[mapguide-commits] r5289 - in sandbox/maestro-3.0: Maestro.Base
Maestro.Base/Editor Maestro.Base/Properties
Maestro.Base/Resources Maestro.Base/Services Maestro.Base/UI
Maestro.Editors Maestro.Editors/MapDefinition
Maestro.Editors/PrintLayout Maestro.Editors/Properties
Maestro.Editors/Resources Maestro.ResourceValidation
MaestroAPITests OSGeo.MapGuide.MaestroAPI
OSGeo.MapGuide.MaestroAPI/ObjectModels
OSGeo.MapGuide.MaestroAPI/Services
svn_mapguide at osgeo.org
Mon Oct 18 03:16:47 EDT 2010
Author: jng
Date: 2010-10-18 00:16:47 -0700 (Mon, 18 Oct 2010)
New Revision: 5289
Added:
sandbox/maestro-3.0/Maestro.Base/Resources/box--arrow.png
sandbox/maestro-3.0/Maestro.Base/Resources/box--plus.png
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.resx
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapTreeModels.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ScaleListGenerator.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.resx
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.resx
sandbox/maestro-3.0/Maestro.Editors/Resources/map--arrow.png
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/PrintLayoutInterfaces.cs
Removed:
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/Logos/
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/Text/
sandbox/maestro-3.0/Maestro.Base/Editor/ResourceEditorService.cs
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
sandbox/maestro-3.0/Maestro.Base/UI/ResourcePropertiesDialog.cs
sandbox/maestro-3.0/Maestro.Editors/IEditorService.cs
sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomLogosSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomLogosSectionCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomTextSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomTextSectionCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintLayoutEditorCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintLayoutEditorCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintPagePropertiesSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintPagePropertiesSectionCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.ResourceValidation/ApplicationDefinitionValidator.cs
sandbox/maestro-3.0/Maestro.ResourceValidation/WebLayoutValidator.cs
sandbox/maestro-3.0/MaestroAPITests/ObjectTests.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Check.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/Envelope.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSourceInterfaces.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaceExtensions.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinitionInterfaces.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/PrintLayout.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ServerConnectionBase.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs
3.0 sandbox changes:
- Add interfaces for Print Layout schema
- Complete implementation of Print Layout Editor
- More Map Definition interface cleanup.
- Introduce an IEnvelope interface to establish a common ground between various generated classes with similar/indentical properties (Envelope/Box2DType)
- Polish up the implementation of the Map Defintion Editor (v1.0.0 schema), targeting the abstract interfaces instead of concrete classes. Short of productive functionality like drag/drop support. This should be a fully functional editor
- Add new OpenResource() API to IEditorService, allowing editors to open an editor for another resource
- Clean up and iconify commands in the base addin file
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/ResourceEditorService.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/ResourceEditorService.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/ResourceEditorService.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -40,14 +40,16 @@
private ISiteExplorer _siteExp;
private IResource _editCopy;
+ private OpenResourceManager _orm;
- public ResourceEditorService(string resourceID, IServerConnection conn, IUrlLauncherService launcher, ISiteExplorer siteExp)
+ public ResourceEditorService(string resourceID, IServerConnection conn, IUrlLauncherService launcher, ISiteExplorer siteExp, OpenResourceManager orm)
this.IsNew = ResourceIdentifier.IsSessionBased(resourceID);
this.ResourceID = resourceID;
_siteExp = siteExp;
_conn = conn;
_launcher = launcher;
+ _orm = orm;
public event EventHandler DirtyStateChanged;
@@ -303,5 +305,10 @@
get { return _conn.SiteVersion; }
+ public void OpenResource(string resourceId)
+ _orm.Open(resourceId, _conn, false, _siteExp);
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-10-18 07:16:47 UTC (rev 5289)
@@ -78,18 +78,24 @@
<MenuItem id="Menu_Edit"
type="Menu"
label="${res:Menu_Edit}">
- <MenuItem id="CopyItem"
- icon="document_copy"
- label="${res:Menu_Edit_Copy}"
- class="Maestro.Base.Commands.NotImplementedCommand" />
- <MenuItem id="CutItem"
- label="${res:Menu_Edit_Cut}"
- icon="scissors_blue"
- <MenuItem id="PasteItem"
- label="${res:Menu_Edit_Paste}"
- icon="clipboard_paste"
+ <Condition action="Disable" name="IsNotRoot">
+ <Condition action="Disable" name="CanCutOrCopy">
+ <MenuItem id="CopyItem"
+ icon="document_copy"
+ label="${res:Menu_Edit_Copy}"
+ class="Maestro.Base.Commands.CopyCommand" />
+ <MenuItem id="CutItem"
+ label="${res:Menu_Edit_Cut}"
+ icon="scissors_blue"
+ class="Maestro.Base.Commands.CutCommand" />
+ </Condition>
+ </Condition>
+ <Condition action="Disable" name="CanPaste">
+ <MenuItem id="PasteItem"
+ label="${res:Menu_Edit_Paste}"
+ icon="clipboard_paste"
+ class="Maestro.Base.Commands.PasteCommand" />
+ </Condition>
</MenuItem>
<!-- For testing various APIs, disabled for releases -->
<Condition action="Exclude" name="DebugMode">
@@ -138,9 +144,11 @@
type="Menu"
label="${res:Menu_Package}">
<MenuItem id="CreatePackage"
+ icon="box__plus"
label="${res:SiteExplorer_SelectedFolder_CreatePackage}"
class="Maestro.Base.Commands.CreatePackageCommand" />
<MenuItem id="LoadPackage"
+ icon="box__arrow"
label="${res:Menu_Package_LoadPackage}"
class="Maestro.Base.Commands.LoadPackageCommand" />
</MenuItem>
@@ -302,31 +310,37 @@
class="Maestro.Base.Commands.SiteExplorer.RenameCommand" />
<MenuItem type="Separator" />
+ icon="box__plus"
<MenuItem id="Copy"
label="${res:SiteExplorer_SelectedItem_Copy}"
<MenuItem id="Cut"
label="${res:SiteExplorer_SelectedItem_Cut}"
</Condition>
</Condition>
<MenuItem id="Paste"
label="${res:SiteExplorer_SelectedFolder_Paste}"
</Condition>
<MenuItem id="Delete"
+ icon="cross_script"
label="${res:SiteExplorer_SelectedItem_Delete}"
class="Maestro.Base.Commands.SiteExplorer.DeleteSelectedItemsCommand" />
</Condition>
<MenuItem id="Validate"
+ icon="tick"
label="${res:SiteExplorer_ValidateResources}"
class="Maestro.Base.Commands.SiteExplorer.ValidateCommand" />
</Condition>
@@ -337,19 +351,23 @@
<Condition action="Disable" name="MultipleSelected">
<MenuItem id="Copy"
<MenuItem id="Cut"
</Condition>
+ icon="tick"
- label="${res:SiteExplorer_SelectedItem_Delete}"
- class="Maestro.Base.Commands.SiteExplorer.DeleteSelectedItemsCommand" />
+ label="${res:SiteExplorer_SelectedItem_Delete}"
+ class="Maestro.Base.Commands.SiteExplorer.DeleteSelectedItemsCommand" />
</Condition>
</Path>
@@ -360,25 +378,30 @@
label="${res:SiteExplorer_SelectedItem_Open}"
class="Maestro.Base.Commands.SiteExplorer.OpenResourceCommand" />
<MenuItem id="OpenXml"
+ icon="document_code"
label="${res:SiteExplorer_SelectedItem_OpenWithXmlEditor}"
class="Maestro.Base.Commands.SiteExplorer.OpenWithXmlEditorCommand" />
<MenuItem id="Rename"
label="${res:SiteExplorer_SelectedItem_Rename}"
<MenuItem id="Copy"
<MenuItem id="Cut"
</Condition>
+ icon="tick"
@@ -395,18 +418,22 @@
<MenuItem id="Copy"
<MenuItem id="Cut"
</Condition>
+ icon="tick"
</Condition>
@@ -419,18 +446,22 @@
<MenuItem id="Copy"
<MenuItem id="Cut"
</Condition>
+ icon="tick"
</Condition>
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-10-18 07:16:47 UTC (rev 5289)
@@ -308,6 +308,8 @@
</ItemGroup>
<ItemGroup>
<Content Include="Maestro.Base.addin" />
+ <None Include="Resources\box--plus.png" />
+ <None Include="Resources\box--arrow.png" />
<None Include="Resources\folder--plus.png" />
<None Include="Resources\cross.png" />
<None Include="Resources\blueprints.png" />
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -227,6 +227,20 @@
+ internal static System.Drawing.Bitmap box__arrow {
+ get {
+ object obj = ResourceManager.GetObject("box__arrow", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
+ internal static System.Drawing.Bitmap box__plus {
+ get {
+ object obj = ResourceManager.GetObject("box__plus", resourceCulture);
/// <summary>
/// Looks up a localized string similar to Done.
/// </summary>
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-10-18 07:16:47 UTC (rev 5289)
@@ -694,4 +694,10 @@
<data name="TPL_RLDF_NAME" xml:space="preserve">
<value>Raster Layer Definition</value>
</data>
+ <data name="box__arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\box--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="box__plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\box--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Base/Resources/box--arrow.png
(Binary files differ)
Property changes on: sandbox/maestro-3.0/Maestro.Base/Resources/box--arrow.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: sandbox/maestro-3.0/Maestro.Base/Resources/box--plus.png
Property changes on: sandbox/maestro-3.0/Maestro.Base/Resources/box--plus.png
Modified: sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -96,7 +96,7 @@
ed = FindEditor(svc, res.GetResourceTypeDescriptor());
var launcher = ServiceRegistry.GetService<UrlLauncherService>();
- var editorSvc = new ResourceEditorService(resourceId, conn, launcher, siteExp);
+ var editorSvc = new ResourceEditorService(resourceId, conn, launcher, siteExp, this);
ed.EditorService = editorSvc;
_openItems[resourceId] = ed;
ed.ViewContentClosing += (sender, e) =>
Modified: sandbox/maestro-3.0/Maestro.Base/UI/ResourcePropertiesDialog.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/ResourcePropertiesDialog.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Base/UI/ResourcePropertiesDialog.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -865,7 +865,7 @@
IFeatureSource fs = (IFeatureSource)m_connection.ResourceService.GetResource(m_resourceId);
bool failures = false;
- Envelope env = null;
+ IEnvelope env = null;
foreach (ClassDefinition scm in fs.Describe().Classes)
foreach (FeatureSetColumn col in scm.Columns)
@@ -874,7 +874,7 @@
try
- Envelope re = m_connection.FeatureService.GetSpatialExtent(fs.ResourceID, scm.Name, col.Name, true);
+ IEnvelope re = m_connection.FeatureService.GetSpatialExtent(fs.ResourceID, scm.Name, col.Name, true);
if (env == null)
env = re;
else
Modified: sandbox/maestro-3.0/Maestro.Editors/IEditorService.cs
--- sandbox/maestro-3.0/Maestro.Editors/IEditorService.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/IEditorService.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -200,11 +200,21 @@
/// </summary>
event EventHandler Saved;
+ /// <summary>
+ /// Synchronises changes in the in-memory resource back to the session repository. This is usually called
+ /// before validation of the edited resource begins.
+ /// </summary>
void SyncSessionCopy();
/// <summary>
/// Gets the MapGuide Server version
/// </summary>
Version SiteVersion { get; }
+ /// <summary>
+ /// Opens the specified resource
+ /// </summary>
+ /// <param name="resourceId"></param>
+ void OpenResource(string resourceId);
Modified: sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
--- sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-10-18 07:16:47 UTC (rev 5289)
@@ -31,10 +31,6 @@
<WarningLevel>4</WarningLevel>
</PropertyGroup>
<ItemGroup>
- <Reference Include="Aga.Controls, Version=1.6.1.0, Culture=neutral, PublicKeyToken=fcc90fbf924463a3, processorArchitecture=MSIL">
- <SpecificVersion>False</SpecificVersion>
- <HintPath>..\Thirdparty\TreeViewAdv\Aga.Controls\obj\Debug\Aga.Controls.dll</HintPath>
- </Reference>
<Reference Include="ICSharpCode.SharpZipLib, Version=0.85.4.369, Culture=neutral, PublicKeyToken=1b03e6acf1164f73, processorArchitecture=MSIL">
<HintPath>..\Thirdparty\SharpZipLib\ICSharpCode.SharpZipLib.dll</HintPath>
@@ -419,6 +415,12 @@
<Compile Include="LoadProcedure\ShpTransformationCtrl.Designer.cs">
<DependentUpon>ShpTransformationCtrl.cs</DependentUpon>
</Compile>
+ <Compile Include="MapDefinition\FiniteScaleListCtrl.cs">
+ <SubType>UserControl</SubType>
+ </Compile>
+ <Compile Include="MapDefinition\FiniteScaleListCtrl.Designer.cs">
+ <DependentUpon>FiniteScaleListCtrl.cs</DependentUpon>
+ </Compile>
<Compile Include="MapDefinition\GroupPropertiesCtrl.cs">
</Compile>
@@ -431,6 +433,12 @@
<Compile Include="MapDefinition\LayerPropertiesCtrl.Designer.cs">
<DependentUpon>LayerPropertiesCtrl.cs</DependentUpon>
</Compile>
+ <Compile Include="MapDefinition\ManualScaleEditor.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="MapDefinition\ManualScaleEditor.Designer.cs">
+ <DependentUpon>ManualScaleEditor.cs</DependentUpon>
+ </Compile>
<Compile Include="MapDefinition\MapDefinitionEditorCtrl.cs">
</Compile>
@@ -449,6 +457,14 @@
<Compile Include="MapDefinition\MapSettingsSectionCtrl.Designer.cs">
<DependentUpon>MapSettingsSectionCtrl.cs</DependentUpon>
</Compile>
+ <Compile Include="MapDefinition\MapTreeModels.cs" />
+ <Compile Include="MapDefinition\ScaleListGenerator.cs" />
+ <Compile Include="PrintLayout\LogoDialog.cs">
+ </Compile>
+ <Compile Include="PrintLayout\LogoDialog.Designer.cs">
+ <DependentUpon>LogoDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="PrintLayout\PrintCustomLogosSectionCtrl.cs">
</Compile>
@@ -473,6 +489,12 @@
<Compile Include="PrintLayout\PrintPagePropertiesSectionCtrl.Designer.cs">
<DependentUpon>PrintPagePropertiesSectionCtrl.cs</DependentUpon>
</Compile>
+ <Compile Include="PrintLayout\TextDialog.cs">
+ </Compile>
+ <Compile Include="PrintLayout\TextDialog.Designer.cs">
+ <DependentUpon>TextDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="Properties\AssemblyInfo.cs" />
<Compile Include="Properties\Resources.Designer.cs">
<AutoGen>True</AutoGen>
@@ -768,6 +790,9 @@
<SubType>Designer</SubType>
</EmbeddedResource>
+ <EmbeddedResource Include="MapDefinition\FiniteScaleListCtrl.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="MapDefinition\GroupPropertiesCtrl.resx">
<DependentUpon>GroupPropertiesCtrl.cs</DependentUpon>
@@ -776,6 +801,9 @@
</EmbeddedResource>
+ <EmbeddedResource Include="MapDefinition\ManualScaleEditor.resx">
<EmbeddedResource Include="MapDefinition\MapDefinitionEditorCtrl.resx">
<DependentUpon>MapDefinitionEditorCtrl.cs</DependentUpon>
@@ -788,6 +816,9 @@
</EmbeddedResource>
+ <EmbeddedResource Include="PrintLayout\LogoDialog.resx">
<EmbeddedResource Include="PrintLayout\PrintCustomLogosSectionCtrl.resx">
<DependentUpon>PrintCustomLogosSectionCtrl.cs</DependentUpon>
@@ -804,6 +835,9 @@
</EmbeddedResource>
+ <EmbeddedResource Include="PrintLayout\TextDialog.resx">
<EmbeddedResource Include="Properties\Resources.resx">
<Generator>ResXFileCodeGenerator</Generator>
<LastGenOutput>Resources.Designer.cs</LastGenOutput>
@@ -859,6 +893,10 @@
<Project>{80FA3158-8B5F-48D1-A393-0378AFE48A7E}</Project>
<Name>OSGeo.MapGuide.MaestroAPI</Name>
</ProjectReference>
+ <ProjectReference Include="..\Thirdparty\TreeViewAdv\Aga.Controls\Aga.Controls.csproj">
+ <Project>{E73BB233-D88B-44A7-A98F-D71EE158381D}</Project>
+ <Name>Aga.Controls</Name>
+ </ProjectReference>
</ItemGroup>
<ItemGroup>
<None Include="Resources\document--plus.png" />
@@ -1315,12 +1353,11 @@
<Content Include="FsEditorMap.xml">
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
</Content>
+ <None Include="Resources\map--arrow.png" />
</ItemGroup>
<ItemGroup>
<Folder Include="DrawingSource\Preview\" />
<Folder Include="LayerDefinition\Raster\" />
- <Folder Include="PrintLayout\Logos\" />
- <Folder Include="PrintLayout\Text\" />
<Folder Include="SymbolDefinition\" />
</ItemGroup>
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,289 @@
+namespace Maestro.Editors.MapDefinition
+ partial class FiniteScaleListCtrl
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Component Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.btnGenerateScales = new System.Windows.Forms.Button();
+ this.numScales = new System.Windows.Forms.NumericUpDown();
+ this.label5 = new System.Windows.Forms.Label();
+ this.cmbRounding = new System.Windows.Forms.ComboBox();
+ this.cmbMethod = new System.Windows.Forms.ComboBox();
+ this.label4 = new System.Windows.Forms.Label();
+ this.label3 = new System.Windows.Forms.Label();
+ this.numMaxScale = new System.Windows.Forms.NumericUpDown();
+ this.numMinScale = new System.Windows.Forms.NumericUpDown();
+ this.label2 = new System.Windows.Forms.Label();
+ this.label1 = new System.Windows.Forms.Label();
+ this.groupBox2 = new System.Windows.Forms.GroupBox();
+ this.lstDisplayScales = new System.Windows.Forms.ListBox();
+ this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+ this.btnEditScalesManually = new System.Windows.Forms.ToolStripButton();
+ this.btnRemoveScale = new System.Windows.Forms.ToolStripButton();
+ this.groupBox1.SuspendLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.numScales)).BeginInit();
+ ((System.ComponentModel.ISupportInitialize)(this.numMaxScale)).BeginInit();
+ ((System.ComponentModel.ISupportInitialize)(this.numMinScale)).BeginInit();
+ this.groupBox2.SuspendLayout();
+ this.toolStrip1.SuspendLayout();
+ this.SuspendLayout();
+ // groupBox1
+ this.groupBox1.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
+ this.groupBox1.Controls.Add(this.btnGenerateScales);
+ this.groupBox1.Controls.Add(this.numScales);
+ this.groupBox1.Controls.Add(this.label5);
+ this.groupBox1.Controls.Add(this.cmbRounding);
+ this.groupBox1.Controls.Add(this.cmbMethod);
+ this.groupBox1.Controls.Add(this.label4);
+ this.groupBox1.Controls.Add(this.label3);
+ this.groupBox1.Controls.Add(this.numMaxScale);
+ this.groupBox1.Controls.Add(this.numMinScale);
+ this.groupBox1.Controls.Add(this.label2);
+ this.groupBox1.Controls.Add(this.label1);
+ this.groupBox1.Location = new System.Drawing.Point(4, 4);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.Size = new System.Drawing.Size(378, 120);
+ this.groupBox1.TabIndex = 0;
