[mapguide-commits] r5417 - trunk/MgDev
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Nov 30 04:01:13 EST 2010
Author: jng
Date: 2010-11-30 01:01:12 -0800 (Tue, 30 Nov 2010)
New Revision: 5417
Added:
   trunk/MgDev/build_sdk.bat
This is the first cut of an SDK profile build script. The aim of this script is to generate the minimal set of header/lib/binary files needed to build an application on the MapGuide Platform, free of server and web dependencies (Currently FDO, ACE and everything under Common). Our test case will be the MG Snapshot driver example from last year's AU (http://au.autodesk.com/?nd=class&session_id=5241). If we can get this to build via the output of this script, then Mission Accomplished!
Added: trunk/MgDev/build_sdk.bat
--- trunk/MgDev/build_sdk.bat	                        (rev 0)
+++ trunk/MgDev/build_sdk.bat	2010-11-30 09:01:12 UTC (rev 5417)
@@ -0,0 +1,429 @@
+ at echo off
+rem MapGuide SDK build script for windows
+rem
+rem Author: Jackie Ng (jumpinjackie at gmail.com)
+rem
+rem This script will build a subset of the MapGuide source code, such that an SDK can be produced for developing MapGuide
+rem applications that do not involve the server/web tier.
+rem
+rem Due to a hard dependency on ACE, the entire header collection of the ACE library is also copied to the output include directory
+rem
+rem Before you start, please make sure you have done the following:
+rem
+rem 1) Build the FDO source and place the files in \Oem\FDO (or alternatively download and extract the latest FDO binary sdk)
+rem    with the following structure:
+rem     - Bin\%CONFIG% (where %CONFIG% is debug or release)
+rem		- Inc
+rem		- Lib
+rem
+rem 2) Download and install the following:
+rem     - doxygen (http://www.doxygen.org)
+rem
+rem 3) Change the values of DOXYGEN to match the paths of your Doxygen installations respectively
+rem
+rem For a "cleaner" build experience, run this script from an exported copy of the
+rem MapGuide source code (ie. without subversion folders).
+rem
+rem Usage:
+rem
+rem build.bat [-h]
+rem           [-v]
+rem	          [-c=BuildType]
+rem           [-a=Action]
+rem           [-o=OutputDirectory]
+rem
+rem BuildType: Release(default), Debug
+rem Action: build(default), install, clean
+rem OutputDirectory: The directory where files will be copied to if -a=install, if -o=default or -o=def then
+rem files will be copied to %MG_DEFAULT_INSTALLDIR%
+rem ==================================================
+rem Top-level vars
+SET OLDPATH=%PATH%
+SET TYPEACTION=build
+SET TYPEBUILD=Release
+rem There are no components in an SDK build. Everything must be built! DO NOT CHANGE!
+SET TYPECOMPONENT=all
+rem MapGuide vars
+SET MG_DEV=%CD%
+SET MG_OEM=%MG_DEV%\Oem
+SET MG_COMMON=%MG_DEV%\Common
+SET MG_DOC=%MG_DEV%\Doc
+SET MG_WEB=%MG_DEV%\Web
+SET MG_WEB_SRC=%MG_WEB%\src
+SET MG_WEB_BIN=%MG_WEB%\bin
+SET MG_DOC_OUTPUT=%MG_DOC%\MgOpensource_WebAPIReference
+SET MG_DOC_DEVGUIDE_SAMPLES=%MG_DOC%\samples\phpsamples
+SET MG_BUILD_TEMP=%MG_DEV%\BuildTemp
+SET MG_SDK_OUTPUT=%MG_DEV%\SDK\%TYPEBUILD%
+SET MG_SDK_BIN=%MG_SDK_OUTPUT%\Bin
+SET MG_SDK_LIB=%MG_SDK_OUTPUT%\Lib
+SET MG_SDK_INC=%MG_SDK_OUTPUT%\Inc
+SET MG_SDK_FDO=%MG_SDK_OUTPUT%\Fdo
+SET MG_BUILD_COMPONENT=
+SET MG_ERROR=0
+rem MSBuild Settings
+rem If the NUMBER_OF_PROCESSORS environment variable is wrong for any reason. Change this value.
