[mapguide-commits] r4825 - trunk/Tools/Maestro/MgCooker
svn_mapguide at osgeo.org
Tue May 4 01:19:35 EDT 2010
Author: jng
Date: 2010-05-04 01:19:34 -0400 (Tue, 04 May 2010)
New Revision: 4825
trunk/Tools/Maestro/MgCooker/SetupRun.cs
Fix #1343: Wrap the MgCooker.exe call in a pushd/popd pair so that it is guaranteed to be running from the directory that MgCooker.exe is in
Modified: trunk/Tools/Maestro/MgCooker/SetupRun.cs
--- trunk/Tools/Maestro/MgCooker/SetupRun.cs 2010-05-04 05:09:21 UTC (rev 4824)
+++ trunk/Tools/Maestro/MgCooker/SetupRun.cs 2010-05-04 05:19:34 UTC (rev 4825)
@@ -311,6 +311,9 @@
else
executable = System.IO.Path.Combine(Application.StartupPath, executable);
+ string exeName = System.IO.Path.GetFileName(executable);
+ string exePath = System.IO.Path.GetDirectoryName(executable);
executable = "\"" + executable + "\"";
using (System.IO.StreamWriter sw = new System.IO.StreamWriter(saveFileDialog1.FileName))
@@ -325,10 +328,26 @@
sw.WriteLine("@echo off");
+ //If on windows, wrap the exe call in a pushd/popd so that the executable is
+ //executed from its own directory
+ if (System.Environment.OSVersion.Platform != PlatformID.MacOSX ||
+ System.Environment.OSVersion.Platform != PlatformID.Unix)
+ sw.WriteLine("pushd \"" + exePath + "\"");
foreach (Config c in ReadTree())
- sw.Write(executable);
+ sw.Write(exeName);
+ else
+ sw.Write(executable);
sw.Write(" batch");
sw.Write(" --mapdefinitions=\"");
sw.Write(c.MapDefinition);
@@ -357,6 +376,12 @@
sw.Write(args.ToString());
sw.WriteLine();
+ sw.WriteLine("popd");
More information about the mapguide-commits
