[mapguide-commits] r4872 -
sandbox/maestro-2.5/Thirdparty/TreeViewAdv
svn_mapguide at osgeo.org
Thu May 13 23:07:45 EDT 2010
Author: jng
Date: 2010-05-13 23:07:45 -0400 (Thu, 13 May 2010)
New Revision: 4872
Removed:
sandbox/maestro-2.5/Thirdparty/TreeViewAdv/Aga.Controls/
sandbox/maestro-2.5/Thirdparty/TreeViewAdv/ReleaseNotes.txt
sandbox/maestro-2.5/Thirdparty/TreeViewAdv/SampleApp/
sandbox/maestro-2.5/Thirdparty/TreeViewAdv/TreeViewAdv.sln
sandbox/maestro-2.5/Thirdparty/TreeViewAdv/UnitTests/
sandbox/maestro-2.5/Thirdparty/TreeViewAdv/VBSample.sln
sandbox/maestro-2.5/Thirdparty/TreeViewAdv/VBSample/
A newer version of TreeViewAdv is available.
Deleted: sandbox/maestro-2.5/Thirdparty/TreeViewAdv/ReleaseNotes.txt
--- sandbox/maestro-2.5/Thirdparty/TreeViewAdv/ReleaseNotes.txt 2010-05-14 03:00:55 UTC (rev 4871)
+++ sandbox/maestro-2.5/Thirdparty/TreeViewAdv/ReleaseNotes.txt 2010-05-14 03:07:45 UTC (rev 4872)
@@ -1,88 +0,0 @@
-1.6.2:
-+ HorizontalScrollPosition added
-+ Fixed: Rendering issues with ExpandingIcon column with UseColumns
-1.6.1:
-+ Fixed: DragAutoScroll() is not working when FPS low.
-+ Tutorial project in VB and a short documentation added (Thanks to Richard Pope).
-1.6:
-+ Asynchronous nodes expanding feature added
-+ Tooltips added to the column headers
-+ Bug in CheckBoxNodeControl using in VirtualMode fixed
-+ Bug in HScrolllBar fixed
-1.5:
-+ Column resizing behaviour improved
-+ GridLineStyle property introduced
-+ Additional navigation keys support added (+,-,*)
-+ ExpandAll, CollapseAll methods added to TreeNodeAdv class
-+ Incremental search works like in standard TreeView now. Warning: no Search property anymore!
-+ ClearSelection method optimized
-+ Performance during Expand/Collapse/FullUpdate improved
-+ UseCompatibleTextRendering property added to BaseTextControl class.
-1.4.4:
-+ Bug during drag&drop of nodes in SimpleExample fixed.
-1.4.3:
-+ Perfromance bug fixed: The complexity of CreateRowMap method is now O(n), instead of O(n^2)
-1.4.2:
-+ Two new events added: IsVisibleValueNeeded and IsEditEnabledValueNeeded. Now it's possible to control
- the visibility and the editability of each particular node.
-+ Loosing changes in EditableControl when leave TreeView bug fixed.
-+ Node.Tag property added.
-1.4.1:
-+ Some times TreeViewAdv crashes when used in different threads on multi-processors machine. Fixed.
-+ Bug with selecting row when FullRowSelect is true fixed. (thanks Sean)
-1.4:
-+ Columns are now reorderable. New event ColumnReordered and new property AllowColumnReorder were introduced.
- Warning: NodeControl.Column property is no longer exist! Use NodeControl.ParentColumn.
-+ Font property added to DrawEventArgs class
-+ Minor improvements in column headers drawing
-1.3:
-Many thanks to Virgil Dupras for his ideas and comments.
-Some of them were implemented in this release:
-+ Column headers are now clickable and will generate OnColumnClicked event,
- SortOrder property is added to TreeColumn class, if set a small mark will
- be drawn in the column header. SortedTreeModel is introduced for a default
- sorting implementation, it can be used as a decorator for ITreeModel
- (see FolderBrowser f.e.)
-+ KeepNodesExpanded property becomes obsolete and is always true now.
- A new algorithm of keeping nodes expanded during refresh is used.
-+ DrawText event is added to BaseTextControl(you can dynamically change a
- text color f.e.)
-+ Fields binding posibility is added to BindableControl
-1.2.2:
-+ Fixed: CheckBox in the scrolled position does not work
-+ Fixed: Cursor property does not work
-1.2:
-+ AutoRowHeight: Automatically resize row height base on it content
-+ Incremental Search: Navigate to a node by typing first chars from it's label
-+ NodeNumericUpDown control
-1.1:
-+ Autoscroll during drag&drop
-+ Display dragging nodes
-+ Performance counter
-1.0:
-First release.
