[mapguide-commits] r5279 - in sandbox/maestro-3.0: Maestro Maestro.Base Maestro.Base/Services Maestro.Login OSGeo.MapGuide.MaestroAPI
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Oct 13 01:59:23 EDT 2010
Author: jng
Date: 2010-10-12 22:59:23 -0700 (Tue, 12 Oct 2010)
New Revision: 5279
   sandbox/maestro-3.0/Maestro.Base/Services/UrlLauncherService.cs
   sandbox/maestro-3.0/Maestro.Base/TabFactory.cs
   sandbox/maestro-3.0/Maestro.Login/LoginDialog.cs
   sandbox/maestro-3.0/Maestro/Program.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ConnectionProviderRegistry.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Platform.cs
3.0 sandbox changes:
 - Tweak the platform check. It *is* the mono runtime we are concerned about here.
Modified: sandbox/maestro-3.0/Maestro/Program.cs
--- sandbox/maestro-3.0/Maestro/Program.cs	2010-10-13 02:32:42 UTC (rev 5278)
+++ sandbox/maestro-3.0/Maestro/Program.cs	2010-10-13 05:59:23 UTC (rev 5279)
@@ -57,7 +57,7 @@
             // to System.Diagnostics.Trace.
             LoggingService.Info("Application start");
-            if (!Platform.IsWindows)
+            if (Platform.IsRunningOnMono)
                 LoggingService.Info(Properties.Resources.Warn_Mono);
Modified: sandbox/maestro-3.0/Maestro.Base/Services/UrlLauncherService.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/UrlLauncherService.cs	2010-10-13 02:32:42 UTC (rev 5278)
+++ sandbox/maestro-3.0/Maestro.Base/Services/UrlLauncherService.cs	2010-10-13 05:59:23 UTC (rev 5279)
@@ -45,7 +45,7 @@
         public bool CanUseEmbeddedWebBrowser
             //Mono's web browser is too unwieldy
-            get { return Platform.IsWindows; }
+            get { return !Platform.IsRunningOnMono; }
         /// <summary>
Modified: sandbox/maestro-3.0/Maestro.Base/TabFactory.cs
--- sandbox/maestro-3.0/Maestro.Base/TabFactory.cs	2010-10-13 02:32:42 UTC (rev 5278)
+++ sandbox/maestro-3.0/Maestro.Base/TabFactory.cs	2010-10-13 05:59:23 UTC (rev 5279)
@@ -95,7 +95,7 @@
                 var tabs = page.Parent as TabControl;
                 if (tabs != null && tabs.TabPages.Contains(page))
-                    if (Platform.IsWindows)
+                    if (!Platform.IsRunningOnMono)
                         var idx = tabs.TabPages.IndexOf(page);
                         tabs.TabPages.Remove(page);
Modified: sandbox/maestro-3.0/Maestro.Login/LoginDialog.cs
--- sandbox/maestro-3.0/Maestro.Login/LoginDialog.cs	2010-10-13 02:32:42 UTC (rev 5278)
+++ sandbox/maestro-3.0/Maestro.Login/LoginDialog.cs	2010-10-13 05:59:23 UTC (rev 5279)
@@ -96,7 +96,7 @@
             rdHttp.Checked = true;
             //Mono = No LocalNativeConnection for you (for now...)
                 rdTcpIp.Enabled = false;
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ConnectionProviderRegistry.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ConnectionProviderRegistry.cs	2010-10-13 02:32:42 UTC (rev 5278)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ConnectionProviderRegistry.cs	2010-10-13 05:59:23 UTC (rev 5279)
@@ -143,7 +143,7 @@
                 throw new ArgumentException("Provider not registered: " + provider);
             ConnectionProviderEntry prv = FindProvider(provider);
-            if (prv != null && !prv.IsMultiPlatform && !Platform.IsWindows)
+            if (prv != null && !prv.IsMultiPlatform && Platform.IsRunningOnMono)
                 throw new NotSupportedException("The specified provider is not usable in your operating system");
             Type t = _ctors[name];
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Platform.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Platform.cs	2010-10-13 02:32:42 UTC (rev 5278)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Platform.cs	2010-10-13 05:59:23 UTC (rev 5279)
@@ -25,9 +25,19 @@
     public static class Platform
-        public static bool IsWindows
+        static Platform()
-            get { return Environment.OSVersion.Platform != PlatformID.Unix && Environment.OSVersion.Platform != PlatformID.MacOSX; }
+            _mrtType = Type.GetType("Mono.Runtime");
+        private static Type _mrtType;
+        public static bool IsRunningOnMono
+            get
+                return _mrtType != null;
More information about the mapguide-commits mailing list