+ this.groupBox1.TabStop = false;
+ this.groupBox1.Text = "Generate Scales";
+ // btnGenerateScales
+ this.btnGenerateScales.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnGenerateScales.Location = new System.Drawing.Point(282, 88);
+ this.btnGenerateScales.Name = "btnGenerateScales";
+ this.btnGenerateScales.Size = new System.Drawing.Size(75, 23);
+ this.btnGenerateScales.TabIndex = 10;
+ this.btnGenerateScales.Text = "Generate";
+ this.btnGenerateScales.UseVisualStyleBackColor = true;
+ this.btnGenerateScales.Click += new System.EventHandler(this.btnGenerateScales_Click);
+ // numScales
+ this.numScales.Location = new System.Drawing.Point(117, 86);
+ this.numScales.Maximum = new decimal(new int[] {
+ 2147483647,
+ 0,
+ 0,
+ 0});
+ this.numScales.Name = "numScales";
+ this.numScales.Size = new System.Drawing.Size(47, 20);
+ this.numScales.TabIndex = 9;
+ // label5
+ this.label5.AutoSize = true;
+ this.label5.Location = new System.Drawing.Point(15, 88);
+ this.label5.Name = "label5";
+ this.label5.Size = new System.Drawing.Size(91, 13);
+ this.label5.TabIndex = 8;
+ this.label5.Text = "Number of Scales";
+ // cmbRounding
+ this.cmbRounding.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.cmbRounding.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+ this.cmbRounding.FormattingEnabled = true;
+ this.cmbRounding.Location = new System.Drawing.Point(243, 57);
+ this.cmbRounding.Name = "cmbRounding";
+ this.cmbRounding.Size = new System.Drawing.Size(114, 21);
+ this.cmbRounding.TabIndex = 7;
+ // cmbMethod
+ this.cmbMethod.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+ this.cmbMethod.FormattingEnabled = true;
+ this.cmbMethod.Location = new System.Drawing.Point(75, 57);
+ this.cmbMethod.Name = "cmbMethod";
+ this.cmbMethod.Size = new System.Drawing.Size(89, 21);
+ this.cmbMethod.TabIndex = 6;
+ // label4
+ this.label4.AutoSize = true;
+ this.label4.Location = new System.Drawing.Point(180, 60);
+ this.label4.Name = "label4";
+ this.label4.Size = new System.Drawing.Size(53, 13);
+ this.label4.TabIndex = 5;
+ this.label4.Text = "Rounding";
+ // label3
+ this.label3.AutoSize = true;
+ this.label3.Location = new System.Drawing.Point(15, 60);
+ this.label3.Name = "label3";
+ this.label3.Size = new System.Drawing.Size(43, 13);
+ this.label3.TabIndex = 4;
+ this.label3.Text = "Method";
+ // numMaxScale
+ this.numMaxScale.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.numMaxScale.Location = new System.Drawing.Point(243, 30);
+ this.numMaxScale.Maximum = new decimal(new int[] {
+ 2147483647,
+ 0,
+ 0,
+ 0});
+ this.numMaxScale.Name = "numMaxScale";
+ this.numMaxScale.Size = new System.Drawing.Size(114, 20);
+ this.numMaxScale.TabIndex = 3;
+ // numMinScale
+ this.numMinScale.Location = new System.Drawing.Point(75, 30);
+ this.numMinScale.Maximum = new decimal(new int[] {
+ 2147483647,
+ 0,
+ 0,
+ 0});
+ this.numMinScale.Name = "numMinScale";
+ this.numMinScale.Size = new System.Drawing.Size(89, 20);
+ this.numMinScale.TabIndex = 2;
+ // label2
+ this.label2.AutoSize = true;
+ this.label2.Location = new System.Drawing.Point(180, 32);
+ this.label2.Name = "label2";
+ this.label2.Size = new System.Drawing.Size(57, 13);
+ this.label2.TabIndex = 1;
+ this.label2.Text = "Max Scale";
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(15, 32);
+ this.label1.Name = "label1";
+ this.label1.Size = new System.Drawing.Size(54, 13);
+ this.label1.TabIndex = 0;
+ this.label1.Text = "Min Scale";
+ // groupBox2
+ this.groupBox2.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
+ | System.Windows.Forms.AnchorStyles.Left)
+ this.groupBox2.Controls.Add(this.lstDisplayScales);
+ this.groupBox2.Controls.Add(this.toolStrip1);
+ this.groupBox2.Location = new System.Drawing.Point(4, 131);
+ this.groupBox2.Name = "groupBox2";
+ this.groupBox2.Size = new System.Drawing.Size(378, 137);
+ this.groupBox2.TabIndex = 1;
+ this.groupBox2.TabStop = false;
+ this.groupBox2.Text = "Display Scales";
+ // lstDisplayScales
+ this.lstDisplayScales.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.lstDisplayScales.FormattingEnabled = true;
+ this.lstDisplayScales.Location = new System.Drawing.Point(3, 41);
+ this.lstDisplayScales.Name = "lstDisplayScales";
+ this.lstDisplayScales.Size = new System.Drawing.Size(372, 82);
+ this.lstDisplayScales.TabIndex = 1;
+ this.lstDisplayScales.SelectedIndexChanged += new System.EventHandler(this.lstDisplayScales_SelectedIndexChanged);
+ // toolStrip1
+ this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.btnEditScalesManually,
+ this.btnRemoveScale});
+ this.toolStrip1.Location = new System.Drawing.Point(3, 16);
+ this.toolStrip1.Name = "toolStrip1";
+ this.toolStrip1.Size = new System.Drawing.Size(372, 25);
+ this.toolStrip1.TabIndex = 0;
+ this.toolStrip1.Text = "toolStrip1";
+ // btnEditScalesManually
+ this.btnEditScalesManually.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnEditScalesManually.Image = global::Maestro.Editors.Properties.Resources.document__pencil;
+ this.btnEditScalesManually.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnEditScalesManually.Name = "btnEditScalesManually";
+ this.btnEditScalesManually.Size = new System.Drawing.Size(23, 22);
+ this.btnEditScalesManually.ToolTipText = "Manually edit scales";
+ this.btnEditScalesManually.Click += new System.EventHandler(this.btnEditScalesManually_Click);
+ // btnRemoveScale
+ this.btnRemoveScale.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnRemoveScale.Enabled = false;
+ this.btnRemoveScale.Image = global::Maestro.Editors.Properties.Resources.cross_script;
+ this.btnRemoveScale.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnRemoveScale.Name = "btnRemoveScale";
+ this.btnRemoveScale.Size = new System.Drawing.Size(23, 22);
+ this.btnRemoveScale.ToolTipText = "Remove selected scale";
+ this.btnRemoveScale.Click += new System.EventHandler(this.btnRemoveScale_Click);
+ // FiniteScaleListCtrl
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Controls.Add(this.groupBox2);
+ this.Controls.Add(this.groupBox1);
+ this.Name = "FiniteScaleListCtrl";
+ this.Size = new System.Drawing.Size(385, 271);
+ this.groupBox1.ResumeLayout(false);
+ this.groupBox1.PerformLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.numScales)).EndInit();
+ ((System.ComponentModel.ISupportInitialize)(this.numMaxScale)).EndInit();
+ ((System.ComponentModel.ISupportInitialize)(this.numMinScale)).EndInit();
+ this.groupBox2.ResumeLayout(false);
+ this.groupBox2.PerformLayout();
+ this.toolStrip1.ResumeLayout(false);
+ this.toolStrip1.PerformLayout();
+ this.ResumeLayout(false);
+ #endregion
+ private System.Windows.Forms.GroupBox groupBox1;
+ private System.Windows.Forms.ComboBox cmbRounding;
+ private System.Windows.Forms.ComboBox cmbMethod;
+ private System.Windows.Forms.Label label4;
+ private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.NumericUpDown numMaxScale;
+ private System.Windows.Forms.NumericUpDown numMinScale;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.Button btnGenerateScales;
+ private System.Windows.Forms.NumericUpDown numScales;
+ private System.Windows.Forms.Label label5;
+ private System.Windows.Forms.GroupBox groupBox2;
+ private System.Windows.Forms.ListBox lstDisplayScales;
+ private System.Windows.Forms.ToolStrip toolStrip1;
+ private System.Windows.Forms.ToolStripButton btnEditScalesManually;
+ private System.Windows.Forms.ToolStripButton btnRemoveScale;
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,166 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Text;
+using System.Windows.Forms;
+using Maestro.Shared.UI;
+using OSGeo.MapGuide.ObjectModels.MapDefinition;
+ public partial class FiniteScaleListCtrl : UserControl
+ internal FiniteScaleListCtrl()
+ InitializeComponent();
+ cmbMethod.DataSource = Enum.GetValues(typeof(ScaleGenerationMethod));
+ cmbRounding.DataSource = Enum.GetValues(typeof(ScaleRoundingMethod));
+ cmbMethod.SelectedIndex = 0;
+ cmbRounding.SelectedIndex = 0;
+ _scales = new BindingList<double>();
+ lstDisplayScales.DataSource = _scales;
+ private BindingList<double> _scales;
+ private IMapDefinition _map;
+ public FiniteScaleListCtrl(IMapDefinition map)
+ : this()
+ _map = map;
+ //Init scale list
+ if (_map.BaseMap != null)
+ foreach (var scale in _map.BaseMap.FiniteDisplayScale)
+ _scales.Add(scale);
+ //Now wire change events
+ _scales.ListChanged += new ListChangedEventHandler(OnScaleListChanged);
+ void OnScaleListChanged(object sender, ListChangedEventArgs e)
+ switch (e.ListChangedType)
+ case ListChangedType.ItemAdded:
+ AddScaleToMap(_scales[e.NewIndex]);
+ break;
+ case ListChangedType.ItemDeleted:
+ RemoveScaleFromMap(_scales[e.NewIndex]);
+ break;
+ case ListChangedType.Reset:
+ ClearScales();
+ break;
+ private void ClearScales()
+ _map.InitBaseMap();
+ _map.BaseMap.RemoveAllScales();
+ private void RemoveScaleFromMap(double scale)
+ _map.BaseMap.RemoveFiniteDisplayScale(scale);
+ private void AddScaleToMap(double scale)
+ _map.BaseMap.AddFiniteDisplayScale(scale);
+ private void btnGenerateScales_Click(object sender, EventArgs e)
+ if (lstDisplayScales.Items.Count > 0)
+ if (MessageBox.Show(this, Properties.Resources.OverwriteDisplayScales, Properties.Resources.Confirm, MessageBoxButtons.YesNo, MessageBoxIcon.Question) == DialogResult.No)
+ return;
+ using (new WaitCursor(this))
+ var values = ScaleListGenerator.GenerateScales(
+ (double)numMinScale.Value,
+ (double)numMaxScale.Value,
+ (ScaleGenerationMethod)cmbMethod.SelectedItem,
+ (ScaleRoundingMethod)cmbRounding.SelectedItem,
+ (int)numScales.Value);
+ _scales.Clear();
+ foreach (var s in values)
+ _scales.Add(s);
+ private void btnRemoveScale_Click(object sender, EventArgs e)
+ if (lstDisplayScales.SelectedItem != null)
+ double scale = (double)lstDisplayScales.SelectedItem;
+ _scales.Remove(scale);
+ private void lstDisplayScales_SelectedIndexChanged(object sender, EventArgs e)
+ btnRemoveScale.Enabled = (lstDisplayScales.SelectedItem != null);
+ private void btnEditScalesManually_Click(object sender, EventArgs e)
+ using (var dlg = new ManualScaleEditor(_scales))
+ if (dlg.ShowDialog() == DialogResult.OK)
+ _scales.Clear();
+ foreach (double scale in dlg.Scales)
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.resx
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.resx 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,123 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -29,7 +29,6 @@
- this.chkSelectable = new System.Windows.Forms.CheckBox();
this.chkExpanded = new System.Windows.Forms.CheckBox();
this.chkLegendVisible = new System.Windows.Forms.CheckBox();
this.chkVisible = new System.Windows.Forms.CheckBox();
@@ -42,7 +41,6 @@
// groupBox1
- this.groupBox1.Controls.Add(this.chkSelectable);
this.groupBox1.Controls.Add(this.chkExpanded);
this.groupBox1.Controls.Add(this.chkLegendVisible);
this.groupBox1.Controls.Add(this.chkVisible);
@@ -58,20 +56,10 @@
this.groupBox1.Text = "Layer Group Properties";
- // chkSelectable
- this.chkSelectable.AutoSize = true;
- this.chkSelectable.Location = new System.Drawing.Point(18, 103);
- this.chkSelectable.Name = "chkSelectable";
- this.chkSelectable.Size = new System.Drawing.Size(240, 17);
- this.chkSelectable.TabIndex = 15;
- this.chkSelectable.Text = "Features on the layer are selectable (if visible)";
- this.chkSelectable.UseVisualStyleBackColor = true;
// chkExpanded
this.chkExpanded.AutoSize = true;
- this.chkExpanded.Location = new System.Drawing.Point(18, 150);
+ this.chkExpanded.Location = new System.Drawing.Point(18, 127);
this.chkExpanded.Name = "chkExpanded";
this.chkExpanded.Size = new System.Drawing.Size(228, 17);
this.chkExpanded.TabIndex = 14;
@@ -81,7 +69,7 @@
// chkLegendVisible
this.chkLegendVisible.AutoSize = true;
- this.chkLegendVisible.Location = new System.Drawing.Point(18, 126);
+ this.chkLegendVisible.Location = new System.Drawing.Point(18, 103);
this.chkLegendVisible.Name = "chkLegendVisible";
this.chkLegendVisible.Size = new System.Drawing.Size(183, 17);
this.chkLegendVisible.TabIndex = 13;
@@ -150,7 +138,6 @@
#endregion
- private System.Windows.Forms.CheckBox chkSelectable;
private System.Windows.Forms.CheckBox chkExpanded;
private System.Windows.Forms.CheckBox chkLegendVisible;
private System.Windows.Forms.CheckBox chkVisible;
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -1,4 +1,23 @@
-using System;
+#endregion
+using System;
@@ -19,34 +38,38 @@
public event EventHandler GroupChanged;
- public GroupPropertiesCtrl(MapLayerGroupType group)
+ public GroupPropertiesCtrl(IMapLayerGroup group)
: this()
group.PropertyChanged += new PropertyChangedEventHandler(OnGroupChanged);
- //txtName.DataBindings.Add("Text", group, "Name");
- //txtLegendLabel.DataBindings.Add("Text", group, "LegendLabel");
TextBoxBinder.BindText(txtName, group, "Name");
TextBoxBinder.BindText(txtLegendLabel, group, "LegendLabel");
- //chkExpanded.DataBindings.Add("Checked", group, "ExpandInLegend");
- //chkLegendVisible.DataBindings.Add("Checked", group, "ShowInLegend");
- //chkVisible.DataBindings.Add("Checked", group, "Visible");
CheckBoxBinder.BindChecked(chkExpanded, group, "ExpandInLegend");
CheckBoxBinder.BindChecked(chkLegendVisible, group, "ShowInLegend");
CheckBoxBinder.BindChecked(chkVisible, group, "Visible");
+ public GroupPropertiesCtrl(IBaseMapGroup group)
+ : this()
+ group.PropertyChanged += new PropertyChangedEventHandler(OnGroupChanged);
+ TextBoxBinder.BindText(txtName, group, "Name");
+ TextBoxBinder.BindText(txtLegendLabel, group, "LegendLabel");
+ CheckBoxBinder.BindChecked(chkExpanded, group, "ExpandInLegend");
+ CheckBoxBinder.BindChecked(chkLegendVisible, group, "ShowInLegend");
+ //CheckBoxBinder.BindChecked(chkVisible, group, "Visible");
+ chkVisible.Visible = false;
void OnGroupChanged(object sender, PropertyChangedEventArgs e)
var handler = this.GroupChanged;
if (handler != null)
handler(this, EventArgs.Empty);
- //void ForceUpdate(object sender, EventArgs e)
- // ((Control)sender).DataBindings[0].WriteValue();
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.Designer.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -29,6 +29,9 @@
+ this.btnBrowse = new System.Windows.Forms.Button();
+ this.txtResourceId = new System.Windows.Forms.TextBox();
@@ -42,6 +45,9 @@
// groupBox1
+ this.groupBox1.Controls.Add(this.btnBrowse);
+ this.groupBox1.Controls.Add(this.txtResourceId);
@@ -53,15 +59,45 @@
this.groupBox1.Dock = System.Windows.Forms.DockStyle.Fill;
this.groupBox1.Location = new System.Drawing.Point(0, 0);
- this.groupBox1.Size = new System.Drawing.Size(417, 188);
+ this.groupBox1.Size = new System.Drawing.Size(417, 217);
this.groupBox1.Text = "Layer Properties";
+ // btnBrowse
+ this.btnBrowse.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnBrowse.Location = new System.Drawing.Point(371, 17);
+ this.btnBrowse.Name = "btnBrowse";
+ this.btnBrowse.Size = new System.Drawing.Size(26, 23);
+ this.btnBrowse.TabIndex = 10;
+ this.btnBrowse.Text = "...";
+ this.btnBrowse.UseVisualStyleBackColor = true;
+ this.btnBrowse.Click += new System.EventHandler(this.btnBrowse_Click);
+ // txtResourceId
+ this.txtResourceId.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtResourceId.Location = new System.Drawing.Point(112, 19);
+ this.txtResourceId.Name = "txtResourceId";
+ this.txtResourceId.ReadOnly = true;
+ this.txtResourceId.Size = new System.Drawing.Size(253, 20);
+ this.txtResourceId.TabIndex = 9;
+ // label3
+ this.label3.Location = new System.Drawing.Point(20, 22);
+ this.label3.Size = new System.Drawing.Size(80, 13);
+ this.label3.TabIndex = 8;
+ this.label3.Text = "Layer Definition";
// chkSelectable
- this.chkSelectable.Location = new System.Drawing.Point(21, 106);
+ this.chkSelectable.Location = new System.Drawing.Point(23, 129);
this.chkSelectable.TabIndex = 7;
@@ -71,7 +107,7 @@
// chkExpanded
- this.chkExpanded.Location = new System.Drawing.Point(21, 153);
+ this.chkExpanded.Location = new System.Drawing.Point(23, 176);
this.chkExpanded.TabIndex = 6;
@@ -81,7 +117,7 @@
// chkLegendVisible
- this.chkLegendVisible.Location = new System.Drawing.Point(21, 129);
+ this.chkLegendVisible.Location = new System.Drawing.Point(23, 152);
this.chkLegendVisible.TabIndex = 5;
@@ -91,7 +127,7 @@
// chkVisible
this.chkVisible.AutoSize = true;
- this.chkVisible.Location = new System.Drawing.Point(21, 83);
+ this.chkVisible.Location = new System.Drawing.Point(23, 106);
this.chkVisible.Name = "chkVisible";
this.chkVisible.Size = new System.Drawing.Size(141, 17);
this.chkVisible.TabIndex = 4;
@@ -102,7 +138,7 @@
this.txtLegendLabel.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
- this.txtLegendLabel.Location = new System.Drawing.Point(110, 48);
+ this.txtLegendLabel.Location = new System.Drawing.Point(112, 71);
this.txtLegendLabel.Name = "txtLegendLabel";
this.txtLegendLabel.Size = new System.Drawing.Size(285, 20);
this.txtLegendLabel.TabIndex = 3;
@@ -111,7 +147,7 @@
this.txtName.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
- this.txtName.Location = new System.Drawing.Point(110, 22);
+ this.txtName.Location = new System.Drawing.Point(112, 45);
this.txtName.Name = "txtName";
this.txtName.Size = new System.Drawing.Size(285, 20);
this.txtName.TabIndex = 2;
@@ -119,7 +155,7 @@
// label2
- this.label2.Location = new System.Drawing.Point(18, 51);
+ this.label2.Location = new System.Drawing.Point(20, 74);
this.label2.Size = new System.Drawing.Size(72, 13);
@@ -128,7 +164,7 @@
// label1
- this.label1.Location = new System.Drawing.Point(18, 25);
+ this.label1.Location = new System.Drawing.Point(20, 48);
this.label1.Size = new System.Drawing.Size(35, 13);
@@ -140,7 +176,7 @@
this.Name = "LayerPropertiesCtrl";
- this.Size = new System.Drawing.Size(417, 188);
+ this.Size = new System.Drawing.Size(417, 217);
@@ -158,5 +194,8 @@
+ private System.Windows.Forms.Button btnBrowse;
+ private System.Windows.Forms.TextBox txtResourceId;
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -1,4 +1,23 @@
-using System;
+#endregion
+using System;
@@ -7,6 +26,9 @@
+using Maestro.Editors.Generic;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.MaestroAPI;
@@ -18,18 +40,14 @@
public event EventHandler LayerChanged;
+ private IResourceService _resSvc;
- public LayerPropertiesCtrl(MapLayerType layer) : this()
+ public LayerPropertiesCtrl(IMapLayer layer, IResourceService resSvc) : this()
