[mapguide-commits] r5239 - in sandbox/maestro-3.0/Maestro.Base: . Editor Properties Services
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Oct 4 01:51:06 EDT 2010
Author: jng
Date: 2010-10-04 05:51:06 +0000 (Mon, 04 Oct 2010)
New Revision: 5239
   sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.cs
   sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs
   sandbox/maestro-3.0/Maestro.Base/Editor/FeatureSourceEditor.cs
   sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.cs
   sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.cs
   sandbox/maestro-3.0/Maestro.Base/Editor/XmlEditor.cs
   sandbox/maestro-3.0/Maestro.Base/IViewContent.cs
   sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
   sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
   sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
   sandbox/maestro-3.0/Maestro.Base/TabFactory.cs
   sandbox/maestro-3.0/Maestro.Base/ViewContentBase.cs
3.0 sandbox changes:
 - Refactor root resource editors to use common pre-save logic.
 - Add pre-save validation stub for subclasses of EditorContentBase to do resource-specific validation
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.cs	2010-10-04 04:39:35 UTC (rev 5238)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.cs	2010-10-04 05:51:06 UTC (rev 5239)
@@ -47,22 +47,5 @@
             _edsvc.BeforeSave += new CancelEventHandler(OnBeforeSave);
             dsEditorCtrl.Bind(service);
-        void OnBeforeSave(object sender, CancelEventArgs e)
-            //We've been editing an in-memory model of the session copy
-            //so we need to save this model back to the session copy before Save()
-            //commits the changes back to the original resource
-            try
-                _edsvc.UpdateResourceContent(_res.Serialize());
-                e.Cancel = false;
-            catch (Exception ex)
-                MessageService.ShowError(ex);
-                e.Cancel = true;
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs	2010-10-04 04:39:35 UTC (rev 5238)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs	2010-10-04 05:51:06 UTC (rev 5239)
@@ -8,6 +8,7 @@
 using OSGeo.MapGuide.MaestroAPI.Resource;
 using OSGeo.MapGuide.MaestroAPI;
 using Maestro.Editors;
+using ICSharpCode.Core;
 namespace Maestro.Base.Editor
@@ -37,6 +38,7 @@
                 _svc = value;
                 _svc.DirtyStateChanged += new EventHandler(OnDirtyStateChanged);
                 _svc.Saved += new EventHandler(OnSaved);
+                _svc.BeforeSave += new CancelEventHandler(OnBeforeSave);
                 this.Resource = _svc.GetEditedResource();
                 UpdateTitle();
@@ -47,6 +49,34 @@
+        protected virtual string GetXmlContent()
+            return this.Resource.Serialize();
+        protected virtual void OnBeforeSave(object sender, CancelEventArgs e)
+            //We've been editing an in-memory model of the session copy
+            //so we need to save this model back to the session copy before Save()
+            //commits the changes back to the original resource
+            try
+                ValidateEditedResource();
+                _svc.UpdateResourceContent(GetXmlContent());
+                e.Cancel = false;
+            catch (Exception ex)
+                MessageService.ShowError(ex);
+                e.Cancel = true;
+        /// <summary>
+        /// Performs any pre-save validation on the currently edited resource
+        /// </summary>
+        protected virtual void ValidateEditedResource() { }
         void OnSaved(object sender, EventArgs e)
             UpdateTitle();
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/FeatureSourceEditor.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/FeatureSourceEditor.cs	2010-10-04 04:39:35 UTC (rev 5238)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/FeatureSourceEditor.cs	2010-10-04 05:51:06 UTC (rev 5239)
@@ -44,27 +44,9 @@
             _edsvc = service;
             _res = _edsvc.GetEditedResource();
-            _edsvc.BeforeSave += new CancelEventHandler(OnBeforeSave);
             fsEditorCtrl.Bind(service);
-            try
-                e.Cancel = false;
-                e.Cancel = true;
         public override string SetupPreviewUrl(string mapguideRootUrl)
             string url = mapguideRootUrl;
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.cs	2010-10-04 04:39:35 UTC (rev 5238)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.cs	2010-10-04 05:51:06 UTC (rev 5239)
@@ -75,22 +75,5 @@
                 throw new NotSupportedException("Could not determine the sub-layer type"); //LOCALIZE
-            try
-                e.Cancel = false;
-                e.Cancel = true;
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.cs	2010-10-04 04:39:35 UTC (rev 5238)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.cs	2010-10-04 05:51:06 UTC (rev 5239)
@@ -48,23 +48,6 @@
             mapEditorCtrl.Bind(service);
-            try
-                e.Cancel = false;
-                e.Cancel = true;
         public override bool CanProfile
             get
