[mapguide-commits] r5415 - in sandbox/maestro-3.0: Maestro
Maestro.Base Maestro.Base/Editor Maestro.Base/Templates
Maestro.Editors Maestro.Editors/Common Maestro.Editors/Fusion
Maestro.Packaging MaestroAPITestRunner MaestroAPITests
MaestroFsPreview OSGeo.MapGuide.MaestroAPI
OSGeo.MapGuide.MaestroAPI/Commands
OSGeo.MapGuide.MaestroAPI/Expression
OSGeo.MapGuide.MaestroAPI/Feature OSGeo.MapGuide.MaestroAPI/IO
OSGeo.MapGuide.MaestroAPI/Mapping
OSGeo.MapGuide.MaestroAPI/ObjectModels
OSGeo.MapGuide.MaestroAPI/Resource
OSGeo.MapGuide.MaestroAPI/Resource/Validation
OSGeo.MapGuide.MaestroAPI/Services OSGeo.MapGuide.MaestroAPI.Http
OSGeo.MapGuide.MaestroAPI.Native
svn_mapguide at osgeo.org
Tue Nov 30 03:21:58 EST 2010
Author: jng
Date: 2010-11-30 00:21:57 -0800 (Tue, 30 Nov 2010)
New Revision: 5415
Added:
sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.cs
sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.resx
sandbox/maestro-3.0/Maestro/Maestro_All.sln
sandbox/maestro-3.0/MaestroAPITestRunner/App.config
sandbox/maestro-3.0/MaestroAPITestRunner/ConnectionProviders.xml
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/MgReadOnlyStream.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/IO/ReadOnlyRewindableStream.cs
Removed:
sandbox/maestro-3.0/MaestroAPITests/App.config
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/IDynamicInvokable.cs
sandbox/maestro-3.0/Maestro.Base/Editor/IEditorFactory.cs
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-3.0/Maestro.Base/Templates/ApplicationDefinitionItemTemplate.cs
sandbox/maestro-3.0/Maestro.Editors/Common/ResourceDataCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexibleLayoutEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexibleLayoutEditor.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/MapSettingsCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/MapSettingsCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/MapSettingsCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
sandbox/maestro-3.0/Maestro.Packaging/PackageBuilder.cs
sandbox/maestro-3.0/MaestroAPITestRunner/MaestroAPITestRunner.csproj
sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj
sandbox/maestro-3.0/MaestroAPITests/RuntimeMapTests.cs
sandbox/maestro-3.0/MaestroFsPreview/MaestroFsPreview.csproj
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeFeatureSetReader.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/OSGeo.MapGuide.MaestroAPI.Native.csproj
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/Utility.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/CommandType.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/ExecuteLoadProcedure.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Expression/FdoFunctionNamespace.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Feature/FeatureSetReader.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaces.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResource.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ApplicationDefinitionValidator.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Services/IResourceService.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Utility.cs
This submission includes the following changes:
- Submit current work on Fusion Editor.
- Move app.config form Unit Test library to Test Runner
- Add an experimental System.IO.Stream wrapper around MgByteReader. This is to remove the overhead of needing to fully copy the contents of the underlying MgByteReader to a fully managed stream and at the same time workaround the issue of invalidation when passed as a parameter. However, MgByteStream to Stream conversion is still the method being used as I am still yet to fully setup the required libraries to fully profile performance for the native implementation.
- Add a performance unit test for RuntimeMap, testing runtime map creation on a 200 layer, 50 group map definition.
- Remove the IDynamicInvokable interface, as supported interface testing is already good enough approach for the pending resource upgrade feature
Property changes on: sandbox/maestro-3.0/Maestro
___________________________________________________________________
Modified: svn:ignore
- Maestro.suo
obj
*.user
*.cache
+ Maestro.suo
obj
*.user
*.cache
*.suo
Added: sandbox/maestro-3.0/Maestro/Maestro_All.sln
--- sandbox/maestro-3.0/Maestro/Maestro_All.sln (rev 0)
+++ sandbox/maestro-3.0/Maestro/Maestro_All.sln 2010-11-30 08:21:57 UTC (rev 5415)
@@ -0,0 +1,158 @@
+Microsoft Visual Studio Solution File, Format Version 10.00
+# Visual C# Express 2008
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro", "Maestro.csproj", "{E0C36475-2B70-4F6D-ACE0-8943167806DC}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "ICSharpCode.Core", "..\Thirdparty\SharpDevelop\ICSharpCode.Core\ICSharpCode.Core.csproj", "{35CEF10F-2D4C-45F2-9DD1-161E0FEC583C}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "ICSharpCode.Core.WinForms", "..\Thirdparty\SharpDevelop\ICSharpCode.Core.WinForms\ICSharpCode.Core.WinForms.csproj", "{857CA1A3-FC88-4BE0-AB6A-D1EE772AB288}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro.Base", "..\Maestro.Base\Maestro.Base.csproj", "{F1E2F468-5030-4DBA-968C-9620284AFAA1}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MaestroBaseTests", "..\MaestroBaseTests\MaestroBaseTests.csproj", "{CE5F281C-0162-4832-87BB-A677D13D116F}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MaestroFsPreview", "..\MaestroFsPreview\MaestroFsPreview.csproj", "{59BE5E18-17B6-431D-836E-C0AABA6D69E8}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro.AddIn.ExtendedObjectModels", "..\Maestro.AddIn.ExtendedObjectModels\Maestro.AddIn.ExtendedObjectModels.csproj", "{32BA7DF6-1AFA-441D-9231-5624C5920706}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MgCooker", "..\MgCooker\MgCooker.csproj", "{C7DCF771-5982-4859-A17F-01126E6F9BA6}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MgCooker.Cmd", "..\MgCooker.Cmd\MgCooker.Cmd.csproj", "{0FD82B7B-1264-410F-86D1-47E9CCACD68E}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro.Editors", "..\Maestro.Editors\Maestro.Editors.csproj", "{5AD2CDBA-952E-4148-98A1-31D2E0D540D5}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro.Login", "..\Maestro.Login\Maestro.Login.csproj", "{07588440-5F9F-4C30-AA06-9CF30BA6DDE6}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro.Packaging", "..\Maestro.Packaging\Maestro.Packaging.csproj", "{0EA33E36-9C33-4D60-B378-B87FADAA0F40}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro.Shared.UI", "..\Maestro.Shared.UI\Maestro.Shared.UI.csproj", "{CFD19053-2172-41D3-8460-0FD2123A1E88}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.MaestroAPI", "..\OSGeo.MapGuide.MaestroAPI\OSGeo.MapGuide.MaestroAPI.csproj", "{80FA3158-8B5F-48D1-A393-0378AFE48A7E}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.MaestroAPI.Http", "..\OSGeo.MapGuide.MaestroAPI.Http\OSGeo.MapGuide.MaestroAPI.Http.csproj", "{6EF1E775-444B-4E5F-87FB-D687C43A68D7}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.MaestroAPI.Native", "..\OSGeo.MapGuide.MaestroAPI.Native\OSGeo.MapGuide.MaestroAPI.Native.csproj", "{F4420153-9DF3-4407-AD65-E8ABED2B6E25}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.ObjectModels.LayerDefinition-1.1.0", "..\ExtendedModels\LayerDefinition-1.1.0\OSGeo.MapGuide.ObjectModels.LayerDefinition-1.1.0.csproj", "{B5EA049C-6AB7-4686-A2F4-4BA2EAC0E585}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.ObjectModels.LayerDefinition-1.2.0", "..\ExtendedModels\LayerDefinition-1.2.0\OSGeo.MapGuide.ObjectModels.LayerDefinition-1.2.0.csproj", "{EDDB0F74-6FE7-4969-80B0-817A629722CD}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.ObjectModels.LayerDefinition-1.3.0", "..\ExtendedModels\LayerDefinition-1.3.0\OSGeo.MapGuide.ObjectModels.LayerDefinition-1.3.0.csproj", "{AC5068F6-CFBE-4BCD-B68B-062725E424D4}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.ObjectModels.LoadProcedure-1.1.0", "..\ExtendedModels\LoadProcedure-1.1.0\OSGeo.MapGuide.ObjectModels.LoadProcedure-1.1.0.csproj", "{B2A1F69E-52AA-42A2-8DED-89ADB9B14A38}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.ObjectModels.LoadProcedure-2.2.0", "..\ExtendedModels\LoadProcedure-2.2.0\OSGeo.MapGuide.ObjectModels.LoadProcedure-2.2.0.csproj", "{D525B343-66D6-4D6B-9A55-78A173D94A51}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.ObjectModels.SymbolDefinition-1.1.0", "..\ExtendedModels\SymbolDefinition-1.1.0\OSGeo.MapGuide.ObjectModels.SymbolDefinition-1.1.0.csproj", "{BF6E996E-27AF-44CD-B3CF-A40874E15B2E}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.ObjectModels.WebLayout-1.1.0", "..\ExtendedModels\WebLayout-1.1.0\OSGeo.MapGuide.ObjectModels.WebLayout-1.1.0.csproj", "{0A93ACA8-5B21-44E6-B0B7-5D1E72D3A6A2}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Aga.Controls", "..\Thirdparty\TreeViewAdv\Aga.Controls\Aga.Controls.csproj", "{E73BB233-D88B-44A7-A98F-D71EE158381D}"
+EndProject
+Global
+ GlobalSection(SolutionConfigurationPlatforms) = preSolution
+ Debug|Any CPU = Debug|Any CPU
+ Release|Any CPU = Release|Any CPU
+ EndGlobalSection
+ GlobalSection(ProjectConfigurationPlatforms) = postSolution
+ {E0C36475-2B70-4F6D-ACE0-8943167806DC}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {E0C36475-2B70-4F6D-ACE0-8943167806DC}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {E0C36475-2B70-4F6D-ACE0-8943167806DC}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {E0C36475-2B70-4F6D-ACE0-8943167806DC}.Release|Any CPU.Build.0 = Release|Any CPU
+ {35CEF10F-2D4C-45F2-9DD1-161E0FEC583C}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {35CEF10F-2D4C-45F2-9DD1-161E0FEC583C}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {35CEF10F-2D4C-45F2-9DD1-161E0FEC583C}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {35CEF10F-2D4C-45F2-9DD1-161E0FEC583C}.Release|Any CPU.Build.0 = Release|Any CPU
+ {857CA1A3-FC88-4BE0-AB6A-D1EE772AB288}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {857CA1A3-FC88-4BE0-AB6A-D1EE772AB288}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {857CA1A3-FC88-4BE0-AB6A-D1EE772AB288}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {857CA1A3-FC88-4BE0-AB6A-D1EE772AB288}.Release|Any CPU.Build.0 = Release|Any CPU
+ {F1E2F468-5030-4DBA-968C-9620284AFAA1}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {F1E2F468-5030-4DBA-968C-9620284AFAA1}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {F1E2F468-5030-4DBA-968C-9620284AFAA1}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {F1E2F468-5030-4DBA-968C-9620284AFAA1}.Release|Any CPU.Build.0 = Release|Any CPU
