[mapguide-commits] r4921 - in sandbox/maestro-2.5: Maestro.Base
Maestro.Base/Editor Maestro.Editors Maestro.Editors/LoadProcedure
svn_mapguide at osgeo.org
Fri May 21 07:16:39 EDT 2010
Author: jng
Date: 2010-05-21 07:16:39 -0400 (Fri, 21 May 2010)
New Revision: 4921
Added:
sandbox/maestro-2.5/Maestro.Base/Editor/LoadProcedureEditor.resx
sandbox/maestro-2.5/Maestro.Base/Editor/LoadProcedureEditor.Designer.cs
sandbox/maestro-2.5/Maestro.Base/Editor/LoadProcedureEditor.cs
sandbox/maestro-2.5/Maestro.Base/Editor/ResourceEditorService.cs
sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-2.5/Maestro.Editors/IEditorBindable.cs
sandbox/maestro-2.5/Maestro.Editors/IEditorService.cs
sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/InputFilesCtrl.cs
sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadProcedureEditorCtrl.Designer.cs
sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadProcedureEditorCtrl.cs
sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadTargetCtrl.Designer.cs
sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadTargetCtrl.cs
sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/SdfTransformationCtrl.Designer.cs
sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/SdfTransformationCtrl.cs
sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/ShpTransformationCtrl.Designer.cs
sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/ShpTransformationCtrl.cs
This submission fleshes out the implementation of the Load Procedure editors
Modified: sandbox/maestro-2.5/Maestro.Base/Editor/LoadProcedureEditor.Designer.cs
--- sandbox/maestro-2.5/Maestro.Base/Editor/LoadProcedureEditor.Designer.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Base/Editor/LoadProcedureEditor.Designer.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -28,10 +28,35 @@
/// </summary>
private void InitializeComponent()
- components = new System.ComponentModel.Container();
+ this.lpEditor = new Maestro.Editors.LoadProcedure.LoadProcedureEditorCtrl();
+ this.panelBody.SuspendLayout();
+ this.SuspendLayout();
+ // panelBody
+ this.panelBody.Controls.Add(this.lpEditor);
+ // lpEditor
+ this.lpEditor.AutoScroll = true;
+ this.lpEditor.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.lpEditor.Location = new System.Drawing.Point(0, 0);
+ this.lpEditor.Name = "lpEditor";
+ this.lpEditor.Size = new System.Drawing.Size(614, 520);
+ this.lpEditor.TabIndex = 0;
+ // LoadProcedureEditor
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Name = "LoadProcedureEditor";
+ this.panelBody.ResumeLayout(false);
+ this.ResumeLayout(false);
#endregion
+ private Maestro.Editors.LoadProcedure.LoadProcedureEditorCtrl lpEditor;
Modified: sandbox/maestro-2.5/Maestro.Base/Editor/LoadProcedureEditor.cs
--- sandbox/maestro-2.5/Maestro.Base/Editor/LoadProcedureEditor.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Base/Editor/LoadProcedureEditor.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -36,7 +36,7 @@
protected override void Bind(Maestro.Editors.IEditorService service)
+ lpEditor.Bind(service);
Added: sandbox/maestro-2.5/Maestro.Base/Editor/LoadProcedureEditor.resx
--- sandbox/maestro-2.5/Maestro.Base/Editor/LoadProcedureEditor.resx (rev 0)
+++ sandbox/maestro-2.5/Maestro.Base/Editor/LoadProcedureEditor.resx 2010-05-21 11:16:39 UTC (rev 4921)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
\ No newline at end of file
Modified: sandbox/maestro-2.5/Maestro.Base/Editor/ResourceEditorService.cs
--- sandbox/maestro-2.5/Maestro.Base/Editor/ResourceEditorService.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Base/Editor/ResourceEditorService.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -28,6 +28,7 @@
using Maestro.Editors.Generic;
using System.ComponentModel;
using System.IO;
+using Maestro.Editors.Common;
namespace Maestro.Base.Editor
@@ -233,5 +234,16 @@
get { return _conn.ResourceService; }
+ public string GetCoordinateSystem()
+ var dlg = new CoordinateSystemPicker(_conn.CoordinateSystemCatalog);
+ if (dlg.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ return dlg.SelectedCoordSys.WKT;
+ return string.Empty;
Modified: sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj 2010-05-21 11:16:39 UTC (rev 4921)
@@ -254,6 +254,9 @@
<EmbeddedResource Include="Editor\LayerDefinitionEditor.resx">
<DependentUpon>LayerDefinitionEditor.cs</DependentUpon>
</EmbeddedResource>
+ <EmbeddedResource Include="Editor\LoadProcedureEditor.resx">
+ <DependentUpon>LoadProcedureEditor.cs</DependentUpon>
+ </EmbeddedResource>
<EmbeddedResource Include="Editor\WebLayoutEditor.resx">
<DependentUpon>WebLayoutEditor.cs</DependentUpon>
<SubType>Designer</SubType>
Modified: sandbox/maestro-2.5/Maestro.Editors/IEditorBindable.cs
--- sandbox/maestro-2.5/Maestro.Editors/IEditorBindable.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Editors/IEditorBindable.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -25,6 +25,12 @@
public interface IEditorBindable : INotifyResourceChanged
+ /// <summary>
+ /// Sets the initial state of this editor and sets up any databinding
+ /// within such that user interface changes will propagate back to the
+ /// model.
