[mapguide-commits] r4851 - in sandbox/maestro-2.5: Maestro
Maestro.Base Maestro.Base/Commands
Maestro.Base/Commands/SiteExplorer Maestro.Base/Properties
Maestro.Base/Resources Maestro.Base/UI
svn_mapguide at osgeo.org
Tue May 11 08:17:47 EDT 2010
Author: jng
Date: 2010-05-11 08:17:46 -0400 (Tue, 11 May 2010)
New Revision: 4851
Added:
sandbox/maestro-2.5/Maestro.Base/Commands/AboutCommand.cs
sandbox/maestro-2.5/Maestro.Base/Commands/LoginCommand.cs
sandbox/maestro-2.5/Maestro.Base/Commands/LogoutCommand.cs
sandbox/maestro-2.5/Maestro.Base/Commands/OptionsCommand.cs
sandbox/maestro-2.5/Maestro.Base/Commands/SiteExplorer/
sandbox/maestro-2.5/Maestro.Base/Commands/SiteExplorer/DisconnectCommand.cs
sandbox/maestro-2.5/Maestro.Base/Commands/SiteExplorer/RefreshCommand.cs
sandbox/maestro-2.5/Maestro.Base/Resources/arrow-circle-045-left.png
sandbox/maestro-2.5/Maestro.Base/Resources/plug--minus.png
sandbox/maestro-2.5/Maestro.Base/UI/
sandbox/maestro-2.5/Maestro.Base/UI/SiteExplorer.Designer.cs
sandbox/maestro-2.5/Maestro.Base/UI/SiteExplorer.cs
sandbox/maestro-2.5/Maestro.Base/UI/SiteExplorer.resx
Removed:
sandbox/maestro-2.5/Maestro.Base/SiteExplorer.Designer.cs
sandbox/maestro-2.5/Maestro.Base/SiteExplorer.cs
sandbox/maestro-2.5/Maestro.Base/SiteExplorer.resx
sandbox/maestro-2.5/Maestro.Base/Commands/StartupCommand.cs
sandbox/maestro-2.5/Maestro.Base/Maestro.Base.addin
sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-2.5/Maestro.Base/Properties/Resources.Designer.cs
sandbox/maestro-2.5/Maestro.Base/Properties/Resources.resx
sandbox/maestro-2.5/Maestro/
Add a whole bunch of dummy commands.
Property changes on: sandbox/maestro-2.5/Maestro
___________________________________________________________________
Modified: svn:ignore
- Maestro.suo
+ Maestro.suo
obj
Property changes on: sandbox/maestro-2.5/Maestro.Base
Added: svn:ignore
+ obj
Added: sandbox/maestro-2.5/Maestro.Base/Commands/AboutCommand.cs
--- sandbox/maestro-2.5/Maestro.Base/Commands/AboutCommand.cs (rev 0)
+++ sandbox/maestro-2.5/Maestro.Base/Commands/AboutCommand.cs 2010-05-11 12:17:46 UTC (rev 4851)
@@ -0,0 +1,29 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+namespace Maestro.Base.Commands
+ internal class AboutCommand : NotImplementedCommand
Added: sandbox/maestro-2.5/Maestro.Base/Commands/LoginCommand.cs
--- sandbox/maestro-2.5/Maestro.Base/Commands/LoginCommand.cs (rev 0)
+++ sandbox/maestro-2.5/Maestro.Base/Commands/LoginCommand.cs 2010-05-11 12:17:46 UTC (rev 4851)
@@ -0,0 +1,29 @@
+#endregion
+using System;
+using System.Text;
+ internal class LoginCommand : NotImplementedCommand
Added: sandbox/maestro-2.5/Maestro.Base/Commands/LogoutCommand.cs
--- sandbox/maestro-2.5/Maestro.Base/Commands/LogoutCommand.cs (rev 0)
+++ sandbox/maestro-2.5/Maestro.Base/Commands/LogoutCommand.cs 2010-05-11 12:17:46 UTC (rev 4851)
@@ -0,0 +1,29 @@
+#endregion
+using System;
+using System.Text;
+ internal class LogoutCommand : NotImplementedCommand
Added: sandbox/maestro-2.5/Maestro.Base/Commands/OptionsCommand.cs
--- sandbox/maestro-2.5/Maestro.Base/Commands/OptionsCommand.cs (rev 0)