+SET CPU_CORES=%NUMBER_OF_PROCESSORS%
+rem Uncomment the line below to enable msbuild logging
+rem SET MSBUILD_LOG=/l:FileLogger,Microsoft.Build.Engine;logfile=Build.log;verbosity=diagnostic
+SET MSBUILD_VERBOSITY=/v:q
+rem Command aliases
+rem SET XCOPY=xcopy /E /Y /I /F
+SET XCOPY=xcopy /E /Y /I /Q
+SET XCOPY_SINGLE=xcopy /Y /I /Q
+SET MSBUILD=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%TYPEBUILD% %MSBUILD_VERBOSITY% %MSBUILD_LOG%
+SET MSBUILD_CLEAN=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%TYPEBUILD% /t:Clean %MSBUILD_VERBOSITY%
+rem Parameter Handling
+:study_params
+if (%1)==() goto pre_build_check
+if "%1"=="-help"    goto help_show
+if "%1"=="-h"       goto help_show
+if "%1"=="-c"       goto get_conf
+if "%1"=="-config"  goto get_conf
+if "%1"=="-a"       goto get_action
+if "%1"=="-action"  goto get_action
+if "%1"=="-v"       goto get_verbose
+if "%1"=="-o"       goto get_output
+goto custom_error
+:next_param
+shift
+shift
+goto study_params
+:get_verbose
+SET MSBUILD_VERBOSITY=/v:d
+goto next_param
+:get_output
+SET MG_OUTPUT=%2
+if "%2" == "default" SET MG_OUTPUT=%MG_DEV%
+if "%2" == "def" SET MG_OUTPUT=%MG_DEV%
+SET MG_SDK_OUTPUT=%MG_OUTPUT%\SDK\%TYPEBUILD%
+goto next_param
+:get_conf
+SET TYPEBUILD=%2
+SET MG_OUTPUT=%MG_DEV%\%TYPEBUILD%
+SET MG_OUTPUT_SERVER=%MG_OUTPUT%\Server
+SET MG_OUTPUT_WEB=%MG_OUTPUT%\Web
+if "%2"=="Release" goto next_param
+if "%2"=="Debug" goto next_param
+SET ERRORMSG=Unrecognised configuration: %2
+goto custom_error
+:get_action
+SET TYPEACTION=%2
+if "%2"=="build" goto next_param
+if "%2"=="clean" goto next_param
+if "%2"=="install" goto next_param
+SET ERRORMSG=Unrecognised action: %2
+goto custom_error
+rem Check Environment Vars
+:pre_build_check
+rem :check_java
+rem if exist "%JAVA_HOME%" goto check_ant
+rem SET ERRORMSG=Unable to find java sdk installation. Please install the java sdk and set the JAVA_HOME environment variable
+rem goto custom_error_no_help
+rem :check_ant
+rem if exist "%ANT_HOME%" goto check_fdo
+rem SET ERRORMSG=Unable to find Apache ant installation. Please install apache ant and set the ANT_HOME environment variable
+:check_fdo
+:check_fdo_bin
+if exist "%MG_OEM%\FDO\Bin\%TYPEBUILD%" goto check_fdo_inc
+SET ERRORMSG=Unable to find FDO binaries. Copy the FDO binaries %MG_OEM%\FDO\Bin\%TYPEBUILD%
+goto custom_error_no_help
+:check_fdo_inc
+if exist "%MG_OEM%\FDO\Bin\%TYPEBUILD%" goto check_fdo_lib
+SET ERRORMSG=Unable to find FDO headers. Copy the FDO headers into %MG_OEM%\Inc
+:check_fdo_lib
+if exist "%MG_OEM%\FDO\Bin\%TYPEBUILD%" goto start_build
+SET ERRORMSG=Unable to find FDO lib files. Copy the FDO lib files into %MG_OEM%\Lib
+:start_build
+echo ===================================================
+echo Configuration is [%TYPEBUILD%]
+echo Action is [%TYPEACTION%] on [%TYPECOMPONENT%]
+echo Deployment Directory for SDK: %MG_SDK_OUTPUT%
+echo CPU cores: %CPU_CORES%
+if "%TYPEACTION%"=="build" goto build
+if "%TYPEACTION%"=="clean" goto clean
+if "%TYPEACTION%"=="install" goto install
+:clean
