[mapguide-commits] r5233 - in trunk/MgDev/Server/src: Common/Manager Core Services/Feature Services/Rendering
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Oct 2 02:18:55 EDT 2010
Author: waltweltonlair
Date: 2010-10-02 06:18:55 +0000 (Sat, 02 Oct 2010)
New Revision: 5233
   trunk/MgDev/Server/src/Common/Manager/CacheManager.cpp
   trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp
   trunk/MgDev/Server/src/Core/OperationThread.cpp
   trunk/MgDev/Server/src/Core/Server.cpp
   trunk/MgDev/Server/src/Services/Feature/FilterUtil.cpp
   trunk/MgDev/Server/src/Services/Feature/ServerDescribeSchema.cpp
   trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
   trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
Just run my regular tab/cleanup script...
Modified: trunk/MgDev/Server/src/Common/Manager/CacheManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/CacheManager.cpp	2010-10-02 06:16:48 UTC (rev 5232)
+++ trunk/MgDev/Server/src/Common/Manager/CacheManager.cpp	2010-10-02 06:18:55 UTC (rev 5233)
@@ -321,7 +321,7 @@
 bool MgCacheManager::IsResourceChangeNotificationNeeded(MgResourceIdentifier* resource)
-    bool notificationNeeded = false;
+    bool notificationNeeded = false;
     // Note that the filter below may be changed in the future or whenever
     // a new resource type is supported.
@@ -352,9 +352,9 @@
          && MgResourceType::PrintLayoutDefinition        != resourceType
          && MgResourceType::PrintLayoutElementDefinition != resourceType)
-            notificationNeeded = true;
+            notificationNeeded = true;
-    return notificationNeeded;
+    return notificationNeeded;
Modified: trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp	2010-10-02 06:16:48 UTC (rev 5232)
+++ trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp	2010-10-02 06:18:55 UTC (rev 5233)
@@ -979,7 +979,7 @@
     // The ACE SELECT reactor does not have the same handle limit as the ACE WFMO reactor.
     // The code below is left as is, but commented out in case the ACE WFMO reactor is ever used in the future.
-    // The limit for the default Windows ACE WFMO reactor is 62 handles this is due to the 64 handle limit of
+    // The limit for the default Windows ACE WFMO reactor is 62 handles this is due to the 64 handle limit of
     // the Windows WaitForMultipleObjects() API, but ACE uses 2 handles internally leaving only 62 handles for the application.
     // The only reason the value 55 is chosen is because it is slightly under this value and
     // so we can log an error as the # of active connections approaches the current ACE reactor limit.
Modified: trunk/MgDev/Server/src/Core/OperationThread.cpp
--- trunk/MgDev/Server/src/Core/OperationThread.cpp	2010-10-02 06:16:48 UTC (rev 5232)
+++ trunk/MgDev/Server/src/Core/OperationThread.cpp	2010-10-02 06:18:55 UTC (rev 5233)
@@ -413,7 +413,7 @@
                 ACE_Time_Value operationTime(0);
                 operationTime = ACE_OS::gettimeofday() - operationStartTime;
                 unsigned long opTime = operationTime.msec();
                 pConnection->IncrementProcessedOperations();
Modified: trunk/MgDev/Server/src/Core/Server.cpp
--- trunk/MgDev/Server/src/Core/Server.cpp	2010-10-02 06:16:48 UTC (rev 5232)
+++ trunk/MgDev/Server/src/Core/Server.cpp	2010-10-02 06:18:55 UTC (rev 5233)
@@ -727,9 +727,9 @@
             report_status(SERVICE_RUNNING);
-            // By default the executeable is the thread owner, but when this is being run as a
+            // By default the executeable is the thread owner, but when this is being run as a
             // service the Windows Service Control Manager becomes the default thread owner.
-            // We need to make this thread the owner of the ACE reactor because this is a
+            // We need to make this thread the owner of the ACE reactor because this is a
             // requirement of the ACE SELECT reactor.
             ACE_Reactor::instance()->owner(ACE_Thread::self());
Modified: trunk/MgDev/Server/src/Services/Feature/FilterUtil.cpp
--- trunk/MgDev/Server/src/Services/Feature/FilterUtil.cpp	2010-10-02 06:16:48 UTC (rev 5232)
+++ trunk/MgDev/Server/src/Services/Feature/FilterUtil.cpp	2010-10-02 06:18:55 UTC (rev 5233)
@@ -153,7 +153,7 @@
     else if (xmlcmp(wnm, L"PropertyName") == 0)
         m_propName = process_identifier(root);
         // This is a workaround for GML3. For Name and Description properties, there will be a "gml:" prefix
         // Remove the prefix to make sure Name and Description properties can be found by FDO API.
         size_t pos = m_propName.find_first_of(L":");
Modified: trunk/MgDev/Server/src/Services/Feature/ServerDescribeSchema.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerDescribeSchema.cpp	2010-10-02 06:16:48 UTC (rev 5232)
+++ trunk/MgDev/Server/src/Services/Feature/ServerDescribeSchema.cpp	2010-10-02 06:18:55 UTC (rev 5233)
@@ -41,7 +41,7 @@
     CREFSTRING schemaName, MgStringCollection* classNames, bool& classNameHintUsed)
     // IMPORTANT INFORMATION
-    // FDO objects cannot be cached as they are not thread safe.