- layer.PropertyChanged += new PropertyChangedEventHandler(OnLayerChanged);
- //txtName.DataBindings.Add("Text", layer, "Name");
- //txtLegendLabel.DataBindings.Add("Text", layer, "LegendLabel");
+ layer.PropertyChanged += new PropertyChangedEventHandler(OnLayerChanged);
+ _resSvc = resSvc;
- //chkExpanded.DataBindings.Add("Checked", layer, "ExpandInLegend");
- //chkLegendVisible.DataBindings.Add("Checked", layer, "ShowInLegend");
- //chkVisible.DataBindings.Add("Checked", layer, "Visible");
- //chkSelectable.DataBindings.Add("Checked", layer, "Selectable");
+ TextBoxBinder.BindText(txtResourceId, layer, "ResourceId");
TextBoxBinder.BindText(txtName, layer, "Name");
TextBoxBinder.BindText(txtLegendLabel, layer, "LegendLabel");
@@ -39,6 +57,23 @@
CheckBoxBinder.BindChecked(chkSelectable, layer, "Selectable");
+ public LayerPropertiesCtrl(IBaseMapLayer layer, IResourceService resSvc)
+ : this()
+ _resSvc = resSvc;
+ TextBoxBinder.BindText(txtName, layer, "Name");
+ TextBoxBinder.BindText(txtLegendLabel, layer, "LegendLabel");
+ CheckBoxBinder.BindChecked(chkExpanded, layer, "ExpandInLegend");
+ CheckBoxBinder.BindChecked(chkLegendVisible, layer, "ShowInLegend");
+ //CheckBoxBinder.BindChecked(chkVisible, layer, "Visible");
+ CheckBoxBinder.BindChecked(chkSelectable, layer, "Selectable");
void OnLayerChanged(object sender, PropertyChangedEventArgs e)
var handler = this.LayerChanged;
@@ -46,9 +81,15 @@
+ private void btnBrowse_Click(object sender, EventArgs e)
+ using (var picker = new ResourcePicker(_resSvc, ResourceTypes.LayerDefinition, ResourcePickerMode.OpenResource))
+ if (picker.ShowDialog() == DialogResult.OK)
+ txtResourceId.Text = picker.ResourceID;
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,95 @@
+ partial class ManualScaleEditor
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// </summary>
+ this.txtScales = new System.Windows.Forms.TextBox();
+ this.btnSave = new System.Windows.Forms.Button();
+ this.btnCancel = new System.Windows.Forms.Button();
+ // txtScales
+ this.txtScales.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
+ this.txtScales.Location = new System.Drawing.Point(13, 13);
+ this.txtScales.Multiline = true;
+ this.txtScales.Name = "txtScales";
+ this.txtScales.Size = new System.Drawing.Size(267, 219);
+ this.txtScales.TabIndex = 0;
+ // btnSave
+ this.btnSave.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnSave.Location = new System.Drawing.Point(123, 238);
+ this.btnSave.Name = "btnSave";
+ this.btnSave.Size = new System.Drawing.Size(75, 23);
+ this.btnSave.TabIndex = 1;
+ this.btnSave.Text = "Save";
+ this.btnSave.UseVisualStyleBackColor = true;
+ this.btnSave.Click += new System.EventHandler(this.btnSave_Click);
+ // btnCancel
+ this.btnCancel.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ this.btnCancel.Location = new System.Drawing.Point(205, 238);
+ this.btnCancel.Name = "btnCancel";
+ this.btnCancel.Size = new System.Drawing.Size(75, 23);
+ this.btnCancel.TabIndex = 2;
+ this.btnCancel.Text = "Cancel";
+ this.btnCancel.UseVisualStyleBackColor = true;
+ this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+ // ManualScaleEditor
+ this.AcceptButton = this.btnSave;
+ this.CancelButton = this.btnCancel;
+ this.ClientSize = new System.Drawing.Size(292, 273);
+ this.ControlBox = false;
+ this.Controls.Add(this.btnCancel);
+ this.Controls.Add(this.btnSave);
+ this.Controls.Add(this.txtScales);
+ this.Name = "ManualScaleEditor";
+ this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
+ this.Text = "Edit Scales Manually";
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.TextBox txtScales;
+ private System.Windows.Forms.Button btnSave;
+ private System.Windows.Forms.Button btnCancel;
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,72 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+ public partial class ManualScaleEditor : Form
+ private ManualScaleEditor()
+ public ManualScaleEditor(IEnumerable<double> scales)
+ : this()
+ List<string> values = new List<string>();
+ foreach (var d in scales)
+ values.Add(d.ToString(System.Threading.Thread.CurrentThread.CurrentUICulture));
+ txtScales.Text = string.Join(Environment.NewLine, values.ToArray());
+ public double[] Scales
+ get
+ List<double> scales = new List<double>();
+ string[] values = txtScales.Lines;
+ foreach (var str in values)
+ scales.Add(double.Parse(str, System.Threading.Thread.CurrentThread.CurrentUICulture));
+ return scales.ToArray();
+ private void btnCancel_Click(object sender, EventArgs e)
+ this.DialogResult = DialogResult.Cancel;
+ private void btnSave_Click(object sender, EventArgs e)
+ this.DialogResult = DialogResult.OK;
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.resx
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.resx 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.Designer.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -28,41 +28,41 @@
/// </summary>
- this.mapSettingsSectionCtrl1 = new Maestro.Editors.MapDefinition.MapSettingsSectionCtrl();
- this.mapLayersSectionCtrl1 = new Maestro.Editors.MapDefinition.MapLayersSectionCtrl();
+ this.mapSettingsCtrl = new Maestro.Editors.MapDefinition.MapSettingsSectionCtrl();
+ this.mapLayersCtrl = new Maestro.Editors.MapDefinition.MapLayersSectionCtrl();
// mapSettingsSectionCtrl1
- this.mapSettingsSectionCtrl1.ContentBackgroundColor = System.Drawing.SystemColors.Control;
- this.mapSettingsSectionCtrl1.Dock = System.Windows.Forms.DockStyle.Top;
- this.mapSettingsSectionCtrl1.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
- this.mapSettingsSectionCtrl1.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
- this.mapSettingsSectionCtrl1.HeaderText = "Map Settings";
- this.mapSettingsSectionCtrl1.Location = new System.Drawing.Point(0, 0);
- this.mapSettingsSectionCtrl1.Name = "mapSettingsSectionCtrl1";
- this.mapSettingsSectionCtrl1.Size = new System.Drawing.Size(604, 206);
- this.mapSettingsSectionCtrl1.TabIndex = 0;
+ this.mapSettingsCtrl.ContentBackgroundColor = System.Drawing.SystemColors.Control;
+ this.mapSettingsCtrl.Dock = System.Windows.Forms.DockStyle.Top;
+ this.mapSettingsCtrl.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
+ this.mapSettingsCtrl.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.mapSettingsCtrl.HeaderText = "Map Settings";
+ this.mapSettingsCtrl.Location = new System.Drawing.Point(0, 0);
+ this.mapSettingsCtrl.Name = "mapSettingsSectionCtrl1";
+ this.mapSettingsCtrl.Size = new System.Drawing.Size(604, 206);
+ this.mapSettingsCtrl.TabIndex = 0;
// mapLayersSectionCtrl1
- this.mapLayersSectionCtrl1.ContentBackgroundColor = System.Drawing.SystemColors.Control;
- this.mapLayersSectionCtrl1.Dock = System.Windows.Forms.DockStyle.Top;
- this.mapLayersSectionCtrl1.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
- this.mapLayersSectionCtrl1.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
- this.mapLayersSectionCtrl1.HeaderText = "Layers";
- this.mapLayersSectionCtrl1.Location = new System.Drawing.Point(0, 206);
- this.mapLayersSectionCtrl1.Name = "mapLayersSectionCtrl1";
- this.mapLayersSectionCtrl1.Size = new System.Drawing.Size(604, 319);
- this.mapLayersSectionCtrl1.TabIndex = 1;
+ this.mapLayersCtrl.ContentBackgroundColor = System.Drawing.SystemColors.Control;
+ this.mapLayersCtrl.Dock = System.Windows.Forms.DockStyle.Top;
+ this.mapLayersCtrl.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
+ this.mapLayersCtrl.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.mapLayersCtrl.HeaderText = "Layers";
+ this.mapLayersCtrl.Location = new System.Drawing.Point(0, 206);
+ this.mapLayersCtrl.Name = "mapLayersSectionCtrl1";
+ this.mapLayersCtrl.Size = new System.Drawing.Size(604, 319);
+ this.mapLayersCtrl.TabIndex = 1;
// MapDefinitionEditorCtrl
this.AutoScroll = true;
- this.Controls.Add(this.mapLayersSectionCtrl1);
- this.Controls.Add(this.mapSettingsSectionCtrl1);
+ this.Controls.Add(this.mapLayersCtrl);
+ this.Controls.Add(this.mapSettingsCtrl);
this.Name = "MapDefinitionEditorCtrl";
this.Size = new System.Drawing.Size(604, 500);
@@ -71,7 +71,7 @@
#endregion
- private MapSettingsSectionCtrl mapSettingsSectionCtrl1;
- private MapLayersSectionCtrl mapLayersSectionCtrl1;
+ private MapSettingsSectionCtrl mapSettingsCtrl;
+ private MapLayersSectionCtrl mapLayersCtrl;
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -35,13 +35,22 @@
private OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition _map;
+ private IEditorService _edSvc;
public override void Bind(IEditorService service)
- _map = service.GetEditedResource() as OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition;
+ _edSvc = service;
+ _map = _edSvc.GetEditedResource() as OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition;
- mapSettingsSectionCtrl1.Bind(service);
- mapLayersSectionCtrl1.Bind(service);
+ mapSettingsCtrl.Bind(service);
+ mapLayersCtrl.Bind(service);
+ mapLayersCtrl.RequestLayerOpen += new OpenLayerEventHandler(OnRequestLayerOpen);
+ void OnRequestLayerOpen(object sender, string layerResourceId)
+ _edSvc.OpenResource(layerResourceId);
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -28,39 +28,45 @@
/// </summary>
- System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(MapLayersSectionCtrl));
this.tabControl1 = new System.Windows.Forms.TabControl();
this.TAB_GROUP = new System.Windows.Forms.TabPage();
this.trvLayersGroup = new Aga.Controls.Tree.TreeViewAdv();
this.NODE_GROUP_ICON = new Aga.Controls.Tree.NodeControls.NodeIcon();
this.NODE_GROUP_TEXT = new Aga.Controls.Tree.NodeControls.NodeTextBox();
- this.toolStripButton1 = new System.Windows.Forms.ToolStripButton();
- this.toolStripButton2 = new System.Windows.Forms.ToolStripButton();
+ this.btnAddGroup = new System.Windows.Forms.ToolStripButton();
+ this.btnRemoveGroup = new System.Windows.Forms.ToolStripButton();
this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripButton3 = new System.Windows.Forms.ToolStripButton();
- this.toolStripButton4 = new System.Windows.Forms.ToolStripButton();
- this.toolStripSeparator2 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripButton5 = new System.Windows.Forms.ToolStripButton();
- this.toolStripButton6 = new System.Windows.Forms.ToolStripButton();
+ this.btnGRPAddLayer = new System.Windows.Forms.ToolStripButton();
+ this.btnGRPRemoveLayer = new System.Windows.Forms.ToolStripButton();
this.toolStripSeparator3 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripButton7 = new System.Windows.Forms.ToolStripButton();
- this.toolStripButton8 = new System.Windows.Forms.ToolStripButton();
- this.toolStripSeparator4 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripButton21 = new System.Windows.Forms.ToolStripButton();
+ this.btnConvertLayerGroupToBaseGroup = new System.Windows.Forms.ToolStripButton();
this.TAB_DRAWING_ORDER = new System.Windows.Forms.TabPage();
this.trvLayerDrawingOrder = new Aga.Controls.Tree.TreeViewAdv();
this.NODE_DRAW_ICON = new Aga.Controls.Tree.NodeControls.NodeIcon();
this.NODE_DRAW_TEXT = new Aga.Controls.Tree.NodeControls.NodeTextBox();
this.toolStrip2 = new System.Windows.Forms.ToolStrip();
- this.toolStripButton9 = new System.Windows.Forms.ToolStripButton();
- this.toolStripButton10 = new System.Windows.Forms.ToolStripButton();
+ this.btnDLAddLayer = new System.Windows.Forms.ToolStripButton();
+ this.btnDLRemoveLayer = new System.Windows.Forms.ToolStripButton();
this.toolStripSeparator5 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripButton11 = new System.Windows.Forms.ToolStripButton();
- this.toolStripButton12 = new System.Windows.Forms.ToolStripButton();
+ this.btnDLMoveLayerUp = new System.Windows.Forms.ToolStripButton();
+ this.btnDLMoveLayerDown = new System.Windows.Forms.ToolStripButton();
this.toolStripSeparator6 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripButton13 = new System.Windows.Forms.ToolStripButton();
- this.toolStripButton14 = new System.Windows.Forms.ToolStripButton();
+ this.btnDLMoveLayerTop = new System.Windows.Forms.ToolStripButton();
+ this.btnDLMoveLayerBottom = new System.Windows.Forms.ToolStripButton();
+ this.TAB_BASE_LAYERS = new System.Windows.Forms.TabPage();
+ this.trvBaseLayers = new Aga.Controls.Tree.TreeViewAdv();
+ this.nodeIcon1 = new Aga.Controls.Tree.NodeControls.NodeIcon();
+ this.nodeTextBox1 = new Aga.Controls.Tree.NodeControls.NodeTextBox();
+ this.toolStrip3 = new System.Windows.Forms.ToolStrip();
+ this.btnNewBaseLayerGroup = new System.Windows.Forms.ToolStripButton();
+ this.btnRemoveBaseLayerGroup = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator2 = new System.Windows.Forms.ToolStripSeparator();
+ this.btnAddBaseLayer = new System.Windows.Forms.ToolStripButton();
+ this.btnRemoveBaseLayer = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator4 = new System.Windows.Forms.ToolStripSeparator();
+ this.btnMoveBaseLayerUp = new System.Windows.Forms.ToolStripButton();
+ this.btnMoveBaseLayerDown = new System.Windows.Forms.ToolStripButton();
this.splitter1 = new System.Windows.Forms.Splitter();
this.propertiesPanel = new System.Windows.Forms.Panel();
this.contentPanel.SuspendLayout();
@@ -69,6 +75,8 @@
this.TAB_DRAWING_ORDER.SuspendLayout();
this.toolStrip2.SuspendLayout();
+ this.TAB_BASE_LAYERS.SuspendLayout();
+ this.toolStrip3.SuspendLayout();
// contentPanel
@@ -82,6 +90,7 @@
this.tabControl1.Controls.Add(this.TAB_GROUP);
this.tabControl1.Controls.Add(this.TAB_DRAWING_ORDER);
+ this.tabControl1.Controls.Add(this.TAB_BASE_LAYERS);
this.tabControl1.Dock = System.Windows.Forms.DockStyle.Left;
this.tabControl1.Location = new System.Drawing.Point(0, 0);
this.tabControl1.Name = "tabControl1";
@@ -138,126 +147,79 @@
// toolStrip1
- this.toolStripButton1,
- this.toolStripButton2,
+ this.btnAddGroup,
+ this.btnRemoveGroup,
this.toolStripSeparator1,
- this.toolStripButton3,
- this.toolStripButton4,
- this.toolStripSeparator2,
- this.toolStripButton5,
- this.toolStripButton6,
+ this.btnGRPAddLayer,
+ this.btnGRPRemoveLayer,
this.toolStripSeparator3,
- this.toolStripButton7,
- this.toolStripButton8,
- this.toolStripSeparator4,
- this.toolStripButton21});
+ this.btnConvertLayerGroupToBaseGroup});
this.toolStrip1.Location = new System.Drawing.Point(3, 3);
this.toolStrip1.Size = new System.Drawing.Size(312, 25);
- // toolStripButton1
+ // btnAddGroup
- this.toolStripButton1.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton1.Image = global::Maestro.Editors.Properties.Resources.folder__plus;
- this.toolStripButton1.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton1.Name = "toolStripButton1";
- this.toolStripButton1.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton1.Text = "toolStripButton1";
+ this.btnAddGroup.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnAddGroup.Image = global::Maestro.Editors.Properties.Resources.folder__plus;
+ this.btnAddGroup.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnAddGroup.Name = "btnAddGroup";
+ this.btnAddGroup.Size = new System.Drawing.Size(23, 22);
+ this.btnAddGroup.ToolTipText = "Add a new group";
+ this.btnAddGroup.Click += new System.EventHandler(this.btnAddGroup_Click);
- // toolStripButton2
+ // btnRemoveGroup
- this.toolStripButton2.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton2.Image = global::Maestro.Editors.Properties.Resources.folder__minus;
- this.toolStripButton2.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton2.Name = "toolStripButton2";
- this.toolStripButton2.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton2.Text = "toolStripButton2";
+ this.btnRemoveGroup.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnRemoveGroup.Image = global::Maestro.Editors.Properties.Resources.folder__minus;
+ this.btnRemoveGroup.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnRemoveGroup.Name = "btnRemoveGroup";
+ this.btnRemoveGroup.Size = new System.Drawing.Size(23, 22);
+ this.btnRemoveGroup.ToolTipText = "Remove selected group";
+ this.btnRemoveGroup.Click += new System.EventHandler(this.btnRemoveGroup_Click);
// toolStripSeparator1
this.toolStripSeparator1.Name = "toolStripSeparator1";
this.toolStripSeparator1.Size = new System.Drawing.Size(6, 25);
- // toolStripButton3
+ // btnGRPAddLayer
- this.toolStripButton3.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton3.Image = global::Maestro.Editors.Properties.Resources.layer__plus;
- this.toolStripButton3.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton3.Name = "toolStripButton3";
- this.toolStripButton3.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton3.Text = "toolStripButton3";
+ this.btnGRPAddLayer.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnGRPAddLayer.Image = global::Maestro.Editors.Properties.Resources.layer__plus;
+ this.btnGRPAddLayer.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnGRPAddLayer.Name = "btnGRPAddLayer";
+ this.btnGRPAddLayer.Size = new System.Drawing.Size(23, 22);
+ this.btnGRPAddLayer.ToolTipText = "Add a new layer";
+ this.btnGRPAddLayer.Click += new System.EventHandler(this.btnGRPAddLayer_Click);
- // toolStripButton4
+ // btnGRPRemoveLayer
- this.toolStripButton4.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton4.Image = global::Maestro.Editors.Properties.Resources.layer__minus;
- this.toolStripButton4.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton4.Name = "toolStripButton4";
- this.toolStripButton4.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton4.Text = "toolStripButton4";
+ this.btnGRPRemoveLayer.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnGRPRemoveLayer.Image = global::Maestro.Editors.Properties.Resources.layer__minus;
+ this.btnGRPRemoveLayer.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnGRPRemoveLayer.Name = "btnGRPRemoveLayer";
+ this.btnGRPRemoveLayer.Size = new System.Drawing.Size(23, 22);
+ this.btnGRPRemoveLayer.ToolTipText = "Remove selected layer";
+ this.btnGRPRemoveLayer.Click += new System.EventHandler(this.btnGRPRemoveLayer_Click);
- // toolStripSeparator2
- this.toolStripSeparator2.Name = "toolStripSeparator2";
- this.toolStripSeparator2.Size = new System.Drawing.Size(6, 25);
- // toolStripButton5
- this.toolStripButton5.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton5.Image = global::Maestro.Editors.Properties.Resources.arrow_090;
- this.toolStripButton5.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton5.Name = "toolStripButton5";