+if "%TYPECOMPONENT%"=="oem" goto clean_oem
+if "%TYPECOMPONENT%"=="common" goto clean_common
+if "%TYPECOMPONENT%"=="server" goto clean_server
+if "%TYPECOMPONENT%"=="web" goto clean_web
+if "%TYPECOMPONENT%"=="doc" goto clean_doc
+:clean_oem
+echo [clean]: Clean Oem
+%MSBUILD_CLEAN% %MG_OEM%\Oem.sln
+echo [clean]: Clean Oem - CS-Map
+%MSBUILD_CLEAN% %MG_OEM%\CSMap\OpenSource.sln
+if not "%TYPECOMPONENT%"=="all" goto quit
+:clean_common
+echo [clean]: Clean Common
+%MSBUILD_CLEAN% %MG_COMMON%\Common.sln
+rem if not "%TYPECOMPONENT%"=="all" goto quit
+goto quit
+rem :clean_doc
+rem echo [clean]: Clean Doc
+rem if exist %MG_DOC_OUTPUT% rd /S /Q %MG_DOC_OUTPUT%
+rem goto quit
+rem =======================================================
+rem Build Targets.... the all targets just carry on
+:build
+if "%TYPECOMPONENT%"=="oem" goto build_oem
+if "%TYPECOMPONENT%"=="common" goto build_common
+if "%TYPECOMPONENT%"=="server" goto build_server
+if "%TYPECOMPONENT%"=="web" goto build_web
+if "%TYPECOMPONENT%"=="doc" goto build_doc
+if "%TYPECOMPONENT%"=="all" goto build_oem
+if "%TYPECOMPONENT%"=="allnodoc" goto build_oem
+SET ERRORMSG=Unrecognised component: %TYPECOMPONENT%
+goto custom_error
+:build_oem
+echo [build]: Building Oem
+%MSBUILD% %MG_OEM%\Oem.sln
+if "%errorlevel%"=="1" goto error
+rem CsMap is not in Oem.sln, so we need to build that separately
+echo [build]: Building Oem - CSMap
+%MSBUILD% %MG_OEM%\CsMap\OpenSource.sln
+:build_common
+echo [build]: Building Common
+%MSBUILD% %MG_COMMON%\Common.sln
+:build_web
+rem Shortcut method. Takes longer, but we get the SWIG'd binaries GUARANTEED!
+echo [build]: Building Web Tier
+%MSBUILD% "%MG_WEB_SRC%\WebTier.sln"
+rem :build_swig
+rem echo [build]: SWIG wrappers - Unmanaged
+rem %MSBUILD% "%MG_WEB%\DotNetUnmanagedApi\Foundation\FoundationApi.vcproj"
+rem %MSBUILD% "%MG_WEB%\DotNetUnmanagedApi\Geometry\GeometryApi.vcproj"
+rem %MSBUILD% "%MG_WEB%\DotNetUnmanagedApi\MapGuideCommon\MapGuideCommonApi.vcproj"
+rem %MSBUILD% "%MG_WEB%\DotNetUnmanagedApi\PlatformBase\PlatformBaseApi.vcproj"
+rem %MSBUILD% "%MG_WEB%\DotNetUnmanagedApi\Web\WebApi.vcproj"
+rem echo [build]: SWIG wrappers - .net assemblies
+rem %MSBUILD% "%MG_WEB%\DotNetApi\Foundation\FoundationDotNetApi.vcproj"
+rem %MSBUILD% "%MG_WEB%\DotNetApi\Geometry\GeometryDotNetApi.vcproj"
+rem %MSBUILD% "%MG_WEB%\DotNetApi\MapGuideCommon\MapGuideCommonDotNetApi.vcproj"
+rem %MSBUILD% "%MG_WEB%\DotNetApi\PlatformBase\PlatformBaseDotNetApi.vcproj"
+rem :build_web
+rem echo [build]: Building Web Tier
+rem %MSBUILD% %MG_WEB_SRC%\WebTier.sln
+rem if "%errorlevel%"=="1" goto error
+rem if "%TYPECOMPONENT%"=="oem" 	 goto quit
+rem if "%TYPECOMPONENT%"=="common" 	 goto quit
+rem if "%TYPECOMPONENT%"=="server" 	 goto quit
+rem if "%TYPECOMPONENT%"=="web" 	 goto quit
+rem if "%TYPECOMPONENT%"=="doc" 	 goto quit
+rem if "%TYPECOMPONENT%"=="allnodoc" goto quit
+rem this is left out with component allnodoc
+rem :build_doc
+rem echo [build]: Building Doc
+rem pushd %MG_DOC%
+rem call MgOpenSource_run_doxygen.bat
+rem popd