+ /// </summary>
+ /// <param name="service"></param>
void Bind(IEditorService service);
Modified: sandbox/maestro-2.5/Maestro.Editors/IEditorService.cs
--- sandbox/maestro-2.5/Maestro.Editors/IEditorService.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Editors/IEditorService.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -169,5 +169,11 @@
/// Raised when the edited resource has changed
/// </summary>
event EventHandler DirtyStateChanged;
+ /// <summary>
+ /// Invokes a prompt to select the coordinate system
+ /// </summary>
+ /// <returns></returns>
+ string GetCoordinateSystem();
Modified: sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/InputFilesCtrl.cs
--- sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/InputFilesCtrl.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/InputFilesCtrl.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -25,14 +25,26 @@
using System.Text;
using System.Windows.Forms;
using Maestro.Shared.UI;
+using System.Diagnostics;
namespace Maestro.Editors.LoadProcedure
- public partial class InputFilesCtrl : CollapsiblePanel
+ public partial class InputFilesCtrl : CollapsiblePanel, IEditorBindable
public InputFilesCtrl()
InitializeComponent();
+ public void Bind(IEditorService service)
+ var lp = service.GetEditedResource() as OSGeo.MapGuide.ObjectModels.LoadProcedure.LoadProcedure;
+ Debug.Assert(lp != null);
+ service.RegisterCustomNotifier(this);
+ lstInputFiles.DataSource = lp.Item.SourceFile;
+ public event EventHandler ResourceChanged;
Modified: sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadProcedureEditorCtrl.Designer.cs
--- sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadProcedureEditorCtrl.Designer.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadProcedureEditorCtrl.Designer.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -30,11 +30,12 @@
- // LoadProcedureEditor
+ // LoadProcedureEditorCtrl
- this.Name = "LoadProcedureEditor";
+ this.AutoScroll = true;
+ this.Name = "LoadProcedureEditorCtrl";
this.Size = new System.Drawing.Size(565, 447);
Modified: sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadProcedureEditorCtrl.cs
--- sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadProcedureEditorCtrl.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadProcedureEditorCtrl.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -24,14 +24,62 @@
using System.Data;
using System.Text;
+using OSGeo.MapGuide.ObjectModels.LoadProcedure;
+using Maestro.Shared.UI;
- public partial class LoadProcedureEditorCtrl : UserControl
+ public partial class LoadProcedureEditorCtrl : UserControl, IEditorBindable
public LoadProcedureEditorCtrl()
+ private OSGeo.MapGuide.ObjectModels.LoadProcedure.LoadProcedure _lp;
+ _lp = service.GetEditedResource() as OSGeo.MapGuide.ObjectModels.LoadProcedure.LoadProcedure;
+ Debug.Assert(_lp != null);
+ CollapsiblePanel tp = null;
+ if (_lp.Item is SdfLoadProcedureType)
+ var trans = new SdfTransformationCtrl();
+ trans.Bind(service);
+ tp = trans;
+ else if (_lp.Item is ShpLoadProcedureType)
+ var trans = new ShpTransformationCtrl();
+ tp = trans;
+ else
+ throw new NotSupportedException();
+ var input = new InputFilesCtrl();
+ input.Bind(service);
+ var target = new LoadTargetCtrl();
+ target.Bind(service);
+ tp.Dock = DockStyle.Top;
+ input.Dock = DockStyle.Top;
+ target.Dock = DockStyle.Top;
+ this.Controls.Add(target);
+ this.Controls.Add(tp);
+ this.Controls.Add(input);
Modified: sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadTargetCtrl.Designer.cs
--- sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadTargetCtrl.Designer.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadTargetCtrl.Designer.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -28,18 +28,205 @@
/// </summary>
+ this.label1 = new System.Windows.Forms.Label();
+ this.label2 = new System.Windows.Forms.Label();
+ this.label3 = new System.Windows.Forms.Label();
+ this.label4 = new System.Windows.Forms.Label();
+ this.chkCreateFeatureSources = new System.Windows.Forms.CheckBox();
+ this.chkCreateLayers = new System.Windows.Forms.CheckBox();
+ this.txtFeatureSourceRoot = new System.Windows.Forms.TextBox();
+ this.txtLayerRoot = new System.Windows.Forms.TextBox();
+ this.txtTargetRoot = new System.Windows.Forms.TextBox();
+ this.txtFeatureFolderName = new System.Windows.Forms.TextBox();
+ this.txtLayerFolderName = new System.Windows.Forms.TextBox();
+ this.btnBrowseRoot = new System.Windows.Forms.Button();
+ this.btnBrowseLayerRoot = new System.Windows.Forms.Button();
+ this.btnBrowseFeatureRoot = new System.Windows.Forms.Button();
+ this.contentPanel.SuspendLayout();
+ // contentPanel
+ this.contentPanel.Controls.Add(this.btnBrowseFeatureRoot);
+ this.contentPanel.Controls.Add(this.btnBrowseLayerRoot);
+ this.contentPanel.Controls.Add(this.btnBrowseRoot);
+ this.contentPanel.Controls.Add(this.txtLayerFolderName);
+ this.contentPanel.Controls.Add(this.txtFeatureFolderName);
+ this.contentPanel.Controls.Add(this.txtTargetRoot);
+ this.contentPanel.Controls.Add(this.txtLayerRoot);
+ this.contentPanel.Controls.Add(this.txtFeatureSourceRoot);
+ this.contentPanel.Controls.Add(this.chkCreateLayers);
+ this.contentPanel.Controls.Add(this.chkCreateFeatureSources);
+ this.contentPanel.Controls.Add(this.label4);
+ this.contentPanel.Controls.Add(this.label3);
+ this.contentPanel.Controls.Add(this.label2);
+ this.contentPanel.Controls.Add(this.label1);
+ this.contentPanel.Size = new System.Drawing.Size(485, 145);
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(18, 17);
+ this.label1.Name = "label1";
+ this.label1.Size = new System.Drawing.Size(138, 13);
+ this.label1.TabIndex = 0;
+ this.label1.Text = "Load Resources Into Folder";
+ // label2
+ this.label2.AutoSize = true;
+ this.label2.Font = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.label2.Location = new System.Drawing.Point(21, 46);
+ this.label2.Name = "label2";
+ this.label2.Size = new System.Drawing.Size(44, 13);
+ this.label2.TabIndex = 1;
+ this.label2.Text = "Create";
+ // label3
+ this.label3.AutoSize = true;
+ this.label3.Font = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.label3.Location = new System.Drawing.Point(135, 46);
+ this.label3.Name = "label3";
+ this.label3.Size = new System.Drawing.Size(71, 13);
+ this.label3.TabIndex = 2;
+ this.label3.Text = "In this path";
+ // label4
+ this.label4.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.label4.AutoSize = true;
+ this.label4.Font = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.label4.Location = new System.Drawing.Point(360, 46);
+ this.label4.Name = "label4";
+ this.label4.Size = new System.Drawing.Size(78, 13);
+ this.label4.TabIndex = 3;
+ this.label4.Text = "Folder Name";
+ // chkCreateFeatureSources
+ this.chkCreateFeatureSources.AutoSize = true;
+ this.chkCreateFeatureSources.Location = new System.Drawing.Point(21, 73);
+ this.chkCreateFeatureSources.Name = "chkCreateFeatureSources";
+ this.chkCreateFeatureSources.Size = new System.Drawing.Size(104, 17);
+ this.chkCreateFeatureSources.TabIndex = 4;
+ this.chkCreateFeatureSources.Text = "Feature Sources";
+ this.chkCreateFeatureSources.UseVisualStyleBackColor = true;
