[mapguide-commits] r4891 - in sandbox/maestro-2.5: MaestroAPITests
MaestroBaseTests OSGeo.MapGuide.MaestroAPI
OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org
Mon May 17 03:10:17 EDT 2010
Author: jng
Date: 2010-05-17 03:10:17 -0400 (Mon, 17 May 2010)
New Revision: 4891
sandbox/maestro-2.5/MaestroAPITests/CapabilityTests.cs
sandbox/maestro-2.5/MaestroAPITests/ResourceTests.cs
sandbox/maestro-2.5/MaestroBaseTests/
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Enums.cs
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/DrawingSource.cs
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/LoadProcedure.cs
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/PrintLayout.cs
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/SymbolDefinition.cs
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/SymbolLibrary.cs
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayout.cs
Add resource id validation to generated classes and update capability unit tests for missing resource types
Modified: sandbox/maestro-2.5/MaestroAPITests/CapabilityTests.cs
--- sandbox/maestro-2.5/MaestroAPITests/CapabilityTests.cs 2010-05-17 06:46:19 UTC (rev 4890)
+++ sandbox/maestro-2.5/MaestroAPITests/CapabilityTests.cs 2010-05-17 07:10:17 UTC (rev 4891)
@@ -60,6 +60,12 @@
break;
+ case ResourceTypes.DrawingSource:
+ var version = caps.GetMaxSupportedResourceVersion(type.ToString());
+ Assert.AreEqual(version, new Version(1, 0, 0));
+ break;
case ResourceTypes.FeatureSource:
@@ -90,6 +96,12 @@
break;
+ case ResourceTypes.SymbolLibrary:
+ break;
case ResourceTypes.SymbolDefinition:
try
@@ -177,6 +189,12 @@
break;
+ break;
@@ -207,6 +225,12 @@
break;
+ break;
try
@@ -294,6 +318,12 @@
break;
+ break;
@@ -324,6 +354,12 @@
break;
+ break;
@@ -397,6 +433,12 @@
break;
+ break;
@@ -427,6 +469,12 @@
break;
+ break;
@@ -500,6 +548,12 @@
break;
+ break;
@@ -530,6 +584,12 @@
break;
+ break;
@@ -603,6 +663,12 @@
break;
+ break;
@@ -633,6 +699,12 @@
break;
+ break;
Modified: sandbox/maestro-2.5/MaestroAPITests/ResourceTests.cs
--- sandbox/maestro-2.5/MaestroAPITests/ResourceTests.cs 2010-05-17 06:46:19 UTC (rev 4890)
+++ sandbox/maestro-2.5/MaestroAPITests/ResourceTests.cs 2010-05-17 07:10:17 UTC (rev 4891)
@@ -33,6 +33,7 @@
using OSGeo.MapGuide.MaestroAPI.Resource.Conversion;
using NMock2;
using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.ObjectModels.Common;
namespace MaestroAPITests
@@ -84,6 +85,342 @@
[Test]
+ public void TestValidResourceIdentifiers()
+ //Verify that only valid resource identifiers can be assigned to certain resource types.
+ IResource res = new FeatureSourceType();
+ #region Feature Source
+ try
+ res.ResourceID = "dklgjlahekjedjfd";
+ Assert.Fail("Should've thrown exception on invalid resource id");
+ catch (InvalidOperationException) { }
+ try
+ res.ResourceID = "Library://UnitTests/";
+ try
+ res.ResourceID = "Library://UnitTests/Test.DrawingSource";
+ try
+ res.ResourceID = "Library://UnitTests/Test.FeatureSource";
+ Assert.Fail("Resource ID should've checked out");
+ #endregion
+ res = new DrawingSource();
+ #region Drawing Source
+ try
+ catch (InvalidOperationException){ }
+ try
+ try
+ try
+ catch (Exception)
+ #endregion
+ res = new MapDefinition();
+ #region Map Definition
+ try
+ try
+ try
+ try
+ res.ResourceID = "Library://UnitTests/Test.MapDefinition";
+ catch (Exception)
+ #endregion
+ res = new WebLayoutType();
+ #region Web Layout
+ try
+ try
+ try
+ try
+ res.ResourceID = "Library://UnitTests/Test.WebLayout";
+ catch (Exception)
+ #endregion
+ res = new ApplicationDefinitionType();
+ #region Application Definition
+ try
+ try
+ try
+ try
+ res.ResourceID = "Library://UnitTests/Test.ApplicationDefinition";
+ catch (Exception)
+ #endregion
+ res = new SymbolLibraryType();
+ #region Symbol Library
+ try
+ try
+ try
+ try
+ res.ResourceID = "Library://UnitTests/Test.SymbolLibrary";
+ catch (Exception)
+ #endregion
+ res = new SimpleSymbolDefinition();
+ #region Simple Symbol Definition
+ try
+ try
+ try
+ try
+ res.ResourceID = "Library://UnitTests/Test.SymbolDefinition";
+ catch (Exception)
+ #endregion
+ res = new CompoundSymbolDefinition();
+ #region Compound Symbol Definition
+ try
+ try
+ try
+ try
+ catch (Exception)
+ #endregion
+ try
+ try
+ try
+ try
+ catch (Exception)
+ #endregion
+ res = new PrintLayout();
+ #region Print Layout
+ try
+ try
+ try
+ try
+ res.ResourceID = "Library://UnitTests/Test.PrintLayout";
+ catch (Exception)
+ #endregion
+ [Test]
public void TestNoConversionOnIdenticalVersion()
//Verify origial reference is returned if we're converting a resource to the same version
Property changes on: sandbox/maestro-2.5/MaestroBaseTests
___________________________________________________________________
Added: svn:ignore
+ bin
obj
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Enums.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Enums.cs 2010-05-17 06:46:19 UTC (rev 4890)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Enums.cs 2010-05-17 07:10:17 UTC (rev 4891)