- this.toolStripButton5.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton5.Text = "toolStripButton5";
- // toolStripButton6
- this.toolStripButton6.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton6.Image = global::Maestro.Editors.Properties.Resources.arrow_270;
- this.toolStripButton6.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton6.Name = "toolStripButton6";
- this.toolStripButton6.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton6.Text = "toolStripButton6";
// toolStripSeparator3
this.toolStripSeparator3.Name = "toolStripSeparator3";
this.toolStripSeparator3.Size = new System.Drawing.Size(6, 25);
- // toolStripButton7
+ // btnConvertLayerGroupToBaseGroup
- this.toolStripButton7.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton7.Image = global::Maestro.Editors.Properties.Resources.layers_stack_arrange;
- this.toolStripButton7.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton7.Name = "toolStripButton7";
- this.toolStripButton7.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton7.Text = "toolStripButton7";
+ this.btnConvertLayerGroupToBaseGroup.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnConvertLayerGroupToBaseGroup.Image = global::Maestro.Editors.Properties.Resources.map__arrow;
+ this.btnConvertLayerGroupToBaseGroup.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnConvertLayerGroupToBaseGroup.Name = "btnConvertLayerGroupToBaseGroup";
+ this.btnConvertLayerGroupToBaseGroup.Size = new System.Drawing.Size(23, 22);
+ this.btnConvertLayerGroupToBaseGroup.ToolTipText = "Convert selected group to a base layer group";
+ this.btnConvertLayerGroupToBaseGroup.Click += new System.EventHandler(this.btnConvertLayerGroupToBaseGroup_Click);
- // toolStripButton8
- this.toolStripButton8.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton8.Image = global::Maestro.Editors.Properties.Resources.layers_stack_arrange_back;
- this.toolStripButton8.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton8.Name = "toolStripButton8";
- this.toolStripButton8.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton8.Text = "toolStripButton8";
- // toolStripSeparator4
- this.toolStripSeparator4.Name = "toolStripSeparator4";
- this.toolStripSeparator4.Size = new System.Drawing.Size(6, 25);
- // toolStripButton21
- this.toolStripButton21.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton21.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton21.Image")));
- this.toolStripButton21.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton21.Name = "toolStripButton21";
- this.toolStripButton21.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton21.Text = "toolStripButton21";
// TAB_DRAWING_ORDER
this.TAB_DRAWING_ORDER.Controls.Add(this.trvLayerDrawingOrder);
@@ -307,84 +269,223 @@
// toolStrip2
this.toolStrip2.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
- this.toolStripButton9,
- this.toolStripButton10,
+ this.btnDLAddLayer,
+ this.btnDLRemoveLayer,
this.toolStripSeparator5,
- this.toolStripButton11,
- this.toolStripButton12,
+ this.btnDLMoveLayerUp,
+ this.btnDLMoveLayerDown,
this.toolStripSeparator6,
- this.toolStripButton13,
- this.toolStripButton14});
+ this.btnDLMoveLayerTop,
+ this.btnDLMoveLayerBottom});
this.toolStrip2.Location = new System.Drawing.Point(3, 3);
this.toolStrip2.Name = "toolStrip2";
this.toolStrip2.Size = new System.Drawing.Size(312, 25);
this.toolStrip2.TabIndex = 0;
this.toolStrip2.Text = "toolStrip2";
- // toolStripButton9
+ // btnDLAddLayer
- this.toolStripButton9.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton9.Image = global::Maestro.Editors.Properties.Resources.layer__plus;
- this.toolStripButton9.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton9.Name = "toolStripButton9";
- this.toolStripButton9.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton9.Text = "toolStripButton3";
+ this.btnDLAddLayer.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnDLAddLayer.Image = global::Maestro.Editors.Properties.Resources.layer__plus;
+ this.btnDLAddLayer.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnDLAddLayer.Name = "btnDLAddLayer";
+ this.btnDLAddLayer.Size = new System.Drawing.Size(23, 22);
+ this.btnDLAddLayer.ToolTipText = "Add new layer";
+ this.btnDLAddLayer.Click += new System.EventHandler(this.btnDLAddLayer_Click);
- // toolStripButton10
+ // btnDLRemoveLayer
- this.toolStripButton10.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton10.Image = global::Maestro.Editors.Properties.Resources.layer__minus;
- this.toolStripButton10.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton10.Name = "toolStripButton10";
- this.toolStripButton10.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton10.Text = "toolStripButton4";
+ this.btnDLRemoveLayer.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnDLRemoveLayer.Image = global::Maestro.Editors.Properties.Resources.layer__minus;
+ this.btnDLRemoveLayer.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnDLRemoveLayer.Name = "btnDLRemoveLayer";
+ this.btnDLRemoveLayer.Size = new System.Drawing.Size(23, 22);
+ this.btnDLRemoveLayer.ToolTipText = "Remove selected layer";
+ this.btnDLRemoveLayer.Click += new System.EventHandler(this.btnDLRemoveLayer_Click);
// toolStripSeparator5
this.toolStripSeparator5.Name = "toolStripSeparator5";
this.toolStripSeparator5.Size = new System.Drawing.Size(6, 25);
- // toolStripButton11
+ // btnDLMoveLayerUp
- this.toolStripButton11.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton11.Image = global::Maestro.Editors.Properties.Resources.arrow_090;
- this.toolStripButton11.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton11.Name = "toolStripButton11";
- this.toolStripButton11.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton11.Text = "toolStripButton5";
+ this.btnDLMoveLayerUp.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnDLMoveLayerUp.Image = global::Maestro.Editors.Properties.Resources.arrow_090;
+ this.btnDLMoveLayerUp.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnDLMoveLayerUp.Name = "btnDLMoveLayerUp";
+ this.btnDLMoveLayerUp.Size = new System.Drawing.Size(23, 22);
+ this.btnDLMoveLayerUp.ToolTipText = "Move selected layer up";
+ this.btnDLMoveLayerUp.Click += new System.EventHandler(this.btnDLMoveLayerUp_Click);
- // toolStripButton12
+ // btnDLMoveLayerDown
- this.toolStripButton12.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton12.Image = global::Maestro.Editors.Properties.Resources.arrow_270;
- this.toolStripButton12.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton12.Name = "toolStripButton12";
- this.toolStripButton12.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton12.Text = "toolStripButton6";
+ this.btnDLMoveLayerDown.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnDLMoveLayerDown.Image = global::Maestro.Editors.Properties.Resources.arrow_270;
+ this.btnDLMoveLayerDown.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnDLMoveLayerDown.Name = "btnDLMoveLayerDown";
+ this.btnDLMoveLayerDown.Size = new System.Drawing.Size(23, 22);
+ this.btnDLMoveLayerDown.ToolTipText = "Move selected layer down";
+ this.btnDLMoveLayerDown.Click += new System.EventHandler(this.btnDLMoveLayerDown_Click);
// toolStripSeparator6
this.toolStripSeparator6.Name = "toolStripSeparator6";
this.toolStripSeparator6.Size = new System.Drawing.Size(6, 25);
- // toolStripButton13
+ // btnDLMoveLayerTop
- this.toolStripButton13.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton13.Image = global::Maestro.Editors.Properties.Resources.layers_stack_arrange;
- this.toolStripButton13.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton13.Name = "toolStripButton13";
- this.toolStripButton13.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton13.Text = "toolStripButton7";
+ this.btnDLMoveLayerTop.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnDLMoveLayerTop.Image = global::Maestro.Editors.Properties.Resources.layers_stack_arrange;
+ this.btnDLMoveLayerTop.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnDLMoveLayerTop.Name = "btnDLMoveLayerTop";
+ this.btnDLMoveLayerTop.Size = new System.Drawing.Size(23, 22);
+ this.btnDLMoveLayerTop.ToolTipText = "Move selected layer to top";
+ this.btnDLMoveLayerTop.Click += new System.EventHandler(this.btnDLMoveLayerTop_Click);
- // toolStripButton14
+ // btnDLMoveLayerBottom
- this.toolStripButton14.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton14.Image = global::Maestro.Editors.Properties.Resources.layers_stack_arrange_back;
- this.toolStripButton14.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton14.Name = "toolStripButton14";
- this.toolStripButton14.Size = new System.Drawing.Size(23, 22);
- this.toolStripButton14.Text = "toolStripButton8";
+ this.btnDLMoveLayerBottom.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnDLMoveLayerBottom.Image = global::Maestro.Editors.Properties.Resources.layers_stack_arrange_back;
+ this.btnDLMoveLayerBottom.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnDLMoveLayerBottom.Name = "btnDLMoveLayerBottom";
+ this.btnDLMoveLayerBottom.Size = new System.Drawing.Size(23, 22);
+ this.btnDLMoveLayerBottom.ToolTipText = "Move selected layer to bottom";
+ this.btnDLMoveLayerBottom.Click += new System.EventHandler(this.btnDLMoveLayerBottom_Click);
+ // TAB_BASE_LAYERS
+ this.TAB_BASE_LAYERS.Controls.Add(this.trvBaseLayers);
+ this.TAB_BASE_LAYERS.Controls.Add(this.toolStrip3);
+ this.TAB_BASE_LAYERS.Location = new System.Drawing.Point(4, 22);
+ this.TAB_BASE_LAYERS.Name = "TAB_BASE_LAYERS";
+ this.TAB_BASE_LAYERS.Padding = new System.Windows.Forms.Padding(3);
+ this.TAB_BASE_LAYERS.Size = new System.Drawing.Size(318, 266);
+ this.TAB_BASE_LAYERS.TabIndex = 2;
+ this.TAB_BASE_LAYERS.Text = "Base Layer Grops";
+ this.TAB_BASE_LAYERS.UseVisualStyleBackColor = true;
+ // trvBaseLayers
+ this.trvBaseLayers.BackColor = System.Drawing.SystemColors.Window;
+ this.trvBaseLayers.BorderStyle = System.Windows.Forms.BorderStyle.None;
+ this.trvBaseLayers.DefaultToolTipProvider = null;
+ this.trvBaseLayers.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.trvBaseLayers.DragDropMarkColor = System.Drawing.Color.Black;
+ this.trvBaseLayers.LineColor = System.Drawing.SystemColors.ControlDark;
+ this.trvBaseLayers.Location = new System.Drawing.Point(3, 28);
+ this.trvBaseLayers.Model = null;
+ this.trvBaseLayers.Name = "trvBaseLayers";
+ this.trvBaseLayers.NodeControls.Add(this.nodeIcon1);
+ this.trvBaseLayers.NodeControls.Add(this.nodeTextBox1);
+ this.trvBaseLayers.SelectedNode = null;
+ this.trvBaseLayers.Size = new System.Drawing.Size(312, 235);
+ this.trvBaseLayers.TabIndex = 1;
+ this.trvBaseLayers.Text = "treeViewAdv1";
+ this.trvBaseLayers.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvBaseLayers_MouseDoubleClick);
+ this.trvBaseLayers.MouseClick += new System.Windows.Forms.MouseEventHandler(this.trvBaseLayers_MouseClick);
+ // nodeIcon1
+ this.nodeIcon1.DataPropertyName = "Icon";
+ this.nodeIcon1.LeftMargin = 1;
+ this.nodeIcon1.ParentColumn = null;
+ this.nodeIcon1.ScaleMode = Aga.Controls.Tree.ImageScaleMode.Clip;
+ // nodeTextBox1
+ this.nodeTextBox1.DataPropertyName = "Text";
+ this.nodeTextBox1.IncrementalSearchEnabled = true;
+ this.nodeTextBox1.LeftMargin = 3;
+ this.nodeTextBox1.ParentColumn = null;
+ // toolStrip3
+ this.toolStrip3.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.btnNewBaseLayerGroup,
+ this.btnRemoveBaseLayerGroup,
+ this.toolStripSeparator2,
+ this.btnAddBaseLayer,
+ this.btnRemoveBaseLayer,
+ this.toolStripSeparator4,
+ this.btnMoveBaseLayerUp,
+ this.btnMoveBaseLayerDown});
+ this.toolStrip3.Location = new System.Drawing.Point(3, 3);
+ this.toolStrip3.Name = "toolStrip3";
+ this.toolStrip3.Size = new System.Drawing.Size(312, 25);
+ this.toolStrip3.TabIndex = 0;
+ this.toolStrip3.Text = "toolStrip3";
+ // btnNewBaseLayerGroup
+ this.btnNewBaseLayerGroup.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnNewBaseLayerGroup.Image = global::Maestro.Editors.Properties.Resources.folder__plus;
+ this.btnNewBaseLayerGroup.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnNewBaseLayerGroup.Name = "btnNewBaseLayerGroup";
+ this.btnNewBaseLayerGroup.Size = new System.Drawing.Size(23, 22);
+ this.btnNewBaseLayerGroup.ToolTipText = "Add a new group";
+ this.btnNewBaseLayerGroup.Click += new System.EventHandler(this.btnNewBaseLayerGroup_Click);
+ // btnRemoveBaseLayerGroup
+ this.btnRemoveBaseLayerGroup.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnRemoveBaseLayerGroup.Image = global::Maestro.Editors.Properties.Resources.folder__minus;
+ this.btnRemoveBaseLayerGroup.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnRemoveBaseLayerGroup.Name = "btnRemoveBaseLayerGroup";
+ this.btnRemoveBaseLayerGroup.Size = new System.Drawing.Size(23, 22);
+ this.btnRemoveBaseLayerGroup.ToolTipText = "Remove selected group";
+ this.btnRemoveBaseLayerGroup.Click += new System.EventHandler(this.btnRemoveBaseLayerGroup_Click);
+ // toolStripSeparator2
+ this.toolStripSeparator2.Name = "toolStripSeparator2";
+ this.toolStripSeparator2.Size = new System.Drawing.Size(6, 25);
+ // btnAddBaseLayer
+ this.btnAddBaseLayer.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnAddBaseLayer.Image = global::Maestro.Editors.Properties.Resources.layer__plus;
+ this.btnAddBaseLayer.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnAddBaseLayer.Name = "btnAddBaseLayer";
+ this.btnAddBaseLayer.Size = new System.Drawing.Size(23, 22);
+ this.btnAddBaseLayer.ToolTipText = "Add a new layer";
+ this.btnAddBaseLayer.Click += new System.EventHandler(this.btnAddBaseLayer_Click);
+ this.btnRemoveBaseLayer.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnRemoveBaseLayer.Image = global::Maestro.Editors.Properties.Resources.layer__minus;
+ this.btnRemoveBaseLayer.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnRemoveBaseLayer.Name = "btnRemoveBaseLayer";
+ this.btnRemoveBaseLayer.Size = new System.Drawing.Size(23, 22);
+ this.btnRemoveBaseLayer.ToolTipText = "Remove selected layer";
+ this.btnRemoveBaseLayer.Click += new System.EventHandler(this.btnRemoveBaseLayer_Click);
+ // toolStripSeparator4
+ this.toolStripSeparator4.Name = "toolStripSeparator4";
+ this.toolStripSeparator4.Size = new System.Drawing.Size(6, 25);
+ // btnMoveBaseLayerUp
+ this.btnMoveBaseLayerUp.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnMoveBaseLayerUp.Image = global::Maestro.Editors.Properties.Resources.arrow_090;
+ this.btnMoveBaseLayerUp.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnMoveBaseLayerUp.Name = "btnMoveBaseLayerUp";
+ this.btnMoveBaseLayerUp.Size = new System.Drawing.Size(23, 22);
+ this.btnMoveBaseLayerUp.ToolTipText = "Move selected layer up";
+ this.btnMoveBaseLayerUp.Click += new System.EventHandler(this.btnMoveBaseLayerUp_Click);
+ // btnMoveBaseLayerDown
+ this.btnMoveBaseLayerDown.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnMoveBaseLayerDown.Image = global::Maestro.Editors.Properties.Resources.arrow_270;
+ this.btnMoveBaseLayerDown.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnMoveBaseLayerDown.Name = "btnMoveBaseLayerDown";
+ this.btnMoveBaseLayerDown.Size = new System.Drawing.Size(23, 22);
+ this.btnMoveBaseLayerDown.ToolTipText = "Move selected layer down";
+ this.btnMoveBaseLayerDown.Click += new System.EventHandler(this.btnMoveBaseLayerDown_Click);
// splitter1
this.splitter1.Location = new System.Drawing.Point(326, 0);
@@ -418,6 +519,10 @@
this.TAB_DRAWING_ORDER.PerformLayout();
this.toolStrip2.ResumeLayout(false);
this.toolStrip2.PerformLayout();
+ this.TAB_BASE_LAYERS.ResumeLayout(false);
+ this.TAB_BASE_LAYERS.PerformLayout();
+ this.toolStrip3.ResumeLayout(false);
+ this.toolStrip3.PerformLayout();
@@ -433,30 +538,37 @@
private Aga.Controls.Tree.TreeViewAdv trvLayersGroup;
private Aga.Controls.Tree.TreeViewAdv trvLayerDrawingOrder;
private System.Windows.Forms.ToolStrip toolStrip2;
- private System.Windows.Forms.ToolStripButton toolStripButton1;
- private System.Windows.Forms.ToolStripButton toolStripButton2;
+ private System.Windows.Forms.ToolStripButton btnAddGroup;
+ private System.Windows.Forms.ToolStripButton btnRemoveGroup;
private System.Windows.Forms.ToolStripSeparator toolStripSeparator1;
- private System.Windows.Forms.ToolStripButton toolStripButton3;
- private System.Windows.Forms.ToolStripButton toolStripButton4;
- private System.Windows.Forms.ToolStripSeparator toolStripSeparator2;
- private System.Windows.Forms.ToolStripButton toolStripButton5;
- private System.Windows.Forms.ToolStripButton toolStripButton6;
+ private System.Windows.Forms.ToolStripButton btnGRPAddLayer;
+ private System.Windows.Forms.ToolStripButton btnGRPRemoveLayer;
private System.Windows.Forms.ToolStripSeparator toolStripSeparator3;
- private System.Windows.Forms.ToolStripButton toolStripButton7;
- private System.Windows.Forms.ToolStripButton toolStripButton8;
- private System.Windows.Forms.ToolStripSeparator toolStripSeparator4;
- private System.Windows.Forms.ToolStripButton toolStripButton21;
- private System.Windows.Forms.ToolStripButton toolStripButton9;
- private System.Windows.Forms.ToolStripButton toolStripButton10;
+ private System.Windows.Forms.ToolStripButton btnConvertLayerGroupToBaseGroup;
+ private System.Windows.Forms.ToolStripButton btnDLAddLayer;
+ private System.Windows.Forms.ToolStripButton btnDLRemoveLayer;
private System.Windows.Forms.ToolStripSeparator toolStripSeparator5;
- private System.Windows.Forms.ToolStripButton toolStripButton11;
- private System.Windows.Forms.ToolStripButton toolStripButton12;
+ private System.Windows.Forms.ToolStripButton btnDLMoveLayerUp;
+ private System.Windows.Forms.ToolStripButton btnDLMoveLayerDown;
private System.Windows.Forms.ToolStripSeparator toolStripSeparator6;
- private System.Windows.Forms.ToolStripButton toolStripButton13;
- private System.Windows.Forms.ToolStripButton toolStripButton14;
+ private System.Windows.Forms.ToolStripButton btnDLMoveLayerTop;
+ private System.Windows.Forms.ToolStripButton btnDLMoveLayerBottom;
private Aga.Controls.Tree.NodeControls.NodeIcon NODE_GROUP_ICON;
private Aga.Controls.Tree.NodeControls.NodeTextBox NODE_GROUP_TEXT;
private Aga.Controls.Tree.NodeControls.NodeIcon NODE_DRAW_ICON;
private Aga.Controls.Tree.NodeControls.NodeTextBox NODE_DRAW_TEXT;