+ // chkCreateLayers
+ this.chkCreateLayers.AutoSize = true;
+ this.chkCreateLayers.Location = new System.Drawing.Point(21, 102);
+ this.chkCreateLayers.Name = "chkCreateLayers";
+ this.chkCreateLayers.Size = new System.Drawing.Size(104, 17);
+ this.chkCreateLayers.TabIndex = 5;
+ this.chkCreateLayers.Text = "Layer Definitions";
+ this.chkCreateLayers.UseVisualStyleBackColor = true;
+ // txtFeatureSourceRoot
+ this.txtFeatureSourceRoot.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
+ this.txtFeatureSourceRoot.Location = new System.Drawing.Point(138, 71);
+ this.txtFeatureSourceRoot.Name = "txtFeatureSourceRoot";
+ this.txtFeatureSourceRoot.Size = new System.Drawing.Size(179, 20);
+ this.txtFeatureSourceRoot.TabIndex = 6;
+ // txtLayerRoot
+ this.txtLayerRoot.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtLayerRoot.Location = new System.Drawing.Point(138, 99);
+ this.txtLayerRoot.Name = "txtLayerRoot";
+ this.txtLayerRoot.Size = new System.Drawing.Size(179, 20);
+ this.txtLayerRoot.TabIndex = 7;
+ // txtTargetRoot
+ this.txtTargetRoot.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtTargetRoot.Location = new System.Drawing.Point(162, 14);
+ this.txtTargetRoot.Name = "txtTargetRoot";
+ this.txtTargetRoot.Size = new System.Drawing.Size(276, 20);
+ this.txtTargetRoot.TabIndex = 8;
+ // txtFeatureFolderName
+ this.txtFeatureFolderName.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.txtFeatureFolderName.Location = new System.Drawing.Point(363, 71);
+ this.txtFeatureFolderName.Name = "txtFeatureFolderName";
+ this.txtFeatureFolderName.Size = new System.Drawing.Size(100, 20);
+ this.txtFeatureFolderName.TabIndex = 9;
+ // txtLayerFolderName
+ this.txtLayerFolderName.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.txtLayerFolderName.Location = new System.Drawing.Point(363, 100);
+ this.txtLayerFolderName.Name = "txtLayerFolderName";
+ this.txtLayerFolderName.Size = new System.Drawing.Size(100, 20);
+ this.txtLayerFolderName.TabIndex = 10;
+ // btnBrowseRoot
+ this.btnBrowseRoot.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnBrowseRoot.Location = new System.Drawing.Point(444, 12);
+ this.btnBrowseRoot.Name = "btnBrowseRoot";
+ this.btnBrowseRoot.Size = new System.Drawing.Size(34, 23);
+ this.btnBrowseRoot.TabIndex = 11;
+ this.btnBrowseRoot.Text = "...";
+ this.btnBrowseRoot.UseVisualStyleBackColor = true;
+ this.btnBrowseRoot.Click += new System.EventHandler(this.btnBrowseRoot_Click);
+ // btnBrowseLayerRoot
+ this.btnBrowseLayerRoot.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnBrowseLayerRoot.Location = new System.Drawing.Point(323, 98);
+ this.btnBrowseLayerRoot.Name = "btnBrowseLayerRoot";
+ this.btnBrowseLayerRoot.Size = new System.Drawing.Size(34, 23);
+ this.btnBrowseLayerRoot.TabIndex = 12;
+ this.btnBrowseLayerRoot.Text = "...";
+ this.btnBrowseLayerRoot.UseVisualStyleBackColor = true;
+ this.btnBrowseLayerRoot.Click += new System.EventHandler(this.btnBrowseLayerRoot_Click);
+ // btnBrowseFeatureRoot
+ this.btnBrowseFeatureRoot.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnBrowseFeatureRoot.Location = new System.Drawing.Point(323, 69);
+ this.btnBrowseFeatureRoot.Name = "btnBrowseFeatureRoot";
+ this.btnBrowseFeatureRoot.Size = new System.Drawing.Size(34, 23);
+ this.btnBrowseFeatureRoot.TabIndex = 13;
+ this.btnBrowseFeatureRoot.Text = "...";
+ this.btnBrowseFeatureRoot.UseVisualStyleBackColor = true;
+ this.btnBrowseFeatureRoot.Click += new System.EventHandler(this.btnBrowseFeatureRoot_Click);
// LoadTargetCtrl
this.HeaderText = "Load Settings";
this.Name = "LoadTargetCtrl";
