug #45877 (Array key '2147483647' left as string). (Matt)
+- Fixed bug #45822 (Near infinite-loops while parsing huge relative offsets).
+  (Derick, Mike Sullivan)
+- Fixed bug #45799 (imagepng() crashes on empty image).
+  (Martin McNickle, Takeshi Abe)
+- Fixed bug #45622 (isset($arrayObject->p) misbehaves with
+  ArrayObject::ARRAY_AS_PROPS set). (robin_fernandes at uk dot ibm dot com, Arnaud)
+- Fixed bug #45614 (ArrayIterator::current(), ::key() can show 1st private prop
+  of wrapped object). (robin_fernandes at uk dot ibm dot com, Arnaud)
+- Fixed bug #45540 (stream_context_create creates bad http request). (Arnaud)
+- Fixed bug #45202 (zlib.output_compression can not be set with ini_set()).
+  (Jani)
+- Fixed bug #45191 (error_log ignores date.timezone php.ini val when setting
+  logging timestamps). (Derick)
+- Fixed bug #45092 (header HTTP context option not being used when compiled
+  using --with-curlwrappers). (Jani)
+- Fixed bug #44996 (xmlrpc_decode() ignores time zone on iso8601.datetime).
+  (Ilia, kawai at apache dot org)
+- Fixed bug #44827 (define() is missing error checks for class constants).
+  (Ilia)
+- Fixed bug #44214 (Crash using preg_replace_callback() and global variables).
+  (Nuno, Scott)
+- Fixed bug #43073 (TrueType bounding box is wrong for angle<>0).
+  (Martin McNickle)
+- Fixed bug #42663 (gzinflate() try to allocate all memory with truncated
+  data). (Arnaud)
+- Fixed bug #42414 (some odbc_*() functions incompatible with Oracle ODBC
+  driver). (jhml at gmx dot net)
+- Fixed bug #42143 (The constant NAN is reported as 0 on Windows)
+- Fixed bug #38805 (PDO truncates text from SQL Server text data type field).
+  (Steph)
+26 Feb 2009, PHP 5.2.9
+- Added optional sorting type flag parameter to array_unique(). Default is
+  SORT_REGULAR. (Andrei)
+- Fixed a crash on extract in zip when files or directories entry names contain
+  a relative path. (Pierre)
+- Fixed error conditions handling in stream_filter_append(). (Arnaud)
+- Fixed zip filename property read. (Pierre)
+- Fixed explode() behavior with empty string to respect negative limit. (Shire)
+- Fixed security issue in imagerotate(), background colour isn't validated
+  correctly with a non truecolour image. Reported by Hamid Ebadi,
+  APA Laboratory (Fixes CVE-2008-5498). (Scott)
+- Fixed a segfault when malformed string is passed to json_decode(). (Scott)
+- Fixed bug in xml_error_string() which resulted in messages being
+  off by one. (Scott)
+- Fixed bug #47422 (modulus operator returns incorrect results on 64 bit
+  linux). (Matt)
+- Fixed bug #47399 (mb_check_encoding() returns true for some illegal SJIS
+  characters). (for-bugs at hnw dot jp, Moriyoshi)
+- Fixed bug #47353 (crash when creating a lot of objects in object
+  destructor). (Tony)
+- Fixed bug #47322 (sscanf %d doesn't work). (Felipe)
+- Fixed bug #47282 (FILTER_VALIDATE_EMAIL is marking valid email addresses
+  as invalid). (Ilia)
+- Fixed bug #47220 (segfault in dom_document_parser in recovery mode). (Rob)
+- Fixed bug #47217 (content-type is not set properly for file uploads). (Ilia)
+- Fixed bug #47174 (base64_decode() interprets pad char in mid string as
+  terminator). (Ilia)
+- Fixed bug #47152 (gzseek/fseek using SEEK_END produces strange results).
+  (Felipe)
+- Fixed bug #47131 (SOAP Extension ignores "user_agent" ini setting). (Ilia)
+- Fixed bug #47109 (Memory leak on $a->{"a"."b"} when $a is not an object).
+  (Etienne, Dmitry)
+- Fixed bug #47104 (Linking shared extensions fails with icc). (Jani)
+- Fixed bug #47049 (SoapClient::__soapCall causes a segmentation fault).
+  (Dmitry)
+- Fixed bug #47048 (Segfault with new pg_meta_data). (Felipe)
+- Fixed bug #47042 (PHP cgi sapi is removing SCRIPT_FILENAME for non
+  apache). (Sriram Natarajan)
+- Fixed bug #47037 (No error when using fopen with empty string). (Cristian
+  Rodriguez R., Felipe)
+- Fixed bug #47035 (dns_get_record returns a garbage byte at the end of a
+  TXT record). (Felipe)
+- Fixed bug #47027 (var_export doesn't show numeric indices on ArrayObject).
+  (Derick)
+- Fixed bug #46985 (OVERWRITE and binary mode does not work, regression
+  introduced in 5.2.8). (Pierre)
+- Fixed bug #46973 (IPv6 address filter rejects valid address). (Felipe)
+- Fixed bug #46964 (Fixed pdo_mysql build with older version of MySQL). (Ilia)
+- Fixed bug #46959 (Unable to disable PCRE). (Scott)
+- Fixed bug #46918 (imap_rfc822_parse_adrlist host part not filled in
+  correctly). (Felipe)
+- Fixed bug #46889 (Memory leak in strtotime()). (Derick)
+- Fixed bug #46887 (Invalid calls to php_error_docref()). (oeriksson at
+  mandriva dot com, Ilia)
+- Fixed bug #46873 (extract($foo) crashes if $foo['foo'] exists). (Arnaud)
+- Fixed bug #46843 (CP936 euro symbol is not converted properly). (ty_c at
+  cybozuy dot co dot jp, Moriyoshi)
+- Fixed bug #46798 (Crash in mssql extension when retrieving a NULL value
+  inside a binary or image column type). (Ilia)
+- Fixed bug #46782 (fastcgi.c parse error). (Matt)
+- Fixed bug #46760 (SoapClient doRequest fails when proxy is used). (Felipe)
+- Fixed bug #46748 (Segfault when an SSL error has more than one error).
+  (Scott)
+- Fixed bug #46739 (array returned by curl_getinfo should contain
+  content_type key). (Mikko)
+- Fixed bug #46699 (xml_parse crash when parser is namespace aware). (Rob)
+- Fixed bug #46419 (Elements of associative arrays with NULL value are
+  lost). (Dmitry)
+- Fixed bug #46282 (Corrupt DBF When Using DATE). (arne at bukkie dot nl)
+- Fixed bug #46026 (bz2.decompress/zlib.inflate filter tries to decompress
+  after end of stream). (Greg)
+- Fixed bug #46005 (User not consistently logged under Apache2). (admorten
+  at umich dot edu, Stas)
+- Fixed bug #45996 (libxml2 2.7 causes breakage with character data in
+  xml_parse()). (Rob)
+- Fixed bug #45940 (MySQLI OO does not populate connect_error property on
+  failed connect). (Johannes)
+- Fixed bug #45923 (mb_st[r]ripos() offset not handled correctly). (Moriyoshi)
+- Fixed bug #45327 (memory leak if offsetGet throws exception). (Greg)
+- Fixed bug #45239 (Encoding detector hangs with mbstring.strict_detection
+  enabled). (Moriyoshi)
+- Fixed bug #45161 (Reusing a curl handle leaks memory). (Mark Karpeles, Jani)
+- Fixed bug #44336 (Improve pcre UTF-8 string matching performance). (frode
+  at coretrek dot com, Nuno)
+- Fixed bug #43841 (mb_strrpos() offset is byte count for negative values).
+  (Moriyoshi)
+- Fixed bug #37209 (mssql_execute with non fatal errors). (Kalle)
+- Fixed bug #35975 (Session cookie expires date format isn't the most
+  compatible. Now matches that of setcookie()). (Scott)
+08 Dec 2008, PHP 5.2.8
+- Reverted bug fix #42718 that broke magic_quotes_gpc (Scott)
+04 Dec 2008, PHP 5.2.7
+- Upgraded PCRE to version 7.8 (Fixes CVE-2008-2371). (Ilia)
+- Updated timezone database to version 2008.9. (Derick)
+- Upgraded bundled libzip to 0.9.0. (Pierre)
+- Added logging option for error_log to send directly to SAPI. (Stas)
+- Added PHP_MAJOR_VERSION, PHP_MINOR_VERSION, PHP_RELEASE_VERSION,
+  PHP_EXTRA_VERSION, PHP_VERSION_ID, PHP_ZTS and PHP_DEBUG constants. (Pierre)
+- Added "PHP_INI_SCAN_DIR" environment variable which can be used to
+  either disable or change the compile time ini scan directory (FR #45114).
+  (Jani)
+- Fixed missing initialization of BG(page_uid) and BG(page_gid),
+  reported by Maksymilian Arciemowicz. (Stas)
+- Fixed memory leak inside sqlite_create_aggregate(). (Felipe)
+- Fixed memory leak inside PDO sqlite's sqliteCreateAggregate() method.
+  (Felipe)
+- Fixed a crash inside gd with invalid fonts (Fixes CVE-2008-3658). (Pierre)
+- Fixed a possible overflow inside memnstr (Fixes CVE-2008-3659).
+  (LaurentGaffie)
+- Fixed incorrect php_value order for Apache configuration, reported by
+  Maksymilian Arciemowicz. (Stas)
+- Fixed memory leak inside readline_callback_handler_remove() function.
+  (Felipe)
+- Fixed sybase_fetch_*() to continue reading after CS_ROW_FAIL status (Timm)
+- Fixed a bug inside dba_replace() that could cause file truncation
+  withinvalid keys. (Ilia)
+- Fixed memory leak inside readline_callback_handler_install() function.(Ilia)
+- Fixed memory leak inside readline_completion_function() function. (Felipe)
+- Fixed stream_get_contents() when using $maxlength and socket is notclosed.
+  indeyets [at] php [dot] net on #46049. (Arnaud)
+- Fixed stream_get_line() to behave as documented on non-blocking streams.
+  (Arnaud)
+- Fixed endless loop in PDOStatement::debugDumpParams().
+  (jonah.harris at gmail dot com)
+- Fixed ability to use "internal" heaps in extensions. (Arnaud, Dmitry)
+- Fixed weekdays adding/subtracting algorithm. (Derick)
+- Fixed some ambiguities in the date parser. (Derick)
+- Fixed a bug with the YYYY-MM format not resetting the day correctly.
+  (Derick)
+- Fixed a bug in the DateTime->modify() methods, it would not use the advanced
+  relative time strings. (Derick)
+- Fixed extraction of zip files or directories when the entry name is a
+  relative path. (Pierre)
+- Fixed read or write errors for large zip archives. (Pierre)
+- Fixed security issues detailed in CVE-2008-2665 and CVE-2008-2666.
+  (Christian Hoffmann)
+- Fixed simplexml asXML() not to lose encoding when dumping entire
+  document to file. (Ilia)
+- Fixed a crash inside PDO when trying instantiate PDORow manually.
+  (Felipe)
+- Fixed build failure of ext/mysqli with libmysql 6.0 - missing
+  rplfunctions. (Andrey)
+- Fixed a regression when using strip_tags() and < is within an
+  attribute.(Scott)
+- Fixed a crash on invalid method in ReflectionParameter constructor.
+  (Christian Seiler)
+- Reverted fix for bug #44197 due to behaviour change in minor version.
+  (Felipe)
+- Fixed bug #46732 (mktime.year description is wrong). (Derick)
+- Fixed bug #46696 (cURL fails in upload files with specified content-type).
+  (Ilia)
+- Fixed bug #46673 (stream_lock call with wrong parameter). (Arnaud)
+- Fixed bug #46649 (Setting array element with that same array produces
+  inconsistent results). (Arnaud)
+- Fixed bug #46626 (mb_convert_case does not handle apostrophe correctly).
+  (Ilia)
+- Fixed bug #46543 (ibase_trans() memory leaks when using wrong parameters).
+  (Felipe)
+- Fixed bug #46521 (Curl ZTS OpenSSL, error in config.m4 fragment).
+  (jd at cpanel dot net)
+- Fixed bug #46496 (wddx_serialize treats input as ISO-8859-1). (Mark Karpeles)
+- Fixed bug #46427 (SoapClient() stumbles over its "stream_context" parameter).
+  (Dmitry, Herman Radtke)
+- Fixed bug #46426 (offset parameter of stream_get_contents() does not
+  workfor "0"). (Felipe)
+- Fixed bug #46406 (Unregistering nodeclass throws E_FATAL). (Rob)
+- Fixed bug #46389 (NetWare needs small patch for _timezone).
+  (patch by guenter at php.net)
+- Fixed bug #46388 (stream_notification_callback inside of object destroys
+  object variables). (Felipe)
+- Fixed bug #46381 (wrong $this passed to internal methods causes segfault).
+  (Tony)
+- Fixed bug #46379 (Infinite loop when parsing '#' in one line file). (Arnaud)
+- Fixed bug #46366 (bad cwd with / as pathinfo). (Dmitry)
+- Fixed bug #46360 (TCP_NODELAY constant for socket_{get,set}_option).
+  (bugs at trick dot vanstaveren dot us)
+- Fixed bug #46343 (IPv6 address filter accepts invalid address). (Ilia)
+- Fixed bug #46335 (DOMText::splitText doesn't handle multibyte characters).
+  (Rob)
+- Fixed bug #46323 (compilation of simplexml for NetWare breaks).
+  (Patch by guenter [at] php [dot] net)
+- Fixed bug #46319 (PHP sets default Content-Type header for HTTP 304
+  response code, in cgi sapi). (Ilia)
+- Fixed bug #46313 (Magic quotes broke $_FILES). (Arnaud)
+- Fixed bug #46308 (Invalid write when changing property from inside getter).
+  (Dmitry)
+- Fixed bug #46292 (PDO::setFetchMode() shouldn't requires the 2nd arg when
+  using FETCH_CLASSTYPE). (Felipe)
+- Fixed bug #46274, #46249 (pdo_pgsql always fill in NULL for empty BLOB and
+  segfaults when returned by SELECT). (Felipe)
+- Fixed bug #46271 (local_cert option is not resolved to full path). (Ilia)
+- Fixed bug #46247 (ibase_set_event_handler() is allowing to pass callback
+  without event). (Felipe)
+- Fixed bug #46246 (difference between call_user_func(array($this, $method))
+  and $this->$method()). (Dmitry)
+- Fixed bug #46222 (ArrayObject EG(uninitialized_var_ptr) overwrite).
+  (Etienne)
+- Fixed bug #46215 (json_encode mutates its parameter and has some
+  class-specific state). (Felipe)
+- Fixed bug #46206 (pg_query_params/pg_execute convert passed values to
+  strings). (Ilia)
+- Fixed bug #46191 (BC break: DOMDocument saveXML() doesn't accept null).
+  (Rob)
+- Fixed bug #46164 (stream_filter_remove() closes the stream). (Arnaud)
+- Fixed bug #46157 (PDOStatement::fetchObject prototype error). (Felipe)
+- Fixed bug #46147 (after stream seek, appending stream filter reads
+  incorrect data). (Greg)
+- Fixed bug #46139 (PDOStatement->setFetchMode() forgets FETCH_PROPS_LATE).
+  (chsc at peytz dot dk, Felipe)
+  on accepted stream) (Mark Karpeles, Pierre)
+- Fixed bug #46088 (RegexIterator::accept - segfault). (Felipe)
+- Fixed bug #46082 (stream_set_blocking() can cause a crash in some
+  circumstances). (Felipe)
+- Fixed bug #46064 (Exception when creating ReflectionProperty object
+  on dynamicly created property). (Felipe)
+- Fixed bug #46059 (Compile failure under IRIX 6.5.30 building posix.c).
+  (Arnaud)
+- Fixed bug #46053 (SplFileObject::seek - Endless loop). (Arnaud)
+- Fixed bug #46051 (SplFileInfo::openFile - memory overlap). (Arnaud)
+- Fixed bug #46047 (SimpleXML converts empty nodes into object with
+  nested array). (Rob)
+- Fixed bug #46031 (Segfault in AppendIterator::next). (Arnaud)
+- Fixed bug #46029 (Segfault in DOMText when using with Reflection). (Rob)
+- Fixed bug #46026 (bzip2.decompress/zlib.inflate filter tries to decompress
+  after end of stream). (Keisial at gmail dot com, Greg)
+- Fixed bug #46024 (stream_select() doesn't return the correct number).
+  (Arnaud)
+- Fixed bug #46010 (warnings incorrectly generated for iv in ecb mode).
+  (Felipe)
+- Fixed bug #46003 (isset on nonexisting node return unexpected results). (Rob)
+- Fixed bug #45956 (parse_ini_file() does not return false with syntax errors
+  in parsed file). (Jani)
+- Fixed bug #45901 (wddx_serialize_value crash with SimpleXMLElement object).
+  (Rob)
+- Fixed bug #45862 (get_class_vars is inconsistent with 'protected' and
+  'private' variables). (ilewis at uk dot ibm dot com, Felipe)
+- Fixed bug #45860 (header() function fails to correctly replace all Status
+  lines). (Dmitry)
+- Fixed bug #45805 (Crash on throwing exception from error handler). (Dmitry)
+- Fixed bug #45765 (ReflectionObject with default parameters of self::xxx cause
+  an error). (Felipe)
+- Fixed bug #45751 (Using auto_prepend_file crashes (out of scope stack address
+  use)). (basant dot kukreja at sun dot com)
+- Fixed bug #45722 (mb_check_encoding() crashes). (Moriyoshi)
+- Fixed bug #45705 (rfc822_parse_adrlist() modifies passed address parameter).
+  (Jani)
+- Fixed bug #45691 (Some per-dir or runtime settings may leak into other
+  requests). (Moriyoshi)
+- Fixed bug #45581 (htmlspecialchars() double encoding &#x hex items). (Arnaud)
+- Fixed bug #45580 (levenshtein() crashes with invalid argument). (Ilia)
+- Fixed bug #45575 (Segfault with invalid non-string as event handler callback).
+- Fixed bug #45568 (ISAPI doesn't properly clear auth_digest in header).
+  (Patch by: navara at emclient dot com)
+- Fixed bug #45556 (Return value from callback isn't freed). (Felipe)
+- Fixed bug #45555 (Segfault with invalid non-string as
+  register_introspection_callback). (Christian Seiler)
+- Fixed bug #45553 (Using XPath to return values for attributes with a
+  namespace does not work). (Rob)
+- Fixed bug #45529 (new DateTimeZone() and date_create()->getTimezone() behave
+  different). (Derick)
+- Fixed bug #45522 (FCGI_GET_VALUES request does not return supplied values).
+  (Arnaud)
+- Fixed bug #45486 (mb_send_mail(); header 'Content-Type: text/plain; charset='
+   parsing incorrect). (Felipe)
+- Fixed bug #45485 (strip_tags and <?XML tag). (Felipe)
+- Fixed bug #45460 (imap patch for fromlength fix in imap_headerinfo doesn't
+  accept lengths of 1024). (Felipe, andrew at lifescale dot com)
+- Fixed bug #45449 (filesize() regression using ftp wrapper).
+  (crrodriguez at suse dot de)
+- Fixed bug #45423 (fastcgi parent process doesn't invoke php_module_shutdown
+  before shutdown) (basant dot kukreja at sun dot com)
+- Fixed bug #45406 (session.serialize_handler declared by shared extension fails).
+  (Kalle, oleg dot grenrus at dynamoid dot com)
+- Fixed bug #45405 (snmp extension memory leak).
+  (Federico Cuello, Rodrigo Campos)
+- Fixed bug #45382 (timeout bug in stream_socket_enable_crypto). (Ilia)
+- Fixed bug #45373 (php crash on query with errors in params). (Felipe)
+- Fixed bug #45352 (Segmentation fault because of tick function on second
+  request). (Dmitry)
+- Fixed bug #45312 (Segmentation fault on second request for array functions).
+  (Dmitry)
+- Fixed bug #45303 (Opening php:// wrapper in append mode results in a warning).
+  (Arnaud)
+- Fixed bug #45251 (double free or corruption with setAttributeNode()). (Rob)
+- Fixed bug #45226 and #18916 (xmlrpc_set_type() segfaults and wrong behavior
+  with valid ISO8601 date string). (Jeff Lawsons)
+- Fixed bug #45220 (curl_read callback returns -1 when needs to return
+  size_t (unsigned)). (Felipe)
+- Fixed bug #45181 (chdir() should clear relative entries in stat cache).
+  (Arnaud)
+- Fixed bug #45178 (memory corruption on assignment result of "new" by
+- Fixed bug #45166 (substr() overflow changes). (Felipe)
+- Fixed bug #45151 (Crash with URI/file..php (filename contains 2 dots)).
+  (Fixes CVE-2008-3660) (Dmitry)
+- Fixed bug #45139 (ReflectionProperty returns incorrect declaring class).
+  (Felipe)
+- Fixed bug #45124 ($_FILES['upload']['size'] sometimes return zero and some
+  times the filesize). (Arnaud)
+- Fixed bug #45028 (CRC32 output endianness is different between crc32() and
+  hash()). (Tony)
+- Fixed bug #45004 (pg_insert() does not accept 4 digit timezone format).
+  (Ilia)
+- Fixed bug #44991 (Compile Failure With freetds0.82).
+  (jklowden at freetds dot org, matthias at dsx dot at)
+- Fixed bug #44938 (gettext functions crash with overly long domain).
+  (Christian Schneider, Ilia)
+- Fixed bug #44925 (preg_grep() modifies input array). (Nuno)
+- Fixed bug #44900 (OpenSSL extension fails to link with OpenSSL 0.9.6).
+  (jd at cpanel dot net, Pierre)
+- Fixed bug #44891 Memory leak using registerPHPFunctions and XSLT Variable
+  as function parameter. (Rob)
+- Fixed bug #44882 (SOAP extension object decoding bug). (Dmitry)
+- Fixed bug #44830 (Very minor issue with backslash in heredoc). (Matt)
+- Fixed bug #44818 (php://memory writeable when opened read only). (Arnaud)
+- Fixed bug #44811 (Improve error message when creating a new SoapClient
+  that contains invalid data). (Markus Fischer, David C)
+- Fixed bug #44798 (Memory leak assigning value to attribute). (Ilia)
+- Fixed bug #44716 (Progress notifications incorrect). (Hannes)
+- Fixed bug #44712 (stream_context_set_params segfaults on invalid arguments).
+  (Hannes)
+- Fixed bug #44617 (wrong HTML entity output when substitute_character=entity).
+  (Moriyoshi)
+- Fixed bug #44607 (stream_get_line unable to correctly identify the "ending"
+  in the stream content). (Arnaud)
+- Fixed bug #44425 (Extending PDO/MySQL class with a __call() function doesn't
+  work). (Johannes)
+- Fixed bug #44327 (PDORow::queryString property & numeric offsets / Crash).
+  (Felipe)
+- Fixed bug #44251, #41125 (PDO + quote() + prepare() can result in segfault).
+  (tsteiner at nerdclub dot net)
+- Fixed bug #44246 (closedir() accepts a file resource opened by fopen()).
+  (Dmitry, Tony)
+- Fixed bug #44182 (extract($a, EXTR_REFS) can fail to split copy-on-write
+  references). (robin_fernandes at uk dot ibm dot com)
+- Fixed bug #44181 (extract($a, EXTR_OVERWRITE|EXTR_REFS) can fail to create
+  references to $a). (robin_fernandes at uk dot ibm dot com)
+- Fixed bug #44127 (UNIX abstract namespace socket connect does not work).
+  (Jani)
+- Fixed bug #43993 (mb_substr_count() behaves differently to substr_count()
+  with overlapping needles). (Moriyoshi)
+- Fixed Bug #43958 (class name added into the error message). (Dmitry)
+- Fixed bug #43941 (json_encode silently cuts non-UTF8 strings). (Stas)
+- Fixed bug #43925 (Incorrect argument counter in prepared statements with
+  pgsql). (Felipe)
+- Fixed bug #43731 (socket_getpeername: cannot use on stdin with inetd).
+  (Arnaud)
+- Fixed bug #43723 (SOAP not sent properly from client for <choice>). (Dmitry)
+- Fixed bug #43668 (Added odbc.default_cursortype to control the ODBCcursor
+  model). (Patrick)
+- Fixed bug #43666 (Fixed code to use ODBC 3.52 datatypes for 64bit
+  systems). (Patrick)
+- Fixed bug #43540 (rfc1867 handler newlength problem). (Arnaud)
+- Fixed bug #43452 (strings containing a weekday, or a number plus weekday
+  behaved incorrect of the current day-of-week was the same as the one in the
+  phrase). (Derick)
+- Fixed bug #43353 (wrong detection of 'data' wrapper causes notice).
+  (gk at gknw dot de, Arnaud)
+- Fixed bug #43053 (Regression: some numbers shown in scientific notation).
+  (int-e at gmx dot de)
+- Fixed bug #43045 (SOAP encoding violation on "INF" for type double/float).
+  (Dmitry)
+- Fixed bug #42862 (IMAP toolkit crash: rfc822.c legacy routine buffer
+  overflow). (Fixes CVE-2008-2829) (Dmitry)
+- Fixed bug #42855 (dns_get_record() doesn't return all text from TXT record).
+  (a dot u dot savchuk at gmail dot com)
+- Fixed bug #42737 (preg_split('//u') triggers a E_NOTICE with newlines).
+  (Nuno)
+- Fixed bug #42718 (FILTER_UNSAFE_RAW not applied when configured as default
+  filter). (Arnaud)
+- Fixed bug #42604 ("make test" fails with --with-config-file-scan-dir=path).
+  (Jani)
+- Fixed bug #42473 (ob_start php://output and headers). (Arnaud)
+- Fixed bug #42318 (problem with nm on AIX, not finding object files).
+  (Dmitry)
+- Fixed bug #42294 (Unified solution for round() based on C99 round). (Ilia)
+- Fixed bug #42078 (pg_meta_data mix tables metadata from different schemas).
+  (Felipe)
+- Fixed bug #41348 (OCI8: allow compilation with Oracle 8.1). (Chris Jones)
+- Fixed bug #41033 (enable signing with DSA keys.
+  (gordyf at google dot com, Pierre)
+- Fixed bug #37100 (data is returned truncated with BINARY CURSOR). (Tony)
+- Fixed bug #30312 (crash in sybase_unbuffered_query() function). (Timm)
+- Fixed bug #24679 (pg_* functions doesn't work using schema). (Felipe)
+- Fixed bug #14962 (PECL) (::extractTo 2nd argument is not really optional)
+  (Mark van Der Velden)
+- Fixed bug #14032 (Mail() always returns false but mail is sent). (Mikko)
+01 May 2008, PHP 5.2.6
+- Fixed two possible crashes inside posix extension (Tony)
+- Fixed incorrect heredoc handling when label is used within the block.
+  (Matt)
+- Fixed possible stack buffer overflow in FastCGI SAPI. (Andrei Nigmatulin)
+- Fixed sending of uninitialized paddings which may contain some information. (Andrei Nigmatulin)
+- Fixed a bug in formatting timestamps when DST is active in the default timezone (Derick)
+- Properly address incomplete multibyte chars inside escapeshellcmd() (Ilia, Stefan Esser)
+- Fix integer overflow in printf(). (Stas, Maksymilian Aciemowicz)
+- Fixed security issue detailed in CVE-2008-0599. (Rasmus)
+- Fixed potential memleak in stream filter parameter for zlib filter. (Greg)
+- Added Reflection API metadata for the methods of the DOM classes. (Sebastian)
+- Fixed weird behavior in CGI parameter parsing. (Dmitry, Hannes Magnusson)
+- Fixed a safe_mode bypass in cURL identified by Maksymilian Arciemowicz.
+  (Ilia)
+- Fixed a bug with PDO::FETCH_COLUMN|PDO::FETCH_GROUP mode when a column # by
+  which to group by data is specified. (Ilia)
+- Fixed segfault in filter extension when using callbacks. (Arnar Mar Sig,
+  Felipe)
+- Fixed faulty fix for bug #40189 (endless loop in zlib.inflate stream filter). (Greg)
+- Upgraded PCRE to version 7.6 (Nuno)
+- Fixed bug #44742 (timezone_offset_get() causes segmentation faults). (Derick)
+- Fixed bug #44720 (Prevent crash within session_register()). (Scott)
+- Fixed bug #44703 (htmlspecialchars() does not detect bad character set argument). (Andy Wharmby)
+- Fixed bug #44673 (With CGI argv/argc starts from arguments, not from script) (Dmitry)
+- Fixed bug #44667 (proc_open() does not handle pipes with the mode 'wb' correctly). (Jani)
+- Fixed bug #44663 (Crash in imap_mail_compose if "body" parameter invalid). (Ilia)
+- Fixed bug #44650 (escaepshellscmd() does not check arg count). (Ilia)
+- Fixed bug #44613 (Crash inside imap_headerinfo()). (Ilia, jmessa)
+- Fixed bug #44603 (Order issues with Content-Type/Length headers on POST). (Ilia)
+- Fixed bug #44594 (imap_open() does not validate # of retries parameter). (Ilia)
+- Fixed bug #44591 (imagegif's filename parameter). (Felipe)
+- Fixed bug #44557 (Crash in imap_setacl when supplied integer as username) (Thomas Jarosch)
+- Fixed bug #44487 (call_user_method_array issues a warning when throwing an exception). (David Soria Parra)
+- Fixed bug #44478 (Inconsistent behaviour when assigning new nodes). (Rob, Felipe)
+- Fixed bug #44445 (email validator does not handle domains starting/ending with a -). (Ilia)
+- Fixed bug #44440 (st_blocks undefined under BeOS). (Felipe)
+- Fixed bug #44394 (Last two bytes missing from output). (Felipe)
+- Fixed bug #44388 (Crash inside exif_read_data() on invalid images) (Ilia)
+- Fixed bug #44373 (PDO_OCI extension compile failed). (Felipe)
+- Fixed bug #44333 (SEGFAULT when using mysql_pconnect() with client_flags). (Felipe)
+- Fixed bug #44306 (Better detection of MIPS processors on Windows). (Ilia)
+- Fixed bug #44242 (metaphone('CMXFXM') crashes PHP). (Felipe)
+- Fixed bug #44233 (MSG_PEEK undefined under BeOS R5). (jonathonfreeman at gmail dot com, Ilia)
+- Fixed bug #44216 (strftime segfaults on large negative value). (Derick)
+- Fixed bug #44209 (strtotime() doesn't support 64 bit timestamps on 64 bit platforms). (Derick)
+- Fixed bug #44206 (OCI8 selecting ref cursors leads to ORA-1000 maximum open cursors reached). (Oracle Corp.)
+- Fixed bug #44200 (A crash in PDO when no bound targets exists and yet bound parameters are present). (Ilia)
+- Fixed bug #44197 (socket array keys lost on socket_select). (Felipe)
+- Fixed bug #44191 (preg_grep messes up array index). (Felipe)
+- Fixed bug #44189 (PDO setAttribute() does not properly validate values for native numeric options). (Ilia)
+- Fixed bug #44184 (Double free of loop-variable on exception). (Dmitry)
+- Fixed bug #44171 (Invalid FETCH_COLUMN index does not raise an error). (Ilia)
+- Fixed bug #44166 (Parameter handling flaw in PDO::getAvailableDrivers()). (Ilia)
+- Fixed bug #44159 (Crash: $pdo->setAttribute(PDO::STATEMENT_ATTR_CLASS, NULL)). (Felipe)
+- Fixed bug #44152 (Possible crash with syslog logging on ZTS builds). (Ilia)
+- Fixed bug #44141 (private parent constructor callable through static function). (Dmitry)
+- Fixed bug #44113 (OCI8 new collection creation can fail with OCI-22303). (Oracle Corp.)
+- Fixed bug #44069 (Huge memory usage with concatenation using . instead of .=). (Dmitry)
+- Fixed bug #44046 (crash inside array_slice() function with an invalid by-ref offset). (Ilia)
+- Fixed bug #44028 (crash inside stream_socket_enable_crypto() when enabling encryption without crypto type). (Ilia)
+- Fixed bug #44018 (RecursiveDirectoryIterator options inconsistancy). (Marcus)
+- Fixed bug #44008 (OCI8 incorrect usage of OCI-Lob->close crashes PHP). (Oracle Corp.)
+- Fixed bug #43998 (Two error messages returned for incorrect encoding for mb_strto[upper|lower]). (Rui)
+- Fixed bug #43994 (mb_ereg 'successfully' matching incorrect). (Rui)
+- Fixed bug #43954 (Memory leak when sending the same HTTP status code multiple times). (Scott)
+- Fixed bug #43927 (koi8r is missing from html_entity_decode()). (andy at demos dot su, Tony)
+- Fixed bug #43912 (Interbase column names are truncated to 31 characters). (Ilia)
+- Fixed bug #43875 (Two error messages returned for $new and $flag argument in mysql_connect()). (Hannes)
+- Fixed bug #43863 (str_word_count() breaks on cyrillic "ya" in locale cp1251). (phprus at gmail dot com, Tony)
+- Fixed bug #43841 (mb_strrpos offset is byte count for negative values). (Rui)
+- Fixed bug #43840 (mb_strpos bounds check is byte count rather than a character count). (Rui)
+- Fixed bug #43808 (date_create never fails (even when it should)). (Derick)
+- Fixed bug #43793 (zlib filter is unable to auto-detect gzip/zlib file headers). (Greg)
+- Fixed bug #43703 (Signature compatibility check broken). (Dmitry)
+- Fixed bug #43677 (Inconsistent behaviour of include_path set with php_value). (manuel at mausz dot at)
+- Fixed bug #43663 (Extending PDO class with a __call() function doesn't work). (David Soria Parra)
+- Fixed bug #43647 (Make FindFile use PATH_SEPARATOR instead of ";"). (Ilia)
+- Fixed bug #43635 (mysql extension ingores INI settings on NULL values passed to mysql_connect()). (Ilia)
+- Fixed bug #43620 (Workaround for a bug inside libcurl 7.16.2 that can result in a crash). (Ilia)
+- Fixed bug #43614 (incorrect processing of numerical string keys of array in arbitrary serialized data). (Dmitriy Buldakov, Felipe)
+- Fixed bug #43606 (define missing depencies of the exif extension). (crrodriguez at suse dot de)
+- Fixed bug #43589 (a possible infinite loop in bz2_filter.c). (Greg)
+- Fixed bug #43580 (removed bogus declaration of a non-existent php_is_url() function). (Ilia)
+- Fixed bug #43559 (array_merge_recursive() doesn't behave as expected with duplicate NULL values). (Felipe, Tony)
+- Fixed bug #43533 (escapeshellarg('') returns null). (Ilia)
+- Fixed bug #43527 (DateTime created from a timestamp reports environment timezone). (Derick)
+- Fixed bug #43522 (stream_get_line() eats additional characters). (Felipe, Ilia, Tony)
+- Fixed bug #43507 (SOAPFault HTTP Status 500 - would like to be able to set the HTTP Status). (Dmitry)
+- Fixed bug #43505 (Assign by reference bug). (Dmitry)
+- Fixed bug #43498 (file_exists() on a proftpd server got SIZE not allowed in ASCII mode). (Ilia, crrodriguez at suse dot de)
+- Fixed bug #43497 (OCI8 XML/getClobVal aka temporary LOBs leak UGA memory). (Chris)
+- Fixed bug #43495 (array_merge_recursive() crashes with recursive arrays). (Ilia)
+- Fixed bug #43493 (pdo_pgsql does not send username on connect when password is not available). (Ilia)
+- Fixed bug #43491 (Under certain conditions, file_exists() never returns). (Dmitry)
+- Fixed bug #43483 (get_class_methods() does not list all visible methods). (Dmitry)
+- Fixed bug #43482 (array_pad() does not warn on very small pad numbers). (Ilia)
+- Fixed bug #43457 (Prepared statement with incorrect parms doesn't throw exception with pdo_pgsql driver). (Ilia)
+- Fixed bug #43450 (Memory leak on some functions with implicit object __toString() call). (David C.)
+- Fixed bug #43386 (array_globals not reset to 0 properly on init). (Ilia)
+- Fixed bug #43377 (PHP crashes with invalid argument for DateTimeZone). (Ilia)
+- Fixed bug #43373 (pcntl_fork() should not raise E_ERROR on error). (Ilia)
+- Fixed bug #43364 (recursive xincludes don't remove internal xml nodes properly). (Rob, patch from ddb at bitxtender.de)
+- Fixed bug #43301 (mb_ereg*_replace() crashes when replacement string is invalid PHP expression and 'e' option is used). (Jani)
+- Fixed bug #43295 (crash because of uninitialized SG(sapi_headers).mimetype). (Dmitry)
+- Fixed bug #43293 (Multiple segfaults in getopt()). (Hannes)
+- Fixed bug #43279 (pg_send_query_params() converts all elements in 'params' to strings). (Ilia)
+- Fixed bug #43276 (Incomplete fix for bug #42739, mkdir() under safe_mode). (Ilia)
+- Fixed bug #43248 (backward compatibility break in realpath()). (Dmitry)
+- Fixed bug #43221 (SimpleXML adding default namespace in addAttribute). (Rob)
+- Fixed bug #43216 (stream_is_local() returns false on "file://"). (Dmitry)
+- Fixed bug #43201 (Crash on using uninitialized vals and __get/__set). (Dmitry)
+- Fixed bug #43182 (file_put_contents() LOCK_EX does not work properly on file truncation). (Ilia)
+- Fixed bug #43175 (__destruct() throwing an exception with __call() causes segfault). (Dmitry)
+- Fixed bug #43128 (Very long class name causes segfault). (Dmitry)
+- Fixed bug #43105 (PHP seems to fail to close open files). (Hannes)
+- Fixed bug #43092 (curl_copy_handle() crashes with > 32 chars long URL). (Jani)
+- Fixed bug #43003 (Invalid timezone reported for DateTime objects constructed using a timestamp). (Derick)
+- Fixed bug #42978 (mismatch between number of bound params and values causes a crash in pdo_pgsql). (Ilia)
+- Fixed bug #42945 (preg_split() swallows part of the string). (Nuno)
+- Fixed bug #42937 (__call() method not invoked when methods are called on parent from child class). (Dmitry)
+- Fixed bug #42841 (REF CURSOR and oci_new_cursor() crash PHP). (Chris)
+- Fixed bug #42838 (Wrong results in array_diff_uassoc) (Felipe)
+- Fixed bug #42779 (Incorrect forcing from HTTP/1.0 request to HTTP/1.1 response). (Ilia)
+- Fixed bug #42736 (xmlrpc_server_call_method() crashes). (Tony)
+- Fixed bug #42692 (Procedure 'int1' not present with doc/lit SoapServer). (Dmitry)
+- Fixed bug #42548 (mysqli PROCEDURE calls can't return result sets). (Hartmut)
+- Fixed bug #42505 (new sendmail default breaks on Netware platform) (Guenter Knauf)
+- Fixed bug #42369 (Implicit conversion to string leaks memory). (David C., Rob).
+- Fixed bug #42272 (var_export() incorrectly escapes char(0)). (Derick)
+- Fixed bug #42261 (Incorrect lengths for date and boolean data types). (Ilia)
+- Fixed bug #42190 (Constructing DateTime with TimeZone Indicator invalidates DateTimeZone). (Derick)
+- Fixed bug #42177 (Warning "array_merge_recursive(): recursion detected" comes again...). (Felipe)
+- Fixed bug #41941 (oci8 extension not lib64 savvy). (Chris)
+- Fixed bug #41828 (Failing to call RecursiveIteratorIterator::__construct() causes a sefault). (Etienne)
+- Fixed bug #41599 (setTime() fails after modify() is used). (Derick)
+- Fixed bug #41562 (SimpleXML memory issue). (Rob)
+- Fixed bug #40013 (php_uname() does not return nodename on Netware (Guenter Knauf)
+- Fixed bug #38468 (Unexpected creation of cycle). (Dmitry)
+- Fixed bug #32979 (OpenSSL stream->fd casts broken in 64-bit build) (stotty at tvnet dot hu)
+08 Nov 2007, PHP 5.2.5
+- Upgraded PCRE to version 7.3 (Nuno)
+- Added optional parameter $provide_object to debug_backtrace(). (Sebastian)
+- Added alpha support for imagefilter() IMG_FILTER_COLORIZE. (Pierre)
+- Added ability to control memory consumption between request using
+  ZEND_MM_COMPACT environment variable. (Dmitry)
+- Improved speed of array_intersect_key(), array_intersect_assoc(),
+  array_uintersect_assoc(), array_diff_key(), array_diff_assoc() and
+  array_udiff_assoc(). (Dmitry)
+- Fixed move_uploaded_file() to always set file permissions of resulting file
+  according to UMASK. (Andrew Sitnikov)
+- Fixed possible crash in ext/soap because of uninitialized value. (Zdash Urf)
+- Fixed regression in glob() when enforcing safe_mode/open_basedir checks on
+  paths containing '*'. (Ilia)
+- Fixed "mail.force_extra_parameters" php.ini directive not to be modifiable
+  in .htaccess due to the security implications - reported by SecurityReason.
+  (Stas)
+- Fixed PDO crash when driver returns empty LOB stream. (Stas)
+- Fixed dl() to only accept filenames - reported by Laurent Gaffie. (Stas)
+- Fixed dl() to limit argument size to MAXPATHLEN (CVE-2007-4887).
+- Fixed iconv_*() functions to limit argument sizes as workaround to libc
+  bug (CVE-2007-4783, CVE-2007-4840 by Laurent Gaffie).
+  (Christian Hoffmann, Stas)
+- Fixed missing brackets leading to build warning and error in the log.
+  Win32 code. (Andrey)
+- Fixed leaks with multiple connects on one mysqli object. (Andrey)
+- Fixed endianness detection on MacOS when building universal binary.
+  (Uwe Schindler, Christian Speich, Tony)
+- Fixed possible triggering of buffer overflows inside glibc
+  implementations of the fnmatch(), setlocale() and glob() functions.
+  Reported by Laurent Gaffie. (Ilia)
+- Fixed imagerectangle regression with 1x1 rectangle (libgd #106). (Pierre)
+- Fixed htmlentities/htmlspecialchars not to accept partial multibyte
+  sequences. (Stas)
+- Fixed bug #43196 (array_intersect_assoc() crashes with non-array input).
+  (Jani)
+- Fixed bug #43139 (PDO ignores ATTR_DEFAULT_FETCH_MODE in some cases with
+  fetchAll()). (Ilia)
+- Fixed bug #43137 (rmdir() and rename() do not clear statcache). (Jani)
+- Fixed bug #43130 (Bound parameters cannot have - in their name). (Ilia)
+- Fixed bug #43099 (XMLWriter::endElement() does not check # of params).
+  (Ilia)
+- Fixed bug #43020 (Warning message is missing with shuffle() and more
+  than one argument). (Scott)
+- Fixed bug #42976 (Crash when constructor for newInstance() or
+  newInstanceArgs() fails) (Ilia)
+- Fixed bug #42943 (ext/mssql: Move *timeout initialization from RINIT
+  to connect time). (Ilia)
+- Fixed bug #42917 (PDO::FETCH_KEY_PAIR doesn't work with setFetchMode).
+  (Ilia)
+- Fixed bug #42890 (Constant "LIST" defined by mysqlclient and c-client).
+  (Andrey)
+- Fixed bug #42869 (automatic session id insertion adds sessions id to
+  non-local forms). (Ilia)
+- Fixed bug #42818 ($foo = clone(array()); leaks memory). (Dmitry)
+- Fixed bug #42817 (clone() on a non-object does not result in a fatal
+  error). (Ilia)
+- Fixed bug #42785 (json_encode() formats doubles according to locale rather
+  then following standard syntax). (Ilia)
+- Fixed bug #42783 (pg_insert() does not accept an empty list for
+  insertion). (Ilia)
+- Fixed bug #42773 (WSDL error causes HTTP 500 Response). (Dmitry)
+- Fixed bug #42772 (Storing $this in a static var fails while handling a cast
+  to string). (Dmitry)
+- Fixed bug #42767 (highlight_string() truncates trailing comment). (Ilia)
+- Fixed bug #42739 (mkdir() doesn't like a trailing slash when safe_mode is
+  enabled). (Ilia)
+- Fixed bug #42703 (Exception raised in an iterator::current() causes segfault
+  in FilterIterator) (Marcus)
+- Fixed bug #42699 (PHP_SELF duplicates path). (Dmitry)
+- Fixed bug #42654 (RecursiveIteratorIterator modifies only part of leaves)
+  (Marcus)
+- Fixed bug #42643 (CLI segfaults if using ATTR_PERSISTENT). (Ilia)
+- Fixed bug #42637 (SoapFault : Only http and https are allowed). (Bill Moran)
+- Fixed bug #42629 (Dynamically loaded PHP extensions need symbols exported
+  on MacOSX). (jdolecek at NetBSD dot org)
+- Fixed bug #42627 (bz2 extension fails to build with -fno-common).
+  (dolecek at netbsd dot org)
+- Fixed Bug #42596 (session.save_path MODE option does not work). (Ilia)
+- Fixed bug #42590 (Make the engine recognize \v and \f escape sequences).