+ {CE5F281C-0162-4832-87BB-A677D13D116F}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {CE5F281C-0162-4832-87BB-A677D13D116F}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {CE5F281C-0162-4832-87BB-A677D13D116F}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {CE5F281C-0162-4832-87BB-A677D13D116F}.Release|Any CPU.Build.0 = Release|Any CPU
+ {59BE5E18-17B6-431D-836E-C0AABA6D69E8}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {59BE5E18-17B6-431D-836E-C0AABA6D69E8}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {59BE5E18-17B6-431D-836E-C0AABA6D69E8}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {59BE5E18-17B6-431D-836E-C0AABA6D69E8}.Release|Any CPU.Build.0 = Release|Any CPU
+ {32BA7DF6-1AFA-441D-9231-5624C5920706}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {32BA7DF6-1AFA-441D-9231-5624C5920706}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {32BA7DF6-1AFA-441D-9231-5624C5920706}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {32BA7DF6-1AFA-441D-9231-5624C5920706}.Release|Any CPU.Build.0 = Release|Any CPU
+ {C7DCF771-5982-4859-A17F-01126E6F9BA6}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {C7DCF771-5982-4859-A17F-01126E6F9BA6}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {C7DCF771-5982-4859-A17F-01126E6F9BA6}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {C7DCF771-5982-4859-A17F-01126E6F9BA6}.Release|Any CPU.Build.0 = Release|Any CPU
+ {0FD82B7B-1264-410F-86D1-47E9CCACD68E}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {0FD82B7B-1264-410F-86D1-47E9CCACD68E}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {0FD82B7B-1264-410F-86D1-47E9CCACD68E}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {0FD82B7B-1264-410F-86D1-47E9CCACD68E}.Release|Any CPU.Build.0 = Release|Any CPU
+ {5AD2CDBA-952E-4148-98A1-31D2E0D540D5}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {5AD2CDBA-952E-4148-98A1-31D2E0D540D5}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {5AD2CDBA-952E-4148-98A1-31D2E0D540D5}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {5AD2CDBA-952E-4148-98A1-31D2E0D540D5}.Release|Any CPU.Build.0 = Release|Any CPU
+ {07588440-5F9F-4C30-AA06-9CF30BA6DDE6}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {07588440-5F9F-4C30-AA06-9CF30BA6DDE6}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {07588440-5F9F-4C30-AA06-9CF30BA6DDE6}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {07588440-5F9F-4C30-AA06-9CF30BA6DDE6}.Release|Any CPU.Build.0 = Release|Any CPU
+ {0EA33E36-9C33-4D60-B378-B87FADAA0F40}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {0EA33E36-9C33-4D60-B378-B87FADAA0F40}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {0EA33E36-9C33-4D60-B378-B87FADAA0F40}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {0EA33E36-9C33-4D60-B378-B87FADAA0F40}.Release|Any CPU.Build.0 = Release|Any CPU
+ {CFD19053-2172-41D3-8460-0FD2123A1E88}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {CFD19053-2172-41D3-8460-0FD2123A1E88}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {CFD19053-2172-41D3-8460-0FD2123A1E88}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {CFD19053-2172-41D3-8460-0FD2123A1E88}.Release|Any CPU.Build.0 = Release|Any CPU
+ {80FA3158-8B5F-48D1-A393-0378AFE48A7E}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {80FA3158-8B5F-48D1-A393-0378AFE48A7E}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {80FA3158-8B5F-48D1-A393-0378AFE48A7E}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {80FA3158-8B5F-48D1-A393-0378AFE48A7E}.Release|Any CPU.Build.0 = Release|Any CPU
+ {6EF1E775-444B-4E5F-87FB-D687C43A68D7}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {6EF1E775-444B-4E5F-87FB-D687C43A68D7}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {6EF1E775-444B-4E5F-87FB-D687C43A68D7}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {6EF1E775-444B-4E5F-87FB-D687C43A68D7}.Release|Any CPU.Build.0 = Release|Any CPU
+ {F4420153-9DF3-4407-AD65-E8ABED2B6E25}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {F4420153-9DF3-4407-AD65-E8ABED2B6E25}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {F4420153-9DF3-4407-AD65-E8ABED2B6E25}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {F4420153-9DF3-4407-AD65-E8ABED2B6E25}.Release|Any CPU.Build.0 = Release|Any CPU
+ {B5EA049C-6AB7-4686-A2F4-4BA2EAC0E585}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {B5EA049C-6AB7-4686-A2F4-4BA2EAC0E585}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {B5EA049C-6AB7-4686-A2F4-4BA2EAC0E585}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {B5EA049C-6AB7-4686-A2F4-4BA2EAC0E585}.Release|Any CPU.Build.0 = Release|Any CPU
+ {EDDB0F74-6FE7-4969-80B0-817A629722CD}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {EDDB0F74-6FE7-4969-80B0-817A629722CD}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {EDDB0F74-6FE7-4969-80B0-817A629722CD}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {EDDB0F74-6FE7-4969-80B0-817A629722CD}.Release|Any CPU.Build.0 = Release|Any CPU
+ {AC5068F6-CFBE-4BCD-B68B-062725E424D4}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {AC5068F6-CFBE-4BCD-B68B-062725E424D4}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {AC5068F6-CFBE-4BCD-B68B-062725E424D4}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {AC5068F6-CFBE-4BCD-B68B-062725E424D4}.Release|Any CPU.Build.0 = Release|Any CPU
+ {B2A1F69E-52AA-42A2-8DED-89ADB9B14A38}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {B2A1F69E-52AA-42A2-8DED-89ADB9B14A38}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {B2A1F69E-52AA-42A2-8DED-89ADB9B14A38}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {B2A1F69E-52AA-42A2-8DED-89ADB9B14A38}.Release|Any CPU.Build.0 = Release|Any CPU
+ {D525B343-66D6-4D6B-9A55-78A173D94A51}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {D525B343-66D6-4D6B-9A55-78A173D94A51}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {D525B343-66D6-4D6B-9A55-78A173D94A51}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {D525B343-66D6-4D6B-9A55-78A173D94A51}.Release|Any CPU.Build.0 = Release|Any CPU
+ {BF6E996E-27AF-44CD-B3CF-A40874E15B2E}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {BF6E996E-27AF-44CD-B3CF-A40874E15B2E}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {BF6E996E-27AF-44CD-B3CF-A40874E15B2E}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {BF6E996E-27AF-44CD-B3CF-A40874E15B2E}.Release|Any CPU.Build.0 = Release|Any CPU
+ {0A93ACA8-5B21-44E6-B0B7-5D1E72D3A6A2}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {0A93ACA8-5B21-44E6-B0B7-5D1E72D3A6A2}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {0A93ACA8-5B21-44E6-B0B7-5D1E72D3A6A2}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {0A93ACA8-5B21-44E6-B0B7-5D1E72D3A6A2}.Release|Any CPU.Build.0 = Release|Any CPU
+ {E73BB233-D88B-44A7-A98F-D71EE158381D}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {E73BB233-D88B-44A7-A98F-D71EE158381D}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {E73BB233-D88B-44A7-A98F-D71EE158381D}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {E73BB233-D88B-44A7-A98F-D71EE158381D}.Release|Any CPU.Build.0 = Release|Any CPU
+ EndGlobalSection
+ GlobalSection(SolutionProperties) = preSolution
+ HideSolutionNode = FALSE
+ EndGlobalSection
+EndGlobal
Added: sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.Designer.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -0,0 +1,62 @@
+namespace Maestro.Base.Editor
+ partial class FusionEditor
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Component Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.flexEditor = new Maestro.Editors.Fusion.FlexibleLayoutEditor();
+ this.panelBody.SuspendLayout();
+ this.SuspendLayout();
+ // panelBody
+ this.panelBody.Controls.Add(this.flexEditor);
+ // flexEditor
+ this.flexEditor.AutoScroll = true;
+ this.flexEditor.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.flexEditor.Location = new System.Drawing.Point(0, 0);
+ this.flexEditor.Name = "flexEditor";
+ this.flexEditor.Size = new System.Drawing.Size(614, 520);
+ this.flexEditor.TabIndex = 0;
+ // FusionEditor
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Name = "FusionEditor";
+ this.panelBody.ResumeLayout(false);
+ this.ResumeLayout(false);
+ #endregion
+ private Maestro.Editors.Fusion.FlexibleLayoutEditor flexEditor;
Added: sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -0,0 +1,51 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Text;
+using System.Windows.Forms;
+using Maestro.Editors;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using Maestro.Editors.Fusion;
+ public partial class FusionEditor: EditorContentBase
+ public FusionEditor()
+ InitializeComponent();
+ private IResource _res;
+ private IEditorService _edsvc;
+ protected override void Bind(IEditorService service)
+ _edsvc = service;
+ _res = _edsvc.GetEditedResource();
+ flexEditor.Bind(service);
Added: sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.resx
--- sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.resx 2010-11-30 08:21:57 UTC (rev 5415)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
\ No newline at end of file
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/IEditorFactory.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/IEditorFactory.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/IEditorFactory.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -38,6 +38,21 @@
IEditorViewContent Create();
+ internal class FusionEditorFactory : IEditorFactory
+ public ResourceTypeDescriptor ResourceTypeAndVersion { get; private set; }
+ public FusionEditorFactory()
+ this.ResourceTypeAndVersion = new ResourceTypeDescriptor(OSGeo.MapGuide.MaestroAPI.ResourceTypes.ApplicationDefinition, "1.0.0");
+ public IEditorViewContent Create()
+ return new FusionEditor();
internal class DrawingSourceEditorFactory : IEditorFactory
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-11-30 08:21:57 UTC (rev 5415)
@@ -39,6 +39,7 @@
<!-- Registered editors -->
<Path name="/Maestro/Editors">
+ <Class id="FusionEditor100" class="Maestro.Base.Editor.FusionEditorFactory" />
<Class id="DrawingSourceEditor100" class="Maestro.Base.Editor.DrawingSourceEditorFactory" />
<Class id="FeatureSourceEditor100" class="Maestro.Base.Editor.FeatureSourceEditorFactory" />
<Class id="LayerDefinitionEditor100" class="Maestro.Base.Editor.LayerDefinitionEditorFactory" />
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-11-30 08:21:57 UTC (rev 5415)
@@ -143,6 +143,12 @@
<Compile Include="Editor\FsEditorOptionPanel.Designer.cs">
<DependentUpon>FsEditorOptionPanel.cs</DependentUpon>