+ private System.Windows.Forms.TabPage TAB_BASE_LAYERS;
+ private System.Windows.Forms.ToolStrip toolStrip3;
+ private System.Windows.Forms.ToolStripButton btnNewBaseLayerGroup;
+ private System.Windows.Forms.ToolStripButton btnRemoveBaseLayerGroup;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator2;
+ private System.Windows.Forms.ToolStripButton btnAddBaseLayer;
+ private System.Windows.Forms.ToolStripButton btnRemoveBaseLayer;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator4;
+ private System.Windows.Forms.ToolStripButton btnMoveBaseLayerUp;
+ private System.Windows.Forms.ToolStripButton btnMoveBaseLayerDown;
+ private Aga.Controls.Tree.TreeViewAdv trvBaseLayers;
+ private Aga.Controls.Tree.NodeControls.NodeIcon nodeIcon1;
+ private Aga.Controls.Tree.NodeControls.NodeTextBox nodeTextBox1;
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -28,6 +28,9 @@
using Aga.Controls.Tree;
using Maestro.Editors.Common;
+using OSGeo.MapGuide.MaestroAPI.Resource;
namespace Maestro.Editors.MapDefinition
@@ -36,260 +39,417 @@
[ToolboxItem(true)]
internal partial class MapLayersSectionCtrl : EditorBindableCollapsiblePanel
- abstract class TreeItem<T>
+ public MapLayersSectionCtrl()
- public TreeItem(string text, Image icon, T item)
- this.Text = text;
- this.Icon = icon;
- this.Tag = item;
- public Image Icon { get; set; }
- public string Text { get; set; }
+ private DrawOrderLayerModel _doLayerModel;
+ private GroupedLayerModel _grpLayerModel;
+ private TiledLayerModel _tiledLayerModel;
- public T Tag { get; set; }
+ public override void Bind(IEditorService service)
+ _edSvc = service;
+ _edSvc.RegisterCustomNotifier(this);
+ _map = (IMapDefinition)service.GetEditedResource();
+ trvLayerDrawingOrder.Model = _doLayerModel = new DrawOrderLayerModel(_map);
+ trvLayersGroup.Model = _grpLayerModel = new GroupedLayerModel(_map);
+ trvBaseLayers.Model = _tiledLayerModel = new TiledLayerModel(_map);
- class ScaleItem : TreeItem<IList<double>>
+ private void RefreshModels()
- public ScaleItem(string name, IList<double> range)
- : base(name, Properties.Resources.magnifier, range)
+ _doLayerModel.Invalidate();
+ _grpLayerModel.Invalidate();
+ public event OpenLayerEventHandler RequestLayerOpen;
+ private void trvLayersGroup_MouseDoubleClick(object sender, MouseEventArgs e)
+ TreeNodeAdv node = trvLayersGroup.GetNodeAt(new Point(e.X, e.Y));
+ if (node != null)
+ var layer = node.Tag as LayerItem;
+ if (layer != null)
+ var handler = this.RequestLayerOpen;
+ if (handler != null)
+ handler(this, layer.Tag.ResourceId);
- class LayerItem : TreeItem<MapLayerType>
+ private void trvLayerDrawingOrder_MouseDoubleClick(object sender, MouseEventArgs e)
- public LayerItem(MapLayerType layer)
- : base(layer.Name, Properties.Resources.layer, layer)
+ TreeNodeAdv node = trvLayerDrawingOrder.GetNodeAt(new Point(e.X, e.Y));
+ if (node != null)
- class GroupItem : TreeItem<MapLayerGroupType>
+ private void trvLayersGroup_MouseClick(object sender, MouseEventArgs e)
- public GroupItem(MapLayerGroupType grp)
- : base(grp.Name, Properties.Resources.folder_horizontal, grp)
+ if (node != null)
+ var group = node.Tag as GroupItem;
+ propertiesPanel.Controls.Clear();
+ var item = new LayerPropertiesCtrl(layer.Tag, _edSvc.ResourceService);
+ item.LayerChanged += (s, evt) => { OnResourceChanged(); };
+ item.Dock = DockStyle.Fill;
+ propertiesPanel.Controls.Add(item);
+ else if (group != null)
+ var item = new GroupPropertiesCtrl(group.Tag);
+ item.GroupChanged += (s, evt) => { OnResourceChanged(); };
- class BaseLayerItem : TreeItem<BaseMapLayerType>
+ private void trvLayerDrawingOrder_MouseClick(object sender, MouseEventArgs e)
- public BaseLayerItem(BaseMapLayerType layer)
+ if (node != null)
- class BaseLayerGroupItem : TreeItem<BaseMapLayerGroupCommonType>
+ private void btnAddGroup_Click(object sender, EventArgs e)
- public BaseLayerGroupItem(BaseMapLayerGroupCommonType group)
- : base(group.Name, Properties.Resources.folder_horizontal, group)
+ var selGroup = GetSelectedLayerGroupItem() as IMapLayerGroup;
+ CreateNewGroup(selGroup);
+ private void btnRemoveGroup_Click(object sender, EventArgs e)
+ var group = GetSelectedLayerGroupItem() as GroupItem;
+ _map.RemoveGroup(group.Tag);
+ private void btnGRPAddLayer_Click(object sender, EventArgs e)
+ using (var picker = new ResourcePicker(_edSvc.ResourceService, ResourceTypes.LayerDefinition, ResourcePickerMode.OpenResource))
+ string layerId = picker.ResourceID;
+ var selGroup = GetSelectedLayerGroupItem() as GroupItem;
+ CreateLayer(layerId, selGroup == null ? null : selGroup.Tag);
+ this.RefreshModels();
- abstract class TreeModelBase : ITreeModel
+ private void btnGRPRemoveLayer_Click(object sender, EventArgs e)
- public abstract System.Collections.IEnumerable GetChildren(TreePath treePath);
+ var layer = GetSelectedLayerGroupItem() as LayerItem;
+ _map.RemoveLayer(layer.Tag);
- public abstract bool IsLeaf(TreePath treePath);
+ private void btnConvertLayerGroupToBaseGroup_Click(object sender, EventArgs e)
+ if (group != null)
+ throw new NotImplementedException();
- public event EventHandler<TreeModelEventArgs> NodesChanged;
- protected void OnNodesInserted(TreeModelEventArgs e)
+ private void btnDLAddLayer_Click(object sender, EventArgs e)
- var handler = this.NodesInserted;
- if (handler != null)
- handler(this, e);
+ var selGroup = GetSelectedDrawOrderItem() as GroupItem;
+ CreateLayer(layerId, selGroup != null ? selGroup.Tag : null);
- public event EventHandler<TreeModelEventArgs> NodesInserted;
+ private void btnDLRemoveLayer_Click(object sender, EventArgs e)
+ var layer = GetSelectedDrawOrderItem() as LayerItem;
- protected void OnNodesRemoved(TreeModelEventArgs e)
+ private void btnDLMoveLayerUp_Click(object sender, EventArgs e)
- var handler = this.NodesRemoved;
- handler(this, e);
+ _map.MoveUp(layer.Tag);
- public event EventHandler<TreeModelEventArgs> NodesRemoved;
+ private void btnDLMoveLayerDown_Click(object sender, EventArgs e)
+ _map.MoveDown(layer.Tag);
- protected void OnStructureChanged(TreePathEventArgs e)
+ private void btnDLMoveLayerTop_Click(object sender, EventArgs e)
- var handler = this.StructureChanged;
- handler(this, e);
+ _map.SetTopDrawOrder(layer.Tag);
- public event EventHandler<TreePathEventArgs> StructureChanged;
+ private void btnDLMoveLayerBottom_Click(object sender, EventArgs e)
+ _map.SetBottomDrawOrder(layer.Tag);
- class DrawOrderLayerModel : TreeModelBase
+ private void CreateNewGroup(IMapLayerGroup parentGroup)
- private OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition _map;
+ int counter = 0;
+ string prefix = Properties.Resources.NewLayerGroup;
+ var group = _map.GetGroupByName(prefix);
+ while (group != null)
+ counter++;
+ prefix = Properties.Resources.NewLayerGroup + counter;
+ group = _map.GetGroupByName(prefix);
- public DrawOrderLayerModel(OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition map)
+ group = _map.AddGroup(prefix);
+ if (parentGroup != null)
+ group.Group = parentGroup.Name;
+ private void CreateLayer(string layerId, IMapLayerGroup parentGroup)
+ int counter = 0;
+ string prefix = ResourceIdentifier.GetName(layerId);
+ string name = prefix;
+ var layer = _map.GetLayerByName(name);
+ while (layer != null)
- _map = map;
+ counter++;
+ name = prefix + counter;
+ layer = _map.GetLayerByName(name);
- public override System.Collections.IEnumerable GetChildren(TreePath treePath)
+ layer = _map.AddLayer(parentGroup.Name, name, layerId);
+ else
+ layer = _map.AddLayer(null, name, layerId);
+ private object GetSelectedDrawOrderItem()
+ if (trvLayerDrawingOrder.SelectedNode != null)
- if (treePath.IsEmpty())
- foreach (var layer in _map.MapLayer)
- yield return new LayerItem(layer);
- else
- yield break;
+ return trvLayerDrawingOrder.SelectedNode.Tag;
+ return null;
- public override bool IsLeaf(TreePath treePath)
+ private object GetSelectedLayerGroupItem()
+ if (trvLayersGroup.SelectedNode != null)
- return !treePath.IsEmpty();
+ return trvLayersGroup.SelectedNode.Tag;
+ return null;
- class GroupedLayerModel : TreeModelBase
+ private void btnNewBaseLayerGroup_Click(object sender, EventArgs e)
+ _map.InitBaseMap();
+ var grp = _map.BaseMap.AddBaseLayerGroup(GenerateBaseGroupName(_map));
+ _tiledLayerModel.Invalidate();
- private Dictionary<string, List<MapLayerType>> _layersByGroup;
+ private object GetSelectedTiledLayerItem()
+ if (trvBaseLayers.SelectedNode != null)
+ return trvBaseLayers.SelectedNode.Tag;
+ else
+ return null;
- public GroupedLayerModel(OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition map)
+ private void btnRemoveBaseLayerGroup_Click(object sender, EventArgs e)
+ var group = GetSelectedTiledLayerItem() as BaseLayerGroupItem;
- _map = map;
- _layersByGroup = new Dictionary<string, List<MapLayerType>>();
- if (!string.IsNullOrEmpty(layer.Group))
- if (!_layersByGroup.ContainsKey(layer.Group))
- _layersByGroup[layer.Group] = new List<MapLayerType>();
- _layersByGroup[layer.Group].Add(layer);
+ _map.BaseMap.RemoveBaseLayerGroup(group.Tag);
+ private void btnAddBaseLayer_Click(object sender, EventArgs e)
- foreach (var group in _map.MapLayerGroup)
+ IBaseMapGroup grp = null;
- yield return new GroupItem(group);
+ grp = group.Tag;
- else
- var gitem = treePath.LastNode as GroupItem;
- if (gitem != null)
+ else
- var group = gitem.Tag;
- foreach (var g in _map.MapLayerGroup)
+ grp = _map.BaseMap.GetFirstGroup();
+ if (grp == null)
- if (g.Group == group.Name)
- yield return new GroupItem(g);
+ grp = _map.BaseMap.AddBaseLayerGroup(GenerateBaseGroupName(_map));
- if (_layersByGroup.ContainsKey(group.Name))
- foreach (var layer in _layersByGroup[group.Name])
- else
- yield break;
+ grp.AddLayer(GenerateBaseLayerName(layerId, _map.BaseMap), layerId);
+ private static string GenerateBaseGroupName(IMapDefinition map)
+ map.InitBaseMap();
+ int counter = 0;
+ string name = Properties.Resources.BaseLayerGroup;
+ if (map.BaseMap.GroupExists(name))
- var layer = treePath.LastNode as LayerItem;
- var group = treePath.LastNode as GroupItem;
+ counter++;
+ name = Properties.Resources.BaseLayerGroup + counter;
+ while (map.BaseMap.GroupExists(name))
+ counter++;
+ return name;
- if (layer != null)
- return true;
- else if (group != null)
- return !_layersByGroup.ContainsKey(group.Tag.Name);
+ private static string GenerateBaseLayerName(string layerId, IBaseMapDefinition baseMapDef)
+ Check.NotNull(baseMapDef, "baseMapDef");
+ Check.NotEmpty(layerId, "layerId");
- throw new ApplicationException();
+ int counter = 0;
+ if (baseMapDef.LayerExists(name))
+ while (baseMapDef.LayerExists(name))
+ counter++;
- public MapLayersSectionCtrl()
- InitializeComponent();
+ return name;
- public override void Bind(IEditorService service)
+ private void btnRemoveBaseLayer_Click(object sender, EventArgs e)
- service.RegisterCustomNotifier(this);
- _map = (OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition)service.GetEditedResource();
- trvLayerDrawingOrder.Model = new DrawOrderLayerModel(_map);
- trvLayersGroup.Model = new GroupedLayerModel(_map);
+ var layer = GetSelectedTiledLayerItem() as BaseLayerItem;
+ var grp = layer.Parent;
+ grp.RemoveBaseMapLayer(layer.Tag);
- public event OpenLayerEventHandler RequestLayerOpen;
- private void trvLayersGroup_MouseDoubleClick(object sender, MouseEventArgs e)
+ private void btnMoveBaseLayerUp_Click(object sender, EventArgs e)
- TreeNodeAdv node = trvLayersGroup.GetNodeAt(new Point(e.X, e.Y));
- if (node != null)
- var layer = node.Tag as LayerItem;
- var handler = this.RequestLayerOpen;
- handler(this, layer.Tag.ResourceId);
+ grp.MoveUp(layer.Tag);
- private void trvLayerDrawingOrder_MouseDoubleClick(object sender, MouseEventArgs e)
+ private void btnMoveBaseLayerDown_Click(object sender, EventArgs e)
- TreeNodeAdv node = trvLayerDrawingOrder.GetNodeAt(new Point(e.X, e.Y));
- if (node != null)
+ grp.MoveDown(layer.Tag);
- private void trvLayersGroup_MouseClick(object sender, MouseEventArgs e)
+ private void trvBaseLayers_MouseClick(object sender, MouseEventArgs e)
+ TreeNodeAdv node = trvBaseLayers.GetNodeAt(new Point(e.X, e.Y));
if (node != null)
- var group = node.Tag as GroupItem;
+ var layer = node.Tag as BaseLayerItem;
+ var group = node.Tag as BaseLayerGroupItem;
+ var scale = node.Tag as ScaleItem;
if (layer != null)
- var item = new LayerPropertiesCtrl(layer.Tag);
@@ -302,22 +462,28 @@
+ else if (scale != null)
+ var item = new FiniteScaleListCtrl(_map);
- private void trvLayerDrawingOrder_MouseClick(object sender, MouseEventArgs e)
+ private void trvBaseLayers_MouseDoubleClick(object sender, MouseEventArgs e)
if (node != null)
if (layer != null)
- propertiesPanel.Controls.Clear();
- item.LayerChanged += (s, evt) => { OnResourceChanged(); };
- item.Dock = DockStyle.Fill;
- propertiesPanel.Controls.Add(item);
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.resx
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.resx 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.resx 2010-10-18 07:16:47 UTC (rev 5289)
@@ -123,23 +123,13 @@
<metadata name="toolStrip2.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>116, 17</value>
</metadata>
+ <metadata name="toolStrip3.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>221, 17</value>
+ </metadata>
<metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>17, 17</value>
</metadata>
- <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
- <data name="toolStripButton21.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpRPAAAAgxJREFUOE+lkvtL
- U2EYx+0PEbtpFwnBKPGKiJImGP0gYhIYs1E5GF5gIxkpA00JRSmMEF0ohMh+GaRWYlqabMVcNdS2QpaI
- VqiDIYhk397vA6fXhCjyhYdzeM/5fp7vczkAdeL2cwho7v/wWzT1zcN+Pwhr51uY2/y41PQaF+wzKKiZ
- QvaN58g0jyLd5KEUcQbg+84P/Cm2tncQjW3j68YWIqubCC3FcOJc478BAuGoZM6zvoRnakXEruEIjhc4
- /g5gZop9c+voGAyLbQIfeBZxLL9BA1jzXvuGbWamuKh+GmmVbswE19A59FEBbmoAG7YbsLtm2mZmiml9
- cvabNDwpz6YB7LYBoMXCumkJr7LOmnnHzBQ/9X2Bo2cOibm1GsBREbAQiYmw/8lnuCeWkVzcgnZlnw1j
- 3HV/wuNXK6i/9x5Hc6wawDlTXHbLJ+LZUBQPRyKwdQdxutwl1h+NLXHh5Ht1ewBHsiwawCW57HyDAfWR
- dvl0uhZQ1eqX8aVc7EKLqrum651ATLf9OJx5XQM4KmY0xPzZ0hFAiQJnXB0WwME0E3IsL5B17ZlADqWb
- NYDrOepdlcysmTWWOrxqbceRWtaLk0VO1XW72D5Vckd2gMBfq8zdpmUG62NJvKM4+XyziDk24xmfWoGE
- s1c0gHPmbrPTpHNJKOCo2G1mZs20zcwUJ5yp1AB5+8/zEwgF5GMVDxh4AAAAAElFTkSuQmCC
-</value>
- </data>
+ </metadata>
</root>
\ No newline at end of file
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.Designer.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -121,7 +121,7 @@
this.btnSetZoom.Name = "btnSetZoom";
this.btnSetZoom.Size = new System.Drawing.Size(104, 48);
this.btnSetZoom.TabIndex = 10;
- this.btnSetZoom.Text = "Set view to current layers extent";
+ this.btnSetZoom.Text = "Set view to combined extent of current layers";
this.btnSetZoom.Click += new System.EventHandler(this.btnSetZoom_Click);
// txtUpperY
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -26,6 +26,10 @@
using System.Windows.Forms;
using Maestro.Shared.UI;
+using OSGeo.MapGuide.ObjectModels.Common;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+using OSGeo.MapGuide.ObjectModels.MapDefinition;
@@ -37,7 +41,7 @@
+ private IMapDefinition _map;
const string META_START = "<MapDescription>";
const string META_END = "</MapDescription>";
@@ -85,12 +89,16 @@
cmbBackgroundColor.CurrentColor = _map.BackgroundColor;
+ else if (e.PropertyName == "MapLayer")
+ btnSetZoom.Enabled = _map.GetLayerCount() > 0;
- txtLowerX.DataBindings.Add("Text", _map.Extents, "MinX");
- txtLowerY.DataBindings.Add("Text", _map.Extents, "MinY");
- txtUpperX.DataBindings.Add("Text", _map.Extents, "MaxX");
- txtUpperY.DataBindings.Add("Text", _map.Extents, "MaxY");
+ TextBoxBinder.BindText(txtLowerX, _map.Extents, "MinX");
+ TextBoxBinder.BindText(txtLowerY, _map.Extents, "MinY");
+ TextBoxBinder.BindText(txtUpperX, _map.Extents, "MaxX");
+ TextBoxBinder.BindText(txtUpperY, _map.Extents, "MaxY");
_map.Extents.PropertyChanged += (sender, e) => { OnResourceChanged(); };
@@ -106,7 +114,46 @@
private void btnSetZoom_Click(object sender, EventArgs e)
+ using (new WaitCursor(this))
+ List<ILayerDefinition> layers = new List<ILayerDefinition>();
+ foreach (var lyr in _map.MapLayer)
+ layers.Add((ILayerDefinition)_service.ResourceService.GetResource(lyr.ResourceId));
+ var env = Util.GetCombinedExtents(layers);
+ _map.SetExtents(env.MinX, env.MinY, env.MaxX, env.MaxY);
+ internal class Util
+ public static IEnvelope GetCombinedExtents(IEnumerable<ILayerDefinition> layers)
+ Check.NotNull(layers, "layers");
+ IEnvelope env = null;
+ foreach (var layer in layers)
+ var e1 = layer.GetSpatialExtent(true);
+ if (env == null)
+ env = e1;
+ else
+ if (e1.MinX < env.MinX)
+ env.MinX = e1.MinX;
+ if (e1.MinY < env.MinY)
+ env.MinY = e1.MinY;
+ if (e1.MaxX > env.MaxX)
+ env.MaxX = e1.MaxX;
+ if (e1.MaxY > env.MaxY)
+ env.MaxY = e1.MaxY;
+ return env;
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapTreeModels.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapTreeModels.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapTreeModels.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,314 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using Aga.Controls.Tree;
+using System.Drawing;
+using System.ComponentModel;
+namespace Maestro.Editors.MapDefinition
+ internal abstract class TreeItem<T>
+ public TreeItem(string text, Image icon, T item)
+ this.Text = text;
+ this.Icon = icon;
+ this.Tag = item;
+ public Image Icon { get; set; }
+ public string Text { get; set; }
+ public T Tag { get; set; }
+ internal class ScaleItem : TreeItem<IList<double>>
+ public ScaleItem(string name, IList<double> range)
+ : base(name, Properties.Resources.magnifier, range)
+ internal class LayerItem : TreeItem<IMapLayer>
+ public LayerItem(IMapLayer layer)
+ : base(layer.Name, Properties.Resources.layer, layer)
+ layer.PropertyChanged += OnPropertyChanged;
+ void OnPropertyChanged(object sender, PropertyChangedEventArgs e)
+ if (e.PropertyName == "LegendLabel")
+ this.Text = this.Tag.LegendLabel;
+ internal class GroupItem : TreeItem<IMapLayerGroup>
+ public GroupItem(IMapLayerGroup grp)
+ : base(grp.Name, Properties.Resources.folder_horizontal, grp)
+ grp.PropertyChanged += OnPropertyChanged;
+ internal class BaseLayerItem : TreeItem<IBaseMapLayer>
+ public BaseLayerItem(IBaseMapLayer layer, IBaseMapGroup parent)
+ this.Parent = parent;
