[mapguide-commits] r4681 - in sandbox/adsk/2.2gp: Common/Foundation/System Common/MapGuideCommon Common/MapGuideCommon/Services Server/src/Common/Base Web/src/WebSupport
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 22 13:54:25 EDT 2010
Author: brucedechant
Date: 2010-03-22 13:54:24 -0400 (Mon, 22 Mar 2010)
New Revision: 4681
Added:
   sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionEventHandler.cpp
   sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionEventHandler.h
   sandbox/adsk/2.2gp/Common/Foundation/System/AceStreamHelper.cpp
   sandbox/adsk/2.2gp/Common/MapGuideCommon/Makefile.am
   sandbox/adsk/2.2gp/Common/MapGuideCommon/MapGuideCommon.vcproj
   sandbox/adsk/2.2gp/Common/MapGuideCommon/MapGuideCommonBuild.cpp
   sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnection.cpp
   sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionImp.cpp
   sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionPool.cpp
   sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionPool.h
   sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionStack.cpp
   sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionStack.h
   sandbox/adsk/2.2gp/Server/src/Common/Base/ClientHandler.cpp
   sandbox/adsk/2.2gp/Web/src/WebSupport/InitializeWebTier.cpp
Fix for trac ticket 900 - Connections in CLOSE_WAIT status never close and are not reused
http://trac.osgeo.org/mapguide/ticket/900
Notes:
- Added background thread on the web tier side to check when a socket connection is closed on the server side and then close it properly
- Increased stale time to 2 minutes from 1 minute to help prevent connections from being cycled too early
- Added some additional error handling
Modified: sandbox/adsk/2.2gp/Common/Foundation/System/AceStreamHelper.cpp
--- sandbox/adsk/2.2gp/Common/Foundation/System/AceStreamHelper.cpp	2010-03-22 16:49:37 UTC (rev 4680)
+++ sandbox/adsk/2.2gp/Common/Foundation/System/AceStreamHelper.cpp	2010-03-22 17:54:24 UTC (rev 4681)
@@ -213,6 +213,11 @@
             stat = ( bConnected ) ? MgStreamHelper::mssNotDone : MgStreamHelper::mssError;
+        else if (res == 0)
+            // No longer connected
+            stat = MgStreamHelper::mssError;
         else
             m_readBufEnd += res;
@@ -238,6 +243,11 @@
             else
@@ -422,7 +432,7 @@
         else
             res = stream.send(buffer, size, MG_MSG_NOSIGNAL);
         //  check for failure
         if ( res >= 0 )
@@ -438,12 +448,12 @@
             else
                 stat = blocking ? MgStreamHelper::mssError : MgStreamHelper::mssNotDone;
     return stat;
 ///<summary>
@@ -548,7 +558,7 @@
 bool MgAceStreamHelper::IsConnected()
-    bool bConnected = false;
+    bool bConnected = true;
     ACE_SOCK_Stream stream;
     stream.set_handle( m_handle );
     UINT8 dummy;
@@ -557,6 +567,7 @@
     if ( res < 0 )
+        // Error or timeout occured
 #ifdef _WIN32
         int error = ::WSAGetLastError(); // errno doesn't work correctly on Windows
         bConnected = ( error == WSAEWOULDBLOCK || error == 0 );
@@ -564,6 +575,11 @@
         bConnected = ( errno == EWOULDBLOCK || errno == 0 || errno == ETIME );
 #endif
+        bConnected = false;
     return bConnected;
Modified: sandbox/adsk/2.2gp/Common/MapGuideCommon/Makefile.am
--- sandbox/adsk/2.2gp/Common/MapGuideCommon/Makefile.am	2010-03-22 16:49:37 UTC (rev 4680)
+++ sandbox/adsk/2.2gp/Common/MapGuideCommon/Makefile.am	2010-03-22 17:54:24 UTC (rev 4681)
@@ -108,6 +108,7 @@
   Services/ServerAdmin.cpp \
   Services/ServerAdminDefs.cpp \
   Services/ServerConnection.cpp \
+  Services/ServerConnectionEventHandler.cpp \
   Services/ServerConnectionImp.cpp \
   Services/ServerConnectionPool.cpp \
   Services/ServerConnectionStack.cpp \
@@ -230,6 +231,7 @@
   Services/ServerAdmin.h \
   Services/ServerAdminDefs.h \
   Services/ServerConnection.h \
