[mapguide-commits] r4908 - sandbox/maestro-2.5/Maestro.Base
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue May 18 05:27:49 EDT 2010
Author: jng
Date: 2010-05-18 05:27:49 -0400 (Tue, 18 May 2010)
New Revision: 4908
   sandbox/maestro-2.5/Maestro.Base/TabFactory.cs
The original Mono workaround for tab closure caused problems in windows (ugh). So I've put that workaround around a platform check and if it's windows, we close the way it was meant to be done.
Modified: sandbox/maestro-2.5/Maestro.Base/TabFactory.cs
--- sandbox/maestro-2.5/Maestro.Base/TabFactory.cs	2010-05-18 09:16:51 UTC (rev 4907)
+++ sandbox/maestro-2.5/Maestro.Base/TabFactory.cs	2010-05-18 09:27:49 UTC (rev 4908)
@@ -21,6 +21,7 @@
 using System.Collections.Generic;
 using System.Text;
 using System.Windows.Forms;
+using OSGeo.MapGuide.MaestroAPI;
 namespace Maestro.Base
@@ -81,33 +82,42 @@
                     var tabs = page.Parent as TabControl;
                     if (tabs != null && tabs.TabPages.Contains(page))
-                        int idx = -1;
-                        //HACK: Mono (2.4) will chuck a hissy fit if we remove
-                        //a tab from a TabControl that has a selected tab so we
-                        //have to null the selected tab, but this cause weird
-                        //visual effects once the tab is removed, so we record
-                        //the selected index, so we can assign the one beside it
-                        //to be the selected tab after removal.
-                        if (tabs.SelectedTab == page)
+                        if (Platform.IsWindows)
-                            idx = tabs.SelectedIndex;
-                            tabs.SelectedTab = null;
+                            var idx = tabs.TabPages.IndexOf(page);
+                            tabs.TabPages.Remove(page);
+                            if (idx > 0)
+                                tabs.SelectedIndex = --idx;
-                        tabs.TabPages.Remove(page);
-                        if (idx > 0)
+                        else
-                            idx--;
-                            tabs.SelectedIndex = idx;
-                        else
-                            //Set to first tab if available.
-                            if (tabs.TabCount > 0)
+                            int idx = -1;
+                            //HACK: Mono (2.4) will chuck a hissy fit if we remove
+                            //a tab from a TabControl that has a selected tab so we
+                            //have to null the selected tab, but this cause weird
+                            //visual effects once the tab is removed, so we record
+                            //the selected index, so we can assign the one beside it
+                            //to be the selected tab after removal.
+                            if (tabs.SelectedTab == page)
-                                tabs.SelectedIndex = 0;
+                                idx = tabs.SelectedIndex;
+                                tabs.SelectedTab = null;
+                            if (idx > 0)
+                                idx--;
+                                tabs.SelectedIndex = idx;
+                            else
+                                //Set to first tab if available.
+                                if (tabs.TabCount > 0)
+                                    tabs.SelectedIndex = 0;
More information about the mapguide-commits mailing list