@@ -33,6 +33,8 @@
PrintLayout,
SymbolDefinition,
LoadProcedure,
+ DrawingSource,
+ SymbolLibrary
public enum Operations
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs 2010-05-17 06:46:19 UTC (rev 4890)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs 2010-05-17 07:10:17 UTC (rev 4891)
@@ -22,6 +22,7 @@
using System.Text;
using System.Xml.Serialization;
+using OSGeo.MapGuide.MaestroAPI;
namespace OSGeo.MapGuide.ObjectModels.ApplicationDefinition
@@ -47,6 +48,13 @@
set
+ if (!ResourceIdentifier.Validate(value))
+ throw new InvalidOperationException("Not a valid resource identifier"); //LOCALIZE
+ var res = new ResourceIdentifier(value);
+ if (res.Extension != ResourceTypes.ApplicationDefinition.ToString())
+ throw new InvalidOperationException("Invalid resource identifier for this type of object: " + res.Extension); //LOCALIZE
_resId = value;
this.OnPropertyChanged("ResourceID");
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/DrawingSource.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/DrawingSource.cs 2010-05-17 06:46:19 UTC (rev 4890)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/DrawingSource.cs 2010-05-17 07:10:17 UTC (rev 4891)
@@ -22,6 +22,7 @@
using System.Text;
namespace OSGeo.MapGuide.ObjectModels.Common
@@ -47,6 +48,13 @@
set
+ if (res.Extension != ResourceTypes.DrawingSource.ToString())
_resId = value;
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs 2010-05-17 06:46:19 UTC (rev 4890)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs 2010-05-17 07:10:17 UTC (rev 4891)
@@ -22,6 +22,7 @@
using System.Text;
namespace OSGeo.MapGuide.ObjectModels.FeatureSource
@@ -47,6 +48,13 @@
set
+ if (res.Extension != ResourceTypes.FeatureSource.ToString())
_resId = value;
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs 2010-05-17 06:46:19 UTC (rev 4890)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs 2010-05-17 07:10:17 UTC (rev 4891)
@@ -22,6 +22,7 @@
using System.Text;
namespace OSGeo.MapGuide.ObjectModels.LayerDefinition
@@ -47,6 +48,13 @@
set
+ if (res.Extension != ResourceTypes.LayerDefinition.ToString())
_resId = value;
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/LoadProcedure.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/LoadProcedure.cs 2010-05-17 06:46:19 UTC (rev 4890)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/LoadProcedure.cs 2010-05-17 07:10:17 UTC (rev 4891)
@@ -22,6 +22,7 @@
using System.Text;
namespace OSGeo.MapGuide.ObjectModels.LoadProcedure
@@ -47,6 +48,13 @@
set
+ if (res.Extension != ResourceTypes.LoadProcedure.ToString())
_resId = value;
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs 2010-05-17 06:46:19 UTC (rev 4890)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs 2010-05-17 07:10:17 UTC (rev 4891)
@@ -22,6 +22,7 @@
using System.Text;
namespace OSGeo.MapGuide.ObjectModels.MapDefinition
@@ -47,6 +48,13 @@
set
+ if (res.Extension != ResourceTypes.MapDefinition.ToString())
_resId = value;
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/PrintLayout.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/PrintLayout.cs 2010-05-17 06:46:19 UTC (rev 4890)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/PrintLayout.cs 2010-05-17 07:10:17 UTC (rev 4891)
@@ -22,6 +22,7 @@
using System.Text;
namespace OSGeo.MapGuide.ObjectModels.PrintLayout
@@ -47,6 +48,13 @@
set
+ if (res.Extension != ResourceTypes.PrintLayout.ToString())
_resId = value;
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/SymbolDefinition.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/SymbolDefinition.cs 2010-05-17 06:46:19 UTC (rev 4890)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/SymbolDefinition.cs 2010-05-17 07:10:17 UTC (rev 4891)
@@ -22,6 +22,7 @@
using System.Text;
namespace OSGeo.MapGuide.ObjectModels.SymbolDefinition
@@ -47,6 +48,13 @@
set
+ if (res.Extension != ResourceTypes.SymbolDefinition.ToString())
_resId = value;
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/SymbolLibrary.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/SymbolLibrary.cs 2010-05-17 06:46:19 UTC (rev 4890)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/SymbolLibrary.cs 2010-05-17 07:10:17 UTC (rev 4891)
@@ -22,6 +22,7 @@
using System.Text;
namespace OSGeo.MapGuide.ObjectModels.SymbolLibrary
@@ -47,6 +48,13 @@
set
+ if (res.Extension != ResourceTypes.SymbolLibrary.ToString())
_resId = value;
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayout.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayout.cs 2010-05-17 06:46:19 UTC (rev 4890)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayout.cs 2010-05-17 07:10:17 UTC (rev 4891)
@@ -22,6 +22,7 @@
using System.Text;
namespace OSGeo.MapGuide.ObjectModels.WebLayout
@@ -47,6 +48,13 @@
set
+ if (res.Extension != ResourceTypes.WebLayout.ToString())
_resId = value;
More information about the mapguide-commits