</Compile>
+ <Compile Include="Editor\FusionEditor.cs">
+ <SubType>UserControl</SubType>
+ </Compile>
+ <Compile Include="Editor\FusionEditor.Designer.cs">
+ <DependentUpon>FusionEditor.cs</DependentUpon>
+ </Compile>
<Compile Include="Editor\IEditorFactory.cs" />
<Compile Include="Editor\IEditorViewContent.cs" />
<Compile Include="Editor\LayerDefinitionEditor.cs">
@@ -409,6 +415,9 @@
<EmbeddedResource Include="Editor\FsEditorOptionPanel.resx">
</EmbeddedResource>
+ <EmbeddedResource Include="Editor\FusionEditor.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="Editor\LayerDefinitionEditor.resx">
<DependentUpon>LayerDefinitionEditor.cs</DependentUpon>
</EmbeddedResource>
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/ApplicationDefinitionItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/ApplicationDefinitionItemTemplate.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/ApplicationDefinitionItemTemplate.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -26,6 +26,7 @@
using OSGeo.MapGuide.ObjectModels;
using OSGeo.MapGuide.ObjectModels.ApplicationDefinition;
+using Maestro.Editors.Generic;
namespace Maestro.Base.Templates
@@ -50,7 +51,20 @@
public override IResource CreateItem(IServerConnection conn)
- return ObjectFactory.CreateFlexibleLayout(conn, FusionTemplateNames.Slate);
+ //This is to just ensure we have a functional template when it's created
+ using (var picker = new ResourcePicker(conn.ResourceService, ResourceTypes.MapDefinition, ResourcePickerMode.OpenResource))
+ if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ var flex = ObjectFactory.CreateFlexibleLayout(conn, FusionTemplateNames.Slate);
+ var grp = flex.MapSet.GetGroupAt(0);
+ var map = grp.GetMapAt(0);
+ map.SetMapDefinition(picker.ResourceID);
+ return flex;
+ return null;
Modified: sandbox/maestro-3.0/Maestro.Editors/Common/ResourceDataCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/Common/ResourceDataCtrl.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/ResourceDataCtrl.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -30,6 +30,7 @@
using Maestro.Shared.UI;
using OSGeo.MapGuide.MaestroAPI.Exceptions;
+using OSGeo.MapGuide.MaestroAPI;
namespace Maestro.Editors.Common
@@ -217,7 +218,10 @@
//var stream = _edSvc.GetResourceData(item.Name);
IResource res = _edSvc.GetEditedResource();
var stream = res.GetResourceData(item.Name);
- File.WriteAllBytes(save.FileName, stream.GetBuffer());
+ using (var fs = File.OpenWrite(save.FileName))
+ Utility.CopyStream(stream, fs);
MessageBox.Show(Properties.Resources.FileDownloaded);
Modified: sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.Designer.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.Designer.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -68,6 +68,8 @@
// groupBox1
+ this.groupBox1.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
this.groupBox1.Controls.Add(this.lstTemplates);
this.groupBox1.Location = new System.Drawing.Point(14, 43);
this.groupBox1.Name = "groupBox1";
@@ -79,7 +81,9 @@
// lstTemplates
this.lstTemplates.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.lstTemplates.LargeImageList = this.tplImageList;
this.lstTemplates.Location = new System.Drawing.Point(3, 16);
+ this.lstTemplates.MultiSelect = false;
this.lstTemplates.Name = "lstTemplates";
this.lstTemplates.Size = new System.Drawing.Size(416, 107);
this.lstTemplates.TabIndex = 0;
@@ -88,6 +92,8 @@
// txtTitle
+ this.txtTitle.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
this.txtTitle.Location = new System.Drawing.Point(93, 17);
this.txtTitle.Name = "txtTitle";
this.txtTitle.Size = new System.Drawing.Size(343, 20);
@@ -96,11 +102,13 @@
// tplImageList
this.tplImageList.ColorDepth = System.Windows.Forms.ColorDepth.Depth8Bit;
- this.tplImageList.ImageSize = new System.Drawing.Size(16, 16);
+ this.tplImageList.ImageSize = new System.Drawing.Size(126, 96);
this.tplImageList.TransparentColor = System.Drawing.Color.Transparent;
// txtTemplateUrl
+ this.txtTemplateUrl.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
this.txtTemplateUrl.Location = new System.Drawing.Point(93, 179);
this.txtTemplateUrl.Name = "txtTemplateUrl";
this.txtTemplateUrl.ReadOnly = true;
Modified: sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -34,9 +34,7 @@
internal delegate void TemplateChangeEventHandler(IApplicationDefinitionTemplateInfo selectedTemplate);
- /// <summary>
- /// Editor control for Fusion Flexible Layouts (Application Definitions)
- /// </summary>
+ [ToolboxItem(true)]
public partial class FlexLayoutSettingsCtrl : EditorBindableCollapsiblePanel
public FlexLayoutSettingsCtrl()
@@ -95,7 +93,10 @@
img = Properties.Resources.question;
tplImageList.Images.Add(tpl.PreviewImageUrl, img);
+ foreach (var tpl in templates.TemplateInfo)
var item = new ListViewItem();
item.Tag = tpl;
item.Name = tpl.Name;
Modified: sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexibleLayoutEditor.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexibleLayoutEditor.Designer.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexibleLayoutEditor.Designer.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -28,18 +28,65 @@
/// </summary>
+ this.settingsCtrl = new Maestro.Editors.Fusion.FlexLayoutSettingsCtrl();
+ this.mapsCtrl = new Maestro.Editors.Fusion.MapSettingsCtrl();
+ this.widgetsCtrl = new Maestro.Editors.Fusion.WidgetSettingsCtrl();
+ // settingsCtrl
+ this.settingsCtrl.ContentBackgroundColor = System.Drawing.SystemColors.Control;
+ this.settingsCtrl.Dock = System.Windows.Forms.DockStyle.Top;
+ this.settingsCtrl.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
+ this.settingsCtrl.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.settingsCtrl.HeaderText = "Flexible Layout Settings";
+ this.settingsCtrl.Location = new System.Drawing.Point(0, 0);
+ this.settingsCtrl.Name = "settingsCtrl";
+ this.settingsCtrl.Size = new System.Drawing.Size(746, 238);
+ this.settingsCtrl.TabIndex = 0;
+ // mapsCtrl
+ this.mapsCtrl.ContentBackgroundColor = System.Drawing.SystemColors.Control;
+ this.mapsCtrl.Dock = System.Windows.Forms.DockStyle.Top;
+ this.mapsCtrl.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
+ this.mapsCtrl.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.mapsCtrl.HeaderText = "Maps";
+ this.mapsCtrl.Location = new System.Drawing.Point(0, 238);
+ this.mapsCtrl.Name = "mapsCtrl";
+ this.mapsCtrl.Size = new System.Drawing.Size(746, 290);
+ this.mapsCtrl.TabIndex = 1;
+ // widgetsCtrl
+ this.widgetsCtrl.ContentBackgroundColor = System.Drawing.SystemColors.Control;
+ this.widgetsCtrl.Dock = System.Windows.Forms.DockStyle.Top;
+ this.widgetsCtrl.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
+ this.widgetsCtrl.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.widgetsCtrl.HeaderText = "Widgets";
+ this.widgetsCtrl.Location = new System.Drawing.Point(0, 528);
+ this.widgetsCtrl.Name = "widgetsCtrl";
+ this.widgetsCtrl.Size = new System.Drawing.Size(746, 319);
+ this.widgetsCtrl.TabIndex = 2;
// FlexibleLayoutEditor
+ this.AutoScroll = true;
+ this.Controls.Add(this.widgetsCtrl);
+ this.Controls.Add(this.mapsCtrl);
+ this.Controls.Add(this.settingsCtrl);
this.Name = "FlexibleLayoutEditor";
- this.Size = new System.Drawing.Size(778, 574);
+ this.Size = new System.Drawing.Size(746, 574);
#endregion
+ private FlexLayoutSettingsCtrl settingsCtrl;
+ private MapSettingsCtrl mapsCtrl;
+ private WidgetSettingsCtrl widgetsCtrl;
Modified: sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexibleLayoutEditor.cs
--- sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexibleLayoutEditor.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexibleLayoutEditor.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -28,6 +28,9 @@
namespace Maestro.Editors.Fusion
+ /// <summary>
+ /// Editor control for Fusion Flexible Layouts (Application Definitions)
+ /// </summary>
public partial class FlexibleLayoutEditor : EditorBase
public FlexibleLayoutEditor()
@@ -39,7 +42,11 @@
public override void Bind(IEditorService service)
+ _flexLayout = (IApplicationDefinition)service.GetEditedResource();
+ settingsCtrl.Bind(service);
+ mapsCtrl.Bind(service);
+ widgetsCtrl.Bind(service);
Added: sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.Designer.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -0,0 +1,182 @@
+namespace Maestro.Editors.Fusion
+ partial class MapCtrl
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ this.label1 = new System.Windows.Forms.Label();
+ this.textBox1 = new System.Windows.Forms.TextBox();
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.label2 = new System.Windows.Forms.Label();
+ this.label3 = new System.Windows.Forms.Label();
+ this.label4 = new System.Windows.Forms.Label();
+ this.txtViewX = new System.Windows.Forms.TextBox();
+ this.txtViewY = new System.Windows.Forms.TextBox();
+ this.txtViewScale = new System.Windows.Forms.TextBox();
+ this.groupBox2 = new System.Windows.Forms.GroupBox();
+ this.listBox1 = new System.Windows.Forms.ListBox();
+ this.groupBox1.SuspendLayout();
+ this.groupBox2.SuspendLayout();
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(27, 18);
+ this.label1.Name = "label1";
+ this.label1.Size = new System.Drawing.Size(42, 13);
+ this.label1.TabIndex = 0;
+ this.label1.Text = "Map ID";
+ // textBox1
+ this.textBox1.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.textBox1.Location = new System.Drawing.Point(95, 15);
+ this.textBox1.Name = "textBox1";
+ this.textBox1.Size = new System.Drawing.Size(359, 20);
+ this.textBox1.TabIndex = 1;
+ // groupBox1
+ this.groupBox1.Controls.Add(this.txtViewScale);
+ this.groupBox1.Controls.Add(this.txtViewY);
+ this.groupBox1.Controls.Add(this.txtViewX);
+ this.groupBox1.Controls.Add(this.label4);
+ this.groupBox1.Controls.Add(this.label3);
+ this.groupBox1.Controls.Add(this.label2);
+ this.groupBox1.Location = new System.Drawing.Point(20, 53);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.Size = new System.Drawing.Size(449, 106);
+ this.groupBox1.TabIndex = 2;
+ this.groupBox1.TabStop = false;
+ this.groupBox1.Text = "Initial View";
+ // label2
+ this.label2.AutoSize = true;
+ this.label2.Location = new System.Drawing.Point(42, 39);
+ this.label2.Name = "label2";
+ this.label2.Size = new System.Drawing.Size(14, 13);
+ this.label2.TabIndex = 0;
+ this.label2.Text = "X";
+ // label3
+ this.label3.AutoSize = true;
+ this.label3.Location = new System.Drawing.Point(191, 39);
+ this.label3.Name = "label3";
+ this.label3.Size = new System.Drawing.Size(14, 13);
+ this.label3.TabIndex = 1;
