[mapguide-commits] r5371 - in trunk/MgDev: Server/src/Services/Feature Web/src/HttpHandler
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Nov 5 02:16:09 EDT 2010
Author: liuar
Date: 2010-11-04 23:16:09 -0700 (Thu, 04 Nov 2010)
New Revision: 5371
   trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
   trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp
   trunk/MgDev/Web/src/HttpHandler/WfsFeatureDefinitions.cpp
   trunk/MgDev/Web/src/HttpHandler/WfsFeatureDefinitions.h
Ticket #1421: OGC WFS 1.1.0 Support
18. In order to pass the WFS certification, Mapguide should provide a way to customize the namespaceURL and namespacePrefix to the response document for GetFeature and DescribeFeatureType.
FDO provided following 2 APIs to set the namespaceURL and namespacePrefix.
    /// \brief
    /// Sets the default namespace which defines all feature/object types found in the input
    /// feature reader which is to be serialized. The user is also supposed to set the schema
    /// location for this namespace.
    /// \param defaultNamespace
    /// Default namespace.
    FDO_API virtual void SetDefaultNamespace(FdoString* defaultNamespace);
    /// \brief
    /// Sets the default namespace prefix
    /// If the prefix is not set then it could be defaulted to the schema name.
    /// Default namespace prefix.
    FDO_API virtual void SetDefaultNamespacePrefix(FdoString* prefix);
MapGuide set thte namespaceURL and namesapcePrefix for the GetFeature response GML based on above FDO API
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp	2010-11-04 22:02:19 UTC (rev 5370)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp	2010-11-05 06:16:09 UTC (rev 5371)
@@ -1830,8 +1830,6 @@
     if (fc == NULL)
         return NULL;
-    STRING geomPropName = fc->GetDefaultGeometryPropertyName();
     //execute the spatial query
     Ptr<MgFeatureQueryOptions> options = new MgFeatureQueryOptions();
@@ -1919,8 +1917,6 @@
     flags->SetMemberName(L"featureMember");
     flags->SetMemberUri(L"http://www.opengis.net/gml");
-    // set schemaLocations
     // gml schema location and version
     if(L"text/xml; subtype=gml/2.1.2" == outputFormat)
@@ -1938,6 +1934,30 @@
         __LINE__, __WFILE__, NULL, L"", NULL);
+    // For WFS CITE certification
+    // gml_id, gml_name and gml_description properties must be serialized with gml namespace.
+    Ptr<MgPropertyDefinitionCollection> properties = fc->GetProperties();
+    for(int i = 0; i<properties->GetCount(); i++)
+        Ptr<MgPropertyDefinition> prop = properties->GetItem(i);
+        STRING propName = prop->GetName();
+        if(L"GML_ID" == MgUtil::ToUpper(propName))
+             FdoPtr<FdoStringCollection> gmlIDRelatePropertyNames = FdoStringCollection::Create();
+             gmlIDRelatePropertyNames->Add(propName.c_str());
+             flags->SetGmlIDRelatePropertyNames(gmlIDRelatePropertyNames);
+        else if(L"GML_NAME" == MgUtil::ToUpper(propName))
+            flags->SetGmlNameRelatePropertyName(propName.c_str());
+        else if(L"GML_DESCRIPTION" == MgUtil::ToUpper(propName))
+            flags->SetGmlDescriptionRelatePropertyName(propName.c_str());
     // wfs schema location
     if(L"1.0.0" == wfsVersion)
@@ -1953,20 +1973,22 @@
-    // default namespace schema location
-    flags->SetSchemaLocation(L"http://www.mynamespace.com/myns", L"http://www.mynamespace.com/myns/myns.xsd");
+    // set the default namespace prefix
+    if(!namespacePrefix.empty())
+        flags->SetDefaultNamespacePrefix(namespacePrefix.c_str());
-    if(!namespacePrefix.empty())
+    if(!namespaceUrl.empty())
-        STRING defaultNamespace(L"http://fdo.osgeo.org/schemas/feature/");
-        defaultNamespace += namespacePrefix;
-        flags->SetDefaultNamespace(defaultNamespace.c_str());
+        flags->SetDefaultNamespace(namespaceUrl.c_str());
     else
-        flags->SetDefaultNamespace(L"http://www.mynamespace.com/myns");
+        STRING defaultNamespace(L"http://fdo.osgeo.org/schemas/feature/");
+        defaultNamespace += schemaName;
+        flags->SetDefaultNamespace(defaultNamespace.c_str());
     //create the FDO xml serializer stack and write out the features
Modified: trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp	2010-11-04 22:02:19 UTC (rev 5370)
+++ trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp	2010-11-05 06:16:09 UTC (rev 5371)
@@ -271,7 +271,7 @@
                             // Call the C++ API
                             Ptr<MgByteReader> resultReader = featureService->GetWfsFeature(featureSourceId, ((sSchemaHash.size()==0) ? sClass : sSchemaHash + _(":") + sClass),
-                                requiredProperties, m_getFeatureParams->GetSrs(), filter, numFeaturesToRetrieve, sVersion, sOutputFormat, sSortCriteria, sPrefix, L"");
+                                requiredProperties, m_getFeatureParams->GetSrs(), filter, numFeaturesToRetrieve, sVersion, sOutputFormat, sSortCriteria, sPrefix, oFeatureTypes.GetNamespaceUrl());
                             // TODO How to determine number of features retrieved...?