+  (Ilia)
+- Fixed bug #42587 (behavior change regarding symlinked .php files). (Dmitry)
+- Fixed bug #42579 (apache_reset_timeout() does not exist). (Jani)
+- Fixed bug #42549 (ext/mysql failed to compile with libmysql 3.23). (Scott)
+- Fixed bug #42523 (PHP_SELF duplicates path). (Dmitry)
+- Fixed bug #42512 (ip2long('255.255.255.255') should return 4294967295 on
+  64-bit PHP). (Derick)
+- Fixed bug #42506 (php_pgsql_convert() timezone parse bug) (nonunnet at
+  gmail dot com, Ilia)
+- Fixed bug #42496 (OCI8 cursor is not closed when using 2 clobs in a select
+  query). (Oracle Corp.)
+- Fixed bug #42462 (Segmentation when trying to set an attribute in a
+  DOMElement). (Rob)
+- Fixed bug #42453 (CGI SAPI does not shut down cleanly with -i/-m/-v cmdline
+  options). (Dmitry)
+- Fixed bug #42452 (PDO classes do not expose Reflection API information).
+  (Hannes)
+- Fixed bug #42468 (Write lock on file_get_contents fails when using a
+  compression stream). (Ilia)
+- Fixed bug #42488 (SoapServer reports an encoding error and the error itself
+  breaks). (Dmitry)
+- Fixed bug #42378 (mysqli_stmt_bind_result memory exhaustion). (Andrey)
+- Fixed bug #42359 (xsd:list type not parsed). (Dmitry)
+- Fixed bug #42326 (SoapServer crash). (Dmitry)
+- Fixed bug #42214 (SoapServer sends clients internal PHP errors). (Dmitry)
+- Fixed bug #42189 (xmlrpc_set_type() crashes php on invalid datetime
+  values). (Ilia)
+- Fixed bug #42139 (XMLReader option constants are broken using XML()). (Rob)
+- Fixed bug #42086 (SoapServer return Procedure '' not present for WSIBasic
+  compliant wsdl). (Dmitry)
+- Fixed bug #41822 (Relative includes broken when getcwd() fails). (Ab5602,
+  Jani)
+- Fixed bug #41561 (Values set with php_admin_* in httpd.conf can be overwritten
+  with ini_set()). (Stas, Jani)
+- Fixed bug #39651 (proc_open() append mode doesn't work on windows). (Nuno)
+30 Aug 2007, PHP 5.2.4
+- Removed --enable-versioning configure option. (Jani)
+- Upgraded PCRE to version 7.2 (Nuno)
+- Updated timezone database to version 2007.6. (Derick)
+- Improved openssl_x509_parse() to return extensions in readable form. (Dmitry)
+- Enabled changing the size of statement cache for non-persistent OCI8
+  connections. (Chris Jones, Tony)
+- Changed "display_errors" php.ini option to accept "stderr" as value which
+  makes the error messages to be outputted to STDERR instead of STDOUT with
+  CGI and CLI SAPIs (FR #22839). (Jani)
+- Changed error handler to send HTTP 500 instead of blank page on PHP errors.
+  (Dmitry, Andrei Nigmatulin)
+- Changed mail() function to be always available. (Johannes)
+- Added check for unknown options passed to configure. (Jani)
+- Added persistent connection status checker to pdo_pgsql.
+  (Elvis Pranskevichus, Ilia)
+- Added support for ATTR_TIMEOUT inside pdo_pgsql driver. (Ilia)
+- Added php_ini_loaded_file() function which returns the path to the actual
+  php.ini in use. (Jani)
+- Added GD version constants GD_MAJOR_VERSION, GD_MINOR_VERSION,
+  GD_RELEASE_VERSION, GD_EXTRA_VERSION and GD_VERSION_STRING. (Pierre)
+- Added missing open_basedir checks to CGI.
+  (anight at eyelinkmedia dot com, Tony)
+- Added missing format validator to unpack() function. (Ilia)
+- Added missing error check inside bcpowmod(). (Ilia)
+- Added CURLOPT_PRIVATE & CURLINFO_PRIVATE constants.
+  (Andrey A. Belashkov, Tony)
+- Added missing MSG_EOR and MSG_EOF constants to sockets extension. (Jani)
+- Added PCRE_VERSION constant. (Tony)
+- Added ReflectionExtension::info() function to print the phpinfo()
+  block for an extension. (Johannes)
+- Implemented FR #41884 (ReflectionClass::getDefaultProperties() does not
+  handle static attributes). (Tony)
+- Fixed "Floating point exception" inside wordwrap().
+  (Mattias Bengtsson, Ilia)
+- Fixed several integer overflows in ImageCreate(), ImageCreateTrueColor(),
+  ImageCopyResampled() and ImageFilledPolygon() reported by Mattias Bengtsson.
+  (Tony)
+- Fixed size calculation in chunk_split(). (Stas)
+- Fixed integer overflow in str[c]spn(). (Stas)
+- Fixed money_format() not to accept multiple %i or %n tokens.
+  (Stas, Ilia)
+- Fixed zend_alter_ini_entry() memory_limit interruption
+  vulnerability. (Ilia)
+- Fixed INFILE LOCAL option handling with MySQL extensions not to be
+  allowed when open_basedir or safe_mode is active. (Stas)
+- Fixed session.save_path and error_log values to be checked against
+  open_basedir and safe_mode (CVE-2007-3378) (Stas, Maksymilian Arciemowicz)
+- Fixed possible invalid read in glob() win32 implementation (CVE-2007-3806).
+  (Tony)
+- Improved fix for MOPB-03-2007. (Ilia)
+- Corrected fix for CVE-2007-2872. (Ilia)
+- Fixed possible crash in imagepsloadfont(), work around a bug in the pslib on
+  Windows. (Pierre)
+- Fixed oci8 and PDO_OCI extensions to allow configuring with Oracle 11g
+  client libraries. (Chris Jones)
+- Fixed EOF handling in case of reading from file opened in write only mode.
+  (Dmitry)
+- Fixed var_export() to use the new H modifier so that it can generate
+  parseable PHP code for floats, independent of the locale. (Derick)
+- Fixed regression introduced by the fix for the libgd bug #74. (Pierre)
+- Fixed SimpleXML's behavior when used with empty(). (Sara)
+- Fixed crash in OpenSSL extension because of non-string passphrase. (Dmitry)
+- Fixed PECL Bug #11345 (PDO_OCI crash after National language Support "NLS"
+  environment initialization error). (Chris Jones)
+- Fixed PECL bug #11216 (crash in ZipArchive::addEmptyDir when a directory
+  already exists). (Pierre)
+- Fixed bug #43926 (isInstance() isn't equivalent to instanceof operator). (Marcus)
+- Fixed bug #42368 (Incorrect error message displayed by pg_escape_string).
+  (Ilia)
+- Fixed bug #42365 (glob() crashes and/or accepts way too many flags).
+  (Jani)
+- Fixed Bug #42364 (Crash when using getRealPath with DirectoryIterator).
+  (Johannes)
+- Fixed bug #42292 ($PHP_CONFIG not set for phpized builds). (Jani)
+- Fixed bug #42261 (header wrong for date field).
+  (roberto at spadim dot com dot br, Ilia)
+- Fixed bug #42259 (SimpleXMLIterator loses ancestry). (Rob)
+- Fixed bug #42247 (ldap_parse_result() not defined under win32). (Jani)
+- Fixed bug #42243 (copy() does not output an error when the first arg is a
+  dir). (Ilia)
+- Fixed bug #42242 (sybase_connect() crashes). (Ilia)
+- Fixed bug #42237 (stream_copy_to_stream returns invalid values for mmaped
+  streams). (andrew dot minerd at sellingsource dot com, Ilia)
+- Fixed bug #42233 (Problems with æøå in extract()). (Jani)
+- Fixed bug #42222 (possible buffer overflow in php_openssl_make_REQ). (Pierre)
+- Fixed bug #42211 (property_exists() fails to find protected properties
+  from a parent class). (Dmitry)
+- Fixed bug #42208 (substr_replace() crashes when the same array is passed
+  more than once). (crrodriguez at suse dot de, Ilia)
+- Fixed bug #42198 (SCRIPT_NAME and PHP_SELF truncated when inside a userdir
+  and using PATH_INFO). (Dmitry)
+- Fixed bug #42195 (C++ compiler required always). (Jani)
+- Fixed bug #42183 (classmap causes crash in non-wsdl mode). (Dmitry)
+- Fixed bug #42173 (oci8 INTERVAL and TIMESTAMP type fixes). (Chris)
+- Fixed bug #42151 (__destruct functions not called after catching a SoapFault
+  exception). (Dmitry)
+- Fixed bug #42142 (substr_replace() returns FALSE when length > string length).
+  (Ilia)
+- Fixed bug #42135 (Second call of session_start() causes creation of SID).
+  (Ilia)
+- Fixed bug #42134 (oci_error() returns false after oci_new_collection() fails).
+  (Tony)
+- Fixed bug #42119 (array_push($arr,&$obj) doesn't work with
+  zend.ze1_compatibility_mode On). (Dmitry)
+- Fixed bug #42117 (bzip2.compress loses data in internal buffer).
+  (Philip, Ilia)
+- Fixed bug #42112 (deleting a node produces memory corruption). (Rob)
+- Fixed bug #42107 (sscanf broken when using %2$s format parameters). (Jani)
+- Fixed bug #42090 (json_decode causes segmentation fault). (Hannes)
+- Fixed bug #42082 (NodeList length zero should be empty). (Hannes)
+- Fixed bug #42072 (No warning message for clearstatcache() with arguments).
+  (Ilia)
+- Fixed bug #42071 (ini scanner allows using NULL as option name). (Jani)
+- Fixed bug #42027 (is_file() / is_dir() matches file/dirnames with wildcard char
+  or trailing slash in Windows). (Dmitry)
+- Fixed bug #42019 (configure option --with-adabas=DIR does not work). (Jani)
+- Fixed bug #42015 (ldap_rename(): server error "DSA is unwilling to perform").
+  (bob at mroczka dot com, Jani)
+- Fixed bug #42009 (is_a() and is_subclass_of() should NOT call autoload, in the
+  same way as "instanceof" operator). (Dmitry)
+- Fixed bug #41989 (move_uploaded_file() & relative path in ZTS mode). (Tony)
+- Fixed bug #41984 (Hangs on large SoapClient requests). (Dmitry)
+- Fixed bug #41983 (Error Fetching http headers terminated by '\n'). (Dmitry)
+- Fixed bug #41973 (--with-ldap=shared fails with LDFLAGS="-Wl,--as-needed"). (Nuno)
+- Fixed bug #41971 (PDOStatement::fetch and PDOStatement::setFetchMode causes
+  unexpected behavior). (Ilia)
+- Fixed bug #41964 (strtotime returns a timestamp for non-time string of
+  pattern '(A|a) .+'). (Derick)
+- Fixed bug #41961 (Ensure search for hidden private methods does not stray from
+  class hierarchy). (robin_fernandes at uk dot ibm dot com)
+- Fixed bug #41947 (SimpleXML incorrectly registers empty strings asnamespaces).
+  (Rob)
+- Fixed bug #41929 (Foreach on object does not iterate over all visible properties).
+  (Dmitry)
+- Fixed bug #41919 (crash in string to array conversion).
+  (judas dot iscariote at gmail dot com, Ilia)
+- Fixed bug #41909 (var_export() is locale sensitive when exporting float
+  values). (Derick)
+- Fixed bug #41908 (CFLAGS="-Os" ./configure --enable-debug fails).
+  (christian at hoffie dot info, Tony)
+- Fixed bug #41904 (proc_open(): empty env array should cause empty environment
+  to be passed to process). (Jani)
+- Fixed bug #41867 (SimpleXML: getName is broken). (Rob)
+- Fixed bug #41865 (fputcsv(): 2nd parameter is not optional). (Jani)
+- Fixed bug #41861 (SimpleXML: getNamespaces() returns the namespaces of a node's
+  siblings). (Rob)
+- Fixed bug #41845 (pgsql extension does not compile with PostgreSQL <7.4). (Ilia)
+- Fixed bug #41844 (Format returns incorrect number of digits for negative years
+  -0001 to -0999). (Derick)
+- Fixed bug #41842 (Cannot create years < 0100 & negative years with date_create
+  or new DateTime). (Derick)
+- Fixed bug #41833 (addChild() on a non-existent node, no node created,
+  getName() segfaults). (Rob)
+- Fixed bug #41831 (pdo_sqlite prepared statements convert resources to
+  strings). (Ilia)
+- Fixed bug #41815 (Concurrent read/write fails when EOF is reached). (Sascha)
+- Fixed bug #41813 (segmentation fault when using string offset as an object).
+  (judas dot iscariote at gmail dot com, Tony)
+- Fixed bug #41795 (checkdnsrr does not support DNS_TXT type).
+  (lucas at facebook dot com, Tony)
+- Fixed bug #41773 (php_strip_whitespace() sends headers with errors
+  suppressed). (Tony)
+- Fixed bug #41770 (SSL: fatal protocol error due to buffer issues). (Ilia)
+- Fixed bug #41765 (Recode crashes/does not work on amd64).
+  (nexus at smoula dot net, Stas)
+- Fixed bug #41724 (libxml_get_last_error() - errors service request scope).
+  (thekid at php dot net, Ilia)
+- Fixed bug #41717 (imagepolygon does not respect thickness). (Pierre)
+- Fixed bug #41713 (Persistent memory consumption on win32 since 5.2). (Dmitry)
+- Fixed bug #41711 (NULL temporary lobs not supported in OCI8).
+  (Chris Jones, Tony)
+- Fixed bug #41709 (strtotime() does not handle 00.00.0000). (Derick)
+- Fixed bug #41698 (float parameters truncated to integer in prepared
+  statements). (Ilia)
+- Fixed bug #41692 (ArrayObject shows weird behavior in respect to
+  inheritance). (Tony)
+- Fixed bug #41691 (ArrayObject::exchangeArray hangs Apache). (Tony)
+- Fixed bug #41686 (Omitting length param in array_slice not possible). (Ilia)
+- Fixed bug #41685 (array_push() fails to warn when next index is
+  already occupied). (Ilia)
+- Fixed bug #41655 (open_basedir bypass via glob()). (Ilia)
+- Fixed bug #41640 (get_class_vars produces error on class constants).
+  (Johannes)
+- Fixed bug #41635 (SoapServer and zlib.output_compression with FastCGI
+  result in major slowdown). (Dmitry)
+- Fixed bug #41633 (Crash instantiating classes with self-referencing
+  constants). (Dmitry)
+- Fixed bug #41630 (segfault when an invalid color index is present in the
+  image data). (Reported by Elliot <wccoder at gmail dot com>) (Pierre)
+- Fixed bug #41628 (PHP settings leak between Virtual Hosts in Apache 1.3).
+  (Scott, manuel at mausz dot at)
+- Fixed bug #41608 (segfault on a weird code with objects and switch()).
+  (Tony)
+- Fixed bug #41600 (url rewriter tags doesn't work with namespaced tags).
+  (Ilia)
+- Fixed bug #41596 (Fixed a crash inside pdo_pgsql on some non-well-formed
+  SQL queries). (Ilia)
+- Fixed bug #41594 (OCI8 statement cache is flushed too frequently). (Tony)
+- Fixed bug #41582 (SimpleXML crashes when accessing newly created element).
+  (Tony)
+- Fixed bug #41576 (configure failure when using --without-apxs or some other
+  SAPIs disabling options). (Jani)
+- Fixed bug #41567 (json_encode() double conversion is inconsistent with PHP).
+  (Lucas, Ilia)
+- Fixed bug #41566 (SOAP Server not properly generating href attributes).
+  (Dmitry)
+- Fixed bug #41555 (configure failure: regression caused by fix for #41265).
+  (Jani)
+- Fixed bug #41527 (WDDX deserialize numeric string array key).
+  (Matt, Ilia)
+- Fixed bug #41523 (strtotime('0000-00-00 00:00:00') is parsed as 1999-11-30).
+  (Derick)
+- Fixed bug #41518 (file_exists() warns of open_basedir restriction on
+  non-existent file). (Tony)
+- Fixed bug #41445 (parse_ini_file() has a problem with certain types of
+  integer as sections). (Tony)
+- Fixed bug #41433 (DBA: configure fails to include correct db.h for db4).
+  (Jani)
+- Fixed bug #41372 (Internal pointer of source array resets during array
+  copying). (Dmitry)
+- Fixed bug #41350 (my_thread_global_end() error during request shutdown on
+  Windows). (Scott, Andrey)
+- Fixed bug #41278 (get_loaded_extensions() should list Zend extensions).
+  (Johannes)
+- Fixed bug #41127 (Memory leak in ldap_{first|next}_attribute functions).
+  (Jani)
+- Fixed bug #40757 (get_object_vars get nothing in child class). (Dmitry)
+- Fixed bug #40705 (Iterating within function moves original array pointer).
+  (Dmitry)
+- Fixed bug #40509 (key() function changed behaviour if global array is used
+  within function). (Dmitry)
+- Fixed bug #40419 (Trailing slash in CGI request does not work). (Dmitry)
+- Fixed bug #39330 (apache2handler does not call shutdown actions before
+  apache child die). (isk at ecommerce dot com, Gopal, Tony)
+- Fixed bug #39291 (ldap_sasl_bind() misses the sasl_authc_id parameter).
+  (diafour at gmail dot com, Jani)
+- Fixed bug #37715 (array pointers resetting on copy). (Dmitry)
+- Fixed bug #37273 (Symlinks and mod_files session handler allow open_basedir
+  bypass). (Ilia)
+- Fixed bug #36492 (Userfilters can leak buckets). (Sara)
+- Fixed bugs #36796, #36918, #41371 (stream_set_blocking() does not work).
+  (Jani)
+- Fixed bug #35981 (pdo-pgsql should not use pkg-config when not present).
+  (Jani)
+- Fixed bug #31892 (PHP_SELF incorrect without cgi.fix_pathinfo, but turning on
+  screws up PATH_INFO). (Dmitry)
+- Fixed bug #21197 (socket_read() outputs error with PHP_NORMAL_READ).
+  (Nuno, Jani)
+31 May 2007, PHP 5.2.3
+- Changed CGI install target to php-cgi and 'make install' to install CLI
+  when CGI is selected. (Jani)
+- Changed JSON maximum nesting depth from 20 to 128. (Rasmus)
+- Improved compilation of heredocs and interpolated strings. (Matt, Dmitry)
+- Optimized out a couple of per-request syscalls. (Rasmus)
+- Optimized digest generation in md5() and sha1() functions. (Ilia)
+- Upgraded bundled SQLite 3 to version 3.3.17. (Ilia)
+- Added "max_input_nesting_level" php.ini option to limit nesting level of
+  input variables. Fix for MOPB-03-2007. (Stas)
+- Added a 4th parameter flag to htmlspecialchars() and htmlentities() that
+  makes the function not encode existing html entities. (Ilia)
+- Added PDO::FETCH_KEY_PAIR mode that will fetch a 2 column result set into
+  an associated array. (Ilia)
+- Added CURLOPT_TIMEOUT_MS and CURLOPT_CONNECTTIMEOUT_MS cURL constants. (Sara)
+- Added --ini switch to CLI that prints out configuration file names. (Marcus)
+- Added mysql_set_charset() to allow runtime altering of connection encoding.
+  (Scott)
+- Implemented FR #41416 (getColumnMeta() should also return table name). (Tony)
+- Fixed an integer overflow inside chunk_split(). Identified by Gerhard Wagner.
+  (Ilia)
+- Fixed SOAP extension's handler() to work even when
+  "always_populate_raw_post_data" is off. (Ilia)
+- Fixed possible infinite loop in imagecreatefrompng. (libgd #86)
+  (by Xavier Roche, CVE-2007-2756). (Pierre)
+- Fixed ext/filter Email Validation Vulnerability (MOPB-45 by Stefan Esser).
+  (Ilia)
+- Fixed altering $this via argument named "this". (Dmitry)
+- Fixed PHP CLI usage of php.ini from the binary location. (Hannes)
+- Fixed segfault in strripos(). (Tony, Joxean Koret)
+- Fixed bug #41693 (scandir() allows empty directory names). (Ilia)
+- Fixed bug #41673 (json_encode breaks large numbers in arrays). (Ilia)
+- Fixed bug #41525 (ReflectionParameter::getPosition() not available). (Marcus)
+- Fixed bug #41511 (Compile failure under IRIX 6.5.30 building md5.c). (Jani)
+- Fixed bug #41504 (json_decode() incorrectly decodes JSON arrays with empty
+  string keys). (Ilia)
+- Fixed bug #41492 (open_basedir/safe_mode bypass inside realpath()). (Ilia)
+- Fixed bug #41477 (no arginfo about SoapClient::__soapCall()). (Ilia)
+- Fixed bug #41455 (ext/dba/config.m4 pollutes global $LIBS and $LDFLAGS).
+  (mmarek at suse dot cz, Tony)
+- Fixed bug #41442 (imagegd2() under output control). (Tony)
+- Fixed bug #41430 (Fatal error with negative values of maxlen parameter of
+  file_get_contents()). (Tony)
+- Fixed bug #41423 (PHP assumes wrongly that certain ciphers are enabled in
+  OpenSSL). (Pierre)
+- Fixed bug #41421 (Uncaught exception from a stream wrapper segfaults).
+  (Tony, Dmitry)
+- Fixed bug #41403 (json_decode cannot decode floats if localeconv
+  decimal_point is not '.'). (Tony)
+- Fixed bug #41401 (wrong unary operator precedence). (Stas)
+- Fixed bug #41394 (dbase_create creates file with corrupted header). (Tony)
+- Fixed bug #41390 (Clarify error message with invalid protocol scheme).
+  (Scott)
+- Fixed bug #41378 (fastcgi protocol lacks support for Reason-Phrase in
+  "Status:" header). (anight at eyelinkmedia dot com, Dmitry)
+- Fixed bug #41374 (whole text concats values of wrong nodes). (Rob)
+- Fixed bug #41358 (configure cannot determine SSL lib with libcurl >= 7.16.2).
+  (Mike)
+- Fixed bug #41353 (crash in openssl_pkcs12_read() on invalid input). (Ilia)
+- Fixed bug #41351 (Invalid opcode with foreach ($a[] as $b)). (Dmitry, Tony)
+- Fixed bug #41347 (checkdnsrr() segfaults on empty hostname). (Scott)
+- Fixed bug #41337 (WSDL parsing doesn't ignore non soap bindings). (Dmitry)
+- Fixed bug #41326 (Writing empty tags with Xmlwriter::WriteElement[ns])
+  (Pierre)
+- Fixed bug #41321 (downgrade read errors in getimagesize() to E_NOTICE).
+  (Ilia)
+- Fixed bug #41304 (compress.zlib temp files left). (Dmitry)
+- Fixed bug #41293 (Fixed creation of HTTP_RAW_POST_DATA when there is no
+  default post handler). (Ilia)
+- Fixed bug #41291 (FastCGI does not set SO_REUSEADDR).
+  (fmajid at kefta dot com, Dmitry)
+- Fixed gd build when used with freetype 1.x (Pierre, Tony)
+- Fixed bug #41287 (Namespace functions don't allow xmlns definition to be
+  optional). (Rob)
+- Fixed bug #41285 (Improved fix for CVE-2007-1887 to work with non-bundled
+  sqlite2 lib). (Ilia)
+- Fixed bug #41283 (Bug with deserializing array key that are doubles or
+  floats in wddx). (Ilia)
+- Fixed bug #41257 (lookupNamespaceURI does not work as expected). (Rob)
+- Fixed bug #41236 (Regression in timeout handling of non-blocking SSL
+  connections during reads and writes). (Ilia)
+- Fixed bug #41134 (zend_ts_hash_clean not thread-safe).
+  (marco dot cova at gmail dot com, Tony)
+- Fixed bug #41097 (ext/soap returning associative array as indexed without
+  using WSDL). (Dmitry)
+- Fixed bug #41004 (minOccurs="0" and null class member variable). (Dmitry)
+- Fixed bug #39542 (Behavior of require/include different to < 5.2.0).
+  (Dmitry)
+03 May 2007, PHP 5.2.2
+- Improved bundled GD
+  . Sync to 2.0.35
+  . Added imagegrabwindow and imagegrabscreen, capture a screen or a
+    window using its handle (Pierre)
+  . colors allocated henceforth from the resulting image overwrite the palette
+    colors (Rob Leslie)
+  . Improved thread safety of the gif support (Roman Nemecek, Nuno, Pierre)
+  . Use the dimension of the GIF frame to create the destination image (Pierre)
+  . Load only once the local color map from a GIF data (Pierre)
+  . Improved thread safety of the freetype cache (Scott MacVicar, Nuno, Pierre)
+  . imagearc huge CPU usage with large angles, libgd bug #74 (Pierre)
+- Improved FastCGI SAPI to support external pipe and socket servers on win32.
+  (Dmitry)
+- Improved Zend Memory Manager
+  . guarantee of reasonable time for worst cases of best-fit free block
+    searching algorithm. (Dmitry)
+  . better cache usage and less fragmentation on erealloc() (Tony, Dmitry)
+- Improved SPL (Marcus)
+  . Added SplFileInfo::getBasename(), DirectoryIterator::getBasename().
+  . Added SplFileInfo::getLinkTarget(), SplFileInfo::getRealPath().
+  . Made RecursiveFilterIterator::accept() abstract as stated in documentation.
+- Improved SOAP
+  . Added ability to encode arrays with "SOAP-ENC:Array" type instead of WSDL
+    type. To activate the ability use "feature"=>SOAP_USE_XSI_ARRAY_TYPE
+    option in SoapClient/SoapServer constructors. (Rob, Dmitry)
+- Added GMP_VERSION constant. (Tony)
+- Added --ri switch to CLI which allows to check extension information. (Marcus)
+- Added tidyNode::getParent() method (John, Nuno)
+- Added openbasedir and safemode checks in zip:// stream wrapper and
+  ZipArchive::open (Pierre)
+- Added php_pdo_sqlite_external.dll, a version of the PDO SQLite driver that
+  links against an external sqlite3.dll.  This provides Windows users to upgrade
+  their sqlite3 version outside of the PHP release cycle.  (Wez, Edin)
+- Added linenumbers to array returned by token_get_all(). (Johannes)
+- Upgraded SQLite 3 to version 3.3.16 (Ilia)
+- Upgraded libraries bundled in the Windows distribution. (Edin)
+  . c-client (imap) to version 2006e
+  . libpq (PostgreSQL) to version 8.2.3
+  . libmysql (MySQL) to version 5.0.37
+  . openssl to version 0.9.8e
+- Upgraded PCRE to version 7.0 (Nuno)
+- Updated timezone database to version 2007.5. (Derick)
+- Fixed commandline handling for CLI and CGI. (Marcus, Johannes)
+- Fixed iterator_apply() with a callback using __call(). (Johannes)
+- Fixed possible multi bytes issues in openssl csr parser (Pierre)
+- Fixed shmop_open() with IPC_CREAT|IPC_EXCL flags on Windows.
+  (Vladimir Kamaev, Tony).
+- Fixed possible leak in ZipArchive::extractTo when safemode checks fails (Ilia)
+- Fixed possible relative path issues in zip_open and TS mode (old API) (Pierre)
+- Fixed zend_llist_remove_tail (Michael Wallner, Dmitry)
+- Fixed a thread safety issue in gd gif read code (Nuno, Roman Nemecek)
+- Fixed CVE-2007-1001, GD wbmp used with invalid image size (Pierre)
+- Fixed unallocated memory access/double free in in array_user_key_compare()
+  (MOPB-24 by Stefan Esser) (Stas)
+- Fixed wrong length calculation in unserialize S type
+  (MOPB-29 by Stefan Esser) (Stas)
+- Fixed bug #41215 (setAttribute return code reversed). (Ilia)
+- Fixed bug #41192 (Per Directory Values only work for one key). (Dmitry)
+- Fixed bug #41175 (addAttribute() fails to add an attribute with an empty
+  value). (Ilia)
+- Fixed bug #41159 (mysql_pconnect() hash does not account for connect
+  flags). (Ilia)
+- Fixed bug #41121 (range() overflow handling for large numbers on 32bit
+  machines). (Ilia)
+- Fixed bug #41118 (PHP does not handle overflow of octal integers). (Tony)
+- Fixed bug #41109 (recursiveiterator.inc says "implements" Iterator instead of
+  "extends"). (Marcus)
+- Fixed bug #40130 (TTF usage doesn't work properly under Netware). (Scott,
+  gk at gknw dot de)
+- Fixed bug #41093 (magic_quotes_gpc ignores first arrays keys). (Arpad, Ilia)
+- Fixed bug #41075 (memleak when creating default object caused exception).
+  (Dmitry)
+- Fixed bug #41067 (json_encode() problem with UTF-16 input). (jp at df5ea
+  dot net. Ilia)
+- Fixed bug #41063 (chdir doesn't like root paths). (Dmitry)
+- Fixed bug #41061 ("visibility error" in ReflectionFunction::export()).
+  (Johannes)
+- Fixed bug #41043 (pdo_oci crash when freeing error text with persistent
+  connection). (Tony)
+- Fixed bug #41037 (unregister_tick_function() inside the tick function crash PHP).
+  (Tony)
+- Fixed bug #41034 (json_encode() ignores null byte started keys in arrays).
+  (Ilia)
+- Fixed bug #41026 (segfault when calling "self::method()" in shutdown functions).
+  (Tony)
+- Fixed bug #40999 (mcrypt_create_iv() not using random seed). (Ilia)
+- Fixed bug #40998 (long session array keys are truncated). (Tony)
+- Implement feature request #40947, allow a single filter as argument
+  for filter_var_array (Pierre)
+- Fixed bug #40935 (pdo_mysql does not raise an exception on empty
+- Fixed bug #40931 (open_basedir bypass via symlink and move_uploaded_file()).
+  (Tony)
+- Fixed bug #40921 (php_default_post_reader crashes when post_max_size is
+  exceeded). (trickie at gmail dot com, Ilia)
+- Fixed bug #40915 (addcslashes unexpected behavior with binary input). (Tony)
+- Fixed bug #40899 (memory leak when nesting list()). (Dmitry)
+- Fixed bug #40897 (error_log file not locked). (Ilia)
+- Fixed bug #40883 (mysql_query() is allocating memory incorrectly). (Tony)
+- Fixed bug #40872 (inconsistency in offsetSet, offsetExists treatment of
+  string enclosed integers). (Marcus)
+- Fixed bug #40861 (strtotime() doesn't handle double negative relative time
+  units correctly). (Derick, Ilia)
+- Fixed bug #40854 (imap_mail_compose() creates an invalid terminator for
+  multipart e-mails). (Ilia)
+- Fixed bug #40848 (sorting issue on 64-bit Solaris). (Wez)
+- Fixed bug #40836 (Segfault in ext/dom). (Rob)
+- Fixed bug #40833 (Crash when using unset() on an ArrayAccess object retrieved
+  via __get()). (Dmitry)
+- Fixed bug #40822 (pdo_mysql does not return rowCount() on select). (Ilia)
+- Fixed bug #40815 (using strings like "class::func" and static methods in
+  set_exception_handler() might result in crash). (Tony)
+- Fixed bug #40809 (Poor performance of ".="). (Dmitry)
+- Fixed bug #40805 (Failure executing function ibase_execute()). (Tony)
+- Fixed bug #40800 (cannot disable memory_limit with -1). (Dmitry, Tony)
+- Fixed bug #40794 (ReflectionObject::getValues() may crash when used with
+  dynamic properties). (Tony)
+- Fixed bug #40784 (Case sensitivity in constructor's fallback). (Tony)
+- Fixed bug #40770 (Apache child exits when PHP memory limit reached). (Dmitry)
+- Fixed bug #40764 (line thickness not respected for horizontal and vertical
+  lines). (Pierre)
+- Fixed bug #40758 (Test fcgi_is_fastcgi() is wrong on windows). (Dmitry)
+- Fixed bug #40754 (added substr() & substr_replace() overflow checks). (Ilia)
+- Fixed bug #40752 (parse_ini_file() segfaults when a scalar setting is
+  redeclared as an array). (Tony)
+- Fixed bug #40750 (openssl stream wrapper ignores default_stream_timeout).
+  (Tony)
+- Fixed bug #40727 (segfault in PDO when failed to bind parameters). (Tony)
+- Fixed bug #40709 (array_reduce() behaves strange with one item stored arrays).
+  (Ilia)
+- Fixed bug #40703 (Resolved a possible namespace conflict between libxmlrpc
+  and MySQL's NDB table handler). (Ilia)
+- Fixed bug #40961 (Incorrect results of DateTime equality check). (Mike)
+- Fixed bug #40678 (Cross compilation fails). (Tony)
+- Fixed bug #40621 (Crash when constructor called inappropriately). (Tony)
+- Fixed bug #40609 (Segfaults when using more than one SoapVar in a request).
+  (Rob, Dmitry)
+- Fixed bug #40606 (umask is not being restored when request is finished).
+  (Tony)
+- Fixed bug #40598 (libxml segfault). (Rob)
+- Fixed bug #40591 (list()="string"; gives invalid opcode). (Dmitry)
+- Fixed bug #40578 (imagettftext() multithreading issue). (Tony, Pierre)
+- Fixed bug #40576 (double values are truncated to 6 decimal digits when
+  encoding). (Tony)
+- Fixed bug #40560 (DIR functions do not work on root UNC path). (Dmitry)
+- Fixed bug #40548 (SplFileInfo::getOwner/getGroup give a warning on broken
+  symlink). (Marcus)
+- Fixed bug #40546 (SplFileInfo::getPathInfo() throws an exception if directory
+  is in root dir). (Marcus)
+- Fixed bug #40545 (multithreading issue in zend_strtod()). (Tony)
+- Fixed bug #40503 (json_encode() value corruption on 32bit systems with
+  overflown values). (Ilia)
+- Fixed bug #40467 (Partial SOAP request sent when XSD sequence or choice
+  include minOccurs=0). (Dmitry)
+- Fixed bug #40465 (Ensure that all PHP elements are printed by var_dump).
+  (wharmby at uk dot ibm dot com, Ilia)
+- Fixed bug #40464 (session.save_path wont use default-value when safe_mode
+  or open_basedir is enabled). (Ilia)
+- Fixed bug #40455 (proc_open() uses wrong command line when safe_mode_exec_dir
+  is set). (Tony)
+- Fixed bug #40432 (strip_tags() fails with greater than in attribute). (Ilia)
+- Fixed bug #40431 (dynamic properties may cause crash in ReflectionProperty
+  methods). (Tony)
+- Fixed bug #40451 (addAttribute() may crash when used with non-existent child
+  node). (Tony)
+- Fixed bug #40442 (ArrayObject::offsetExists broke in 5.2.1, works in 5.2.0).
+  (olivier at elma dot fr, Marcus)
+- Fixed bug #40428 (imagepstext() doesn't accept optional parameter). (Pierre)
+- Fixed bug #40417 (Allow multiple instances of the same named PDO token in
+  prepared statement emulation code). (Ilia)
+- Fixed bug #40414 (possible endless fork() loop when running fastcgi).
+  (Dmitry)
+- Fixed bug #40410 (ext/posix does not compile on MacOS 10.3.9). (Tony)
+- Fixed bug #40392 (memory leaks in PHP milter SAPI).
+  (tuxracer69 at gmail dot com, Tony)
+- Fixed bug #40371 (pg_client_encoding() not working on Windows). (Edin)
+- Fixed bug #40352 (FCGI_WEB_SERVER_ADDRS function get lost). (Dmitry)
+- Fixed bug #40290 (strtotime() returns unexpected result with particular
+  timezone offset). (Derick)
+- Fixed bug #40286 (PHP fastcgi with PHP_FCGI_CHILDREN don't kill children when
+  parent is killed). (Dmitry)
+- Fixed bug #40261 (Extremely slow data handling due to memory fragmentation).
+  (Dmitry)
+- Fixed bug #40236 (php -a function allocation eats memory). (Dmitry)
+- Fixed bug #40109 (iptcembed fails on non-jfif jpegs). (Tony)
+- Fixed bug #39965 (Latitude and longitude are backwards in date_sun_info()).
+  (Derick)
+- Implement #39867 (openssl PKCS#12 support) (Marc Delling, Pierre)
+- Fixed bug #39836 (SplObjectStorage empty after unserialize). (Marcus)
+- Fixed bug #39416 (Milliseconds in date()). (Derick)
+- Fixed bug #39396 (stream_set_blocking crashes on Win32). (Ilia, maurice at
+  iceblog dot de)
+- Fixed bug #39351 (relative include fails on Solaris). (Dmitry, Tony)
+- Fixed bug #39322 (proc_terminate() destroys process resource). (Nuno)
+- Fixed bug #38406 (crash when assigning objects to SimpleXML attributes). (Tony)
+- Fixed bug #37799 (ftp_ssl_connect() falls back to non-ssl connection). (Nuno)
+- Fixed bug #36496 (SSL support in imap_open() not working on Windows). (Edin)
+- Fixed bug #36226 (Inconsistent handling when passing nillable arrays).
+  (Dmitry)
+- Fixed bug #35872 (Avoid crash caused by object store being referenced during
+  RSHUTDOWN). (Andy)
+- Fixed bug #34794 (proc_close() hangs when used with two processes).
+  (jdolecek at netbsd dot org, Nuno)
+- Fixed PECL bug #10194 (crash in Oracle client when memory limit reached in
+  the callback). (Tony)
+- Fixed substr_compare and substr_count information leak (MOPB-14) (Stas, Ilia)
+- Fixed crash on op-assign where argument is string offset (Brian, Stas)
+- Fixed bug #38710 (data leakage because of nonexisting boundary checking in
+  statements in mysqli) (Stas)
+- Fixed bug #37386 (autocreating element doesn't assign value to first node).
+  (Rob)
+- Fixed bug #37013 (server hangs when returning circular object references).
+  (Dmitry)
+- Fixed bug #33664 Console window appears when using exec()
+  (Richard Quadling, Stas)
+08 Feb 2007, PHP 5.2.1
+- Added read-timeout context option "timeout" for HTTP streams. (Hannes, Ilia).
+- Added CURLOPT_TCP_NODELAY constant to Curl extension. (Sara)
+- Added support for hex numbers of any size. (Matt)
+- Added function stream_socket_shutdown(). It is a wrapper for system
+  shutdown() function, that shut downs part of a full-duplex connection.
+  (Dmitry)
+- Added internal heap protection (Dmitry)
+  . memory-limit is always enabled (--enable-memory-limit removed)
+  . default value if memory-limit is set to 128M
+  . safe unlinking
+  . cookies
+  . canary protection (debug build only)
+  . random generation of cookies and canaries
+- Added forward support for 'b' prefix in front of string literals. (Andrei)
+- Added three new functions to ext/xmlwriter (Rob, Ilia)
+  . xmlwriter_start_dtd_entity()
+  . xmlwriter_end_dtd_entity()
+  . xmlwriter_write_dtd_entity()
+- Added a meta tag to phpinfo() output to prevent search engines from indexing
+  the page. (Ilia)
+- Added new function, sys_get_temp_dir(). (Hartmut)
+- Added missing object support to file_put_contents(). (Ilia)
+- Added support for md2, ripemd256 and ripemd320 algos to hash(). (Sara)
+- Added forward support for (binary) cast. (Derick)
+- Added optimization for imageline with horizontal and vertical lines (Pierre)
+- Removed dependency from SHELL32.DLL. (Dmitry)
+- Removed double "wrong parameter count" warnings in various functions.
+  (Hannes)
+- Moved extensions to PECL:
+  . ext/informix (Derick, Tony)
+- Changed double-to-string utilities to use BSD implementation. (Dmitry, Tony)
+- Updated bundled libcURL to version 7.16.0 in the Windows distro. (Edin)
+- Updated timezone database to version 2006.16. (Derick)
+- cgi.* and fastcgi.* directives are moved to INI subsystem. The new directive
+  cgi.check_shebang_line can be used to omitting check for "#! /usr/bin/php"
+  line. (Dmitry).
+- Improved proc_open(). Now on Windows it can run external commands not
+  through CMD.EXE. (Dmitry)
+- VCWD_REALPATH() is improved to use realpath cache without VIRTUAL_DIR.
+  (Dmitry)
+- ext/bcmath initialization code is moved from request startup to module
+  startup. (Dmitry)
+- Zend Memory Manager Improvements (Dmitry)
+  . use HeapAlloc() instead of VirtualAlloc()
+  . use "win32" storage manager (instead of "malloc") on Windows by default
+- Zip Extension Improvements (Pierre)
+  . Fixed leak in statName and stateIndex
+  . Fixed return setComment (Hannes)
+  . Added addEmptyDir method
+- Filter Extension Improvements (Ilia, Pierre)
+  . Fixed a bug when callback function returns a non-modified value.
+  . Added filter support for $_SERVER in cgi/apache2 sapis.
+  . Make sure PHP_SELF is filtered in Apache 1 sapi.
+  . Fixed bug #39358 (INSTALL_HEADERS contains incorrect reference to
+    php_filter.h).
+  . Added "default" option that allows a default value to be set for an
+    invalid or missing value.
+  . Invalid filters fails instead of returning unsafe value
+  . Fixed possible double encoding problem with sanitizing filters
+  . Make use of space-strict strip_tags() function
+  . Fixed whitespace trimming
+  . Added support for FastCGI environment variables. (Dmitry)
+- PDO_MySQL Extension Improvements (Ilia)
+  . Enabled buffered queries by default.
+  . Enabled prepared statement emulation by default.
+- Small optimization of the date() function. (Matt,Ilia)
+- Optimized the internal is_numeric_string() function. (Matt,Ilia)
+- Optimized array functions utilizing php_splice(). (Ilia)
+- Windows related optimizations (Dmitry, Stas)
+  . COM initialization/deinitialization are done only if necessary
+  . removed unnecessary checks for ISREG file and corresponding stat() calls
+  . opendir() is reimplementation using GetFistFile/GetNextFile those are
+    faster then _findfirst/_findnext
+  . implemented registry cache that prevent registry lookup on each request.
+    In case of modification of corresponding registry-tree PHP will reload it
+    automatic
+  . start timeout thread only if necessary
+  . stat() is reimplementation using GetFileAttributesEx(). The new
+    implementation is faster then implementation in MS VC CRT, but it doesn't
+    support Windows 95.
+- Streams optimization (Dmitry)
+  . removed unnecessary ftell() calls (one call for each included PHP file)
+  . disabled calls to read() after EOF
+- Fixed incorrect function names on FreeBSD where inet_pton() was named
+  __inet_pton() and inet_ntop() was named __inet_ntop(). (Hannes)
+- Fixed FastCGI impersonation for persistent connections on Windows. (Dmitry)
+- Fixed wrong signature initialization in imagepng (Takeshi Abe)
+- Fixed ftruncate() with negative size on FreeBSD. (Hannes)
+- Fixed segfault in RegexIterator when given invalid regex. (Hannes)
+- Fixed segfault in SplFileObject->openFile()->getPathname(). (Hannes)
+- Fixed segfault in ZTS mode when OCI8 statements containing sub-statements
+  are destroyed in wrong order. (Tony)
+- Fixed the validate email filter so that the letter "v" can also be used in
+  the user part of the email address. (Derick)
+- Fixed bug #40297 (compile failure in ZTS mode when collections support is
+  missing). (Tony)
+- Fixed bug #40285 (The PDO prepare parser goes into an infinite loop in
+  some instances). (Ilia)
+- Fixed bug #40274 (Sessions fail with numeric root keys). (Ilia)
+- Fixed bug #40259 (ob_start call many times - memory error). (Dmitry)
+- Fixed bug #40231 (file_exists incorrectly reports false). (Dmitry)
+- Fixed bug #40228 (ZipArchive::extractTo does create empty directories
+  recursively). (Pierre)
+- Fixed bug #40200 (The FastCgi version has different realpath results than
+  thread safe version). (Dmitry)
+- Fixed bug #40191 (use of array_unique() with objects triggers segfault).
+  (Tony)
+- Fixed bug #40189 (possible endless loop in zlib.inflate stream filter).
+  (Greg, Tony)
+- Fixed bug #40169 (CURLOPT_TCP_NODELAY only available in curl >= 7.11.2).
+  (Tony)
+- Fixed bug #40129 (iconv extension doesn't compile with CodeWarrior on
+  Netware). (gk at gknw dot de, Tony)
+- Fixed bug #40127 (apache2handler doesn't compile on Netware).
+  (gk at gknw dot de)
+- Fixed bug #40121 (PDO_DBLIB driver wont free statements). (Ilia)
+- Fixed bug #40098 (php_fopen_primary_script() not thread safe). (Ilia)
+- Fixed bug #40092 (chroot() doesn't clear realpath cache). (Dmitry)
+- Fixed bug #40091 (spl_autoload_register with 2 instances of the same class).
+  (Ilia)
+- Fixed bug #40083 (milter SAPI functions always return false/null). (Tony)
+- Fixed bug #40079 (php_get_current_user() not thread safe).