+ this.label3.Text = "Y";
+ // label4
+ this.label4.AutoSize = true;
+ this.label4.Location = new System.Drawing.Point(35, 65);
+ this.label4.Name = "label4";
+ this.label4.Size = new System.Drawing.Size(34, 13);
+ this.label4.TabIndex = 2;
+ this.label4.Text = "Scale";
+ // txtViewX
+ this.txtViewX.Location = new System.Drawing.Point(75, 36);
+ this.txtViewX.Name = "txtViewX";
+ this.txtViewX.Size = new System.Drawing.Size(80, 20);
+ this.txtViewX.TabIndex = 3;
+ // txtViewY
+ this.txtViewY.Location = new System.Drawing.Point(223, 36);
+ this.txtViewY.Name = "txtViewY";
+ this.txtViewY.Size = new System.Drawing.Size(80, 20);
+ this.txtViewY.TabIndex = 4;
+ // txtViewScale
+ this.txtViewScale.Location = new System.Drawing.Point(75, 62);
+ this.txtViewScale.Name = "txtViewScale";
+ this.txtViewScale.Size = new System.Drawing.Size(80, 20);
+ this.txtViewScale.TabIndex = 5;
+ // groupBox2
+ this.groupBox2.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.groupBox2.Controls.Add(this.listBox1);
+ this.groupBox2.Location = new System.Drawing.Point(20, 166);
+ this.groupBox2.Name = "groupBox2";
+ this.groupBox2.Size = new System.Drawing.Size(449, 125);
+ this.groupBox2.TabIndex = 3;
+ this.groupBox2.TabStop = false;
+ this.groupBox2.Text = "Maps In Group";
+ // listBox1
+ this.listBox1.Dock = System.Windows.Forms.DockStyle.Left;
+ this.listBox1.FormattingEnabled = true;
+ this.listBox1.Location = new System.Drawing.Point(3, 16);
+ this.listBox1.Name = "listBox1";
+ this.listBox1.Size = new System.Drawing.Size(300, 95);
+ this.listBox1.TabIndex = 0;
+ // MapCtrl
+ this.Controls.Add(this.groupBox2);
+ this.Controls.Add(this.groupBox1);
+ this.Controls.Add(this.textBox1);
+ this.Controls.Add(this.label1);
+ this.Name = "MapCtrl";
+ this.Size = new System.Drawing.Size(492, 308);
+ this.groupBox1.ResumeLayout(false);
+ this.groupBox1.PerformLayout();
+ this.groupBox2.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.TextBox textBox1;
+ private System.Windows.Forms.GroupBox groupBox1;
+ private System.Windows.Forms.TextBox txtViewScale;
+ private System.Windows.Forms.TextBox txtViewY;
+ private System.Windows.Forms.TextBox txtViewX;
+ private System.Windows.Forms.Label label4;
+ private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.GroupBox groupBox2;
+ private System.Windows.Forms.ListBox listBox1;
Added: sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -0,0 +1,45 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+using OSGeo.MapGuide.ObjectModels.ApplicationDefinition;
+ public partial class MapCtrl : UserControl
+ public MapCtrl()
+ private IMapGroup _group;
+ public MapCtrl(IMapGroup group) : this()
+ _group = group;
Added: sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.resx
--- sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.resx 2010-11-30 08:21:57 UTC (rev 5415)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/Fusion/MapSettingsCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Fusion/MapSettingsCtrl.Designer.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Editors/Fusion/MapSettingsCtrl.Designer.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -28,9 +28,11 @@
/// </summary>
+ this.components = new System.ComponentModel.Container();
System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(MapSettingsCtrl));
this.lstMaps = new System.Windows.Forms.ListView();
+ this.mapImgList = new System.Windows.Forms.ImageList(this.components);
this.toolStrip1 = new System.Windows.Forms.ToolStrip();
this.btnAddMap = new System.Windows.Forms.ToolStripButton();
this.btnRemoveMap = new System.Windows.Forms.ToolStripButton();
@@ -58,10 +60,17 @@
resources.ApplyResources(this.lstMaps, "lstMaps");
this.lstMaps.Name = "lstMaps";
+ this.lstMaps.SmallImageList = this.mapImgList;
this.lstMaps.UseCompatibleStateImageBehavior = false;
this.lstMaps.View = System.Windows.Forms.View.List;
this.lstMaps.SelectedIndexChanged += new System.EventHandler(this.lstMaps_SelectedIndexChanged);
+ // mapImgList
+ this.mapImgList.ImageStream = ((System.Windows.Forms.ImageListStreamer)(resources.GetObject("mapImgList.ImageStream")));
+ this.mapImgList.TransparentColor = System.Drawing.Color.Transparent;
+ this.mapImgList.Images.SetKeyName(0, "map.png");
// toolStrip1
this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
@@ -112,5 +121,6 @@
private System.Windows.Forms.ToolStripButton btnAddMap;
private System.Windows.Forms.ToolStripButton btnRemoveMap;
private System.Windows.Forms.Panel propertiesPanel;
+ private System.Windows.Forms.ImageList mapImgList;
Modified: sandbox/maestro-3.0/Maestro.Editors/Fusion/MapSettingsCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/Fusion/MapSettingsCtrl.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Editors/Fusion/MapSettingsCtrl.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -33,6 +33,7 @@
public partial class MapSettingsCtrl : EditorBindableCollapsiblePanel
public MapSettingsCtrl()
@@ -47,6 +48,7 @@
+ service.RegisterCustomNotifier(this);
try
_fsvc = (IFusionService)service.GetService((int)ServiceType.Fusion);
@@ -62,7 +64,11 @@
_edsvc = service;
_edsvc.RegisterCustomNotifier(this);
+ foreach (var grp in _flexLayout.MapSet.MapGroups)
+ AddMap(grp);
private void AddMap(IMapGroup group)
@@ -96,7 +102,14 @@
private void lstMaps_SelectedIndexChanged(object sender, EventArgs e)
+ var grp = this.SelectedGroup;
+ if (grp != null)
+ propertiesPanel.Controls.Clear();
+ var mapCtrl = new MapCtrl(grp);
+ mapCtrl.Dock = DockStyle.Fill;
+ propertiesPanel.Controls.Add(mapCtrl);
private void btnRemoveMap_Click(object sender, EventArgs e)
@@ -107,8 +120,8 @@
var group = (IMapGroup)item.Tag;
_flexLayout.MapSet.RemoveGroup(group);
lstMaps.Items.Remove(item);
+ OnResourceChanged();
@@ -128,7 +141,9 @@
name = prefix + counter;
- _flexLayout.AddMapGroup(name, true, picker.ResourceID);
+ var grp = _flexLayout.AddMapGroup(name, true, picker.ResourceID);
+ AddMap(grp);
Modified: sandbox/maestro-3.0/Maestro.Editors/Fusion/MapSettingsCtrl.resx
--- sandbox/maestro-3.0/Maestro.Editors/Fusion/MapSettingsCtrl.resx 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Editors/Fusion/MapSettingsCtrl.resx 2010-11-30 08:21:57 UTC (rev 5415)
@@ -121,6 +121,10 @@
<data name="propertiesPanel.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Bottom, Left, Right</value>
</data>
+ <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="propertiesPanel.AutoScroll" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
<assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="propertiesPanel.Location" type="System.Drawing.Point, System.Drawing">
<value>209, 6</value>
@@ -128,7 +132,6 @@
<data name="propertiesPanel.Size" type="System.Drawing.Size, System.Drawing">
<value>426, 251</value>
</data>
- <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="propertiesPanel.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
</data>
@@ -156,6 +159,52 @@
<data name="lstMaps.Size" type="System.Drawing.Size, System.Drawing">
<value>194, 210</value>
</data>
+ <metadata name="mapImgList.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>108, 16</value>
+ </metadata>
+ <data name="mapImgList.ImageStream" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>
+ AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
+ LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAABk
+ CAAAAk1TRnQBSQFMAwEBAAEQAQABEAEAARABAAEQAQAE/wEJAQAI/wFCAU0BNgEEBgABNgEEAgABKAMA
+ AUADAAEQAwABAQEAAQgGAAEEGAABgAIAAYADAAKAAQABgAMAAYABAAGAAQACgAIAA8ABAAHAAdwBwAEA
+ AfABygGmAQABMwUAATMBAAEzAQABMwEAAjMCAAMWAQADHAEAAyIBAAMpAQADVQEAA00BAANCAQADOQEA
+ AYABfAH/AQACUAH/AQABkwEAAdYBAAH/AewBzAEAAcYB1gHvAQAB1gLnAQABkAGpAa0CAAH/ATMDAAFm
+ AwABmQMAAcwCAAEzAwACMwIAATMBZgIAATMBmQIAATMBzAIAATMB/wIAAWYDAAFmATMCAAJmAgABZgGZ
+ AgABZgHMAgABZgH/AgABmQMAAZkBMwIAAZkBZgIAApkCAAGZAcwCAAGZAf8CAAHMAwABzAEzAgABzAFm
+ AgABzAGZAgACzAIAAcwB/wIAAf8BZgIAAf8BmQIAAf8BzAEAATMB/wIAAf8BAAEzAQABMwEAAWYBAAEz
+ AQABmQEAATMBAAHMAQABMwEAAf8BAAH/ATMCAAMzAQACMwFmAQACMwGZAQACMwHMAQACMwH/AQABMwFm
+ AgABMwFmATMBAAEzAmYBAAEzAWYBmQEAATMBZgHMAQABMwFmAf8BAAEzAZkCAAEzAZkBMwEAATMBmQFm
+ AQABMwKZAQABMwGZAcwBAAEzAZkB/wEAATMBzAIAATMBzAEzAQABMwHMAWYBAAEzAcwBmQEAATMCzAEA
+ ATMBzAH/AQABMwH/ATMBAAEzAf8BZgEAATMB/wGZAQABMwH/AcwBAAEzAv8BAAFmAwABZgEAATMBAAFm
+ AQABZgEAAWYBAAGZAQABZgEAAcwBAAFmAQAB/wEAAWYBMwIAAWYCMwEAAWYBMwFmAQABZgEzAZkBAAFm
+ ATMBzAEAAWYBMwH/AQACZgIAAmYBMwEAA2YBAAJmAZkBAAJmAcwBAAFmAZkCAAFmAZkBMwEAAWYBmQFm
+ AQABZgKZAQABZgGZAcwBAAFmAZkB/wEAAWYBzAIAAWYBzAEzAQABZgHMAZkBAAFmAswBAAFmAcwB/wEA
+ AWYB/wIAAWYB/wEzAQABZgH/AZkBAAFmAf8BzAEAAcwBAAH/AQAB/wEAAcwBAAKZAgABmQEzAZkBAAGZ
+ AQABmQEAAZkBAAHMAQABmQMAAZkCMwEAAZkBAAFmAQABmQEzAcwBAAGZAQAB/wEAAZkBZgIAAZkBZgEz
+ AQABmQEzAWYBAAGZAWYBmQEAAZkBZgHMAQABmQEzAf8BAAKZATMBAAKZAWYBAAOZAQACmQHMAQACmQH/
+ AQABmQHMAgABmQHMATMBAAFmAcwBZgEAAZkBzAGZAQABmQLMAQABmQHMAf8BAAGZAf8CAAGZAf8BMwEA
+ AZkBzAFmAQABmQH/AZkBAAGZAf8BzAEAAZkC/wEAAcwDAAGZAQABMwEAAcwBAAFmAQABzAEAAZkBAAHM
+ AQABzAEAAZkBMwIAAcwCMwEAAcwBMwFmAQABzAEzAZkBAAHMATMBzAEAAcwBMwH/AQABzAFmAgABzAFm
+ ATMBAAGZAmYBAAHMAWYBmQEAAcwBZgHMAQABmQFmAf8BAAHMAZkCAAHMAZkBMwEAAcwBmQFmAQABzAKZ
+ AQABzAGZAcwBAAHMAZkB/wEAAswCAALMATMBAALMAWYBAALMAZkBAAPMAQACzAH/AQABzAH/AgABzAH/
+ ATMBAAGZAf8BZgEAAcwB/wGZAQABzAH/AcwBAAHMAv8BAAHMAQABMwEAAf8BAAFmAQAB/wEAAZkBAAHM
+ ATMCAAH/AjMBAAH/ATMBZgEAAf8BMwGZAQAB/wEzAcwBAAH/ATMB/wEAAf8BZgIAAf8BZgEzAQABzAJm
+ AQAB/wFmAZkBAAH/AWYBzAEAAcwBZgH/AQAB/wGZAgAB/wGZATMBAAH/AZkBZgEAAf8CmQEAAf8BmQHM
+ AQAB/wGZAf8BAAH/AcwCAAH/AcwBMwEAAf8BzAFmAQAB/wHMAZkBAAH/AswBAAH/AcwB/wEAAv8BMwEA
+ AcwB/wFmAQAC/wGZAQAC/wHMAQACZgH/AQABZgH/AWYBAAFmAv8BAAH/AmYBAAH/AWYB/wEAAv8BZgEA
+ ASEBAAGlAQADXwEAA3cBAAOGAQADlgEAA8sBAAOyAQAD1wEAA90BAAPjAQAD6gEAA/EBAAP4AQAB8AH7
+ Af8BAAGkAqABAAOAAwAB/wIAAf8DAAL/AQAB/wMAAf8BAAH/AQAC/wIAA/8BAA//MQABvA0HAbwxAAEH
+ Af8L9AH/AQcxAAG8AfQGcwJ4ARwCmQH0AbwxAAG8AfQBcwEcAXgBcwJ4AZkBHAGfAcMBCAH0AbwxAAG8
+ AfQBcwEcAXgBcwF4ApkBmAGfARsBBwH0AbwxAAG8AfQDcwN4AZgCmQEIAbsB9AG8MQABvAH/AXMDeAKZ
+ AZ8BmQEbARkBuwH/AbwxAAG8Af8BcwN4ApkBnwGZAfEB3AG6Af8BvDEAAfAB/wFzAXgBmQF4AZkBnwHD
+ AQgBCQHcAboB/wHwMQAB8AH/A3gDmQEIArsCugH/AfAxAAHwAf8BeAOZAcMBGwHxAbsC3AG6Af8B8DEA
+ AfAB/wF4A5kBwwHCAQkBugHcAdsBugH/AfAxAAHwAf8BeAGYApkBCAK7A7oBtAH/AfAxAAHxDf8B8TEA
+ AfMN8gHzMQABQgFNAT4HAAE+AwABKAMAAUADAAEQAwABAQEAAQEFAAGAFwAD/wIAAQEHAAEBBwABAQcA
+ AQEHAAEBBwABAQcAAQEHAAEBBwABAQcAAQEHAAEBBwABAQcAAQEHAAEBBwABAQcAAQEGAAs=
+</value>
+ </data>
<data name="lstMaps.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
</data>
@@ -267,6 +316,12 @@
<data name="$this.Size" type="System.Drawing.Size, System.Drawing">
<value>638, 290</value>
</data>
