[mapguide-commits] r4926 - in sandbox/maestro-2.5:
OSGeo.MapGuide.MaestroAPI/Schemas
Thirdparty/Xsd2Code/Xsd2Code.Console
Thirdparty/Xsd2Code/Xsd2Code.Console/Resources
Thirdparty/Xsd2Code/Xsd2Code.Library
svn_mapguide at osgeo.org
Tue May 25 01:51:32 EDT 2010
Author: jng
Date: 2010-05-25 01:51:31 -0400 (Tue, 25 May 2010)
New Revision: 4926
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Schemas/generate.bat
sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console/
sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console/EntryPoint.cs
sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console/Resources/Help.txt
sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console/Xsd2Code.csproj
sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Library/
Update internal copy of Xsd2Code with support for lazy loading switch.
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Schemas/generate.bat
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Schemas/generate.bat 2010-05-25 00:52:54 UTC (rev 4925)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Schemas/generate.bat 2010-05-25 05:51:31 UTC (rev 4926)
@@ -1,5 +1,5 @@
SET NS_ROOT=OSGeo.MapGuide.ObjectModels
-SET XSD_OPTS=/c BindingList /is+ /cl+ /db+ /sc+ /xa+ /if+ /hp+
+SET XSD_OPTS=/c BindingList /is+ /cl+ /db+ /sc+ /xa+ /hp+ /if- /ll-
SET GEN_ROOT=..\..\Generated
xsd2code.exe ApplicationDefinition-1.0.0.xsd %GEN_ROOT%\ApplicationDefinition-1.0.0.cs /n %NS_ROOT%.ApplicationDefinition %XSD_OPTS%
xsd2code.exe ApplicationDefinitionInfo-1.0.0.xsd %GEN_ROOT%\ApplicationDefinitionInfo-1.0.0.cs /n %NS_ROOT%.ApplicationDefinition %XSD_OPTS%
Property changes on: sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console
___________________________________________________________________
Added: svn:ignore
+ bin
obj
Modified: sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console/EntryPoint.cs
--- sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console/EntryPoint.cs 2010-05-25 00:52:54 UTC (rev 4925)
+++ sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console/EntryPoint.cs 2010-05-25 05:51:31 UTC (rev 4926)
@@ -281,6 +281,14 @@
generatorParams.HidePrivateFieldInIde = false;
break;
+ case "/ll":
+ case "/ll+":
+ generatorParams.EnableLasyLoading = true;
+ break;
+ case "/ll-":
+ generatorParams.EnableLasyLoading = false;
+ break;
case "/s":
case "/s+":
case "/is":
Modified: sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console/Resources/Help.txt
--- sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console/Resources/Help.txt 2010-05-25 00:52:54 UTC (rev 4925)
+++ sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console/Resources/Help.txt 2010-05-25 05:51:31 UTC (rev 4926)
@@ -56,6 +56,9 @@
/if[+] - Enable initialization of fields (default)
/if- - Disable all field initialization constructor or lazy
+ /ll[+] - Enable Lazy Loading. Initialization of fields (/if) must be enabled
+ /ll[-] - Do not enable Lazy Loading (default)
/eit[+] - Exclude types from included Schemas in generation
/eit- - Generate types from included schemas (default)
Modified: sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console/Xsd2Code.csproj
--- sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console/Xsd2Code.csproj 2010-05-25 00:52:54 UTC (rev 4925)
+++ sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Console/Xsd2Code.csproj 2010-05-25 05:51:31 UTC (rev 4926)
@@ -48,7 +48,7 @@
<TargetFrameworkVersion>v3.5</TargetFrameworkVersion>
</PropertyGroup>
<PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
- <OutputPath>bin\Debug\</OutputPath>
+ <OutputPath>..\..\..\OSGeo.MapGuide.MaestroAPI\Schemas\</OutputPath>
<AllowUnsafeBlocks>false</AllowUnsafeBlocks>
<BaseAddress>285212672</BaseAddress>
<CheckForOverflowUnderflow>false</CheckForOverflowUnderflow>
@@ -106,11 +106,6 @@
<Reference Include="System.Xml">
<Name>System.XML</Name>
</Reference>
- <ProjectReference Include="..\Xsd2Code.Library\Xsd2Code.Library.csproj">
- <Name>Xsd2Code.Library</Name>
- <Project>{1B59FB12-699C-4927-ACA3-D7F0E0F79100}</Project>
- <Package>{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}</Package>
- </ProjectReference>
</ItemGroup>
<ItemGroup>
<Content Include="App.ico" />
Property changes on: sandbox/maestro-2.5/Thirdparty/Xsd2Code/Xsd2Code.Library
Added: svn:ignore
+ bin
obj
More information about the mapguide-commits