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/XmlEditor.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/XmlEditor.cs	2010-10-04 04:39:35 UTC (rev 5238)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/XmlEditor.cs	2010-10-04 05:51:06 UTC (rev 5239)
@@ -88,19 +88,14 @@
         protected override void Bind(IEditorService service)
             service.RegisterCustomNotifier(editor);
-            service.BeforeSave += new CancelEventHandler(OnBeforeSave);
             editor.Bind(service);
             editor.ReadyForEditing(); //This turns on event broadcasting
             this.Title = "XML Editor: " + ResourceIdentifier.GetName(this.EditorService.ResourceID); //LOCALIZE
+        protected override string GetXmlContent()
-            //Because we're working with raw XML, we need to save the XML back to our session
-            //copy first before the save operation starts
-            this.EditorService.UpdateResourceContent(this.XmlContent);
-            e.Cancel = false;
+            return this.XmlContent;
         public string XmlContent
Modified: sandbox/maestro-3.0/Maestro.Base/IViewContent.cs
--- sandbox/maestro-3.0/Maestro.Base/IViewContent.cs	2010-10-04 04:39:35 UTC (rev 5238)
+++ sandbox/maestro-3.0/Maestro.Base/IViewContent.cs	2010-10-04 05:51:06 UTC (rev 5239)
@@ -21,6 +21,7 @@
 using System.Collections.Generic;
 using System.Text;
 using System.Drawing;
+using System.ComponentModel;
@@ -71,8 +72,12 @@
         /// <summary>
         /// Fired when the view has been closed internally
         /// </summary>
-        event EventHandler ViewContentClosing;
+        event CancelEventHandler ViewContentClosing;
         /// <summary>
+        /// Fired when the view has been closed internally
+        /// </summary>
+        event EventHandler ViewContentClosed;
+        /// <summary>
         /// Fired when the view is going to hide
         /// </summary>
         event EventHandler ViewContentHiding;
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs	2010-10-04 04:39:35 UTC (rev 5238)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs	2010-10-04 05:51:06 UTC (rev 5239)
@@ -260,6 +260,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to This resource has unsaved changes. Close and discard these changes?.
+        /// </summary>
+        internal static string CloseUnsavedResource {
+            get {
+                return ResourceManager.GetString("CloseUnsavedResource", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Are you sure you want to delete?.
         /// </summary>
         internal static string ConfirmDelete {
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx	2010-10-04 04:39:35 UTC (rev 5238)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx	2010-10-04 05:51:06 UTC (rev 5239)
@@ -673,4 +673,7 @@
   <data name="NewResource" xml:space="preserve">
     <value>New Resource</value>
   </data>
+  <data name="CloseUnsavedResource" xml:space="preserve">
+    <value>This resource has unsaved changes. Close and discard these changes?</value>
+  </data>
 </root>
\ No newline at end of file
Modified: sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs	2010-10-04 04:39:35 UTC (rev 5238)
+++ sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs	2010-10-04 05:51:06 UTC (rev 5239)
@@ -101,6 +101,16 @@
                 _openItems[resourceId] = ed;
                 ed.ViewContentClosing += (sender, e) =>
+                    if (ed.IsDirty)
+                        if (!MessageService.AskQuestion(Properties.Resources.CloseUnsavedResource))
+                            e.Cancel = true;
+                ed.ViewContentClosed += (sender, e) =>
                     _openItems.Remove(resourceId);
                     siteExp.FlagNode(resourceId, NodeFlagAction.None);
Modified: sandbox/maestro-3.0/Maestro.Base/TabFactory.cs
--- sandbox/maestro-3.0/Maestro.Base/TabFactory.cs	2010-10-04 04:39:35 UTC (rev 5238)
+++ sandbox/maestro-3.0/Maestro.Base/TabFactory.cs	2010-10-04 05:51:06 UTC (rev 5239)
@@ -89,7 +89,7 @@
-            content.ViewContentClosing += (sender, e) =>
+            content.ViewContentClosed += (sender, e) =>
                 //Remove itself from the tab control
                 var tabs = page.Parent as TabControl;
Modified: sandbox/maestro-3.0/Maestro.Base/ViewContentBase.cs
--- sandbox/maestro-3.0/Maestro.Base/ViewContentBase.cs	2010-10-04 04:39:35 UTC (rev 5238)
+++ sandbox/maestro-3.0/Maestro.Base/ViewContentBase.cs	2010-10-04 05:51:06 UTC (rev 5239)
@@ -69,12 +69,20 @@
         public virtual void Close()
-            var handler = this.ViewContentClosing;
+            CancelEventArgs ce = new CancelEventArgs(false);
+            var ceHandler = this.ViewContentClosing;
+            if (ceHandler != null)
+                ceHandler(this, ce);
+            if (ce.Cancel)
+                return;
+            var handler = this.ViewContentClosed;
             if (handler != null)
                 handler(this, EventArgs.Empty);
-        public event EventHandler ViewContentClosing;
+        public event CancelEventHandler ViewContentClosing;
         public void ShowError(Exception ex)
@@ -158,5 +166,7 @@
             get { return ViewRegion.Document; }
+        public event EventHandler ViewContentClosed;
More information about the mapguide-commits mailing list