+  (Ilia, wharmby at uk dot ibm dot com)
+- Fixed bug #40078 (ORA-01405 when fetching NULL values using
+  oci_bind_array_by_name()). (Tony)
+- Fixed bug #40076 (zend_alloc.c: Value of enumeration constant must be in
+  range of signed integer). (Dmitry)
+- Fixed bug #40073 (exif_read_data dies on certain images). (Tony, Marcus)
+- Fixed bug #40036 (empty() does not work correctly with ArrayObject when
+  using ARRAY_AS_PROPS). (Ilia)
+- Fixed bug #40012 (php_date.c doesn't compile on Netware).
+  (gk at gknw dot de, Derick)
+- Fixed bug #40009 (http_build_query(array()) returns NULL). (Ilia)
+- Fixed bug #40002 (Try/Catch performs poorly). (Dmitry)
+- Fixed bug #39993 (tr_TR.UTF-8 locale has problems with PHP). (Ilia)
+- Fixed bug #39990 (Cannot "foreach" over overloaded properties). (Dmitry)
+- Fixed bug #39988 (type argument of oci_define_by_name() is ignored).
+- Fixed bug #39984 (redirect response code in header() could be ignored
+  in CGI sapi). (Ilia)
+- Fixed bug #39979 (PGSQL_CONNECT_FORCE_NEW will causes next connect to
+  establish a new connection). (Ilia)
+- Fixed bug #39971 (pg_insert/pg_update do not allow now() to be used
+  for timestamp fields). (Ilia)
+- Fixed bug #39969 (ini setting short_open_tag has no effect when using
+  --enable-maintainer-zts). (Dmitry)
+- Fixed bug #39952 (zip ignoring --with-libdir on zlib checks)
+  (judas dot iscariote at gmail dot com)
+- Fixed bug #39944 (References broken). (Dmitry)
+- Fixed bug #39935 (Extensions tidy,mcrypt,mhash,pdo_sqlite ignores
+  --with-libdir). (judas dot iscariote at gmail dot com, Derick)
+- Fixed bug #39903 (Notice message when executing __halt_compiler() more than
+  once). (Tony)
+- Fixed bug #39898 (FILTER_VALIDATE_URL validates \r\n\t etc). (Ilia)
+- Fixed bug #39890 (using autoconf 2.6x and --with-layout=GNU breaks PEAR
+  install path). (Tony)
+- Fixed bug #39884 (ReflectionParameter::getClass() throws exception for
+  type hint self). (thekid at php dot net)
+- Fixed bug #39878 (CURL doesn't compile on Sun Studio Pro). (Ilia)
+- Fixed bug #39873 (number_format() breaks with locale & decimal points).
+  (Ilia)
+- Fixed bug #39869 (safe_read does not initialize errno).
+  (michiel at boland dot org, Dmitry)
+- Fixed bug #39850 (SplFileObject throws contradictory/wrong error messages
+  when trying to open "php://wrong"). (Tony)
+- Fixed bug #39846 (Invalid IPv4 treated as valid). (Ilia)
+- Fixed bug #39845 (Persistent connections generate a warning in pdo_pgsql).
+  (Ilia)
+- Fixed bug #39832 (SOAP Server: parameter not matching the WSDL specified
+  type are set to 0). (Dmitry)
+- Fixed bug #39825 (foreach produces memory error). (Dmitry)
+- Fixed bug #39816 (apxs2filter ignores httpd.conf & .htaccess php config
+  settings). (Ilia)
+- Fixed bug #39815 (SOAP double encoding is not locale-independent). (Dmitry)
+- Fixed bug #39797 (virtual() does not reset changed INI settings). (Ilia)
+- Fixed bug #39795 (build fails on AIX because crypt_r() uses different
+  data struct). (Tony)
+- Fixed bug #39791 (Crash in strtotime() on overly long relative date
+  multipliers). (Ilia)
+- Fixed bug #39787 (PHP doesn't work with Apache 2.3).
+  (mv at binarysec dot com).
+- Fixed bug #39782 (setTime() on a DateTime constructed with a Weekday
+  yields incorrect results). (Ilia)
+- Fixed bug #39780 (PNG image with CRC/data error raises fatal error) (Pierre)
+- Fixed bug #39779 (Enable AUTH PLAIN mechanism in underlying libc-client).
+  (michael dot heimpold at s2000 dot tu-chemnitz dot de, Ilia)
+- Fixed bug #39775 ("Indirect modification ..." message is not shown).
+  (Dmitry)
+- Fixed bug #39763 (magic quotes are applied twice by ext/filter in
+  parse_str()). (Ilia)
+- Fixed bug #39760 (cloning fails on nested SimpleXML-Object). (Rob)
+- Fixed bug #39759 (Can't use stored procedures fetching multiple result
+  sets in pdo_mysql). (Ilia)
+- Fixed bug #39754 (Some POSIX extension functions not thread safe).
+- Fixed bug #39751 (putenv crash on Windows). (KevinJohnHoffman at gmail.com)
+- Fixed bug #39732 (oci_bind_array_by_name doesn't work on Solaris 64bit).
+  (Tony)
+- Fixed bug #39724 (Broken build due to spl/filter usage of pcre extension).
+  (Tony, Ilia)
+- Fixed bug #39718 (possible crash if assert.callback is set in ini). (Ilia)
+- Fixed bug #39702 (php crashes in the allocator on linux-m68k). (Dmitry)
+- Fixed bug #39685 (iconv() - undefined function). (Hannes)
+- Fixed bug #39673 (file_get_contents causes bus error on certain offsets).
+  (Tony)
+- Fixed bug #39663 (Memory leak in pg_get_notify() and a possible memory
+  corruption on Windows in pgsql and pdo_pgsql extensions).
+  (Ilia, matteo at beccati dot com)
+- Fixed bug #39662 (Segfault when calling asXML() of a cloned
+  SimpleXMLElement). (Rob, Tony)
+- Fixed bug #39656 (crash when calling fetch() on a PDO statment object after
+  closeCursor()). (Ilia, Tony)
+- Fixed bug #39653 (ext/dba doesn't check for db-4.5 and db-4.4 when db4
+  support is enabled). (Tony)
+- Fixed bug #39652 (Wrong negative results from memory_get_usage()). (Dmitry)
+- Fixed bug #39648 (Implementation of PHP functions chown() and chgrp() are
+  not thread safe). (Ilia, wharmby at uk dot ibm dot com)
+- Fixed bug #39640 (Segfault with "Allowed memory size exhausted"). (Dmitry)
+- Fixed bug #39625 (Apache crashes on importStylesheet call). (Rob)
+- Fixed bug #39623 (thread safety fixes on *nix for putenv() & mime_magic).
+- Fixed bug #39621 (str_replace() is not binary safe on strings with equal
+  length). (Tony)
+- Fixed bug #39613 (Possible segfault in imap initialization due to missing
+  module dependency). (wharmby at uk dot ibm dot com, Tony)
+- Fixed bug #39606 (Use of com.typelib_file in PHP.ini STILL causes A/V). (Rob)
+- Fixed bug #39602 (Invalid session.save_handler crashes PHP). (Dmitry)
+- Fixed bug #39596 (Creating Variant of type VT_ARRAY). (Rob)
+- Fixed bug #39583 (ftp_put() does not change transfer mode to ASCII). (Tony)
+- Fixed bug #39576 (array_walk() doesn't separate user data zval). (Tony)
+- Fixed bug #39575 (move_uploaded_file() no longer working (safe mode
+  related)). (Tony)
+- Fixed bug #39571 (timeout ssl:// connections). (Ilia)
+- Fixed bug #39564 (PDO::errorInfo() returns inconsistent information when
+  sqlite3_step() fails). (Tony)
+- Fixed bug #39548 (ZMSG_LOG_SCRIPT_NAME not routed to OutputDebugString()
+  on Windows). (Dmitry)
+- Fixed bug #39538 (fgetcsv can't handle starting newlines and trailing odd
+  number of backslashes). (David Soria Parra, Pierre)
+- Fixed bug #39534 (Error in maths to calculate of
+  ZEND_MM_ALIGNED_MIN_HEADER_SIZE). (wharmby at uk dot ibm dot com, Dmitry)
+- Fixed bug #39527 (Failure to retrieve results when multiple unbuffered,
+  prepared statements are used in pdo_mysql). (Ilia)
+- Fixed bug #39508 (imagefill crashes with small images 3 pixels or less).
+  (Pierre)
+- Fixed bug #39506 (Archive corrupt with ZipArchive::addFile method). (Pierre)
+- Fixed bug #39504 (xmlwriter_write_dtd_entity() creates Attlist tag, not
+  entity). (Hannes)
+- Fixed bug #39483 (Problem with handling of \ char in prepared statements).
+  (Ilia, suhachov at gmail dot com)
+- Fixed bug #39458 (ftp_nlist() returns false on empty dirs). (Nuno)
+- Fixed bug #39454 (Returning a SOAP array segfaults PHP). (Dmitry)
+- Fixed bug #39450 (getenv() fills other super-globals). (Ilia, Tony)
+- Fixed bug #39449 (Overloaded array properties do not work correctly).
+  (Dmitry)
+- Fixed bug #39445 (Calling debug_backtrace() in the __toString()
+  function produces a crash). (Dmitry)
+- Fixed bug #39438 (Fatal error: Out of memory). (Dmitry)
+- Fixed bug #39435 ('foo' instanceof bar gives invalid opcode error). (Sara)
+- Fixed bug #39414 (Syntax error while compiling with Sun Workshop Complier).
+  (Johannes)
+- Fixed bug #39398 (Booleans are not automatically translated to integers).
+  (Ilia)
+- Fixed bug #39394 (Missing check for older variants of openssl). (Ilia)
+- Fixed bug #39367 (clearstatcache() doesn't clear realpath cache).
+  (j at pureftpd dot org, Dmitry)
+- Fixed bug #39366 (imagerotate does not use alpha with angle > 45 degrees)
+  (Pierre)
+- Fixed bug #39364 (Removed warning on empty haystack inside mb_strstr()).
+  (Ilia)
+- Fixed bug #39362 (Added an option to imap_open/imap_reopen to control the
+  number of connection retries). (Ilia)
+- Fixed bugs #39361 & #39400 (mbstring function overloading problem). (Seiji)
+- Fixed bug #39354 (Allow building of curl extension against libcurl
+  7.16.0). (Ilia)
+- Fixed bug #39350 (crash with implode("\n", array(false))). (Ilia)
+- Fixed bug #39344 (Unnecessary calls to OnModify callback routine for
+  an extension INI directive). (wharmby at uk dot ibm dot com, Dmitry)
+- Fixed bug #39320 (ZEND_HASH_APPLY_STOP causes deletion). (Marcus)
+- Fixed bug #39313 (spl_autoload triggers Fatal error). (Marcus)
+- Fixed bug #39300 (make install fails if wget is not available). (Tony)
+- Fixed bug #39297 (Memory corruption because of indirect modification of
+  overloaded array). (Dmitry)
+- Fixed bug #39286 (misleading error message when invalid dimensions are
+  given) (Pierre)
+- Fixed bug #39273 (imagecopyresized may ignore alpha channel) (Pierre)
+- Fixed bug #39265 (Fixed path handling inside mod_files.sh).
+  (michal dot taborsky at gmail dot com, Ilia)
+- Fixed bug #39217 (serialNumber might be -1 when the value is too large).
+  (Pierre, Tony)
+- Fixed bug #39215 (Inappropriate close of stdin/stdout/stderr). (Wez, Ilia)
+- Fixed bug #39201 (Possible crash in Apache 2 with 413 ErrorHandler). (Ilia)
+- Fixed bug #39151 (Parse error in recursiveiteratoriterator.php). (Marcus)
+- Fixed bug #39121 (Incorrect return array handling in non-wsdl soap client).
+  (Dmitry)
+- Fixed bug #39090 (DirectoryFilterDots doxygen docs and example is wrong).
+  (Marcus)
+- Fixed bug #38852 (XML-RPC Breaks iconv). (Hannes)
+- Fixed bug #38770 (unpack() broken with longs on 64 bit machines).
+  (Ilia, David Soria Parra).
+- Fixed bug #38698 (for some keys cdbmake creates corrupted db and cdb can't
+  read valid db). (Marcus)
+- Fixed bug #38680 (Added missing handling of basic types in json_decode).
+  (Ilia)
+- Fixed bug #38604 (Fixed request time leak inside foreach() when iterating
+  through virtual properties). (Dmitry)
+- Fixed bug #38602 (header( "HTTP/1.0 ..." ) does not change proto version).
+  (Ilia)
+- Fixed bug #38542 (proc_get_status() returns wrong PID on windows). (Nuno)
+- Fixed bug #38536 (SOAP returns an array of values instead of an object).
+  (Dmitry)
+- Fixed bug #38456 (Apache2 segfaults when virtual() is called in .php
+  ErrorDocument). (Ilia)
+- Fixed bug #38325 (spl_autoload_register() gives wrong line for "class not
+  found"). (Ilia)
+- Fixed bug #38319 (Remove bogus warnings from persistent PDO connections).
+  (Ilia)
+- Fixed bug #38274 (Memlimit fatal error sent to "wrong" stderr when using
+  fastcgi). (Dmitry)
+- Fixed bug #38252 (Incorrect PDO error message on invalid default fetch
+  mode). (Ilia)
+- Fixed bug #37927 (Prevent trap when COM extension processes argument of
+  type VT_DISPATCH|VT_REF) (Andy)
+- Fixed bug #37773 (iconv_substr() gives "Unknown error" when string
+  length = 1"). (Ilia)
+- Fixed bug #37627 (session save_path check checks the parent directory).
+  (Ilia)
+- Fixed bug #37619 (proc_open() closes stdin on fork() failure).
+  (jdolecek at NetBSD dot org, Nuno)
+- Fixed bug #37588 (COM Property propputref converts to PHP function
+  and can't be accesed). (Rob)
+- Fixed bug #36975 (natcasesort() causes array_pop() to misbehave).
+  (Hannes)
+- Fixed bug #36812 (pg_execute() modifies input array). (Ilia)
+- Fixed bug #36798 (Error parsing named parameters with queries containing
+  high-ascii chars). (Ilia)
+- Fixed bug #36644 (possible crash in variant_date_from_timestamp()). (Ilia)
+- Fixed bug #36427 (proc_open() / proc_close() leak handles on windows).
+- Fixed bug #36392 (wrong number of decimal digits with %e specifier in
+  sprintf). (Matt,Ilia)
+- Fixed bug #36214 (__get method works properly only when conditional
+  operator is used). (Dmitry)
+- Fixed bug #35634 (Erroneous "Class declarations may not be nested"
+  error raised). (Carl P. Corliss, Dmitry)
+- Fixed bug #35106 (nested foreach fails when array variable has a
+  reference). (Dmitry)
+- Fixed bug #34564 (COM extension not returning modified "out" argument) (Andy)
+- Fixed bug #33734 (Something strange with COM Object). (Rob)
+- Fixed bug #33386 (ScriptControl only sees last function of class). (Rob)
+- Fixed bug #33282 (Re-assignment by reference does not clear the is_ref
+  flag) (Ilia, Dmitry, Matt Wilmas)
+- Fixed bug #30074 (apparent symbol table error with
+  extract($blah, EXTR_REFS)) (Brian)
+- Fixed bug #29840 (is_executable() does not honor safe_mode_exec_dir
+  setting). (Ilia)
+- Fixed PECL bug #7295 (ORA-01405: fetched column value is NULL on LOB
+  fields). (Tony)
+02 Nov 2006, PHP 5.2.0
+- Updated bundled OpenSSL to version 0.9.8d in the Windows distro. (Edin)
+- Updated Postgresql client libraries to 8.1.4 in the Windows distro. (Edin)
+- Updated PCRE to version 6.7. (Ilia)
+- Updated libsqlite in ext/pdo_sqlite to 3.3.7. (Ilia)
+- Updated bundled MySQL client library to version 5.0.22 in the Windows
+  distribution. (Edin)
+- Updated timezonedb to version 2006.7. (Derick)
+- Added ability to make SOAP call userspace PHP<->XML converters. (Dmitry)
+- Added support for character sets in pg_escape_string() for PostgreSQL 8.1.4
+  and higher. (Ilia)
+- Added support for character sets in PDO quote() method for PostgreSQL 8.1.4
+- Added DSA key generation support to openssl_pkey_new(), FR #38731 (marci
+  at balabit dot hu, Tony)
+- Added SoapServer::setObject() method (it is a simplified version of
+  SoapServer::setClass() method). (Dmitry)
+- Added support for hexadecimal entity in imagettftext() for the bundled GD.
+  (Pierre)
+- Added support for httpOnly flag for session extension and cookie setting
+  functions. (Scott MacVicar, Ilia)
+- Added version specific registry keys to allow different configurations for
+  different php version. (Richard, Dmitry)
+- Added "PHPINIDir" Apache directive to apache and apache_hooks SAPIs.
+  (Dmitry)
+- Added an optional boolean parameter to memory_get_usage() and
+  memory_get_peak_usage() to get memory size allocated by emalloc() or real
+  size of memory allocated from system. (Dmitry)
+- Added Zip Archive extension. (Pierre)
+- Added RFC1867 fileupload processing hook. (Stefan E.)
+- Added JSON and Filter extensions. (Derick, Rasmus)
+- Added error messages to disk_free_space() and disk_total_space() functions.
+  FR #37971 (Tony)
+- Added PATHINFO_FILENAME option to pathinfo() to get the filename.
+  (Toby S. and Christian S.)
+- Added array_fill_keys() function. (Marcus, Matt Wilmas)
+- Added posix_initgroups() function. (Ilia)
+- Added an optional parameter to parse_url() to allow retrieval of distinct
+  URL components. (Ilia)
+- Added optional parameter to http_build_query() to allow specification of
+  string separator. (Ilia)
+- Added image_type_to_extension() function. (Hannes, Ilia)
+- Added allow_url_include ini directive to complement allow_url_fopen. (Rasmus)
+- Added automatic module globals management. (Dmitry)
+- Added RFC2397 (data: stream) support. (Marcus)
+- Added new error mode E_RECOVERABLE_ERROR. (Derick, Marcus, Tony)
+- Added support for getenv() input filtering. (Rasmus)
+- Added support for constructors in interfaces to force constructor signature
+  checks in implementations. (Marcus)
+- Added memory_get_peak_usage() function for retrieving peak memory usage of
+  a PHP script. (Ilia)
+- Added pg_field_table() function. (Edin)
+- Added SimpleXMLElement::saveXML() as an alias for SimpleXMLElement::asXML().
+  (Hannes)
+- Added DOMNode::getNodePath() for getting an XPath for a node. (Christian)
+- Added gmp_nextprime() function. (ants dot aasma at gmail dot com, Tony)
+- Added error_get_last() function. (Mike)
+- Removed current working directory from the php.ini search path for CLI and
+  re-added it for other SAPIs (restore to pre 5.1.x behavior). (Edin)
+  . ext/filepro (Derick, Tony)
+  . ext/hwapi (Derick, Tony)
+- Disabled CURLOPT_FOLLOWLOCATION in curl when open_basedir or
+  safe_mode are enabled. (Stefan E., Ilia)
+- Increased default memory limit to 16 megabytes to accommodate for a more
+  accurate memory utilization measurement.
+- In addition to path to php.ini, PHPRC now may specify full file name.
+  (Dmitry)
+- Optimized array/HashTable copying. (Matt Wilmas, Dmitry)
+- Optimized zend_try/zend_catch macros by eliminating memcpy(3). (Dmitry)
+- Optimized require_once() and include_once() by eliminating fopen(3) on
+  second usage. (Dmitry)
+- Optimized request shutdown sequence. Restoring ini directives now iterates
+  only over modified directives instead of all. (Dmitry)
+- Changed priority of PHPRC environment variable on win32 to be higher then
+  value from registry. (Dmitry)
+- Changed __toString() to be called wherever applicable. (Marcus)
+- Changed E_ALL error reporting mode to include E_RECOVERABLE_ERROR. (Marcus)
+- Changed realpath cache to be disabled when "open_basedir" or "safe_mode"
+  are enabled on per-request basis. (Ilia)
+- Improved SNMP extension: (Jani)
+  . Renamed snmp_set_oid_numeric_print() to snmp_set_oid_output_format().
+  . Added 2 new constants: SNMP_OID_OUTPUT_FULL and SNMP_OID_OUTPUT_NUMERIC
+  . Fixed bug #37564 (AES privacy encryption not possible due to net-snmp 5.2
+    compatibility issue). (Patch: scott dot moynes+php at gmail dot com)
+- Improved OpenSSL extension: (Pierre)
+  . Added support for all supported algorithms in openssl_verify
+  . Added openssl_pkey_get_details, returns the details of a key
+  . Added x509 v3 extensions support
+  . Added openssl_csr_get_subject() and openssl_csr_get_public_key()
+  . Added 3 new constants OPENSSL_VERSION_TEXT and OPENSSL_VERSION_NUMBER and
+    OPENSSL_KEYTYPE_EC
+- Improved the Zend memory manager: (Dmitry)
+  . Removed unnecessary "--disable-zend-memory-manager" configure option.
+  . Added "--enable-malloc-mm" configure option which is enabled by default in
+    debug builds to allow using internal and external memory debuggers.
+  . Allow tweaking the memory manager with ZEND_MM_MEM_TYPE and ZEND_MM_SEG_SIZE
+    environment variables.
+  . For more information: Zend/README.ZEND_MM
+- Improved safe_mode check for the error_log() function. (Ilia)
+- Improved the error reporting in SOAP extension on request failure. (Ilia)
+- Improved crypt() on win32 to be about 10 times faster and to have friendlier
+  license. (Frank, Dmitry)
+- Improved performance of the implode() function on associated arrays. (Ilia)
+- Improved performance of str_replace() when doing 1 char to 1 char or 1 char
+  to many chars replacement. (Ilia)
+- Improved apache2filter SAPI:
+  . Allowed PHP to be an arbitrary filter in the chain and read the script from
+    the Apache stream. (John)
+  . Added support for apache2filter in the Windows build including binary
+    support for both Apache 2.0.x (php5apache2_filter.dll) and Apache 2.2.x
+    (php5apache2_2_filter.dll). (Edin)
+- Improved apache2handler SAPI:
+  . Changed ap_set_content_type() to be called only once. (Mike)
+  . Added support for Apache 2.2 handler in the Windows distribution. (Edin)
+- Improved FastCGI SAPI: (Dmitry)
+  . Removed source compatibility with libfcgi.
+  . Optimized access to FastCGI environment variables by using HashTable
+    instead of linear search.
+  . Allowed PHP_FCGI_MAX_REQUESTS=0 that assumes no limit.
+  . Allowed PHP_FCGI_CHILDREN=0 that assumes no worker children. (FastCGI
+    requests are handled by main process itself)
+- Improved CURL:
+  . Added control character checks for "open_basedir" and "safe_mode" checks.
+    (Ilia)
+  . Added implementation of curl_multi_info_read(). (Brian)
+- Improved PCRE: (Andrei)
+  . Added run-time configurable backtracking/recursion limits.
+  . Added preg_last_error(). (Andrei)
+- Improved PDO:
+  . Added new attribute ATTR_DEFAULT_FETCH_MODE. (Pierre)
+  . Added FETCH_PROPS_LATE. (Marcus)
+- Improved SPL: (Marcus)
+  . Made most iterator code exception safe.
+  . Added RegExIterator and RecursiveRegExIterator.
+  . Added full caching support and ArrayAccess to CachingIterator.
+  . Added array functions to ArrayObject/ArrayIterator and made them faster.
+  . Added support for reading csv and skipping empty lines in SplFileObject.
+  . Added CachingIterator::TOSTRING_USE_INNER, calls inner iterator __toString.
+  . Added ability to set the CSV separator per SplFileObject.
+- Improved xmlReader: (Rob)
+  . Added readInnerXml(), xmlReader::setSchema().
+  . Added readInnerXML(), readOuterXML(), readString(), setSchema(). (2.6.20+)
+  . Changed to passing libxml options when loading reader.
+- Fixed invalid read in imagecreatefrompng when an empty file is given
+  (Pierre, Tony)
+- Fixed infinite loop when a wrong color index is given to imagefill (Pierre)
+- Fixed mess with CGI/CLI -d option (now it works with cgi; constants are
+  working exactly like in php.ini; with FastCGI -d affects all requests).
+  (Dmitry)
+- Fixed missing open_basedir check inside chdir() function. (Ilia)
+- Fixed overflow on 64bit systems in str_repeat() and wordwrap(). (Stefan E.)
+- Fixed XSLTProcessor::importStylesheet() to return TRUE on success
+  (Christian)
+- Fixed leaks in openssl_csr_sign and openssl_csr_new (Pierre)
+- Fixed phpinfo() cutoff of variables at \0. (Ilia)
+- Fixed a bug in the filter extension that prevented magic_quotes_gpc from
+  being applied when RAW filter is used. (Ilia)
+- Fixed memory leaks in openssl streams context options. (Pierre)
+- Fixed handling of extremely long paths inside tempnam() function. (Ilia)
+- Fixed bug #39721 (Runtime inheritance causes data corruption). (Dmitry)
+- Fixed bug #39304 (Segmentation fault with list unpacking of string offset).
+  (Dmitry)
+- Fixed bug #39192 (Not including nsapi.h properly with SJSWS 7). This will
+  make PHP 5.2 compatible to new Sun Webserver. (Uwe)
+- Fixed bug #39140 (Uncaught exception may cause crash). (Dmitry)
+- Fixed bug #39125 (Memleak when reflecting non-existing class/method). (Tony)
+- Fixed bug #39067 (getDeclaringClass() and private properties). (Tony)
+- Fixed bug #39039 (SSL: fatal protocol error when fetching HTTPS from servers
+  running Google web server). (Ilia)
+- Fixed bug #39035 (Compatibility issue between DOM and
+  zend.ze1_compatibility_mode). (Rob)
+- Fixed bug #39034 (curl_exec() with return transfer returns TRUE on empty
+  files). (Ilia)
+- Fixed bug #39032 (strcspn() stops on null character). (Tony)
+- Fixed bug #39020 (PHP in FastCGI server mode crashes). (Dmitry)
+- Fixed bug #39017 (foreach(($obj = new myClass) as $v); echo $obj;
+  segfaults). (Dmitry)
+- Fixed bug #39004 (Fixed generation of config.nice with autoconf 2.60). (Ilia)
+- Fixed bug #39003 (__autoload() is called for type hinting). (Dmitry, Tony)
+- Fixed bug #39001 (ReflectionProperty returns incorrect declaring class for
+  protected properties). (Tony)
+- Fixed bug #38996 (PDO_MYSQL doesn't check connections for liveness). (Tony)
+- Fixed bug #38993 (Fixed safe_mode/open_basedir checks for session.save_path,
+  allowing them to account for extra parameters). (Ilia)
+- Fixed bug #38989 (Absolute path with slash at beginning doesn't work on win).
+  (Dmitry)
+- Fixed bug #38985 (Can't cast COM objects). (Wez)
+- Fixed bug #38981 (using FTP URLs in get_headers() causes crash). (Tony)
+- Fixed bug #38963 (Fixed a possible open_basedir bypass in tempnam()). (Ilia)
+- Fixed bug #38961 (metaphone() results in segmentation fault on NetBSD).
+  (Tony)
+- Fixed bug #38949 (Cannot get xmlns value attribute). (Rob)
+- Fixed bug #38942 (Double old-style-ctor inheritance). (Dmitry)
+- Fixed bug #38941 (imap extension does not compile against new version of the
+  imap library). (Ilia)
+- Fixed bug #38934 (move_uploaded_file() cannot read uploaded file outside of
+  open_basedir). (Ilia)
+- Fixed bug #38904 (apache2filter changes cwd to /). (Ilia, Hannes)
+- Fixed bug #38891 (get_headers() do not work with curl-wrappers). (Ilia)
+- Fixed bug #38882 (ldap_connect causes segfault with newer versions of
+  OpenLDAP). (Tony)
+- Fixed bug #38859 (parse_url() fails if passing '@' in passwd). (Tony)
+- Fixed bug #38850 (lookupNamespaceURI doesn't return default namespace). (Rob)
+- Fixed bug #38844 (curl_easy_strerror() is defined only since cURL 7.12.0).
+  (Tony)
+- Fixed bug #38813 (DOMEntityReference->__construct crashes when called
+  explicitly). (Rob)
+- Fixed bug #38808 ("maybe ref" issue for current() and others). (Dmitry)
+- Fixed bug #38779 (engine crashes when require()'ing file with syntax error
+  through userspace stream wrapper). (Tony, Dmitry)
+- Fixed bug #38772 (inconsistent overriding of methods in different visibility
+  contexts). (Dmitry)
+- Fixed bug #38759 (PDO sqlite2 empty query causes segfault). (Tony)
+- Fixed bug #38721 (Invalid memory read in date_parse()). (Tony, Derick)
+- Fixed bug #38700 (SoapClient::__getTypes never returns). (Dmitry)
+- Fixed bug #38693 (curl_multi_add_handle() set curl handle to null). (Ilia)
+- Fixed bug #38687 (sockaddr local storage insufficient for all sock families).
+  (Sara)
+- Fixed bug #38661 (mixed-case URL breaks url-wrappers). (Ilia)
+- Fixed bug #38653 (memory leak in ReflectionClass::getConstant()). (Tony)
+- Fixed bug #38649 (uninit'd optional arg in stream_socket_sendto()). (Sara)
+- Fixed bug #38637 (curl_copy_handle() fails to fully copy the cURL handle).
+  (Tony, Ilia)
+- Fixed bug #38624 (Strange warning when incrementing an object property and
+  exception is thrown from __get method). (Tony)
+- Fixed bug #38623 (leaks in a tricky code with switch() and exceptions).
+  (Dmitry)
+- Fixed bug #38579 (include_once() may include the same file twice). (Dmitry)
+- Fixed bug #38574 (missing curl constants and improper constant detection).
+  (Ilia)
+- Fixed bug #38543 (shutdown_executor() may segfault when memory_limit is too
+  low). (Dmitry)
+- Fixed bug #38535 (memory corruption in pdo_pgsql driver on error retrieval
+  inside a failed query executed via query() method). (Ilia)
+- Fixed bug #38534 (segfault when calling setlocale() in userspace session
+  handler). (Tony)
+- Fixed bug #38524 (strptime() does not initialize the internal date storage
+  structure). (Ilia)
+- Fixed bug #38511, #38473, #38263 (Fixed session extension request shutdown
+  order to ensure it is shutdown before the extensions it may depend on).
+  (Ilia)
+- Fixed bug #38488 (Access to "php://stdin" and family crashes PHP on win32).
+  (Dmitry)
+- Fixed bug #38474 (getAttribute select attribute by order, even when
+  prefixed). (Rob)
+- Fixed bug #38467 (--enable-versioning causes make fail on OS X). (Tony)
+- Fixed bug #38465 (ReflectionParameter fails if default value is an access
+  to self::). (Johannes)
+- Fixed bug #38464 (array_count_values() mishandles numeric strings).
+  (Matt Wilmas, Ilia)
+- Fixed bug #38461 (setting private attribute with __set() produces
+  segfault). (Tony)
+- Fixed bug #38458, PECL bug #8944, PECL bug #7775 (error retrieving columns
+  after long/text columns with PDO_ODBC). (Wez)
+- Fixed bug #38454 (warning upon disabling handler via
+  xml_set_element_handler). (dtorop933 at gmail dot com, Rob)
+- Fixed bug #38451 (PDO_MYSQL doesn't compile on Solaris). (Tony)
+- Fixed bug #38450 (constructor is not called for classes used in userspace
+  stream wrappers). (Tony)
+- Fixed bug #38438 (DOMNodeList->item(0) segfault on empty NodeList). (Ilia)
+- Fixed bug #38431 (xmlrpc_get_type() crashes PHP on objects). (Tony)
+- Fixed bug #38427 (unicode causes xml_parser to misbehave). (Rob)
+- Fixed bug #38424 (Different attribute assignment if new or existing). (Rob)
+- Fixed bug #38400 (Use of com.typelib_file may cause a crash). (Ilia)
+- Fixed bug #38394 (PDO fails to recover from failed prepared statement
+  execution). (Ilia)
+- Fixed bug #38377 (session_destroy() gives warning after
+  session_regenerate_id()). (Ilia)
+- Implemented #38357 (dbase_open can't open DBase 3 dbf file).
+  (rodrigo at fabricadeideias dot com, Mike)
+- Fixed bug #38354 (Unwanted reformatting of XML when using AsXML). (Christian)
+- Fixed bug #38347 (Segmentation fault when using foreach with an unknown/empty
+  SimpleXMLElement). (Tony)
+- Fixed bug #38322 (reading past array in sscanf() leads to arbitrary code
+  execution). (Tony)
+- Fixed bug #38315 (Constructing in the destructor causes weird behavior).
+  (Dmitry)
+- Fixed bug #38303 (spl_autoload_register() suppress all errors silently).
+  (Ilia)
+- Fixed bug #38290 (configure script ignores --without-cdb,inifile,flatfile).
+  (Marcus)
+- Fixed bug #38289 (segfault in session_decode() when _SESSION is NULL).
+  (Tony)
+- Fixed bug #38287 (static variables mess up global vars). (Dmitry)
+- Fixed bug #38278 (session_cache_expire()'s value does not match phpinfo's
+  session.cache_expire). (Tony)
+- Fixed bug #38276 (file_exists() works incorrectly with long filenames
+  on Windows). (Ilia, Tony)
+- Fixed bug #38269 (fopen wrapper doesn't fail on invalid hostname with
+  curlwrappers enabled). (Tony)
+- Fixed bug #38265 (heap corruption). (Dmitry)
+- Fixed bug #38261 (openssl_x509_parse() leaks with invalid cert) (Pierre)
+- Fixed bug #38255 (openssl possible leaks while passing keys) (Pierre)
+- Fixed bug #38253 (PDO produces segfault with default fetch mode). (Tony)
+- Fixed bug #38251 (socket_select() and invalid arguments). (Tony)
+- Fixed bug #38236 (Binary data gets corrupted on multipart/formdata POST).
+  (Ilia)
+- Fixed bug #38234 (Exception in __clone makes memory leak). (Dmitry, Nuno)
+- Fixed bug #38229 (strtotime() does not parse YYYY-MM format). (Ilia)
+- Fixed bug #38224 (session extension can't handle broken cookies). (Ilia)
+- Fixed bug #38220 (Crash on some object operations). (Dmitry)
+- Fixed bug #38217 (ReflectionClass::newInstanceArgs() tries to allocate too
+  much memory). (Tony)
+- Fixed bug #38214 (gif interlace output cannot work). (Pierre)
+- Fixed bug #38213, #37611, #37571 (wddx encoding fails to handle certain
+  characters). (Ilia)
+- Fixed bug #38212 (Segfault on invalid imagecreatefromgd2part() parameters).
+  (Pierre)
+- Fixed bug #38211 (variable name and cookie name match breaks script
+  execution). (Dmitry)
+- Fixed bug #38199 (fclose() unable to close STDOUT and STDERR). (Tony)
+- Fixed bug #38198 (possible crash when COM reports an exception). (Ilia)
+- Fixed bug #38194 (ReflectionClass::isSubclassOf() returns TRUE for the
+  class itself). (Ilia)
+- Fixed bug #38183 (disable_classes=Foobar causes disabled class to be
+  called Foo). (Jani)
+- Fixed bug #38179 (imagecopy from a palette to a truecolor image loose alpha
+  channel) (Pierre)
+- Fixed bug #38173 (Freeing nested cursors causes OCI8 to segfault). (Tony)
+- Fixed bug #38168 (Crash in pdo_pgsql on missing bound parameters). (Ilia)
+- Fixed bug #38161 (oci_bind_by_name() returns garbage when Oracle didn't set
+  the variable). (Tony)
+- Fixed bug #38146 (Cannot use array returned from foo::__get('bar') in write
+  context). (Dmitry)
+- Fixed bug #38132 (ReflectionClass::getStaticProperties() retains \0 in key
+  names). (Ilia)
+- Fixed bug #38125 (undefined reference to spl_dual_it_free_storage). (Marcus)
+- Fixed bug #38112 (corrupted gif segfaults) (Pierre)
+- Fixed bug #38096 (large timeout values ignored on 32bit machines in
+  stream_socket_accept() and stream_socket_client()). (Ilia)
+- Fixed bug #38086 (stream_copy_to_stream() returns 0 when maxlen is bigger
+  than the actual length). (Tony)
+- Fixed bug #38072 (boolean arg for mysqli_autocommit() is always true on
+  Solaris). (Tony)
+- Fixed bug #38067 (Parameters are not decoded from utf-8 when using encoding
+  option). (Dmitry)
+- Fixed bug #38064 (ignored constructor visibility). (Marcus)
+- Fixed bug #38055 (Wrong interpretation of boolean parameters). (Dmitry)
+- Fixed bug #38047 ("file" and "line" sometimes not set in backtrace from
+  inside error handler). (Dmitry)
+- Fixed bug #38019 (segfault extending mysqli class). (Dmitry)
+- Fixed bug #38005 (SoapFault faultstring doesn't follow encoding rules).
+  (Dmitry)
+- Fixed bug #38004 (Parameters in SoapServer are decoded twice). (Dmitry)
+- Fixed bug #38003 (in classes inherited from MySQLi it's possible to call
+  private constructors from invalid context). (Tony)
+- Fixed bug #37987 (invalid return of file_exists() in safe mode). (Ilia)
+- Fixed bug #37947 (zend_ptr_stack reallocation problem). (Dmitry)
+- Fixed bug #37945 (pathinfo() cannot handle argument with special characters
+  like German "Umlaut"). (Mike)
+- Fixed bug #37931 (possible crash in OCI8 after database restart
+  when using persistent connections). (Tony)
+- Fixed bug #37923 (Display constant value in reflection::export). (Johannes)
+- Fixed bug #37920 (compilation problems on z/OS). (Tony)
+- Fixed bug #37870 (pgo_pgsql tries to de-allocate unused statements).
+  (Ilia, ce at netage dot bg)
+- Fixed bug #37864 (file_get_contents() leaks on empty file). (Hannes)
+- Fixed bug #37862 (Integer pointer comparison to numeric value).
+  (bugs-php at thewrittenword dot com)
+- Fixed bug #37846 (wordwrap() wraps incorrectly). (ddk at krasn dot ru, Tony)
+- Fixed bug #37816 (ReflectionProperty does not throw exception when accessing
+  protected attribute). (Marcus)
+- Fixed bug #37811 (define not using toString on objects). (Marcus)
+- Fixed bug #37807 (segmentation fault during SOAP schema import). (Tony)
+- Fixed bug #37806 (weird behavior of object type and comparison). (Marcus)
+- Fixed bug #37780 (memory leak trying to execute a non existing file (CLI)).
+  (Mike)
+- Fixed bug #37779 (empty include_path leads to search for files inside /).
+  (jr at terragate dot net, Ilia)
+- Fixed bug #37747 (strtotime segfaults when given "nextyear"). (Derick)
+- Fixed bug #37720 (merge_php_config scrambles values).
+  (Mike, pumuckel at metropolis dot de)
+- Fixed bug #37709 (Possible crash in PDO::errorCode()). (Ilia)
+- Fixed bug #37707 (clone without assigning leaks memory). (Ilia, Nuno, Dmitri)
+- Fixed bug #37705 (Semaphore constants not available). (Ilia)
+- Fixed bug #37671 (MySQLi extension fails to recognize BIT column). (Ilia)
+- Fixed bug #37667 (Object is not added into array returned by __get). (Marcus)
+- Fixed bug #37635 (parameter of pcntl signal handler is trashed). (Mike)
+- Fixed bug #37632 (Protected method access problem). (Marcus)
+- Fixed bug #37630 (MySQL extensions should link against thread safe client
+  libs if built with ZTS). (Mike)
+- Fixed bug #37620 (mysqli_ssl_set validation is inappropriate). (Georg)
+- Fixed bug #37616 (DATE_RFC822 does not product RFC 822 dates).
+  (Hannes Magnusson, Derick)
+- Fixed bug #37614 (Class name lowercased in error message). (Johannes)
+- Fixed bug #37587 (var without attribute causes segfault). (Marcus)
+- Fixed bug #37586 (Bumped minimum PCRE version to 6.6, needed for recursion
+  limit support). (Ilia)
+- Fixed bug #37581 (oci_bind_array_by_name clobbers input array when using
+  SQLT_AFC, AVC). (Tony)
+- Fixed bug #37569 (WDDX incorrectly encodes high-ascii characters). (Ilia)
+- Fixed bug #37565 (Using reflection::export with simplexml causing a crash).
+  (Marcus)
+- Fixed bug #37564 (AES privacy encryption not possible due to net-snmp 5.2
+  compatibility issue). (Jani, patch by scott dot moynes+php at gmail dot com)
+- Fixed bug #37563 (array_key_exists performance is poor for &$array). (Ilia)
+- Fixed bug #37558 (timeout functionality doesn't work after a second PHP
+  start-up on the same thread). (p dot desarnaud at wanadoo dot fr)
+- Fixed bug #37531 (oci8 persistent connection corruption). (Tony)
+- Fixed bug #37523 (namespaces added too late, leads to missing xsi:type
+  attributes. Incompatibility with libxml2-2.6.24). (Dmitry)
+- Fixed bug #37514 (strtotime doesn't assume year correctly). (Derick)
+- Fixed bug #37510 (session_regenerate_id changes session_id() even on
+  failure). (Hannes)
+- Fixed bug #37505 (touch() truncates large files). (Ilia)
+- Fixed bug #37499 (CLI segmentation faults during cleanup with sybase-ct
+  extension enabled). (Tony)
+- Fixed bug #37496 (FastCGI output buffer overrun). (Piotr, Dmitry)
+- Fixed bug #37487 (oci_fetch_array() array-type should always default to
+  OCI_BOTH). (Tony)
+- Fixed bug #37457 (Crash when an exception is thrown in accept() method of
+  FilterIterator). (Marcus)
+- Fixed bug #37456 (DOMElement->setAttribute() loops forever). (Rob)
+- Fixed bug #37445 (Fixed crash in pdo_mysql resulting from premature object
+  destruction). (Ilia)
+- Fixed bug #37428 (PHP crashes on windows if there are start-up errors and
+  event log is used for logging them). (Edin)
+- Fixed bug #37418 (tidy module crashes on shutdown). (Tony)
+- Fixed bug #37416 (iterator_to_array() hides exceptions thrown in rewind()
+  method). (Tony)
+- Fixed bug #37413 (Rejected versions of flex that don't work). (Ilia)
+- Fixed bug #37395 (recursive mkdir() fails to create nonexistent directories
+  in root dir). (Tony)
+- Fixed bug #37394 (substr_compare() returns an error when offset equals
+  string length). (Ilia)
+- Fixed bug #37392 (Unnecessary call to OCITransRollback() at the end of
+  request). (Tony)
+- Fixed bug #37376 (fastcgi.c compile fail with gcc 2.95.4). (Ilia)
+- Fixed bug #37368 (Incorrect timestamp returned for strtotime()). (Derick)
+- Fixed bug #37363 (PDO_MYSQL does not build if no other mysql extension is
+  enabled). (Mike)
+- Fixed bug #37348 (make PEAR install ignore open_basedir). (Ilia)
+- Fixed bug #37341 ($_SERVER in included file is shortened to two entries,
+  if $_ENV gets used). (Dmitry)
+- Fixed bug #37313 (sigemptyset() used without including <signal.h>).
+  (jdolecek)
+- Fixed bug #37306 (max_execution_time = max_input_time). (Dmitry)
+- Fixed bug #37278 (SOAP not respecting uri in __soapCall). (Dmitry)
+- Fixed bug #37265 (Added missing safe_mode & open_basedir checks to
+  imap_body()). (Ilia)
+- Fixed bug #37262 (var_export() does not escape \0 character). (Ilia)
+- Fixed bug #37256 (php-fastcgi doesn't handle connection abort). (Dmitry)
+- Fixed bug #37244 (Added strict flag to base64_decode() that enforces
+  RFC3548 compliance). (Ilia)
+- Fixed bug #37144 (PHP crashes trying to assign into property of dead object).
+  (Dmitry)
+- Fixed bug #36949 (invalid internal mysqli objects dtor). (Mike)
+- Implement #36732 (req/x509 extensions support for openssl_csr_new and
+  openssl_csr_sign) (ben at psc dot edu, Pierre)
+- Fixed bug #36759 (Objects destructors are invoked in wrong order when script
+  is finished). (Dmitry)
+- Fixed bug #36681 (pdo_pgsql driver incorrectly ignored some errors).
+  (Wez, Ilia)
+- Fixed bug #36630 (umask not reset at the end of the request). (Ilia)
+- Fixed bug #36515 (Unlinking buckets from non-existent brigades). (Sara)
+- Fixed bug #35973 (Error ORA-24806 occurs when trying to fetch a NCLOB
+  field). (Tony)
+- Fixed bug #35886 (file_get_contents() fails with some combinations of
+  offset & maxlen). (Nuno)
+- Fixed bug #35512 (Lack of read permission on main script results in
+  E_WARNING rather then E_ERROR). (Ilia)
+- Fixed bug #34180 (--with-curlwrappers causes PHP to disregard some HTTP
+  stream context options). (Mike)
+- Fixed bug #34066 (recursive array_walk causes segfault). (Tony)
+- Fixed bug #34065 (throw in foreach causes memory leaks). (Dmitry)
+- Fixed bug #34005 (oci_password_change() fails).