+rem goto quit
+rem INSTALL Targets.... the all targets just carry on
+:install
+:install_sdk
+echo [install]: SDK
+if not exist "%MG_SDK_INC%\ACE" mkdir "%MG_SDK_INC%\ACE"
+if not exist "%MG_SDK_INC%\Fdo" mkdir "%MG_SDK_INC%\Fdo"
+if not exist "%MG_SDK_LIB%\Fdo" mkdir "%MG_SDK_LIB%\Fdo"
+if not exist "%MG_SDK_BIN%\Fdo" mkdir "%MG_SDK_BIN%\Fdo"
+if not exist "%MG_SDK_BIN%" mkdir "%MG_SDK_BIN%"
+if not exist "%MG_SDK_LIB%" mkdir "%MG_SDK_LIB%"
+if not exist "%MG_SDK_INC%" mkdir "%MG_SDK_INC%"
+echo [install]: SDK - Oem
+rem ACE
+copy /Y "%MG_OEM%\ACE\ACE_wrappers\lib\ACE.dll" "%MG_SDK_BIN%"
+copy /Y "%MG_OEM%\ACE\ACE_wrappers\lib\ACE.pdb" "%MG_SDK_BIN%"
+copy /Y "%MG_OEM%\ACE\ACE_wrappers\lib\ACE.lib" "%MG_SDK_LIB%"
+rem Due to hard dependency, we need the header files too
+%XCOPY% /S "%MG_OEM%\ACE\ACE_wrappers\ace\*.h" "%MG_SDK_INC%\ACE" /EXCLUDE:svn_excludes.txt
+rem GEOS
+copy /Y "%MG_OEM%\geos-2.2.0\VisualStudio\%TYPEBUILD%\GEOS.dll" "%MG_SDK_BIN%"
+copy /Y "%MG_OEM%\geos-2.2.0\VisualStudio\%TYPEBUILD%\GEOS.pdb" "%MG_SDK_BIN%"
+rem xerces
+copy /Y "%MG_OEM%\dbxml\xerces-c-src\Build\Win32\VC9\%TYPEBUILD%\xerces-c_3_1mg.dll" "%MG_SDK_BIN%"
+copy /Y "%MG_OEM%\dbxml\xerces-c-src\Build\Win32\VC9\%TYPEBUILD%\xerces-c_3_1mg.pdb" "%MG_SDK_BIN%"
+echo [install]: SDK - FDO
+rem FDO SDK. Copy each subdir into each respective "Fdo" subdirectory to distinguish FDO files from MG files
+%XCOPY% "%MG_OEM%\FDO\bin\%TYPEBUILD%" "%MG_SDK_BIN%\Fdo"
+%XCOPY% "%MG_OEM%\FDO\Inc" "%MG_SDK_INC%\Fdo"
+%XCOPY% "%MG_OEM%\FDO\Lib" "%MG_SDK_LIB%\Fdo"
+echo [install]: SDK - MG Common
+rem Common binaries
+copy /Y "%MG_COMMON%\bin\%TYPEBUILD%\*.dll" "%MG_SDK_BIN%
+copy /Y "%MG_COMMON%\lib\%TYPEBUILD%\*.lib" "%MG_SDK_LIB%
+copy /Y "%MG_COMMON%\bin\%TYPEBUILD%\*.pdb" "%MG_SDK_BIN%
+rem Foundation
+if not exist "%MG_SDK_INC%\Foundation" mkdir "%MG_SDK_INC%\Foundation"
+%XCOPY% /S "%MG_COMMON%\Foundation\*.h" "%MG_SDK_INC%\Foundation" /EXCLUDE:svn_excludes.txt
+rem Geometry
+if not exist "%MG_SDK_INC%\Geometry" mkdir "%MG_SDK_INC%\Geometry"
+%XCOPY% /S "%MG_COMMON%\Geometry\*.h" "%MG_SDK_INC%\Geometry" /EXCLUDE:svn_excludes.txt
+rem MdfModel
+if not exist "%MG_SDK_INC%\MdfModel" mkdir "%MG_SDK_INC%\MdfModel"
+%XCOPY% /S "%MG_COMMON%\MdfModel\*.h" "%MG_SDK_INC%\MdfModel" /EXCLUDE:svn_excludes.txt
+rem MdfParser
+if not exist "%MG_SDK_INC%\MdfParser" mkdir "%MG_SDK_INC%\MdfParser"
+%XCOPY% /S "%MG_COMMON%\MdfParser\*.h" "%MG_SDK_INC%\MdfParser" /EXCLUDE:svn_excludes.txt
+rem PlatformBase
+if not exist "%MG_SDK_INC%\PlatformBase" mkdir "%MG_SDK_INC%\PlatformBase"
+%XCOPY% /S "%MG_COMMON%\PlatformBase\*.h" "%MG_SDK_INC%\PlatformBase" /EXCLUDE:svn_excludes.txt
+rem Renderers
+if not exist "%MG_SDK_INC%\Renderers" mkdir "%MG_SDK_INC%\Renderers"
+%XCOPY% /S "%MG_COMMON%\Renderers\*.h" "%MG_SDK_INC%\Renderers" /EXCLUDE:svn_excludes.txt
+rem Schema
+if not exist "%MG_SDK_INC%\Schema" mkdir "%MG_SDK_INC%\Schema"
+%XCOPY% "%MG_COMMON%\Schema" "%MG_SDK_INC%\Schema" /EXCLUDE:svn_excludes.txt
+rem Stylization
+if not exist "%MG_SDK_INC%\Stylization" mkdir "%MG_SDK_INC%\Stylization"