Deleted: sandbox/maestro-2.5/Thirdparty/TreeViewAdv/TreeViewAdv.sln
--- sandbox/maestro-2.5/Thirdparty/TreeViewAdv/TreeViewAdv.sln 2010-05-14 03:00:55 UTC (rev 4871)
+++ sandbox/maestro-2.5/Thirdparty/TreeViewAdv/TreeViewAdv.sln 2010-05-14 03:07:45 UTC (rev 4872)
@@ -1,174 +0,0 @@
-Microsoft Visual Studio Solution File, Format Version 9.00
-# Visual Studio 2005
-Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Aga.Controls", "Aga.Controls\Aga.Controls.csproj", "{E73BB233-D88B-44A7-A98F-D71EE158381D}"
-EndProject
-Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "SampleApp", "SampleApp\SampleApp.csproj", "{C197EFF6-AD4E-4E44-8601-D101E0736144}"
-EndProject
-Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Aga.Controls.UnitTests", "UnitTests\Aga.Controls.UnitTests.csproj", "{F74BBDC5-A90C-438B-A6C2-347B49398FDB}"
-EndProject
-Project("{2150E333-8FDC-42A3-9474-1A3956D46DE8}") = "Solution Items", "Solution Items", "{C8A04BBE-4366-4640-A7CF-1A8B27F68DDD}"
- ProjectSection(SolutionItems) = preProject
- ReleaseNotes.txt = ReleaseNotes.txt
- EndProjectSection
- ProjectSection(FolderStartupServices) = postProject
- {B4F97281-0DBD-4835-9ED8-7DFB966E87FF} = {B4F97281-0DBD-4835-9ED8-7DFB966E87FF}
- EndProjectSection
-EndProject
-Global
- GlobalSection(SolutionConfigurationPlatforms) = preSolution
- Debug|Any CPU = Debug|Any CPU
- Release|Any CPU = Release|Any CPU
- EndGlobalSection
- GlobalSection(ProjectConfigurationPlatforms) = postSolution
- {E73BB233-D88B-44A7-A98F-D71EE158381D}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {E73BB233-D88B-44A7-A98F-D71EE158381D}.Debug|Any CPU.Build.0 = Debug|Any CPU
- {E73BB233-D88B-44A7-A98F-D71EE158381D}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {E73BB233-D88B-44A7-A98F-D71EE158381D}.Release|Any CPU.Build.0 = Release|Any CPU
- {C197EFF6-AD4E-4E44-8601-D101E0736144}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {C197EFF6-AD4E-4E44-8601-D101E0736144}.Debug|Any CPU.Build.0 = Debug|Any CPU
- {C197EFF6-AD4E-4E44-8601-D101E0736144}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {C197EFF6-AD4E-4E44-8601-D101E0736144}.Release|Any CPU.Build.0 = Release|Any CPU
- {F74BBDC5-A90C-438B-A6C2-347B49398FDB}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {F74BBDC5-A90C-438B-A6C2-347B49398FDB}.Debug|Any CPU.Build.0 = Debug|Any CPU
- {F74BBDC5-A90C-438B-A6C2-347B49398FDB}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {F74BBDC5-A90C-438B-A6C2-347B49398FDB}.Release|Any CPU.Build.0 = Release|Any CPU
- EndGlobalSection
- GlobalSection(SolutionProperties) = preSolution
- HideSolutionNode = FALSE
- EndGlobalSection
- GlobalSection(TextTemplating) = postSolution
- TextTemplating = 1
- EndGlobalSection
-EndGlobal
Deleted: sandbox/maestro-2.5/Thirdparty/TreeViewAdv/VBSample.sln
--- sandbox/maestro-2.5/Thirdparty/TreeViewAdv/VBSample.sln 2010-05-14 03:00:55 UTC (rev 4871)
+++ sandbox/maestro-2.5/Thirdparty/TreeViewAdv/VBSample.sln 2010-05-14 03:07:45 UTC (rev 4872)
@@ -1,25 +0,0 @@
-Project("{F184B08F-C81C-45F6-A57F-5ABD9991F28F}") = "VBMultiColTree", "VBSample\VBMultiColTree\VBMultiColTree.vbproj", "{B6FE37C1-11BD-466B-A5D5-82C230487864}"
-EndProject
-Project("{2150E333-8FDC-42A3-9474-1A3956D46DE8}") = "Solution Items", "Solution Items", "{076844FE-D17E-496D-9319-CB97E06E03B7}"
- VBSample\Some Notes on using TreeViewAdv version 1_6_0_0.doc = VBSample\Some Notes on using TreeViewAdv version 1_6_0_0.doc
- EndProjectSection
-EndProject
-Global
- EndGlobalSection
- {B6FE37C1-11BD-466B-A5D5-82C230487864}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {B6FE37C1-11BD-466B-A5D5-82C230487864}.Debug|Any CPU.Build.0 = Debug|Any CPU
- {B6FE37C1-11BD-466B-A5D5-82C230487864}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {B6FE37C1-11BD-466B-A5D5-82C230487864}.Release|Any CPU.Build.0 = Release|Any CPU
- EndGlobalSection
- EndGlobalSection
-EndGlobal
More information about the mapguide-commits