+  Services/ServerConnectionEventHandler.h \
   Services/ServerConnectionImp.h \
   Services/ServerConnectionPool.h \
   Services/ServerConnectionStack.h \
Modified: sandbox/adsk/2.2gp/Common/MapGuideCommon/MapGuideCommon.vcproj
--- sandbox/adsk/2.2gp/Common/MapGuideCommon/MapGuideCommon.vcproj	2010-03-22 16:49:37 UTC (rev 4680)
+++ sandbox/adsk/2.2gp/Common/MapGuideCommon/MapGuideCommon.vcproj	2010-03-22 17:54:24 UTC (rev 4681)
@@ -4357,6 +4357,46 @@
 			</File>
 			<File
+				RelativePath=".\Services\ServerConnectionEventHandler.cpp"
+				<FileConfiguration
+					Name="Debug|Win32"
+					ExcludedFromBuild="true"
+					<Tool
+						Name="VCCLCompilerTool"
+				</FileConfiguration>
+					Name="Debug|x64"
+					<Tool
+					Name="Release|Win32"
+					<Tool
+					Name="Release|x64"
+					<Tool
+			</File>
+			<File
+				RelativePath=".\Services\ServerConnectionEventHandler.h"
+			</File>
+			<File
 				RelativePath=".\Services\ServerConnectionImp.cpp"
 				<FileConfiguration
Modified: sandbox/adsk/2.2gp/Common/MapGuideCommon/MapGuideCommonBuild.cpp
--- sandbox/adsk/2.2gp/Common/MapGuideCommon/MapGuideCommonBuild.cpp	2010-03-22 16:49:37 UTC (rev 4680)
+++ sandbox/adsk/2.2gp/Common/MapGuideCommon/MapGuideCommonBuild.cpp	2010-03-22 17:54:24 UTC (rev 4681)
@@ -118,6 +118,7 @@
 #include  "Services/ServerConnectionImp.cpp"
 #include  "Services/ServerConnectionPool.cpp"
 #include  "Services/ServerConnectionStack.cpp"
+#include  "Services/ServerConnectionEventHandler.cpp"
 #include  "Services/ServerInformation.cpp"
 #include  "Services/Site.cpp"
 #include  "Services/SiteManager.cpp"
Modified: sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnection.cpp
--- sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnection.cpp	2010-03-22 16:49:37 UTC (rev 4680)
+++ sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnection.cpp	2010-03-22 17:54:24 UTC (rev 4681)
@@ -28,8 +28,7 @@
 #include <dlfcn.h>
 #endif
-static Ptr<MgServerConnectionPool> g_connectionPool = new MgServerConnectionPool();
-const time_t MgServerConnection::sm_kStaleTime = 60; // in seconds
+const time_t MgServerConnection::sm_kStaleTime = 120; // in seconds
 ACE_Recursive_Thread_Mutex MgServerConnection::sm_mutex;
@@ -292,6 +291,9 @@
     CHECKNULL((MgUserInformation*)userInformation, L"MgServerConnection.Acquire");
     CHECKNULL((MgConnectionProperties*)connProp, L"MgServerConnection.Acquire");
+    MgServerConnectionPool* connectionPool = MgServerConnectionPool::GetInstance();
+    CHECKNULL(connectionPool, L"MgServerConnection.Acquire");
     Ptr<MgServerConnection> msc;
     MgServerConnectionStack* stack = NULL;
@@ -300,9 +302,9 @@
         ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, sm_mutex, NULL));
         wstring hash = connProp->Hash();
-        MgServerConnectionPool::ConnectionPool::iterator iter = g_connectionPool->pool.find(hash);
+        MgServerConnectionPool::ConnectionPool::iterator iter = connectionPool->pool.find(hash);
-        if (iter != g_connectionPool->pool.end())
+        if (iter != connectionPool->pool.end())
             stack = iter->second;
@@ -310,7 +312,7 @@
         if (stack == NULL)
             stack = new MgServerConnectionStack(connProp->GetPort());
-            (g_connectionPool->pool)[hash] = stack;
+            (connectionPool->pool)[hash] = stack;
@@ -364,6 +366,7 @@
         ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, sm_mutex));
-        g_connectionPool->pool.erase(hash);
+        connectionPool->pool.erase(hash);
Added: sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionEventHandler.cpp
--- sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionEventHandler.cpp	                        (rev 0)
+++ sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionEventHandler.cpp	2010-03-22 17:54:24 UTC (rev 4681)
@@ -0,0 +1,49 @@
+//  Copyright (C) 2004-2010 by Autodesk, Inc.