                             // Note: for now, maxFeatures is managed by the MgWfsFeatures object. - TMT 2006-3-20
Modified: trunk/MgDev/Web/src/HttpHandler/WfsFeatureDefinitions.cpp
--- trunk/MgDev/Web/src/HttpHandler/WfsFeatureDefinitions.cpp	2010-11-04 22:02:19 UTC (rev 5370)
+++ trunk/MgDev/Web/src/HttpHandler/WfsFeatureDefinitions.cpp	2010-11-05 06:16:09 UTC (rev 5371)
@@ -183,7 +183,7 @@
-bool MgWfsFeatureDefinitions::GetMetadataDefinitions(MgXmlParser& Input,CStream& oStream, bool& isPublished)
+bool MgWfsFeatureDefinitions::GetMetadataDefinitions(MgXmlParser& Input,CStream& oStream, bool& isPublished, STRING& prefix)
     STRING sDebug = Input.Current().Contents();
     MgXmlSynchronizeOnElement ElementResourceDocumentHeader(Input,_("ResourceDocumentHeader"));
@@ -243,6 +243,11 @@
                     isPublished = true;
+                // If user defined a customized prefix, it will replace the auto generated one.
+                else if(SZ_EQ(sDefinitionName.c_str(), _("Feature.Prefix")))
+                     prefix = sValue;
                 // WFS 1.1.0 replaces PrimarySRS with DefaultSRS
                 else if(SZ_EQ(sDefinitionName.c_str(), _("Feature.PrimarySRS")))
@@ -332,6 +337,13 @@
                 STRING requiredPrefix = typeName.substr(0, separatorPos);
                 if(!requiredPrefix.empty())
+                    // If there's a customized prefix, we should ignore the optimization.
+                    if(requiredPrefix.find(_("ns")) != 0)
+                        requiredPrefixList = NULL;
+                        break;
                     requiredPrefixList->Add(requiredPrefix);
                 else
@@ -403,7 +415,7 @@
                 AddDefinition(oDefinitions,_("Feature.Prefix"),sPrefix.c_str());
                 AddDefinition(oDefinitions,_("Feature.Resource"),sResource.c_str());
-            else if(GetMetadataDefinitions(Input,oDefinitions,required))
+            else if(GetMetadataDefinitions(Input,oDefinitions,required,sPrefix))
                 // Optimization: Stop processing if this feature source isn't published
                 if(!required)
@@ -635,6 +647,21 @@
+STRING MgWfsFeatureDefinitions::GetNamespaceUrl()
+    STRING sKey = _("<Define item='Feature.Url'>");
+    STRING::size_type iPos = m_sSourcesAndClasses.find(sKey);
+    STRING url = _("");
+    if(iPos != STRING::npos)
+        iPos += sKey.length(); // advance us past the key
+        STRING::size_type iEnd = m_sSourcesAndClasses.find(_("</Define>"),iPos); // NOXLATE
+        url = m_sSourcesAndClasses.substr(iPos,iEnd-iPos);
+    return url;
Modified: trunk/MgDev/Web/src/HttpHandler/WfsFeatureDefinitions.h
--- trunk/MgDev/Web/src/HttpHandler/WfsFeatureDefinitions.h	2010-11-04 22:02:19 UTC (rev 5370)
+++ trunk/MgDev/Web/src/HttpHandler/WfsFeatureDefinitions.h	2010-11-05 06:16:09 UTC (rev 5371)
@@ -54,10 +54,11 @@
     //   and DescribeFeatureType.)
     bool PrefixToFeatureSource(STRING sPrefix, REFSTRING sFeatureSource, REFSTRING sSchemaName);
+    STRING GetNamespaceUrl();
 private:
     bool   SkipElement(MgXmlParser& Input,CPSZ pszElementName);
     bool   GetElementContents(MgXmlParser& Input,CPSZ pszElementName,STRING& sValue);
-    bool   GetMetadataDefinitions(MgXmlParser& Input,CStream& oStream,bool& isPublished);
+    bool   GetMetadataDefinitions(MgXmlParser& Input,CStream& oStream,bool& isPublished,STRING& prefix);
     void   AddDefinition(CStream& oStream,CPSZ pszPropertyName,CPSZ pszPropertyValue);
More information about the mapguide-commits mailing list
