[mapguide-commits] r4888 - in sandbox/maestro-2.5: MaestroAPITests
OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI.Http
svn_mapguide at osgeo.org
Mon May 17 01:45:19 EDT 2010
Author: jng
Date: 2010-05-17 01:45:17 -0400 (Mon, 17 May 2010)
New Revision: 4888
sandbox/maestro-2.5/MaestroAPITests/CapabilityTests.cs
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI.Http/HttpCapabilities.cs
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Enums.cs
This submission adds unit tests for http capabilities. All known MGOS site versions are tested.
Modified: sandbox/maestro-2.5/MaestroAPITests/CapabilityTests.cs
--- sandbox/maestro-2.5/MaestroAPITests/CapabilityTests.cs 2010-05-16 03:49:32 UTC (rev 4887)
+++ sandbox/maestro-2.5/MaestroAPITests/CapabilityTests.cs 2010-05-17 05:45:17 UTC (rev 4888)
@@ -21,12 +21,654 @@
using System.Collections.Generic;
using System.Text;
using NUnit.Framework;
+using NMock2;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Http;
+using OSGeo.MapGuide.MaestroAPI.Services;
namespace MaestroAPITests
[TestFixture]
public class CapabilityTests
+ private Mockery _mocks;
+ [Test]
+ public void TestHttpCapabilities100()
+ _mocks = new Mockery();
+ var conn = _mocks.NewMock<IServerConnection>();
+ Stub.On(conn).GetProperty("SiteVersion").Will(Return.Value(new Version(1, 0)));
+ var caps = new HttpCapabilities(conn);
+ foreach (ResourceTypes type in Enum.GetValues(typeof(ResourceTypes)))
+ switch (type)
+ case ResourceTypes.ApplicationDefinition:
+ try
+ caps.GetMaxSupportedResourceVersion(type.ToString());
+ Assert.Fail("MGOS 1.0.0 doesn't support fusion!");
+ catch (NotSupportedException) { }
+ break;
+ case ResourceTypes.FeatureSource:
+ var version = caps.GetMaxSupportedResourceVersion(type.ToString());
+ Assert.AreEqual(version, new Version(1, 0, 0));
+ break;
+ case ResourceTypes.LayerDefinition:
+ break;
+ case ResourceTypes.LoadProcedure:
+ break;
+ case ResourceTypes.MapDefinition:
+ break;
+ case ResourceTypes.PrintLayout:
+ break;
+ case ResourceTypes.SymbolDefinition:
+ try
+ Assert.Fail("MGOS 1.0.0 doesn't support advanced symbology!");
+ break;
+ case ResourceTypes.WebLayout:
+ break;
+ Assert.IsTrue(caps.SupportsResourcePreviews);
+ int[] services = caps.SupportedServices;
+ foreach (ServiceType st in Enum.GetValues(typeof(ServiceType)))
+ switch (st)
+ case ServiceType.Drawing:
+ Assert.IsTrue(Array.IndexOf<int>(services, (int)st) >= 0);
+ break;
+ case ServiceType.Feature:
+ break;
+ case ServiceType.Fusion:
+ Assert.IsTrue(Array.IndexOf<int>(services, (int)st) < 0);
+ break;
+ case ServiceType.Mapping:
+ break;
+ case ServiceType.Resource:
+ break;
+ case ServiceType.Tile:
+ break;
+ [Test]
+ public void TestHttpCapabilities110()
+ Stub.On(conn).GetProperty("SiteVersion").Will(Return.Value(new Version(1, 1)));
+ switch (type)
+ try
+ Assert.Fail("MGOS 1.1.0 doesn't support fusion!");
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ try
+ Assert.Fail("MGOS 1.1.0 doesn't support advanced symbology!");
+ break;
+ break;
+ switch (st)
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ [Test]
+ public void TestHttpCapabilities120()
+ Stub.On(conn).GetProperty("SiteVersion").Will(Return.Value(new Version(1, 2)));
+ switch (type)
+ try
+ Assert.Fail("MGOS 1.2.0 doesn't support fusion!");
+ break;
+ break;
+ Assert.AreEqual(version, new Version(1, 1, 0));
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ switch (st)