+ public IBaseMapGroup Parent
+ get;
+ set;
+ internal class BaseLayerGroupItem : TreeItem<IBaseMapGroup>
+ public BaseLayerGroupItem(IBaseMapGroup group)
+ : base(group.Name, Properties.Resources.folder_horizontal, group)
+ group.PropertyChanged += OnPropertyChanged;
+ internal abstract class TreeModelBase : ITreeModel
+ public abstract System.Collections.IEnumerable GetChildren(TreePath treePath);
+ public abstract bool IsLeaf(TreePath treePath);
+ public event EventHandler<TreeModelEventArgs> NodesChanged;
+ protected void OnNodesInserted(TreeModelEventArgs e)
+ var handler = this.NodesInserted;
+ handler(this, e);
+ public event EventHandler<TreeModelEventArgs> NodesInserted;
+ protected void OnNodesRemoved(TreeModelEventArgs e)
+ var handler = this.NodesRemoved;
+ handler(this, e);
+ public event EventHandler<TreeModelEventArgs> NodesRemoved;
+ protected void OnStructureChanged(TreePathEventArgs e)
+ var handler = this.StructureChanged;
+ handler(this, e);
+ public event EventHandler<TreePathEventArgs> StructureChanged;
+ internal void Invalidate()
+ OnStructureChanged(new TreePathEventArgs(TreePath.Empty));
+ internal void Invalidate(TreePath path)
+ OnStructureChanged(new TreePathEventArgs(path));
+ internal class DrawOrderLayerModel : TreeModelBase
+ public DrawOrderLayerModel(IMapDefinition map)
+ _map = map;
+ public override System.Collections.IEnumerable GetChildren(TreePath treePath)
+ if (treePath.IsEmpty())
+ foreach (var layer in _map.MapLayer)
+ yield return new LayerItem(layer);
+ else
+ yield break;
+ public override bool IsLeaf(TreePath treePath)
+ return !treePath.IsEmpty();
+ internal class GroupedLayerModel : TreeModelBase
+ public GroupedLayerModel(IMapDefinition map)
+ _map = map;
+ foreach (var group in _map.MapLayerGroup)
+ yield return new GroupItem(group);
+ foreach (var layer in _map.GetLayersWithoutGroups())
+ else
+ var gitem = treePath.LastNode as GroupItem;
+ if (gitem != null)
+ var group = gitem.Tag;
+ foreach (var g in _map.MapLayerGroup)
+ if (g.Group == group.Name)
+ yield return new GroupItem(g);
+ foreach (var l in _map.GetLayersForGroup(gitem.Tag.Name))
+ yield return new LayerItem(l);
+ else
+ yield break;
+ var layer = treePath.LastNode as LayerItem;
+ var group = treePath.LastNode as GroupItem;
+ return true;
+ return false;
+ throw new ApplicationException();
+ internal class TiledLayerModel : TreeModelBase
+ public TiledLayerModel(IMapDefinition map)
+ _map = map;
+ if (_map.BaseMap != null)
+ yield return new ScaleItem(Properties.Resources.FiniteDisplayScales, new List<double>(_map.BaseMap.FiniteDisplayScale));
+ foreach (var grp in _map.BaseMap.BaseMapLayerGroup)
+ yield return new BaseLayerGroupItem(grp);
+ else
+ yield return new ScaleItem(Properties.Resources.FiniteDisplayScales, new List<double>());
+ else
+ var grp = treePath.LastNode as BaseLayerGroupItem;
+ if (grp != null)
+ foreach (var layer in _map.BaseMap.GetLayersForGroup(grp.Tag.Name))
+ yield return new BaseLayerItem(layer, grp.Tag);
+ return grp == null;
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ScaleListGenerator.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ScaleListGenerator.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ScaleListGenerator.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,114 @@
+#endregion
+using System;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI;
+ internal enum ScaleGenerationMethod
+ Linear,
+ Exponential
+ internal enum ScaleRoundingMethod
+ None,
+ Regular,
+ Pretty
+ internal static class ScaleListGenerator
+ public static double[] GenerateScales(double minScale, double maxScale, ScaleGenerationMethod method, ScaleRoundingMethod rounding, int scaleCount)
+ Check.Precondition(minScale < maxScale, "minScale < maxScale");
+ Check.Precondition(scaleCount > 0, "scaleCount > 0");
+ List<double> vals = new List<double>();
+ if (method == ScaleGenerationMethod.Linear)
+ double inc = (double)(maxScale - minScale) / (double)scaleCount;
+ double cur = (double)minScale;
+ for (int i = 0; i < scaleCount; i++)
+ vals.Add(cur);
+ cur += inc;
+ //In case the rounding sucks
+ vals[(int)(scaleCount - 1)] = (double)maxScale;
+ else if (method == ScaleGenerationMethod.Exponential)
+ double b = Math.Pow((double)(maxScale - minScale), 1 / (double)(scaleCount));
+ vals.Add(cur);
+ cur = ((double)maxScale) / Math.Pow(b, (int)scaleCount - i - 1) + (double)minScale;
+ else
+ vals.Clear();
+ double span = (double)maxScale - (double)minScale;
+ double b = Math.Log10((double)maxScale / (double)(scaleCount - 1));
+ vals.Add(Math.Pow(i, b) + (double)minScale);
+ if (rounding == ScaleRoundingMethod.Regular || rounding == ScaleRoundingMethod.Pretty)
+ for (int i = 0; i < vals.Count; i++)
+ vals[i] = Math.Round(vals[i]);
+ if (rounding == ScaleRoundingMethod.Pretty)
+ int group = (int)Math.Floor(Math.Log10(vals[i]));
+ group--;
+ vals[i] = Math.Round(Math.Round((vals[i] / Math.Pow(10, group))) * Math.Pow(10, group));
+ //Sort and weed out dupes
+ var sorted = new SortedList<double, double>();
+ foreach (var d in vals)
+ if (!sorted.ContainsKey(d))
+ sorted.Add(d, d);
+ return new List<double>(sorted.Keys).ToArray();
Added: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,367 @@
+namespace Maestro.Editors.PrintLayout
+ partial class LogoDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.btnCancel = new System.Windows.Forms.Button();
+ this.btnOK = new System.Windows.Forms.Button();
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.label9 = new System.Windows.Forms.Label();
+ this.numRotation = new System.Windows.Forms.NumericUpDown();
+ this.label5 = new System.Windows.Forms.Label();
+ this.label4 = new System.Windows.Forms.Label();
+ this.label3 = new System.Windows.Forms.Label();
+ this.cmbPositionUnits = new System.Windows.Forms.ComboBox();
+ this.numPosBottom = new System.Windows.Forms.NumericUpDown();
+ this.numPosLeft = new System.Windows.Forms.NumericUpDown();
+ this.groupBox2 = new System.Windows.Forms.GroupBox();
+ this.label6 = new System.Windows.Forms.Label();
+ this.numSizeWidth = new System.Windows.Forms.NumericUpDown();
+ this.label7 = new System.Windows.Forms.Label();
+ this.numSizeHeight = new System.Windows.Forms.NumericUpDown();
+ this.label8 = new System.Windows.Forms.Label();
+ this.cmbSizeUnits = new System.Windows.Forms.ComboBox();
+ this.groupBox3 = new System.Windows.Forms.GroupBox();
+ this.btnBrowseSymbolName = new System.Windows.Forms.Button();
+ this.txtSymbolName = new System.Windows.Forms.TextBox();
+ this.btnBrowseSymbolLibrary = new System.Windows.Forms.Button();
+ this.txtSymbolLibraryId = new System.Windows.Forms.TextBox();
+ this.label2 = new System.Windows.Forms.Label();
+ this.label1 = new System.Windows.Forms.Label();
+ this.groupBox1.SuspendLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.numRotation)).BeginInit();
+ ((System.ComponentModel.ISupportInitialize)(this.numPosBottom)).BeginInit();
+ ((System.ComponentModel.ISupportInitialize)(this.numPosLeft)).BeginInit();
+ this.groupBox2.SuspendLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.numSizeWidth)).BeginInit();
+ ((System.ComponentModel.ISupportInitialize)(this.numSizeHeight)).BeginInit();
+ this.groupBox3.SuspendLayout();
+ this.SuspendLayout();
+ // btnCancel
+ this.btnCancel.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnCancel.Location = new System.Drawing.Point(344, 242);
+ this.btnCancel.Name = "btnCancel";
+ this.btnCancel.Size = new System.Drawing.Size(75, 23);
+ this.btnCancel.TabIndex = 0;
+ this.btnCancel.Text = "Cancel";
+ this.btnCancel.UseVisualStyleBackColor = true;
+ this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+ // btnOK
+ this.btnOK.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnOK.Location = new System.Drawing.Point(263, 242);
+ this.btnOK.Name = "btnOK";
+ this.btnOK.Size = new System.Drawing.Size(75, 23);
+ this.btnOK.TabIndex = 1;
+ this.btnOK.Text = "OK";
+ this.btnOK.UseVisualStyleBackColor = true;
+ this.btnOK.Click += new System.EventHandler(this.btnOK_Click);
+ // groupBox1
+ this.groupBox1.Controls.Add(this.label9);
+ this.groupBox1.Controls.Add(this.numRotation);
+ this.groupBox1.Controls.Add(this.label5);
+ this.groupBox1.Controls.Add(this.label4);
+ this.groupBox1.Controls.Add(this.label3);
+ this.groupBox1.Controls.Add(this.cmbPositionUnits);
+ this.groupBox1.Controls.Add(this.numPosBottom);
+ this.groupBox1.Controls.Add(this.numPosLeft);
+ this.groupBox1.Location = new System.Drawing.Point(12, 102);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.Size = new System.Drawing.Size(200, 133);
+ this.groupBox1.TabIndex = 2;
+ this.groupBox1.TabStop = false;
+ this.groupBox1.Text = "Position";
+ // label9
+ this.label9.AutoSize = true;
+ this.label9.Location = new System.Drawing.Point(22, 102);
+ this.label9.Name = "label9";
+ this.label9.Size = new System.Drawing.Size(47, 13);
+ this.label9.TabIndex = 7;
+ this.label9.Text = "Rotation";
+ // numRotation
+ this.numRotation.DecimalPlaces = 2;
+ this.numRotation.Location = new System.Drawing.Point(74, 100);
+ this.numRotation.Name = "numRotation";
+ this.numRotation.Size = new System.Drawing.Size(120, 20);
+ this.numRotation.TabIndex = 6;
+ // label5
+ this.label5.AutoSize = true;
+ this.label5.Location = new System.Drawing.Point(22, 76);
+ this.label5.Name = "label5";
+ this.label5.Size = new System.Drawing.Size(31, 13);
+ this.label5.TabIndex = 5;
+ this.label5.Text = "Units";
+ // label4
+ this.label4.AutoSize = true;
+ this.label4.Location = new System.Drawing.Point(22, 49);
+ this.label4.Name = "label4";
+ this.label4.Size = new System.Drawing.Size(40, 13);
+ this.label4.TabIndex = 4;
+ this.label4.Text = "Bottom";
+ // label3
+ this.label3.AutoSize = true;
+ this.label3.Location = new System.Drawing.Point(22, 21);
+ this.label3.Name = "label3";
+ this.label3.Size = new System.Drawing.Size(25, 13);
+ this.label3.TabIndex = 3;
+ this.label3.Text = "Left";
+ // cmbPositionUnits
+ this.cmbPositionUnits.FormattingEnabled = true;
+ this.cmbPositionUnits.Location = new System.Drawing.Point(74, 73);
+ this.cmbPositionUnits.Name = "cmbPositionUnits";
+ this.cmbPositionUnits.Size = new System.Drawing.Size(120, 21);
+ this.cmbPositionUnits.TabIndex = 2;
+ // numPosBottom
+ this.numPosBottom.DecimalPlaces = 2;
+ this.numPosBottom.Location = new System.Drawing.Point(74, 47);
+ this.numPosBottom.Name = "numPosBottom";
+ this.numPosBottom.Size = new System.Drawing.Size(120, 20);
+ this.numPosBottom.TabIndex = 1;
+ // numPosLeft
+ this.numPosLeft.DecimalPlaces = 2;
+ this.numPosLeft.Location = new System.Drawing.Point(74, 19);
+ this.numPosLeft.Name = "numPosLeft";
+ this.numPosLeft.Size = new System.Drawing.Size(120, 20);
+ this.numPosLeft.TabIndex = 0;
+ // groupBox2
+ this.groupBox2.Controls.Add(this.label6);
+ this.groupBox2.Controls.Add(this.numSizeWidth);
+ this.groupBox2.Controls.Add(this.label7);
+ this.groupBox2.Controls.Add(this.numSizeHeight);
+ this.groupBox2.Controls.Add(this.label8);
+ this.groupBox2.Controls.Add(this.cmbSizeUnits);
+ this.groupBox2.Location = new System.Drawing.Point(219, 102);
+ this.groupBox2.Name = "groupBox2";
+ this.groupBox2.Size = new System.Drawing.Size(200, 133);
+ this.groupBox2.TabIndex = 3;
+ this.groupBox2.TabStop = false;
+ this.groupBox2.Text = "Size";
+ // label6
+ this.label6.AutoSize = true;
+ this.label6.Location = new System.Drawing.Point(13, 76);
+ this.label6.Name = "label6";
+ this.label6.Size = new System.Drawing.Size(31, 13);
+ this.label6.TabIndex = 11;
+ this.label6.Text = "Units";
+ // numSizeWidth
+ this.numSizeWidth.DecimalPlaces = 2;
+ this.numSizeWidth.Location = new System.Drawing.Point(65, 19);
+ this.numSizeWidth.Name = "numSizeWidth";
+ this.numSizeWidth.Size = new System.Drawing.Size(120, 20);
+ this.numSizeWidth.TabIndex = 6;
+ // label7
+ this.label7.AutoSize = true;
+ this.label7.Location = new System.Drawing.Point(13, 48);
+ this.label7.Name = "label7";
+ this.label7.Size = new System.Drawing.Size(38, 13);
+ this.label7.TabIndex = 10;
+ this.label7.Text = "Height";
+ // numSizeHeight
+ this.numSizeHeight.DecimalPlaces = 2;
+ this.numSizeHeight.Location = new System.Drawing.Point(65, 46);
+ this.numSizeHeight.Name = "numSizeHeight";
+ this.numSizeHeight.Size = new System.Drawing.Size(120, 20);
+ this.numSizeHeight.TabIndex = 7;
+ // label8
+ this.label8.AutoSize = true;
+ this.label8.Location = new System.Drawing.Point(13, 21);
+ this.label8.Name = "label8";
+ this.label8.Size = new System.Drawing.Size(35, 13);
+ this.label8.TabIndex = 9;
+ this.label8.Text = "Width";
+ // cmbSizeUnits
+ this.cmbSizeUnits.FormattingEnabled = true;
+ this.cmbSizeUnits.Location = new System.Drawing.Point(65, 73);
+ this.cmbSizeUnits.Name = "cmbSizeUnits";
+ this.cmbSizeUnits.Size = new System.Drawing.Size(120, 21);
+ this.cmbSizeUnits.TabIndex = 8;
+ // groupBox3
+ this.groupBox3.Controls.Add(this.btnBrowseSymbolName);
+ this.groupBox3.Controls.Add(this.txtSymbolName);
+ this.groupBox3.Controls.Add(this.btnBrowseSymbolLibrary);
+ this.groupBox3.Controls.Add(this.txtSymbolLibraryId);
+ this.groupBox3.Controls.Add(this.label2);
+ this.groupBox3.Controls.Add(this.label1);
+ this.groupBox3.Location = new System.Drawing.Point(13, 13);
+ this.groupBox3.Name = "groupBox3";
+ this.groupBox3.Size = new System.Drawing.Size(406, 83);
+ this.groupBox3.TabIndex = 4;
+ this.groupBox3.TabStop = false;
+ this.groupBox3.Text = "Symbol Reference";
+ // btnBrowseSymbolName
+ this.btnBrowseSymbolName.Location = new System.Drawing.Point(362, 50);
+ this.btnBrowseSymbolName.Name = "btnBrowseSymbolName";
+ this.btnBrowseSymbolName.Size = new System.Drawing.Size(29, 23);
+ this.btnBrowseSymbolName.TabIndex = 5;
+ this.btnBrowseSymbolName.Text = "...";
+ this.btnBrowseSymbolName.UseVisualStyleBackColor = true;
+ this.btnBrowseSymbolName.Click += new System.EventHandler(this.btnBrowseSymbolName_Click);
+ // txtSymbolName
+ this.txtSymbolName.Location = new System.Drawing.Point(129, 52);
+ this.txtSymbolName.Name = "txtSymbolName";
+ this.txtSymbolName.ReadOnly = true;
+ this.txtSymbolName.Size = new System.Drawing.Size(227, 20);
+ this.txtSymbolName.TabIndex = 4;
+ // btnBrowseSymbolLibrary
+ this.btnBrowseSymbolLibrary.Location = new System.Drawing.Point(362, 23);
+ this.btnBrowseSymbolLibrary.Name = "btnBrowseSymbolLibrary";
+ this.btnBrowseSymbolLibrary.Size = new System.Drawing.Size(29, 23);
+ this.btnBrowseSymbolLibrary.TabIndex = 3;
+ this.btnBrowseSymbolLibrary.Text = "...";
+ this.btnBrowseSymbolLibrary.UseVisualStyleBackColor = true;
+ this.btnBrowseSymbolLibrary.Click += new System.EventHandler(this.btnBrowseSymbolLibrary_Click);
+ // txtSymbolLibraryId
+ this.txtSymbolLibraryId.Location = new System.Drawing.Point(129, 25);
+ this.txtSymbolLibraryId.Name = "txtSymbolLibraryId";
+ this.txtSymbolLibraryId.ReadOnly = true;
+ this.txtSymbolLibraryId.Size = new System.Drawing.Size(227, 20);
+ this.txtSymbolLibraryId.TabIndex = 2;
+ // label2
+ this.label2.AutoSize = true;
+ this.label2.Location = new System.Drawing.Point(21, 55);
+ this.label2.Name = "label2";
+ this.label2.Size = new System.Drawing.Size(35, 13);
+ this.label2.TabIndex = 1;
+ this.label2.Text = "Name";
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(21, 28);
+ this.label1.Name = "label1";
+ this.label1.Size = new System.Drawing.Size(89, 13);
+ this.label1.TabIndex = 0;
+ this.label1.Text = "Symbol Library ID";
+ // LogoDialog
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.ClientSize = new System.Drawing.Size(431, 277);
+ this.Controls.Add(this.groupBox3);
+ this.Controls.Add(this.groupBox2);
+ this.Controls.Add(this.groupBox1);
+ this.Controls.Add(this.btnOK);
+ this.Controls.Add(this.btnCancel);
+ this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog;
+ this.MaximizeBox = false;
+ this.MinimizeBox = false;
+ this.Name = "LogoDialog";
+ this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
+ this.Text = "Logo Element";
+ this.groupBox1.ResumeLayout(false);
+ this.groupBox1.PerformLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.numRotation)).EndInit();
+ ((System.ComponentModel.ISupportInitialize)(this.numPosBottom)).EndInit();
+ ((System.ComponentModel.ISupportInitialize)(this.numPosLeft)).EndInit();
+ this.groupBox2.ResumeLayout(false);
+ this.groupBox2.PerformLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.numSizeWidth)).EndInit();
+ ((System.ComponentModel.ISupportInitialize)(this.numSizeHeight)).EndInit();
+ this.groupBox3.ResumeLayout(false);
+ this.groupBox3.PerformLayout();
+ this.ResumeLayout(false);
+ #endregion
+ private System.Windows.Forms.Button btnCancel;
+ private System.Windows.Forms.Button btnOK;
+ private System.Windows.Forms.GroupBox groupBox1;
+ private System.Windows.Forms.GroupBox groupBox2;
+ private System.Windows.Forms.GroupBox groupBox3;
+ private System.Windows.Forms.Button btnBrowseSymbolLibrary;
+ private System.Windows.Forms.TextBox txtSymbolLibraryId;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.Button btnBrowseSymbolName;
+ private System.Windows.Forms.TextBox txtSymbolName;
+ private System.Windows.Forms.Label label5;
+ private System.Windows.Forms.Label label4;
+ private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.ComboBox cmbPositionUnits;
+ private System.Windows.Forms.NumericUpDown numPosBottom;
+ private System.Windows.Forms.NumericUpDown numPosLeft;
+ private System.Windows.Forms.Label label6;
+ private System.Windows.Forms.NumericUpDown numSizeWidth;
+ private System.Windows.Forms.Label label7;
+ private System.Windows.Forms.NumericUpDown numSizeHeight;
+ private System.Windows.Forms.Label label8;
+ private System.Windows.Forms.ComboBox cmbSizeUnits;
+ private System.Windows.Forms.Label label9;
+ private System.Windows.Forms.NumericUpDown numRotation;
Added: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.cs
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,147 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+using System.Windows.Forms;
+using Maestro.Editors.Generic;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using Maestro.Editors.Common;
+ public partial class LogoDialog : Form
+ private LogoDialog()
+ InitializeComponent();
+ private IServerConnection _conn;
+ public LogoDialog(IServerConnection conn)
+ : this()
+ //TOOD: Maybe be more graceful? Like allow text entry, but disable browsing buttons?
