[mapguide-commits] r4859 - in sandbox/maestro-2.5: Maestro.Base
MaestroAPITests OSGeo.MapGuide.MaestroAPI
svn_mapguide at osgeo.org
Wed May 12 12:55:36 EDT 2010
Author: jng
Date: 2010-05-12 12:55:36 -0400 (Wed, 12 May 2010)
New Revision: 4859
Added:
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Platform.cs
sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-2.5/Maestro.Base/Workbench.cs
sandbox/maestro-2.5/MaestroAPITests/
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
- Add a platform detection class (ie. To check whether we're running in Mono)
- Allow toolbar visibility to be tweaked on the Workbench even if there is no visible toolbars.
Modified: sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj 2010-05-12 16:16:21 UTC (rev 4858)
+++ sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj 2010-05-12 16:55:36 UTC (rev 4859)
@@ -109,6 +109,10 @@
</EmbeddedResource>
</ItemGroup>
<ItemGroup>
+ <ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI\OSGeo.MapGuide.MaestroAPI.csproj">
+ <Project>{80FA3158-8B5F-48D1-A393-0378AFE48A7E}</Project>
+ <Name>OSGeo.MapGuide.MaestroAPI</Name>
+ </ProjectReference>
<ProjectReference Include="..\Thirdparty\SharpDevelop\ICSharpCode.Core.WinForms\ICSharpCode.Core.WinForms.csproj">
<Project>{857CA1A3-FC88-4BE0-AB6A-D1EE772AB288}</Project>
<Name>ICSharpCode.Core.WinForms</Name>
Modified: sandbox/maestro-2.5/Maestro.Base/Workbench.cs
--- sandbox/maestro-2.5/Maestro.Base/Workbench.cs 2010-05-12 16:16:21 UTC (rev 4858)
+++ sandbox/maestro-2.5/Maestro.Base/Workbench.cs 2010-05-12 16:55:36 UTC (rev 4859)
@@ -99,14 +99,16 @@
this.Controls.Add(toolStripContainer);
ctxToolbar = new ContextMenuStrip();
+ menu.ContextMenuStrip = ctxToolbar;
toolStripContainer.TopToolStripPanel.ContextMenuStrip = ctxToolbar;
toolStripContainer.BottomToolStripPanel.ContextMenuStrip = ctxToolbar;
toolStripContainer.LeftToolStripPanel.ContextMenuStrip = ctxToolbar;
toolStripContainer.RightToolStripPanel.ContextMenuStrip = ctxToolbar;
toolbar = ToolbarService.CreateToolStrip(this, "/Maestro/Shell/Toolbars/Main");
- AddToolbar("Base", toolbar, ToolbarRegion.Top, false);
+ AddToolbar("Base", toolbar, ToolbarRegion.Top, true);
status = new StatusStrip();
statusLabel = new ToolStripStatusLabel();
status.Items.Add(statusLabel);
@@ -294,28 +296,6 @@
(item as IStatusUpdate).UpdateStatus();
- /// <summary>
- /// </summary>
- /// <param name="m"></param>
- protected override void WndProc(ref Message m)
- if (m.Msg == NativeMethods.WM_SHOWME)
- if (WindowState == FormWindowState.Minimized)
- WindowState = FormWindowState.Normal;
- // get our current "TopMost" value (ours will always be false though)
- bool top = TopMost;
- // make our form jump to the top of everything
- TopMost = true;
- // set it back to whatever it was
- TopMost = top;
- base.WndProc(ref m);
/// <summary>
Property changes on: sandbox/maestro-2.5/MaestroAPITests
___________________________________________________________________
Added: svn:ignore
+ bin
obj
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-05-12 16:16:21 UTC (rev 4858)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-05-12 16:55:36 UTC (rev 4859)
@@ -193,6 +193,7 @@
<Compile Include="ObjectModels\SymbolDefinition.cs" />
<Compile Include="ObjectModels\SymbolLibrary.cs" />
<Compile Include="ObjectModels\WebLayout.cs" />
+ <Compile Include="Platform.cs" />
<Compile Include="Properties\Resources.Designer.cs">
<AutoGen>True</AutoGen>
<DesignTime>True</DesignTime>
Added: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Platform.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Platform.cs (rev 0)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Platform.cs 2010-05-12 16:55:36 UTC (rev 4859)
@@ -0,0 +1,33 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+namespace OSGeo.MapGuide.MaestroAPI
+ public static class Platform
+ public static bool IsWindows
+ get { return Environment.OSVersion.Platform != PlatformID.Unix || Environment.OSVersion.Platform != PlatformID.MacOSX; }
More information about the mapguide-commits