+++ sandbox/maestro-2.5/Maestro.Base/Commands/OptionsCommand.cs 2010-05-11 12:17:46 UTC (rev 4851)
@@ -0,0 +1,29 @@
+#endregion
+using System;
+using System.Text;
+ internal class OptionsCommand : NotImplementedCommand
Added: sandbox/maestro-2.5/Maestro.Base/Commands/SiteExplorer/DisconnectCommand.cs
--- sandbox/maestro-2.5/Maestro.Base/Commands/SiteExplorer/DisconnectCommand.cs (rev 0)
+++ sandbox/maestro-2.5/Maestro.Base/Commands/SiteExplorer/DisconnectCommand.cs 2010-05-11 12:17:46 UTC (rev 4851)
@@ -0,0 +1,29 @@
+#endregion
+using System;
+using System.Text;
+namespace Maestro.Base.Commands.SiteExplorer
+ internal class DisconnectCommand : NotImplementedCommand
Added: sandbox/maestro-2.5/Maestro.Base/Commands/SiteExplorer/RefreshCommand.cs
--- sandbox/maestro-2.5/Maestro.Base/Commands/SiteExplorer/RefreshCommand.cs (rev 0)
+++ sandbox/maestro-2.5/Maestro.Base/Commands/SiteExplorer/RefreshCommand.cs 2010-05-11 12:17:46 UTC (rev 4851)
@@ -0,0 +1,29 @@
+#endregion
+using System;
+using System.Text;
+ internal class RefreshCommand : NotImplementedCommand
Modified: sandbox/maestro-2.5/Maestro.Base/Commands/StartupCommand.cs
--- sandbox/maestro-2.5/Maestro.Base/Commands/StartupCommand.cs 2010-05-11 11:40:15 UTC (rev 4850)
+++ sandbox/maestro-2.5/Maestro.Base/Commands/StartupCommand.cs 2010-05-11 12:17:46 UTC (rev 4851)
@@ -29,6 +29,7 @@
public override void Run()
+ ResourceService.RegisterNeutralImages(Properties.Resources.ResourceManager);
ResourceService.RegisterNeutralStrings(Properties.Resources.ResourceManager);
Workbench.WorkbenchInitialized += (sender, e) =>
@@ -36,7 +37,7 @@
var wb = Workbench.Instance;
wb.Text = "MapGuide Maestro";
- //var exp = new SiteExplorer();
+ //var exp = new UI.SiteExplorer();
//wb.ShowContent(exp, ViewRegion.Left);
Modified: sandbox/maestro-2.5/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-2.5/Maestro.Base/Maestro.Base.addin 2010-05-11 11:40:15 UTC (rev 4850)
+++ sandbox/maestro-2.5/Maestro.Base/Maestro.Base.addin 2010-05-11 12:17:46 UTC (rev 4851)
@@ -17,6 +17,7 @@
<MenuItem id="Menu_File"
type="Menu"
label="${res:Menu_File}">
+ <MenuItem type="Separator" />
<MenuItem id="Menu_File_Quit"
label="${res:Menu_File_Quit}"
class="Maestro.Base.Commands.QuitCommand" />
@@ -24,14 +25,16 @@
<MenuItem id="Menu_Tools"
type="Menu"
label="${res:Menu_Tools}">
+ <MenuItem id="Menu_Tools_Options"
+ label="${res:Menu_Tools_Options}"
+ class="Maestro.Base.Commands.OptionsCommand"/>
</MenuItem>
<MenuItem id="Menu_Help"
type="Menu"
label="${res:Menu_Help}">
<MenuItem id="Menu_Help_About"
label="${res:Menu_Help_About}"
- class="Maestro.Base.Commands.NotImplementedCommand" />
+ class="Maestro.Base.Commands.AboutCommand" />
</MenuItem>
</Path>
@@ -45,4 +48,21 @@
</Path>
+ <!-- Site Explorer Toolbar -->
+ <Path name="/Maestro/Shell/SiteExplorer/Toolbar">
+ <ToolbarItem id="SiteExplorer_Refresh"
+ label="${res:SiteExplorer_Refresh}"
+ icon="arrow-circle-045-left"
+ class="Maestro.Base.Commands.SiteExplorer.RefreshCommand" />
+ <ToolbarItem id="SiteExplorer_Disconnect"
