[mapguide-commits] r5264 - in trunk/Tools/Maestro/Maestro/ResourceValidators: . Strings
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Oct 10 21:30:38 EDT 2010
Author: jng
Date: 2010-10-10 18:30:38 -0700 (Sun, 10 Oct 2010)
New Revision: 5264
   trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/WebLayoutValidator.Designer.cs
   trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/WebLayoutValidator.resx
   trunk/Tools/Maestro/Maestro/ResourceValidators/WebLayoutValidator.cs
Update web layout validator to detect dangling menu commands
Modified: trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/WebLayoutValidator.Designer.cs
--- trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/WebLayoutValidator.Designer.cs	2010-10-11 00:28:00 UTC (rev 5263)
+++ trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/WebLayoutValidator.Designer.cs	2010-10-11 01:30:38 UTC (rev 5264)
@@ -97,6 +97,33 @@
         /// <summary>
+        ///   Looks up a localized string similar to Context Menu contains a reference to a command that doesn&apos;t exist: {0}.
+        /// </summary>
+        internal static string NonExistentMenuCommandReference {
+            get {
+                return ResourceManager.GetString("NonExistentMenuCommandReference", resourceCulture);
+        /// <summary>
+        ///   Looks up a localized string similar to Task Pane contains a reference to a command that does not exist: {0}.
+        /// </summary>
+        internal static string NonExistentTaskPaneCommandReference {
+            get {
+                return ResourceManager.GetString("NonExistentTaskPaneCommandReference", resourceCulture);
+        /// <summary>
+        ///   Looks up a localized string similar to Toolbar contains a reference to a command that does not exist: {0}.
+        /// </summary>
+        internal static string NonExistentToolbarCommandReference {
+            get {
+                return ResourceManager.GetString("NonExistentToolbarCommandReference", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Layout specifies a start view that is outside the map&apos;s initial extents.
         /// </summary>
         internal static string StartViewOutsideExtentsWarning {
Modified: trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/WebLayoutValidator.resx
--- trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/WebLayoutValidator.resx	2010-10-11 00:28:00 UTC (rev 5263)
+++ trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/WebLayoutValidator.resx	2010-10-11 01:30:38 UTC (rev 5264)
@@ -131,6 +131,15 @@
     <value>Layout does not specify a map</value>
     <comment>An error message that is displayed if no map is specified in the layout</comment>
   </data>
+  <data name="NonExistentMenuCommandReference" xml:space="preserve">
+    <value>Context Menu contains a reference to a command that doesn't exist: {0}</value>
+  </data>
+  <data name="NonExistentTaskPaneCommandReference" xml:space="preserve">
+    <value>Task Pane contains a reference to a command that does not exist: {0}</value>
+  </data>
+  <data name="NonExistentToolbarCommandReference" xml:space="preserve">
+    <value>Toolbar contains a reference to a command that does not exist: {0}</value>
+  </data>
   <data name="StartViewOutsideExtentsWarning" xml:space="preserve">
     <value>Layout specifies a start view that is outside the map's initial extents</value>
     <comment>A warning message that is displayed if the layout specifies a start center point that is outside the map's specified extents</comment>
Modified: trunk/Tools/Maestro/Maestro/ResourceValidators/WebLayoutValidator.cs
--- trunk/Tools/Maestro/Maestro/ResourceValidators/WebLayoutValidator.cs	2010-10-11 00:28:00 UTC (rev 5263)
+++ trunk/Tools/Maestro/Maestro/ResourceValidators/WebLayoutValidator.cs	2010-10-11 01:30:38 UTC (rev 5264)
@@ -70,6 +70,37 @@
+                //Check for command references to non-existent commands
+                foreach (UIItemType item in layout.ContextMenu.MenuItem)
+                    if (item.Function == UIItemFunctionType.Command)
+                        CommandItemType cmdRef = (CommandItemType)item;
+                        if (!cmds.ContainsKey(cmdRef.Command))
+                            issues.Add(new ValidationIssue(layout, ValidationStatus.Error, string.Format(Strings.WebLayoutValidator.NonExistentMenuCommandReference, cmdRef.Command)));
+                foreach (UIItemType item in layout.TaskPane.TaskBar.MenuButton)
+                            issues.Add(new ValidationIssue(layout, ValidationStatus.Error, string.Format(Strings.WebLayoutValidator.NonExistentTaskPaneCommandReference, cmdRef.Command)));
+                foreach (UIItemType item in layout.ToolBar.Button)
+                            issues.Add(new ValidationIssue(layout, ValidationStatus.Error, string.Format(Strings.WebLayoutValidator.NonExistentToolbarCommandReference, cmdRef.Command)));
                 if (recurse)
                     try
More information about the mapguide-commits mailing list
