[mapguide-commits] r4855 - in sandbox/adsk/2.1: Server/src/Core
Web/src
svn_mapguide at osgeo.org
Tue May 11 17:38:31 EDT 2010
Author: brucedechant
Date: 2010-05-11 17:38:30 -0400 (Tue, 11 May 2010)
New Revision: 4855
sandbox/adsk/2.1/Server/src/Core/serverconfig.ini
sandbox/adsk/2.1/Web/src/webconfig.ini
Notes:
- Remove ini file settings that are hidden at this time.
Modified: sandbox/adsk/2.1/Server/src/Core/serverconfig.ini
--- sandbox/adsk/2.1/Server/src/Core/serverconfig.ini 2010-05-11 17:48:21 UTC (rev 4854)
+++ sandbox/adsk/2.1/Server/src/Core/serverconfig.ini 2010-05-11 21:38:30 UTC (rev 4855)
@@ -460,23 +460,6 @@
Filename = "Error.log"
Parameters = CLIENT,CLIENTIP,USER,ERROR,STACKTRACE
-[PerformanceLogProperties]
-# P E R F O R M A N C E L O G
-# Property Name Description
-# Enabled 0 = log disabled, 1 = log enabled
-# Filename Name of the log file
-# Parameters Log parameters
-# Interval Time interval in seconds for when the server
-# writes the performance information to the log
-Enabled = 0
-Filename = "Performance.log"
-Parameters = ADMINOPQCOUNT,CLIENTOPQCOUNT,SITEOPQCOUNT,AVGOPTIME,CPU,WORKINGSET,VIRTUALMEMORY,TOTALOPTIME,TOTALACTIVECONNECTIONS,TOTALCONNECTIONS,TOTALPROCESSEDOP,TOTALRECEIVEDOP,UPTIME, CACHESIZE, CACHEDROPPEDENTRIES
-Interval = 300
[SessionLogProperties]
# S E S S I O N L O G
Modified: sandbox/adsk/2.1/Web/src/webconfig.ini
--- sandbox/adsk/2.1/Web/src/webconfig.ini 2010-05-11 17:48:21 UTC (rev 4854)
+++ sandbox/adsk/2.1/Web/src/webconfig.ini 2010-05-11 21:38:30 UTC (rev 4855)
@@ -39,14 +39,12 @@
# case and the last 2 characters must
# be upper case.
-# LogsPath Path where log files are stored
# ResourcesPath Path where the localization resource files are stored
# TcpIpMtu The TCP/IP maximum transmission unit
# 0 < Value <= 65535
# TempPath Path where the temporary files are stored
DefaultMessageLocale = en
-LogsPath = Logs/
ResourcesPath = Resources/
TcpIpMtu = 1460
TempPath = Temp/
@@ -117,19 +115,11 @@
# 0 = false and 1 = true
# DisableWms Disables OGC Wms HTTP requests
-# ErrorLogEnabled 0 = log disabled, 1 = log enabled
-# ErrorLogFilename Name of the log file
-# RequestLogEnabled 0 = log disabled, 1 = log enabled
-# RequestLogFilename Name of the log file
DebugPause = 0
DisableAuthoring = 0
DisableWfs = 0
DisableWms = 0
-ErrorLogEnabled = 0
-ErrorLogFilename = Error.log
-RequestLogEnabled = 0
-RequestLogFilename = Request.log
[OgcProperties]
More information about the mapguide-commits