+  (pholdaway at technocom-wireless dot com, Tony)
+- Fixed bug #33895 (Missing math constants). (Hannes)
+- Fixed bug #33770 (https:// or ftps:// do not work when --with-curlwrappers
+  is used and ssl certificate is not verifiable). (Ilia)
+- Fixed bug #29538 (number_format and problem with 0). (Matt Wilmas)
+- Implement #28382 (openssl_x509_parse() extensions support) (Pierre)
+- Fixed PECL bug #9061 (oci8 might reuse wrong persistent connection). (Tony)
+- Fixed PECL bug #8816 (issue in php_oci_statement_fetch with more than one
+  piecewise column) (jeff at badtz-maru dot com, Tony)
+- Fixed PECL bug #8112 (OCI8 persistent connections misbehave when Apache
+  process times out). (Tony)
+- Fixed PECL bug #7755 (error selecting DOUBLE fields with PDO_ODBC).
+  ("slaws", Wez)
+04 May 2006, PHP 5.1.4
+- Added "capture_peer_cert" and "capture_peer_cert_chain" context options
+  for SSL streams. (Wez).
+- Added PDO::PARAM_EVT_* family of constants. (Sara)
+- Fixed possible crash in highlight_string(). (Dmitry)
+- Fixed bug #37291 (FastCGI no longer works with isapi_fcgi.dll). (Dmitry)
+- Fixed bug #37277 (cloning Dom Documents or Nodes does not work). (Rob)
+- Fixed bug #37276 (problems with $_POST array). (Dmitry)
+- Fixed bug #36632 (bad error reporting for pdo_odbc exec UPDATE). (Wez).
+- Fixed bug #35552 (crash when pdo_odbc prepare fails). (Wez).
+28 Apr 2006, PHP 5.1.3
+- Updated bundled PCRE library to version 6.6. (Andrei)
+  . ext/msession (Derick)
+- Reimplemented FastCGI interface. (Dmitry)
+  - Fixed issues with not/double calling of constructors of SPL iterators.
+  - Fixed issues with info-class/file-class in SPL directory handling classes.
+  - Fixed ArrayIterator::seek().
+  - Added SimpleXMLIterator::count().
+  - Dropped erroneous RecursiveDirectoryIterator::getSubPathInfo().
+- Improved SimpleXML: (Marcus, Rob)
+  . Added SimpleXMLElement::getName() to retrieve name of element.
+  . Added ability to create elements on the fly.
+  . Added addChild() method for element creation supporting namespaces.
+  . Added addAttribute() method for attribute creation supporting namespaces.
+  . Added ability to delete specific elements and attributes by offset.
+- Improved Reflection API: (Marcus)
+  . Added ReflectionClass::newInstanceArgs($args).
+  . Added ability to analyze extension dependency.
+  . Added ReflectionFunction::isDeprecated() and constant IS_DEPRECATED.
+  . Added ReflectionParameter::getDeclaringClass().
+  . Changed reflection constants to be prefixed with IS_. (Johannes)
+- Improved cURL extension: (Ilia)
+  . Added curl_setopt_array() function that allows setting of multiple
+    options via an associated array.
+  . Added the ability to retrieve the request message sent to the server.
+- Improved GD extension: (Pierre)
+  . Added a weak/tolerant mode to the JPEG loader.
+  . Added filtering mode option to imagepng() to allow reducing file size.
+  . Fixed imagecolorallocate() and imagecolorallocatelapha() to return FALSE
+    on error.
+- Changed get_headers() to retrieve headers also from non-200 responses.
+  (Ilia)
+- Changed get_headers() to use the default context. (Ilia)
+- Added lchown() and lchgrp() to change user/group ownership of symlinks.
+  (Derick)
+- Added support for exif date format in strtotime(). (Derick)
+- Added a check for special characters in the session name. (Ilia)
+- Added "consumed" stream filter. (Marcus)
+- Added new mysqli constants for BIT and NEW_DECIMAL field types:
+  MYSQLI_TYPE_NEWDECIMAL and MYSQLI_TYPE_BIT. FR #36007. (Georg)
+- Added imap_savebody() that allows message body to be written to a
+  file. (Mike)
+- Added overflow checks to wordwrap() function. (Ilia)
+- Added support for BINARY_DOUBLE and BINARY_FLOAT to PDO_OCI and OCI8
+  (also fixes bug #36764). (Tony)
+- Eliminated run-time constant fetching for TRUE, FALSE and NULL. (Dmitry)
+- Removed the E_STRICT deprecation notice from "var". (Ilia)
+- Fixed reading stream filters never notified about EOF. (Mike)
+- Fixed tempnam() 2nd parameter to be checked against path components. (Ilia)
+- Fixed a bug that would not fill in the fifth argument to preg_replace()
+  properly, if the variable was not declared previously. (Andrei)
+- Fixed safe_mode check for source argument of the copy() function. (Ilia)
+- Fixed mysqli bigint conversion under Windows (Georg)
+- Fixed XSS inside phpinfo() with long inputs. (Ilia)
+- Fixed Apache2 SAPIs header handler modifying header strings. (Mike)
+- Fixed 'auto_globals_jit' to work together with 'register_argc_argv'. (Dmitry)
+- Fixed offset/length parameter validation in substr_compare() function. (Ilia)
+- Fixed debug_zval_dump() to support private and protected members. (Dmitry)
+- Fixed SoapFault::getMessage(). (Dmitry)
+- Fixed issue with iconv_mime_decode where the "encoding" would only allow
+  upper case specifiers. (Derick)
+- Fixed tiger hash algorithm generating wrong results on big endian platforms.
+  (Mike)
+- Fixed crash with DOMImplementation::createDocumentType("name:"). (Mike)
+- Fixed bug #37205 (Serving binary content/images fails with "comm with server
+  aborted" FastCGI err). (Dmitry)
+- Fixed bug #37192 (cc may complain about non-constant initializers in
+  hash_adler.c). (Mike)
+- Fixed bug #37191 (chmod takes off sticky bit when safe_mode is On). (Tony)
+- Fixed bug #37167 (PDO segfaults when throwing exception from the
+  fetch handler). (Tony)
+- Fixed bug #37162 (wddx does not build as a shared extension).
+  (jdolecek at NetBSD dot org, Ilia)
+- Fixed bug #37158 (fread behavior changes after calling
+  stream_wrapper_register). (Wez)
+- Fixed bug #37138 (__autoload tries to load callback'ed self and parent).
+  (Dmitry)
+- Fixed bug #37103 (libmbfl headers not installed). (Jani)
+- Fixed bug #37062 (compile failure on ARM architecture). (Tony)
+- Fixed bug #37061 (curl_exec() doesn't zero-terminate binary strings). (Tony)
+- Fixed bug #37060 (Type of retval of Countable::count() is not checked).
+  (Johannes)
+- Fixed bug #37059 (oci_bind_by_name() doesn't support RAW and LONG RAW
+  fields). (Tony)
+- Fixed bug #37057 (xmlrpc_decode() may produce arrays with numeric strings,
+  which are unaccessible). (Tony)
+- Fixed bug #37055 (incorrect reference counting for persistent OCI8
+  connections). (Tony)
+- Fixed bug #37054 (SoapClient Error Fetching http headers). (Dmitry)
+- Fixed bug #37053 (html_errors with internal classes produces wrong links).
+  (Tony)
+- Fixed bug #37046 (foreach breaks static scope). (Dmitry)
+- Fixed bug #37045 (Fixed check for special chars for http redirects). (Ilia)
+- Fixed bug #37017 (strtotime fails before 13:00:00 with some time zones
+  identifiers). (Derick)
+- Fixed bug #37002 (Have to quote literals in INI when concatenating with
+  vars). (Dmitry)z
+- Fixed bug #36988 (mktime freezes on long numbers). (Derick)
+- Fixed bug #36981 (SplFileObject->fgets() ignores max_length). (Tony)
+- Fixed bug #36957 (serialize() does not handle recursion). (Ilia)
+- Fixed bug #36944 (strncmp & strncasecmp do not return false on negative
+  string length). (Tony)
+- Fixed bug #36941 (ArrayIterator does not clone itself). (Marcus)
+- Fixed bug #36934 (OCILob->read() doesn't move internal pointer when
+  reading 0's). (Tony)
+- Fixed bug #36908 (wsdl default value overrides value in soap request).
+  (Dmitry)
+- Fixed bug #36898 (__set() leaks in classes extending internal ones).
+  (Tony, Dmitry)
+- Fixed bug #36886 (User filters can leak buckets in some situations). (Ilia)
+- Fixed bug #36878 (error messages are printed even though an exception has
+  been thrown). (Tony)
+- Fixed bug #36875 (is_*() functions do not account for open_basedir). (Ilia)
+- Fixed bug #36872 (session_destroy() fails after call to
+  session_regenerate_id(true)). (Ilia)
+- Fixed bug #36869 (memory leak in output buffering when using chunked
+  output). (Tony)
+- Fixed bug #36859 (DOMElement crashes when calling __construct when
+  cloning). (Tony)
+- Fixed bug #36857 (Added support for partial content fetching to the
+  HTTP streams wrapper). (Ilia)
+- Fixed bug #36851 (Documentation and code discrepancies for NULL
+  data in oci_fetch_*() functions). (Tony)
+- Fixed bug #36825 (Exceptions thrown in ArrayObject::offsetGet cause
+  segfault). (Tony)
+- Fixed bug #36820 (Privileged connection with an Oracle password file
+  fails). (Tony)
+- Fixed bug #36809 (__FILE__ behavior changed). (Dmitry)
+- Fixed bug #36808 (syslog ident becomes garbage between requests). (Tony)
+- Fixed bug #36802 (mysqli_set_charset() crash with a non-open connection).
+  (Ilia)
+- Fixed bug #36756 (DOMDocument::removeChild corrupts node). (Rob)
+- Fixed bug #36749 (SOAP: 'Error Fetching http body' when using HTTP Proxy).
+  (Dmitry)
+- Fixed bug #36745 (No error message when load data local file isn't found).
+  (Georg)
+- Fixed bug #36743 (In a class extending XMLReader array properties are not
+  writable). (Tony)
+- Fixed bug #36727 (segfault in pdo_pgsql bindValue() when no parameters are
+  defined). (Tony)
+- Fixed bug #36721 (The SoapServer is not able to send a header that it didn't
+  receive). (Dmitry)
+- Fixed bug #36697 (Transparency is lost when using imagecreatetruecolor).
+  (Pierre)
+- Fixed bug #36689 (Removed arbitrary limit on the length of syslog messages).
+  (Ilia)
+- Fixed bug #36656 (http_build_query generates invalid URIs due to use of
+  square brackets). (Mike)
+- Fixed bug #36638 (strtotime() returns false when 2nd argument < 1). (Derick)
+- Fixed bug #36629 (SoapServer::handle() exits on SOAP faults). (Dmitry)
+- Fixed bug #36625 (pg_trace() does not work). (iakio at mono-space dot net)
+- Fixed bug #36614 (Segfault when using Soap). (Dmitry)
+- Fixed bug #36611 (assignment to SimpleXML object attribute changes argument
+  type to string). (Tony)
+- Fixed bug #36606 (pg_query_params() changes arguments type to string). (Tony)
+- Fixed bug #36599 (DATE_W3C format constant incorrect). (Derick)
+- Fixed bug #36575 (SOAP: Incorrect complex type instantiation with
+  hierarchies). (Dmitry)
+- Fixed bug #36572 (Added PDO::MYSQL_ATTR_DIRECT_QUERY constant that should
+  be set when executing internal queries like "show master status" via MySQL).
+  (Ilia)
+- Fixed bug #36568 (memory_limit setting on win32 has no effect). (Dmitry)
+- Fixed bug #36513 (comment will be outputted in last line). (Dmitry)
+- Fixed bug #36510 (strtotime() fails to parse date strings with tabs).
+  (Ilia, Derick)
+- Fixed bug #36459 (Incorrect adding PHPSESSID to links, which contains \r\n).
+  (Ilia)
+- Fixed bug #36458 (sleep() accepts negative values). (Ilia)
+- Fixed bug #36436 (DBA problem with Berkeley DB4). (Marcus)
+- Fixed bug #36434 (Improper resolution of declaring class name of an
+  inherited property). (Ilia)
+- Fixed bug #36420 (segfault when access result->num_rows after calling
+  result->close()). (Ilia,Tony)
+- Fixed bug #36403 (oci_execute() no longer supports OCI_DESCRIBE_ONLY). (Tony)
+- Fixed bug #36400 (Custom 5xx error does not return correct HTTP response error
+  code). (Tony)
+- Fixed bug #36396 (strtotime() fails to parse dates in dd-mm-yyyy format).
+  (Derick)
+- Fixed bug #36388 (ext/soap crashes when throwing exception and session
+  persistence). (David)
+- Fixed bug #36382 (PDO/PgSQL's getColumnMeta() crashes). (Derick)
+- Fixed bug #36359 (splFileObject::fwrite() doesn't write when no data
+  length specified). (Tony)
+- Fixed bug #36351 (parse_url() does not parse numeric paths properly). (Ilia)
+- Fixed bug #36345 (PDO/MySQL problem loading BLOB over 1MB). (Ilia)
+- Fixed bug #36337 (ReflectionProperty fails to return correct visibility).
+  (Ilia)
+- Fixed bug #36334 (Added missing documentation about realpath cache INI
+  settings). (Ilia)
+- Fixed bug #36308 (ReflectionProperty::getDocComment() does not reflect
+  extended class commentary). (Ilia)
+- Fixed bug #36306 (crc32() differ on 32-bit and 64-bit platforms)
+  (anight at eyelinkmedia dot com, Pierre)
+- Fixed bug #36303 (foreach on error_zval produces segfault). (Dmitry)
+- Fixed bug #36295 (typo in SplFileObject::flock() parameter name). (Tony)
+- Fixed bug #36287 (Segfault with SplFileInfo conversion). (Marcus)
+- Fixed bug #36283 (SOAPClient Compression Broken). (Dmitry)
+- Fixed bug #36268 (Object destructors called even after fatal errors). (Dmitry)
+- Fixed bug #36258 (SplFileObject::getPath() may lead to segfault). (Tony)
+- Fixed bug #36250 (PHP causes ORA-07445 core dump in Oracle server 9.2.x).
+  (Tony)
+- Fixed bug #36242 (Possible memory corruption in stream_select()). (Tony)
+- Fixed bug #36235 (ocicolumnname returns false before a successful fetch).
+  (Tony)
+- Fixed bug #36226 (Inconsistent handling when passing potential arrays).
+  (Dmitry)
+- Fixed bug #36224 (date(DATE_ATOM) gives wrong results).
+  (Derick, Hannes Magnusson)
+- Fixed bug #36222 (errorInfo in PDOException is always NULL). (Ilia)
+- Fixed bug #36208 (symbol namespace conflicts using bundled gd). (Jakub Moc)
+- Fixed bug #36205 (Memory leaks on duplicate cookies). (Dmitry)
+- Fixed bug #36185 (str_rot13() crash on non-string parameter). (Pierre)
+- Fixed bug #36176 (PDO_PGSQL - PDO::exec() does not return number of rows
+  affected by the operation). (Ilia)
+- Fixed bug #36158 (SIGTERM is not handled correctly when running as a
+  FastCGI server). (Dmitry)
+- Fixed bug #36152 (problems with curl+ssl and pgsql+ssl in same PHP). (Mike)
+- Fixed bug #36148 (unpack("H*hex", $data) is adding an extra character to
+  the end of the string). (Ilia)
+- Fixed bug #36134 (DirectoryIterator constructor failed to detect empty
+  directory names). (Ilia)
+- Fixed bug #36113 (Reading records of unsupported type causes segfault).
+  (Tony)
+- Fixed bug #36096 (oci_result() returns garbage after oci_fetch() failed).
+  (Tony)
+- Fixed bug #36083 (SoapClient waits for responses on one-way operations).
+  (Dmitry)
+- Fixed bug #36071 (Engine Crash related with 'clone'). (Dmitry)
+- Fixed bug #36055 (possible OCI8 crash in multi-threaded environment). (Tony)
+- Fixed bug #36046 (parse_ini_file() miscounts lines in multi-line values).
+  (Ilia)
+- Fixed bug #36038 (ext/hash compile failure on Mac OSX). (Tony)
+- Fixed bug #36037 (heredoc adds extra line number). (Dmitry)
+- Fixed bug #36016 (realpath cache memleaks). (Dmitry, Nuno)
+- Fixed bug #36011 (Strict errormsg wrong for call_user_func() and the likes).
+  (Marcus)
+- Fixed bug #36010 (Segfault when re-creating and re-executing statements with
+  bound parameters). (Tony)
+- Fixed bug #36006 (Problem with $this in __destruct()). (Dmitry)
+- Fixed bug #35999 (recursive mkdir() does not work with relative path
+  like "foo/bar"). (Tony)
+- Fixed bug #35998 (SplFileInfo::getPathname() returns unix style filenames
+  in win32). (Marcus)
+- Fixed bug #35988 (Unknown persistent list entry type in module shutdown).
+  (Dmitry)
+- Fixed bug #35954 (Fatal com_exception casting object). (Rob)
+- Fixed bug #35900 (stream_select() should warning when tv_sec is negative).
+  (Ilia)
+- Fixed bug #35785 (SimpleXML causes memory read error zend engine). (Marcus)
+- Fixed bug #34272 (empty array onto COM object blows up). (Rob)
+- Fixed bug #33292 (apache_get_modules() crashes on Windows). (Edin)
+- Fixed bug #29476 (sqlite_fetch_column_types() locks the database forever).
+  (Ilia)
+12 Jan 2006, PHP 5.1.2
+- Updated libsqlite in ext/sqlite to 2.8.17. (Ilia)
+- Updated libsqlite in ext/pdo_sqlite to 3.2.8. (Ilia)
+- Updated to libxml2-2.6.22 and libxslt-1.1.15 in the win32 bundle. (Rob)
+- Added new extensions: (Ilia, Wez)
+  . XMLWriter
+  . Hash
+- Added PNG compression support to GD extension. (Pierre)
+- Added reflection constants as class constants. (Johannes)
+- Added --enable-gcov configure option to enable C-level code coverage.
+  (John, Jani, Ilia, Marcus)
+- Added missing support for 'B' format identifier to date() function. (Ilia)
+- Changed reflection to be an extension. (Marcus)
+- Improved SPL extension: (Marcus)
+  . Added class SplFileInfo as root class for DirectoryIterator and
+    SplFileObject
+  . Added SplTempFileObject
+- Improved SimpleXML extension: (Marcus)
+  . Fixed memleaks
+  . Fixed var_dump()
+  . Fixed isset/empty/(bool) behavior
+  . Fixed iterator edge cases
+  . Added methods getNamespaces(), getDocNamespaces()
+- Upgraded pear to version 1.4.6. (Greg)
+- Added constants for libxslt and libexslt versions: LIBXSLT_VERSION,
+  LIBXSLT_DOTTED_VERSION, LIBEXSLT_VERSION and LIBEXSLT_DOTTED_VERSION. (Pierre)
+- Fixed possible crash in apache_getenv()/apache_setenv() on invalid parameters.
+  (Ilia)
+- Changed errors to warnings in imagecolormatch(). (Pierre)
+- Fixed segfault/leak in imagecolormatch(). (Pierre)
+- Fixed small leak in mysqli_stmt_fetch() when bound variable was empty string.
+  (Andrey)
+- Fixed prepared statement name conflict handling in PDO_PGSQL. (Thies, Ilia)
+- Fixed memory corruption when PDO::FETCH_LAZY mode is being used. (Ilia)
+- Fixed possible leaks in imagecreatefromstring() with invalid data. (Pierre)
+- Fixed possible memory corruption inside mb_strcut(). (Ilia)
+- Fixed possible header injection by limiting each header to a single line.
+  (Ilia)
+- Fixed possible XSS inside error reporting functionality. (Ilia)
+- Fixed many bugs in OCI8. (Tony)
+- Fixed crash and leak in mysqli when using 4.1.x client libraries and
+  connecting to 5.x server. (Andrey)
+- Fixed bug #35916 (Duplicate calls to stream_bucket_append() lead to a crash).
+  (Ilia)
+- Fixed bug #35908 (curl extension uses undefined GCRY_THREAD_OPTIONS_USER).
+  (Ilia)
+- Fixed bug #35907 (PDO_OCI uses hardcoded lib path $ORACLE_HOME/lib). (Tony)
+- Fixed bug #35887 (wddx_deserialize not parsing dateTime fields properly).
+  (Derick)
+- Fixed bug #35885 (strtotime("NOW") no longer works). (Derick)
+- Fixed bug #35821 (array_map() segfaults when exception is throwed from
+  the callback). (Tony)
+- Fixed bug #35817 (unpack() does not decode odd number of hexadecimal values).
+  (Ilia)
+- Fixed bug #35797 (segfault on PDOStatement::execute() with
+  zend.ze1_compatibility_mode = On). (Tony, Ilia)
+- Fixed bug #35781 (stream_filter_append() can cause segfault). (Tony)
+- Fixed bug #35760 (sybase_ct doesn't compile on Solaris using old gcc). (Tony)
+- Fixed bug #35759 (mysqli_stmt_bind_result() makes huge allocation when
+  column empty). (Andrey)
+- Fixed bug #35751 (using date with a timestamp makes httpd segfault). (Derick)
+- Fixed bug #35740 (memory leak when including a directory). (Tony)
+- Fixed bug #35730 (ext/mssql + freetds: Use correct character encoding
+  and allow setting it). (Frank)
+- Fixed bug #35723 (xmlrpc_introspection.c fails compile per C99 std). (Jani)
+- Fixed bug #35720 (A final constructor can be overwritten). (Marcus)
+- Fixed bug #35713 (getopt() returns array with numeric strings when passed
+  options like '-1'). (Tony)
+- Fixed bug #35705 (strtotime() fails to parse soap date format without TZ).
+  (Ilia)
+- Fixed bug #35699 (date() can't handle leap years before 1970). (Derick)
+- Fixed bug #35694 (Improved error message for invalid fetch mode). (Ilia)
+- Fixed bug #35692 (iconv_mime_decode() segmentation fault; with libiconv
+  only). (Tony)
+- Fixed bug #35690 (pack() tries to allocate huge memory block when packing
+  float values to strings). (Tony)
+- Fixed bug #35669 (imap_mail_compose() crashes with
+  multipart-multiboundary-email). (Ilia)
+- Fixed bug #35660 (AIX TZ variable format not understood, yields UTC
+  timezone). (Derick)
+- Fixed bug #35655 (whitespace following end of heredoc is lost). (Ilia)
+- Fixed bug #35630 (strtotime() crashes on certain relative identifiers).
+  (Ilia)
+- Fixed bug #35629 (crash in http:// wrapper on multiple redirects). (Ilia)
+- Fixed bug #35624 (strtotime() does not handle 3 character weekdays). (Ilia)
+- Fixed bug #35612 (iis6 Access Violation crash). (Dmitry, alacn.uhahaa)
+- Fixed bug #35594 (Multiple calls to getopt() may result in a crash).
+  (rabbitt at gmail dot com, Ilia)
+- Fixed bug #35571 (Fixed crash in Apache 2 SAPI when more then one php
+  script is loaded via SSI include). (Ilia)
+- Fixed bug #35570 (segfault when re-using soap client object). (Dmitry)
+- Fixed bug #35558 (mktime() interpreting 3 digit years incorrectly). (Ilia)
+- Fixed bug #35543 (php crash when calling non existing method of a class
+  that extends PDO). (Tony)
+- Fixed bug #35539 (typo in error message for ErrorException). (Tony)
+- FIxed bug #35536 (mysql_field_type() doesn't handle NEWDECIMAL). (Tony)
+- Fixed bug #35517 (mysql_stmt_fetch returns NULL on data truncation). (Georg)
+- Fixed bug #35509 (string constant as array key has different behavior inside
+  object). (Dmitry)
+- Fixed bug #35508 (PDO fails when unknown fetch mode specified). (Tony)
+- Fixed bug #35499 (strtotime() does not handle whitespace around the date
+  string). (Ilia)
+- Fixed bug #35496 (Crash in mcrypt_generic()/mdecrypt_generic() without
+  proper init). (Ilia)
+- Fixed bug #35490 (socket_sendto() unable to handle IPv6 addresses). (Tony)
+- Fixed bug #35461 (Ming extension fails to compile with ming 0.3beta1). (Jani)
+- Fixed bug #35437 (Segfault or Invalid Opcode 137/1/4). (Dmitry)
+- Fixed bug #35470 (Assigning global using variable name from array doesn't
+  function). (Dmitry)
+- Fixed bug #35456 (+ 1 [time unit] format did not work). (Ilia)
+- Fixed bug #35447 (xml_parse_into_struct() chokes on the UTF-8 BOM). (Rob)
+- Fixed bug #35431 (PDO crashes when using LAZY fetch with fetchAll). (Wez)
+- Fixed bug #35430 (PDO crashes on incorrect FETCH_FUNC use). (Tony)
+- Fixed bug #35427 (str_word_count() handles '-' incorrectly). (Ilia)
+- Fixed bug #35425 (idate() function ignores timezone settings). (Ilia)
+- Fixed bug #35422 (strtotime() does not parse times with UTC as timezone).
+  (Ilia)
+- Fixed bug #35414 (strtotime() no longer works with ordinal suffix). (Ilia)
+- Fixed bug #35410 (wddx_deserialize() doesn't handle large ints as keys
+  properly). (Ilia)
+- Fixed bug #35409 (undefined reference to 'rl_completion_matches'). (Jani)
+- Fixed bug #35399 (Since fix of bug #35273 SOAP decoding of
+  soapenc:base64binary fails). (Dmitry)
+- Fixed bug #35393 (changing static protected members from outside the class,
+  one more reference issue). (Dmitry)
+- Fixed bug #35381 (ssl library is not initialized properly). (Alan)
+- Fixed bug #35377 (PDO_SQLITE: undefined reference to "fdatasync").
+  (Nuno, Jani)
+- Fixed bug #35373 (HP-UX "alias not allowed in this configuration"). (Dmitry)
+- Fixed bug #35288 (iconv() function defined as libiconv()). (Nuno)
+- Fixed bug #35103 (mysqli handles bad unsigned (big)int incorrectly).(Andrey)
+- Fixed bug #35062 (socket_read() produces warnings on non blocking sockets).
+  (Nuno, Ilia)
+- Fixed bug #35028 (SimpleXML object fails FALSE test). (Marcus)
+- Fixed bug #34729 (Crash in ZTS mode under Apache). (Dmitry, Zeev)
+- Fixed bug #34429 (Output buffering cannot be turned off with FastCGI).
+  (Dmitry, Ilya)
+- Fixed bug #34359 (Possible crash inside fopen http wrapper). (Ilia,Sara,Nuno)
+- Fixed bug #33789 (Many Problems with SunFuncs). (Derick)
+- Fixed bug #33671 (sun_rise and sun_set don't return a GMT timestamp if one
+  passes an offset). (Derick)
+- Fixed bug #32820 (date_sunrise and date_sunset don't handle GMT offset
+  well). (Derick)
+- Fixed bug #31347 (is_dir and is_file (incorrectly) return true for any string
+  greater then 255 characters). (Nuno,Ilia)
+- Fixed bug #30937 (date_sunrise() & date_sunset() don't handle endless
+  day/night at high latitudes). (Derick)
+- Fixed bug #30760 (Remove MessageBox on win32 for E_CORE errors if
+  display_startup_error is off). (Ilia)
+- Fixed bug #29955 (mb_strtoupper() / lower() broken with Turkish encoding).
+  (Rui)
+- Fixed bug #28899 (mb_substr() and substr() behave differently when
+  "mbstring.func_overload" is enabled). (Rui)
+- Fixed bug #27678 (number_format() crashes with large numbers). (Marcus)
+28 Nov 2005, PHP 5.1.1
+- Disabled native date class to prevent pear::date conflict. (Ilia)
+- Changed reflection constants be both PHP and class constants. (Johannes)
+- Added an additional field $frame['object'] to the result array of
+  debug_backtrace() that contains a reference to the respective object when the
+  frame was called from an object. (Sebastian)
+- Fixed bug #35423 (RecursiveDirectoryIterator doesnt appear to recurse with
+  RecursiveFilterIterator). (Marcus)
+- Fixed bug #35413 (Removed -dev flag from Zend Engine version). (Ilia)
+- Fixed bug #35411 (Regression with \{$ handling). (Ilia)
+- Fixed bug #35406 (eval hangs when evall'ed code ends with comment w/o
+  newline). (Marcus)
+- Fixed bug #35391 (pdo_mysql::exec does not return number of affected rows).
+  (Tony)
+- Fixed bug #35382 (Comment in end of file produces fatal error). (Ilia)
+- Fixed bug #35360 (exceptions in interactive mode (php -a) may cause crash).
+  (Dmitry)
+- Fixed bug #35358 (Incorrect error messages for PDO class constants). (Ilia)
+- Fixed bug #35338 (pdo_pgsql does not handle binary bound params). (Wez)
+- Fixed bug #35316 (Application exception trying to create COM object). (Rob)
+- Fixed bug #35170 (PHP_AUTH_DIGEST differs under Apache 1.x and 2.x). (Ilia)
+24 Nov 2005, PHP 5.1
+- Added support for class constants and static members for internal classes.
+  (Dmitry, Michael Wallner)
+- Added "new_link" parameter to mssql_connect() (Bug #34369). (Frank)
+- Added missing safe_mode checks for image* functions and cURL. (Ilia)
+- Added missing safe_mode/open_basedir checks for file uploads. (Ilia)
+- Added PDO_MYSQL_ATTR_USE_BUFFERED_QUERY parameter for pdo_mysql. (Ilia)
+- Added date_timezone_set() function to set the timezone that the date
+  function will use. (Derick)
+- Added pg_fetch_all_columns() function to fetch all values of a column from a
+  result cursor. (Ilia)
+- Added support for LOCK_EX flag for file_put_contents(). (Ilia)
+- Added bindto socket context option. (Ilia)
+- Added offset parameter to the stream_copy_to_stream() function. (Ilia)
+- Added offset & length parameters to substr_count() function. (Ilia)
+- Added man pages for "phpize" and "php-config" scripts. (Jakub Vrana)
+- Added support for .cc files in extensions. (Brian)
+- Added PHP_INT_MAX and PHP_INT_SIZE as predefined constants. (Andrey)
+- Added user opcode API that allow overloading of opcode handlers. (Dmitry)
+- Added an optional remove old session parameter to session_regenerate_id().
+  (Ilia)
+- Added array type hinting. (Dmitry)
+- Added the tidy_get_opt_doc() function to return documentation for
+  configuration options in tidy. (Patch by: nlopess at php.net)
+- Added imageconvolution() function which can be used to apply a custom 3x3
+  matrix convolution to an image. (Pierre)
+- Added optional first parameter to XsltProcessor::registerPHPFunctions to
+  only allow certain functions to be called from XSLT. (Christian)
+- Added the ability to override the autotools executables used by the
+  buildconf script via the PHP_AUTOCONF and PHP_AUTOHEADER environmental
+  variables. (Jon)
+- Added several new functions to support the PostgreSQL v3 protocol introduced
+  in PostgreSQL 7.4. (Christopher)
+  . pg_transaction_status() - in-transaction status of a database connection.
+  . pg_query_params() - execution of parameterized queries.
+  . pg_prepare() - prepare named queries.
+  . pg_execute() - execution of named prepared queries.
+  . pg_send_query_params() - async equivalent of pg_query_params().
+  . pg_send_prepare() - async equivalent of pg_prepare().
+  . pg_send_execute() - async equivalent of pg_execute().
+  . pg_result_error_field() - highly detailed error information, most
+    importantly
+    the SQLSTATE error code.
+  . pg_set_error_verbosity() - set verbosity of errors.
+- Added optional fifth parameter "count" to preg_replace_callback() and
+  preg_replace() to count the number of replacements made. FR #32275. (Andrey)
+- Added optional third parameter "charlist" to str_word_count() which contains
+  characters to be considered as word part. FR #31560. (Andrey, Ilia)
+- Added interface Serializable. (Stanislav, Marcus)
+- Added pg_field_type_oid() PostgreSQL function. (mauroi at digbang dot com)
+- Added zend_declare_property_...() and zend_update_property_...() API
+  functions for bool, double and binary safe strings. (Hartmut)
+- Added possibility to access INI variables from within .ini file. (Andrei)
+- Added variable $_SERVER['REQUEST_TIME'] containing request start time.
+  (Ilia)
+- Added optional float parameter to gettimeofday(). (Ilia)
+- Added apache_reset_timeout() Apache1 function. (Rasmus)
+- Added sqlite_fetch_column_types() 3rd argument for arrays. (Ilia)
+- Added optional offset parameter to stream_get_contents() and
+  file_get_contents(). (Ilia)
+- Added optional maxlen parameter to file_get_contents(). (Ilia)
+- Added SAPI hook to get the current request time. (Rasmus)
+- Added new functions:
+  . array_diff_key() (Andrey)
+  . array_diff_ukey() (Andrey)
+  . array_intersect_key() (Christiano Duarte)
+  . array_intersect_ukey() (Christiano Duarte)
+  . array_product() (Andrey)
+  . DomDocumentFragment::appendXML() (Christian)
+  . fputcsv() (David Sklar)
+  . htmlspecialchars_decode() (Ilia)
+  . inet_pton() (Sara)
+  . inet_ntop() (Sara)
+  . mysqli::client_info property (Georg)
+  . posix_access() (Magnus)
+  . posix_mknod() (Magnus)
+  . SimpleXMLElement::registerXPathNamespace() (Christian)
+  . stream_context_get_default() (Wez)
+  . stream_socket_enable_crypto() (Wez)
+  . stream_wrapper_unregister() (Sara)
+  . stream_wrapper_restore() (Sara)
+  . stream_filter_remove() (Sara)
+  . time_sleep_until() (Ilia)
+- Added DomDocument::$recover property for parsing not well-formed XML
+ Documents. (Christian)
+- Added Cursor support for MySQL 5.0.x in mysqli (Georg)
+- Added proxy support to ftp wrapper via http. (Sara)
+- Added MDTM support to ftp_url_stat. (Sara)
+- Added zlib stream filter support. (Sara)
+- Added bz2 stream filter support. (Sara)
+- Added max_redirects context option that specifies how many HTTP
+  redirects to follow. (Ilia)
+- Added support of parameter=>value arrays to
+  xsl_xsltprocessor_set_parameter(). (Tony)
+- PHP extension loading mechanism with support for module
+  dependencies and conflicts. (Jani, Dmitry)
+- Improved interactive mode of PHP CLI (php -a). (Johannes, Marcus)
+- Improved performance of:
+  . general execution/compilation. (Andi, Thies, Sterling, Dmitry, Marcus)
+  . switch() statement. (Dmitry)
+  . several array functions. (Marcus)
+  . virtual path handling by adding a realpath() cache. (Andi)
+  . variable fetches. (Andi)
+  . magic method invocations. (Marcus)
+- Improved support for embedded server in mysqli. (Georg)
+- Improved mysqli extension. (Georg)
+  . added constructor for mysqli_stmt and mysqli_result classes
+  . added new function mysqli_get_charset()
+  . added new function mysqli_set_charset()
+  . added new class mysqli_driver
+  . added new class mysqli_warning
+  . added new class mysqli_exception
+  . added new class mysqli_sql_exception
+- Improved SPL extension. (Marcus)
+  . Moved RecursiveArrayIterator from examples into extension
+  . Moved RecursiveFilterIterator from examples into extension
+  . Added SplObjectStorage
+  . Made all SPL constants class constants
+  . Renamed CachingRecursiveIterator to RecursiveCachingIterator to follow
+    Recursive<*>Iterator naming scheme.
+  . added standard hierarchy of Exception classes
+  . added interface Countable
+  . added interfaces Subject and SplObserver
+  . added spl_autoload*() functions
+  . converted several 5.0 examples into c code
+  . added class SplFileObject
+  . added possibility to use a string with class_parents() and
+    class_implements(). (Andrey)
+- Changed type hints to allow "null" as default value for class and array.
+  (Marcus, Derick, Dmitry)
+- Changed SQLite extension to be a shared module in Windows distribution.
+  (Edin)
+- Changed "instanceof" and "catch" operators, is_a() and is_subclass_of()
+  functions to not call __autoload(). (Dmitry)
+- Changed sha1_file() and md5_file() functions to use streams instead of low
+  level IO. (Uwe)
+- Changed abstract private methods to be not allowed anymore. (Stas)
+- Changed stream_filter_(ap|pre)pend() to return resource. (Sara)
+- Changed mysqli_exception and sqlite_exception to use RuntimeException as
+  base if SPL extension is present. (Georg, Marcus)
+- Upgraded bundled libraries:
+  . PCRE library to version 6.2. (Andrei)
+  . SQLite 3 library in ext/pdo_sqlite to 3.2.7. (Ilia)
+  . SQLite 2 library in ext/sqlite to 2.8.16. (Ilia)
+- Upgraded bundled libraries in Windows distribution. (Edin)
+  . zlib 1.2.3
+  . curl 7.14.0
+  . openssl 0.9.8
+  . ming 0.3b
+  . libpq (PostgreSQL) 8.0.1
+- Implemented feature request #33452 (Year belonging to ISO week). (Derick)
+- Allowed return by reference from internal functions. (Marcus, Andi, Dmitry)
+- Rewrote strtotime() with support for timezones and many new formats.
+  Implements feature requests #21399, #26694, #28088, #29150, #29585 and
+  #29595. (Derick)
+- Moved extensions to PECL:
+  . ext/cpdf        (Tony, Derick)
+  . ext/dio         (Jani, Derick)
+  . ext/fam         (Jani, Derick)
+  . ext/ingres_ii   (Jani, Derick)
+  . ext/mnogosearch (Jani, Derick)
+  . ext/w32api      (Jani, Derick)
+  . ext/yp          (Jani, Derick)
+  . ext/mcve        (Jani, Derick, Pierre)
+  . ext/oracle      (Jani, Derick)
+  . ext/ovrimos     (Jani, Derick, Pierre)
+  . ext/pfpro       (Jani, Derick, Pierre)
+  . ext/dbx         (Jani, Derick)
+  . ext/ircg        (Jani, Derick)
+- Removed php_check_syntax() function which never worked properly. (Ilia)
+- Removed garbage manager in Zend Engine which results in more aggressive
+  freeing of data. (Dmitry, Andi)
+- Fixed "make test" to work for phpized extensions. (Hartmut, Jani)
+- Fixed Apache 2 regression with sub-request handling on non-linux systems.
+  (Ilia, Tony)
+- Fixed PDO shutdown problem (possible infinite loop running rollback on
+  shutdown). (Wez)
+- Fixed PECL bug #3714 (PDO: beginTransaction doesn't work if you're in
+  auto-commit mode). (Wez)
+- Fixed ZTS destruction. (Marcus)
+- Fixed __get/__set to allow recursive calls for different properties. (Dmitry)
+- Fixed a bug where stream_get_meta_data() did not return the "uri" element
+  for files opened with tmpname(). (Derick)
+- Fixed a problem with SPL iterators aggregating the inner iterator. (Marcus)
+- Fixed an error in mysqli_fetch_fields (returned NULL instead of an array
+  when row number > field_count). (Georg)
+- Fixed bug in mysql::client_version(). (Georg)
+- Fixed bug in mysqli extension with unsigned int(11) being represented as
+  signed integer in PHP instead of string in 32bit systems. (Andrey)
+- Fixed bug with $HTTP_RAW_POST_DATA not getting set. (Brian)
+- Fixed crash inside stream_get_line() when length parameter equals 0. (Ilia)
+- Fixed ext/mysqli to allocate less memory when fetching bound params of type
+  (MEDIUM|LONG)BLOB/(MEDIUM|LONG)TEXT. (Andrey)
+- Fixed extension initialization to respect dependencies between extensions.
+  (Wez)
+- Fixed failing queries (FALSE returned) with mysqli_query() on 64 bit systems.
+  (Andrey)
+- Fixed fgetcsv() and fputcsv() inconsistency. (Dmitry)
+- Fixed inheritance check to control return by reference and pass by
+  reference correctly (ArrayAccess can no longer support references correctly).
+  (Marcus, Andi, Dmitry)
+- Fixed initializing and argument checking for posix_mknod(). (Derick)
+- Fixed memory corruption in ImageTTFText() with 64bit systems. (Andrey)
+- Fixed memory corruption in pg_copy_from() in case the as_null parameter was
+  passed. (Derick)
+- Fixed memory corruption in stristr(). (Derick)
+- Fixed possible GLOBALS variable override when register_globals are ON.
+  (Ilia, Stefan)
+- Fixed possible INI setting leak via virtual() in Apache 2 sapi. (Ilia)
+- Fixed possible register_globals toggle via parse_str(). (Ilia, Stefan)
+- Fixed potential GLOBALS overwrite via import_request_variables() and
+  possible crash and/or memory corruption. (Ilia)
+- Fixed segfaults when CURL callback functions throw exception. (Tony)
+- Fixed support for shared extensions on AIX. (Dmitry)
+- Fixed bug #35342 (isset(DOMNodeList->length) returns false). (Rob)
+- Fixed bug #35341 (Fix for bug #33760 breaks build with older curl). (Tony)
+- Fixed bug #35336 (crash on PDO::FETCH_CLASS + __set()). (Tony)
+- Fixed bug #35303 (PDO prepare() crashes with invalid parameters). (Ilia)
+- Fixed bug #35293 (PDO segfaults when using persistent connections). (Tony)
+- Fixed bug #35278 (Multiple virtual() calls crash Apache 2 php module). (Ilia)
+- Fixed bug #35273 (Error in mapping soap - java types). (Dmitry)
+- Fixed bug #35249 (compile failure when ext/readline is compiled as shared).
+  (Jani)
+- Fixed bug #35248 (sqlite_query() doesn't set error_msg when return value is
+  being used). (Ilia)
+- Fixed bug #35243 (php_mblen() crashes when compiled with thread-safety on
+  Linux). (Patch: shulmanb at il dot ibm dot com, Jani)
+- Fixed bug #35239 (Objects can lose references). (Dmitry)
+- Fixed bug #35229 (call_user_func() crashes when argument_stack is nearly
+  full). (Dmitry)
+- Fixed bug #35197 (Destructor is not called). (Tony)
+- Fixed bug #35179 (tokenizer extension needs T_HALT_COMPILER). (Greg)
+- Fixed bug #35176 (include()/require()/*_once() produce wrong error messages
+  about main()). (Dmitry)
+- Fixed bug #35147 (__HALT_COMPILER() breaks with --enable-zend-multibyte).
+  (Dmitry, Moriyoshi)
+- Fixed bug #35143 (gettimeofday() ignores current time zone). (Derick)
+- Fixed bug #35142 (SOAP Client/Server Complex Object Support). (Dmitry)
+- Fixed bug #35135 (PDOStatment without related PDO object may crash). (Ilia)
+- Fixed bug #35091 (SoapClient leaks memory). (Dmitry)
+- Fixed bug #35079 (stream_set_blocking(true) toggles, not enables blocking).
+  (askalski at gmail dot com, Tony)
+- Fixed bug #35078 (configure does not find ldap_start_tls_s). (Jani)
+- Fixed bug #35046 (phpinfo() uses improper css enclosure). (Ilia)
+- Fixed bugs #35022, #35019 (Regression in the behavior of key() and
+  current() functions). (Ilia)
+- Fixed bug #35017 (Exception thrown in error handler may cause unexpected
+  behavior). (Dmitry)
+- Fixed bug #35014 (array_product() always returns 0). (Ilia)
+- Fixed bug #35009 (ZTS: Persistent resource destruct crashes when extension
+  is compiled as shared). (Dmitry)
+- Fixed bug #34996 (ImageTrueColorToPalette() crashes when ncolors is zero).
+  (Tony)
+- Fixed bug #34982 (array_walk_recursive() modifies elements outside function
+  scope). (Dmitry)
+- Fixed bug #34977 (Compile failure on MacOSX due to use of varargs.h). (Tony)
+- Fixed bug #34968 (bz2 extension fails on to build on some win32 setups).
+ (Ilia)
+- Fixed bug #34965 (tidy is not binary safe). (Mike)
+- Fixed bug #34957 (PHP doesn't respect ACLs for access checks). (Wez)
+- Fixed bug #34950 (Unable to get WSDL through proxy). (Dmitry)
+- Fixed bug #34938 (dns_get_record() doesn't resolve long hostnames and
+  leaks). (Tony)
+- Fixed bug #34905 (Digest authentication does not work with Apache 1). (Ilia)
+- Fixed bug #34902 (mysqli::character_set_name() - undefined method). (Tony)
+- Fixed bug #34899 (Fixed sqlite extension compile failure). (Ilia)
+- Fixed bug #34893 (PHP5.1 overloading, Cannot access private property).