+ this.Size = new System.Drawing.Size(485, 172);
+ this.contentPanel.ResumeLayout(false);
+ this.contentPanel.PerformLayout();
#endregion
+ private System.Windows.Forms.Button btnBrowseFeatureRoot;
+ private System.Windows.Forms.Button btnBrowseLayerRoot;
+ private System.Windows.Forms.Button btnBrowseRoot;
+ private System.Windows.Forms.TextBox txtLayerFolderName;
+ private System.Windows.Forms.TextBox txtFeatureFolderName;
+ private System.Windows.Forms.TextBox txtTargetRoot;
+ private System.Windows.Forms.TextBox txtLayerRoot;
+ private System.Windows.Forms.TextBox txtFeatureSourceRoot;
+ private System.Windows.Forms.CheckBox chkCreateLayers;
+ private System.Windows.Forms.CheckBox chkCreateFeatureSources;
+ private System.Windows.Forms.Label label4;
+ private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.Label label1;
Modified: sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadTargetCtrl.cs
--- sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadTargetCtrl.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/LoadTargetCtrl.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -28,11 +28,46 @@
- public partial class LoadTargetCtrl : CollapsiblePanel
+ public partial class LoadTargetCtrl : CollapsiblePanel, IEditorBindable
public LoadTargetCtrl()
+ private IEditorService _service;
+ _service = service;
+ var lp = _service.GetEditedResource() as OSGeo.MapGuide.ObjectModels.LoadProcedure.LoadProcedure;
+ txtTargetRoot.DataBindings.Add("Text", lp.Item, "RootPath");
+ chkCreateFeatureSources.DataBindings.Add("Checked", lp.Item, "GenerateSpatialDataSources");
+ chkCreateLayers.DataBindings.Add("Checked", lp.Item, "GenerateLayers");
+ txtFeatureSourceRoot.DataBindings.Add("Text", lp.Item, "SpatialDataSourcesPath");
+ txtFeatureFolderName.DataBindings.Add("Text", lp.Item, "SpatialDataSourcesFolder");
+ txtLayerRoot.DataBindings.Add("Text", lp.Item, "LayersPath");
+ txtLayerFolderName.DataBindings.Add("Text", lp.Item, "LayersFolder");
+ private void btnBrowseRoot_Click(object sender, EventArgs e)
+ txtTargetRoot.Text = _service.SelectFolder();
+ private void btnBrowseFeatureRoot_Click(object sender, EventArgs e)
+ txtFeatureSourceRoot.Text = _service.SelectFolder();
+ private void btnBrowseLayerRoot_Click(object sender, EventArgs e)
+ txtLayerRoot.Text = _service.SelectFolder();
Modified: sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/SdfTransformationCtrl.Designer.cs
--- sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/SdfTransformationCtrl.Designer.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/SdfTransformationCtrl.Designer.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -52,6 +52,7 @@
this.contentPanel.Controls.Add(this.btnBrowseCs);
this.contentPanel.Controls.Add(this.txtCoordinateSystem);
+ this.contentPanel.Size = new System.Drawing.Size(449, 236);
// label1
@@ -81,6 +82,7 @@
this.btnBrowseCs.TabIndex = 2;
this.btnBrowseCs.Text = "...";
this.btnBrowseCs.UseVisualStyleBackColor = true;
+ this.btnBrowseCs.Click += new System.EventHandler(this.btnBrowseCs_Click);
// label2
@@ -147,6 +149,7 @@
this.HeaderText = "Transformation";
this.Name = "SdfTransformationCtrl";
+ this.Size = new System.Drawing.Size(449, 263);
((System.ComponentModel.ISupportInitialize)(this.numGeneralizePercentage)).EndInit();
Modified: sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/SdfTransformationCtrl.cs
--- sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/SdfTransformationCtrl.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/SdfTransformationCtrl.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -25,14 +25,46 @@
