[mapguide-commits] r4924 - in sandbox/maestro-2.5: Maestro.Base
Maestro.Base/Commands/Conditions Maestro.Base/UI
OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org
Mon May 24 08:13:10 EDT 2010
Author: jng
Date: 2010-05-24 08:13:09 -0400 (Mon, 24 May 2010)
New Revision: 4924
Added:
sandbox/maestro-2.5/Maestro.Base/Commands/Conditions/SelectedRootItemConditionEvaluator.cs
sandbox/maestro-2.5/Maestro.Base/Maestro.Base.addin
sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-2.5/Maestro.Base/UI/RepositoryTreeModel.cs
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/ResourceItems.cs
This submission includes the following changes:
- Include root node in the SiteExplorer
- Add new condition evaluator to determine if selected node is the root node.
- Wrap certain commands under the selected folder context menu to be disabled if selected folder is root.
Added: sandbox/maestro-2.5/Maestro.Base/Commands/Conditions/SelectedRootItemConditionEvaluator.cs
--- sandbox/maestro-2.5/Maestro.Base/Commands/Conditions/SelectedRootItemConditionEvaluator.cs (rev 0)
+++ sandbox/maestro-2.5/Maestro.Base/Commands/Conditions/SelectedRootItemConditionEvaluator.cs 2010-05-24 12:13:09 UTC (rev 4924)
@@ -0,0 +1,43 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using ICSharpCode.Core;
+namespace Maestro.Base.Commands.Conditions
+ internal class SelectedRootItemConditionEvaluator : IConditionEvaluator
+ public bool IsValid(object caller, Condition condition)
+ var wb = Workbench.Instance;
+ if (wb != null)
+ var exp = wb.ActiveSiteExplorer;
+ if (exp != null && exp.SelectedItems.Length == 1)
+ return !exp.SelectedItems[0].IsRoot;
+ return true;
Modified: sandbox/maestro-2.5/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-2.5/Maestro.Base/Maestro.Base.addin 2010-05-24 11:07:59 UTC (rev 4923)
+++ sandbox/maestro-2.5/Maestro.Base/Maestro.Base.addin 2010-05-24 12:13:09 UTC (rev 4924)
@@ -13,6 +13,7 @@
<ConditionEvaluator name="DebugMode" class="Maestro.Base.Commands.Conditions.DebugModeConditionEvaluator" />
<ConditionEvaluator name="IsConnected" class="Maestro.Base.Commands.Conditions.IsConnectedConditionEvaluator" />
<ConditionEvaluator name="NotConnected" class="Maestro.Base.Commands.Conditions.NotConnectedConditionEvaluator" />
+ <ConditionEvaluator name="IsNotRoot" class="Maestro.Base.Commands.Conditions.SelectedRootItemConditionEvaluator" />
<ConditionEvaluator name="EditorFunction" class="Maestro.Base.Commands.Conditions.ActiveEditorConditionEvaluator" />
<ConditionEvaluator name="CanClose" class="Maestro.Base.Commands.Conditions.CloseableDocumentConditionEvaluator" />
<ConditionEvaluator name="SelectedItem" class="Maestro.Base.Commands.Conditions.SelectedItemConditionEvaluator" />
@@ -232,19 +233,23 @@
<MenuItem id="CreatePackage"
label="${res:SiteExplorer_SelectedFolder_CreatePackage}"
class="Maestro.Base.Commands.NotImplementedCommand" />
- <MenuItem id="Delete"
- label="${res:SiteExplorer_SelectedItem_Delete}"
- class="Maestro.Base.Commands.NotImplementedCommand" />
+ <Condition action="Disable" name="IsNotRoot">
+ <MenuItem id="Delete"
+ label="${res:SiteExplorer_SelectedItem_Delete}"
+ class="Maestro.Base.Commands.NotImplementedCommand" />
+ </Condition>
<MenuItem id="LoadPackage"
label="${res:SiteExplorer_SelectedFolder_LoadPackage}"
<MenuItem type="Separator" />
- <MenuItem id="Copy"
- label="${res:SiteExplorer_SelectedItem_Copy}"
- <MenuItem id="Cut"
- label="${res:SiteExplorer_SelectedItem_Cut}"
+ <MenuItem id="Copy"
+ label="${res:SiteExplorer_SelectedItem_Copy}"
+ <MenuItem id="Cut"
+ label="${res:SiteExplorer_SelectedItem_Cut}"
+ </Condition>
<MenuItem id="Paste"
label="${res:SiteExplorer_SelectedFolder_Paste}"