+ if (Array.IndexOf(conn.Capabilities.SupportedServices, (int)ServiceType.Drawing) < 0)
+ throw new InvalidOperationException("Required service not supported on this connection: " + ServiceType.Drawing.ToString()); //LOCALIZEME
+ _conn = conn;
+ public string SymbolLibraryID
+ get { return txtSymbolLibraryId.Text; }
+ set { txtSymbolLibraryId.Text = value; }
+ public string SymbolName
+ get { return txtSymbolName.Text; }
+ set { txtSymbolName.Text = value; }
+ public float PositionLeft
+ get { return Convert.ToSingle(numPosLeft.Value); }
+ set { numPosLeft.Value = Convert.ToDecimal(value); }
+ public float PositionBottom
+ get { return Convert.ToSingle(numPosBottom.Value); }
+ set { numPosBottom.Value = Convert.ToDecimal(value); }
+ public string PositionUnits
+ get { return cmbPositionUnits.Text; }
+ set { cmbPositionUnits.Text = value; }
+ public float SizeWidth
+ get { return Convert.ToSingle(numSizeWidth.Value); }
+ set { numSizeWidth.Value = Convert.ToDecimal(value); }
+ public float SizeHeight
+ get { return Convert.ToSingle(numSizeHeight.Value); }
+ set { numSizeHeight.Value = Convert.ToDecimal(value); }
+ public float Rotation
+ get { return Convert.ToSingle(numRotation.Value); }
+ set { numRotation.Value = Convert.ToDecimal(value); }
+ public string SizeUnits
+ get { return cmbSizeUnits.Text; }
+ set { cmbSizeUnits.Text = value; }
+ private void btnOK_Click(object sender, EventArgs e)
+ this.DialogResult = DialogResult.OK;
+ private void btnCancel_Click(object sender, EventArgs e)
+ this.DialogResult = DialogResult.Cancel;
+ private void btnBrowseSymbolLibrary_Click(object sender, EventArgs e)
+ using (var picker = new ResourcePicker(_conn.ResourceService, ResourceTypes.SymbolLibrary, ResourcePickerMode.OpenResource))
+ if (picker.ShowDialog() == DialogResult.OK)
+ this.SymbolLibraryID = picker.ResourceID;
+ this.SymbolName = string.Empty;
+ private void btnBrowseSymbolName_Click(object sender, EventArgs e)
+ if (string.IsNullOrEmpty(this.SymbolLibraryID))
+ MessageBox.Show(Properties.Resources.SelectSymbolLibraryFirst);
+ return;
+ using (var picker = new SymbolPicker(this.SymbolLibraryID, _conn))
+ this.SymbolName = picker.SymbolName;
Added: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.resx
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.resx 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomLogosSectionCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomLogosSectionCtrl.Designer.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomLogosSectionCtrl.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -59,24 +59,29 @@
this.btnAdd.Image = global::Maestro.Editors.Properties.Resources.plus_circle;
this.btnAdd.ImageTransparentColor = System.Drawing.Color.Magenta;
this.btnAdd.Name = "btnAdd";
- this.btnAdd.Size = new System.Drawing.Size(46, 22);
+ this.btnAdd.Size = new System.Drawing.Size(49, 22);
this.btnAdd.Text = "Add";
+ this.btnAdd.Click += new System.EventHandler(this.btnAdd_Click);
// btnEdit
+ this.btnEdit.Enabled = false;
this.btnEdit.Image = global::Maestro.Editors.Properties.Resources.document__pencil;
this.btnEdit.ImageTransparentColor = System.Drawing.Color.Magenta;
this.btnEdit.Name = "btnEdit";
- this.btnEdit.Size = new System.Drawing.Size(45, 22);
+ this.btnEdit.Size = new System.Drawing.Size(47, 22);
this.btnEdit.Text = "Edit";
+ this.btnEdit.Click += new System.EventHandler(this.btnEdit_Click);
// btnDelete
+ this.btnDelete.Enabled = false;
this.btnDelete.Image = global::Maestro.Editors.Properties.Resources.cross_script;
this.btnDelete.ImageTransparentColor = System.Drawing.Color.Magenta;
this.btnDelete.Name = "btnDelete";
- this.btnDelete.Size = new System.Drawing.Size(58, 22);
+ this.btnDelete.Size = new System.Drawing.Size(60, 22);
this.btnDelete.Text = "Delete";
+ this.btnDelete.Click += new System.EventHandler(this.btnDelete_Click);
// lstCustomLogos
@@ -86,6 +91,8 @@
this.lstCustomLogos.Size = new System.Drawing.Size(449, 267);
this.lstCustomLogos.TabIndex = 2;
this.lstCustomLogos.UseCompatibleStateImageBehavior = false;
+ this.lstCustomLogos.View = System.Windows.Forms.View.Tile;
+ this.lstCustomLogos.SelectedIndexChanged += new System.EventHandler(this.lstCustomLogos_SelectedIndexChanged);
// PrintCustomLogosSectionCtrl
Modified: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomLogosSectionCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomLogosSectionCtrl.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomLogosSectionCtrl.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -25,15 +25,155 @@
using System.Text;
+using OSGeo.MapGuide.ObjectModels.PrintLayout;
[ToolboxItem(true)]
- internal partial class PrintCustomLogosSectionCtrl : CollapsiblePanel
+ internal partial class PrintCustomLogosSectionCtrl : EditorBindableCollapsiblePanel
public PrintCustomLogosSectionCtrl()
+ _logos = new BindingList<ILogo>();
+ private BindingList<ILogo> _logos;
+ private IPrintLayout _layout;
+ service.RegisterCustomNotifier(this);
+ _layout = (IPrintLayout)service.GetEditedResource();
+ _conn = _layout.CurrentConnection;
+ foreach (var logo in _layout.CustomLogos)
+ _logos.Add(logo);
+ AddLogoToListView(logo);
+ _logos.ListChanged += new ListChangedEventHandler(OnLogoListChanged);
+ void OnLogoListChanged(object sender, ListChangedEventArgs e)
+ switch (e.ListChangedType)
+ case ListChangedType.ItemAdded:
+ _layout.AddLogo(_logos[e.NewIndex]);
+ AddLogoToListView(_logos[e.NewIndex]);
+ break;
+ OnResourceChanged();
+ private void AddLogoToListView(ILogo logo)
+ var item = new ListViewItem(logo.Name);
+ item.Tag = logo;
+ //TODO: It would be really nice to show the actual
+ //symbol here
+ lstCustomLogos.Items.Add(item);
+ private void RemoveLogoFromListView(ILogo logo)
+ ListViewItem remove = null;
+ foreach (ListViewItem item in lstCustomLogos.Items)
+ if (item.Tag == logo)
+ remove = item;
+ break;
+ lstCustomLogos.Items.Remove(remove);
+ private void btnAdd_Click(object sender, EventArgs e)
+ using (var dlg = new LogoDialog(_conn))
+ if (dlg.ShowDialog() == DialogResult.OK)
+ var pos = _layout.CreateLogoPosition(dlg.PositionLeft, dlg.PositionBottom, dlg.PositionUnits);
+ var size = _layout.CreateLogoSize(dlg.SizeWidth, dlg.SizeHeight, dlg.SizeUnits);
+ var logo = _layout.CreateLogo(dlg.SymbolLibraryID, dlg.SymbolName, size, pos);
+ logo.Rotation = dlg.Rotation;
+ _logos.Add(logo);
+ private void btnEdit_Click(object sender, EventArgs e)
+ if (lstCustomLogos.SelectedItems.Count > 0)
+ var item = lstCustomLogos.SelectedItems[0];
+ var logo = item.Tag as ILogo;
+ if (logo != null)
+ dlg.SymbolLibraryID = logo.ResourceId;
+ dlg.SymbolName = logo.Name;
+ dlg.PositionBottom = logo.Position.Bottom;
+ dlg.PositionLeft = logo.Position.Left;
+ dlg.PositionUnits = logo.Position.Units;
+ dlg.SizeHeight = logo.Size.Height;
+ dlg.SizeUnits = logo.Size.Units;
+ dlg.SizeWidth = logo.Size.Width;
+ dlg.Rotation = logo.Rotation.HasValue ? logo.Rotation.Value : 0.0f;
+ logo.ResourceId = dlg.SymbolLibraryID;
+ logo.Name = dlg.SymbolName;
+ logo.Position.Bottom = dlg.PositionBottom;
+ logo.Position.Left = dlg.PositionLeft;
+ logo.Position.Units = dlg.PositionUnits;
+ logo.Size.Height = dlg.SizeHeight;
+ logo.Size.Units = dlg.SizeUnits;
+ logo.Size.Width = dlg.SizeWidth;
+ item.Text = logo.Name;
+ private void btnDelete_Click(object sender, EventArgs e)
+ if (logo != null)
+ _logos.Remove(logo);
+ //Have to remove manually due to brain-dead API design
+ //of BindingList<T>
+ _layout.RemoveLogo(logo);
+ RemoveLogoFromListView(logo);
+ private void lstCustomLogos_SelectedIndexChanged(object sender, EventArgs e)
+ btnEdit.Enabled = btnDelete.Enabled = (lstCustomLogos.SelectedItems.Count > 0);
Modified: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomTextSectionCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomTextSectionCtrl.Designer.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomTextSectionCtrl.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -32,7 +32,7 @@
this.btnAdd = new System.Windows.Forms.ToolStripButton();
this.btnEdit = new System.Windows.Forms.ToolStripButton();
this.btnDelete = new System.Windows.Forms.ToolStripButton();
- this.lstCustomText = new System.Windows.Forms.ListView();
+ this.lstCustomText = new System.Windows.Forms.ListBox();
this.contentPanel.SuspendLayout();
this.toolStrip1.SuspendLayout();
@@ -59,33 +59,39 @@
// btnEdit
// btnDelete
// lstCustomText
this.lstCustomText.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.lstCustomText.FormattingEnabled = true;
this.lstCustomText.Location = new System.Drawing.Point(0, 25);
this.lstCustomText.Name = "lstCustomText";
- this.lstCustomText.Size = new System.Drawing.Size(449, 267);
+ this.lstCustomText.Size = new System.Drawing.Size(449, 264);
this.lstCustomText.TabIndex = 1;
- this.lstCustomText.UseCompatibleStateImageBehavior = false;
+ this.lstCustomText.SelectedIndexChanged += new System.EventHandler(this.lstCustomText_SelectedIndexChanged);
// PrintCustomTextSectionCtrl
@@ -107,6 +113,6 @@
private System.Windows.Forms.ToolStripButton btnAdd;
private System.Windows.Forms.ToolStripButton btnEdit;
private System.Windows.Forms.ToolStripButton btnDelete;
- private System.Windows.Forms.ListView lstCustomText;
+ private System.Windows.Forms.ListBox lstCustomText;
Modified: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomTextSectionCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomTextSectionCtrl.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomTextSectionCtrl.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -25,15 +25,113 @@
using System.Text;
[ToolboxItem(true)]
- internal partial class PrintCustomTextSectionCtrl : CollapsiblePanel
+ internal partial class PrintCustomTextSectionCtrl : EditorBindableCollapsiblePanel
public PrintCustomTextSectionCtrl()
+ _texts = new BindingList<IText>();
+ lstCustomText.DisplayMember = "Value";
+ lstCustomText.DataSource = _texts;
+ private BindingList<IText> _texts;
+ //Init current defined text
+ foreach (var txt in _layout.CustomText)
+ if (txt.Value == null && txt.Font == null && txt.Position == null)
+ continue;
+ _texts.Add(txt);
+ //Now wire change listeners
+ _texts.ListChanged += new ListChangedEventHandler(OnTextListChanged);
+ void OnTextListChanged(object sender, ListChangedEventArgs e)
+ _layout.AddText(_texts[e.NewIndex]);
+ break;
+ using (var dlg = new TextDialog())
+ var pos = _layout.CreateTextPosition(dlg.PositionLeft, dlg.PositionBottom, dlg.PositionUnits);
+ var fnt = _layout.CreateFont(dlg.FontName, dlg.FontHeight, dlg.FontUnits);
+ var txt = _layout.CreateText(dlg.TextString, fnt, pos);
+ _texts.Add(txt);
+ var txt = lstCustomText.SelectedItem as IText;
+ if (txt != null)
+ dlg.TextString = txt.Value;
+ dlg.FontUnits = txt.Font.Units;
+ dlg.FontName = txt.Font.Name;
+ dlg.FontHeight = txt.Font.Height;
+ dlg.PositionBottom = txt.Position.Bottom;
+ dlg.PositionLeft = txt.Position.Left;
+ dlg.PositionUnits = txt.Position.Units;
+ txt.Value = dlg.TextString;
+ txt.Font.Units = dlg.FontUnits;
+ txt.Font.Name = dlg.FontName;
+ txt.Font.Height = dlg.FontHeight;
+ txt.Position.Bottom = dlg.PositionBottom;
+ txt.Position.Left = dlg.PositionLeft;
+ txt.Position.Units = dlg.PositionUnits;
+ if (txt != null)
+ _texts.Remove(txt);
+ _layout.RemoveText(txt);
+ private void lstCustomText_SelectedIndexChanged(object sender, EventArgs e)
+ btnEdit.Enabled = btnDelete.Enabled = (lstCustomText.SelectedItem != null);
Modified: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintLayoutEditorCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintLayoutEditorCtrl.Designer.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintLayoutEditorCtrl.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -28,65 +28,66 @@
/// </summary>
- this.printPagePropertiesSectionCtrl1 = new Maestro.Editors.PrintLayout.PrintPagePropertiesSectionCtrl();
- this.printCustomTextSectionCtrl1 = new Maestro.Editors.PrintLayout.PrintCustomTextSectionCtrl();
- this.printCustomLogosSectionCtrl1 = new Maestro.Editors.PrintLayout.PrintCustomLogosSectionCtrl();
+ this.printSettingsCtrl = new Maestro.Editors.PrintLayout.PrintPagePropertiesSectionCtrl();
+ this.printLogosCtrl = new Maestro.Editors.PrintLayout.PrintCustomLogosSectionCtrl();
+ this.printTextCtrl = new Maestro.Editors.PrintLayout.PrintCustomTextSectionCtrl();
- // printPagePropertiesSectionCtrl1
+ // printSettingsCtrl
- this.printPagePropertiesSectionCtrl1.ContentBackgroundColor = System.Drawing.SystemColors.Control;
- this.printPagePropertiesSectionCtrl1.Dock = System.Windows.Forms.DockStyle.Top;
- this.printPagePropertiesSectionCtrl1.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
- this.printPagePropertiesSectionCtrl1.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
- this.printPagePropertiesSectionCtrl1.HeaderText = "Page and Layout Properties";
- this.printPagePropertiesSectionCtrl1.Location = new System.Drawing.Point(0, 0);
- this.printPagePropertiesSectionCtrl1.Name = "printPagePropertiesSectionCtrl1";
- this.printPagePropertiesSectionCtrl1.Size = new System.Drawing.Size(536, 217);
- this.printPagePropertiesSectionCtrl1.TabIndex = 0;
+ this.printSettingsCtrl.ContentBackgroundColor = System.Drawing.SystemColors.Control;
+ this.printSettingsCtrl.Dock = System.Windows.Forms.DockStyle.Top;
+ this.printSettingsCtrl.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
+ this.printSettingsCtrl.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.printSettingsCtrl.HeaderText = "Page and Layout Properties";
+ this.printSettingsCtrl.Location = new System.Drawing.Point(0, 0);
+ this.printSettingsCtrl.Name = "printSettingsCtrl";
+ this.printSettingsCtrl.Size = new System.Drawing.Size(502, 217);
+ this.printSettingsCtrl.TabIndex = 0;
- // printCustomTextSectionCtrl1
+ // printLogosCtrl
- this.printCustomTextSectionCtrl1.ContentBackgroundColor = System.Drawing.SystemColors.Control;
- this.printCustomTextSectionCtrl1.Dock = System.Windows.Forms.DockStyle.Top;
- this.printCustomTextSectionCtrl1.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
- this.printCustomTextSectionCtrl1.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
- this.printCustomTextSectionCtrl1.HeaderText = "Custom Text";
- this.printCustomTextSectionCtrl1.Location = new System.Drawing.Point(0, 217);
- this.printCustomTextSectionCtrl1.Name = "printCustomTextSectionCtrl1";
- this.printCustomTextSectionCtrl1.Size = new System.Drawing.Size(536, 185);
- this.printCustomTextSectionCtrl1.TabIndex = 1;
+ this.printLogosCtrl.ContentBackgroundColor = System.Drawing.SystemColors.Control;
+ this.printLogosCtrl.Dock = System.Windows.Forms.DockStyle.Top;
+ this.printLogosCtrl.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
+ this.printLogosCtrl.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.printLogosCtrl.HeaderText = "Custom Logos";
+ this.printLogosCtrl.Location = new System.Drawing.Point(0, 217);
+ this.printLogosCtrl.Name = "printLogosCtrl";
+ this.printLogosCtrl.Size = new System.Drawing.Size(502, 319);
+ this.printLogosCtrl.TabIndex = 2;
- // printCustomLogosSectionCtrl1
+ // printTextCtrl
- this.printCustomLogosSectionCtrl1.ContentBackgroundColor = System.Drawing.SystemColors.Control;
- this.printCustomLogosSectionCtrl1.Dock = System.Windows.Forms.DockStyle.Top;
- this.printCustomLogosSectionCtrl1.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
- this.printCustomLogosSectionCtrl1.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
- this.printCustomLogosSectionCtrl1.HeaderText = "Custom Logos";
- this.printCustomLogosSectionCtrl1.Location = new System.Drawing.Point(0, 402);
- this.printCustomLogosSectionCtrl1.Name = "printCustomLogosSectionCtrl1";
- this.printCustomLogosSectionCtrl1.Size = new System.Drawing.Size(536, 188);
- this.printCustomLogosSectionCtrl1.TabIndex = 2;
+ this.printTextCtrl.ContentBackgroundColor = System.Drawing.SystemColors.Control;
+ this.printTextCtrl.Dock = System.Windows.Forms.DockStyle.Top;
+ this.printTextCtrl.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
+ this.printTextCtrl.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.printTextCtrl.HeaderText = "Custom Text";
+ this.printTextCtrl.Location = new System.Drawing.Point(0, 536);
+ this.printTextCtrl.Name = "printTextCtrl";
+ this.printTextCtrl.Size = new System.Drawing.Size(502, 319);
+ this.printTextCtrl.TabIndex = 3;
// PrintLayoutEditorCtrl
this.AutoScroll = true;
- this.Controls.Add(this.printCustomLogosSectionCtrl1);
- this.Controls.Add(this.printCustomTextSectionCtrl1);
- this.Controls.Add(this.printPagePropertiesSectionCtrl1);
+ this.Controls.Add(this.printTextCtrl);
+ this.Controls.Add(this.printLogosCtrl);
+ this.Controls.Add(this.printSettingsCtrl);
this.Name = "PrintLayoutEditorCtrl";
- this.Size = new System.Drawing.Size(536, 435);
+ this.Size = new System.Drawing.Size(502, 435);
#endregion
- private PrintPagePropertiesSectionCtrl printPagePropertiesSectionCtrl1;
- private PrintCustomTextSectionCtrl printCustomTextSectionCtrl1;
- private PrintCustomLogosSectionCtrl printCustomLogosSectionCtrl1;
+ private PrintPagePropertiesSectionCtrl printSettingsCtrl;
+ private PrintCustomLogosSectionCtrl printLogosCtrl;
+ private PrintCustomTextSectionCtrl printTextCtrl;
Modified: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintLayoutEditorCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintLayoutEditorCtrl.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintLayoutEditorCtrl.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -36,7 +36,9 @@
+ printSettingsCtrl.Bind(service);
+ printLogosCtrl.Bind(service);
+ printTextCtrl.Bind(service);
Modified: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintPagePropertiesSectionCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintPagePropertiesSectionCtrl.Designer.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintPagePropertiesSectionCtrl.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -30,26 +30,24 @@
this.bgColorPicker = new System.Windows.Forms.ColorDialog();
- this.txtBgColor = new System.Windows.Forms.TextBox();
- this.btnPickColor = new System.Windows.Forms.Button();
this.grpLayout = new System.Windows.Forms.GroupBox();
- this.chkTitle = new System.Windows.Forms.CheckBox();
- this.chkURL = new System.Windows.Forms.CheckBox();
- this.chkLegend = new System.Windows.Forms.CheckBox();
- this.chkDateTime = new System.Windows.Forms.CheckBox();
- this.chkScaleBar = new System.Windows.Forms.CheckBox();
- this.chkCustomLogos = new System.Windows.Forms.CheckBox();
- this.chkNorthArrow = new System.Windows.Forms.CheckBox();
this.chkCustomText = new System.Windows.Forms.CheckBox();
+ this.chkNorthArrow = new System.Windows.Forms.CheckBox();
+ this.chkCustomLogos = new System.Windows.Forms.CheckBox();
+ this.chkScaleBar = new System.Windows.Forms.CheckBox();
+ this.chkDateTime = new System.Windows.Forms.CheckBox();
+ this.chkLegend = new System.Windows.Forms.CheckBox();
+ this.chkURL = new System.Windows.Forms.CheckBox();
+ this.chkTitle = new System.Windows.Forms.CheckBox();
+ this.cmbBgColor = new Maestro.Editors.Common.ColorComboBox();
this.grpLayout.SuspendLayout();
// contentPanel
+ this.contentPanel.Controls.Add(this.cmbBgColor);
this.contentPanel.Controls.Add(this.grpLayout);
- this.contentPanel.Controls.Add(this.btnPickColor);
- this.contentPanel.Controls.Add(this.txtBgColor);
this.contentPanel.Controls.Add(this.label1);
this.contentPanel.Size = new System.Drawing.Size(449, 190);
@@ -62,23 +60,6 @@
this.label1.Text = "Background Color";
- // txtBgColor
- this.txtBgColor.Location = new System.Drawing.Point(114, 15);
- this.txtBgColor.Name = "txtBgColor";
- this.txtBgColor.ReadOnly = true;
- this.txtBgColor.Size = new System.Drawing.Size(123, 20);
- this.txtBgColor.TabIndex = 1;
- // btnPickColor
- this.btnPickColor.Location = new System.Drawing.Point(243, 13);
- this.btnPickColor.Name = "btnPickColor";
- this.btnPickColor.Size = new System.Drawing.Size(26, 23);
- this.btnPickColor.TabIndex = 2;
- this.btnPickColor.Text = "...";
- this.btnPickColor.UseVisualStyleBackColor = true;
// grpLayout
this.grpLayout.Controls.Add(this.chkCustomText);
@@ -96,36 +77,46 @@
this.grpLayout.TabStop = false;
this.grpLayout.Text = "Layout Visibility";
- // chkTitle
+ // chkCustomText
- this.chkTitle.AutoSize = true;
- this.chkTitle.Location = new System.Drawing.Point(19, 19);
- this.chkTitle.Name = "chkTitle";
- this.chkTitle.Size = new System.Drawing.Size(46, 17);
- this.chkTitle.TabIndex = 0;
- this.chkTitle.Text = "Title";
- this.chkTitle.UseVisualStyleBackColor = true;
+ this.chkCustomText.AutoSize = true;
+ this.chkCustomText.Location = new System.Drawing.Point(184, 90);
+ this.chkCustomText.Name = "chkCustomText";
+ this.chkCustomText.Size = new System.Drawing.Size(85, 17);
+ this.chkCustomText.TabIndex = 7;
+ this.chkCustomText.Text = "Custom Text";
+ this.chkCustomText.UseVisualStyleBackColor = true;
- // chkURL
+ // chkNorthArrow
- this.chkURL.AutoSize = true;
- this.chkURL.Location = new System.Drawing.Point(184, 19);
- this.chkURL.Name = "chkURL";
- this.chkURL.Size = new System.Drawing.Size(48, 17);
- this.chkURL.TabIndex = 1;
- this.chkURL.Text = "URL";
- this.chkURL.UseVisualStyleBackColor = true;
+ this.chkNorthArrow.AutoSize = true;
+ this.chkNorthArrow.Location = new System.Drawing.Point(19, 91);
+ this.chkNorthArrow.Name = "chkNorthArrow";
+ this.chkNorthArrow.Size = new System.Drawing.Size(82, 17);
+ this.chkNorthArrow.TabIndex = 6;
+ this.chkNorthArrow.Text = "North Arrow";
+ this.chkNorthArrow.UseVisualStyleBackColor = true;
- // chkLegend
+ // chkCustomLogos
- this.chkLegend.AutoSize = true;
- this.chkLegend.Location = new System.Drawing.Point(19, 43);
- this.chkLegend.Name = "chkLegend";
- this.chkLegend.Size = new System.Drawing.Size(62, 17);
- this.chkLegend.TabIndex = 2;
- this.chkLegend.Text = "Legend";
- this.chkLegend.UseVisualStyleBackColor = true;
+ this.chkCustomLogos.AutoSize = true;
+ this.chkCustomLogos.Location = new System.Drawing.Point(184, 66);
+ this.chkCustomLogos.Name = "chkCustomLogos";
+ this.chkCustomLogos.Size = new System.Drawing.Size(93, 17);
+ this.chkCustomLogos.TabIndex = 5;
+ this.chkCustomLogos.Text = "Custom Logos";
+ this.chkCustomLogos.UseVisualStyleBackColor = true;
+ // chkScaleBar
+ this.chkScaleBar.AutoSize = true;
+ this.chkScaleBar.Location = new System.Drawing.Point(19, 67);
+ this.chkScaleBar.Name = "chkScaleBar";
+ this.chkScaleBar.Size = new System.Drawing.Size(72, 17);
+ this.chkScaleBar.TabIndex = 4;
+ this.chkScaleBar.Text = "Scale Bar";
+ this.chkScaleBar.UseVisualStyleBackColor = true;
// chkDateTime
this.chkDateTime.AutoSize = true;
@@ -136,45 +127,43 @@
this.chkDateTime.Text = "Date/Time";
this.chkDateTime.UseVisualStyleBackColor = true;
- // chkScaleBar
+ // chkLegend
- this.chkScaleBar.AutoSize = true;
- this.chkScaleBar.Location = new System.Drawing.Point(19, 67);
- this.chkScaleBar.Name = "chkScaleBar";
- this.chkScaleBar.Size = new System.Drawing.Size(72, 17);
- this.chkScaleBar.TabIndex = 4;
- this.chkScaleBar.Text = "Scale Bar";
- this.chkScaleBar.UseVisualStyleBackColor = true;
+ this.chkLegend.AutoSize = true;
+ this.chkLegend.Location = new System.Drawing.Point(19, 43);
+ this.chkLegend.Name = "chkLegend";
+ this.chkLegend.Size = new System.Drawing.Size(62, 17);
+ this.chkLegend.TabIndex = 2;
+ this.chkLegend.Text = "Legend";
+ this.chkLegend.UseVisualStyleBackColor = true;
- // chkCustomLogos
+ // chkURL
- this.chkCustomLogos.AutoSize = true;
- this.chkCustomLogos.Location = new System.Drawing.Point(184, 66);
- this.chkCustomLogos.Name = "chkCustomLogos";
- this.chkCustomLogos.Size = new System.Drawing.Size(93, 17);
- this.chkCustomLogos.TabIndex = 5;
- this.chkCustomLogos.Text = "Custom Logos";
- this.chkCustomLogos.UseVisualStyleBackColor = true;
+ this.chkURL.AutoSize = true;
+ this.chkURL.Location = new System.Drawing.Point(184, 19);
+ this.chkURL.Name = "chkURL";
+ this.chkURL.Size = new System.Drawing.Size(48, 17);
+ this.chkURL.TabIndex = 1;
+ this.chkURL.Text = "URL";
+ this.chkURL.UseVisualStyleBackColor = true;
- // chkNorthArrow
+ // chkTitle
- this.chkNorthArrow.AutoSize = true;
- this.chkNorthArrow.Location = new System.Drawing.Point(19, 91);
- this.chkNorthArrow.Name = "chkNorthArrow";
- this.chkNorthArrow.Size = new System.Drawing.Size(82, 17);
- this.chkNorthArrow.TabIndex = 6;
- this.chkNorthArrow.Text = "North Arrow";
- this.chkNorthArrow.UseVisualStyleBackColor = true;
+ this.chkTitle.AutoSize = true;
+ this.chkTitle.Location = new System.Drawing.Point(19, 19);
+ this.chkTitle.Name = "chkTitle";
+ this.chkTitle.Size = new System.Drawing.Size(46, 17);
+ this.chkTitle.TabIndex = 0;
+ this.chkTitle.Text = "Title";
+ this.chkTitle.UseVisualStyleBackColor = true;
- // chkCustomText
+ // cmbBgColor
- this.chkCustomText.AutoSize = true;
- this.chkCustomText.Location = new System.Drawing.Point(184, 90);
- this.chkCustomText.Name = "chkCustomText";
- this.chkCustomText.Size = new System.Drawing.Size(85, 17);
- this.chkCustomText.TabIndex = 7;
- this.chkCustomText.Text = "Custom Text";
- this.chkCustomText.UseVisualStyleBackColor = true;
+ this.cmbBgColor.FormattingEnabled = true;
+ this.cmbBgColor.Location = new System.Drawing.Point(130, 15);
+ this.cmbBgColor.Name = "cmbBgColor";
+ this.cmbBgColor.Size = new System.Drawing.Size(121, 21);
+ this.cmbBgColor.TabIndex = 4;
// PrintPagePropertiesSectionCtrl
@@ -204,7 +193,6 @@
private System.Windows.Forms.CheckBox chkLegend;
private System.Windows.Forms.CheckBox chkURL;
private System.Windows.Forms.CheckBox chkTitle;
- private System.Windows.Forms.Button btnPickColor;
- private System.Windows.Forms.TextBox txtBgColor;
+ private Maestro.Editors.Common.ColorComboBox cmbBgColor;
Modified: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintPagePropertiesSectionCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintPagePropertiesSectionCtrl.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintPagePropertiesSectionCtrl.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -25,15 +25,47 @@