+ <data name=">>mapImgList.Name" xml:space="preserve">
+ <value>mapImgList</value>
+ </data>
+ <data name=">>mapImgList.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ImageList, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
<data name=">>btnAddMap.Name" xml:space="preserve">
<value>btnAddMap</value>
</data>
Modified: sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.Designer.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.Designer.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -32,6 +32,7 @@
System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(WidgetSettingsCtrl));
this.trvWidgets = new System.Windows.Forms.TreeView();
+ this.widgetImageList = new System.Windows.Forms.ImageList(this.components);
this.btnAddWidget = new System.Windows.Forms.ToolStripDropDownButton();
this.widgetToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
@@ -45,7 +46,6 @@
this.toolStripSeparator2 = new System.Windows.Forms.ToolStripSeparator();
this.btnConfigureWidgets = new System.Windows.Forms.ToolStripButton();
this.propertiesPanel = new System.Windows.Forms.Panel();
- this.widgetImageList = new System.Windows.Forms.ImageList(this.components);
this.contentPanel.SuspendLayout();
this.toolStrip1.SuspendLayout();
@@ -73,11 +73,23 @@
// trvWidgets
this.trvWidgets.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.trvWidgets.ImageIndex = 0;
+ this.trvWidgets.ImageList = this.widgetImageList;
this.trvWidgets.Location = new System.Drawing.Point(3, 41);
this.trvWidgets.Name = "trvWidgets";
+ this.trvWidgets.SelectedImageIndex = 0;
this.trvWidgets.Size = new System.Drawing.Size(194, 239);
this.trvWidgets.TabIndex = 1;
+ // widgetImageList
+ this.widgetImageList.ImageStream = ((System.Windows.Forms.ImageListStreamer)(resources.GetObject("widgetImageList.ImageStream")));
+ this.widgetImageList.TransparentColor = System.Drawing.Color.Transparent;
+ this.widgetImageList.Images.SetKeyName(0, "application.png");
+ this.widgetImageList.Images.SetKeyName(1, "gear.png");
+ this.widgetImageList.Images.SetKeyName(2, "ui-separator.png");
+ this.widgetImageList.Images.SetKeyName(3, "ui-menu.png");
// toolStrip1
@@ -112,7 +124,7 @@
this.widgetToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.gear;
this.widgetToolStripMenuItem.Name = "widgetToolStripMenuItem";
- this.widgetToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.widgetToolStripMenuItem.Size = new System.Drawing.Size(141, 22);
this.widgetToolStripMenuItem.Text = "Widget";
this.widgetToolStripMenuItem.Click += new System.EventHandler(this.widgetToolStripMenuItem_Click);
@@ -120,7 +132,7 @@
this.separatorToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.ui_separator;
this.separatorToolStripMenuItem.Name = "separatorToolStripMenuItem";
- this.separatorToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.separatorToolStripMenuItem.Size = new System.Drawing.Size(141, 22);
this.separatorToolStripMenuItem.Text = "Separator";
this.separatorToolStripMenuItem.Click += new System.EventHandler(this.separatorToolStripMenuItem_Click);
@@ -128,7 +140,7 @@
this.flyoutMenuToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.ui_menu;
this.flyoutMenuToolStripMenuItem.Name = "flyoutMenuToolStripMenuItem";
- this.flyoutMenuToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.flyoutMenuToolStripMenuItem.Size = new System.Drawing.Size(141, 22);
this.flyoutMenuToolStripMenuItem.Text = "Flyout Menu";
this.flyoutMenuToolStripMenuItem.Click += new System.EventHandler(this.flyoutMenuToolStripMenuItem_Click);
@@ -199,20 +211,12 @@
this.propertiesPanel.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
+ this.propertiesPanel.AutoScroll = true;
this.propertiesPanel.Location = new System.Drawing.Point(209, 6);
this.propertiesPanel.Name = "propertiesPanel";
this.propertiesPanel.Size = new System.Drawing.Size(436, 280);
this.propertiesPanel.TabIndex = 1;
- // widgetImageList
- this.widgetImageList.ImageStream = ((System.Windows.Forms.ImageListStreamer)(resources.GetObject("widgetImageList.ImageStream")));
- this.widgetImageList.TransparentColor = System.Drawing.Color.Transparent;
- this.widgetImageList.Images.SetKeyName(0, "application.png");
- this.widgetImageList.Images.SetKeyName(1, "gear.png");
- this.widgetImageList.Images.SetKeyName(2, "ui-separator.png");
- this.widgetImageList.Images.SetKeyName(3, "ui-menu.png");
// WidgetSettingsCtrl
Modified: sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -31,6 +31,7 @@
public partial class WidgetSettingsCtrl : EditorBindableCollapsiblePanel
public WidgetSettingsCtrl()
@@ -63,9 +64,60 @@
+ InitWidgetSet();
+ private void InitWidgetSet()
+ var set = _flexLayout.GetFirstWidgetSet();
+ if (set != null)
+ foreach (var cnt in set.Containers)
+ IUIItemContainer uicnt = cnt as IUIItemContainer;
+ if (uicnt != null)
+ var node = CreateContainerNode(cnt);
+ trvWidgets.Nodes.Add(node);
+ foreach (var wgtref in uicnt.Items)
+ var child = CreateNode(wgtref);
+ node.Nodes.Add(child);
+ if (wgtref.Function == UiItemFunctionType.Flyout)
+ ProcessFlyoutChildren(child, (IFlyoutItem)wgtref);
+ private void ProcessFlyoutChildren(TreeNode parent, IFlyoutItem menu)
+ foreach (var item in menu.Items)
+ var node = CreateNode(item);
+ parent.Nodes.Add(node);
+ if (item.Function == UiItemFunctionType.Flyout)
+ ProcessFlyoutChildren(node, (IFlyoutItem)item);
+ private TreeNode CreateContainerNode(IWidgetContainer cnt)
+ var node = new TreeNode();
+ node.Name = cnt.Name;
+ node.Text = cnt.Name;
+ node.ImageIndex = IDX_CONTAINER;
+ node.Tag = cnt;
+ return node;
private void widgetToolStripMenuItem_Click(object sender, EventArgs e)
var cnt = this.SelectedContainer;
@@ -120,18 +172,21 @@
node.ImageIndex = node.SelectedImageIndex = IDX_MENU;
node.Text = ((IFlyoutItem)item).Label;
+ node.Tag = item;
break;
case UiItemFunctionType.Separator:
node.ImageIndex = node.SelectedImageIndex = IDX_SEPARATOR;
node.Text = Properties.Resources.Separator;
+ node.Tag = item;
break;
case UiItemFunctionType.Widget:
node.ImageIndex = node.SelectedImageIndex = IDX_WIDGET;
node.Text = ((IWidgetItem)item).Widget;
+ node.Tag = item;
break;
@@ -151,6 +206,14 @@
+ internal IUIItem SelectedWidgetReference
+ get
+ return this.SelectedNode.Tag as IUIItem;
private void btnRemoveWidget_Click(object sender, EventArgs e)
Modified: sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.resx
--- sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.resx 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.resx 2010-11-30 08:21:57 UTC (rev 5415)
@@ -117,9 +117,6 @@
</resheader>
- <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 17</value>
- </metadata>
<metadata name="widgetImageList.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>122, 17</value>
</metadata>
@@ -128,7 +125,7 @@
ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAACU
- CQAAAk1TRnQBSQFMAgEBBAEAASgBAAEoAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
+ CQAAAk1TRnQBSQFMAgEBBAEAATgBAAE4AQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
AwABQAMAASADAAEBAQABCAYAAQgYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
@@ -171,4 +168,7 @@
AoEGAAGAAQEC/wQAAcABAwL/BAABwAEDAv8EAAHAAQMC/wQAAeABBwL/BAAB/AE/Av8CAAb/AgAL
</value>
</data>
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
--- sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-11-30 08:21:57 UTC (rev 5415)
@@ -269,6 +269,12 @@
<Compile Include="Fusion\FlexLayoutSettingsCtrl.Designer.cs">
<DependentUpon>FlexLayoutSettingsCtrl.cs</DependentUpon>
</Compile>
+ <Compile Include="Fusion\MapCtrl.cs">
+ </Compile>
+ <Compile Include="Fusion\MapCtrl.Designer.cs">
+ <DependentUpon>MapCtrl.cs</DependentUpon>
+ </Compile>
<Compile Include="Fusion\MapSettingsCtrl.cs">
</Compile>
@@ -915,6 +921,9 @@
<EmbeddedResource Include="Fusion\FlexLayoutSettingsCtrl.resx">
</EmbeddedResource>
+ <EmbeddedResource Include="Fusion\MapCtrl.resx">
<EmbeddedResource Include="Fusion\MapSettingsCtrl.resx">
<DependentUpon>MapSettingsCtrl.cs</DependentUpon>
</EmbeddedResource>
Modified: sandbox/maestro-3.0/Maestro.Packaging/PackageBuilder.cs
--- sandbox/maestro-3.0/Maestro.Packaging/PackageBuilder.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/Maestro.Packaging/PackageBuilder.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -247,7 +247,9 @@
filemap.Add(new KeyValuePair<string, string>(filebase + "_DATA_" + EncodeFilename(rd.Name), System.IO.Path.Combine(temppath, Guid.NewGuid().ToString())));
System.IO.FileInfo fi = new System.IO.FileInfo(filemap[filemap.Count - 1].Value);
using (System.IO.FileStream fs = new System.IO.FileStream(fi.FullName, System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
- m_connection.ResourceService.GetResourceData(doc.ResourceId, rd.Name).WriteTo(fs);
+ Utility.CopyStream(m_connection.ResourceService.GetResourceData(doc.ResourceId, rd.Name), fs);
AddResourceData(manifest, temppath, doc, fi, filemap[filemap.Count - 1].Key, rd, m_connection);
@@ -556,7 +558,9 @@
ms2.Position = 0;
using (System.IO.FileStream fs = new System.IO.FileStream(lookup[path], System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
- ms2.WriteTo(fs);
+ Utility.CopyStream(ms2, fs);
ms2.Dispose();
@@ -784,7 +788,9 @@
ms2.Position = 0;
using (System.IO.FileStream fs = new System.IO.FileStream(filemap_lookup[rix.Contentpath], System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
- ms2.WriteTo(fs);
ms2.Dispose();
Added: sandbox/maestro-3.0/MaestroAPITestRunner/App.config
--- sandbox/maestro-3.0/MaestroAPITestRunner/App.config (rev 0)
+++ sandbox/maestro-3.0/MaestroAPITestRunner/App.config 2010-11-30 08:21:57 UTC (rev 5415)
@@ -0,0 +1,20 @@
+<?xml version="1.0" encoding="utf-8" ?>
+<configuration>
+ <system.net>
+ <defaultProxy>
+ <proxy bypassonlocal="false" usesystemdefault="true" />
+ </defaultProxy>
+ </system.net>
+ <runtime>
+ <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
+ <dependentAssembly>
+ <assemblyIdentity name="MapGuideDotNetApi" />
+ <codeBase version="1.0.0.1" href="MapGuideDotNetApi-2.2.dll"/>
+ <bindingRedirect oldVersion="2.0.0.2308" newVersion="1.0.0.1" />
+ </dependentAssembly>
+ </assemblyBinding>
+ </runtime>
+</configuration>
Added: sandbox/maestro-3.0/MaestroAPITestRunner/ConnectionProviders.xml
--- sandbox/maestro-3.0/MaestroAPITestRunner/ConnectionProviders.xml (rev 0)
+++ sandbox/maestro-3.0/MaestroAPITestRunner/ConnectionProviders.xml 2010-11-30 08:21:57 UTC (rev 5415)
@@ -0,0 +1,24 @@
+<ConnectionProviderRegistry>
+ <ConnectionProvider>
+ <Name>Maestro.Http</Name>
+ <Description>Connection using the mapagent http API</Description>
+ <Assembly>OSGeo.MapGuide.MaestroAPI.Http.dll</Assembly>
