[mapguide-commits] r5255 - sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Oct 7 09:05:13 EDT 2010
Author: jng
Date: 2010-10-07 13:05:12 +0000 (Thu, 07 Oct 2010)
New Revision: 5255
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaces.cs
Add abstract layer interface documentation
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaces.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaces.cs	2010-10-07 12:42:50 UTC (rev 5254)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaces.cs	2010-10-07 13:05:12 UTC (rev 5255)
@@ -151,56 +151,189 @@
         Raster
+    /// <summary>
+    /// Factory interface to assist in creating common layer definition elements
+    /// </summary>
     public interface ILayerElementFactory
+        /// <summary>
+        /// Creates a name-value pair
+        /// </summary>
+        /// <param name="name"></param>
+        /// <param name="value"></param>
+        /// <returns></returns>
         INameStringPair CreatePair(string name, string value);
+        /// <summary>
+        /// Creates a default area rule (monochromatic)
+        /// </summary>
         IAreaRule CreateDefaultAreaRule();
+        /// <summary>
+        /// Creates a default area style (monochromatic)
+        /// </summary>
         IAreaVectorStyle CreateDefaultAreaStyle();
+        /// <summary>
+        /// Creates a default fill (monochromatic)
+        /// </summary>
         IFill CreateDefaultFill();
+        /// <summary>
+        /// Creates a default line style (monochromatic)
+        /// </summary>
         ILineVectorStyle CreateDefaultLineStyle();
+        /// <summary>
+        /// Creates a default mark symbol
+        /// </summary>
         IMarkSymbol CreateDefaultMarkSymbol();
+        /// <summary>
+        /// Creates a default point style
+        /// </summary>
         IPointVectorStyle CreateDefaultPointStyle();
+        /// <summary>
+        /// Creates a default 2D point symbolization
+        /// </summary>
         IPointSymbolization2D CreateDefaultPointSymbolization2D();
+        /// <summary>
+        /// Creates a default stroke
+        /// </summary>
         IStroke CreateDefaultStroke();
+        /// <summary>
+        /// Creates a default text symbol
+        /// </summary>
         ITextSymbol CreateDefaultTextSymbol();
+        /// <summary>
+        /// Creates a fill
+        /// </summary>
+        /// <param name="pattern"></param>
+        /// <param name="background"></param>
+        /// <param name="foreground"></param>
         IFill CreateFill(string pattern, System.Drawing.Color background, System.Drawing.Color foreground);
+        /// <summary>
+        /// Creates a default line rule
+        /// </summary>
         ILineRule CreateDefaultLineRule();
+        /// <summary>
+        /// Creates a default point rule
+        /// </summary>
         IPointRule CreateDefaultPointRule();
+        /// <summary>
+        /// Creates a stroke of the specified color
+        /// </summary>
+        /// <param name="color"></param>
         IStroke CreateStroke(System.Drawing.Color color);
+        /// <summary>
+        /// Creates a vector scale range
+        /// </summary>
         IVectorScaleRange CreateVectorScaleRange();
+        /// <summary>
+        /// Creates a font symbol
+        /// </summary>
         IFontSymbol CreateDefaultFontSymbol();
+    /// <summary>
+    /// Top-level interface of the layer definition
+    /// </summary>
     public interface ILayerDefinition : IResource, ILayerElementFactory
         ISubLayerDefinition SubLayer { get; }
+    /// <summary>
+    /// Represents the base of all layer definitions
+    /// </summary>
     public interface ISubLayerDefinition : INotifyPropertyChanged
+        /// <summary>
+        /// Gets the type of layer definition
+        /// </summary>
         LayerType LayerType { get; }
+        /// <summary>
+        /// Gets or sets the resource id which is the data source for this layer
+        /// </summary>
         string ResourceId { get; set; }
+    /// <summary>
+    /// Represents a layer definition based on a vector-based feature source
+    /// </summary>
     public interface IVectorLayerDefinition : ISubLayerDefinition
+        /// <summary>
+        /// Gets or sets fully qualified name of the feature class which this layer applies
+        /// </summary>
         string FeatureName { get; set; }
+        /// <summary>
+        /// Gets or sets the geometry field of the feature class which this layer applies
+        /// </summary>
         string Geometry { get; set; }
+        /// <summary>
+        /// Gets or sets an FDO expression which represents the URL that is opened when
+        /// a feature is selected
+        /// </summary>
         string Url { get; set; }
+        /// <summary>
+        /// Gets or sets an FDO expression which represents the HTML content that is displayed
+        /// when the mouse is over the current feature
+        /// </summary>
         string ToolTip { get; set; }
+        /// <summary>
+        /// Gets or sets an FDO filter which is applied when rendering/styling features
+        /// </summary>
         string Filter { get; set; }
+        //FIXME: this compiles, but will probably break when run due to lack of co/contravariance support pre-4.0
+        /// <summary>
+        /// Gets the scale ranges for this layer
+        /// </summary>
         IList<IVectorScaleRange> VectorScaleRange { get; }
+        /// <summary>
+        /// Gets the property mappings for this layer. This determines which properties
+        /// are displayed (and what labels to use) in the property pane and
+        /// </summary>
         IList<INameStringPair> PropertyMapping { get; }
+    /// <summary>
+    /// Represents a layer definition based on a raster-based feature source
+    /// </summary>
     public interface IRasterLayerDefinition : ISubLayerDefinition
@@ -212,6 +345,9 @@
     //If only all layers were as simple as this one...