using System.Text;
- public partial class SdfTransformationCtrl : CollapsiblePanel
+ public partial class SdfTransformationCtrl : CollapsiblePanel, IEditorBindable
public SdfTransformationCtrl()
+ var sdflp = lp.Item as OSGeo.MapGuide.ObjectModels.LoadProcedure.SdfLoadProcedureType;
+ txtCoordinateSystem.DataBindings.Add("Text", sdflp, "CoordinateSystem");
+ numGeneralizePercentage.DataBindings.Add("Value", sdflp, "Generalization");
+ cmbSdfConflictStrategy.DataSource = Enum.GetValues(typeof(SdfKeyTreatmentType));
+ //cmbSdfConflictStrategy.DataBindings.Add("SelectedItem", sdflp, "SdfKeyTreatement");
+ private void btnBrowseCs_Click(object sender, EventArgs e)
+ string cs = _service.GetCoordinateSystem();
+ if (!string.IsNullOrEmpty(cs) && cs != txtCoordinateSystem.Text)
+ txtCoordinateSystem.Text = cs;
Modified: sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/ShpTransformationCtrl.Designer.cs
--- sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/ShpTransformationCtrl.Designer.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/ShpTransformationCtrl.Designer.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -34,24 +34,27 @@
this.btnBrowseCs = new System.Windows.Forms.Button();
this.txtCoordinateSystem = new System.Windows.Forms.TextBox();
+ this.chkConvertToSdf = new System.Windows.Forms.CheckBox();
((System.ComponentModel.ISupportInitialize)(this.numGeneralizePercentage)).BeginInit();
// contentPanel
+ this.contentPanel.Controls.Add(this.chkConvertToSdf);
this.contentPanel.Controls.Add(this.numGeneralizePercentage);
+ this.contentPanel.Size = new System.Drawing.Size(449, 182);
// label4
- this.label4.Location = new System.Drawing.Point(18, 118);
+ this.label4.Location = new System.Drawing.Point(18, 142);
this.label4.Size = new System.Drawing.Size(311, 13);
this.label4.TabIndex = 13;
@@ -104,12 +107,24 @@
this.label1.TabIndex = 8;
this.label1.Text = "Use the following Coordinate System (if none found)";
+ // chkConvertToSdf
+ this.chkConvertToSdf.AutoSize = true;
+ this.chkConvertToSdf.Enabled = false;
+ this.chkConvertToSdf.Location = new System.Drawing.Point(21, 113);
+ this.chkConvertToSdf.Name = "chkConvertToSdf";
+ this.chkConvertToSdf.Size = new System.Drawing.Size(99, 17);
+ this.chkConvertToSdf.TabIndex = 14;
+ this.chkConvertToSdf.Text = "Convert to SDF";
+ this.chkConvertToSdf.UseVisualStyleBackColor = true;
// ShpTransformationCtrl
this.Name = "ShpTransformationCtrl";
+ this.Size = new System.Drawing.Size(449, 209);
@@ -125,5 +140,6 @@
private System.Windows.Forms.Button btnBrowseCs;
private System.Windows.Forms.TextBox txtCoordinateSystem;
+ private System.Windows.Forms.CheckBox chkConvertToSdf;
Modified: sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/ShpTransformationCtrl.cs
--- sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/ShpTransformationCtrl.cs 2010-05-21 10:38:46 UTC (rev 4920)
+++ sandbox/maestro-2.5/Maestro.Editors/LoadProcedure/ShpTransformationCtrl.cs 2010-05-21 11:16:39 UTC (rev 4921)
@@ -25,14 +25,35 @@
using System.Text;
- public partial class ShpTransformationCtrl : CollapsiblePanel
+ public partial class ShpTransformationCtrl : CollapsiblePanel, IEditorBindable
public ShpTransformationCtrl()
+ var shplp = lp.Item as OSGeo.MapGuide.ObjectModels.LoadProcedure.ShpLoadProcedureType;
+ txtCoordinateSystem.DataBindings.Add("Text", shplp, "CoordinateSystem");
+ numGeneralizePercentage.DataBindings.Add("Value", shplp, "Generalization");
+ chkConvertToSdf.DataBindings.Add("Checked", shplp, "ConvertToSdf");
More information about the mapguide-commits