+//  This library is free software; you can redistribute it and/or
+//  modify it under the terms of version 2.1 of the GNU Lesser
+//  General Public License as published by the Free Software Foundation.
+//  This library is distributed in the hope that it will be useful,
+//  but WITHOUT ANY WARRANTY; without even the implied warranty of
+//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+//  Lesser General Public License for more details.
+//  You should have received a copy of the GNU Lesser General Public
+//  License along with this library; if not, write to the Free Software
+//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+#include "MapGuideCommon.h"
+#include "ServerConnectionImp.h"
+#include "ServerConnectionStack.h"
+#include "ServerConnectionPool.h"
+#include "ServerConnection.h"
+#include "ServerConnectionEventHandler.h"
+MgServerConnectionEventHandler::MgServerConnectionEventHandler()
+MgServerConnectionEventHandler::~MgServerConnectionEventHandler()
+int MgServerConnectionEventHandler::handle_timeout(const ACE_Time_Value& currentTime, const void* arg)
+    MG_TRY()
+    ACE_UNUSED_ARG(currentTime);
+    ACE_UNUSED_ARG(arg);
+    ACE_Time_Value now = ACE_High_Res_Timer::gettimeofday();
+    MgServerConnectionPool* pool = MgServerConnectionPool::GetInstance();
+    if (NULL != pool)
+        pool->CloseStaleConnections(&now);
+    MG_CATCH_AND_RELEASE()
+    return 0;
Property changes on: sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionEventHandler.cpp
___________________________________________________________________
Added: svn:eol-style
   + native
Added: sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionEventHandler.h
--- sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionEventHandler.h	                        (rev 0)
+++ sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionEventHandler.h	2010-03-22 17:54:24 UTC (rev 4681)
@@ -0,0 +1,43 @@
+#ifndef MG_SERVER_CONNECTION_EVENT_HANDLER_H
+#define MG_SERVER_CONNECTION_EVENT_HANDLER_H
+#include "Foundation.h"
+class MgServerConnectionEventHandler : public ACE_Event_Handler
+public:
+    MgServerConnectionEventHandler();
+    virtual ~MgServerConnectionEventHandler();
+    // ACE_Event_Handler method
+    int handle_timeout(const ACE_Time_Value& currentTime, const void* arg);
+private:
+    // Unimplemented Constructors/Methods
+    // MgServerConnectionEventHandler();
+    // MgServerConnectionEventHandler(const MgServerConnectionEventHandler&);
+    // MgServerConnectionEventHandler& operator=(const MgServerConnectionEventHandler&);
+#endif
\ No newline at end of file
Property changes on: sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionEventHandler.h
   + native
Modified: sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionImp.cpp
--- sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionImp.cpp	2010-03-22 16:49:37 UTC (rev 4680)
+++ sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionImp.cpp	2010-03-22 17:54:24 UTC (rev 4681)
@@ -133,17 +133,6 @@
     if (mServer != NULL)
-        // Send a control packet to the server to dump the connection early
-        Ptr<MgAceStreamHelper> streamHelper = new MgAceStreamHelper(mServer->get_handle());
-        MgStream stream(streamHelper);
-        MgControlPacket packet;
-        packet.m_PacketHeader = MgPacketParser::mphControl;
-        packet.m_PacketVersion = 1;
-        packet.m_ControlID = MgPacketParser::mciClose;
-        stream.WriteControlPacket(packet);
         // close the writer and attempt to gracefully leave
         mServer->close_writer();
Modified: sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionPool.cpp
--- sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionPool.cpp	2010-03-22 16:49:37 UTC (rev 4680)
+++ sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionPool.cpp	2010-03-22 17:54:24 UTC (rev 4681)
@@ -18,16 +18,42 @@
+MgServerConnectionPool* MgServerConnectionPool::sm_pool = NULL;
 /// <summary>
 /// Constructor for connection stack
 /// </summary>
 MgServerConnectionPool::MgServerConnectionPool()
+    // Start up the event timer.