+    /// <summary>
+    /// Represents a layer definition based on a DWF-based drawing source
+    /// </summary>
     public interface IDrawingLayerDefinition : ISubLayerDefinition
         /// <summary>
@@ -276,9 +412,19 @@
         IVectorScaleRange Clone();
+    /// <summary>
+    /// Represents a name-value pair
+    /// </summary>
     public interface INameStringPair
+        /// <summary>
+        /// Gets or set the name
+        /// </summary>
         string Name { get; set; }
+        /// <summary>
+        /// Gets or sets the value
+        /// </summary>
         string Value { get; set; }
@@ -350,6 +496,9 @@
         /// <param name="rule"></param>
         void RemoveRule(ILineRule rule);
+        /// <summary>
+        /// Removes all current rules
+        /// </summary>
         void RemoveAllRules();
@@ -385,6 +534,9 @@
         void RemoveRule(IPointRule rule);
+        /// <summary>
+        /// </summary>
@@ -430,10 +582,22 @@
         /// </summary>
         IEnumerable<IStroke> Strokes { get; }
+        /// <summary>
+        /// Removes any existing strokes and adds the specified list of strokes
+        /// </summary>
+        /// <param name="strokes"></param>
         void SetStrokes(IEnumerable<IStroke> strokes);
+        /// <summary>
+        /// Adds a stroke to this rule
+        /// </summary>
+        /// <param name="stroke"></param>
         void AddStroke(IStroke stroke);
+        /// <summary>
+        /// Removes a stroke from this rule
+        /// </summary>
         void RemoveStroke(IStroke stroke);
@@ -453,12 +617,24 @@
     /// </summary>
     public interface IStroke
+        /// <summary>
+        /// Gets or sets the line style
+        /// </summary>
         string LineStyle { get; set; }
+        /// <summary>
+        /// Gets or sets the thickness
+        /// </summary>
         string Thickness { get; set; }
+        /// <summary>
+        /// Gets or sets the color
+        /// </summary>
         string Color { get; set; }
+        /// <summary>
+        /// Gets or sets the thickness unit
+        /// </summary>
         LengthUnitType Unit { get; set; }
@@ -480,6 +656,9 @@
     public enum PointSymbolType
+        /// <summary>
+        /// A textual symbol
+        /// </summary>
         Text,
         /// <summary>
         /// A predefined shape such as a square or circle.