+    // FDO objects cannot be cached as they are not thread safe.
     // This is not an issue because we create a MapGuide wrapper of this information that is thread safe.
     FdoPtr<FdoFeatureSchemaCollection> ffsc;
     ffsc = NULL;
@@ -1049,7 +1049,7 @@
         FdoPtr<FdoFeatureSchemaCollection> fdoSchemas;
         fdoSchemas = NULL;
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp	2010-10-02 06:16:48 UTC (rev 5232)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp	2010-10-02 06:18:55 UTC (rev 5233)
@@ -1286,7 +1286,7 @@
 /// retrieve schema information. If this collection is null or empty, information
 /// is returned for all feature classes.
 /// \param outputFormat (String/string)
-/// A string identifying the output format of
+/// A string identifying the output format of
 /// the retrieved schema information.
 /// The supported values of output format are specified in OpenGIS Web Feature Service (WFS) Implementation Specification - section 8.2
 /// http://portal.opengeospatial.org/files/?artifact_id=8339
@@ -1728,7 +1728,7 @@
 /// \param wfsVersion (String/string)
 /// A string identifying the wfs version
 /// the retrieved feature information.
 /// The supported values of output format are specified in OpenGIS Web Feature Service (WFS) Implementation Specification - section 9.2
@@ -1746,9 +1746,9 @@
 /// MgInvalidArgumentException
 MgByteReader* MgServerFeatureService::GetWfsFeature(MgResourceIdentifier* fs,
                                                      CREFSTRING featureClass,
-                                                     MgStringCollection* propNames,
-                                                     CREFSTRING srs,
-                                                     CREFSTRING wfsFilter,
+                                                     MgStringCollection* propNames,
+                                                     CREFSTRING srs,
+                                                     CREFSTRING wfsFilter,
                                                      INT32 maxFeatures,
                                                      CREFSTRING wfsVersion,
                                                      CREFSTRING outputFormat,
@@ -1830,7 +1830,7 @@
                 if(prop->GetPropertyType() == MgFeaturePropertyType::GeometricProperty)
                     STRING ogcFilter = MgUtil::ReplaceString(wfsFilter,GEOM_PROP_TAG.c_str(),prop->GetName().c_str());
                     if(!fdoFilterString.empty())
                         fdoFilterString += L" OR ";
@@ -1839,7 +1839,7 @@
         options->SetFilter(fdoFilterString);
@@ -1854,7 +1854,7 @@
             STRING sSortByProperty = sSortCriteria.substr(0, pos);
             orderByProperties->Add(sSortByProperty);
             STRING sSortOption  = MgUtil::ToUpper(sSortCriteria.substr(pos+1));
             if(sSortOption == L"D")
@@ -1890,7 +1890,7 @@
     flags->SetMemberName(L"featureMember");
     flags->SetMemberUri(L"http://www.opengis.net/gml");
-    // set schemaLocations
+    // set schemaLocations
     // gml schema location and version
     if(L"text/xml; subtype=gml/2.1.2" == outputFormat)
@@ -1908,7 +1908,7 @@
         throw new MgInvalidArgumentException(L"MgServerFeatureService.GetWfsFeature",
         __LINE__, __WFILE__, NULL, L"", NULL);
     // wfs schema location
     if(L"1.0.0" == wfsVersion)
@@ -1923,16 +1923,16 @@
     // default namespace schema location
     flags->SetSchemaLocation(L"http://www.mynamespace.com/myns", L"http://www.mynamespace.com/myns/myns.xsd");
     // set the default namespace
     if(!namespacePrefix.empty())
         STRING defaultNamespace(L"http://fdo.osgeo.org/schemas/feature/");
         defaultNamespace += namespacePrefix;
         flags->SetDefaultNamespace(defaultNamespace.c_str());
     else
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp	2010-10-02 06:16:48 UTC (rev 5232)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp	2010-10-02 06:18:55 UTC (rev 5233)
@@ -963,7 +963,7 @@
                     if (!tempInstance.get())
                         continue;
                     if (((map->GetWatermarkUsage() & MgMap::Viewer) != 0
-                        && (tempInstance->GetUsage() & WatermarkInstance::Viewer) == 0)
+                        && (tempInstance->GetUsage() & WatermarkInstance::Viewer) == 0)
                         || ((map->GetWatermarkUsage() & MgMap::WMS) != 0
                         && (tempInstance->GetUsage() & WatermarkInstance::WMS) == 0))
                         continue;
@@ -998,7 +998,7 @@
                     continue;
                 ldf.reset(MgLayerBase::GetLayerDefinition(mapLayer->GetLayerResourceContent()));
                 WatermarkInstanceCollection* layerWatermarks = ldf->GetWatermarks();
                 for (int j=layerWatermarks->GetCount()-1; j>=0; j--)
                     tempWatermarkInstances.Adopt(layerWatermarks->OrphanAt(j));
@@ -1008,7 +1008,7 @@
                         continue;
                         continue;
More information about the mapguide-commits mailing list