+  (Dmitry)
+- Fixed bug #34884 (Possible crash in ext/sqlite when sqlite.assoc_case is
+  being used). (Tony, Ilia)
+- Fixed bug #34879 (str_replace, array_map corrupt negative array indexes on
+  64-bit platforms). (Dmitry)
+- Fixed bug #34873 (Segmentation Fault on foreach in object). (Dmitry)
+- Fixed bug #34856 (configure fails to detect libiconv's type). (Tony)
+- Fixed bug #34855 (ibase_service_attach() segfault on AMD64).
+  (irie at gmx dot de, Tony)
+- Fixed bug #34851 (SO_RECVTIMEO and SO_SNDTIMEO socket options expect
+  integer parameter on Windows). (Mike)
+- Fixed bug #34850 (--program-suffix and --program-prefix not included in
+  man page names). (Jani)
+- Fixed bug #34821 (zlib encoders fail on widely varying binary data on
+  windows). (Mike, Ilia)
+- Fixed bug #34818 (several functions crash when invalid mysqli_link object
+  is passed). (Tony)
+- Fixed bug #34810 (mysqli::init() and others use wrong $this pointer without
+  checks). (Tony)
+- Fixed bug #34809 (FETCH_INTO in PDO crashes without a destination object).
+  (Ilia)
+- Fixed bug #34802 (Fixed crash on object instantiation failure). (Ilia)
+- Fixed bug #34796 (missing SSL linking in ext/ftp when configured as shared).
+  (Jani)
+- Fixed bug #34790 (preg_match_all(), named capturing groups, variable
+  assignment/return => crash). (Dmitry)
+- Fixed bug #34788 (SOAP Client not applying correct namespace to generated
+  values). (Dmitry)
+- Fixed bug #34787 (SOAP Client not handling boolean types correctly). (Dmitry)
+- Fixed bug #34786 (2 @ results in change to error_reporting() to random
+  value) (Dmitry, Tony)
+- Fixed bug #34785 (subclassing of mysqli_stmt does not work). (Georg)
+- Fixed bug #34782 (token_get_all() gives wrong result). (Dmitry)
+- Fixed bug #34777 (Crash in dblib when fetching non-existent error info).
+  (Ilia)
+- Fixed bug #34771 (strtotime() fails with 1-12am/pm). (Derick)
+- Fixed bug #34767 (Zend Engine 1 Compatibility not copying objects
+  correctly). (Dmitry)
+- Fixed bug #34758 (PDO_DBLIB did not implement rowCount()). (Ilia)
+- Fixed bug #34757 (iconv_substr() gives "Unknown error" when offset > string
+  length). (Tony)
+- Fixed bug #34742 (ftp wrapper failures caused from segmented command
+  transfer). (Ilia)
+- Fixed bug #34725 (CLI segmentation faults during cleanup). (Dmitry)
+- Fixed bug #34723 (array_count_values() strips leading zeroes). (Tony)
+- Fixed bug #34712 (zend.ze1_compatibility_mode = on segfault). (Dmitry)
+- Fixed bug #34704 (Infinite recursion due to corrupt JPEG). (Marcus)
+- Fixed bug #34678 (__call(), is_callable() and static methods). (Dmitry)
+- Fixed bug #34676 (missing support for strtotime("midnight") and
+  strtotime("noon")). (Derick)
+- Fixed bug #34645 (ctype corrupts memory when validating large numbers).
+ (Ilia)
+- Fixed bug #34643 (wsdl default value has no effect). (Dmitry)
+- Fixed bug #34623 (Crash in pdo_mysql on longtext fields). (Ilia)
+- Fixed bug #34617 (zend_deactivate: objects_store used after
+  zend_objects_store_destroy is called). (Dmitry)
+- Fixed bug #34590 (User defined PDOStatement class can't implement
+  methods). (Marcus)
+- Fixed bug #34584 (Segfault with SPL autoload handler). (Marcus)
+- Fixed bug #34581 (crash with mod_rewrite). (Tony, Ilia)
+- Fixed bug #34565 (mb_send_mail does not fetch
+  mail.force_extra_parameters). (Marco, Ilia)
+- Fixed bug #34557 (php -m exits with "error" 1). (Johannes)
+- Fixed bug #34518 (Unset doesn't separate container in CV). (Dmitry)
+- Fixed bug #34505 (Possible memory corruption when unmangling properties
+  with empty names). (Tony)
+- Fixed bug #34478 (Incorrect parsing of url's fragment (#...)). (Dmitry)
+- Fixed bug #34467 (foreach + __get + __set inconsistency). (Dmitry)
+- Fixed bug #34456 (Possible crash inside pspell extension). (Ilia)
+- Fixed bug #34453 (parsing http://www.w3.org/2001/xml.xsd exception). (Dmitry)
+- Fixed bug #34450 (Segfault when calling mysqli_close() in destructor). (Tony)
+- Fixed bug #34449 (ext/soap: XSD_ANYXML functionality not exposed). (Dmitry)
+- Fixed bug #34420 (Possible crash inside curl_multi_remove_handle()). (Ilia)
+- Fixed bug #34358 (Fatal error: Cannot re-assign $this). (Dmitry)
+- Fixed bug #34331 (php crashes when variables_order is empty). (Ilia)
+- Fixed bug #34321 (Possible crash in filter code). (Ilia)
+- Fixed bug #34311 (unserialize() crashes with chars above 191 dec). (Nuno)
+- Fixed bug #34310 (foreach($arr as $c->d => $x) crashes). (Dmitry)
+- Fixed bug #34307 (on_modify handler not called to set the default value if
+  setting from php.ini was invalid). (Andrei)
+- Fixed bug #34306 (wddx_serialize_value() crashes with long array keys).
+  (Jani)
+- Fixed bug #34304 (date() doesn't have a modifier for ISO Week Day). (Derick)
+- Fixed bug #34302 (date('W') do not return leading zeros for week 1 to 9).
+  (Derick)
+- Fixed bug #34299 (ReflectionClass::isInstantiable() returns true for abstract
+  classes). (Marcus)
+- Fixed bug #34284 (CLI phpinfo showing html on _SERVER["argv"]). (Jani)
+- Fixed bug #34277 (array_filter() crashes with references and objects).
+  (Dmitry)
+- Fixed bug #34276 (setAttributeNS doesn't work with default namespace).
+  (Rob)
+- Fixed bug #34260 (Segfault with callbacks (array_map) + overloading).
+  (Dmitry)
+- Fixed bug #34257 (lib64 not handled correctly in ming extension). (Marcus)
+- Fixed bug #34221 (Compiling xmlrpc as shared fails other parts). (Jani)
+- Fixed bug #34216 (Segfault with autoload). (Marcus)
+- Fixed bug #34199 (if($obj)/if(!$obj) inconsistency because of cast handler).
+  (Dmitry, Alex)
+- Fixed bug #34191 (ob_gzhandler does not enforce trailing \0). (Ilia)
+- Fixed bug #34156 (memory usage remains elevated after memory limit is
+  reached). (Ilia)
+- Fixed bug #34148 (+,- and . not supported as parts of scheme). (Ilia)
+- Fixed bug #34137 (assigning array element by reference causes binary mess).
+  (Dmitry)
+- Fixed bug #34103 (line numbering not maintained in dom document). (Rob)
+- Fixed bug #34078 (Reflection API problems in methods with boolean or
+  null default values). (Tony)
+- Fixed bug #34068 (Numeric string as array key not cast to integer in
+  wddx_deserialize()). (Ilia)
+- Fixed bug #34064 (arr[] as param to function in class gives invalid
+  opcode). (Dmitry)
+- Fixed bug #34062 (Crash in catch block when many arguments are used).
+  (Dmitry)
+- Fixed bug #34052 (date('U') returns %ld not unix timestamp). (Nuno)
+- Fixed bug #34045 (Buffer overflow with serialized object). (Dmitry)
+- Fixed bug #34001 (pdo_mysql truncates numeric fields at 4 chars). (Ilia)
+- Fixed bug #33999 (object remains object when cast to int). (Dmitry)
+- Fixed bug #33996 (No information given for fatal error on passing invalid
+  value to typed argument). (Dmitry)
+- Fixed bug #33989 (extract($GLOBALS,EXTR_REFS) crashes PHP). (Dmitry)
+- Fixed bug #33987 (php script as ErrorDocument causes crash in Apache 2).
+  (Ilia)
+- Fixed bug #33967 (misuse of Exception constructor doesn't display
+  errorfile). (Jani)
+- Fixed bug #33966 (Wrong use of reflectionproperty causes a segfault). (Tony)
+- Fixed bug #33963 (mssql_bind() fails on input parameters). (Frank)
+- Fixed bug #33958 (duplicate cookies and magic_quotes=off may cause a crash).
+  (Ilia)
+- Fixed bug #33957 (gmdate('W')/date('W') sometimes returns wrong week number).
+  (Derick)
+- Fixed bug #33940 (array_map() fails to pass by reference when called
+  recursively). (Dmitry)
+- Fixed bug #33917 (number_format() output with > 1 char separators). (Jani)
+- Fixed bug #33904 (input array keys being escaped when magic quotes is off).
+  (Ilia)
+- Fixed bug #33903 (spl_autoload_register class method). (Marcus)
+- Fixed bug #33899 (CLI: setting extension_dir=some/path extension=foobar.so
+  does not work). (Jani)
+- Fixed bug #33882 (CLI was looking for php.ini in wrong path). (Hartmut)
+- Fixed bug #33869 (strtotime() problem with "+1days" format). (Ilia)
+- Fixed bug #33841 (pdo sqlite driver forgets to update affected column
+  count on execution of prepared statments). (Ilia)
+- Fixed bug #33837 (Informix ESQL version numbering schema changed). (Jani)
+- Fixed bug #33829 (mime_content_type() returns text/plain for gzip and bzip
+  files). (Derick)
+- Fixed bug #33802 (throw Exception in error handler causes crash). (Dmitry)
+- Fixed bug #33771 (error_reporting falls to 0 when @ was used inside
+  try/catch block). (Tony)
+- Fixed bug #33760 (cURL needs to implement CRYPTO_callback functions to
+  prevent locking). (Mike, Ilia)
+- Fixed bug #33732 (Wrong behavior of constants in class and interface
+  extending). (Dmitry)
+- Fixed bug #33723 (php_value overrides php_admin_value). (Dmitry)
+- Fixed bug #33720 (mb_encode_mimeheader does not work for multibyte
+  chars). (Rui)
+- Fixed bug #33710 (ArrayAccess objects does not initialize $this). (Dmitry)
+- Fixed bug #33690 (Crash setting some ini directives in httpd.conf). (Rasmus)
+- Fixed bug #33673 (Added detection for partially uploaded files). (Ilia)
+- Fixed bug #33605 (substr_compare() crashes with negative offset and length).
+  (Tony)
+- Fixed bug #33597 (setcookie() "expires" date format doesn't comply with RFC).
+  (Tony)
+- Fixed bug #33588 (LDAP: RootDSE query not possible). (Jani)
+- Fixed bug #33578 (strtotime() problem with "Oct17" format). (Derick)
+- Fixed bug #33578 (strtotime() doesn't understand "11 Oct" format). (Derick)
+- Fixed bug #33562 (date("") crashes). (Derick)
+- Fixed bug #33558 (warning with nested calls to functions returning by
+  reference). (Dmitry)
+- Fixed bug #33536 (strtotime() defaults to now even on non time string).
+  (Derick)
+- Fixed bug #33532 (Different output for strftime() and date()). (Derick)
+- Fixed bug #33523 (Memory leak in xmlrpc_encode_request()). (Ilia)
+- Fixed bug #33520 (crash if safe_mode is on and session.save_path is changed).
+  (Dmitry)
+- Fixed bug #33512 (Add missing support for isset()/unset() overloading to
+  complement the property get/set methods). (Dmitry)
+- Fixed bug #33491 (crash after extending MySQLi internal class). (Tony)
+- Fixed bug #33475 (cURL handle is not closed on curl_close(). (Ilia)
+- Fixed bug #33469 (Compile error undefined reference to ifx_checkAPI). (Jani)
+- Fixed bug #33433 (strtoll not available on Tru64). (Jani, Derick)
+- Fixed bug #33427 (ext/odbc: check if unixODBC header file exists). (Jani)
+- Fixed bug #33415 (strtotime() related bugs). (Derick)
+- Fixed bug #33414 (Comprehensive list of incorrect days returned after
+  strtotime() / date() tests). (Derick)
+- Fixed bug #33389 (double free() when exporting a ReflectionClass). (Marcus)
+- Fixed bug #33383 (crash when retrieving empty LOBs). (Tony)
+- Fixed bug #33382 (array_reverse() fails after *sort()),  introduced by
+  zend_hash_sort() optimizations in HEAD. (Tony)
+- Fixed bug #33340 (CLI Crash when calling php:function from XSLT). (Rob)
+- Fixed bug #33326 (Cannot build extensions with phpize on Macosx). (Jani)
+- Fixed bug #33318 (throw 1; results in Invalid opcode 108/1/8). (Dmitry)
+- Fixed bug #33312 (ReflectionParameter methods do not work correctly).
+  (Dmitry)
+- Fixed bug #33299 (php:function no longer handles returned dom objects).
+  (Rob, Joe Orton)
+- Fixed bug #33286 (nested array_walk() calls and user array compare functions
+  broken; FCI cache). (Andrei, patch from m.bretz at metropolis-ag.de)
+- Fixed bug #33277 (private method accessed by child class). (Dmitry)
+- Fixed bug #33268 (iconv_strlen() works only with a parameter of < 3 in
+  length). (Ilia)
+- Fixed bug #33257 (array_splice() inconsistent when passed function instead of
+  variable). (Dmitry)
+- Fixed bug #33243 (ze1_compatibility_mode does not work as expected). (Dmitry)
+- Fixed bug #33242 (Mangled error message when stream fails). (Derick)
+- Fixed bug #33222 (segfault when CURL handle is closed in a callback). (Tony)
+- Fixed bug #33214 (odbc_next_result does not signal SQL errors with
+  2-statement SQL batches). (rich at kastle dot com, Tony)
+- Fixed bug #33212 ([GCC 4]: 'zend_error_noreturn' aliased to external symbol
+  'zend_error'). (Dmitry)
+- Fixed bug #33210 (relax jpeg recursive loop protection). (Ilia)
+- Fixed bug #33201 (Crash when fetching some data types). (Frank)
+- Fixed bug #33200 (preg_replace(): magic_quotes_sybase=On makes 'e' modifier
+  misbehave). (Jani)
+- Fixed bug #33185 (--enable-session=shared does not build). (Jani)
+- Fixed bug #33171 (foreach enumerates private fields declared in base
+  classes). (Dmitry)
+- Fixed bug #33167 (Possible crash inside pg_fetch_array()). (Ilia)
+- Fixed bug #33164 (Soap extension incorrectly detects HTTP/1.1). (Ilia)
+- Fixed bug #33156 (cygwin version of setitimer doesn't accept ITIMER_PROF).
+  (Nuno)
+- Fixed bug #33153 (crash in mssql_next result). (Frank)
+- Fixed bug #33150 (shtool: insecure temporary file creation). (Jani)
+- Fixed bug #33136 (method offsetSet in class extended from ArrayObject crash
+  PHP). (Marcus)
+- Fixed bug #33125 (imagecopymergegray() produces mosaic rainbow effect).
+  (Pierre)
+- Fixed bug #33116 (crash when assigning class name to global variable in
+  __autoload). (Dmitry)
+- Fixed bug #33090 (mysqli_prepare() doesn't return an error). (Georg)
+- Fixed bug #33076 (str_ireplace() incorrectly counts result string length
+  and may cause segfault). (Tony)
+- Fixed bug #33072 (Add a safemode/open_basedir check for runtime
+  "session.save_path" change using session_save_path() function). (Rasmus)
+- Fixed bug #33070 (Improved performance of bzdecompress() by several orders
+  of magnitude). (Ilia)
+- Fixed bug #33059 (crash when moving xml attribute set in dtd). (Ilia)
+- Fixed bug #33057 (Don't send extraneous entity-headers on a 304 as per
+  RFC 2616 section 10.3.5) (Rasmus, Choitel)
+- Fixed bug #33019 (socket errors cause memory leaks in php_strerror()).
+  (jwozniak23 at poczta dot onet dot pl, Tony).
+- Fixed bug #33017 ("make distclean" gives an error with VPATH build). (Jani)
+- Fixed bug #33013 ("next month" was handled wrong while parsing dates).
+  (Derick)
+- Fixed bug #32993 (implemented Iterator function current() don't throw
+  exception). (Dmitry)
+- Fixed bug #32981 (ReflectionMethod::getStaticVariables() causes apache2.0.54
+  seg fault). (Dmitry)
+- Fixed bug #32956 (mysql_bind_result() doesn't support MYSQL_TYPE_NULL).
+  (Georg)
+- Fixed bug #32947 (Incorrect option for mysqli default password). (Georg)
+- Fixed bug #32944 (Disabling session.use_cookies doesn't prevent reading
+  session cookies). (Jani, Tony)
+- Fixed bug #32941 (Sending structured SOAP fault kills a php). (Dmitry)
+- Fixed bug #32937 (open_basedir looses trailing / in the limiter).
+  (Adam Conrad)
+- Fixed bug #32936 (http redirects URLs are not checked for control chars).
+  (Ilia)
+- Fixed bug #32933 (Cannot extend class "SQLiteDatabase"). (Marcus)
+- Fixed bug #32932 (Oracle LDAP: ldap_get_entries(), invalid pointer). (Jani)
+- Fixed bug #32930 (class extending DOMDocument doesn't clone properly). (Rob)
+- Fixed bug #32924 (file included with "auto_prepend_file" can be included
+  with require_once() or include_once()). (Stas)
+- Fixed bug #32904 (pg_get_notify() ignores result_type parameter). (Tony)
+- Fixed bug #32852 (Crash with singleton and __destruct when
+  zend.ze1_compatibility_mode = On). (Dmitry)
+- Fixed bug #32833 (Invalid opcode). (Dmitry)
+- Fixed bug #32813 (parse_url() does not handle scheme-only urls properly).
+  (Ilia)
+- Fixed bug #32810 (temporary files not using plain file wrapper). (Ilia)
+- Fixed bug #32809 (Missing T1LIB support on Windows). (Edin)
+- Fixed bug #32802 (General cookie overrides more specific cookie). (Ilia)
+- Fixed bugs #32800, #32830 (ext/odbc: Problems with 64bit systems). (Jani)
+- Fixed bug #32799 (crash: calling the corresponding global var during the
+  destruct). (Dmitry)
+- Fixed bug #32776 (SOAP doesn't support one-way operations). (Dmitry)
+- Fixed bug #32773 (GMP functions break when second parameter is 0). (Stas)
+- Fixed bug #32759 (incorrect determination of default value (COM)). (Wez)
+- Fixed bug #32758 (Cannot access safearray properties in VB6 objects). (Wez)
+- Fixed bug #32755 (Segfault in replaceChild() when DocumentFragment has no
+  children). (Rob)
+- Fixed bug #32753 (Undefined constant SQLITE_NOTADB). (Ilia)
+- Fixed bug #32742 (segmentation fault when the stream with a wrapper
+  is not closed). (Tony, Dmitry)
+- Fixed bug #32699 (pg_affected_rows() was defined when it was not available).
+  (Derick)
+- Fixed bug #32686 (Require/include file in destructor causes segfault).
+  (Marcus)
+- Fixed bug #32682 (ext/mssql: Error on module shutdown when called from
+  activescript). (Frank)
+- Fixed bug #32674 (exception in iterator causes crash). (Dmitry)
+- Fixed bug #32660 (Assignment by reference causes crash when field access is
+  overloaded (__get)). (Dmitry)
+- Fixed bug #32647 (Using register_shutdown_function() with invalid callback
+  can crash PHP). (Jani)
+- Fixed bug #32615 (Segfault in replaceChild() using fragment when
+  previousSibling is NULL). (Rob)
+- Fixed bug #32613 (ext/snmp: use of snmp_shutdown() causes snmpapp.conf
+  access errors). (Jani, ric at arizona dot edu)
+- Fixed bug #32608 (html_entity_decode() converts single quotes even if
+  ENT_NOQUOTES is given). (Ilia)
+- Fixed bug #32596 (Segfault/Memory Leak by getClass (etc) in __destruct).
+  (Dmitry)
+- Fixed bug #32591 (ext/mysql: Unsatisfied symbol: ntohs with HP-UX). (Jani)
+- Fixed bug #32589 (possible crash inside imap_mail_compose() function).
+  (Ilia)
+- Fixed bug #32589 (Possible crash inside imap_mail_compose, with charsets).
+  (Ilia)
+- Fixed bug #32587 (Apache2: errors sent to error_log do not include
+  timestamps). (Jani)
+- Fixed bug #32560 (configure looks for incorrect db2 library). (Tony)
+- Fixed bug #32553 (mmap loads only the 1st 2000000 bytes on Win32). (Ilia)
+- Fixed bug #32533 (proc_get_status() returns the incorrect process status).
+  (Ilia)
+- Fixed bug #32530 (chunk_split() does not append endstr if chunklen is
+  longer then the original string). (Ilia)
+- Fixed bug #32491 (File upload error - unable to create a temporary file).
+  (Uwe Schindler)
+- Fixed bug #32455 (wrong setting property to unset value). (Dmitry)
+- Fixed bug #32429 (method_exists() always return TRUE if __call method
+  exists). (Dmitry)
+- Fixed bug #32428 (The @ warning error suppression operator is broken).
+  (Dmitry)
+- Fixed bug #32427 (Interfaces are not allowed 'static' access modifier).
+  (Dmitry)
+- Fixed bug #32405 (mysqli::fetch() returns bad data - 64bit problem).
+  (Andrey)
+- Fixed bug #32296 (get_class_methods() output has changed between 5.0.2 and
+  5.0.3). (Dmitry)
+- Fixed bug #32282 (Segfault in mysqli_fetch_array on 64-bit). (Georg)
+- Fixed bug #32245 (xml_parser_free() in a function assigned to the xml
+  parser gives a segfault). (Rob)
+- Fixed bug #32179 (xmlrpc_encode() segfaults with recursive references).
+  (Tony)
+- Fixed bug #32171 (Userspace stream wrapper crashes PHP). (Tony, Dmitry)
+- Fixed bug #32160 (copying a file into itself leads to data loss). (Ilia)
+- Fixed bug #32139 (SOAP client does not auto-handle base64 encoding). (Ilia)
+- Fixed bug #32109 ($_POST is not populated in multi-threaded environment).
+  (Moriyoshi)
+- Fixed bug #32080 (segfault when assigning object to itself with
+  zend.ze1_compatibility_mode=On). (Dmitry)
+- Fixed bug #32021 (Crash caused by range('', 'z')). (Derick)
+- Fixed bug #32013 (ext/mysqli bind_result causes fatal error: memory limit).
+  (Andrey)
+- Fixed bug #32010 (Memory leak in mssql_fetch_batch). (fmk)
+- Fixed bug #32009 (crash when mssql_bind() is called more than once). (Frank)
+- Fixed bug #31971 (ftp_login fails on some SSL servers).
+  (frantisek at augusztin dot com)
+- Fixed bug #31887 (ISAPI: Custom 5xx error does not return correct HTTP
+  response message). (Jani)
+- Fixed bug #31828 (Crash with zend.ze1_compatibility_mode=On). (Dmitry)
+- Fixed bug #31668 (multi_query works exactly every other time - multi query
+  d/e flag global and not per connection). (Andrey)
+- Fixed bug #31636 (another crash when echoing a COM object). (Wez)
+- Fixed bug #31583 (php_std_date() uses short day names in non-y2k_compliance
+  mode). (mike at php dot net)
+- Fixed bug #31525 (object reference being dropped. $this getting lost).
+ (Stas, Dmitry)
+- Fixed bug #31502 (Wrong deserialization from session when using WDDX
+  serializer). (Dmitry)
+- Fixed bug #31478 (segfault with empty() / isset()). (Moriyoshi)
+- Fixed bug #31465 (False warning in unpack() when working with *). (Ilia)
+- Fixed bug #31363 (broken non-blocking flock()). (ian at snork dot net)
+- Fixed bug #31358 (Older GCC versions do not provide portable va_copy()).
+  (Jani)
+- Fixed bug #31341 (escape on curly inconsistent). (Dmitry)
+- Fixed bug #31256 (PHP_EVAL_LIBLINE configure macro does not handle
+  -pthread). (Jani)
+- Fixed bug #31213 (Side effects caused by fix of bug #29493). (Dmitry)
+- Fixed bug #31177 (memory leaks and corruption because of incorrect
+  refcounting). (Dmitry)
+- Fixed bug #31158 (array_splice on $GLOBALS crashes). (Dmitry)
+- Fixed bug #31054 (safe_mode & open_basedir checks only check first
+  include_path value). (Ilia)
+- Fixed bug #31033 (php:function(string, nodeset) with xsl:key crashes PHP).
+  (Rob)
+- Fixed bug #30961 (Wrong line number in ReflectionClass getStartLine()).
+  (Dmitry)
+- Fixed bug #30889 (Conflict between __get/__set and ++ operator). (Dmitry)
+- Fixed bug #30833 (array_count_values() modifying input array). (Tony)
+- Fixed bug #30828 (debug_backtrace() reports incorrect class in overridden
+  methods). (Dmitry)
+- Fixed bug #30820 (static member conflict with $this->member silently
+  ignored). (Dmitry)
+- Fixed bug #30819 (Better support for LDAP SASL bind). (Jani)
+- Fixed bug #30791 (magic methods (__sleep/__wakeup/__toString) call
+  __call if object is overloaded). (Dmitry)
+- Fixed bug #30707 (Segmentation fault on exception in method).
+  (Stas, Dmitry)
+- Fixed bug #30702 (cannot initialize class variable from class constant).
+  (Dmitry)
+- Fixed bug #30578 (Output buffers flushed before calling __destruct()
+  functions). (Jani)
+- Fixed bug #30519 (Interface not existing says Class not found). (Dmitry)
+- Fixed bug #30407 (Strange behavior of default arguments). (Dmitry)
+- Fixed bug #30394 (Assignment operators yield wrong result with __get/__set).
+  (Dmitry)
+- Fixed bug #30332 (zend.ze1_compatibility_mode isn't fully compatible with
+  array_push()). (Dmitry)
+- Fixed bug #30162 (Catching exception in constructor causes lose of
+  $this). (Dmitry)
+- Fixed bug #30140 (Problem with array in static properties). (Dmitry)
+- Fixed bug #30126 (Enhancement for error message for abstract classes).
+  (Marcus)
+- Fixed bug #30096 (gmmktime does not return the current time). (Derick)
+- Fixed bug #30080 (Passing array or non array of objects). (Dmitry)
+- Fixed bug #30052 (Crash on shutdown after odbc_pconnect()). (Edin)
+- Fixed bug #29983 (PHP does not explicitly set mime type & charset). (Ilia)
+- Fixed bug #29975 (memory leaks when set_error_handler() is used inside error
+  handler). (Tony)
+- Fixed bug #29971 (variables_order behavior). (Dmitry)
+- Fixed bug #29944 (Function defined in switch, crashes). (Dmitry)
+- Fixed bug #29896 (Backtrace argument list out of sync). (Dmitry)
+- Fixed bug #29728 (Reflection API Feature: Default parameter value). (Marcus)
+- Fixed bug #29689 (default value of protected member overrides default value
+  of private and other private variable problems in inherited classes). (Stas)
+- Fixed bug #29683 (headers_list() returns empty array). (Tony)
+- Fixed bug #29583 (crash when echoing a COM object). (M.Sisolak, Wez)
+- Fixed bug #29522 (accessing properties without connection). (Georg)
+- Fixed bug #29361 (var_export() producing invalid code). (Derick)
+- Fixed bug #29338 (unencoded spaces get ignored after certain tags). (Ilia)
+- Fixed bug #29335 (fetch functions now use MYSQLI_BOTH as default). (Georg)
+- Fixed bug #29334 (win32 mail() provides incorrect Date: header). (Jani)
+- Fixed bug #29311 (calling parent constructor in mysqli). (Georg)
+- Fixed bug #29268 (__autoload() not called with Reflection->getClass()).
+  (Dmitry)
+- Fixed bug #29256 (SOAP HTTP Error when envelop size is more than 24345
+  bytes). (Dmitry, Wez)
+- Fixed bug #29253 (array_diff with $GLOBALS argument fails). (Dmitry)
+- Fixed bug #29236 (memory error when wsdl-cache is enabled). (Dmitry)
+- Fixed bug #29210 (Function: is_callable - no support for private and
+  protected classes). (Dmitry)
+- Fixed bug #29109 (SoapFault exception: [WSDL] Out of memory). (Dmitry)
+- Fixed bug #29104 (Function declaration in method doesn't work). (Dmitry)
+- Fixed bug #29061 (soap extension segfaults). (Dmitry)
+- Fixed bug #29015 (Incorrect behavior of member vars(non string ones)-numeric
+  mem vars and others). (Dmitry)
+- Fixed bug #28985 (__getTypes() returning nothing on complex WSDL). (Dmitry)
+- Fixed bug #28969 (Wrong data encoding of special characters). (Dmitry)
+- Fixed bug #28839 (SIGSEGV in interactive mode (php -a)).
+  (kameshj at fastmail dot fm)
+- Fixed bug #28605 (Need to use -[m]ieee option for Alpha CPUs). (Jani)
+- Fixed bug #28568 (SAPI::known_post_content_types is not thread safe).
+  (Moriyoshi)
+- Fixed bug #28377 (debug_backtrace is intermittently passing args). (Dmitry)
+- Fixed bug #28355 (glob wont error if dir is not readable). (Hartmut)
+- Fixed bug #28072 (static array with some constant keys will be incorrectly
+  ordered). (Dmitry)
+- Fixed bug #27908 (xml default_handlers not being called). (Rob)
+- Fixed bug #27598 (list() array key assignment causes HUGE memory leak).
+  (Dmitry)
+- Fixed bug #27268 (Bad references accentuated by clone). (Dmitry)
+- Fixed bug #26456 (Wrong results from Reflection-API getDocComment() when
+  called via STDIN). (Dmitry)
+- Fixed bug #25922 (In error handler, modifying 5th arg (errcontext) may
+  result in seg fault). (Dmitry)
+- Fixed bug #25359 (array_multisort() doesn't work in a function if array is
+  global or reference). (Dmitry)
+- Fixed bug #22836 (returning reference to uninitialized variable). (Dmitry)
+- Fixed bug #21306 (ext/sesssion: catch bailouts of write handler during
+  RSHUTDOWN). (Jani, Xuefer at 21cn dot com)
+- Fixed bug #15854 (boolean ini options may be incorrectly displayed as Off
+  when they are On). (Tony)
+- Fixed bugs #14561, #20382, #26090, #26320, #28024, #30532, #32086, #32270,
+  #32555, #32588, #33056 (strtotime() related bugs). (Derick)
+31 Mar 2005, PHP 5.0.4
+- Added SNMPv2 support. (harrie)
+- Added Oracle Instant Client support. (cjbj at hotmail dot com, Tony)
+- Added length and charsetnr for field array and object in mysqli. (Georg)
+- Added checks for negative values to gmp_sqrt(), gmp_powm(), gmp_sqrtrem()
+  and gmp_fact() to prevent SIGFPE. (Tony)
+- Changed foreach() to throw an exception if IteratorAggregate::getIterator()
+  does not return an Iterator. (Marcus)
+- Changed phpize not to require libtool. (Jani)
+- Updated bundled oniguruma library (used for multibyte regular expression)
+  to 3.7.0. (Moriyoshi)
+- Updated bundled libmbfl library (used for multibyte functions). (Moriyoshi)
+  Fixed bugs:
+  . Bug #32311 (mb_encode_mimeheader() does not properly escape characters)
+  . Bug #32063 (mb_convert_encoding ignores named entity 'alpha')
+  . Bug #31911 (mb_decode_mimeheader() is case-sensitive to hex escapes)
+  . bug #30573 (compiler warnings in libmbfl due to invalid type cast)
+  . Bug #30549 (incorrect character translations for some ISO8859 charsets).
+- Fixed bug preventing from building oci8 as shared.
+  (stanislav dot voroniy at portavita dot nl, Tony)
+- Fixed a bug in mysql_affected_rows and mysql_stmt_affected_rows when the
+  api function returns -1 (Georg)
+- Fixed several leaks in ext/browscap and sapi/embed. (Andrei)
+- Fixed several leaks in ext/filepro. (Tony)
+- Fixed build system to always use bundled libtool files. (Jani)
+- Fixed a bug in mysqli_stmt_execute() (type conversion with NULL values).
+  (Georg)
+- Fixed segfault in mysqli_fetch_field_direct() when invalid field offset
+  is passed. (Tony)
+- Fixed posix_getsid() & posix_getpgid() to return sid & pgid instead
+  of true. (Tony)
+- Fixed bug #32394 (offsetUnset() segfaults in a foreach). (Marcus)
+- Fixed bug #32373 (segfault in bzopen() if supplied path to non-existent
+  file). (Tony)
+- Fixed bug #32326 (Check values of Connection/Transfer-Encoding
+  case-incentively in SOAP extension). (Ilia)
+- Fixed bug #32290 (call_user_func_array() calls wrong class method within
+  child class). (Marcus)
+- Fixed bug #32238 (spl_array.c: void function cannot return value). (Johannes)
+- Fixed bug #32210 (proc_get_status() sets "running" always to true). (Ilia)
+- Fixed bug #32200 (Prevent using both --with-apxs2 and --with-apxs2filter).
+  (Jani)
+- Fixed bug #32134 (Overloading offsetGet/offsetSet). (Marcus)
+- Fixed bug #32130 (ArrayIterator::seek() does not throw an Exception on
+  invalid index). (Marcus)
+- Fixed bug #32115 (dateTime SOAP encoding of timezone incorrect). (Dmitry)
+- Fixed bug #32081 (in mysqli default socket value is not being used). (Ilia)
+- Fixed bug #32011 (Fragments which replaced Nodes are not globaly useable).
+  (Rob)
+- Fixed bug #32001 (xml_parse_into_struct() function exceeds maximum
+  execution time). (Rob, Moriyoshi)
+- Fixed bug #31980 (Unicode exif data not available on Windows). (Edin)
+- Fixed bug #31960 (msql_fetch_row() and msql_fetch_array() dropping columns
+  with NULL values). (Daniel Convissor)
+- Fixed bug #31878 (Segmentation fault using clone keyword on nodes). (Rob)
+- Fixed bug #31858 (--disable-cli does not force --without-pear). (Jani)
+- Fixed bug #31842 (*date('r') does not return RFC2822 conforming date string).
+  (Jani)
+- Fixed bug #31832 (SOAP encoding problem with complex types in WSDL mode with
+  multiple parts). (Dmitry)
+- Fixed bug #31797 (exif_read_data() uses too low nesting limit). (Ilia)
+- Fixed bug #31796 (readline completion handler does not handle empty return
+  values). (Ilia)
+- Fixed bug #31792 (getrusage() does not provide ru_nswap value). (Ilia)
+- Fixed bug #31755 (Cannot create SOAP header in no namespace). (Dmitry)
+- Fixed bug #31754 (dbase_open() fails for mode = 1). (Mehdi, Derick)
+- Fixed bug #31751 (pg_parameter_status() missing on Windows). (Edin)
+- Fixed bug #31747 (SOAP Digest Authentication doesn't work with
+  "HTTP/1.1 100 Continue" response). (Dmitry)
+- Fixed bug #31732 (mb_get_info() causes segfault when no parameters
+  specified). (Tony)
+- Fixed bug #31710 (Wrong return values for mysqli_autocommit/commit/rollback).
+  (Georg)
+- Fixed bug #31705 (parse_url() does not recognize http://foo.com#bar). (Ilia)
+- Fixed bug #31695 (Cannot redefine endpoint when using WSDL). (Dmitry)
+- Fixed bug #31684 (dio_tcsetattr(): misconfigured termios settings).
+  (elod at itfais dot com)
+- Fixed bug #31683 (changes to $name in __get($name) override future
+  parameters) (Dmitry)
+- Fixed bug #31699 (unserialize() float problem on non-English locales). (Ilia)
+- Fixed bug #31562 (__autoload() problem with static variables). (Marcus)
+- Fixed bug #31651 (ReflectionClass::getDefaultProperties segfaults with arrays).
+  (Marcus)
+- Fixed bug #31623 (OCILogin does not support password grace period).
+  (daniel dot beet at accuratesoftware dot com, Tony)
+- Fixed bug #31527 (crash in msg_send() when non-string is stored without
+  being serialized). (Ilia)
+- Fixed bug #31515 (Improve performance of scandir() by factor of 10 or so). (Ilia)
+- Fixed bug #31514 (open_basedir uses path_translated rather then cwd for .
+  translation). (Ilia)
+- Fixed bug #31480 (Possible infinite loop in imap_mail_compose()). (Ilia)
+- Fixed bug #31479 (Fixed crash in chunk_split(), when chunklen > strlen). (Ilia)
+- Fixed bug #31454 (session_set_save_handler crashes PHP when supplied
+  non-existent object ref). (Tony)
+- Fixed bug #31444 (Memory leak in zend_language_scanner.c).
+  (hexer at studentcenter dot org)
+- Fixed bug #31442 (unserialize broken on 64-bit systems). (Marcus)
+- Fixed bug #31440 ($GLOBALS can be overwritten via GPC when register_globals
+  is enabled). (Ilia)
+- Fixed bug #31422 (No Error-Logging on SoapServer-Side). (Dmitry)
+- Fixed bug #31413 (curl POSTFIELDS crashes on 64-bit platforms). (Joe)
+- Fixed bug #31396 (compile fails with gd 2.0.33 without freetype). (Jani)
+- Fixed bug #31371 (highlight_file() trims new line after heredoc). (Ilia)
+- Fixed bug #31361 (simplexml/domxml segfault when adding node twice). (Rob)
+- Fixed bug #31348 (CachingIterator::rewind() leaks). (Marcus)
+- Fixed bug #31346 (ArrayIterator::next segfaults). (Marcus)
+- Fixed bug #31190 (Unexpected warning then exception is thrown from
+  call_user_func_array()). (phpbugs at domain51 dot net, Dmitry)
+- Fixed bug #31142 (imap_mail_compose() fails to generate correct output). (Ilia)
+- Fixed bug #31139 (XML Parser Functions seem to drop &amp; when parsing). (Rob)
+- Fixed bug #31398 (When magic_guotes_gpc are enabled filenames with ' get cutoff).
+  (Ilia)
+- Fixed bug #31288 (Possible crash in mysql_fetch_field(), if mysql_list_fields()
+  was not called previously). (Ilia)
+- Fixed bug #31107, #31110, #31111, #31249 (Compile failure of zend_strtod.c).
+  (Jani)
+- Fixed bug #31110 (PHP 4.3.10 does not compile on Tru64 UNIX 5.1B). (Derick)
+- Fixed bug #31107 (Compile failure on Solaris 9 (Intel) and gcc 3.4.3). (Derick)
+- Fixed bug #31103 (Better error message when c-client cannot be found). (Ilia)
+- Fixed bug #31101 (missing kerberos header file path with --with-openssl). (Jani)
+- Fixed bug #31098 (isset() / empty() incorrectly return true in dereference of
+  a string type). (Moriyoshi)
+- Fixed bug #31087 (broken php_url_encode_hash macro). (Ilia)
+- Fixed bug #31072 (var_export() does not output an array element with an empty
+  string key). (Derick)
+- Fixed bug #31060 (imageftbbox() does not use linespacing parameter). (Jani)
+- Fixed bug #31056 (php_std_date() returns invalid formatted date if
+  y2k_compliance is On). (Ilia)
+- Fixed bug #31055 (apache2filter: per request leak proportional to the full
+  path of the request URI). (kameshj at fastmail dot fm)
+- Fixed bug #30901 (can't send cookies with soap envelop). (Dmitry)
+- Fixed bug #30871 (Misleading warning message for array_combine()). (Andrey)
+- Fixed bug #30868 (evaluated pointer comparison in mbregex causes compile
+  failure). (Moriyoshi)
+- Fixed bug #30862 (Static array with boolean indexes). (Marcus)
+- Fixed bug #30726 (-.1 like numbers are not being handled correctly). (Ilia)
+- Fixed bug #30725 (PHP segfaults when an exception is thrown in getIterator()
+  within foreach). (Marcus)
+- Fixed bug #30609 (cURL functions bypass open_basedir). (Jani)
+- Fixed bug #30446 (apache2handler: virtual() includes files out of sequence)
+- Fixed bug #30430 (odbc_next_result() doesn't bind values and that results
+  in segfault). (pdan-php at esync dot org, Tony)
+- Fixed bug #30266 (Invalid opcode 137/1/8). (Marcus)
+- Fixed bug #30120 imagettftext() and imagettfbbox() accept too many
+  parameters). (Jani)
+- Fixed bug #30106 (SOAP cannot not parse 'ref' element. Causes Uncaught
+  SoapFault exception). (Dmitry)
+- Fixed bug #29989 (type re_registers redefined in oniguruma.h). (Moriyoshi)
+- Fixed bug #28803 (enabled debug causes bailout errors with CLI on AIX
+  because of fflush() called on already closed filedescriptor). (Tony)
+- Fixed bug #29767 (Weird behaviour of __set($name, $value)). (Dmitry)
+- Fixed bug #29733 (printf() handles repeated placeholders wrong).
+  (bugs dot php dot net at bluetwanger dot de, Ilia)
+- Fixed bug #29424 (width and height inverted for JPEG2000 files). (Ilia)
+- Fixed bug #29329 (configure for mysqli with shared doesn't work). (Georg)
+- Fixed bug #29136 (make test - libtool failure on MacOSX). (Jani)
+- Fixed bug #28976 (mail(): use "From:" from headers if sendmail_from is empty).
+  (Jani)
+- Fixed bug #28930 (PHP sources pick wrong header files generated by bison).
+  (eggert at gnu dot org, Jani)
+- Fixed bug #28840 (__destruct of a class that extends mysqli not called).
+  (Marcus)
+- Fixed bug #28804 (ini-file section parsing pattern is buggy).
+  (wendland at scan-plus dot de)
+- Fixed bug #28451 (corrupt EXIF headers have unlimited recursive IFD directory
+  entries). (Andrei)
+- Fixed bug #28444 (Cannot access undefined property for object with overloaded
+  property access). (Dmitry)
+- Fixed bug #28442 (Changing a static variables in a class changes it across
+  sub/super classes.) (Marcus)
+- Fixed bug #28324 (HTTP_SESSION_VARS appear when register_long_arrays is
+  Off). (Tony)
+- Fixed bug #28074 (FastCGI: stderr should be written in a FCGI stderr stream).
+  (chris at ex-parrot dot com)
+- Fixed bug #28067 (partially incorrect utf8 to htmlentities mapping). (Derick,
+  Benjamin Greiner)
+- Fixed bug #28041 (SOAP HTTP Digest Access Authentication). (Dmitry)
+- Fixed bug #27633 (Double \r problem on ftp_get in ASCII mode on Win32). (Ilia)
+- Fixed bug #18613 (Multiple OUs in x509 certificate not handled properly).
+  (Jani)
+15 Dec 2004, PHP 5.0.3
+- Added the %F modifier to *printf to render a non-locale-aware representation
+  of a float with the . as decimal seperator. (Derick)
+- Fixed error handling in mysqli_multi_query. (Georg)
+- Extended the functionality of is_subclass_of() to accept either a class name
+  or an object as first parameter. (Andrey)
+- Fixed potential problems with unserializing invalid serialize data. (Marcus)
+- Fixed bug #32076 (ReflectionMethod::isDestructor() always return true).
+  (Derick, Tony)
+- Fixed bug #31034 (Problem with non-existing iconv header file). (Derick)
+- Fixed bug #30995 (snmp extension does not build with net-snmp 5.2). (Ilia)
+- Fixed bug #30994 (SOAP server unable to handle request with references).
+  (Dmitry)
+- Fixed bug #30990 (allow popen() on *NIX to accept 'b' flag). (Ilia)
+- Fixed bug #30967 (properties in extended mysqli classes don't work). (Georg)
+- Fixed bug #30928 (When Using WSDL, SoapServer doesn't handle private or
+  protected properties). (Dmitry)
+- Fixed bug #30922 (reflective functions crash PHP when interfaces extend
+  themselves). (Tony, Dmitry)
+- Fixed bug #30904 (segfault when recording soapclient into session). (Tony,
+  Dmitry)
+- Fixed bug #30890 (MySQLi testsuite)
+- Fixed bug #30856 (ReflectionClass::getStaticProperties segfaults). (Marcus)
+- Fixed bug #30832 ("!" stripped off comments in xml parser). (Rob)
+- Fixed bug #30799 (SoapServer doesn't handle private or protected properties).
+  (Dmitry)
+- Fixed bug #30783 (Apache crash when using ReflectionFunction::
+  getStaticVariables()). (Marcus)
+- Fixed bug #30750 (Meaningful error message when upload directory is not
+  accessible). (Ilia)
+- Fixed bug #30685 (Malformed SOAPClient http header reequest). (Dmitry)
+- Fixed bug #30672 (Problem handling exif data in jpeg images at unusual
+  places). (Marcus)
+- Fixed bug #30658 (Ensure that temporary files created by GD are removed).