+ label="${res:SiteExplorer_Disconnect}"
+ icon="plug--minus"
+ class="Maestro.Base.Commands.SiteExplorer.DisconnectCommand" />
+ </Path>
+ <!-- Site Explorer Context Menu -->
+ <Path name="/Maestro/Shell/SiteExplorer/ContextMenu">
+ </Path>
</AddIn>
\ No newline at end of file
Modified: sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj 2010-05-11 11:40:15 UTC (rev 4850)
+++ sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj 2010-05-11 12:17:46 UTC (rev 4851)
@@ -38,8 +38,14 @@
<Reference Include="System.Xml" />
</ItemGroup>
<ItemGroup>
+ <Compile Include="Commands\AboutCommand.cs" />
+ <Compile Include="Commands\LoginCommand.cs" />
+ <Compile Include="Commands\LogoutCommand.cs" />
<Compile Include="Commands\NotImplementedCommand.cs" />
+ <Compile Include="Commands\OptionsCommand.cs" />
<Compile Include="Commands\QuitCommand.cs" />
+ <Compile Include="Commands\SiteExplorer\DisconnectCommand.cs" />
+ <Compile Include="Commands\SiteExplorer\RefreshCommand.cs" />
<Compile Include="Commands\StartupCommand.cs" />
<Compile Include="ISubView.cs" />
<Compile Include="IViewContent.cs" />
@@ -49,10 +55,10 @@
<DesignTime>True</DesignTime>
<DependentUpon>Resources.resx</DependentUpon>
</Compile>
- <Compile Include="SiteExplorer.cs">
+ <Compile Include="UI\SiteExplorer.cs">
<SubType>UserControl</SubType>
</Compile>
- <Compile Include="SiteExplorer.Designer.cs">
+ <Compile Include="UI\SiteExplorer.Designer.cs">
<DependentUpon>SiteExplorer.cs</DependentUpon>
</Compile>
<Compile Include="TabFactory.cs" />
@@ -78,6 +84,8 @@
</ItemGroup>
<ItemGroup>
<Content Include="Maestro.Base.addin" />
+ <None Include="Resources\arrow-circle-045-left.png" />
+ <None Include="Resources\plug--minus.png" />
<None Include="Resources\server.png" />
<None Include="Resources\MapGuide Maestro.ico" />
</ItemGroup>
@@ -87,7 +95,7 @@
<LastGenOutput>Resources.Designer.cs</LastGenOutput>
<SubType>Designer</SubType>
</EmbeddedResource>
- <EmbeddedResource Include="SiteExplorer.resx">
+ <EmbeddedResource Include="UI\SiteExplorer.resx">
</EmbeddedResource>
Modified: sandbox/maestro-2.5/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-2.5/Maestro.Base/Properties/Resources.Designer.cs 2010-05-11 11:40:15 UTC (rev 4850)
+++ sandbox/maestro-2.5/Maestro.Base/Properties/Resources.Designer.cs 2010-05-11 12:17:46 UTC (rev 4851)
@@ -60,6 +60,13 @@
+ internal static System.Drawing.Bitmap arrow_circle_045_left {
+ get {
+ object obj = ResourceManager.GetObject("arrow-circle-045-left", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
/// <summary>
/// Looks up a localized string similar to Site Explorer: {0}.
/// </summary>
@@ -86,6 +93,15 @@
/// <summary>
+ /// Looks up a localized string similar to Login.
+ /// </summary>
+ internal static string Menu_File_Login {
+ get {
+ return ResourceManager.GetString("Menu_File_Login", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Quit.
/// </summary>
internal static string Menu_File_Quit {
@@ -121,11 +137,45 @@
+ /// <summary>
+ /// Looks up a localized string similar to Options.
