[mapguide-commits] r4828 - branches/2.1/MgDev/Oem/LinuxApt
svn_mapguide at osgeo.org
Tue May 4 07:32:02 EDT 2010
Author: trevorwekel
Date: 2010-05-04 07:32:02 -0400 (Tue, 04 May 2010)
New Revision: 4828
branches/2.1/MgDev/Oem/LinuxApt/build_apt.sh
Ticket #1341 Include LDAP authentication for bundled Apache on Linux
- Sumbit updated build script for 2.1 stream
Modified: branches/2.1/MgDev/Oem/LinuxApt/build_apt.sh
--- branches/2.1/MgDev/Oem/LinuxApt/build_apt.sh 2010-05-04 08:27:49 UTC (rev 4827)
+++ branches/2.1/MgDev/Oem/LinuxApt/build_apt.sh 2010-05-04 11:32:02 UTC (rev 4828)
@@ -63,8 +63,8 @@
check_apache_build ()
- if [ $? -ne 0 ]; then
- error=$?
+ error=$?
+ if [ $error -ne 0 ]; then
echo "Apache build failed ($error)."
exit $error
fi
@@ -72,8 +72,8 @@
check_php_build ()
- error=$?
+ error=$?
echo "Php build failed ($error)."
exit $error
fi
@@ -81,8 +81,8 @@
check_apache_install ()
- error=$?
+ error=$?
echo "Apache install failed ($error)."
exit $error
fi
@@ -90,8 +90,8 @@
check_php_install ()
- error=$?
+ error=$?
echo "Php install failed ($error)."
exit $error
fi
@@ -99,8 +99,8 @@
check_tomcat_build ()
- error=$?
+ error=$?
echo "Tomcat build failed ($error)."
exit $error
fi
@@ -108,8 +108,8 @@
check_tomcat_install ()
- error=$?
+ error=$?
echo "Tomcat install failed ($error)."
exit $error
fi
@@ -120,9 +120,10 @@
# Notes: none
echo Apache Httpd build started
+tar -zxf httpd-2.2.4.tar.gz
pushd httpd-2.2.4
./configure --prefix=$INSTALLWEB/apache2 --enable-mods-shared=all \
---with-included-apr --with-port=$PORT
+--enable-ldap --with-ldap --enable-authnz-ldap --with-included-apr --with-port=$PORT
check_apache_build
make
check_apache_build
@@ -133,16 +134,19 @@
# Apache shutdown procedure
# Notes: none
-echo Attempting to shutdown Apache
-pushd $INSTALLWEB/apache2/bin
-./apachectl stop
-popd
-echo Attempting to remove old Apache and Php
-pushd $INSTALLWEB
-rm -rf apache2
-rm -rf php
-popd
-echo Completed uninstall of Apache and Php
+echo Checking for existing Apache install
+if [ -d $INSTALLWEB/apache2/bin ]; then
+ echo Attempting to shutdown Apache
+ pushd $INSTALLWEB/apache2/bin
+ ./apachectl stop
+ popd
+ echo Attempting to remove old Apache and Php
+ pushd $INSTALLWEB
+ rm -rf apache2
+ rm -rf php
+ popd
+ echo Completed uninstall of Apache and Php
+fi
# Apache install procedure
@@ -173,13 +177,21 @@
popd
-# Create symlink for agent.
+# Create dummy mapagent.fcgi and symlinks for module.
mkdir -p $INSTALLWEB/www/mapagent
mkdir $INSTALLWEB/bin
pushd $INSTALLWEB/www/mapagent
-ln -s ../../bin/mapagent mapagent.fcgi
+cat > mapagent.fcgi <<END-OF-FCGI
+// Empty file. IIS application mappings and Apache script aliases are
+used to bind this file to the actual MapAgent binaries
+END-OF-FCGI
popd
+mkdir -p $INSTALLWEB/lib
+pushd $INSTALLWEB/apache2/modules
+ln -s ../../lib/mod_mgmapagent.so mod_mgmapagent.so
+popd
# Php build procedure
# Notes: none
@@ -212,6 +224,7 @@
if [ "$TOMCAT" = "1" ]; then
echo Tomcat connector build/install started
+tar -zxf tomcat-connectors-1.2.25-src.tar.gz
pushd tomcat-connectors-1.2.25-src/native
./configure --with-apxs=$INSTALLWEB/apache2/bin/apxs
@@ -255,41 +268,64 @@
rm httpd.conf.mgorig_
popd
+# Required modifications for envvars
+pushd $INSTALLWEB/apache2/bin
+cat >> envvars <<END-OF-ENVVARS
+export LD_LIBRARY_PATH=$INSTALLWEB/lib:$INSTALLWEB/php/lib:$INSTALLDIR/lib
+export MENTOR_DICTIONARY_PATH=$INSTALLDIR/share/gis/coordsys
+END-OF-ENVVARS
+popd
# Required modifications to httpd.conf, append to mapguide.conf
pushd $INSTALLWEB/apache2/conf
cat >> mapguide.conf <<END-OF-CONFIGURATION
# Environment variables for MapGuide
SetEnv LD_LIBRARY_PATH "$INSTALLWEB/lib:$INSTALLWEB/php/lib:$INSTALLDIR/lib"
-SetEnv GDAL_DATA $INSTALLDIR/share/gdal