Modified: sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj 2010-05-24 11:07:59 UTC (rev 4923)
+++ sandbox/maestro-2.5/Maestro.Base/Maestro.Base.csproj 2010-05-24 12:13:09 UTC (rev 4924)
@@ -47,6 +47,7 @@
<Compile Include="Commands\Conditions\NotConnectedConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\DebugModeConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\SelectedItemConditionEvaluator.cs" />
+ <Compile Include="Commands\Conditions\SelectedRootItemConditionEvaluator.cs" />
<Compile Include="Commands\CopyCommand.cs" />
<Compile Include="Commands\CutCommand.cs" />
<Compile Include="Commands\LoginCommand.cs" />
Modified: sandbox/maestro-2.5/Maestro.Base/UI/RepositoryTreeModel.cs
--- sandbox/maestro-2.5/Maestro.Base/UI/RepositoryTreeModel.cs 2010-05-24 11:07:59 UTC (rev 4923)
+++ sandbox/maestro-2.5/Maestro.Base/UI/RepositoryTreeModel.cs 2010-05-24 12:13:09 UTC (rev 4924)
@@ -24,6 +24,7 @@
using OSGeo.MapGuide.MaestroAPI;
using OSGeo.MapGuide.ObjectModels.Common;
using System.Drawing;
+using System.Diagnostics;
namespace Maestro.Base.UI
@@ -39,6 +40,11 @@
_item = item;
+ public bool IsRoot
+ get { return this.ResourceId == "Library://"; }
public string ResourceId
get { return _item.ResourceId; }
@@ -78,29 +84,36 @@
get
- switch (_item.ResourceType)
+ if (IsRoot)
- case ResourceTypes.DrawingSource:
- return Properties.Resources.blueprints;
- case ResourceTypes.FeatureSource:
- return Properties.Resources.database_share;
- case ResourceTypes.Folder:
- return Properties.Resources.folder_horizontal;
- case ResourceTypes.LayerDefinition:
- return Properties.Resources.layer;
- case ResourceTypes.MapDefinition:
- return Properties.Resources.map;
- case ResourceTypes.WebLayout:
- return Properties.Resources.application_browser;
- case ResourceTypes.ApplicationDefinition:
- return Properties.Resources.applications_stack;
- case ResourceTypes.SymbolLibrary:
- return Properties.Resources.images_stack;
- case ResourceTypes.PrintLayout:
- return Properties.Resources.printer;
- default:
- return Properties.Resources.document;
+ return Properties.Resources.server;
+ else
+ switch (_item.ResourceType)
+ case ResourceTypes.DrawingSource:
+ return Properties.Resources.blueprints;
+ case ResourceTypes.FeatureSource:
+ return Properties.Resources.database_share;
+ case ResourceTypes.Folder:
+ return Properties.Resources.folder_horizontal;
+ case ResourceTypes.LayerDefinition:
+ return Properties.Resources.layer;
+ case ResourceTypes.MapDefinition:
+ return Properties.Resources.map;
+ case ResourceTypes.WebLayout:
+ return Properties.Resources.application_browser;
+ case ResourceTypes.ApplicationDefinition:
+ return Properties.Resources.applications_stack;
+ case ResourceTypes.SymbolLibrary:
+ return Properties.Resources.images_stack;
+ case ResourceTypes.PrintLayout:
+ return Properties.Resources.printer;
+ default:
+ return Properties.Resources.document;
@@ -158,7 +171,7 @@
if (treePath.IsEmpty())
- var list = _conn.ResourceService.GetRepositoryResources("Library://", 1);
+ var list = _conn.ResourceService.GetRepositoryResources("Library://", 0);
return GetSorted(list);
else
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/ResourceItems.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/ResourceItems.cs 2010-05-24 11:07:59 UTC (rev 4923)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/ObjectModels/ResourceItems.cs 2010-05-24 12:13:09 UTC (rev 4924)
@@ -83,7 +83,13 @@
[XmlIgnore]
public string Name
- get { return ResourceIdentifier.GetName(this.ResourceId); }
+ get
+ if (this.ResourceId != "Library://")
+ return ResourceIdentifier.GetName(this.ResourceId);
+ else
+ return "Root"; //LOCALIZE
[XmlIgnore]
More information about the mapguide-commits