+ /// </summary>
+ internal static string Menu_Tools_Options {
+ get {
+ return ResourceManager.GetString("Menu_Tools_Options", resourceCulture);
+ internal static System.Drawing.Bitmap plug__minus {
+ get {
+ object obj = ResourceManager.GetObject("plug--minus", resourceCulture);
internal static System.Drawing.Bitmap server {
get {
object obj = ResourceManager.GetObject("server", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Disconnect.
+ /// </summary>
+ internal static string SiteExplorer_Disconnect {
+ get {
+ return ResourceManager.GetString("SiteExplorer_Disconnect", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Refresh.
+ /// </summary>
+ internal static string SiteExplorer_Refresh {
+ get {
+ return ResourceManager.GetString("SiteExplorer_Refresh", resourceCulture);
Modified: sandbox/maestro-2.5/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-2.5/Maestro.Base/Properties/Resources.resx 2010-05-11 11:40:15 UTC (rev 4850)
+++ sandbox/maestro-2.5/Maestro.Base/Properties/Resources.resx 2010-05-11 12:17:46 UTC (rev 4851)
@@ -117,12 +117,21 @@
<resheader name="writer">
<value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
+ <data name="Menu_Help_About" xml:space="preserve">
+ <value>About</value>
+ </data>
<data name="Content_SiteExplorer" xml:space="preserve">
<value>Site Explorer: {0}</value>
</data>
+ <data name="Menu_Help" xml:space="preserve">
+ <value>Help</value>
+ </data>
+ <data name="Menu_Tools" xml:space="preserve">
+ <value>Tools</value>
+ </data>
<assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
- <data name="MapGuide_Maestro" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\MapGuide Maestro.ico;System.Drawing.Icon, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="plug--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\plug--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="Menu_File" xml:space="preserve">
<value>File</value>
@@ -130,16 +139,25 @@
<data name="Menu_File_Quit" xml:space="preserve">
<value>Quit</value>
</data>
- <data name="Menu_Help" xml:space="preserve">
- <value>Help</value>
+ <data name="MapGuide_Maestro" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\MapGuide Maestro.ico;System.Drawing.Icon, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="Menu_Help_About" xml:space="preserve">
- <value>About</value>
- </data>
- <data name="Menu_Tools" xml:space="preserve">
- <value>Tools</value>
- </data>
<data name="server" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\server.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="arrow-circle-045-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-circle-045-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="Menu_File_Login" xml:space="preserve">
+ <value>Login</value>
+ </data>
+ <data name="Menu_Tools_Options" xml:space="preserve">
+ <value>Options</value>
+ </data>
+ <data name="SiteExplorer_Disconnect" xml:space="preserve">
+ <value>Disconnect</value>
+ </data>
+ <data name="SiteExplorer_Refresh" xml:space="preserve">
+ <value>Refresh</value>
+ </data>
</root>
Added: sandbox/maestro-2.5/Maestro.Base/Resources/arrow-circle-045-left.png
(Binary files differ)
Property changes on: sandbox/maestro-2.5/Maestro.Base/Resources/arrow-circle-045-left.png
Added: svn:mime-type
+ application/octet-stream
Added: sandbox/maestro-2.5/Maestro.Base/Resources/plug--minus.png
Property changes on: sandbox/maestro-2.5/Maestro.Base/Resources/plug--minus.png
Deleted: sandbox/maestro-2.5/Maestro.Base/SiteExplorer.Designer.cs
--- sandbox/maestro-2.5/Maestro.Base/SiteExplorer.Designer.cs 2010-05-11 11:40:15 UTC (rev 4850)
+++ sandbox/maestro-2.5/Maestro.Base/SiteExplorer.Designer.cs 2010-05-11 12:17:46 UTC (rev 4851)
@@ -1,69 +0,0 @@
-namespace Maestro.Base
- partial class SiteExplorer
- /// <summary>
- /// Required designer variable.
- /// </summary>
- private System.ComponentModel.IContainer components = null;
- /// <summary>
- /// Clean up any resources being used.
- /// </summary>
- /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
- protected override void Dispose(bool disposing)
- if (disposing && (components != null))
- components.Dispose();
- base.Dispose(disposing);
- #region Component Designer generated code
- /// <summary>
- /// Required method for Designer support - do not modify
- /// the contents of this method with the code editor.