+  (Ilia)
+- Fixed bug #30645 (def. multi result set support for mysql_connect). (Georg)
+- Fixed bug #30637 (compile with pear error). (Antony)
+- Fixed bug #30587 (array_multisort doesn't separate zvals before
+  changing them). (Tony)
+- Fixed bug #30572 (crash when comparing SimpleXML attribute to a boolean).
+  (Andi)
+- Fixed bug #30566 (attribute namespace URIs are inconsistent when parsing).
+  (Rob)
+- Fixed bug #30490 (PEAR installation fails). (Antony)
+- Fixed bug #30475 (curl_getinfo() may crash in some situations). (Ilia)
+- Fixed bug #30442 (segfault when parsing ?getvariable[][ ). (Tony)
+- Fixed bug #30388 (rename across filesystems loses ownership and
+  permission info). (Tony)
+- Fixed bug #30387 (stream_socket_client async connect was broken).
+  (vnegrier at esds dot com, Wez).
+- Fixed bug #30381 (Strange results with get_class_vars()). (Marcus)
+- Fixed bug #30375 (cal_info() does not work without a parameter). (Ilia)
+- Fixed bug #30362 (stream_get_line() not handling end string correctly).
+  (Ilia)
+- Fixed bug #30359 (SOAP client requests have no port in "Host" field).
+  (Dmitry)
+- Fixed bug #30356 (str_ireplace() does not work on all strings). (Ilia)
+- Fixed bug #30344 (Reflection::getModifierNames() returns too long strings).
+  (Marcus)
+- Fixed bug #30329 (Error Fetching http body, No Content-Length, connection
+  closed or chunked data). (Dmitry)
+- Fixed bug #30282 (segfault when using unknown/unsupported
+  session.save_handler and/or session.serialize_handler). (Tony)
+- Fixed bug #30281 (Prevent non-wbmp images from being detected as such).
+  (Ilia)
+- Fixed bug #30276 (Possible crash in ctype_digit on large numbers). (Ilia)
+- Fixed bug #30230 (exception handler not working with objects). (Marcus)
+- Fixed bug #30224 (Sybase date strings are sometimes not null terminated).
+  (Ilia)
+- Fixed bug #30175 (SOAP results aren't parsed correctly). (Dmitry)
+- Fixed bug #30147 (OO sqlite_fetch_object did not reset error handler). (Wez)
+- Fixed bug #30133 (get_current_user() crashes on Windows). (Edin)
+- Fixed bug #30061 (xml_set_start_namespace_decl_handler not called). (Rob)
+- Fixed bug #30057 (did not detect IPV6 on FreeBSD 4.1). (Wez)
+- Fixed bug #30042 (strtotime does not use second param). (Derick)
+- Fixed bug #30027 (Possible crash inside ftp_get()).
+  (cfield at affinitysolutions dot com)
+- Fixed bug #29954 (array_reduce segfaults when initial value is array). (Tony)
+- Fixed bug #29883 (isset gives invalid values on strings). (Tony, Dmitry)
+- Fixed bug #29801 (Set limit on the size of mmapable data). (Ilia)
+- Fixed bug #29557 (strtotime error). (Derick)
+- Fixed bug #29418 (double free when openssl_csr_new fails).
+  (Kamesh Jayachandran).
+- Fixed bug #29385 (Soapserver always uses std class). (David, Dmitry)
+- Fixed bug #29211 (SoapClient doesn't request wsdl through proxy). (Rob)
+- Fixed bug #28817 (Var problem when extending domDocument). (Georg)
+- Fixed bug #28599 (strtotime fails with zero base time). (Derick)
+- Fixed bug #28598 (Lost support for MS Symbol fonts). (Pierre)
+- Fixed bug #28220 (mb_strwidth() returns wrong width values for some hangul
+  characters). (Moriyoshi)
+- Fixed bug #28228 (NULL decimal separator is not being handled correctly).
+  (Ilia)
+- Fixed bug #28209 (strtotime("now")). (Derick)
+- Fixed bug #27798 (private / protected variables not exposed by
+  get_object_vars() inside class). (Marcus)
+- Fixed bug #27728 (Can't return within a zend_try {} block or the previous
+  bailout state isn't restored. (Andi)
+- Fixed bug #27183 (Userland stream wrapper segfaults on stream_write).
+  (Christian)
+23 Sep 2004, PHP 5.0.2
+- Added new boolean (fourth) parameter to array_slice() that turns on the
+  preservation of keys in the returned array. (Derick)
+- Added the sorting flag SORT_LOCALE_STRING to the sort() functions which makes
+  them sort based on the current locale. (Derick)
+- Added interface_exists() and make class_exists() only return true for real
+  classes. (Andrey)
+- Added PHP_EOL constant that contains the OS way of representing newlines.
+  (Paul Hudson, Derick)
+- Implemented periodic PCRE compiled regexp cache cleanup, to avoid memory
+  exhaustion. (Andrei)
+- Renamed SoapClient->__call() to SoapClinet->__soapCall(). (Dmitry)
+- Fixed bug with raw_post_data not getting set (Brian)
+- Fixed a file-descriptor leak with phpinfo() and other 'special' URLs (Zeev)
+- Fixed bug #30209 (ReflectionClass::getMethod() lowercases attribute).
+  (Marcus)
+- Fixed bug #30182 (SOAP module processing WSDL file dumps core). (Dmitry)
+- Fixed bug #30045 (Cannot pass big integers (> 2147483647) in SOAP requests).
+  (Dmitry)
+- Fixed bug #29985 (unserialize()/ __PHP_Incomplete_class does not report
+  correctly class name). (Marcus, Tony)
+- Fixed bug #29945 (simplexml_load_file URL limitation 255 char). (Rob)
+- Fixed bug #29873 (No defines around pcntl_*priority definitions). (Derick)
+- Fixed bug #29844 (SOAP doesn't return the result of a valid SOAP request).
+  (Dmitry)
+- Fixed bug #29842 (soapclient return null value). (Dmitry)
+- Fixed bug #29839 (incorrect convert (xml:lang to lang)). (Dmitry)
+- Fixed bug #29830 (SoapServer::setClass() should not export non-public
+- Fixed bug #29828 (Interfaces no longer work). (Marcus)
+- Fixed bug #29821 (Fixed possible crashes in convert_uudecode() on invalid
+  data). (Ilia)
+- Fixed bug #29808 (array_count_values() breaks with numeric strings). (Ilia)
+- Fixed bug #29805 (HTTP Authentication Issues). (Uwe Schindler)
+- Fixed bug #29795 (SegFault with Soap and Amazon's Web Services). (Dmitry)
+- Fixed bug #29737 (ip2long should return -1 if IP is 255.255.255.255 and FALSE
+  on error). (Tony)
+- Fixed bug #29711 (Changed ext/xml to default to UTF-8 output). (Rob)
+- Fixed bug #29678 (opendir() with ftp:// wrapper segfaults if path does not
+  have trailing slash). (Ilia)
+- Fixed bug #29657 (xml_* functions throw non descriptive error).
+  (Christian, Rob)
+- Fixed bug #29656 (segfault on result and statement properties). (Georg)
+- Fixed bug #29566 (foreach/string handling strangeness (crash)). (Dmitry)
+- Fixed bug #29447 (Reflection API issues). (Marcus)
+- Fixed bug #29296 (Added sslv2 and sslv3 transports). (Wez)
+- Fixed bug #29283 (Invalid statement handle in mysqli on execute). (Georg)
+- Fixed bug #29913 (parse_url() is now binary safe). (Ilia)
+- Fixed bug #27994 (segfault with Soapserver when WSDL-Cache is enabled).
+  (Dmitry)
+- Fixed bug #27791 (Apache 2.0 SAPI build against Apache 2 HEAD). (Joe Orton,
+  Derick)
+- Fixed bug #26737 (private/protected properties not serialized when user
+  declared method __sleep() exists). E_NOTICE thrown when __sleep() returns
+  name of non-existing member. (Andrey, Curt)
+12 Aug 2004, PHP 5.0.1
+- Changed destructor mechanism so that destructors are called prior to request
+  shutdown. (Marcus)
+- Rewritten UNIX and Windows install help files. (Documentation Team)
+- Updated several libraries bundled with the windows release which now
+  includes libxml2-2.6.11, libxslt-1.1.7 and iconv-1.9.1. (Rob, Edin)
+- Improved and moved ActiveScript SAPI to PECL.  (Wez)
+- Fixed bug #29606 (php_strip_whitespace() prints to stdout rather then
+  returning the value). (Ilia)
+- Fixed bug #29577 (MYSQLI_CLIENT_FOUND_ROWS undefined) (Georg)
+- Fixed bug #29573 (Segmentation fault, when exception thrown within
+  PHP function called from XSLT). (Christian)
+- Fixed bug #29522 (accessing properties without connection) (Georg)
+- Fixed bug #29505 (get_class_vars() severely broken when used with arrays).
+  (Marcus)
+- Fixed bug #29490 (.Net object instantiation failed). (Michael Sisolak).
+- Fixed bug #29474 (win32: usleep() doesn't work). (Wez)
+- Fixed bug #29449 (win32: feof() hangs on empty tcp stream). (Wez)
+- Fixed bug #29437 (Possible crash inside array_walk_recursive()). (Ilia)
+- Fixed bug #29431 (crash when parsing invalid address; invalid address
+  returned by stream_socket_recvfrom(), stream_socket_getname()). (Wez)
+- Fixed bug #29409 (Segfault in PHP functions called from XSLT). (Rob)
+- Fixed unloading of dynamically loaded extensions.
+  (Marcus, kameshj at fastmail dot fm)
+- Fixed bug #29395 (sqlite_escape_string() returns bogus data on empty
+  strings). (Ilia, Tony)
+- Fixed bug #29392 (com_dotnet crashes when echo'ing an object). (Wez)
+- Fixed bug #29368 (The destructor is called when an exception is thrown from
+  the constructor). (Marcus)
+- Fixed bug #29354 (Exception constructor marked as both public and protected).
+  (Marcus)
+- Fixed bug #29342 (strtotime() does not handle empty date string properly).
+  (Ilia)
+- Fixed bug #29340 (win32 build produces invalid php_ifx.dll). (Edin)
+- Fixed bug #29335 (fetch functions now use MYSQLI_BOTH as default) (Georg)
+- Fixed bug #29291 (get_class_vars() return names with NULLs). (Marcus)
+- Fixed bug #29264 (gettext extension not working). (Edin)
+- Fixed bug #29258 (variant_date_from_timestamp() does not honour
+  timezone).  (Wez)
+- Fixed bug #29256 (error when sending large packets on a socket). (Dmitry)
+- Fixed bug #29147 (Compile Error in mnoGoSearch functions). (Sergey, Antony)
+- Fixed bug #29132 ($_SERVER["PHP_AUTH_USER"] isn't defined). (Stefan)
+- Fixed bug #29119 (html_entity_decode() misbehaves with UTF-8). (Moriyoshi)
+- Fixed bug #28895 (ReflectionClass::isAbstract always returns false). (Marcus)
+- Fixed bug #28829 (Thread-unsafety in bcmath elementary values). (Sara)
+- Fixed bug #28464 (catch() does not catch exceptions by interfaces). (Marcus)
+- Fixed bug #27669 (PHP 5 didn't support all possibilities for calling static
+  methods dynamically). (Dmitry)
+- Fixed ReflectionClass::getMethod() and ReflectionClass::getProperty() to
+  raise an ReflectionException instead of returning NULL on failure.
+  (Sebastian)
+- Fixed convert.* filters to consume remaining buckets_in on flush. (Sara)
+- Fixed bug in mysqli->client_version. (Georg)
+13 Jul 2004, PHP 5.0.0
+- Updated PCRE to provide better error handling in certain cases. (Andrei)
+- Changed doc comments to require a single white space after '/**'. (Marcus)
+- Fixed bug #29019 (Database not closing). (Marcus)
+- Fixed bug #29008 (array_combine() does not handle non-numeric/string keys).
+  (Ilia)
+- Fixed bug #28999 (fixed behaviour of exec() to work as it did in 4.X). (Ilia)
+- Fixed bug #28868 (Internal filter registry not thread safe). (Sara)
+- Fixed bug #28851 (call_user_func_array has typo in error message). (Marcus)
+- Fixed bug #28831 (ArrayObject::offsetGet() does the work of offsetUnset()).
+  (Marcus)
+- Fixed bug #28822 (ArrayObject::offsetExists() works inverted). (Marcus)
+- Fixed bug #28789 (ReflectionProperty getValue() fails on public static
+  members). (Marcus)
+- Fixed bug #28771 (Segfault when using xslt and clone). (Rob)
+- Fixed bug #28751 (SoapServer does not call _autoload()). (Dmitry)
+- Fixed bug #28739 (array_*diff() and array_*intersect() not clearing the fci
+  cache before work). (Andrey)
+- Fixed bug #28721 (appendChild() and insertBefore() unset DOMText).(Rob)
+- Fixed bug #28702 (SOAP does not parse WSDL service address correctly). (Dmitry)
+- Fixed bug #28699 (Reflection api bugs). (Marcus)
+- Fixed bug #28694 (ReflectionExtension::getFunctions() crashes PHP). (Marcus)
+- Fixed bug #28512 (Allocate enough space to store MSSQL data). (Frank)
+- Fixed strip_tags() to correctly handle '\0' characters. (Stefan)
Added: trunk/Installer/Support/Web/x64/Php/README.REDIST.BINS
--- trunk/Installer/Support/Web/x64/Php/README.REDIST.BINS	                        (rev 0)
+++ trunk/Installer/Support/Web/x64/Php/README.REDIST.BINS	2010-06-26 14:06:52 UTC (rev 4976)
@@ -0,0 +1,429 @@
+1. libmagic (ext/fileinfo) see ext/fileinfo/libmagic/LICENSE
+2. Oniguruma (ext/mbstring) see ext/mbstring/oniguruma/COPYING
+3. libmbfl (ext/mbstring) see ext/mbstring/libmbfl/LICENSE
+4. pcrelib (ext/pcre) see ext/pcre/pcrelib/LICENCE
+5. ext/standard crypt
+6. ext/standard crypt's blowfish implementation
+7. Sqlite/Sqlite3 ext/sqlite3 ext/sqlite
+8. ext/json/json_parser
+9. ext/standard/rand
+10. ext/standard/scanf
+11. ext/standard/strnatcmp.c
+12. ext/standard/uuencode
+13. libxmlrpc ext/xmlrpc
+14. libzip ext/zip
+15. main/snprintf.c
+16. main/strlcat
+17. main/strlcpy
+18. libgd see ext/gd/libgd/COPYING
+FreeSec: libcrypt for NetBSD
+Copyright (c) 1994 David Burren
+All rights reserved.
+Redistribution and use in source and binary forms, with or without
+modification, are permitted provided that the following conditions
+are met:
+1. Redistributions of source code must retain the above copyright
+	 notice, this list of conditions and the following disclaimer.
+2. Redistributions in binary form must reproduce the above copyright
+	 notice, this list of conditions and the following disclaimer in the
+	 documentation and/or other materials provided with the distribution.
+3. Neither the name of the author nor the names of other contributors
+	 may be used to endorse or promote products derived from this software
+	 without specific prior written permission.
+THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+SUCH DAMAGE.
+This code comes from John the Ripper password cracker, with reentrant
+and crypt(3) interfaces added, but optimizations specific to password
+cracking removed.
+Written by Solar Designer <solar at openwall.com> in 1998-2002 and
+placed in the public domain.
+There's absolutely no warranty.
+It is my intent that you should be able to use this on your system,
+as a part of a software package, or anywhere else to improve security,
+ensure compatibility, or for any other purpose. I would appreciate
+it if you give credit where it is due and keep your modifications in
+the public domain as well, but I don't require that in order to let
+you place this code and any modifications you make under a license
+of your choice.
+This implementation is compatible with OpenBSD bcrypt.c (version 2a)
+by Niels Provos <provos at citi.umich.edu>, and uses some of his
+ideas. The password hashing algorithm was designed by David Mazieres
+<dm at lcs.mit.edu>.
+There's a paper on the algorithm that explains its design decisions:
+http://www.usenix.org/events/usenix99/provos.html
+Some of the tricks in BF_ROUND might be inspired by Eric Young's
+Blowfish library (I can't be sure if I would think of something if I
+hadn't seen his code).
+The author disclaims copyright to this source code.  In place of
+a legal notice, here is a blessing:
+  May you do good and not evil.
+  May you find forgiveness for yourself and forgive others.
+  May you share freely, never taking more than you give.
+Copyright (c) 2005 JSON.org
+Permission is hereby granted, free of charge, to any person obtaining a copy
+of this software and associated documentation files (the "Software"), to deal
+in the Software without restriction, including without limitation the rights
+to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
+copies of the Software, and to permit persons to whom the Software is
+furnished to do so, subject to the following conditions:
+The above copyright notice and this permission notice shall be included in all
+copies or substantial portions of the Software.
+The Software shall be used for Good, not Evil.
+THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
+AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
+OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
+SOFTWARE.
+The following php_mt_...() functions are based on a C++ class MTRand by
+Richard J. Wagner. For more information see the web page at
+http://www-personal.engin.umich.edu/~wagnerr/MersenneTwister.html
+Mersenne Twister random number generator -- a C++ class MTRand
+Based on code by Makoto Matsumoto, Takuji Nishimura, and Shawn Cokus
+Richard J. Wagner  v1.0  15 May 2003  rjwagner at writeme.com
+The Mersenne Twister is an algorithm for generating random numbers.  It
+was designed with consideration of the flaws in various other generators.
+The period, 2^19937-1, and the order of equidistribution, 623 dimensions,
+are far greater.  The generator is also fast; it avoids multiplication and
+division, and it benefits from caches and pipelines.  For more information
+see the inventors' web page at http://www.math.keio.ac.jp/~matumoto/emt.html
+Reference
+M. Matsumoto and T. Nishimura, "Mersenne Twister: A 623-Dimensionally
+Equidistributed Uniform Pseudo-Random Number Generator", ACM Transactions on
+Modeling and Computer Simulation, Vol. 8, No. 1, January 1998, pp 3-30.
+Copyright (C) 1997 - 2002, Makoto Matsumoto and Takuji Nishimura,
+Copyright (C) 2000 - 2003, Richard J. Wagner
+are met:
+3. The names of its contributors may not be used to endorse or promote
+	 products derived from this software without specific prior written
+	 permission.
+THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+A PARTICULAR PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE COPYRIGHT OWNER OR
+CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
+PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
+LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
+NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+scanf.c --
+This file contains the base code which implements sscanf and by extension
+fscanf. Original code is from TCL8.3.0 and bears the following copyright:
+This software is copyrighted by the Regents of the University of
+California, Sun Microsystems, Inc., Scriptics Corporation,
+and other parties.  The following terms apply to all files associated
+with the software unless explicitly disclaimed in individual files.
+The authors hereby grant permission to use, copy, modify, distribute,
+and license this software and its documentation for any purpose, provided
+that existing copyright notices are retained in all copies and that this
+notice is included verbatim in any distributions. No written agreement,
+license, or royalty fee is required for any of the authorized uses.
+Modifications to this software may be copyrighted by their authors
+and need not follow the licensing terms described here, provided that
+the new terms are clearly indicated on the first page of each file where
+they apply.
+IN NO EVENT SHALL THE AUTHORS OR DISTRIBUTORS BE LIABLE TO ANY PARTY
+FOR DIRECT, INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES
+ARISING OUT OF THE USE OF THIS SOFTWARE, ITS DOCUMENTATION, OR ANY
+DERIVATIVES THEREOF, EVEN IF THE AUTHORS HAVE BEEN ADVISED OF THE
+POSSIBILITY OF SUCH DAMAGE.
+THE AUTHORS AND DISTRIBUTORS SPECIFICALLY DISCLAIM ANY WARRANTIES,
+INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY,
+FITNESS FOR A PARTICULAR PURPOSE, AND NON-INFRINGEMENT.  THIS SOFTWARE
+IS PROVIDED ON AN "AS IS" BASIS, AND THE AUTHORS AND DISTRIBUTORS HAVE
+NO OBLIGATION TO PROVIDE MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS, OR
+MODIFICATIONS.
+GOVERNMENT USE: If you are acquiring this software on behalf of the
+U.S. government, the Government shall have only "Restricted Rights"
+in the software and related documentation as defined in the Federal
+Acquisition Regulations (FARs) in Clause 52.227.19 (c) (2).  If you
+are acquiring the software on behalf of the Department of Defense, the
+software shall be classified as "Commercial Computer Software" and the
+Government shall have only "Restricted Rights" as defined in Clause
+252.227-7013 (c) (1) of DFARs.  Notwithstanding the foregoing, the
+authors grant the U.S. Government and others acting in its behalf
+permission to use and distribute the software in accordance with the
+terms specified in this license.
+strnatcmp.c -- Perform 'natural order' comparisons of strings in C.
+Copyright (C) 2000 by Martin Pool <mbp at humbug.org.au>
+This software is provided 'as-is', without any express or implied
+warranty.  In no event will the authors be held liable for any damages
+arising from the use of this software.
+Permission is granted to anyone to use this software for any purpose,
+including commercial applications, and to alter it and redistribute it
+freely, subject to the following restrictions:
+1. The origin of this software must not be misrepresented; you must not
+	 claim that you wrote the original software. If you use this software
+	 in a product, an acknowledgment in the product documentation would be
+	 appreciated but is not required.
+2. Altered source versions must be plainly marked as such, and must not be
+	 misrepresented as being the original software.
+3. This notice may not be removed or altered from any source distribution.
+Portions of this code are based on Berkeley's uuencode/uudecode
+implementation.
+Copyright (c) 1983, 1993
+The Regents of the University of California.  All rights reserved.
+are met:
+3. All advertising materials mentioning features or use of this software
+	must display the following acknowledgement:
+This product includes software developed by the University of
+California, Berkeley and its contributors.
+4. Neither the name of the University nor the names of its contributors
+THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+SUCH DAMAGE.
+Copyright 2000 Epinions, Inc.
+Subject to the following 3 conditions, Epinions, Inc.  permits you, free
+of charge, to (a) use, copy, distribute, modify, perform and display this
+software and associated documentation files (the "Software"), and (b)
+permit others to whom the Software is furnished to do so as well.
+1) The above copyright notice and this permission notice shall be included
+without modification in all copies or substantial portions of the
+Software.
+2) THE SOFTWARE IS PROVIDED "AS IS", WITHOUT ANY WARRANTY OR CONDITION OF
+ANY KIND, EXPRESS, IMPLIED OR STATUTORY, INCLUDING WITHOUT LIMITATION ANY
+IMPLIED WARRANTIES OF ACCURACY, MERCHANTABILITY, FITNESS FOR A PARTICULAR
+PURPOSE OR NONINFRINGEMENT.
+3) IN NO EVENT SHALL EPINIONS, INC. BE LIABLE FOR ANY DIRECT, INDIRECT,
+SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES OR LOST PROFITS ARISING OUT
+OF OR IN CONNECTION WITH THE SOFTWARE (HOWEVER ARISING, INCLUDING
+NEGLIGENCE), EVEN IF EPINIONS, INC.  IS AWARE OF THE POSSIBILITY OF SUCH
+DAMAGES.
+14. libzip ext/zip
+zip.h -- exported declarations.
+Copyright (C) 1999-2009 Dieter Baron and Thomas Klausner
+This file is part of libzip, a library to manipulate ZIP archives.
+The authors can be contacted at <libzip at nih.at>
+are met:
+	 the documentation and/or other materials provided with the
+	 distribution.
+3. The names of the authors may not be used to endorse or promote
+	 written permission.
+THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS
+OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY
+DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
+IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
+IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+Copyright (c) 2002, 2006 Todd C. Miller <Todd.Miller at courtesan.com>
+Permission to use, copy, modify, and distribute this software for any
+purpose with or without fee is hereby granted, provided that the above
+copyright notice and this permission notice appear in all copies.
+THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+Sponsored in part by the Defense Advanced Research Projects
+Agency (DARPA) and Air Force Research Laboratory, Air Force
+Materiel Command, USAF, under agreement number F39502-99-1-0512.
+main/spprintf
+Copyright (c) 1995-1998 The Apache Group.  All rights reserved.
+are met:
+	 distribution.
+	 software must display the following acknowledgment:
+	 "This product includes software developed by the Apache Group
+	 for use in the Apache HTTP server project (http://www.apache.org/)."
+4. The names "Apache Server" and "Apache Group" must not be used to
+	 endorse or promote products derived from this software without
+	 prior written permission.
+5. Redistributions of any form whatsoever must retain the following
+	 acknowledgment:
+THIS SOFTWARE IS PROVIDED BY THE APACHE GROUP ``AS IS'' AND ANY
+EXPRESSED OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE APACHE GROUP OR
+ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
+LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
+OF THE POSSIBILITY OF SUCH DAMAGE.
+This software consists of voluntary contributions made by many
+individuals on behalf of the Apache Group and was originally based
+on public domain software written at the National Center for
+Supercomputing Applications, University of Illinois, Urbana-Champaign.
+For more information on the Apache Group and the Apache HTTP server
+project, please see <http://www.apache.org/>.
+This code is based on, and used with the permission of, the
+SIO stdio-replacement strx_* functions by Panos Tsirigotis
+<panos at alumni.cs.colorado.edu> for xinetd.
+16. main/strlcat
+17. main/strlcpy
+Copyright (c) 1998 Todd C. Miller <Todd.Miller at courtesan.com>
+are met:
+3. The name of the author may not be used to endorse or promote products
+	derived from this software without specific prior written permission.
+THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
+AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL
+THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Added: trunk/Installer/Support/Web/x64/Php/dev/php5ts.lib
(Binary files differ)
Property changes on: trunk/Installer/Support/Web/x64/Php/dev/php5ts.lib
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/Installer/Support/Web/x64/Php/ext/php_bz2.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_bz2.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_curl.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_curl.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_exif.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_exif.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_fileinfo.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_fileinfo.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_gd2.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_gd2.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_gettext.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_gettext.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_gmp.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_gmp.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_imap.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_imap.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_intl.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_intl.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_ldap.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_ldap.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_mbstring.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_mbstring.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_mysql.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_mysql.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_mysqli.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_mysqli.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_openssl.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_openssl.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_pdo_mysql.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_pdo_mysql.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_pdo_odbc.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_pdo_odbc.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_pdo_pgsql.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_pdo_pgsql.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_pdo_sqlite.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_pdo_sqlite.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_pgsql.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_pgsql.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_shmop.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_shmop.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_soap.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_soap.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_sockets.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_sockets.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_sqlite.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_sqlite.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_sqlite3.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_sqlite3.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_tidy.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_tidy.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_xmlrpc.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_xmlrpc.dll
Added: trunk/Installer/Support/Web/x64/Php/ext/php_xsl.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/ext/php_xsl.dll
Added: trunk/Installer/Support/Web/x64/Php/php-cgi.exe
Property changes on: trunk/Installer/Support/Web/x64/Php/php-cgi.exe
Added: trunk/Installer/Support/Web/x64/Php/php-win.exe
Property changes on: trunk/Installer/Support/Web/x64/Php/php-win.exe
Added: trunk/Installer/Support/Web/x64/Php/php.exe
Property changes on: trunk/Installer/Support/Web/x64/Php/php.exe
Added: trunk/Installer/Support/Web/x64/Php/php.gif
Property changes on: trunk/Installer/Support/Web/x64/Php/php.gif
Added: trunk/Installer/Support/Web/x64/Php/php.ini
--- trunk/Installer/Support/Web/x64/Php/php.ini	                        (rev 0)
+++ trunk/Installer/Support/Web/x64/Php/php.ini	2010-06-26 14:06:52 UTC (rev 4976)
@@ -0,0 +1,1263 @@
+[PHP]
+; About php.ini   ;
+; This file controls many aspects of PHP's behavior.  In order for PHP to
+; read it, it must be named 'php.ini'.  PHP looks for it in the current
+; working directory, in the path designated by the environment variable
+; PHPRC, and in the path that was defined in compile time (in that order).
+; Under Windows, the compile-time path is the Windows directory.  The
+; path in which the php.ini file is looked for can be overridden using
+; the -c argument in command line mode.
+; The syntax of the file is extremely simple.  Whitespace and Lines
+; beginning with a semicolon are silently ignored (as you probably guessed).
+; Section headers (e.g. [Foo]) are also silently ignored, even though
+; they might mean something in the future.
+; Directives are specified using the following syntax:
+; directive = value
+; Directive names are *case sensitive* - foo=bar is different from FOO=bar.
+; The value can be a string, a number, a PHP constant (e.g. E_ALL or M_PI), one
+; of the INI constants (On, Off, True, False, Yes, No and None) or an expression
+; (e.g. E_ALL & ~E_NOTICE), or a quoted string ("foo").
+; Expressions in the INI file are limited to bitwise operators and parentheses:
+; |        bitwise OR
+; &        bitwise AND
+; ~        bitwise NOT
+; !        boolean NOT
+; Boolean flags can be turned on using the values 1, On, True or Yes.
+; They can be turned off using the values 0, Off, False or No.
+; An empty string can be denoted by simply not writing anything after the equal
+; sign, or by using the None keyword:
+;  foo =         ; sets foo to an empty string
+;  foo = none    ; sets foo to an empty string
+;  foo = "none"  ; sets foo to the string 'none'
+; If you use constants in your value, and these constants belong to a
+; dynamically loaded extension (either a PHP extension or a Zend extension),
+; you may only use these constants *after* the line that loads the extension.
+; About this file ;
+; This is the recommended, PHP 5-style version of the php.ini-dist file.  It
+; sets some non standard settings, that make PHP more efficient, more secure,
+; and encourage cleaner coding.
+; The price is that with these settings, PHP may be incompatible with some
+; applications, and sometimes, more difficult to develop with.  Using this
+; file is warmly recommended for production sites.  As all of the changes from
+; the standard settings are thoroughly documented, you can go over each one,
+; and decide whether you want to use it or not.
+; For general information about the php.ini file, please consult the php.ini-dist
+; file, included in your PHP distribution.
+; This file is different from the php.ini-dist file in the fact that it features
+; different values for several directives, in order to improve performance, while
+; possibly breaking compatibility with the standard out-of-the-box behavior of
+; PHP.  Please make sure you read what's different, and modify your scripts
+; accordingly, if you decide to use this file instead.
+; - register_globals = Off         [Security, Performance]
+;     Global variables are no longer registered for input data (POST, GET, cookies,
+;     environment and other server variables).  Instead of using $foo, you must use
+;     you can use $_REQUEST["foo"] (includes any variable that arrives through the
+;     request, namely, POST, GET and cookie variables), or use one of the specific
+;     $_GET["foo"], $_POST["foo"], $_COOKIE["foo"] or $_FILES["foo"], depending
+;     on where the input originates.  Also, you can look at the
+;     import_request_variables() function.
+;     Note that register_globals is going to be depracated (i.e., turned off by
+;     default) in the next version of PHP, because it often leads to security bugs.
+;     Read http://php.net/manual/en/security.registerglobals.php for further
+;     information.
+; - register_long_arrays = Off     [Performance]
+;     Disables registration of the older (and deprecated) long predefined array
+;     variables ($HTTP_*_VARS).  Instead, use the superglobals that were
+;     introduced in PHP 4.1.0
+; - display_errors = Off           [Security]
+;     With this directive set to off, errors that occur during the execution of
+;     scripts will no longer be displayed as a part of the script output, and thus,
+;     will no longer be exposed to remote users.  With some errors, the error message
+;     content may expose information about your script, web server, or database
+;     server that may be exploitable for hacking.  Production sites should have this
+;     directive set to off.
+; - log_errors = On                [Security]
+;     This directive complements the above one.  Any errors that occur during the
+;     execution of your script will be logged (typically, to your server's error log,
+;     but can be configured in several ways).  Along with setting display_errors to off,
+;     this setup gives you the ability to fully understand what may have gone wrong,
+;     without exposing any sensitive information to remote users.
+; - output_buffering = 4096        [Performance]
+;     Set a 4KB output buffer.  Enabling output buffering typically results in less
+;     writes, and sometimes less packets sent on the wire, which can often lead to
+;     better performance.  The gain this directive actually yields greatly depends
+;     on which Web server you're working with, and what kind of scripts you're using.
+; - register_argc_argv = Off       [Performance]
+;     Disables registration of the somewhat redundant $argv and $argc global
+;     variables.
+; - magic_quotes_gpc = Off         [Performance]
+;     Input data is no longer escaped with slashes so that it can be sent into
+;     SQL databases without further manipulation.  Instead, you should use the
+;     function addslashes() on each input element you wish to send to a database.
+; - variables_order = "GPCS"       [Performance]
+;     The environment variables are not hashed into the $_ENV.  To access
+;     environment variables, you can use getenv() instead.
+; - error_reporting = E_ALL        [Code Cleanliness, Security(?)]
+;     By default, PHP surpresses errors of type E_NOTICE.  These error messages
+;     are emitted for non-critical errors, but that could be a symptom of a bigger
+;     problem.  Most notably, this will cause error messages about the use
+;     of uninitialized variables to be displayed.
+; - allow_call_time_pass_reference = Off     [Code cleanliness]
+;     It's not possible to decide to force a variable to be passed by reference
+;     when calling a function.  The PHP 4 style to do this is by making the
+;     function require the relevant argument by reference.
+; Language Options ;
+; Enable the PHP scripting language engine under Apache.
+engine = On
+; Enable compatibility mode with Zend Engine 1 (PHP 4.x)
+zend.ze1_compatibility_mode = Off
+; Allow the <? tag.  Otherwise, only <?php and <script> tags are recognized.
+; NOTE: Using short tags should be avoided when developing applications or
+; libraries that are meant for redistribution, or deployment on PHP
+; servers which are not under your control, because short tags may not
+; be supported on the target server. For portable, redistributable code,
+; be sure not to use short tags.
+short_open_tag = On
+; Allow ASP-style <% %> tags.
+asp_tags = Off
+; The number of significant digits displayed in floating point numbers.
+precision    =  14
+; Enforce year 2000 compliance (will cause problems with non-compliant browsers)
+y2k_compliance = On
+; Output buffering allows you to send header lines (including cookies) even
+; after you send body content, at the price of slowing PHP's output layer a
+; bit.  You can enable output buffering during runtime by calling the output
+; buffering functions.  You can also enable output buffering for all files by
+; setting this directive to On.  If you wish to limit the size of the buffer
+; to a certain size - you can use a maximum number of bytes instead of 'On', as
+; a value for this directive (e.g., output_buffering=4096).
+output_buffering = 4096
+; You can redirect all of the output of your scripts to a function.  For
+; example, if you set output_handler to "mb_output_handler", character
+; encoding will be transparently converted to the specified encoding.
+; Setting any output handler automatically turns on output buffering.
+; Note: People who wrote portable scripts should not depend on this ini
+;       directive. Instead, explicitly set the output handler using ob_start().
+;       Using this ini directive may cause problems unless you know what script
+;       is doing.
+; Note: You cannot use both "mb_output_handler" with "ob_iconv_handler"
+;       and you cannot use both "ob_gzhandler" and "zlib.output_compression".
+; Note: output_handler must be empty if this is set 'On' !!!!
+;       Instead you must use zlib.output_handler.
+;output_handler =
+; Transparent output compression using the zlib library
+; Valid values for this option are 'off', 'on', or a specific buffer size
+; to be used for compression (default is 4KB)
+; Note: Resulting chunk size may vary due to nature of compression. PHP
+;       outputs chunks that are few hundreds bytes each as a result of
+;       compression. If you prefer a larger chunk size for better
+;       performance, enable output_buffering in addition.
+; Note: You need to use zlib.output_handler instead of the standard
+;       output_handler, or otherwise the output will be corrupted.
+zlib.output_compression = Off
+; You cannot specify additional output handlers if zlib.output_compression
+; is activated here. This setting does the same as output_handler but in
+; a different order.
+;zlib.output_handler =
+; Implicit flush tells PHP to tell the output layer to flush itself
+; automatically after every output block.  This is equivalent to calling the
+; PHP function flush() after each and every call to print() or echo() and each
+; and every HTML block.  Turning this option on has serious performance
+; implications and is generally recommended for debugging purposes only.
+implicit_flush = Off
+; The unserialize callback function will be called (with the undefined class'
+; name as parameter), if the unserializer finds an undefined class
+; which should be instanciated.
+; A warning appears if the specified function is not defined, or if the
+; function doesn't include/implement the missing class.
+; So only set this entry, if you really want to implement such a
+; callback-function.
+unserialize_callback_func=
+; When floats & doubles are serialized store serialize_precision significant
+; digits after the floating point. The default value ensures that when floats
+; are decoded with unserialize, the data will remain the same.
+serialize_precision = 100
+; Whether to enable the ability to force arguments to be passed by reference
+; at function call time.  This method is deprecated and is likely to be
+; unsupported in future versions of PHP/Zend.  The encouraged method of
+; specifying which arguments should be passed by reference is in the function
+; declaration.  You're encouraged to try and turn this option Off and make
+; sure your scripts work properly with it in order to ensure they will work
+; with future versions of the language (you will receive a warning each time
+; you use this feature, and the argument will be passed by value instead of by
+; reference).
+allow_call_time_pass_reference = Off
+; Safe Mode
+safe_mode = Off
+; By default, Safe Mode does a UID compare check when
+; opening files. If you want to relax this to a GID compare,
+; then turn on safe_mode_gid.
+safe_mode_gid = Off
+; When safe_mode is on, UID/GID checks are bypassed when
+; including files from this directory and its subdirectories.
+; (directory must also be in include_path or full path must
+; be used when including)
+safe_mode_include_dir =
+; When safe_mode is on, only executables located in the safe_mode_exec_dir
+; will be allowed to be executed via the exec family of functions.
+safe_mode_exec_dir =
+; Setting certain environment variables may be a potential security breach.
+; This directive contains a comma-delimited list of prefixes.  In Safe Mode,
+; the user may only alter environment variables whose names begin with the
+; prefixes supplied here.  By default, users will only be able to set
+; environment variables that begin with PHP_ (e.g. PHP_FOO=BAR).
+; Note:  If this directive is empty, PHP will let the user modify ANY
+; environment variable!
+safe_mode_allowed_env_vars = PHP_
+; This directive contains a comma-delimited list of environment variables that
+; the end user won't be able to change using putenv().  These variables will be
+; protected even if safe_mode_allowed_env_vars is set to allow to change them.
+safe_mode_protected_env_vars = LD_LIBRARY_PATH
+; open_basedir, if set, limits all file operations to the defined directory
+; and below.  This directive makes most sense if used in a per-directory
+; or per-virtualhost web server configuration file. This directive is
+; *NOT* affected by whether Safe Mode is turned On or Off.
+;open_basedir =
+; This directive allows you to disable certain functions for security reasons.
+; It receives a comma-delimited list of function names. This directive is
+disable_functions =
+; This directive allows you to disable certain classes for security reasons.
+; It receives a comma-delimited list of class names. This directive is
+disable_classes =
+; Colors for Syntax Highlighting mode.  Anything that's acceptable in
+; <span style="color: ???????"> would work.
+;highlight.string  = #DD0000
+;highlight.comment = #FF9900
+;highlight.keyword = #007700
+;highlight.bg      = #FFFFFF
+;highlight.default = #0000BB
+;highlight.html    = #000000
+; Misc
+; Decides whether PHP may expose the fact that it is installed on the server
+; (e.g. by adding its signature to the Web server header).  It is no security
+; threat in any way, but it makes it possible to determine whether you use PHP
+; on your server or not.
+expose_php = Off
+; Resource Limits ;
+max_execution_time = 180    ; Maximum execution time of each script, in seconds
+max_input_time = 60        ; Maximum amount of time each script may spend parsing request data
+memory_limit = 256M         ; Maximum amount of memory a script may consume
+; Error handling and logging ;
+; error_reporting is a bit-field.  Or each number up to get desired error
+; reporting level
+; E_ALL             - All errors and warnings (doesn't include E_STRICT)
+; E_ERROR           - fatal run-time errors
+; E_WARNING         - run-time warnings (non-fatal errors)
+; E_PARSE           - compile-time parse errors
+; E_NOTICE          - run-time notices (these are warnings which often result
+;                     from a bug in your code, but it's possible that it was
+;                     intentional (e.g., using an uninitialized variable and
+;                     relying on the fact it's automatically initialized to an
+;                     empty string)
+; E_STRICT          - run-time notices, enable to have PHP suggest changes
+;                     to your code which will ensure the best interoperability
+;                     and forward compatibility of your code
+; E_CORE_ERROR      - fatal errors that occur during PHP's initial startup
+; E_CORE_WARNING    - warnings (non-fatal errors) that occur during PHP's
+;                     initial startup
+; E_COMPILE_ERROR   - fatal compile-time errors
+; E_COMPILE_WARNING - compile-time warnings (non-fatal errors)
+; E_USER_ERROR      - user-generated error message
+; E_USER_WARNING    - user-generated warning message
+; E_USER_NOTICE     - user-generated notice message
+; Examples:
+;   - Show all errors, except for notices and coding standards warnings
+;error_reporting = E_ALL & ~E_NOTICE & ~E_STRICT
+;   - Show only errors
+;error_reporting = E_COMPILE_ERROR|E_ERROR|E_CORE_ERROR
+error_reporting  = E_ALL
+; Print out errors (as a part of the output).  For production web sites,
+; you're strongly encouraged to turn this feature off, and use error logging
+; instead (see below).  Keeping display_errors enabled on a production web site
+; may reveal security information to end users, such as file paths on your Web
+; server, your database schema or other information.
+display_errors = Off
+; Even when display_errors is on, errors that occur during PHP's startup
+; sequence are not displayed.  It's strongly recommended to keep
+; display_startup_errors off, except for when debugging.
+display_startup_errors = Off
+; Log errors into a log file (server-specific log, stderr, or error_log (below))
+; As stated above, you're strongly advised to use error logging in place of
+; error displaying on production web sites.
+log_errors = On
+; Set maximum length of log_errors. In error_log information about the source is
+; added. The default is 1024 and 0 allows to not apply any maximum length at all.
+log_errors_max_len = 1024
+; Do not log repeated messages. Repeated errors must occur in same file on same
+; line until ignore_repeated_source is set true.
+ignore_repeated_errors = Off
+; Ignore source of message when ignoring repeated messages. When this setting
+; is On you will not log errors with repeated messages from different files or
+; sourcelines.
+ignore_repeated_source = Off
+; If this parameter is set to Off, then memory leaks will not be shown (on
+; stdout or in the log). This has only effect in a debug compile, and if
+; error reporting includes E_WARNING in the allowed list
+report_memleaks = On
+; Store the last error/warning message in $php_errormsg (boolean).
+track_errors = Off
+; Disable the inclusion of HTML tags in error messages.
+; Note: Never use this feature for production boxes.
+;html_errors = Off
+; If html_errors is set On PHP produces clickable error messages that direct
+; to a page describing the error or function causing the error in detail.
+; You can download a copy of the PHP manual from http://www.php.net/docs.php
+; and change docref_root to the base URL of your local copy including the
+; leading '/'. You must also specify the file extension being used including
+; the dot.
+;docref_root = "/phpmanual/"
+;docref_ext = .html
+; String to output before an error message.
+;error_prepend_string = "<font color=ff0000>"
+; String to output after an error message.
+;error_append_string = "</font>"
+; Log errors to specified file.
+;error_log = filename
+; Log errors to syslog (Event Log on NT, not valid in Windows 95).
+;error_log = syslog
+; Data Handling ;
+; Note - track_vars is ALWAYS enabled as of PHP 4.0.3
+; The separator used in PHP generated URLs to separate arguments.
+; Default is "&".
+;arg_separator.output = "&amp;"
+; List of separator(s) used by PHP to parse input URLs into variables.
+; Default is "&".
+; NOTE: Every character in this directive is considered as separator!
+;arg_separator.input = ";&"
+; This directive describes the order in which PHP registers GET, POST, Cookie,
+; Environment and Built-in variables (G, P, C, E & S respectively, often
+; referred to as EGPCS or GPC).  Registration is done from left to right, newer
+; values override older values.
+variables_order = "GPCS"
+; Whether or not to register the EGPCS variables as global variables.  You may
+; want to turn this off if you don't want to clutter your scripts' global scope
+; with user data.  This makes most sense when coupled with track_vars - in which
+; case you can access all of the GPC variables through the $HTTP_*_VARS[],
+; variables.
+; You should do your best to write your scripts so that they do not require
+; register_globals to be on;  Using form variables as globals can easily lead
+; to possible security problems, if the code is not very well thought of.
+register_globals = Off
+; Whether or not to register the old-style input arrays, HTTP_GET_VARS
+; and friends.  If you're not using them, it's recommended to turn them off,
+; for performance reasons.
+register_long_arrays = Off
+; This directive tells PHP whether to declare the argv&argc variables (that
+; would contain the GET information).  If you don't use these variables, you
+; should turn it off for increased performance.
+register_argc_argv = Off
+; When enabled, the SERVER and ENV variables are created when they're first
+; used (Just In Time) instead of when the script starts. If these variables
+; are not used within a script, having this directive on will result in a
+; performance gain. The PHP directives register_globals, register_long_arrays,
+; and register_argc_argv must be disabled for this directive to have any affect.