+ <Type>OSGeo.MapGuide.MaestroAPI.HttpServerConnection</Type>
+ </ConnectionProvider>
+ If you want to use the Maestro.LocalNative provider, you need to set up
+ assembly binding redirection by editing Maestro.exe.config. See these links
+ below for more information:
+ http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/MapGuideDotNetApiVersions
+ http://themapguyde.blogspot.com/2010/10/using-maestro-in-native-mode-with.html
+ <Name>Maestro.LocalNative</Name>
+ <Description>Connection using the MapGuide Web API</Description>
+ <Assembly>OSGeo.MapGuide.MaestroAPI.Native.dll</Assembly>
+ <Type>OSGeo.MapGuide.MaestroAPI.LocalNativeConnection</Type>
+</ConnectionProviderRegistry>
Modified: sandbox/maestro-3.0/MaestroAPITestRunner/MaestroAPITestRunner.csproj
--- sandbox/maestro-3.0/MaestroAPITestRunner/MaestroAPITestRunner.csproj 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/MaestroAPITestRunner/MaestroAPITestRunner.csproj 2010-11-30 08:21:57 UTC (rev 5415)
@@ -32,6 +32,10 @@
<WarningLevel>4</WarningLevel>
</PropertyGroup>
<ItemGroup>
+ <Reference Include="MapGuideDotNetApi, Version=2.0.0.2308, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
+ <SpecificVersion>False</SpecificVersion>
+ <HintPath>..\Thirdparty\MapGuideDotNetApi\MapGuideDotNetApi.dll</HintPath>
+ </Reference>
<Reference Include="nunit-console-runner, Version=2.5.5.10112, Culture=neutral, PublicKeyToken=96d09a1eb7f44a77, processorArchitecture=MSIL">
<HintPath>..\Thirdparty\NUnit\bin\net-2.0\lib\nunit-console-runner.dll</HintPath>
@@ -58,11 +62,23 @@
<Project>{351D49A3-2E4A-4EC3-AFC2-D56598F44F51}</Project>
<Name>MaestroAPITests</Name>
</ProjectReference>
+ <ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI.Native\OSGeo.MapGuide.MaestroAPI.Native.csproj">
+ <Project>{F4420153-9DF3-4407-AD65-E8ABED2B6E25}</Project>
+ <Name>OSGeo.MapGuide.MaestroAPI.Native</Name>
+ </ProjectReference>
<ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI\OSGeo.MapGuide.MaestroAPI.csproj">
<Project>{80FA3158-8B5F-48D1-A393-0378AFE48A7E}</Project>
<Name>OSGeo.MapGuide.MaestroAPI</Name>
</ProjectReference>
</ItemGroup>
+ <ItemGroup>
+ <None Include="App.config" />
+ </ItemGroup>
+ <ItemGroup>
+ <Content Include="ConnectionProviders.xml">
+ <CopyToOutputDirectory>Always</CopyToOutputDirectory>
+ </Content>
+ </ItemGroup>
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
<!-- To modify your build process, add your task inside one of the targets below and uncomment it.
Other similar extension points exist, see Microsoft.Common.targets.
Deleted: sandbox/maestro-3.0/MaestroAPITests/App.config
--- sandbox/maestro-3.0/MaestroAPITests/App.config 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/MaestroAPITests/App.config 2010-11-30 08:21:57 UTC (rev 5415)
@@ -1,8 +0,0 @@
-<?xml version="1.0" encoding="utf-8" ?>
-<configuration>
- <system.net>
- <defaultProxy>
- <proxy bypassonlocal="false" usesystemdefault="true" />
- </defaultProxy>
- </system.net>
-</configuration>
Modified: sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj
--- sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj 2010-11-30 08:21:57 UTC (rev 5415)
@@ -90,7 +90,6 @@
<None Include="Resources\SelectFeatureSample.xml" />
</ItemGroup>
<ItemGroup>
- <None Include="App.config" />
<None Include="Resources\SelectSqlSample.xml" />
<None Include="TestData\DrawingService\CorruptedDwf.dwf">
Modified: sandbox/maestro-3.0/MaestroAPITests/RuntimeMapTests.cs
--- sandbox/maestro-3.0/MaestroAPITests/RuntimeMapTests.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/MaestroAPITests/RuntimeMapTests.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -41,6 +41,7 @@
using OSGeo.MapGuide.MaestroAPI.Resource.Validation;
using OSGeo.MapGuide.ObjectModels.LoadProcedure;
+ using System.Diagnostics;
[SetUpFixture]
public class TestBootstrap
@@ -518,9 +519,64 @@
+ public virtual void TestLargeMapCreatePerformance()
+ //Create a 200 layer, 50 group map. This is not part of the benchmark
+ var mdf = ObjectFactory.CreateMapDefinition(_conn, "LargeMap");
+ string root = "Library://UnitTests/LargeMapTest/";
+ //We have to create 200 unique layer definitions (same content) otherwise only one GetResourceContent
+ //call is issued, thus not truly reflecting on how a 200 layer map would really perform
+ //But that doesn't mean we have to read the same file 200 times
+ MemoryStream ms = new MemoryStream();
+ using (var fs = File.OpenRead("TestData/MappingService/UT_Rail.ldf"))
+ Utility.CopyStream(fs, ms);
+ int step = 4;
+ int g = 0;
+ for (int i = 0; i < 200; i++)
+ if (i % step == 0)
+ g++;
+ string layerName = "Layer" + i;
+ string groupName = "Group" + g;
+ if (mdf.GetGroupByName(groupName) == null)
+ mdf.AddGroup(groupName);
+ //Rewind
+ ms.Position = 0;
+ string lid = root + "Layers/Layer" + i + ".LayerDefinition";
+ _conn.ResourceService.SetResourceXmlData(lid, ms);
+ mdf.AddLayer(groupName, layerName, lid);
+ Assert.IsTrue(Array.IndexOf(_conn.Capabilities.SupportedServices, (int)ServiceType.Mapping) >= 0);
+ var mapSvc = (IMappingService)_conn.GetService((int)ServiceType.Mapping);
+ var mid = "Session:" + _conn.SessionID + "//TestLargeMapCreatePerformance.Map";
+ //Begin Benchmark
+ var sw = new Stopwatch();
+ sw.Start();
+ var map = mapSvc.CreateMap(mid, mdf, 1.0);
+ sw.Stop();
+ string msg = "Create Map time for 200 layer, 50 group map: " + sw.ElapsedMilliseconds + "ms";
+ Trace.WriteLine(msg);
+ Console.WriteLine(msg);
- [TestFixture]
+ [TestFixture(Ignore = true)]
+ //[TestFixture]
public class HttpRuntimeMapTests : RuntimeMapTests
protected override IServerConnection CreateTestConnection()
@@ -554,15 +610,22 @@
base.TestRender12k();
+ [Test]
+ public override void TestLargeMapCreatePerformance()
+ base.TestLargeMapCreatePerformance();
- [TestFixture(Ignore = true)]
+ //[TestFixture(Ignore = true)]
+ [TestFixture]
public class LocalRuntimeMapTests : RuntimeMapTests
return ConnectionProviderRegistry.CreateConnection("Maestro.LocalNative",
- "ConfigPath", "webconfig.ini",
+ "ConfigFile", "webconfig.ini",
"Username", "Administrator",
"Password", "admin");
@@ -590,5 +653,11 @@
+ [Test]
Modified: sandbox/maestro-3.0/MaestroFsPreview/MaestroFsPreview.csproj
--- sandbox/maestro-3.0/MaestroFsPreview/MaestroFsPreview.csproj 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/MaestroFsPreview/MaestroFsPreview.csproj 2010-11-30 08:21:57 UTC (rev 5415)
@@ -51,9 +51,9 @@
<HintPath>..\Maestro.Shared.UI\bin\Debug\Maestro.Shared.UI.dll</HintPath>
</Reference>
- <Reference Include="OSGeo.MapGuide.MaestroAPI, Version=1.0.0.0, Culture=neutral, processorArchitecture=MSIL">
+ <Reference Include="OSGeo.MapGuide.MaestroAPI, Version=3.0.0.5334, Culture=neutral, processorArchitecture=MSIL">
- <HintPath>..\OSGeo.MapGuide.MaestroAPI\bin\Debug\OSGeo.MapGuide.MaestroAPI.dll</HintPath>
+ <HintPath>..\SDK\bin\Release\OSGeo.MapGuide.MaestroAPI.dll</HintPath>
</Reference>
<Reference Include="System" />
<Reference Include="System.Data" />
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/CommandType.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/CommandType.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/CommandType.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -28,6 +28,5 @@
/// </summary>
public enum CommandType : int
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/ExecuteLoadProcedure.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/ExecuteLoadProcedure.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/ExecuteLoadProcedure.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -34,7 +34,7 @@
/// <summary>
/// A command to execute Load Procedures
/// </summary>
- public interface IExecuteLoadProcedure : ICommand
+ internal interface IExecuteLoadProcedure : ICommand
/// <summary>
/// Executes the specified load proc.
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Expression/FdoFunctionNamespace.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Expression/FdoFunctionNamespace.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Expression/FdoFunctionNamespace.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -31,6 +31,8 @@
/// </summary>
public static class FdoFunctionNamespace
+ //TODO: Use a data type hierachy akin to FDO's LiteralValue and its descendants
// NOTE: ExpressionEngine will auto-coerce null values to DBNull.Value so when
// testing for nulls, test for DBNull.Value
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Feature/FeatureSetReader.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Feature/FeatureSetReader.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Feature/FeatureSetReader.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -529,9 +529,6 @@
get { return m_row[GetName(i)]; }
- /// <summary>
- /// </summary>
internal class FeatureSetRowEnumerator : IEnumerator<IDataRecord>
private FeatureSetReader _parent;
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/IO/ReadOnlyRewindableStream.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/IO/ReadOnlyRewindableStream.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/IO/ReadOnlyRewindableStream.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -0,0 +1,85 @@
+#endregion
+using System;
+using System.Text;
+using System.IO;
+namespace OSGeo.MapGuide.MaestroAPI.IO
+ /// <summary>
+ /// A read-only, rewindable stream
+ /// </summary>
+ public abstract class ReadOnlyRewindableStream : Stream
+ /// <summary>
+ /// Resets the internal position of the stream
+ /// </summary>
+ public abstract void Rewind();
+ public override bool CanRead
+ get { return true; }
+ public override bool CanSeek
+ get { return false; }
+ public override bool CanWrite
+ /// <summary>
+ /// Gets whether this stream is rewindable. If not, calls to <see cref="Rewind"/> throw a
+ /// <see cref="T:System.InvalidOperationException"/>
+ /// </summary>
+ public abstract bool CanRewind { get; }
+ public override long Position
+ get
+ throw new NotImplementedException();
+ set
+ public override long Seek(long offset, SeekOrigin origin)
+ public override void SetLength(long value)
+ public override void Write(byte[] buffer, int offset, int count)
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -147,6 +147,11 @@
internal RuntimeMap(IMapDefinition mdf, double metersPerUnit)
: this(mdf.CurrentConnection)
+ //TODO: Performance would be greatly improved if we can take advantage of
+ //the new GetResourceContents() API in 2.2. But can we do this via the combination
+ //of reflection and assembly binding redirection seeing as we are referencing
+ //a 2.0.x assembly?