+    m_timer.reactor(ACE_Reactor::instance());
+    m_timer.activate();
+    // Create the event handler and register to fire every 20 seconds
+    m_eventHandler = new MgServerConnectionEventHandler();
+    ACE_Time_Value interval = ACE_Time_Value(20);
+    ACE_Time_Value startTime = ACE_OS::gettimeofday() + interval;
+    m_id = m_timer.schedule(m_eventHandler, 0, startTime, interval);
 MgServerConnectionPool::~MgServerConnectionPool()
+    m_timer.cancel(m_id);
+    m_timer.deactivate();
+    m_timer.close();
+    // Remove the event handler.
+    if (NULL != m_eventHandler)
+        ACE_Reactor::instance()->remove_handler(m_eventHandler,
+            ACE_Event_Handler::TIMER_MASK | ACE_Event_Handler::DONT_CALL);
+    delete m_eventHandler;
+    m_eventHandler = NULL;
     ConnectionPool::iterator iter = pool.begin();
     while (iter != pool.end())
@@ -46,3 +72,54 @@
     delete this;
+MgServerConnectionPool* MgServerConnectionPool::GetInstance()
+    MG_TRY()
+    if (MgServerConnectionPool::sm_pool == NULL)
+        // Perform Double-Checked Locking Optimization.
+        ACE_MT (ACE_GUARD_RETURN (ACE_Recursive_Thread_Mutex, ace_mon, *ACE_Static_Object_Lock::instance (), 0));
+            MgServerConnectionPool::sm_pool = new MgServerConnectionPool();
+    MG_CATCH_AND_THROW(L"MgServerConnectionPool.GetInstance")
+    // To avoid overheads and maintain thread safety,
+    // do not assign this returned static singleton to a Ptr object.
+    return MgServerConnectionPool::sm_pool;
+void MgServerConnectionPool::CloseStaleConnections(ACE_Time_Value* timeValue)
+    ACE_MT (ACE_GUARD (ACE_Recursive_Thread_Mutex, ace_mon, *ACE_Static_Object_Lock::instance ()));
+    MG_TRY()
+    MgServerConnectionPool::ConnectionPool::iterator iter;
+    for (iter = MgServerConnectionPool::sm_pool->pool.begin();
+         iter != MgServerConnectionPool::sm_pool->pool.end();
+         iter++)
+        MgServerConnectionStack* stack = iter->second;
+        if (NULL != stack)
+            stack->CloseStaleConnections(timeValue);
+void MgServerConnectionPool::CloseConnections()
+    MG_TRY()
+    if (MgServerConnectionPool::sm_pool != NULL)
+            delete MgServerConnectionPool::sm_pool;
+            MgServerConnectionPool::sm_pool = NULL;
Modified: sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionPool.h
--- sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionPool.h	2010-03-22 16:49:37 UTC (rev 4680)
+++ sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionPool.h	2010-03-22 17:54:24 UTC (rev 4681)
@@ -24,10 +24,15 @@
 class MG_MAPGUIDE_API MgServerConnection;
 class MG_MAPGUIDE_API MgConnectionProperties;
+class MgServerConnectionEventHandler;
 #endif
 #include <map>
+#include "ace/Reactor.h"
+#include "ace/Timer_Queue_Adapters.h"
+#include "ace/Timer_Heap.h"
 class MgServerConnectionPool;
 template class MG_MAPGUIDE_API Ptr<MgServerConnectionPool>;
@@ -54,6 +59,21 @@
     virtual ~MgServerConnectionPool();
+    /// \brief
+    /// Return global instance
+    static MgServerConnectionPool* GetInstance();
+    /// \brief
+    /// Close expired connections
+    static void CloseStaleConnections(ACE_Time_Value* timeValue);
+    /// \brief
+    /// Close global instance and release all connections
+    static void CloseConnections();
     typedef std::map<wstring, MgServerConnectionStack*> ConnectionPool;
     ConnectionPool pool;
@@ -61,6 +81,13 @@
 protected:
     void Dispose();
+private:
+    ACE_Thread_Timer_Queue_Adapter<ACE_Timer_Heap> m_timer;
+    long m_id;
+    MgServerConnectionEventHandler* m_eventHandler;
+    static MgServerConnectionPool* sm_pool;
 /// \endcond
Modified: sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionStack.cpp
--- sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionStack.cpp	2010-03-22 16:49:37 UTC (rev 4680)
+++ sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionStack.cpp	2010-03-22 17:54:24 UTC (rev 4681)
@@ -145,20 +145,6 @@
-    // Remove a stale connection from the back of the queue
-    if (m_queue->size() > 0)
-        conn = m_queue->back();
-        if (NULL != conn && conn->IsStale(&now))
-            m_queue->pop_back();
-            SAFE_RELEASE(conn);
-            conn = NULL;
     // Pull a connection from the front of the queue and make sure it's valid.