+auto_globals_jit = On
+; Maximum size of POST data that PHP will accept.
+post_max_size = 64M
+; Magic quotes
+; Magic quotes for incoming GET/POST/Cookie data.
+magic_quotes_gpc = Off
+; Magic quotes for runtime-generated data, e.g. data from SQL, from exec(), etc.
+magic_quotes_runtime = Off
+; Use Sybase-style magic quotes (escape ' with '' instead of \').
+magic_quotes_sybase = Off
+; Automatically add files before or after any PHP document.
+auto_prepend_file =
+auto_append_file =
+; As of 4.0b4, PHP always outputs a character encoding by default in
+; the Content-type: header.  To disable sending of the charset, simply
+; set it to be empty.
+; PHP's built-in default is text/html
+default_mimetype = "text/html"
+;default_charset = "iso-8859-1"
+; Always populate the $HTTP_RAW_POST_DATA variable.
+;always_populate_raw_post_data = On
+; Paths and Directories ;
+; UNIX: "/path1:/path2"
+;include_path = ".:/php/includes"
+; Windows: "\path1;\path2"
+;include_path = ".;c:\php\includes"
+; The root of the PHP pages, used only if nonempty.
+; if PHP was not compiled with FORCE_REDIRECT, you SHOULD set doc_root
+; if you are running php as a CGI under any web server (other than IIS)
+; see documentation for security issues.  The alternate is to use the
+; cgi.force_redirect configuration below
+doc_root =
+; The directory under which PHP opens the script using /~username used only
+; if nonempty.
+user_dir =
+; Directory in which the loadable extensions (modules) reside.
+extension_dir = "%MG_WEB_PHP%ext"
+; Whether or not to enable the dl() function.  The dl() function does NOT work
+; properly in multithreaded servers, such as IIS or Zeus, and is automatically
+; disabled on them.
+enable_dl = On
+; cgi.force_redirect is necessary to provide security running PHP as a CGI under
+; most web servers.  Left undefined, PHP turns this on by default.  You can
+; turn it off here AT YOUR OWN RISK
+; **You CAN safely turn this off for IIS, in fact, you MUST.**
+; cgi.force_redirect = 1
+; if cgi.nph is enabled it will force cgi to always sent Status: 200 with
+; every request.
+; cgi.nph = 1
+; if cgi.force_redirect is turned on, and you are not running under Apache or Netscape
+; (iPlanet) web servers, you MAY need to set an environment variable name that PHP
+; will look for to know it is OK to continue execution.  Setting this variable MAY
+; cause security issues, KNOW WHAT YOU ARE DOING FIRST.
+; cgi.redirect_status_env = ;
+; FastCGI under IIS (on WINNT based OS) supports the ability to impersonate
+; security tokens of the calling client.  This allows IIS to define the
+; security context that the request runs under.  mod_fastcgi under Apache
+; does not currently support this feature (03/17/2002)
+; Set to 1 if running under IIS.  Default is zero.
+; fastcgi.impersonate = 1;
+; Disable logging through FastCGI connection
+; fastcgi.log = 0
+; cgi.rfc2616_headers configuration option tells PHP what type of headers to
+; use when sending HTTP response code. If it's set 0 PHP sends Status: header that
+; is supported by Apache. When this option is set to 1 PHP will send
+; RFC2616 compliant header.
+; Default is zero.
+;cgi.rfc2616_headers = 0
+; File Uploads ;
+; Whether to allow HTTP file uploads.
+file_uploads = On
+; Temporary directory for HTTP uploaded files (will use system default if not
+; specified).
+;upload_tmp_dir =
+; Maximum allowed size for uploaded files.
+upload_max_filesize = 2M
+; Fopen wrappers ;
+; Whether to allow the treatment of URLs (like http:// or ftp://) as files.
+allow_url_fopen = On
+; Define the anonymous ftp password (your email address)
+;from="john at doe.com"
+; Define the User-Agent string
+; user_agent="PHP"
+; Default timeout for socket based streams (seconds)
+default_socket_timeout = 60
+; If your scripts have to deal with files from Macintosh systems,
+; or you are running on a Mac and need to deal with files from
+; unix or win32 systems, setting this flag will cause PHP to
+; automatically detect the EOL character in those files so that
+; fgets() and file() will work regardless of the source of the file.
+; auto_detect_line_endings = Off
+; Dynamic Extensions ;
+; If you wish to have an extension loaded automatically, use the following
+; syntax:
+;   extension=modulename.extension
+; For example, on Windows:
+;   extension=msql.dll
+; ... or under UNIX:
+;   extension=msql.so
+; Note that it should be the name of the module only; no directory information
+; needs to go here.  Specify the location of the extension with the
+; extension_dir directive above.
+;Windows Extensions
+;Note that ODBC support is built in, so no dll is needed for it.
+extension=php_mbstring.dll
+;extension=php_bz2.dll
+;extension=php_cpdf.dll
+;extension=php_curl.dll
+;extension=php_dba.dll
+;extension=php_dbase.dll
+;extension=php_dbx.dll
+;extension=php_exif.dll
+;extension=php_fdf.dll
+;extension=php_filepro.dll
+;extension=php_gd2.dll
+;extension=php_gettext.dll
+;extension=php_ifx.dll
+;extension=php_iisfunc.dll
+;extension=php_imap.dll
+;extension=php_interbase.dll
+;extension=php_java.dll
+;extension=php_ldap.dll
+;extension=php_mcrypt.dll
+;extension=php_mhash.dll
+;extension=php_mime_magic.dll
+;extension=php_ming.dll
+;extension=php_mssql.dll
+;extension=php_msql.dll
+;extension=php_mysql.dll
+;extension=php_oci8.dll
+;extension=php_openssl.dll
+;extension=php_oracle.dll
+;extension=php_pdf.dll
+;extension=php_pgsql.dll
+;extension=php_shmop.dll
+;extension=php_snmp.dll
+;extension=php_sockets.dll
+;extension=php_sybase_ct.dll
+;extension=php_tidy.dll
+;extension=php_w32api.dll
+;extension=php_xmlrpc.dll
+extension=php_xsl.dll
+;extension=php_yaz.dll
+;extension=php_zip.dll
+extension=php_MapGuideApiEnvConfig.dll
+extension=php_MapGuideApi.dll
+; Module Settings ;
+[Syslog]
+; Whether or not to define the various syslog variables (e.g. $LOG_PID,
+; $LOG_CRON, etc.).  Turning it off is a good idea performance-wise.  In
+; runtime, you can define these variables by calling define_syslog_variables().
+define_syslog_variables  = Off
+[mail function]
+; For Win32 only.
+SMTP = localhost
+smtp_port = 25
+; For Win32 only.
+;sendmail_from = me at example.com
+; For Unix only.  You may supply arguments as well (default: "sendmail -t -i").
+;sendmail_path =
+; Force the addition of the specified parameters to be passed as extra parameters
+; to the sendmail binary. These parameters will always replace the value of
+; the 5th parameter to mail(), even in safe mode.
+;mail.force_extra_parameters =
+[SQL]
+sql.safe_mode = Off
+[ODBC]
+;odbc.default_db    =  Not yet implemented
+;odbc.default_user  =  Not yet implemented
+;odbc.default_pw    =  Not yet implemented
+; Allow or prevent persistent links.
+odbc.allow_persistent = On
+; Check that a connection is still valid before reuse.
+odbc.check_persistent = On
+; Maximum number of persistent links.  -1 means no limit.
+odbc.max_persistent = -1
+; Maximum number of links (persistent + non-persistent).  -1 means no limit.
+odbc.max_links = -1
+; Handling of LONG fields.  Returns number of bytes to variables.  0 means
+; passthru.
+odbc.defaultlrl = 4096
+; Handling of binary data.  0 means passthru, 1 return as is, 2 convert to char.
+; See the documentation on odbc_binmode and odbc_longreadlen for an explanation
+; of uodbc.defaultlrl and uodbc.defaultbinmode
+odbc.defaultbinmode = 1
+[MySQL]
+mysql.allow_persistent = On
+mysql.max_persistent = -1
+mysql.max_links = -1
+; Default port number for mysql_connect().  If unset, mysql_connect() will use
+; the $MYSQL_TCP_PORT or the mysql-tcp entry in /etc/services or the
+; compile-time value defined MYSQL_PORT (in that order).  Win32 will only look
+; at MYSQL_PORT.
+mysql.default_port =
+; Default socket name for local MySQL connects.  If empty, uses the built-in
+; MySQL defaults.
+mysql.default_socket =
+; Default host for mysql_connect() (doesn't apply in safe mode).
+mysql.default_host =
+; Default user for mysql_connect() (doesn't apply in safe mode).
+mysql.default_user =
+; Default password for mysql_connect() (doesn't apply in safe mode).
+; Note that this is generally a *bad* idea to store passwords in this file.
+; *Any* user with PHP access can run 'echo get_cfg_var("mysql.default_password")
+; and reveal this password!  And of course, any users with read access to this
+; file will be able to reveal the password as well.
+mysql.default_password =
+; Maximum time (in secondes) for connect timeout. -1 means no limit
+mysql.connect_timeout = 60
+; Trace mode. When trace_mode is active (=On), warnings for table/index scans and
+; SQL-Errors will be displayed.
+mysql.trace_mode = Off
+[MySQLI]
+; Maximum number of links.  -1 means no limit.
+mysqli.max_links = -1
+; Default port number for mysqli_connect().  If unset, mysqli_connect() will use
+; at MYSQL_PORT.
+mysqli.default_port = 3306
+; MySQL defaults.
+mysqli.default_socket =
+mysqli.default_host =
+mysqli.default_user =
+; Default password for mysqli_connect() (doesn't apply in safe mode).
+; *Any* user with PHP access can run 'echo get_cfg_var("mysqli.default_pw")
+mysqli.default_pw =
+; Allow or prevent reconnect
+mysqli.reconnect = Off
+[mSQL]
+msql.allow_persistent = On
+msql.max_persistent = -1
+; Maximum number of links (persistent+non persistent).  -1 means no limit.
+msql.max_links = -1
+[PostgresSQL]
+pgsql.allow_persistent = On
+; Detect broken persistent links always with pg_pconnect().
+; Auto reset feature requires a little overheads.
+pgsql.auto_reset_persistent = Off
+pgsql.max_persistent = -1
+pgsql.max_links = -1
+; Ignore PostgreSQL backends Notice message or not.
+; Notice message logging require a little overheads.
+pgsql.ignore_notice = 0
+; Log PostgreSQL backends Noitce message or not.
+; Unless pgsql.ignore_notice=0, module cannot log notice message.
+pgsql.log_notice = 0
+[Sybase]
+sybase.allow_persistent = On
+sybase.max_persistent = -1
+sybase.max_links = -1
+;sybase.interface_file = "/usr/sybase/interfaces"
+; Minimum error severity to display.
+sybase.min_error_severity = 10
+; Minimum message severity to display.
+sybase.min_message_severity = 10
+; Compatability mode with old versions of PHP 3.0.
+; If on, this will cause PHP to automatically assign types to results according
+; to their Sybase type, instead of treating them all as strings.  This
+; compatability mode will probably not stay around forever, so try applying
+; whatever necessary changes to your code, and turn it off.
+sybase.compatability_mode = Off
+[Sybase-CT]
+sybct.allow_persistent = On
+sybct.max_persistent = -1
+sybct.max_links = -1
+; Minimum server message severity to display.
+sybct.min_server_severity = 10
+; Minimum client message severity to display.
+sybct.min_client_severity = 10
+[dbx]
+; returned column names can be converted for compatibility reasons
+; possible values for dbx.colnames_case are
+; "unchanged" (default, if not set)
+; "lowercase"
+; "uppercase"
+; the recommended default is either upper- or lowercase, but
+; unchanged is currently set for backwards compatibility
+dbx.colnames_case = "lowercase"
+[bcmath]
+; Number of decimal digits for all bcmath functions.
+bcmath.scale = 0
+[browscap]
+;browscap = extra/browscap.ini
+[Informix]
+; Default host for ifx_connect() (doesn't apply in safe mode).
+ifx.default_host =
+; Default user for ifx_connect() (doesn't apply in safe mode).
+ifx.default_user =
+; Default password for ifx_connect() (doesn't apply in safe mode).
+ifx.default_password =
+ifx.allow_persistent = On
+ifx.max_persistent = -1
+ifx.max_links = -1
+; If on, select statements return the contents of a text blob instead of its id.
+ifx.textasvarchar = 0
+; If on, select statements return the contents of a byte blob instead of its id.
+ifx.byteasvarchar = 0
+; Trailing blanks are stripped from fixed-length char columns.  May help the
+; life of Informix SE users.
+ifx.charasvarchar = 0
+; If on, the contents of text and byte blobs are dumped to a file instead of
+; keeping them in memory.
+ifx.blobinfile = 0
+; NULL's are returned as empty strings, unless this is set to 1.  In that case,
+; NULL's are returned as string 'NULL'.
+ifx.nullformat = 0
+[Session]
+; Handler used to store/retrieve data.
+session.save_handler = files
+; Argument passed to save_handler.  In the case of files, this is the path
+; where data files are stored. Note: Windows users have to change this
+; variable in order to use PHP's session functions.
+; As of PHP 4.0.1, you can define the path as:
+;     session.save_path = "N;/path"
+; where N is an integer.  Instead of storing all the session files in
+; /path, what this will do is use subdirectories N-levels deep, and
+; store the session data in those directories.  This is useful if you
+; or your OS have problems with lots of files in one directory, and is
+; a more efficient layout for servers that handle lots of sessions.
+; NOTE 1: PHP will not create this directory structure automatically.
+;         You can use the script in the ext/session dir for that purpose.
+; NOTE 2: See the section on garbage collection below if you choose to
+;         use subdirectories for session storage
+; The file storage module creates files using mode 600 by default.
+; You can change that by using
+;     session.save_path = "N;MODE;/path"
+; where MODE is the octal representation of the mode. Note that this
+; does not overwrite the process's umask.
+;session.save_path = "/tmp"
+session.save_path = "%MG_WEB_TEMP%"
+; Whether to use cookies.
+session.use_cookies = 1
+; This option enables administrators to make their users invulnerable to
+; attacks which involve passing session ids in URLs; defaults to 0.
+; session.use_only_cookies = 1
+; Name of the session (used as cookie name).
+session.name = PHPSESSID
+; Initialize session on request startup.
+session.auto_start = 0
+; Lifetime in seconds of cookie or, if 0, until browser is restarted.
+session.cookie_lifetime = 0
+; The path for which the cookie is valid.
+session.cookie_path = /
+; The domain for which the cookie is valid.
+session.cookie_domain =
+; Handler used to serialize data.  php is the standard serializer of PHP.
+session.serialize_handler = php
+; Define the probability that the 'garbage collection' process is started
+; on every session initialization.
+; The probability is calculated by using gc_probability/gc_divisor,
+; e.g. 1/100 means there is a 1% chance that the GC process starts
+; on each request.
+session.gc_probability = 1
+session.gc_divisor     = 1000
+; After this number of seconds, stored data will be seen as 'garbage' and
+; cleaned up by the garbage collection process.
+session.gc_maxlifetime = 1440
+; NOTE: If you are using the subdirectory option for storing session files
+;       (see session.save_path above), then garbage collection does *not*
+;       happen automatically.  You will need to do your own garbage
+;       collection through a shell script, cron entry, or some other method.
+;       For example, the following script would is the equivalent of
+;       setting session.gc_maxlifetime to 1440 (1440 seconds = 24 minutes):
+;          cd /path/to/sessions; find -cmin +24 | xargs rm
+; PHP 4.2 and less have an undocumented feature/bug that allows you to
+; to initialize a session variable in the global scope, albeit register_globals
+; is disabled.  PHP 4.3 and later will warn you, if this feature is used.
+; You can disable the feature and the warning separately. At this time,
+; the warning is only displayed, if bug_compat_42 is enabled.
+session.bug_compat_42 = 0
+session.bug_compat_warn = 1
+; Check HTTP Referer to invalidate externally stored URLs containing ids.
+; HTTP_REFERER has to contain this substring for the session to be
+; considered as valid.
+session.referer_check =
+; How many bytes to read from the file.
+session.entropy_length = 0
+; Specified here to create the session id.
+session.entropy_file =
+;session.entropy_length = 16
+;session.entropy_file = /dev/urandom
+; Set to {nocache,private,public,} to determine HTTP caching aspects
+; or leave this empty to avoid sending anti-caching headers.
+session.cache_limiter = nocache
+; Document expires after n minutes.
+session.cache_expire = 180
+; trans sid support is disabled by default.
+; Use of trans sid may risk your users security.
+; Use this option with caution.
+; - User may send URL contains active session ID
+;   to other person via. email/irc/etc.
+; - URL that contains active session ID may be stored
+;   in publically accessible computer.
+; - User may access your site with the same session ID
+;   always using URL stored in browser's history or bookmarks.
+session.use_trans_sid = 0
+; Select a hash function
+; 0: MD5   (128 bits)
+; 1: SHA-1 (160 bits)
+session.hash_function = 0
+; Define how many bits are stored in each character when converting
+; the binary hash data to something readable.
+; 4 bits: 0-9, a-f
+; 5 bits: 0-9, a-v
+; 6 bits: 0-9, a-z, A-Z, "-", ","
+session.hash_bits_per_character = 5
+; The URL rewriter will look for URLs in a defined set of HTML tags.
+; form/fieldset are special; if you include them here, the rewriter will
+; add a hidden <input> field with the info which is otherwise appended
+; to URLs.  If you want XHTML conformity, remove the form entry.
+; Note that all valid entries require a "=", even if no value follows.
+url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=fakeentry"
+[MSSQL]
+mssql.allow_persistent = On
+mssql.max_persistent = -1
+mssql.max_links = -1
+mssql.min_error_severity = 10
+mssql.min_message_severity = 10
+mssql.compatability_mode = Off
+; Connect timeout
+;mssql.connect_timeout = 5
+; Query timeout
+;mssql.timeout = 60
+; Valid range 0 - 2147483647.  Default = 4096.
+;mssql.textlimit = 4096
+;mssql.textsize = 4096
+; Limits the number of records in each batch.  0 = all records in one batch.
+;mssql.batchsize = 0
+; Specify how datetime and datetim4 columns are returned
+; On => Returns data converted to SQL server settings
+; Off => Returns values as YYYY-MM-DD hh:mm:ss
+;mssql.datetimeconvert = On
+; Use NT authentication when connecting to the server
+mssql.secure_connection = Off
+; Specify max number of processes. Default = 25
+;mssql.max_procs = 25
+[Assertion]
+; Assert(expr); active by default.
+;assert.active = On
+; Issue a PHP warning for each failed assertion.
+;assert.warning = On
+; Don't bail out by default.
+;assert.bail = Off
+; User-function to be called if an assertion fails.
+;assert.callback = 0
+; Eval the expression with current error_reporting().  Set to true if you want
+; error_reporting(0) around the eval().
+;assert.quiet_eval = 0
+[Ingres II]
+ingres.allow_persistent = On
+ingres.max_persistent = -1
+; Maximum number of links, including persistents.  -1 means no limit.
+ingres.max_links = -1
+; Default database (format: [node_id::]dbname[/srv_class]).
+ingres.default_database =
+; Default user.
+ingres.default_user =
+; Default password.
+ingres.default_password =
+[Verisign Payflow Pro]
+; Default Payflow Pro server.
+pfpro.defaulthost = "test-payflow.verisign.com"
+; Default port to connect to.
+pfpro.defaultport = 443
+; Default timeout in seconds.
+pfpro.defaulttimeout = 30
+; Default proxy IP address (if required).
+;pfpro.proxyaddress =
+; Default proxy port.
+;pfpro.proxyport =
+; Default proxy logon.
+;pfpro.proxylogon =
+; Default proxy password.
+;pfpro.proxypassword =
+[com]
+; path to a file containing GUIDs, IIDs or filenames of files with TypeLibs
+;com.typelib_file =
+; allow Distributed-COM calls
+;com.allow_dcom = true
+; autoregister constants of a components typlib on com_load()
+;com.autoregister_typelib = true
+; register constants casesensitive
+;com.autoregister_casesensitive = false
+; show warnings on duplicate constat registrations
+;com.autoregister_verbose = true
+[mbstring]
+; language for internal character representation.
+mbstring.language = UTF-8
+; internal/script encoding.
+; Some encoding cannot work as internal encoding.
+; (e.g. SJIS, BIG5, ISO-2022-*)
+mbstring.internal_encoding = UTF-8
+; http input encoding.
+mbstring.http_input = UTF-8
+; http output encoding. mb_output_handler must be
+; registered as output buffer to function
+mbstring.http_output = pass
+; enable automatic encoding translation accoding to
+; mbstring.internal_encoding setting. Input chars are
+; converted to internal encoding by setting this to On.
+; Note: Do _not_ use automatic encoding translation for
+;       portable libs/applications.
+mbstring.encoding_translation = Off
+; automatic encoding detection order.
+; auto means
+mbstring.detect_order = auto
+; substitute_character used when character cannot be converted
+; one from another
+;mbstring.substitute_character = none;
+; overload(replace) single byte functions by mbstring functions.
+; mail(), ereg(), etc are overloaded by mb_send_mail(), mb_ereg(),
+; etc. Possible values are 0,1,2,4 or combination of them.
+; For example, 7 for overload everything.
+; 0: No overload
+; 1: Overload mail() function
+; 2: Overload str*() functions
+; 4: Overload ereg*() functions
+mbstring.func_overload = 0
+[FrontBase]
+;fbsql.allow_persistent = On
+;fbsql.autocommit = On
+;fbsql.default_database =
+;fbsql.default_database_password =
+;fbsql.default_host =
+;fbsql.default_password =
+;fbsql.default_user = "_SYSTEM"
+;fbsql.generate_warnings = Off
+;fbsql.max_connections = 128
+;fbsql.max_links = 128
+;fbsql.max_persistent = -1
+;fbsql.max_results = 128
+;fbsql.batchSize = 1000
+[exif]
+; Exif UNICODE user comments are handled as UCS-2BE/UCS-2LE and JIS as JIS.
+; With mbstring support this will automatically be converted into the encoding
+; given by corresponding encode setting. When empty mbstring.internal_encoding
+; is used. For the decode settings you can distinguish between motorola and
+; intel byte order. A decode setting cannot be empty.
+;exif.encode_unicode = ISO-8859-15
+;exif.decode_unicode_motorola = UCS-2BE
+;exif.decode_unicode_intel    = UCS-2LE
+;exif.encode_jis =
+;exif.decode_jis_motorola = JIS
+;exif.decode_jis_intel    = JIS
+[Tidy]
+; The path to a default tidy configuration file to use when using tidy
+;tidy.default_config = /usr/local/lib/php/default.tcfg
+; Should tidy clean and repair output automatically?
+; WARNING: Do not use this option if you are generating non-html content
+; such as dynamic images
+tidy.clean_output = Off
+[soap]
+; Enables or disables WSDL caching feature.
+soap.wsdl_cache_enabled=1
+; Sets the directory name where SOAP extension will put cache files.
+soap.wsdl_cache_dir="/tmp"
+; (time to live) Sets the number of second while cached file will be used
+; instead of original one.
+soap.wsdl_cache_ttl=86400
+; Local Variables:
+; tab-width: 4
+; End:
Added: trunk/Installer/Support/Web/x64/Php/php.ini-development
--- trunk/Installer/Support/Web/x64/Php/php.ini-development	                        (rev 0)
+++ trunk/Installer/Support/Web/x64/Php/php.ini-development	2010-06-26 14:06:52 UTC (rev 4976)
@@ -0,0 +1,1892 @@
+[PHP]
+; About php.ini   ;
+; PHP's initialization file, generally called php.ini, is responsible for
+; configuring many of the aspects of PHP's behavior.
+; PHP attempts to find and load this configuration from a number of locations.
+; The following is a summary of its search order:
+; 1. SAPI module specific location.
+; 2. The PHPRC environment variable. (As of PHP 5.2.0)
+; 3. A number of predefined registry keys on Windows (As of PHP 5.2.0)
+; 4. Current working directory (except CLI)
+; 5. The web server's directory (for SAPI modules), or directory of PHP
+; (otherwise in Windows)
+; 6. The directory from the --with-config-file-path compile time option, or the
+; Windows directory (C:\windows or C:\winnt)
+; See the PHP docs for more specific information.
+; http://php.net/configuration.file
+; Directives following the section heading [PATH=/www/mysite] only
+; apply to PHP files in the /www/mysite directory.  Directives
+; following the section heading [HOST=www.example.com] only apply to
+; PHP files served from www.example.com.  Directives set in these
+; special sections cannot be overridden by user-defined INI files or
+; at runtime. Currently, [PATH=] and [HOST=] sections only work under
+; CGI/FastCGI.
+; http://php.net/ini.sections
+; Directives are variables used to configure PHP or PHP extensions.
+; There is no name validation.  If PHP can't find an expected
+; directive because it is not set or is mistyped, a default value will be used.
+; (e.g. E_ALL & ~E_NOTICE), a quoted string ("bar"), or a reference to a
+; previously set variable or directive (e.g. ${foo})
+; |  bitwise OR
+; ^  bitwise XOR
+; &  bitwise AND
+; ~  bitwise NOT
+; !  boolean NOT
+;  foo = None    ; sets foo to an empty string
+;  foo = "None"  ; sets foo to the string 'None'
+; PHP comes packaged with two INI files. One that is recommended to be used
+; in production environments and one that is recommended to be used in
+; development environments.
+; php.ini-production contains settings which hold security, performance and
+; best practices at its core. But please be aware, these settings may break
+; compatibility with older or less security conscience applications. We
+; recommending using the production ini in production and testing environments.
+; php.ini-development is very similar to its production variant, except it's
+; much more verbose when it comes to errors. We recommending using the
+; development version only in development environments as errors shown to
+; application users can inadvertently leak otherwise secure information.
+; Quick Reference ;
+; The following are all the settings which are different in either the production
+; or development versions of the INIs with respect to PHP's default behavior.
+; Please see the actual settings later in the document for more details as to why
+; we recommend these changes in PHP's behavior.
+; allow_call_time_pass_reference
+;   Default Value: On
+;   Development Value: Off
+;   Production Value: Off
+; display_errors
+;   Development Value: On
+;   Default Value: Off
+; error_reporting
+;   Default Value: E_ALL & ~E_NOTICE
+;   Development Value: E_ALL | E_STRICT
+;   Production Value: E_ALL & ~E_DEPRECATED
+; html_errors
+;   Production value: Off
+; log_errors
+;   Production Value: On
+; magic_quotes_gpc
+; max_input_time
+;   Default Value: -1 (Unlimited)
+;   Development Value: 60 (60 seconds)
+;   Production Value: 60 (60 seconds)
+; output_buffering
+;   Development Value: 4096
+;   Production Value: 4096
+; register_argc_argv
+; register_long_arrays
+; request_order
+;   Default Value: None
+;   Development Value: "GP"
+;   Production Value: "GP"
+; session.bug_compat_42
+; session.bug_compat_warn
+; session.gc_divisor
+;   Default Value: 100
+;   Development Value: 1000
+;   Production Value: 1000
+; session.hash_bits_per_character
+;   Default Value: 4
+;   Development Value: 5
+;   Production Value: 5
+; short_open_tag
+; track_errors
+; url_rewriter.tags
+;   Default Value: "a=href,area=href,frame=src,form=,fieldset="
+;   Development Value: "a=href,area=href,frame=src,input=src,form=fakeentry"
+;   Production Value: "a=href,area=href,frame=src,input=src,form=fakeentry"
+; variables_order
+;   Default Value: "EGPCS"
+;   Development Value: "GPCS"
+;   Production Value: "GPCS"
+; php.ini Options  ;
+; Name for user-defined php.ini (.htaccess) files. Default is ".user.ini"
+;user_ini.filename = ".user.ini"
+; To disable this feature set this option to empty value
+; TTL for user-defined php.ini files (time-to-live) in seconds. Default is 300 seconds (5 minutes)
+;user_ini.cache_ttl = 300
+; http://php.net/engine
+engine = On
+; This directive determines whether or not PHP will recognize code between
+; <? and ?> tags as PHP source which should be processed as such. It's been
+; recommended for several years that you not use the short tag "short cut" and
+; instead to use the full <?php and ?> tag combination. With the wide spread use
+; of XML and use of these tags by other languages, the server can become easily
+; confused and end up parsing the wrong code in the wrong context. But because
+; this short cut has been a feature for such a long time, it's currently still
+; supported for backwards compatibility, but we recommend you don't use them.
+; http://php.net/short-open-tag
+short_open_tag = Off
+; http://php.net/asp-tags
+asp_tags = Off
+; http://php.net/precision
+precision = 14
+; http://php.net/y2k-compliance
+; Output buffering is a mechanism for controlling how much output data
+; (excluding headers and cookies) PHP should keep internally before pushing that
+; data to the client. If your application's output exceeds this setting, PHP
+; will send that data in chunks of roughly the size you specify.
+; Turning on this setting and managing its maximum buffer size can yield some
+; interesting side-effects depending on your application and web server.
+; You may be able to send headers and cookies after you've already sent output
+; through print or echo. You also may see performance benefits if your server is
+; emitting less packets due to buffered output versus PHP streaming the output
+; as it gets it. On production servers, 4096 bytes is a good setting for performance
+; reasons.
+; Note: Output buffering can also be controlled via Output Buffering Control
+;   functions.
+; Possible Values:
+;   On = Enabled and buffer is unlimited. (Use with caution)
+;   Off = Disabled
+;   Integer = Enables the buffer and sets its maximum size in bytes.
+; Note: This directive is hardcoded to Off for the CLI SAPI
+; http://php.net/output-buffering
+;   is doing.
+; http://php.net/output-handler
+;output_handler =
+; http://php.net/zlib.output-compression
+; http://php.net/zlib.output-compression-level
+;zlib.output_compression_level = -1
+; http://php.net/zlib.output-handler
+; http://php.net/implicit-flush
+; Note: This directive is hardcoded to On for the CLI SAPI
+; which should be instantiated. A warning appears if the specified function is
+; not defined, or if the function doesn't include/implement the missing class.
+unserialize_callback_func =
+; This directive allows you to enable and disable warnings which PHP will issue
+; if you pass a value by reference at function call time. Passing values by
+; reference at function call time is a deprecated feature which will be removed
+; from PHP at some point in the near future. The acceptable method for passing a
+; value by reference to a function is by declaring the reference in the functions
+; definition, not at call time. This directive does not disable this feature, it
+; only determines whether PHP will warn you about it or not. These warnings
+; should enabled in development environments only.
+; Default Value: On (Suppress warnings)
+; Development Value: Off (Issue warnings)
+; Production Value: Off (Issue warnings)
+; http://php.net/allow-call-time-pass-reference
+; Safe Mode
+; http://php.net/safe-mode
+safe_mode = Off
+; http://php.net/safe-mode-gid
+; http://php.net/safe-mode-include-dir
+; http://php.net/safe-mode-exec-dir
+; http://php.net/safe-mode-allowed-env-vars
+; http://php.net/safe-mode-protected-env-vars
+; http://php.net/open-basedir
+;open_basedir =
+; http://php.net/disable-functions
+; http://php.net/disable-classes
+disable_classes =
+; http://php.net/syntax-highlighting
+; If enabled, the request will be allowed to complete even if the user aborts
+; the request. Consider enabling it if executing long requests, which may end up
+; being interrupted by the user or a browser timing out. PHP's default behavior
+; is to disable this feature.
+; http://php.net/ignore-user-abort
+;ignore_user_abort = On
+; Determines the size of the realpath cache to be used by PHP. This value should
+; be increased on systems where PHP opens many files to reflect the quantity of
+; the file operations performed.
+; http://php.net/realpath-cache-size
+;realpath_cache_size = 16k
+; Duration of time, in seconds for which to cache realpath information for a given
+; file or directory. For systems with rarely changing files, consider increasing this
+; value.
+; http://php.net/realpath-cache-ttl
+;realpath_cache_ttl = 120
+; Miscellaneous ;
+; http://php.net/expose-php
+expose_php = On
+; Maximum execution time of each script, in seconds
+; http://php.net/max-execution-time
+; Note: This directive is hardcoded to 0 for the CLI SAPI
+max_execution_time = 30
+; Maximum amount of time each script may spend parsing request data. It's a good
+; idea to limit this time on productions servers in order to eliminate unexpectedly
+; long running scripts.
+; Note: This directive is hardcoded to -1 for the CLI SAPI
+; http://php.net/max-input-time
+; Maximum input variable nesting level
+; http://php.net/max-input-nesting-level
+;max_input_nesting_level = 64
+; Maximum amount of memory a script may consume (128MB)
+; http://php.net/memory-limit
+memory_limit = 128M
+; This directive informs PHP of which errors, warnings and notices you would like
+; it to take action for. The recommended way of setting values for this
+; directive is through the use of the error level constants and bitwise
+; operators. The error level constants are below here for convenience as well as
+; some common settings and their meanings.
+; By default, PHP is set to take action on all errors, notices and warnings EXCEPT
+; those related to E_NOTICE and E_STRICT, which together cover best practices and
+; recommended coding standards in PHP. For performance reasons, this is the
+; recommend error reporting setting. Your production server shouldn't be wasting
+; resources complaining about best practices and coding standards. That's what
+; development servers and development settings are for.
+; Note: The php.ini-development file has this setting as E_ALL | E_STRICT. This
+; means it pretty much reports everything which is exactly what you want during
+; development and early testing.
+; Error Level Constants:
+; E_ALL             - All errors and warnings (includes E_STRICT as of PHP 6.0.0)
+; E_RECOVERABLE_ERROR  - almost fatal run-time errors
+;                     empty string)
+;                     initial startup
+; E_DEPRECATED      - warn about code that will not work in future versions
+;                     of PHP
+; E_USER_DEPRECATED - user-generated deprecation warnings
+; Common Values:
+;   E_ALL & ~E_NOTICE  (Show all errors, except for notices and coding standards warnings.)
+;   E_ALL & ~E_NOTICE | E_STRICT  (Show all errors, except for notices)
+;   E_COMPILE_ERROR|E_RECOVERABLE_ERROR|E_ERROR|E_CORE_ERROR  (Show only errors)
+;   E_ALL | E_STRICT  (Show all errors, warnings and notices including coding standards.)
+; http://php.net/error-reporting
+error_reporting = E_ALL | E_STRICT
+; This directive controls whether or not and where PHP will output errors,
+; notices and warnings too. Error output is very useful during development, but
+; it could be very dangerous in production environments. Depending on the code
+; which is triggering the error, sensitive information could potentially leak
+; out of your application such as database usernames and passwords or worse.
+; It's recommended that errors be logged on production servers rather than
+; having the errors sent to STDOUT.
+; Possible Values:
+;   Off = Do not display any errors
+;   stderr = Display errors to STDERR (affects only CGI/CLI binaries!)
+;   On or stdout = Display errors to STDOUT
+; http://php.net/display-errors
+display_errors = On
+; The display of errors which occur during PHP's startup sequence are handled
+; separately from display_errors. PHP's default behavior is to suppress those
+; errors from clients. Turning the display of startup errors on can be useful in
+; debugging configuration problems. But, it's strongly recommended that you
+; leave this setting off on production servers.
+; http://php.net/display-startup-errors
+display_startup_errors = On
+; Besides displaying errors, PHP can also log errors to locations such as a
+; server-specific log, STDERR, or a location specified by the error_log
+; directive found below. While errors should not be displayed on productions
+; servers they should still be monitored and logging is a great way to do that.
+; http://php.net/log-errors
+log_errors = On
+; http://php.net/log-errors-max-len
+; line unless ignore_repeated_source is set true.
+; http://php.net/ignore-repeated-errors
+; source lines.
+; http://php.net/ignore-repeated-source
+; http://php.net/report-memleaks
+; This setting is on by default.
+;report_zend_debug = 0
+; Store the last error/warning message in $php_errormsg (boolean). Setting this value
+; to On can assist in debugging and is appropriate for development servers. It should
+; however be disabled on production servers.
+; http://php.net/track-errors
+track_errors = On
+; Turn off normal error reporting and emit XML-RPC error XML
+; http://php.net/xmlrpc-errors
+;xmlrpc_errors = 0
+; An XML-RPC faultCode
+;xmlrpc_error_number = 0
+; When PHP displays or logs an error, it has the capability of inserting html
+; links to documentation related to that error. This directive controls whether
+; those HTML links appear in error messages or not. For performance and security
+; reasons, it's recommended you disable this on production servers.
+; http://php.net/html-errors
+html_errors = On
+; You can download a copy of the PHP manual from http://php.net/docs
+; the dot. PHP's default behavior is to leave these settings empty.
+; http://php.net/docref-root
+; Examples
+; http://php.net/docref-ext
+; String to output before an error message. PHP's default behavior is to leave
+; this setting blank.
+; http://php.net/error-prepend-string
+; Example:
+;error_prepend_string = "<font color=#ff0000>"
+; String to output after an error message. PHP's default behavior is to leave
+; http://php.net/error-append-string
+; Example:
+; Log errors to specified file. PHP's default behavior is to leave this value
+; empty.
+; http://php.net/error-log
+; Example:
+;error_log = php_errors.log
+; Data Handling ;
+; PHP's default setting is "&".
+; http://php.net/arg-separator.output
+; Example:
+; http://php.net/arg-separator.input
+; Example:
+; This directive determines which super global arrays are registered when PHP
+; starts up. If the register_globals directive is enabled, it also determines
+; what order variables are populated into the global space. G,P,C,E & S are
+; abbreviations for the following respective super globals: GET, POST, COOKIE,
+; ENV and SERVER. There is a performance penalty paid for the registration of
+; these arrays and because ENV is not as commonly used as the others, ENV is
+; is not recommended on productions servers. You can still get access to
+; the environment variables through getenv() should you need to.
+; Production Value: "GPCS";
+; http://php.net/variables-order
+; This directive determines which super global data (G,P,C,E & S) should
+; be registered into the super global array REQUEST. If so, it also determines
+; the order in which that data is registered. The values for this directive are
+; specified in the same manner as the variables_order directive, EXCEPT one.
+; Leaving this value empty will cause PHP to use the value set in the
+; variables_order directive. It does not mean it will leave the super globals
+; array REQUEST empty.
+; http://php.net/request-order
+request_order = "GP"
+; with user data.
+; http://php.net/register-globals
+; Determines whether the deprecated long $HTTP_*_VARS type predefined variables
+; are registered by PHP or not. As they are deprecated, we obviously don't
+; recommend you use them. They are on by default for compatibility reasons but
+; they are not recommended on production servers.
+; http://php.net/register-long-arrays
+; This directive determines whether PHP registers $argv & $argc each time it
+; runs. $argv contains an array of all the arguments passed to PHP when a script
+; is invoked. $argc contains an integer representing the number of arguments
+; that were passed when the script was invoked. These arrays are extremely
+; useful when running scripts from the command line. When this directive is
+; enabled, registering these variables consumes CPU cycles and memory each time
+; a script is executed. For performance reasons, this feature should be disabled
+; on production servers.
+; http://php.net/register-argc-argv
+; http://php.net/auto-globals-jit
+; http://php.net/post-max-size
+post_max_size = 8M
+; Magic quotes are a preprocessing feature of PHP where PHP will attempt to
+; escape any character sequences in GET, POST, COOKIE and ENV data which might
+; otherwise corrupt data being placed in resources such as databases before
+; making that data available to you. Because of character encoding issues and
+; non-standard SQL implementations across many databases, it's not currently
+; possible for this feature to be 100% accurate. PHP's default behavior is to
+; enable the feature. We strongly recommend you use the escaping mechanisms
+; designed specifically for the database your using instead of relying on this
+; feature. Also note, this feature has been deprecated as of PHP 5.3.0 and is
+; scheduled for removal in PHP 6.
+; http://php.net/magic-quotes-gpc
+; http://php.net/magic-quotes-runtime
+; http://php.net/magic-quotes-sybase
+; Automatically add files before PHP document.
+; http://php.net/auto-prepend-file
+; Automatically add files after PHP document.
+; http://php.net/auto-append-file
+auto_append_file =
+; By default, PHP will output a character encoding using
+; http://php.net/default-mimetype
+; PHP's default character set is set to empty.
+; http://php.net/default-charset
+; Always populate the $HTTP_RAW_POST_DATA variable. PHP's default behavior is
+; to disable this feature.
+; http://php.net/always-populate-raw-post-data
+; PHP's default setting for include_path is ".;/path/to/php/pear"
+; http://php.net/include-path
+; http://php.net/doc-root
+doc_root =
+; if nonempty.
+; http://php.net/user-dir
+user_dir =
+; http://php.net/extension-dir
+; extension_dir = "./"
+; On windows:
+; extension_dir = "ext"
+; http://php.net/enable-dl
+enable_dl = Off
+; http://php.net/cgi.force-redirect
+;cgi.force_redirect = 1
+; every request. PHP's default behavior is to disable this feature.
+;cgi.nph = 1
+; http://php.net/cgi.redirect-status-env
+;cgi.redirect_status_env = ;
+; cgi.fix_pathinfo provides *real* PATH_INFO/PATH_TRANSLATED support for CGI.  PHP's
+; previous behaviour was to set PATH_TRANSLATED to SCRIPT_FILENAME, and to not grok
+; what PATH_INFO is.  For more information on PATH_INFO, see the cgi specs.  Setting
+; this to 1 will cause PHP CGI to fix its paths to conform to the spec.  A setting
+; of zero causes PHP to behave as before.  Default is 1.  You should fix your scripts
+; to use SCRIPT_FILENAME rather than PATH_TRANSLATED.
+; http://php.net/cgi.fix-pathinfo
+;cgi.fix_pathinfo=1
+; http://php.net/fastcgi.impersonate
+;fastcgi.impersonate = 1;
+; Disable logging through FastCGI connection. PHP's default behavior is to enable
+; this feature.
+;fastcgi.logging = 0
+; Default is zero.
+; http://php.net/cgi.rfc2616-headers
+; File Uploads ;
+; http://php.net/file-uploads
+file_uploads = On
+; specified).
+; http://php.net/upload-tmp-dir
+;upload_tmp_dir =
+; http://php.net/upload-max-filesize
+; Maximum number of files that can be uploaded via a single request
+max_file_uploads = 20
+; Fopen wrappers ;
+; http://php.net/allow-url-fopen
+; Whether to allow include/require to open URLs (like http:// or ftp://) as files.
+; http://php.net/allow-url-include
+allow_url_include = Off
+; Define the anonymous ftp password (your email address). PHP's default setting
+; for this is empty.
+; http://php.net/from
+; Define the User-Agent string. PHP's default setting for this is empty.
+; http://php.net/user-agent
+;user_agent="PHP"
+; http://php.net/default-socket-timeout
+; http://php.net/auto-detect-line-endings
+;auto_detect_line_endings = Off
+; syntax:
+; ... or with a path:
+;   extension=/path/to/extension/msql.so
+; If you only provide the name of the extension, PHP will look for it in its
+; default extension directory.
+; Windows Extensions
+; Note that ODBC support is built in, so no dll is needed for it.
+; Note that many DLL files are located in the extensions/ (PHP 4) ext/ (PHP 5)
+; extension folders as well as the separate PECL DLL download (PHP 5).
+; Be sure to appropriately set the extension_dir directive.
+;extension=php_fileinfo.dll
+;extension=php_gmp.dll
+;extension=php_intl.dll
+;extension=php_mbstring.dll
+;extension=php_mysqli.dll
+;extension=php_oci8.dll      ; Use with Oracle 10gR2 Instant Client
+;extension=php_oci8_11g.dll  ; Use with Oracle 11g Instant Client
+;extension=php_pdo_firebird.dll
+;extension=php_pdo_mssql.dll
+;extension=php_pdo_mysql.dll
+;extension=php_pdo_oci.dll
+;extension=php_pdo_odbc.dll
+;extension=php_pdo_pgsql.dll
+;extension=php_pdo_sqlite.dll
+;extension=php_phar.dll
+;extension=php_pspell.dll
+;extension=php_soap.dll
+;extension=php_sqlite.dll
+;extension=php_sqlite3.dll
+;extension=php_xsl.dll
+[Date]
+; Defines the default timezone used by the date functions
+; http://php.net/date.timezone
+;date.timezone =
+; http://php.net/date.default-latitude
+;date.default_latitude = 31.7667
+; http://php.net/date.default-longitude
+;date.default_longitude = 35.2333
+; http://php.net/date.sunrise-zenith
+;date.sunrise_zenith = 90.583333
+; http://php.net/date.sunset-zenith
+;date.sunset_zenith = 90.583333
+[filter]
+; http://php.net/filter.default
+;filter.default = unsafe_raw
+; http://php.net/filter.default-flags
+;filter.default_flags =
+[iconv]
+;iconv.input_encoding = ISO-8859-1
+;iconv.internal_encoding = ISO-8859-1
+;iconv.output_encoding = ISO-8859-1
+[intl]
+;intl.default_locale =
+; This directive allows you to produce PHP errors when some error
+; happens within intl functions. The value is the level of the error produced.