+%XCOPY% /S "%MG_COMMON%\Stylization\*.h" "%MG_SDK_INC%\Stylization" /EXCLUDE:svn_excludes.txt
+rem Delete some stuff that should not be there
+pushd "%MG_SDK_BIN%"
+del GeometryConsoleTest.pdb
+popd
+echo [install]: SWIG wrappers
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\OSGeo.MapGuide.Foundation.dll" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\OSGeo.MapGuide.Geometry.dll" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\OSGeo.MapGuide.MapGuideCommon.dll" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\OSGeo.MapGuide.PlatformBase.dll" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\OSGeo.MapGuide.Foundation.pdb" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\OSGeo.MapGuide.Geometry.pdb" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\OSGeo.MapGuide.MapGuideCommon.pdb" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\OSGeo.MapGuide.PlatformBase.pdb" "%MG_SDK_BIN%"
+rem The unmanaged glue
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\FoundationUnmanagedApi.dll" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\GeometryUnmanagedApi.dll" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\MapGuideCommonUnmanagedApi.dll" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\PlatformBaseUnmanagedApi.dll" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\FoundationUnmanagedApi.pdb" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\GeometryUnmanagedApi.pdb" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\MapGuideCommonUnmanagedApi.pdb" "%MG_SDK_BIN%"
+copy /Y "%MG_WEB_BIN%\%TYPEBUILD%\PlatformBaseUnmanagedApi.pdb" "%MG_SDK_BIN%"
+goto quit
+:error
+echo [ERROR]: There was an error building the component
+exit /B 1
+:custom_error_no_help
+echo [ERROR]: %ERRORMSG%
+SET ERRORMSG=
+exit /B 1
+:custom_error
+SET ERRORMSG=
+echo Please use the format:
+:help_show
+echo ************************************************************************
+echo build.bat [-h]
+echo           [-v]
+echo           [-c=BuildType]
+echo           [-w=Component]
+echo           [-a=Action]
+echo           [-o=OutputDirectory]
+echo Help:                  -h[elp]
+echo Verbose:               -v
+echo BuildType:             -c[onfig]=Release(default), Debug
+echo Action:                -a[ction]=build(default),
+echo                                  install,
+echo                                  clean,
+echo Component:             -w[ith]=all(default),
+echo                                oem,
+echo                                common,
+echo                                server,
+echo                                web,
+echo                                doc
+:quit
+SET TYPEACTION=
+SET TYPEBUILD=
+SET MG_OUTPUT=
+SET MG_DEV=
+SET MG_INSTALLER=
+SET MG_OEM=
+SET MG_SERVER=
+SET MG_WEB=
+SET MG_WEB_SRC=
+SET MG_WEB_BIN=
+SET MG_UNIT_TEST=
+SET MG_FUSION=
+SET MG_DOC=
+SET MG_DOC_OUTPUT=
+SET MG_ERROR=
+SET MSBUILD_LOG=
+SET XCOPY=
+SET MSBUILD=
+SET PATH=%OLDPATH%
More information about the mapguide-commits mailing list