     conn = NULL;
     while (NULL == conn && m_queue->size() > 0)
@@ -215,3 +201,26 @@
     SAFE_ADDREF(connection);
     m_inUse->push_back(connection);
+void MgServerConnectionStack::CloseStaleConnections(ACE_Time_Value* timeValue)
+    ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, m_mutex));
+    // Remove a stale connection from the back of the queue
+    // Work from the back of the queue until the connections are not stale
+    while (m_queue->size() > 0)
+        MgServerConnection* conn = m_queue->back();
+        if (NULL != conn && conn->IsStale(timeValue))
+            m_queue->pop_back();
+            SAFE_RELEASE(conn);
+            conn = NULL;
+        else
+            break;
Modified: sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionStack.h
--- sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionStack.h	2010-03-22 16:49:37 UTC (rev 4680)
+++ sandbox/adsk/2.2gp/Common/MapGuideCommon/Services/ServerConnectionStack.h	2010-03-22 17:54:24 UTC (rev 4681)
@@ -82,6 +82,11 @@
     void InUse(MgServerConnection* connection);
+    /// \brief
+    /// Close stale connections
+    void CloseStaleConnections(ACE_Time_Value* timeValue);
 private:
     typedef std::deque<MgServerConnection*> ConnectionQueue;
Modified: sandbox/adsk/2.2gp/Server/src/Common/Base/ClientHandler.cpp
--- sandbox/adsk/2.2gp/Server/src/Common/Base/ClientHandler.cpp	2010-03-22 16:49:37 UTC (rev 4680)
+++ sandbox/adsk/2.2gp/Server/src/Common/Base/ClientHandler.cpp	2010-03-22 17:54:24 UTC (rev 4681)
@@ -65,20 +65,6 @@
 /// </summary>
 MgClientHandler::~MgClientHandler()
-    // close writer and listen for ack
-    m_SockStream.close_writer();
-    char buf[256];
-    ssize_t len = 0;
-    while ((len = m_SockStream.recv((void*)buf, 256, MG_MSG_NOSIGNAL)) > 0)
-        // clearing out buffer
-    m_SockStream.close_reader();
-    m_SockStream.close();
     m_pMessageQueue = NULL;
     if (m_pConnection != NULL)
@@ -264,6 +250,7 @@
+    m_pMessageQueue->flush();
     MgServerManager* pServerManager = MgServerManager::GetInstance();
     if(pServerManager)
Modified: sandbox/adsk/2.2gp/Web/src/WebSupport/InitializeWebTier.cpp
--- sandbox/adsk/2.2gp/Web/src/WebSupport/InitializeWebTier.cpp	2010-03-22 16:49:37 UTC (rev 4680)
+++ sandbox/adsk/2.2gp/Web/src/WebSupport/InitializeWebTier.cpp	2010-03-22 17:54:24 UTC (rev 4681)
@@ -16,6 +16,7 @@
+#include "Services/ServerConnectionPool.h"
 // Initialize only once per process
@@ -65,6 +66,9 @@
     if (!m_bInitialized)
         return;
+    // Close all open connections before we drop ACE
+    MgServerConnectionPool::CloseConnections();
     // Uninitialize ACE
     ACE::fini();
More information about the mapguide-commits mailing list