@@ -561,26 +740,59 @@
     public interface ITextSymbol : ISymbol
+        /// <summary>
+        /// Gets or sets the textual content
+        /// </summary>
         string Text { get; set; }
+        /// <summary>
+        /// Gets or sets the name of the font
+        /// </summary>
         string FontName { get; set; }
+        /// <summary>
+        /// Gets or sets the foreground color
+        /// </summary>
         string ForegroundColor { get; set; }
+        /// <summary>
+        /// Gets or sets the background color
+        /// </summary>
         string BackgroundColor { get; set; }
+        /// <summary>
+        /// Gets or sets the background style
+        /// </summary>
         BackgroundStyleType BackgroundStyle { get; set; }
+        /// <summary>
+        /// Gets or sets the horizontal alignment
+        /// </summary>
         string HorizontalAlignment { get; set; }
+        /// <summary>
+        /// Gets or sets the vertical alignment
+        /// </summary>
         string VerticalAlignment { get; set; }
+        /// <summary>
+        /// Gets or sets whether to bold the text
+        /// </summary>
         string Bold { get; set; }
+        /// <summary>
+        /// Gets or sets whether to italicize the text
+        /// </summary>
         string Italic { get; set; }
+        /// <summary>
+        /// Gets or sets whether to underline the text
+        /// </summary>
         string Underlined { get; set; }
+        /// <summary>
+        /// Gets or sets the advanced placement settings
+        /// </summary>
         IAdvancedPlacement AdvancedPlacement { get; set; }
@@ -589,10 +801,19 @@
     /// </summary>
     public interface IMarkSymbol : ISymbol
+        /// <summary>
+        /// Gets or sets the type of shape
+        /// </summary>
         ShapeType Shape { get; set; }
+        /// <summary>
+        /// Gets or sets the fill settings
+        /// </summary>
         IFill Fill { get; set; }
+        /// <summary>
+        /// Gets or sets the outline settings
+        /// </summary>
         IStroke Edge { get; set; }
@@ -606,25 +827,55 @@
         /// </summary>
+        /// <summary>
+        /// Gets or sets the character
+        /// </summary>
         string Character { get; set; }
+        /// <summary>
+        /// </summary>
         bool? Bold { get; set; }
+        /// <summary>
+        /// </summary>
         bool? Italic { get; set; }
+        /// <summary>
+        /// </summary>
         bool? Underlined { get; set; }
+        /// <summary>
+        /// </summary>
+    /// <summary>
+    /// Represents a DWF-based W2D symbol
+    /// </summary>
     public interface IW2DSymbol : ISymbol
+        /// <summary>
+        /// Gets or sets the reference to the symbol
+        /// </summary>
         ISymbolReference W2DSymbol { get; set; }
+        /// <summary>
+        /// Gets or sets the fill color
+        /// </summary>
         string FillColor { get; set; }
+        /// <summary>
+        /// Gets or sets the line color
+        /// </summary>
         string LineColor { get; set; }
+        /// <summary>
+        /// Gets or sets the text color
+        /// </summary>
         string TextColor { get; set; }
@@ -673,12 +924,24 @@
     /// </summary>
     public interface IBlockSymbol : ISymbol
+        /// <summary>
+        /// Gets or sets the name of the drawing
+        /// </summary>
         string DrawingName { get; set; }
+        /// <summary>
+        /// Gets or sets the name of the block
+        /// </summary>
         string BlockName { get; set; }
+        /// <summary>
+        /// Gets or sets the color of the block
+        /// </summary>
         string BlockColor { get; set; }
+        /// <summary>
+        /// Gets or sets the color of the layer
+        /// </summary>
         string LayerColor { get; set; }
@@ -690,12 +953,24 @@
         ISymbol Symbol { get; set; }
+    /// <summary>
+    /// Represents a fill
+    /// </summary>
     public interface IFill
+        /// <summary>
+        /// Gets or sets the fill pattern
+        /// </summary>
         string FillPattern { get; set; }
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
@@ -739,10 +1014,19 @@
     /// </summary>
     public interface IGridColorBands
+        /// <summary>
+        /// Gets or sets the red channel band
+        /// </summary>
         IChannelBand RedBand { get; set; }
+        /// <summary>
+        /// Gets or sets the green channel band
+        /// </summary>
         IChannelBand GreenBand { get; set; }
+        /// <summary>
+        /// Gets or sets the blue channel band
+        /// </summary>
         IChannelBand BlueBand { get; set; }
@@ -836,8 +1120,17 @@
         /// </summary>
         double ConstrastFactor { get; set; }
+        /// <summary>
+        /// Gets the color rules for this style
+        /// </summary>
         IList<IGridColorRule> ColorRule { get; }
+        /// <summary>
+        /// Adds a color rule to this style
+        /// </summary>
+        /// <param name="rule"></param>
         void AddColorRule(IGridColorRule rule);
More information about the mapguide-commits mailing list