- /// </summary>
- private void InitializeComponent()
- this.toolStrip1 = new System.Windows.Forms.ToolStrip();
- this.trvResources = new System.Windows.Forms.TreeView();
- this.SuspendLayout();
- // toolStrip1
- this.toolStrip1.Location = new System.Drawing.Point(0, 0);
- this.toolStrip1.Name = "toolStrip1";
- this.toolStrip1.Size = new System.Drawing.Size(233, 25);
- this.toolStrip1.TabIndex = 0;
- this.toolStrip1.Text = "toolStrip1";
- // trvResources
- this.trvResources.Dock = System.Windows.Forms.DockStyle.Fill;
- this.trvResources.Location = new System.Drawing.Point(0, 25);
- this.trvResources.Name = "trvResources";
- this.trvResources.Size = new System.Drawing.Size(233, 458);
- this.trvResources.TabIndex = 1;
- // SiteExplorer
- this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
- this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
- this.Controls.Add(this.trvResources);
- this.Controls.Add(this.toolStrip1);
- this.Name = "SiteExplorer";
- this.Size = new System.Drawing.Size(233, 483);
- this.ResumeLayout(false);
- this.PerformLayout();
- #endregion
- private System.Windows.Forms.ToolStrip toolStrip1;
- private System.Windows.Forms.TreeView trvResources;
Deleted: sandbox/maestro-2.5/Maestro.Base/SiteExplorer.cs
--- sandbox/maestro-2.5/Maestro.Base/SiteExplorer.cs 2010-05-11 11:40:15 UTC (rev 4850)
+++ sandbox/maestro-2.5/Maestro.Base/SiteExplorer.cs 2010-05-11 12:17:46 UTC (rev 4851)
@@ -1,38 +0,0 @@
-#region Disclaimer / License
-// Copyright (C) 2010, Jackie Ng
-// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of the GNU Lesser General Public
-// License as published by the Free Software Foundation; either
-// version 2.1 of the License, or (at your option) any later version.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
-#endregion
-using System;
-using System.Collections.Generic;
-using System.ComponentModel;
-using System.Drawing;
-using System.Data;
-using System.Text;
-using System.Windows.Forms;
- public partial class SiteExplorer : ViewContentBase
- public SiteExplorer()
- InitializeComponent();
- this.Title = string.Format(Properties.Resources.Content_SiteExplorer, "Test");
Deleted: sandbox/maestro-2.5/Maestro.Base/SiteExplorer.resx
--- sandbox/maestro-2.5/Maestro.Base/SiteExplorer.resx 2010-05-11 11:40:15 UTC (rev 4850)
+++ sandbox/maestro-2.5/Maestro.Base/SiteExplorer.resx 2010-05-11 12:17:46 UTC (rev 4851)
@@ -1,123 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<root>
- Microsoft ResX Schema
- Version 2.0
- The primary goals of this format is to allow a simple XML format
- that is mostly human readable. The generation and parsing of the
- various data types are done through the TypeConverter classes
- associated with the data types.
- Example:
- ... ado.net/XML headers & schema ...
- <resheader name="resmimetype">text/microsoft-resx</resheader>
- <resheader name="version">2.0</resheader>
- <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
- <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
- <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
- <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
- <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
- <value>[base64 mime encoded serialized .NET Framework object]</value>
- </data>
- <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
- <comment>This is a comment</comment>
- </data>
- There are any number of "resheader" rows that contain simple
- name/value pairs.
- Each data row contains a name, and value. The row also contains a
- type or mimetype. Type corresponds to a .NET class that support
- text/value conversion through the TypeConverter architecture.
- Classes that don't support this are serialized and stored with the
- mimetype set.
- The mimetype is used for serialized objects, and tells the
- ResXResourceReader how to depersist the object. This is currently not
- extensible. For a given mimetype the value must be set accordingly:
- Note - application/x-microsoft.net.object.binary.base64 is the format
- that the ResXResourceWriter will generate, however the reader can
- read any of the formats listed below.
- mimetype: application/x-microsoft.net.object.binary.base64
- value : The object must be serialized with
- : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
- : and then encoded with base64 encoding.