this.MetersPerUnit = metersPerUnit;
this.MapDefinition = mdf.ResourceID;
@@ -842,7 +847,7 @@
protected Dictionary<string, ILayerDefinition> layerDefinitionCache = new Dictionary<string, ILayerDefinition>();
/// <summary>
- /// Creats and adds the layer to the map
+ /// Creates and adds the layer to the map
/// </summary>
/// <param name="layerDefinitionId">The layer definition id.</param>
/// <param name="group">The group.</param>
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-11-30 08:21:57 UTC (rev 5415)
@@ -186,6 +186,7 @@
<Compile Include="Expression\MgFunctionNamespace.cs" />
<Compile Include="Feature\ClassDefinition.cs" />
<Compile Include="IConnectionCapabilities.cs" />
+ <Compile Include="IO\ReadOnlyRewindableStream.cs" />
<Compile Include="MaestroApiProviderAttribute.cs" />
<Compile Include="ConnectionProviderRegistry.cs" />
<Compile Include="CoordinateSystem\CoordinateSystem.cs" />
@@ -211,7 +212,6 @@
<Compile Include="ObjectModels\FeatureSourceInterfaces.cs" />
<Compile Include="ObjectModels\Geometries.cs" />
<Compile Include="ObjectModels\GridLayerDefinitionImpl.cs" />
- <Compile Include="ObjectModels\IDynamicInvokable.cs" />
<Compile Include="ObjectModels\Envelope.cs" />
<Compile Include="ObjectModels\FeatureSource.cs" />
<Compile Include="ObjectModels\IRepositoryItem.cs" />
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -194,6 +194,11 @@
+ IMapGroup IMapSet.GetGroupAt(int index)
+ return this.MapSet[index];
IWidget IApplicationDefinition.CreateWidget(string name, IWidgetInfo widgetInfo)
var wparams = widgetInfo.Parameters;
@@ -209,9 +214,9 @@
ImageClass = widgetInfo.ImageClass,
ImageUrl = widgetInfo.ImageUrl,
Label = widgetInfo.Label,
- Location = widgetInfo.Location ?? string.Empty,
+ Location = widgetInfo.Location ?? string.Empty, //Required to satisfy content model
Name = name,
- StatusText = widgetInfo.StatusText ?? string.Empty,
+ StatusText = widgetInfo.StatusText ?? string.Empty, //Required to satisfy content model
Tooltip = widgetInfo.Tooltip,
Type = widgetInfo.Type
@@ -221,7 +226,7 @@
widget = new WidgetType()
Extension = new CustomContentType() { Any = new XmlElement[0] },
Name = name,
Type = widgetInfo.Type,
@@ -255,11 +260,12 @@
IUIItemContainer IApplicationDefinition.CreateContainer(string name, IApplicationDefinitionContainerInfo containerInfo)
- return new UiItemContainerType()
- Name = name,
- Type = containerInfo.Type,
- Item = new System.ComponentModel.BindingList<UiItemType>()
+ return new UiItemContainerType()
+ Name = name,
+ Type = containerInfo.Type,
+ Item = new System.ComponentModel.BindingList<UiItemType>(),
+ Extension = new CustomContentType() { Any = new XmlElement[0] }
@@ -650,6 +656,19 @@
partial class MapGroupType : IMapGroup
+ int IMapGroup.MapCount
+ get
+ return this.Map.Count;
+ IMap IMapGroup.GetMapAt(int index)
+ return (IMap)this.Map[index];
IMapView IMapGroup.InitialView
get
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -634,6 +634,26 @@
Check.NotNull(map, "map");
map.SetValue("ResourceId", mapDefId);
+ /// <summary>
+ /// Gets the first widget set of this application definition.
+ /// </summary>
+ /// <param name="appDef"></param>
+ /// <returns></returns>
+ public static IWidgetSet GetFirstWidgetSet(this IApplicationDefinition appDef)
+ Check.NotNull(appDef, "appDef");
+ IWidgetSet set = null;
+ foreach (var wgt in appDef.WidgetSets)
+ if (set == null)
+ set = wgt;
+ break;
+ return set;
@@ -788,6 +808,8 @@
int MapGroupCount { get; }
+ IMapGroup GetGroupAt(int index);
void AddGroup(IMapGroup group);
void RemoveGroup(IMapGroup group);
@@ -804,6 +826,10 @@
void AddMap(IMap map);
void RemoveMap(IMap map);
+ int MapCount { get; }
+ IMap GetMapAt(int index);
public interface IMap : INotifyPropertyChanged, IExtensibleElement
Deleted: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/IDynamicInvokable.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/IDynamicInvokable.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/IDynamicInvokable.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -1,136 +0,0 @@
-#region Disclaimer / License
-// Copyright (C) 2010, Jackie Ng
-// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of the GNU Lesser General Public
-// License as published by the Free Software Foundation; either
-// version 2.1 of the License, or (at your option) any later version.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
-#endregion
-using System;
-using System.Collections.Generic;
-using System.Text;
-using System.Reflection;
-using System.ComponentModel;
-namespace OSGeo.MapGuide.ObjectModels
- /// <summary>
- /// Interface allowing for dynamic invocation of public properties and methods.
- /// </summary>
- public interface IDynamicInvokable
- //Nothing here. All done through extension methods baby!
- /// <summary>
- /// Extension method class
- /// </summary>
- public static class DynamicInvokableExtensions
- /// <summary>
- /// Gets the value of the specified property
- /// </summary>
- /// <param name="idi"></param>
- /// <param name="name"></param>
- /// <returns></returns>
- /// <exception cref="MissingMemberException">Thrown if the specified property could not be found</exception>
- public static object InvokeGetProperty(this IDynamicInvokable idi, string name)
- var prop = idi.GetType().GetProperty(name);
- if (prop != null)
- return prop.GetValue(idi, null);
- throw new MissingMemberException(name);
- /// <summary>
- /// Attempts to get the value of the specified property. Returns the specified default value if the named
- /// property could not be found
- /// </summary>
- /// <param name="defaultValue"></param>
- public static object TryInvokeGetProperty(this IDynamicInvokable idi, string name, object defaultValue)
- if (prop != null)
- return defaultValue;
- /// <summary>
- /// Sets the value of the specified property
- /// </summary>
- /// <param name="value"></param>
- /// <exception cref="MissingMemberException">thrown if the specified property could not be found</exception>
- public static void InvokeSetProperty(this IDynamicInvokable idi, string name, object value)
- if (prop != null)
- prop.SetValue(idi, value, null);
- /// <summary>
- /// Attempts to set the value of the specified property. Does nothing if the named property
- /// could not be found
- /// </summary>
- public static void TryInvokeSetProperty(this IDynamicInvokable idi, string name, object value)
- if (prop != null)
- /// <summary>
- /// Invokes a method of the specified name with the specified arguments. If the method returns
- /// a value, it is discarded. If you require the return value, use <see cref="InvokeMethodWithReturnValue"/>
- /// instead
- /// </summary>
- /// <param name="args"></param>
- public static void InvokeMethod(this IDynamicInvokable idi, string name, params object[] args)
- var method = idi.GetType().GetMethod(name);
- if (method != null)
- method.Invoke(idi, args);
- throw new MissingMethodException(name);
- /// <summary>
- /// </summary>
- public static object InvokeMethodWithReturnValue(this IDynamicInvokable idi, string name, params object[] args)
- return method.Invoke(idi, args);
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaces.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaces.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaces.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -602,7 +602,7 @@
/// <summary>
/// Style specification for a area geometry layer
/// </summary>
- public interface IAreaVectorStyle : IVectorStyle, IDynamicInvokable
+ public interface IAreaVectorStyle : IVectorStyle
/// <summary>
/// Enumerates the rules in this specification
@@ -630,7 +630,7 @@
/// <summary>
/// Style specification for a line geometry layer
/// </summary>
- public interface ILineVectorStyle : IVectorStyle, IDynamicInvokable
+ public interface ILineVectorStyle : IVectorStyle
/// <summary>
@@ -658,7 +658,7 @@
/// <summary>
/// Style specification for a point geometry layer
/// </summary>
- public interface IPointVectorStyle : IVectorStyle, IDynamicInvokable
+ public interface IPointVectorStyle : IVectorStyle
/// <summary>
/// Gets or sets whether to create a text layer
@@ -696,7 +696,7 @@
/// <summary>
/// Base interface for style rules of all geometric types
/// </summary>
- public interface IVectorRule : IDynamicInvokable
+ public interface IVectorRule
/// <summary>
/// Gets or sets the label for the rule to be displayed in the legend
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -247,7 +247,7 @@
Name = name,
BackgroundColor = Color.White,
MapLayer = new System.ComponentModel.BindingList<OSGeo.MapGuide.ObjectModels.MapDefinition_1_0_0.MapLayerType>(),
- //MapLayerGroup = new System.ComponentModel.BindingList<MapLayerGroupType>(),
+ MapLayerGroup = new System.ComponentModel.BindingList<OSGeo.MapGuide.ObjectModels.MapDefinition_1_0_0.MapLayerGroupType>(),
@@ -308,9 +308,10 @@
static readonly string[] parameterizedWidgets =
+ KnownWidgetNames.CTRLClick,
KnownWidgetNames.ZoomOnClick,
KnownWidgetNames.ExtentHistory,
- KnownWidgetNames.BufferPanel,
+ KnownWidgetNames.Buffer,
KnownWidgetNames.Measure,
KnownWidgetNames.InvokeScript,
KnownWidgetNames.InvokeURL,
@@ -330,7 +331,23 @@
Check.NotNull(owner, "owner");
Check.Precondition(Array.IndexOf(owner.Capabilities.SupportedServices, (int)ServiceType.Fusion) >= 0, "Required Fusion service not supported on this connection");
+ var fusionSvc = (IFusionService)owner.GetService((int)ServiceType.Fusion);
+ var templates = fusionSvc.GetApplicationTemplates();
+ var appDef = DeserializeEmbeddedFlexLayout();
+ //Find matching template.