-SetEnv PROJ_LIB $INSTALLDIR/share/proj
+SetEnv MENTOR_DICTIONARY_PATH "$INSTALLDIR/share/gis/coordsys"
-#LoadModule mgmapagent_module modules/mod_mgmapagent.so
+LoadModule mgmapagent_module modules/mod_mgmapagent.so
+RewriteEngine On
#START NormalCGI PHP configuration
#ScriptAlias /php/ "$INSTALLWEB/php/bin/"
#Action application/x-httpd-php "/php/php"
#AddType application/x-httpd-php .php
#END NormalCGI PHP configuration
-# MapViewer to MapViewerPhp aliases
-ScriptAlias /mapguide/mapagent/mapagent "$INSTALLWEB/www/mapagent/mapagent"
-AliasMatch ^/mapguide/mapviewerajax/([^\?])(.*)$ "$INSTALLWEB/www/mapviewerphp/\$1\$2"
-AliasMatch ^/mapguide/mapviewerajax/(.*)$ "$INSTALLWEB/www/mapviewerphp/ajaxviewer.php\$1"
-AliasMatch ^/mapguide/mapviewerdwf/([^\?])(.*)$ "$INSTALLWEB/www/mapviewerphp/\$1\$2"
-AliasMatch ^/mapguide/mapviewerdwf/(.*)$ "$INSTALLWEB/www/mapviewerphp/dwfviewer.php\$1"
+# CGI agent alias
+#ScriptAlias /mapguide/mapagent/mapagent.fcgi "$INSTALLWEB/www/mapagent/mapagent"
+# mapviewerajax to mapviewerphp rewrite rules
+# comment out for java api/viewer
+RewriteRule ^/mapguide/mapviewerajax/([^\?])(.*)$ /mapguide/mapviewerphp/\$1\$2 [PT]
+RewriteRule ^/mapguide/mapviewerajax/(.*)$ /mapguide/mapviewerphp/ajaxviewer.php\$1 [PT]
+RewriteRule ^/mapguide/mapviewerdwf/([^\?])(.*)$ /mapguide/mapviewerphp/\$1\$2 [PT]
+RewriteRule ^/mapguide/mapviewerdwf/(.*)$ /mapguide/mapviewerphp/dwfviewer.php\$1 [PT]
+# mapviewerajax to mapviewerjava aliases
+# uncomment for java api/viewer
+#RewriteRule ^/mapguide/mapviewerajax/([^\?])(.*)$ /mapguide/mapviewerjava/\$1\$2 [PT]
+#RewriteRule ^/mapguide/mapviewerajax/(.*)$ /mapguide/mapviewerjava/ajaxviewer.jsp\$1 [PT]
+#RewriteRule ^/mapguide/mapviewerdwf/([^\?])(.*)$ /mapguide/mapviewerjava/\$1\$2 [PT]
+#RewriteRule ^/mapguide/mapviewerdwf/(.*)$ /mapguide/mapviewerjava/dwfviewer.jsp\$1 [PT]
Alias /mapguide "$INSTALLWEB/www/"
<Directory "$INSTALLWEB/www/">
AllowOverride All
Options All
Order allow,deny
Allow from all
-AddHandler php5-script .php
-#AddHandler mgmapagent_handler fcgi
+ AddHandler php5-script .php
+ AddHandler mgmapagent_handler fcgi
RewriteEngine on
RewriteRule .* - [E=REMOTE_USER:%{HTTP:Authorization},L]
</Directory>
popd
@@ -303,9 +339,8 @@
echo Tomcat configuration started
#Tomcat Integration
-#Taken from http://tomcat.apache.org/connectors-doc/howto/quick.html
# Load mod_jk module
# Update this path to match your modules location
LoadModule jk_module modules/mod_jk.so
@@ -328,6 +363,7 @@
# Send everything for context /examples to worker named worker1 (ajp13)
JkMount /mapguide/mapviewerjava/* worker1
JkMount /mapguide/javaviewersample/* worker1
cat > workers.properties <<END-OF-CONFIGURATION
@@ -345,6 +381,11 @@
popd
+if [ ! -d $INSTALLWEB/tomcat/conf/Catalina/localhost ]; then
+mkdir -p $INSTALLWEB/tomcat/conf/Catalina/localhost
+fi
pushd $INSTALLWEB/tomcat/conf/Catalina/localhost
cat > mapguide.xml <<END_OF_CONFIGURATION
@@ -371,6 +412,23 @@
mv -f $INSTALLWEB/tomcat/conf/server.xml $INSTALLWEB/tomcat/conf/server_orig.xml
cp -f server.xml $INSTALLWEB/tomcat/conf
+pushd $INSTALLWEB/tomcat/bin
+if [ ! -e startup.sh.orig ]; then
+mv startup.sh startup.sh.orig
+fi
+LIB_PATH=$INSTALLWEB/lib:$INSTALLDIR/lib
+cat > startup.sh <<END_OF_CONFIGURATION
+#!/bin/bash
+export LD_LIBRARY_PATH=$LIB_PATH
+export JAVA_OPTS="-Djava.library.path=$LIB_PATH"
+END_OF_CONFIGURATION
+cat startup.sh.orig >> startup.sh
+chmod 755 startup.sh
+popd
echo Tomcat configuration completed
fi
@@ -431,8 +489,6 @@
echo Tomcat startup
-export LD_LIBRARY_PATH=$INSTALLWEB/lib:$INSTALLDIR/lib:$LD_LIBRARY_PATH
-export JAVA_OPTS="-Djava.library.path=$LD_LIBRARY_PATH"
./startup.sh
popd
More information about the mapguide-commits