- mimetype: application/x-microsoft.net.object.soap.base64
- : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
- mimetype: application/x-microsoft.net.object.bytearray.base64
- value : The object must be serialized into a byte array
- : using a System.ComponentModel.TypeConverter
- <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
- <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
- <xsd:element name="root" msdata:IsDataSet="true">
- <xsd:complexType>
- <xsd:choice maxOccurs="unbounded">
- <xsd:element name="metadata">
- <xsd:complexType>
- <xsd:sequence>
- <xsd:element name="value" type="xsd:string" minOccurs="0" />
- </xsd:sequence>
- <xsd:attribute name="name" use="required" type="xsd:string" />
- <xsd:attribute name="type" type="xsd:string" />
- <xsd:attribute name="mimetype" type="xsd:string" />
- <xsd:attribute ref="xml:space" />
- </xsd:complexType>
- </xsd:element>
- <xsd:element name="assembly">
- <xsd:complexType>
- <xsd:attribute name="alias" type="xsd:string" />
- <xsd:attribute name="name" type="xsd:string" />
- </xsd:element>
- <xsd:element name="data">
- <xsd:complexType>
- <xsd:sequence>
- <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
- <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
- </xsd:sequence>
- <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
- <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
- <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
- </xsd:element>
- <xsd:element name="resheader">
- <xsd:complexType>
- <xsd:sequence>
- </xsd:sequence>
- <xsd:attribute name="name" type="xsd:string" use="required" />
- </xsd:element>
- </xsd:choice>
- </xsd:element>
- </xsd:schema>
- <value>text/microsoft-resx</value>
- </resheader>
- <value>2.0</value>
- </resheader>
- <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </resheader>
- <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </resheader>
- <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 17</value>
- </metadata>
-</root>
Added: sandbox/maestro-2.5/Maestro.Base/UI/SiteExplorer.Designer.cs
--- sandbox/maestro-2.5/Maestro.Base/UI/SiteExplorer.Designer.cs (rev 0)
+++ sandbox/maestro-2.5/Maestro.Base/UI/SiteExplorer.Designer.cs 2010-05-11 12:17:46 UTC (rev 4851)
@@ -0,0 +1,46 @@
+namespace Maestro.Base.UI
+ partial class SiteExplorer
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Component Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.SuspendLayout();
+ // SiteExplorer
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Name = "SiteExplorer";
+ this.Size = new System.Drawing.Size(233, 483);
+ this.ResumeLayout(false);
+ #endregion
Added: sandbox/maestro-2.5/Maestro.Base/UI/SiteExplorer.cs
--- sandbox/maestro-2.5/Maestro.Base/UI/SiteExplorer.cs (rev 0)
+++ sandbox/maestro-2.5/Maestro.Base/UI/SiteExplorer.cs 2010-05-11 12:17:46 UTC (rev 4851)
@@ -0,0 +1,54 @@
+#endregion
+using System;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Text;
+using System.Windows.Forms;
+using ICSharpCode.Core.WinForms;
+ public partial class SiteExplorer : ViewContentBase
+ private ToolStrip toolStrip;
+ private TreeView trvResources;
+ private ContextMenuStrip trvContextMenu;
+ public SiteExplorer()
+ InitializeComponent();
+ protected override void OnLoad(EventArgs e)
+ this.Title = string.Format(Properties.Resources.Content_SiteExplorer, "Test");
+ toolStrip = ToolbarService.CreateToolStrip(this, "/Maestro/Shell/SiteExplorer/Toolbar");
+ trvResources = new TreeView();
+ trvContextMenu = MenuService.CreateContextMenu(this, "/Maestro/Shell/SiteExplorer/ContextMenu");
+ toolStrip.Dock = DockStyle.Top;
+ trvResources.Dock = DockStyle.Fill;
+ this.Controls.Add(toolStrip);
+ this.Controls.Add(trvResources);
Added: sandbox/maestro-2.5/Maestro.Base/UI/SiteExplorer.resx
--- sandbox/maestro-2.5/Maestro.Base/UI/SiteExplorer.resx (rev 0)
+++ sandbox/maestro-2.5/Maestro.Base/UI/SiteExplorer.resx 2010-05-11 12:17:46 UTC (rev 4851)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
More information about the mapguide-commits