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ [Test]
+ public void TestHttpCapabilities200()
+ Stub.On(conn).GetProperty("SiteVersion").Will(Return.Value(new Version(2, 0)));
+ switch (type)
+ break;
+ break;
+ Assert.AreEqual(version, new Version(1, 2, 0));
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ switch (st)
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ [Test]
+ public void TestHttpCapabilities210()
+ Stub.On(conn).GetProperty("SiteVersion").Will(Return.Value(new Version(2, 1)));
+ switch (type)
+ break;
+ break;
+ Assert.AreEqual(version, new Version(1, 3, 0));
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ switch (st)
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ [Test]
+ public void TestHttpCapabilities220()
+ Stub.On(conn).GetProperty("SiteVersion").Will(Return.Value(new Version(2, 2)));
+ switch (type)
+ break;
+ break;
+ break;
+ Assert.AreEqual(version, new Version(2, 2, 0));
+ break;
+ break;
+ break;
+ break;
+ break;
+ switch (st)
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Enums.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Enums.cs 2010-05-16 03:49:32 UTC (rev 4887)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Enums.cs 2010-05-17 05:45:17 UTC (rev 4888)
@@ -24,12 +24,15 @@
public enum ResourceTypes
MapDefinition,
- LayerDefiniton,
+ LayerDefinition,
FeatureSource,
WebLayout,
RuntimeMap,
Folder,
ApplicationDefinition,
+ PrintLayout,
+ SymbolDefinition,
+ LoadProcedure,
public enum Operations
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI.Http/HttpCapabilities.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI.Http/HttpCapabilities.cs 2010-05-16 03:49:32 UTC (rev 4887)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI.Http/HttpCapabilities.cs 2010-05-17 05:45:17 UTC (rev 4888)
@@ -26,9 +26,9 @@
internal class HttpCapabilities : IConnectionCapabilities
- private HttpServerConnection _parent;
+ private IServerConnection _parent;
- internal HttpCapabilities(HttpServerConnection parent)
+ internal HttpCapabilities(IServerConnection parent)
_parent = parent;
@@ -38,6 +38,10 @@
Version ver = new Version(1, 0, 0);
switch (resourceType)
+ case "ApplicationDefinition":
+ if (!SupportsFusion())
+ throw new NotSupportedException();
+ break;
case "LayerDefinition":
ver = GetMaxLayerDefinitionVersion();
break;
@@ -48,12 +52,25 @@
ver = GetMaxWebLayoutVersion();
break;
case "SymbolDefinition":
- ver = GetMaxSymbolDefinitionVersion();
+ if (!SupportsAdvancedSymbols())
+ else
+ ver = GetMaxSymbolDefinitionVersion();
break;
return ver;
+ private bool SupportsAdvancedSymbols()
+ return (_parent.SiteVersion >= new Version(1, 2));
+ private bool SupportsFusion()
+ return (_parent.SiteVersion >= new Version(2, 0));
private Version GetMaxLoadProcedureVersion()
if (_parent.SiteVersion >= new Version(2, 2))
@@ -67,7 +84,7 @@
private Version GetMaxSymbolDefinitionVersion()
- if (_parent.SiteVersion >= new Version(2, 2))
+ if (_parent.SiteVersion >= new Version(2, 0))
return new Version(1, 1, 0);
return new Version(1, 0, 0);
@@ -111,8 +128,8 @@
(int)ServiceType.Feature,
(int)ServiceType.Fusion,
(int)ServiceType.Mapping,
- (int)ServiceType.Tile
- //(int)ServiceType.Drawing
+ (int)ServiceType.Tile,
+ (int)ServiceType.Drawing
else //Fusion doesn't exist pre-2.0
@@ -121,8 +138,8 @@
(int)ServiceType.Resource,
More information about the mapguide-commits