+; Default is 0, which does not produce any errors.
+;intl.error_level = E_WARNING
+[sqlite]
+; http://php.net/sqlite.assoc-case
+;sqlite.assoc_case = 0
+[sqlite3]
+;sqlite3.extension_dir =
+[Pcre]
+;PCRE library backtracking limit.
+; http://php.net/pcre.backtrack-limit
+;pcre.backtrack_limit=100000
+;PCRE library recursion limit.
+;Please note that if you set this value to a high number you may consume all
+;the available process stack and eventually crash PHP (due to reaching the
+;stack size limit imposed by the Operating System).
+; http://php.net/pcre.recursion-limit
+;pcre.recursion_limit=100000
+[Pdo]
+; Whether to pool ODBC connections. Can be one of "strict", "relaxed" or "off"
+; http://php.net/pdo-odbc.connection-pooling
+;pdo_odbc.connection_pooling=strict
+;pdo_odbc.db2_instance_name
+[Pdo_mysql]
+; If mysqlnd is used: Number of cache slots for the internal result set cache
+; http://php.net/pdo_mysql.cache_size
+pdo_mysql.cache_size = 2000
+; MySQL defaults.
+; http://php.net/pdo_mysql.default-socket
+pdo_mysql.default_socket=
+[Phar]
+; http://php.net/phar.readonly
+;phar.readonly = On
+; http://php.net/phar.require-hash
+;phar.require_hash = On
+;phar.cache_list =
+[Syslog]
+; http://php.net/define-syslog-variables
+[mail function]
+; For Win32 only.
+; http://php.net/smtp
+SMTP = localhost
+; http://php.net/smtp-port
+smtp_port = 25
+; For Win32 only.
+; http://php.net/sendmail-from
+; http://php.net/sendmail-path
+;sendmail_path =
+; Add X-PHP-Originating-Script: that will include uid of the script followed by the filename
+mail.add_x_header = On
+; Log all mail() calls including the full path of the script, line #, to address and headers
+;mail.log =
+[SQL]
+; http://php.net/sql.safe-mode
+[ODBC]
+; http://php.net/odbc.default-db
+; http://php.net/odbc.default-user
+; http://php.net/odbc.default-pw
+; Controls the ODBC cursor model.
+; Default: SQL_CURSOR_STATIC (default).
+;odbc.default_cursortype
+; http://php.net/odbc.allow-persistent
+; http://php.net/odbc.check-persistent
+; http://php.net/odbc.max-persistent
+; http://php.net/odbc.max-links
+; passthru.
+; http://php.net/odbc.defaultlrl
+; of odbc.defaultlrl and odbc.defaultbinmode
+; http://php.net/odbc.defaultbinmode
+;birdstep.max_links = -1
+[Interbase]
+ibase.allow_persistent = 1
+ibase.max_persistent = -1
+ibase.max_links = -1
+; Default database name for ibase_connect().
+;ibase.default_db =
+; Default username for ibase_connect().
+;ibase.default_user =
+; Default password for ibase_connect().
+;ibase.default_password =
+; Default charset for ibase_connect().
+;ibase.default_charset =
+; Default timestamp format.
+ibase.timestampformat = "%Y-%m-%d %H:%M:%S"
+; Default date format.
+ibase.dateformat = "%Y-%m-%d"
+; Default time format.
+ibase.timeformat = "%H:%M:%S"
+[MySQL]
+; Allow accessing, from PHP's perspective, local files with LOAD DATA statements
+; http://php.net/mysql.allow_local_infile
+mysql.allow_local_infile = On
+; http://php.net/mysql.allow-persistent
+; http://php.net/mysql.cache_size
+mysql.cache_size = 2000
+; http://php.net/mysql.max-persistent
+; http://php.net/mysql.max-links
+; at MYSQL_PORT.
+; http://php.net/mysql.default-port
+; MySQL defaults.
+; http://php.net/mysql.default-socket
+; http://php.net/mysql.default-host
+; http://php.net/mysql.default-user
+; http://php.net/mysql.default-password
+; Maximum time (in seconds) for connect timeout. -1 means no limit
+; http://php.net/mysql.connect-timeout
+; http://php.net/mysql.trace-mode
+[MySQLi]
+; http://php.net/mysqli.max-persistent
+mysqli.max_persistent = -1
+; http://php.net/mysqli.max-links
+; http://php.net/mysqli.cache_size
+mysqli.cache_size = 2000
+; at MYSQL_PORT.
+; http://php.net/mysqli.default-port
+; MySQL defaults.
+; http://php.net/mysqli.default-socket
+; http://php.net/mysqli.default-host
+; http://php.net/mysqli.default-user
+; http://php.net/mysqli.default-pw
+[mysqlnd]
+; Enable / Disable collection of general statstics by mysqlnd which can be
+; used to tune and monitor MySQL operations.
+; http://php.net/mysqlnd.collect_statistics
+mysqlnd.collect_statistics = On
+; Enable / Disable collection of memory usage statstics by mysqlnd which can be
+; http://php.net/mysqlnd.collect_memory_statistics
+mysqlnd.collect_memory_statistics = On
+; Size of a pre-allocated buffer used when sending commands to MySQL in bytes.
+; http://php.net/mysqlnd.net_cmd_buffer_size
+;mysqlnd.net_cmd_buffer_size = 2048
+; Size of a pre-allocated buffer used for reading data sent by the server in
+; bytes.
+; http://php.net/mysqlnd.net_read_buffer_size
+;mysqlnd.net_read_buffer_size = 32768
+[OCI8]
+; Connection: Enables privileged connections using external
+; credentials (OCI_SYSOPER, OCI_SYSDBA)
+; http://php.net/oci8.privileged-connect
+;oci8.privileged_connect = Off
+; Connection: The maximum number of persistent OCI8 connections per
+; process. Using -1 means no limit.
+; http://php.net/oci8.max-persistent
+;oci8.max_persistent = -1
+; Connection: The maximum number of seconds a process is allowed to
+; maintain an idle persistent connection. Using -1 means idle
+; persistent connections will be maintained forever.
+; http://php.net/oci8.persistent-timeout
+;oci8.persistent_timeout = -1
+; Connection: The number of seconds that must pass before issuing a
+; ping during oci_pconnect() to check the connection validity. When
+; set to 0, each oci_pconnect() will cause a ping. Using -1 disables
+; pings completely.
+; http://php.net/oci8.ping-interval
+;oci8.ping_interval = 60
+; Connection: Set this to a user chosen connection class to be used
+; for all pooled server requests with Oracle 11g Database Resident
+; Connection Pooling (DRCP).  To use DRCP, this value should be set to
+; the same string for all web servers running the same application,
+; the database pool must be configured, and the connection string must
+; specify to use a pooled server.
+;oci8.connection_class =
+; High Availability: Using On lets PHP receive Fast Application
+; Notification (FAN) events generated when a database node fails. The
+; database must also be configured to post FAN events.
+;oci8.events = Off
+; Tuning: This option enables statement caching, and specifies how
+; many statements to cache. Using 0 disables statement caching.
+; http://php.net/oci8.statement-cache-size
+;oci8.statement_cache_size = 20
+; Tuning: Enables statement prefetching and sets the default number of
+; rows that will be fetched automatically after statement execution.
+; http://php.net/oci8.default-prefetch
+;oci8.default_prefetch = 100
+; Compatibility. Using On means oci_close() will not close
+; oci_connect() and oci_new_connect() connections.
+; http://php.net/oci8.old-oci-close-semantics
+;oci8.old_oci_close_semantics = Off
+[PostgresSQL]
+; http://php.net/pgsql.allow-persistent
+; http://php.net/pgsql.auto-reset-persistent
+; http://php.net/pgsql.max-persistent
+; http://php.net/pgsql.max-links
+; http://php.net/pgsql.ignore-notice
+; http://php.net/pgsql.log-notice
+[Sybase-CT]
+; http://php.net/sybct.allow-persistent
+; http://php.net/sybct.max-persistent
+; http://php.net/sybct.max-links
+; http://php.net/sybct.min-server-severity
+; http://php.net/sybct.min-client-severity
+; Set per-context timeout
+; http://php.net/sybct.timeout
+;sybct.timeout=
+;sybct.packet_size
+; The maximum time in seconds to wait for a connection attempt to succeed before returning failure.
+; Default: one minute
+;sybct.login_timeout=
+; The name of the host you claim to be connecting from, for display by sp_who.
+; Default: none
+;sybct.hostname=
+; Allows you to define how often deadlocks are to be retried. -1 means "forever".
+; Default: 0
+;sybct.deadlock_retry_count=
+[bcmath]
+; http://php.net/bcmath.scale
+bcmath.scale = 0
+[browscap]
+; http://php.net/browscap
+[Session]
+; http://php.net/session.save-handler
+; The path can be defined as:
+; http://php.net/session.save-path
+; http://php.net/session.use-cookies
+; http://php.net/session.cookie-secure
+;session.cookie_secure =
+; This option forces PHP to fetch and use a cookie for storing and maintaining
+; the session id. We encourage this operation as it's very helpful in combatting
+; session hijacking when not specifying and managing your own session id. It is
+; not the end all be all of session hijacking defense, but it's a good start.
+; http://php.net/session.use-only-cookies
+session.use_only_cookies = 1
+; http://php.net/session.name
+; http://php.net/session.auto-start
+; http://php.net/session.cookie-lifetime
+; http://php.net/session.cookie-path
+; http://php.net/session.cookie-domain
+; Whether or not to add the httpOnly flag to the cookie, which makes it inaccessible to browser scripting languages such as JavaScript.
+; http://php.net/session.cookie-httponly
+session.cookie_httponly =
+; http://php.net/session.serialize-handler
+; Defines the probability that the 'garbage collection' process is started
+; on every session initialization. The probability is calculated by using
+; gc_probability/gc_divisor. Where session.gc_probability is the numerator
+; and gc_divisor is the denominator in the equation. Setting this value to 1
+; when the session.gc_divisor value is 100 will give you approximately a 1% chance
+; the gc will run on any give request.
+; Default Value: 1
+; http://php.net/session.gc-probability
+; Defines the probability that the 'garbage collection' process is started on every
+; session initialization. The probability is calculated by using the following equation:
+; gc_probability/gc_divisor. Where session.gc_probability is the numerator and
+; session.gc_divisor is the denominator in the equation. Setting this value to 1
+; the gc will run on any give request. Increasing this value to 1000 will give you
+; a 0.1% chance the gc will run on any give request. For high volume production servers,
+; this is a more efficient approach.
+; http://php.net/session.gc-divisor
+; http://php.net/session.gc-maxlifetime
+; to initialize a session variable in the global scope, even when register_globals
+; the warning is only displayed, if bug_compat_42 is enabled. This feature
+; introduces some serious security problems if not handled correctly. It's
+; recommended that you do not use this feature on production servers. But you
+; should enable this on development servers and enable the warning as well. If you
+; do not enable the feature on development servers, you won't be warned when it's
+; used and debugging errors caused by this can be difficult to track down.
+; http://php.net/session.bug-compat-42
+session.bug_compat_42 = On
+; This setting controls whether or not you are warned by PHP when initializing a
+; session value into the global space. session.bug_compat_42 must be enabled before
+; these warnings can be issued by PHP. See the directive above for more information.
+; http://php.net/session.bug-compat-warn
+session.bug_compat_warn = On
+; http://php.net/session.referer-check
+; http://php.net/session.entropy-length
+; http://php.net/session.entropy-file
+; http://php.net/session.cache-limiter
+; http://php.net/session.cache-expire
+; http://php.net/session.use-trans-sid
+; Select a hash function for use in generating session ids.
+; Possible Values
+;   0  (MD5 128 bits)
+;   1  (SHA-1 160 bits)
+; This option may also be set to the name of any hash function supported by
+; the hash extension. A list of available hashes is returned by the hash_alogs()
+; function.
+; http://php.net/session.hash-function
+; Possible values:
+;   4  (4 bits: 0-9, a-f)
+;   5  (5 bits: 0-9, a-v)
+;   6  (6 bits: 0-9, a-z, A-Z, "-", ",")
+; Default Value: 4
+; http://php.net/session.hash-bits-per-character
+; http://php.net/url-rewriter.tags
+[MSSQL]
+; Compatibility mode with old versions of PHP 3.0.
+; Connect timeout
+; Query timeout
+; Specify max number of processes. -1 = library default
+; msdlib defaults to 25
+; FreeTDS defaults to 4096
+;mssql.max_procs = -1
+; Specify client character set.
+; If empty or not set the client charset from freetds.comf is used
+; This is only used when compiled with FreeTDS
+;mssql.charset = "ISO-8859-1"
+[Assertion]
+; http://php.net/assert.active
+; http://php.net/assert.warning
+; http://php.net/assert.bail
+;assert.bail = Off
+; http://php.net/assert.callback
+; http://php.net/assert.quiet-eval
+[COM]
+; http://php.net/com.typelib-file
+; http://php.net/com.allow-dcom
+; http://php.net/com.autoregister-typelib
+; http://php.net/com.autoregister-casesensitive
+; show warnings on duplicate constant registrations
+; http://php.net/com.autoregister-verbose
+; The default character set code-page to use when passing strings to and from COM objects.
+; Default: system ANSI code page
+;com.code_page=
+[mbstring]
+; http://php.net/mbstring.language
+;mbstring.language = Japanese
+; http://php.net/mbstring.internal-encoding
+;mbstring.internal_encoding = EUC-JP
+; http://php.net/mbstring.http-input
+;mbstring.http_input = auto
+; http://php.net/mbstring.http-output
+;mbstring.http_output = SJIS
+; enable automatic encoding translation according to
+; http://php.net/mbstring.encoding-translation
+;mbstring.encoding_translation = Off
+; auto means
+; http://php.net/mbstring.detect-order
+;mbstring.detect_order = auto
+; one from another
+; http://php.net/mbstring.substitute-character
+; 0: No overload
+; http://php.net/mbstring.func-overload
+;mbstring.func_overload = 0
+; enable strict encoding detection.
+;mbstring.strict_detection = Off
+; This directive specifies the regex pattern of content types for which mb_output_handler()
+; is activated.
+; Default: mbstring.http_output_conv_mimetype=^(text/|application/xhtml\+xml)
+;mbstring.http_output_conv_mimetype=
+; Allows to set script encoding. Only affects if PHP is compiled with --enable-zend-multibyte
+; Default: ""
+;mbstring.script_encoding=
+[gd]
+; Tell the jpeg decode to ignore warnings and try to create
+; a gd image. The warning will then be displayed as notices
+; disabled by default
+; http://php.net/gd.jpeg-ignore-warning
+;gd.jpeg_ignore_warning = 0
+[exif]
+; http://php.net/exif.encode-unicode
+; http://php.net/exif.decode-unicode-motorola
+; http://php.net/exif.decode-unicode-intel
+; http://php.net/exif.encode-jis
+;exif.encode_jis =
+; http://php.net/exif.decode-jis-motorola
+; http://php.net/exif.decode-jis-intel
+[Tidy]
+; http://php.net/tidy.default-config
+; http://php.net/tidy.clean-output
+[soap]
+; http://php.net/soap.wsdl-cache-enabled
+; http://php.net/soap.wsdl-cache-dir
+; http://php.net/soap.wsdl-cache-ttl
+; Sets the size of the cache limit. (Max. number of WSDL files to cache)
+soap.wsdl_cache_limit = 5
+[sysvshm]
+; A default size of the shared memory segment
+;sysvshm.init_mem = 10000
+[ldap]
+; Sets the maximum number of open links or -1 for unlimited.
+ldap.max_links = -1
+[mcrypt]
+; For more information about mcrypt settings see http://php.net/mcrypt-module-open
+; Directory where to load mcrypt algorithms
+; Default: Compiled in into libmcrypt (usually /usr/local/lib/libmcrypt)
+;mcrypt.algorithms_dir=
+; Directory where to load mcrypt modes
+;mcrypt.modes_dir=
+[dba]
+;dba.default_handler=
+; Local Variables:
+; tab-width: 4
+; End:
Added: trunk/Installer/Support/Web/x64/Php/php.ini-production
--- trunk/Installer/Support/Web/x64/Php/php.ini-production	                        (rev 0)
+++ trunk/Installer/Support/Web/x64/Php/php.ini-production	2010-06-26 14:06:52 UTC (rev 4976)
@@ -0,0 +1,1900 @@
+[PHP]
+; About php.ini   ;
+; The syntax of the file is extremely simple.  Whitespace and Lines
+; beginning with a semicolon are silently ignored (as you probably guessed).
+; Section headers (e.g. [Foo]) are also silently ignored, even though
+; they might mean something in the future.
+; CGI/FastCGI.
+; Directives are specified using the following syntax:
+; directive = value
+; Directive names are *case sensitive* - foo=bar is different from FOO=bar.
+; The value can be a string, a number, a PHP constant (e.g. E_ALL or M_PI), one
+; of the INI constants (On, Off, True, False, Yes, No and None) or an expression
+; Expressions in the INI file are limited to bitwise operators and parentheses:
+; |  bitwise OR
+; ^  bitwise XOR
+; &  bitwise AND
+; ~  bitwise NOT
+; !  boolean NOT
+; Boolean flags can be turned on using the values 1, On, True or Yes.
+; They can be turned off using the values 0, Off, False or No.
+; An empty string can be denoted by simply not writing anything after the equal
+; sign, or by using the None keyword:
+;  foo =         ; sets foo to an empty string
+; If you use constants in your value, and these constants belong to a
+; dynamically loaded extension (either a PHP extension or a Zend extension),
+; you may only use these constants *after* the line that loads the extension.
+; About this file ;
+; display_errors
+; display_startup_errors
+; error_reporting
+; html_errors
+; log_errors
+; magic_quotes_gpc
+; max_input_time
+; output_buffering
+; request_order
+;   Default Value: 4
+; short_open_tag
+; track_errors
+; variables_order
+; Language Options ;
+; Enable the PHP scripting language engine under Apache.
+engine = On
+; Allow ASP-style <% %> tags.
+asp_tags = Off
+; The number of significant digits displayed in floating point numbers.
+precision = 14
+; Enforce year 2000 compliance (will cause problems with non-compliant browsers)
+y2k_compliance = On
+; reasons.
+;   functions.
+; Possible Values:
+;   Off = Disabled
+output_buffering = 4096
+; You can redirect all of the output of your scripts to a function.  For
+; example, if you set output_handler to "mb_output_handler", character
+; encoding will be transparently converted to the specified encoding.
+; Setting any output handler automatically turns on output buffering.
+; Note: People who wrote portable scripts should not depend on this ini
+;   directive. Instead, explicitly set the output handler using ob_start().
+;   Using this ini directive may cause problems unless you know what script
+;   is doing.
+; Note: You cannot use both "mb_output_handler" with "ob_iconv_handler"
+;   and you cannot use both "ob_gzhandler" and "zlib.output_compression".
+; Note: output_handler must be empty if this is set 'On' !!!!
+;   Instead you must use zlib.output_handler.
+;output_handler =
+; Transparent output compression using the zlib library
+; Valid values for this option are 'off', 'on', or a specific buffer size
+; to be used for compression (default is 4KB)
+; Note: Resulting chunk size may vary due to nature of compression. PHP
+;   outputs chunks that are few hundreds bytes each as a result of
+;   compression. If you prefer a larger chunk size for better
+;   performance, enable output_buffering in addition.
+; Note: You need to use zlib.output_handler instead of the standard
+;   output_handler, or otherwise the output will be corrupted.
+zlib.output_compression = Off
+; You cannot specify additional output handlers if zlib.output_compression
+; is activated here. This setting does the same as output_handler but in
+; a different order.
+;zlib.output_handler =
+; Implicit flush tells PHP to tell the output layer to flush itself
+; automatically after every output block.  This is equivalent to calling the
+; PHP function flush() after each and every call to print() or echo() and each
+; and every HTML block.  Turning this option on has serious performance
+; implications and is generally recommended for debugging purposes only.
+implicit_flush = Off
+; The unserialize callback function will be called (with the undefined class'
+; name as parameter), if the unserializer finds an undefined class
+; So only set this entry, if you really want to implement such a
+; callback-function.
+; When floats & doubles are serialized store serialize_precision significant
+; digits after the floating point. The default value ensures that when floats
+; are decoded with unserialize, the data will remain the same.
+serialize_precision = 100
+allow_call_time_pass_reference = Off
+; Safe Mode
+safe_mode = Off
+; By default, Safe Mode does a UID compare check when
+; opening files. If you want to relax this to a GID compare,
+; then turn on safe_mode_gid.
+safe_mode_gid = Off
+; When safe_mode is on, UID/GID checks are bypassed when
+; including files from this directory and its subdirectories.
+; (directory must also be in include_path or full path must
+; be used when including)
+safe_mode_include_dir =
+; When safe_mode is on, only executables located in the safe_mode_exec_dir
+; will be allowed to be executed via the exec family of functions.
+safe_mode_exec_dir =
+; Setting certain environment variables may be a potential security breach.
+; This directive contains a comma-delimited list of prefixes.  In Safe Mode,
+; the user may only alter environment variables whose names begin with the
+; prefixes supplied here.  By default, users will only be able to set
+; environment variables that begin with PHP_ (e.g. PHP_FOO=BAR).
+; Note:  If this directive is empty, PHP will let the user modify ANY
+;   environment variable!
+safe_mode_allowed_env_vars = PHP_
+; This directive contains a comma-delimited list of environment variables that
+; the end user won't be able to change using putenv().  These variables will be
+; protected even if safe_mode_allowed_env_vars is set to allow to change them.
+safe_mode_protected_env_vars = LD_LIBRARY_PATH
+; open_basedir, if set, limits all file operations to the defined directory
+; and below.  This directive makes most sense if used in a per-directory
+; or per-virtualhost web server configuration file. This directive is
+; *NOT* affected by whether Safe Mode is turned On or Off.
+;open_basedir =
+; This directive allows you to disable certain functions for security reasons.
+; It receives a comma-delimited list of function names. This directive is
+disable_functions =
+; This directive allows you to disable certain classes for security reasons.
+; It receives a comma-delimited list of class names. This directive is
+disable_classes =
+; Colors for Syntax Highlighting mode.  Anything that's acceptable in
+; <span style="color: ???????"> would work.
+;highlight.string  = #DD0000
+;highlight.comment = #FF9900
+;highlight.keyword = #007700
+;highlight.bg      = #FFFFFF
+;highlight.default = #0000BB
+;highlight.html    = #000000
+; value.
+; Miscellaneous ;
+; Decides whether PHP may expose the fact that it is installed on the server
+; (e.g. by adding its signature to the Web server header).  It is no security
+; threat in any way, but it makes it possible to determine whether you use PHP
+; on your server or not.
+expose_php = On
+; Resource Limits ;
+max_input_time = 60
+; Error handling and logging ;
+; E_ERROR           - fatal run-time errors
+; E_WARNING         - run-time warnings (non-fatal errors)
+; E_PARSE           - compile-time parse errors
+; E_NOTICE          - run-time notices (these are warnings which often result
+;                     from a bug in your code, but it's possible that it was
+;                     intentional (e.g., using an uninitialized variable and
+;                     relying on the fact it's automatically initialized to an
+;                     empty string)
+; E_STRICT          - run-time notices, enable to have PHP suggest changes
+;                     to your code which will ensure the best interoperability
+;                     and forward compatibility of your code
+; E_CORE_ERROR      - fatal errors that occur during PHP's initial startup
+; E_CORE_WARNING    - warnings (non-fatal errors) that occur during PHP's
+;                     initial startup
+; E_COMPILE_ERROR   - fatal compile-time errors
+; E_COMPILE_WARNING - compile-time warnings (non-fatal errors)
+; E_USER_ERROR      - user-generated error message
+; E_USER_WARNING    - user-generated warning message
+; E_USER_NOTICE     - user-generated notice message
+;                     of PHP
+; Common Values:
+error_reporting = E_ALL & ~E_DEPRECATED
+; Possible Values:
+display_errors = Off
+display_startup_errors = Off
+log_errors = On
+; Set maximum length of log_errors. In error_log information about the source is
+; added. The default is 1024 and 0 allows to not apply any maximum length at all.
+log_errors_max_len = 1024
+; Do not log repeated messages. Repeated errors must occur in same file on same
+ignore_repeated_errors = Off
+; Ignore source of message when ignoring repeated messages. When this setting
+; is On you will not log errors with repeated messages from different files or
+; source lines.
+ignore_repeated_source = Off
+; If this parameter is set to Off, then memory leaks will not be shown (on
+; stdout or in the log). This has only effect in a debug compile, and if
+; error reporting includes E_WARNING in the allowed list
+report_memleaks = On
+track_errors = Off
+;xmlrpc_errors = 0
+html_errors = Off
+; If html_errors is set On PHP produces clickable error messages that direct
+; to a page describing the error or function causing the error in detail.
+; and change docref_root to the base URL of your local copy including the
+; leading '/'. You must also specify the file extension being used including
+; Note: Never use this feature for production boxes.
+; Examples
+;docref_root = "/phpmanual/"
+;docref_ext = .html
+; Example:
+; Example:
+;error_append_string = "</font>"
+; empty.
+; Example:
+; Log errors to syslog (Event Log on NT, not valid in Windows 95).
+;error_log = syslog
+; Data Handling ;
+; The separator used in PHP generated URLs to separate arguments.
+; Example:
+;arg_separator.output = "&amp;"
+; List of separator(s) used by PHP to parse input URLs into variables.
+; NOTE: Every character in this directive is considered as separator!
+; Example:
+;arg_separator.input = ";&"
+variables_order = "GPCS"
+; Whether or not to register the EGPCS variables as global variables.  You may
+; want to turn this off if you don't want to clutter your scripts' global scope
+; with user data.
+; You should do your best to write your scripts so that they do not require
+; register_globals to be on;  Using form variables as globals can easily lead
+; to possible security problems, if the code is not very well thought of.
+register_globals = Off
+register_long_arrays = Off
+register_argc_argv = Off
+; When enabled, the SERVER and ENV variables are created when they're first
+; used (Just In Time) instead of when the script starts. If these variables
+; are not used within a script, having this directive on will result in a
+; performance gain. The PHP directives register_globals, register_long_arrays,
+; and register_argc_argv must be disabled for this directive to have any affect.
+auto_globals_jit = On
+; Maximum size of POST data that PHP will accept.
+post_max_size = 8M
+magic_quotes_gpc = Off
+; Magic quotes for runtime-generated data, e.g. data from SQL, from exec(), etc.
+magic_quotes_runtime = Off
+; Use Sybase-style magic quotes (escape ' with '' instead of \').
+magic_quotes_sybase = Off
+auto_prepend_file =
+auto_append_file =
+; the Content-type: header.  To disable sending of the charset, simply
+; set it to be empty.
+; PHP's built-in default is text/html
+default_mimetype = "text/html"
+;default_charset = "iso-8859-1"
+;always_populate_raw_post_data = On
+; Paths and Directories ;
+; UNIX: "/path1:/path2"
+;include_path = ".:/php/includes"
+; Windows: "\path1;\path2"
+;include_path = ".;c:\php\includes"
+; The root of the PHP pages, used only if nonempty.
+; if PHP was not compiled with FORCE_REDIRECT, you SHOULD set doc_root
+; if you are running php as a CGI under any web server (other than IIS)
+; see documentation for security issues.  The alternate is to use the
+; cgi.force_redirect configuration below
+doc_root =
+; The directory under which PHP opens the script using /~username used only
+; if nonempty.
+user_dir =
+; Directory in which the loadable extensions (modules) reside.
+; On windows:
+; Whether or not to enable the dl() function.  The dl() function does NOT work
+; properly in multithreaded servers, such as IIS or Zeus, and is automatically
+; disabled on them.
+enable_dl = Off
+; cgi.force_redirect is necessary to provide security running PHP as a CGI under
+; most web servers.  Left undefined, PHP turns this on by default.  You can
+; turn it off here AT YOUR OWN RISK
+; **You CAN safely turn this off for IIS, in fact, you MUST.**
+; if cgi.nph is enabled it will force cgi to always sent Status: 200 with
+;cgi.nph = 1
+; if cgi.force_redirect is turned on, and you are not running under Apache or Netscape
+; (iPlanet) web servers, you MAY need to set an environment variable name that PHP
+; will look for to know it is OK to continue execution.  Setting this variable MAY
+; cause security issues, KNOW WHAT YOU ARE DOING FIRST.
+; FastCGI under IIS (on WINNT based OS) supports the ability to impersonate
+; security tokens of the calling client.  This allows IIS to define the
+; security context that the request runs under.  mod_fastcgi under Apache
+; does not currently support this feature (03/17/2002)
+; Set to 1 if running under IIS.  Default is zero.
+; this feature.
+; cgi.rfc2616_headers configuration option tells PHP what type of headers to
+; use when sending HTTP response code. If it's set 0 PHP sends Status: header that
+; is supported by Apache. When this option is set to 1 PHP will send
+; RFC2616 compliant header.
+; Default is zero.
+;cgi.rfc2616_headers = 0
+; File Uploads ;
+; Whether to allow HTTP file uploads.
+file_uploads = On
+; Temporary directory for HTTP uploaded files (will use system default if not
+; specified).
+;upload_tmp_dir =
+; Maximum allowed size for uploaded files.
+upload_max_filesize = 2M
+; Fopen wrappers ;
+; Whether to allow the treatment of URLs (like http:// or ftp://) as files.
+allow_url_fopen = On
+;from="john at doe.com"
+;user_agent="PHP"
+; Default timeout for socket based streams (seconds)
+default_socket_timeout = 60
+; If your scripts have to deal with files from Macintosh systems,
+; or you are running on a Mac and need to deal with files from
+; unix or win32 systems, setting this flag will cause PHP to
+; automatically detect the EOL character in those files so that
+; fgets() and file() will work regardless of the source of the file.
+; Dynamic Extensions ;
+; If you wish to have an extension loaded automatically, use the following
+; syntax:
+;   extension=modulename.extension
+; For example, on Windows:
+;   extension=msql.dll
+; ... or under UNIX:
+;   extension=msql.so
+;extension=php_bz2.dll
+;extension=php_curl.dll
+;extension=php_dba.dll
+;extension=php_exif.dll
+;extension=php_gd2.dll
+;extension=php_gettext.dll
+;extension=php_imap.dll
+;extension=php_interbase.dll
+;extension=php_ldap.dll
+;extension=php_ming.dll
+;extension=php_mssql.dll
+;extension=php_mysql.dll
+;extension=php_openssl.dll
+;extension=php_pgsql.dll
+;extension=php_shmop.dll
+;extension=php_snmp.dll
+;extension=php_sockets.dll
+;extension=php_sybase_ct.dll
+;extension=php_tidy.dll
+;extension=php_xmlrpc.dll
+;extension=php_zip.dll
+; Module Settings ;
+[Date]
+;date.timezone =
+[filter]
+[iconv]
+[intl]
+[sqlite]
+[sqlite3]
+[Pcre]
+[Pdo]
+[Pdo_mysql]
+; Default socket name for local MySQL connects.  If empty, uses the built-in
+; MySQL defaults.
+[Phar]
+;phar.cache_list =
+[Syslog]
+; Whether or not to define the various syslog variables (e.g. $LOG_PID,
+; $LOG_CRON, etc.).  Turning it off is a good idea performance-wise.  In
+; runtime, you can define these variables by calling define_syslog_variables().
+define_syslog_variables  = Off
+[mail function]
+; For Win32 only.
+SMTP = localhost
+smtp_port = 25
+; For Win32 only.
+;sendmail_from = me at example.com
+; For Unix only.  You may supply arguments as well (default: "sendmail -t -i").
+;sendmail_path =
+; Force the addition of the specified parameters to be passed as extra parameters
+; to the sendmail binary. These parameters will always replace the value of
+; the 5th parameter to mail(), even in safe mode.
+;mail.force_extra_parameters =
+;mail.log =
+[SQL]
+sql.safe_mode = Off
+[ODBC]
+;odbc.default_db    =  Not yet implemented
+;odbc.default_user  =  Not yet implemented
+;odbc.default_pw    =  Not yet implemented
+; Allow or prevent persistent links.
+odbc.allow_persistent = On
+; Check that a connection is still valid before reuse.
+odbc.check_persistent = On
+; Maximum number of persistent links.  -1 means no limit.
+odbc.max_persistent = -1
+; Maximum number of links (persistent + non-persistent).  -1 means no limit.
+odbc.max_links = -1
+; Handling of LONG fields.  Returns number of bytes to variables.  0 means
+; passthru.
+odbc.defaultlrl = 4096
+; Handling of binary data.  0 means passthru, 1 return as is, 2 convert to char.
+; See the documentation on odbc_binmode and odbc_longreadlen for an explanation
+odbc.defaultbinmode = 1
+[Interbase]
+[MySQL]
+mysql.allow_persistent = On
+mysql.max_persistent = -1
+mysql.max_links = -1
+; Default port number for mysql_connect().  If unset, mysql_connect() will use
+; the $MYSQL_TCP_PORT or the mysql-tcp entry in /etc/services or the
+; compile-time value defined MYSQL_PORT (in that order).  Win32 will only look
+; at MYSQL_PORT.
+mysql.default_port =
+; MySQL defaults.
+mysql.default_socket =
+; Default host for mysql_connect() (doesn't apply in safe mode).
+mysql.default_host =
+; Default user for mysql_connect() (doesn't apply in safe mode).
+mysql.default_user =
+; Default password for mysql_connect() (doesn't apply in safe mode).
+; Note that this is generally a *bad* idea to store passwords in this file.
+; *Any* user with PHP access can run 'echo get_cfg_var("mysql.default_password")
+; and reveal this password!  And of course, any users with read access to this
+; file will be able to reveal the password as well.
+mysql.default_password =
+mysql.connect_timeout = 60
+; Trace mode. When trace_mode is active (=On), warnings for table/index scans and
+; SQL-Errors will be displayed.
+mysql.trace_mode = Off
+[MySQLi]
+; http://php.net/mysqli.allow_local_infile
+;mysqli.allow_local_infile = On
+; http://php.net/mysqli.allow-persistent
+mysqli.allow_persistent = On
+; Maximum number of links.  -1 means no limit.
+mysqli.max_links = -1
+; Default port number for mysqli_connect().  If unset, mysqli_connect() will use
+; at MYSQL_PORT.
+mysqli.default_port = 3306
+; MySQL defaults.
+mysqli.default_socket =
+mysqli.default_host =
+mysqli.default_user =
+; Default password for mysqli_connect() (doesn't apply in safe mode).
+; *Any* user with PHP access can run 'echo get_cfg_var("mysqli.default_pw")
+mysqli.default_pw =
+; Allow or prevent reconnect
+mysqli.reconnect = Off
+[mysqlnd]
+mysqlnd.collect_memory_statistics = Off
+; bytes.
+[OCI8]
+;oci8.events = Off
+[PostgresSQL]
+pgsql.allow_persistent = On
+; Detect broken persistent links always with pg_pconnect().
+; Auto reset feature requires a little overheads.
+pgsql.auto_reset_persistent = Off
+pgsql.max_persistent = -1
+; Maximum number of links (persistent+non persistent).  -1 means no limit.
+pgsql.max_links = -1
+; Ignore PostgreSQL backends Notice message or not.
+; Notice message logging require a little overheads.
+pgsql.ignore_notice = 0
+; Log PostgreSQL backends Noitce message or not.
+; Unless pgsql.ignore_notice=0, module cannot log notice message.
+pgsql.log_notice = 0
+[Sybase-CT]
+sybct.allow_persistent = On
+sybct.max_persistent = -1
+sybct.max_links = -1
+; Minimum server message severity to display.
+sybct.min_server_severity = 10
+; Minimum client message severity to display.
+sybct.min_client_severity = 10
+;sybct.timeout=
+;sybct.packet_size
+; Default: none
+;sybct.hostname=
+; Default: 0
+[bcmath]
+; Number of decimal digits for all bcmath functions.
+bcmath.scale = 0
+[browscap]
+;browscap = extra/browscap.ini
+[Session]
+; Handler used to store/retrieve data.
+session.save_handler = files
+; Argument passed to save_handler.  In the case of files, this is the path
+; where data files are stored. Note: Windows users have to change this
+; variable in order to use PHP's session functions.
+;     session.save_path = "N;/path"
+; where N is an integer.  Instead of storing all the session files in
+; /path, what this will do is use subdirectories N-levels deep, and
+; store the session data in those directories.  This is useful if you
+; or your OS have problems with lots of files in one directory, and is
+; a more efficient layout for servers that handle lots of sessions.
+; NOTE 1: PHP will not create this directory structure automatically.
+;         You can use the script in the ext/session dir for that purpose.
+; NOTE 2: See the section on garbage collection below if you choose to
+;         use subdirectories for session storage
+; The file storage module creates files using mode 600 by default.
+; You can change that by using
+;     session.save_path = "N;MODE;/path"
+; where MODE is the octal representation of the mode. Note that this
+; does not overwrite the process's umask.
+;session.save_path = "/tmp"
+; Whether to use cookies.
+session.use_cookies = 1
+; Name of the session (used as cookie name).
+session.name = PHPSESSID
+; Initialize session on request startup.
+session.auto_start = 0
+; Lifetime in seconds of cookie or, if 0, until browser is restarted.
+session.cookie_lifetime = 0
+; The path for which the cookie is valid.
+session.cookie_path = /
+; The domain for which the cookie is valid.
+session.cookie_domain =
+; Handler used to serialize data.  php is the standard serializer of PHP.
+session.serialize_handler = php
+; Default Value: 1
+session.gc_probability = 1
+session.gc_divisor = 1000
+; After this number of seconds, stored data will be seen as 'garbage' and
+; cleaned up by the garbage collection process.
+session.gc_maxlifetime = 1440
+; NOTE: If you are using the subdirectory option for storing session files
+;       (see session.save_path above), then garbage collection does *not*
+;       happen automatically.  You will need to do your own garbage
+;       collection through a shell script, cron entry, or some other method.
+;       For example, the following script would is the equivalent of
+;       setting session.gc_maxlifetime to 1440 (1440 seconds = 24 minutes):
+;          cd /path/to/sessions; find -cmin +24 | xargs rm
+; PHP 4.2 and less have an undocumented feature/bug that allows you to
+; is disabled.  PHP 4.3 and later will warn you, if this feature is used.
+; You can disable the feature and the warning separately. At this time,
+session.bug_compat_42 = Off
+session.bug_compat_warn = Off
+; Check HTTP Referer to invalidate externally stored URLs containing ids.
+; HTTP_REFERER has to contain this substring for the session to be
+; considered as valid.
+session.referer_check =
+; How many bytes to read from the file.
+session.entropy_length = 0
+; Specified here to create the session id.
+;session.entropy_file = /dev/urandom
+session.entropy_file =
+;session.entropy_length = 16
+; Set to {nocache,private,public,} to determine HTTP caching aspects
+; or leave this empty to avoid sending anti-caching headers.
+session.cache_limiter = nocache
+; Document expires after n minutes.
+session.cache_expire = 180
+; trans sid support is disabled by default.
+; Use of trans sid may risk your users security.
+; Use this option with caution.
+; - User may send URL contains active session ID
+;   to other person via. email/irc/etc.
+; - URL that contains active session ID may be stored
+;   in publically accessible computer.
+; - User may access your site with the same session ID
+;   always using URL stored in browser's history or bookmarks.
+session.use_trans_sid = 0
+; Possible Values
+;   0  (MD5 128 bits)
+; function.
+session.hash_function = 0
+; Define how many bits are stored in each character when converting
+; the binary hash data to something readable.
+; Possible values:
+; Default Value: 4
+session.hash_bits_per_character = 5
+; The URL rewriter will look for URLs in a defined set of HTML tags.
+; form/fieldset are special; if you include them here, the rewriter will
+; add a hidden <input> field with the info which is otherwise appended
+; to URLs.  If you want XHTML conformity, remove the form entry.
+; Note that all valid entries require a "=", even if no value follows.
+url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=fakeentry"
+[MSSQL]
+mssql.allow_persistent = On
+mssql.max_persistent = -1
+mssql.max_links = -1
+; Minimum error severity to display.
+mssql.min_error_severity = 10
+; Minimum message severity to display.
+mssql.min_message_severity = 10
+mssql.compatability_mode = Off
+; Connect timeout
+;mssql.connect_timeout = 5
+; Query timeout
+;mssql.timeout = 60
+; Valid range 0 - 2147483647.  Default = 4096.
+;mssql.textlimit = 4096
+;mssql.textsize = 4096
+; Limits the number of records in each batch.  0 = all records in one batch.
+;mssql.batchsize = 0
+; Specify how datetime and datetim4 columns are returned
+; On => Returns data converted to SQL server settings
+; Off => Returns values as YYYY-MM-DD hh:mm:ss
+;mssql.datetimeconvert = On
+; Use NT authentication when connecting to the server
+mssql.secure_connection = Off
+[Assertion]
+; Assert(expr); active by default.
+;assert.active = On
+; Issue a PHP warning for each failed assertion.
+;assert.warning = On
+; Don't bail out by default.
+;assert.bail = Off
+; User-function to be called if an assertion fails.
+;assert.callback = 0
+; Eval the expression with current error_reporting().  Set to true if you want
+; error_reporting(0) around the eval().
+;assert.quiet_eval = 0
+[COM]
+; path to a file containing GUIDs, IIDs or filenames of files with TypeLibs
+;com.typelib_file =
+; allow Distributed-COM calls
+;com.allow_dcom = true
+; autoregister constants of a components typlib on com_load()
+;com.autoregister_typelib = true
+; register constants casesensitive
+;com.autoregister_casesensitive = false
+;com.autoregister_verbose = true
+;com.code_page=
+[mbstring]
+; language for internal character representation.
+; internal/script encoding.
+; Some encoding cannot work as internal encoding.
+; (e.g. SJIS, BIG5, ISO-2022-*)
+; http input encoding.
+; http output encoding. mb_output_handler must be
+; registered as output buffer to function
+; mbstring.internal_encoding setting. Input chars are
+; converted to internal encoding by setting this to On.
+; Note: Do _not_ use automatic encoding translation for
+;       portable libs/applications.
+; automatic encoding detection order.
+; auto means
+; substitute_character used when character cannot be converted
+; one from another
+;mbstring.substitute_character = none;
+; overload(replace) single byte functions by mbstring functions.
+; mail(), ereg(), etc are overloaded by mb_send_mail(), mb_ereg(),
+; etc. Possible values are 0,1,2,4 or combination of them.
+; For example, 7 for overload everything.
+; 0: No overload
+; 1: Overload mail() function
+; 2: Overload str*() functions
+; 4: Overload ereg*() functions
+; is activated.
+; Default: ""
+[gd]
+[exif]
+; Exif UNICODE user comments are handled as UCS-2BE/UCS-2LE and JIS as JIS.
+; With mbstring support this will automatically be converted into the encoding
+; given by corresponding encode setting. When empty mbstring.internal_encoding
+; is used. For the decode settings you can distinguish between motorola and
+; intel byte order. A decode setting cannot be empty.
+;exif.encode_unicode = ISO-8859-15
+;exif.decode_unicode_motorola = UCS-2BE
+;exif.decode_unicode_intel    = UCS-2LE
+;exif.encode_jis =
+;exif.decode_jis_motorola = JIS
+;exif.decode_jis_intel    = JIS
+[Tidy]
+; The path to a default tidy configuration file to use when using tidy
+;tidy.default_config = /usr/local/lib/php/default.tcfg
+; Should tidy clean and repair output automatically?
+; WARNING: Do not use this option if you are generating non-html content
+; such as dynamic images
+tidy.clean_output = Off
+[soap]
+; Enables or disables WSDL caching feature.
+soap.wsdl_cache_enabled=1
+; Sets the directory name where SOAP extension will put cache files.
+soap.wsdl_cache_dir="/tmp"
+; (time to live) Sets the number of second while cached file will be used
+; instead of original one.
+soap.wsdl_cache_ttl=86400
+[sysvshm]
+[ldap]
+[mcrypt]
+;mcrypt.modes_dir=
+[dba]
+; Local Variables:
+; tab-width: 4
+; End:
Added: trunk/Installer/Support/Web/x64/Php/php5apache2_2.dll
(Binary files differ)
Property changes on: trunk/Installer/Support/Web/x64/Php/php5apache2_2.dll
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/Installer/Support/Web/x64/Php/php5apache2_2_filter.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/php5apache2_2_filter.dll
Added: trunk/Installer/Support/Web/x64/Php/php5isapi.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/php5isapi.dll
Added: trunk/Installer/Support/Web/x64/Php/php5ts.dll
Property changes on: trunk/Installer/Support/Web/x64/Php/php5ts.dll
Added: trunk/Installer/Support/Web/x64/Php/snapshot
--- trunk/Installer/Support/Web/x64/Php/snapshot	                        (rev 0)
+++ trunk/Installer/Support/Web/x64/Php/snapshot	2010-06-26 14:06:52 UTC (rev 4976)
@@ -0,0 +1,7 @@
+#! /bin/sh
+if test -n "$1"; then
+  flags="DISTNAME=$1"
+fi
+${MAKE:-make} $flags -f build/build.mk snapshot
More information about the mapguide-commits mailing list