+ var tpl = templates.FindTemplate(templateName);
+ if (tpl != null)
+ appDef.TemplateUrl = tpl.LocationUrl;
+ appDef.Title = tpl.Name;
+ appDef.CurrentConnection = owner;
+ return appDef;
+ Check.Precondition(Array.IndexOf(owner.Capabilities.SupportedServices, (int)ServiceType.Fusion) >= 0, "Required Fusion service not supported on this connection");
IApplicationDefinition appDef = new ApplicationDefinitionType()
CurrentConnection = owner,
@@ -343,7 +360,9 @@
var widgets = fusionSvc.GetApplicationWidgets();
var containers = fusionSvc.GetApplicationContainers();
- //Find matching template
+ //Find matching template. If it's a known template we should be able to
+ //build it programatically, otherwise return a deserialized copy from our
+ //embedded resource
if (tpl != null)
@@ -361,7 +380,7 @@
//Context menus, every template has them
var mapContextMenu = appDef.CreateContainer("MapContextMenu", containers.FindContainer("ContextMenu"));
- var taskPaneMenu = appDef.CreateContainer("TaskContextMenu", containers.FindContainer("ContextMenu"));
+ var taskPaneMenu = appDef.CreateContainer("TaskMenu", containers.FindContainer("ContextMenu"));
//Menu
var menu = appDef.CreateContainer("FileMenu", containers.FindContainer("Toolbar"));
@@ -420,7 +439,7 @@
buffer.Tooltip = Res.ADF_Widget_Buffer_Label;
//Measure
- var measure = (IUIWidget)appDef.CreateWidget("tbBuffer", widgets.FindWidget(KnownWidgetNames.Measure));
+ var measure = (IUIWidget)appDef.CreateWidget("Measure", widgets.FindWidget(KnownWidgetNames.Measure));
var measureParams = new NameValueCollection();
measureParams["Type"] = "both";
measureParams["MeasureTooltipContainer"] = "MeasureResult";
@@ -469,6 +488,7 @@
widgetSet.AddWidget(prevView);
widgetSet.AddWidget(nextView);
widgetSet.AddWidget(buffer);
+ widgetSet.AddWidget(measure);
widgetSet.AddWidget(showOverview);
widgetSet.AddWidget(showTaskPane);
widgetSet.AddWidget(showLegend);
@@ -495,8 +515,8 @@
toolbar.AddItem(appDef.CreateWidgetReference(KnownWidgetNames.SelectPolygon));
toolbar.AddItem(appDef.CreateWidgetReference(KnownWidgetNames.ClearSelection));
- toolbar.AddItem(appDef.CreateWidgetReference(KnownWidgetNames.Buffer));
- toolbar.AddItem(appDef.CreateWidgetReference(KnownWidgetNames.Measure));
+ toolbar.AddItem(appDef.CreateWidgetReference(buffer.Name));
+ toolbar.AddItem(appDef.CreateWidgetReference(measure.Name));
//2.2 specific stuff
if (owner.SiteVersion >= new Version(2, 2))
@@ -619,6 +639,7 @@
return appDef;
internal static IApplicationDefinition DeserializeEmbeddedFlexLayout()
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -1104,7 +1104,7 @@
/// <param name="resourceID">The id of the resource to fetch data from</param>
/// <param name="dataname">The name of the associated data item</param>
/// <returns>A stream containing the references resource data</returns>
- abstract public System.IO.MemoryStream GetResourceData(string resourceID, string dataname);
+ abstract public System.IO.Stream GetResourceData(string resourceID, string dataname);
/// <summary>
/// Uploads data to a resource
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResource.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResource.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResource.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -31,7 +31,7 @@
/// <summary>
/// Represents an editable MapGuide Resource
/// </summary>
- public interface IResource : IVersionedEntity, ICloneable, INotifyPropertyChanged, IDynamicInvokable
+ public interface IResource : IVersionedEntity, ICloneable, INotifyPropertyChanged
/// <summary>
/// Gets or sets the current connection.
@@ -152,7 +152,7 @@
/// <param name="res"></param>
/// <param name="dataName"></param>
- public static MemoryStream GetResourceData(this IResource res, string dataName)
+ public static Stream GetResourceData(this IResource res, string dataName)
if (res.CurrentConnection == null)
throw new ArgumentException(Properties.Resources.ERR_RESOURCE_NOT_ATTACHED);
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ApplicationDefinitionValidator.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ApplicationDefinitionValidator.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ApplicationDefinitionValidator.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -46,6 +46,15 @@
if (resource.ResourceType != OSGeo.MapGuide.MaestroAPI.ResourceTypes.ApplicationDefinition)
return null;
+ //TODO: Other items to check for
+ // - References to non-existent widgets
+ // - MapWidget checks
+ // - Ensure map id checks out
+ // - Ensure context menu id checks out
+ // - Verify containers of template are all referenced within this flexible layout
+ // - Check required parameters of widgets are satisfied
List<ValidationIssue> issues = new List<ValidationIssue>();
IApplicationDefinition fusionApp = resource as IApplicationDefinition;
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Services/IResourceService.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Services/IResourceService.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Services/IResourceService.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -108,7 +108,7 @@
/// <param name="resourceID"></param>
/// <param name="dataname"></param>
- System.IO.MemoryStream GetResourceData(string resourceID, string dataname);
+ System.IO.Stream GetResourceData(string resourceID, string dataname);
/// <summary>
/// Gets the document header of the specified resource
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Utility.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Utility.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Utility.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -21,6 +21,7 @@
using System.Drawing;
using Topology.Geometries;
+using OSGeo.MapGuide.MaestroAPI.IO;
@@ -151,10 +152,32 @@
int r;
byte[] buf = new byte[1024];
- if (rewind && source.CanSeek)
- try { source.Position = 0; }
- catch { }
+ bool rewound = false;
+ if (rewind)
+ if (source.CanSeek)
+ try
+ source.Position = 0;
+ rewound = true;
+ catch { }
+ else
+ ReadOnlyRewindableStream roSource = source as ReadOnlyRewindableStream;
+ if (roSource != null && roSource.CanRewind)
+ roSource.Rewind();
+ rewound = true;
+ //if (!rewound)
+ // throw new InvalidOperationException("Could not rewind the source stream. Most likely the source stream does not support seeking or rewinding"); //LOCALIZEME
do
r = source.Read(buf, 0, buf.Length);
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -369,10 +369,11 @@
return string.Empty;
- public override System.IO.MemoryStream GetResourceData(string resourceID, string dataname)
+ public override System.IO.Stream GetResourceData(string resourceID, string dataname)
string req = m_reqBuilder.GetResourceData(resourceID, dataname);
+ return this.OpenRead(req);
System.IO.MemoryStream ms = new System.IO.MemoryStream();
Utility.CopyStream(this.OpenRead(req), ms);
@@ -382,6 +383,7 @@
#endif
ms.Position = 0;
return ms;
public override Stream GetResourceXmlData(string resourceID)
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -183,7 +183,7 @@
return (FdoProviderCapabilities) base.DeserializeObject(typeof(FdoProviderCapabilities), Utility.MgStreamToNetStream(fes, fes.GetType().GetMethod("GetCapabilities"), new object[] { provider }));
MgResourceService res = this.Connection.CreateService(MgServiceType.ResourceService) as MgResourceService;
return Utility.MgStreamToNetStream(res, res.GetType().GetMethod("GetResourceData"), new object[] { new MgResourceIdentifier(resourceID), dataname });
@@ -381,7 +381,7 @@
public ResourceDataList EnumerateResourceData(string resourceID)
- System.IO.MemoryStream ms = Utility.MgStreamToNetStream(res, res.GetType().GetMethod("EnumerateResourceData"), new object[] { new MgResourceIdentifier(resourceID) });
+ System.IO.Stream ms = Utility.MgStreamToNetStream(res, res.GetType().GetMethod("EnumerateResourceData"), new object[] { new MgResourceIdentifier(resourceID) });
return (ResourceDataList)DeserializeObject(typeof(ResourceDataList), ms);
@@ -459,7 +459,7 @@
public override ResourceReferenceList EnumerateResourceReferences(string resourceid)
- System.IO.MemoryStream ms = Utility.MgStreamToNetStream(res, res.GetType().GetMethod("EnumerateReferences"), new object[] { new MgResourceIdentifier(resourceid) });
+ System.IO.Stream ms = Utility.MgStreamToNetStream(res, res.GetType().GetMethod("EnumerateReferences"), new object[] { new MgResourceIdentifier(resourceid) });
return (ResourceReferenceList)DeserializeObject(typeof(ResourceReferenceList), ms);
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeFeatureSetReader.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeFeatureSetReader.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeFeatureSetReader.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -141,7 +141,6 @@
try
//No MapGuide dll, convert to WKT and then to internal representation
- System.IO.MemoryStream ms = Utility.MgStreamToNetStream(rd, rd.GetType().GetMethod("GetGeometry"), new string[] { p });
OSGeo.MapGuide.MgAgfReaderWriter rdw = new OSGeo.MapGuide.MgAgfReaderWriter();
OSGeo.MapGuide.MgGeometry g = rdw.Read(rd.GetGeometry(p));
OSGeo.MapGuide.MgWktReaderWriter rdww = new OSGeo.MapGuide.MgWktReaderWriter();
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/MgReadOnlyStream.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/MgReadOnlyStream.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/MgReadOnlyStream.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -0,0 +1,106 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using System.IO;
+namespace OSGeo.MapGuide.MaestroAPI.Native
+ /// <summary>
+ /// Represents a method that returns a <see cref="OSGeo.MapGuide.MgByteReader"/> instance
+ /// </summary>
+ public delegate MgByteReader GetByteReaderMethod();
+ /// <summary>
+ /// A read-only <see cref="System.IO.Stream"/> adapter for the <see cref="OSGeo.MapGuide.MgByteReader"/>
+ /// class.
+ /// </summary>
+ public class MgReadOnlyStream : ReadOnlyRewindableStream
+ private MgByteReader _reader;
+ /// <summary>
+ /// Creates a new instance
+ /// </summary>
+ /// <param name="method"></param>
+ public MgReadOnlyStream(GetByteReaderMethod method)
+ _reader = method();
+ ~MgReadOnlyStream()
+ Dispose(false);
+ GC.SuppressFinalize(this);
+ protected override void Dispose(bool disposing)
+ if (disposing)
+ _reader.Dispose();
+ base.Dispose(disposing);
+ public override void Flush()
+ public override long Length
+ get { return _reader.GetLength(); }
+ public override bool CanRewind
+ get { return _reader.IsRewindable(); }
+ public override void Rewind()
+ if (!CanRewind)
+ throw new InvalidOperationException("This stream is not rewindable"); //LOCALIZEME
+ _reader.Rewind();
+ public override int Read(byte[] buffer, int offset, int count)
+ int read = 0;
+ //For good times, please always have the offset as 0
+ if (offset == 0)
+ read = _reader.Read(buffer, count);
+ else //So you want to play the hard way eh? Bad performance for you!
+ byte[] b = new byte[count];
+ read = _reader.Read(b, count);
+ Array.Copy(b, 0, buffer, offset, read);
+ return read;
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/OSGeo.MapGuide.MaestroAPI.Native.csproj
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/OSGeo.MapGuide.MaestroAPI.Native.csproj 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/OSGeo.MapGuide.MaestroAPI.Native.csproj 2010-11-30 08:21:57 UTC (rev 5415)
@@ -52,6 +52,7 @@
<Compile Include="..\Properties\GlobalAssemblyInfo.cs">
<Link>GlobalAssemblyInfo.cs</Link>
</Compile>
+ <Compile Include="MgReadOnlyStream.cs" />
<Compile Include="Properties\AssemblyInfo.cs" />
<Compile Include="LocalNativeCapabilities.cs" />
<Compile Include="LocalNativeConnection.cs" />
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/Utility.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/Utility.cs 2010-11-29 20:45:16 UTC (rev 5414)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/Utility.cs 2010-11-30 08:21:57 UTC (rev 5415)
@@ -64,11 +64,30 @@
/// <param name="source">The object which has a stream</param>
/// <param name="mi">The method to call</param>
/// <param name="args">Arguments to the method</param>
- /// <returns>A memorystream with the MgStream's content</returns>
- public static System.IO.MemoryStream MgStreamToNetStream(object source, System.Reflection.MethodInfo mi, object[] args)
+ /// <returns>A read-only <see cref="System.IO.Stream"/> that wraps the underlying <see cref="OSGeo.MapGuide.MgByteReader"/></returns>
+ public static System.IO.Stream MgStreamToNetStream(object source, System.Reflection.MethodInfo mi, object[] args)
try
+ //How can we work around invalidating MgByteReader when it's passed as a parameter?
+ //Cheat the system by deferring execution of MgByteReader reference assignment until
+ //we're in the ctor of MgReadOnlyStream. Only MgReadOnlyStream has access to the MgByteReader
+ //Everything else interacts through the .net Stream interface. Win-win.
+ GetByteReaderMethod method = () => { return (OSGeo.MapGuide.MgByteReader)mi.Invoke(source, args); };
+ return new MgReadOnlyStream(method);
+ catch (System.Reflection.TargetInvocationException tex)
+ if (tex.InnerException != null)
+ throw tex.InnerException;
+ else
+ throw;
+ try
OSGeo.MapGuide.MgByteReader rd = (OSGeo.MapGuide.MgByteReader)mi.Invoke(source, args);
More information about the mapguide-commits