using System.Text;
[ToolboxItem(true)]
- internal partial class PrintPagePropertiesSectionCtrl : CollapsiblePanel
+ internal partial class PrintPagePropertiesSectionCtrl : EditorBindableCollapsiblePanel
public PrintPagePropertiesSectionCtrl()
+ public override void Bind(IEditorService service)
+ cmbBgColor.ResetColors();
+ //ColorComboBox requires custom databinding
+ cmbBgColor.CurrentColor = _layout.PageProperties.BackgroundColor;
+ cmbBgColor.SelectedIndexChanged += (sender, e) =>
+ _layout.PageProperties.BackgroundColor = cmbBgColor.CurrentColor;
+ _layout.LayoutProperties.PropertyChanged += (sender, e) =>
+ CheckBoxBinder.BindChecked(chkCustomLogos, _layout.LayoutProperties, "ShowCustomLogos");
+ CheckBoxBinder.BindChecked(chkCustomText, _layout.LayoutProperties, "ShowCustomText");
+ CheckBoxBinder.BindChecked(chkDateTime, _layout.LayoutProperties, "ShowDateTime");
+ CheckBoxBinder.BindChecked(chkLegend, _layout.LayoutProperties, "ShowLegend");
+ CheckBoxBinder.BindChecked(chkNorthArrow, _layout.LayoutProperties, "ShowNorthArrow");
+ CheckBoxBinder.BindChecked(chkScaleBar, _layout.LayoutProperties, "ShowScaleBar");
+ CheckBoxBinder.BindChecked(chkTitle, _layout.LayoutProperties, "ShowTitle");
+ CheckBoxBinder.BindChecked(chkURL, _layout.LayoutProperties, "ShowURL");
Added: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,303 @@
+ partial class TextDialog
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ this.btnBrowseFontName = new System.Windows.Forms.Button();
+ this.txtFontName = new System.Windows.Forms.TextBox();
+ this.numFontHeight = new System.Windows.Forms.NumericUpDown();
+ this.cmbFontUnits = new System.Windows.Forms.ComboBox();
+ this.txtContent = new System.Windows.Forms.TextBox();
+ ((System.ComponentModel.ISupportInitialize)(this.numFontHeight)).BeginInit();
+ // groupBox2
+ this.groupBox2.Controls.Add(this.btnBrowseFontName);
+ this.groupBox2.Controls.Add(this.txtFontName);
+ this.groupBox2.Controls.Add(this.numFontHeight);
+ this.groupBox2.Controls.Add(this.cmbFontUnits);
+ this.groupBox2.Location = new System.Drawing.Point(219, 109);
+ this.groupBox2.Size = new System.Drawing.Size(200, 110);
+ this.groupBox2.TabIndex = 5;
+ this.groupBox2.Text = "Font";
+ // btnBrowseFontName
+ this.btnBrowseFontName.Location = new System.Drawing.Point(159, 16);
+ this.btnBrowseFontName.Name = "btnBrowseFontName";
+ this.btnBrowseFontName.Size = new System.Drawing.Size(26, 23);
+ this.btnBrowseFontName.TabIndex = 2;
+ this.btnBrowseFontName.Text = "...";
+ this.btnBrowseFontName.UseVisualStyleBackColor = true;
+ this.btnBrowseFontName.Click += new System.EventHandler(this.btnBrowseFontName_Click);
+ // txtFontName
+ this.txtFontName.Location = new System.Drawing.Point(65, 18);
+ this.txtFontName.Name = "txtFontName";
+ this.txtFontName.Size = new System.Drawing.Size(88, 20);
+ this.txtFontName.TabIndex = 12;
+ // label6
+ // label7
+ // numFontHeight
+ this.numFontHeight.DecimalPlaces = 2;
+ this.numFontHeight.Location = new System.Drawing.Point(65, 46);
+ this.numFontHeight.Name = "numFontHeight";
+ this.numFontHeight.Size = new System.Drawing.Size(120, 20);
+ this.numFontHeight.TabIndex = 7;
+ // label8
+ this.label8.Text = "Name";
+ // cmbFontUnits
+ this.cmbFontUnits.FormattingEnabled = true;
+ this.cmbFontUnits.Location = new System.Drawing.Point(65, 73);
+ this.cmbFontUnits.Name = "cmbFontUnits";
+ this.cmbFontUnits.Size = new System.Drawing.Size(120, 21);
+ this.cmbFontUnits.TabIndex = 8;
+ // groupBox1
+ this.groupBox1.Location = new System.Drawing.Point(13, 109);
+ this.groupBox1.Size = new System.Drawing.Size(200, 110);
+ this.groupBox1.TabIndex = 4;
+ // label5
+ // label4
+ this.label4.Location = new System.Drawing.Point(22, 48);
+ // label3
+ // numPosBottom
+ this.numPosBottom.Location = new System.Drawing.Point(74, 46);
+ // numPosLeft
+ // btnOK
+ this.btnOK.Location = new System.Drawing.Point(262, 228);
+ this.btnOK.TabIndex = 13;
+ // btnCancel
+ this.btnCancel.Location = new System.Drawing.Point(343, 228);
+ this.btnCancel.TabIndex = 12;
+ // groupBox3
+ this.groupBox3.Controls.Add(this.txtContent);
+ this.groupBox3.Size = new System.Drawing.Size(405, 90);
+ this.groupBox3.TabIndex = 14;
+ this.groupBox3.Text = "Text";
+ // txtContent
+ this.txtContent.Location = new System.Drawing.Point(73, 24);
+ this.txtContent.Multiline = true;
+ this.txtContent.Name = "txtContent";
+ this.txtContent.Size = new System.Drawing.Size(317, 49);
+ this.txtContent.TabIndex = 1;
+ // label1
+ this.label1.Location = new System.Drawing.Point(21, 27);
+ this.label1.Size = new System.Drawing.Size(44, 13);
+ this.label1.Text = "Content";
+ // TextDialog
+ this.ClientSize = new System.Drawing.Size(430, 263);
+ this.Name = "TextDialog";
+ this.Text = "Text Element";
+ ((System.ComponentModel.ISupportInitialize)(this.numFontHeight)).EndInit();
+ #endregion
+ private System.Windows.Forms.NumericUpDown numFontHeight;
+ private System.Windows.Forms.ComboBox cmbFontUnits;
+ private System.Windows.Forms.Button btnBrowseFontName;
+ private System.Windows.Forms.TextBox txtFontName;
+ private System.Windows.Forms.TextBox txtContent;
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.cs
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,102 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+ public partial class TextDialog : Form
+ public TextDialog()
+ public string TextString
+ get { return txtContent.Text; }
+ set { txtContent.Text = value; }
+ public string FontName
+ get { return txtFontName.Text; }
+ set { txtFontName.Text = value; }
+ public float FontHeight
+ get { return Convert.ToSingle(numFontHeight.Value); }
+ set { numFontHeight.Value = Convert.ToDecimal(value); }
+ public string FontUnits
+ get { return cmbFontUnits.Text; }
+ set { cmbFontUnits.Text = value; }
+ private void btnBrowseFontName_Click(object sender, EventArgs e)
+ using (var dlg = new FontDialog())
+ this.FontName = dlg.Font.Name;
+ this.FontHeight = dlg.Font.Height;
+ this.FontUnits = "points";
Added: sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.resx
--- sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.resx 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -172,6 +172,15 @@
/// <summary>
+ /// Looks up a localized string similar to Base Layer Group.
+ /// </summary>
+ internal static string BaseLayerGroup {
+ get {
+ return ResourceManager.GetString("BaseLayerGroup", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Between {0} and {1}.
/// </summary>
internal static string BetweenLabel {
@@ -274,6 +283,15 @@
/// <summary>
+ /// Looks up a localized string similar to Confirm.
+ /// </summary>
+ internal static string Confirm {
+ get {
+ return ResourceManager.GetString("Confirm", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to The content file does not exist.
/// </summary>
internal static string ContentFileMissing {
@@ -1461,6 +1479,13 @@
+ internal static System.Drawing.Bitmap map__arrow {
+ get {
+ object obj = ResourceManager.GetObject("map--arrow", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
internal static System.Drawing.Bitmap MgCooker {
get {
object obj = ResourceManager.GetObject("MgCooker", resourceCulture);
@@ -1521,6 +1546,24 @@
/// <summary>
+ /// Looks up a localized string similar to New Layer.
+ /// </summary>
+ internal static string NewLayer {
+ get {
+ return ResourceManager.GetString("NewLayer", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to New Layer Group.
+ /// </summary>
+ internal static string NewLayerGroup {
+ get {
+ return ResourceManager.GetString("NewLayerGroup", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to No active resource data file selected.
/// </summary>
internal static string NoActiveDataFile {
@@ -1595,6 +1638,15 @@
/// <summary>
+ /// Looks up a localized string similar to Overwrite the current display scales?.
+ /// </summary>
+ internal static string OverwriteDisplayScales {
+ get {
+ return ResourceManager.GetString("OverwriteDisplayScales", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to This resource already exists, continue with save?.
/// </summary>
internal static string OverwriteResource {
@@ -1785,6 +1837,15 @@
/// <summary>
+ /// Looks up a localized string similar to Please specify the symbol library first.
+ /// </summary>
+ internal static string SelectSymbolLibraryFirst {
+ get {
+ return ResourceManager.GetString("SelectSymbolLibraryFirst", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Sequential.
/// </summary>
internal static string SequentialName {
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-10-18 07:16:47 UTC (rev 5289)
@@ -118,811 +118,832 @@
</resheader>
<assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
- <data name="exclamation" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\exclamation.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="scissors-blue" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\scissors-blue.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="plus-circle" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\plus-circle.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="ColorCountError" xml:space="preserve">
+ <value>Failed to read {0} color(s) in line {1}</value>
+ <comment>An error message that is displayed if the expected color count does not match the actual count</comment>
</data>
- <data name="application-search-result" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\application-search-result.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="minus-circle" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\minus-circle.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="document--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\document--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_tasks" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_tasks.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="layer--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\layer--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="application--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\application--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="XmlDocIsValid" xml:space="preserve">
- <value>Document is valid</value>
+ <data name="DataReadError" xml:space="preserve">
+ <value>Unable to read data from the selected column: {0}</value>
+ <comment>An error message that is displayed when the column read fails</comment>
</data>
- <data name="globe--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\globe--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_invokeurl_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_invokeurl_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="application-import" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\application-import.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="MoreThanLabel" xml:space="preserve">
+ <value>More than {0}</value>
+ <comment>The label used for the highest value in the graduated theme set</comment>
</data>
- <data name="InfiniteValue" xml:space="preserve">
- <value>infinite</value>
- <comment>A value that is displayed when the value assigned is infinite</comment>
+ <data name="icon_selectpolygon_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_selectpolygon_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="sql" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\sql.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="tick-circle-frame" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\tick-circle-frame.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FindEmptyString" xml:space="preserve">
- <value>Cannot Find an Empty String</value>
+ <data name="application--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\application--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="property" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\property.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_printablepage_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_printablepage_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="edit-indent" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\edit-indent.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_refreshmap_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_refreshmap_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="tick" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\tick.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="block" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\block.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="control" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\control.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_print" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_print.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="application-export" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\application-export.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_forward_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_forward_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="arrow-270" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\arrow-270.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="SaveResourceFirst" xml:space="preserve">
+ <value>Please save this resource first</value>
</data>
- <data name="databases-relation" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\databases-relation.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="layer" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\layer.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="layer--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\layer--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="control" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\control.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="arrow-return-180" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\arrow-return-180.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_zoomout_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomout_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="XmlEditorCursorTemplate" xml:space="preserve">
- <value>Line {0}, Column {1}</value>
+ <data name="PackageReadError" xml:space="preserve">
+ <value>Failed to read package. Error message was: {0}</value>
+ <comment>A message displayed when the package could not be read</comment>
</data>
- <data name="sql-join-right" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\sql-join-right.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="sql-join-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\sql-join-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="clipboard-paste" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\clipboard-paste.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="document--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\document--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="sql-join" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\sql-join.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="magnifier" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\magnifier.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="tick-circle-frame" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\tick-circle-frame.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_zoomin_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomin_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="NoColumnValuesError" xml:space="preserve">
- <value>No values found in selected column</value>
- <comment>A message displayed when the column has no values</comment>
+ <data name="grid" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\grid.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="layers-stack-arrange" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\layers-stack-arrange.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
- <data name="control-stop-square" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\control-stop-square.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="document--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\document--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="arrow-curve" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\arrow-curve.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="table--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\table--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FunctionTooltip" xml:space="preserve">
- <value>Function: {1}({2})
-Description: {3}
-Returns: {0}</value>
- <comment>The tooltip displayed in the text editor when the cursor is over a function name</comment>
+ <data name="cross-circle-frame" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\cross-circle-frame.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="minus-circle" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\minus-circle.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="AggregateQuery" xml:space="preserve">
+ <value>Aggregate Query</value>
</data>
- <data name="scissors-blue" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\scissors-blue.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="server" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\server.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="TitleError" xml:space="preserve">
- <value>Error</value>
+ <data name="icon_printablepage" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_printablepage.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="TransparentName" xml:space="preserve">
- <value>Transparent</value>
+ <data name="InfiniteValue" xml:space="preserve">
+ <value>infinite</value>
+ <comment>A value that is displayed when the value assigned is infinite</comment>
</data>
- <data name="globe--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\globe--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="OperationCompleted" xml:space="preserve">
+ <value>Operation Completed</value>
</data>
- <data name="FindReplaceNothing" xml:space="preserve">
- <value>Nothing to replace</value>
+ <data name="arrow-return-180" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-return-180.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="server" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\server.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="InvalidResourceId" xml:space="preserve">
+ <value>Not a valid resource identifier</value>
</data>
- <data name="block" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\block.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="layers-stack-arrange" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\layers-stack-arrange.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="application--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\application--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_selectwithin_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_selectwithin_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="globe--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\globe--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="layer--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\layer--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="table" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\table.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="question" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\question.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="arrow-circle-135" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\arrow-circle-135.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_zoomin" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomin.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="layer--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\layer--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="ui_menu" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\ui-menu.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
- <data name="MgCooker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAHrSURBVDhPhZLtS1NhGMb9T/rQx6ACyUVDyQjDaKAGQYOB
- Ew2K9ilifrA+LDAMablFb1IM03DbMXMwj4O15VZ5iPly2Go0yzCzF0iwr4OdX3seOxK1owcunofzPPfv
- vq77nLo6i2d44j0Xb8elgk90rO7VfN80dB13coLmyUFalCMcHjvJ+fBnHkdLu4Psty5wKhZgz9022tUw
- 9oiHpuQy+1IG7umNnQGdfkV2bA4fq3ZtpCP+EI9u4NAM6mMJDkaDuPoj1pCGgUt/LDfiSYV4sFzGm6/g
- zBkcGOtj/4gTm/+cNeBqvIBttIeexDDqlwqhjxX6ixVcc1/lHITawn5rwBVlVRa0x4ZoVc7i1V5JBx3p
- nIwk4wU6rQG+e3m8ehlnMrodxaGOc+K1gS21waHRMzh6B3cepHDRrf2UHe3jp2mZXaf+hcHeRBnxeXf9
- H4L3Z3HfnOJoyMVxtUSD+ovW55t03SnguzZNOp2xhiws6GjaPJPPXnLDn8Hnn6NvIMvl3qcEApHq2Rsp
- SxcCUHj7QUrsTaAo0vUSi0vv5JklxCwUl0Wxuf4NE3vLGCuf1rdtii7Z7JZlASoWV1G6uslEpsjlFmvH
- WFv7wcxM6j8JZ9++bzL/aISV/Ja7mnNYqmY07YouQubg/l1NwG/XLb2y/7oFegAAAABJRU5ErkJggg==
-</value>
+ <data name="icon_clearselect" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_clearselect.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="TestConnectionNoErrors" xml:space="preserve">
- <value>Provider reported no errors</value>
+ <data name="icon_help_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_help_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="magnifier" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\magnifier.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_panleft" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_panleft.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="sort-number" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\sort-number.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_popupscrolldown_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_popupscrolldown_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="arrow-090" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\arrow-090.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="InvokeScriptCmdDescription" xml:space="preserve">
+ <value>Invoke Script Command</value>
</data>
<data name="globe--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\globe--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="application--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\application--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="drive-download" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\drive-download.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="document-copy" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\document-copy.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="QualitativeName" xml:space="preserve">
+ <value>Qualitative</value>
+ <comment>A display name for the Qualitative data type</comment>
</data>
- <data name="FileDownloaded" xml:space="preserve">
- <value>File Downloaded</value>
+ <data name="funnel" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\funnel.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="function" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\function.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="sort-number" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\sort-number.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="folder--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\folder--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_selectwithin" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_selectwithin.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="sum" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\sum.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="sql-join-right" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\sql-join-right.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="MoreColorsName" xml:space="preserve">
- <value>More colors...</value>
+ <data name="icon_popupscrollup_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_popupscrollup_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="InvalidValueError" xml:space="preserve">
- <value>Invalid value</value>
- <comment>An error message that is displayed when the entered value is invalid</comment>
+ <data name="OperationCancelled" xml:space="preserve">
+ <value>Operation Cancelled</value>
</data>
- <data name="cross" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\cross.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="TooMuchDataWarning" xml:space="preserve">
+ <value>The selected column contains more than {0} different values.
+The calculated averages only accounts for the first {0} distinct values.</value>
+ <comment>A warning message that is displayed if the dataset is too large</comment>
</data>
- <data name="drive-upload" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\drive-upload.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="TooManyRulesWarning" xml:space="preserve">
+ <value>You are creating a large number of rules, this will likely result in Maestro becoming unresponsive.
+Do you want to continue?</value>
+ <comment>A warning message that is displayed if the user has selected options that will generate a very large number of rules</comment>
</data>
- <data name="cross-script" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\cross-script.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FiniteDisplayScales" xml:space="preserve">
+ <value>Finite Display Scales</value>
</data>
- <data name="cross-circle-frame" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\cross-circle-frame.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="ruler" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\ruler.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="layer" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\layer.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="document-copy" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\document-copy.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="arrow-curve-180-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\arrow-curve-180-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="InvalidRestorePathError" xml:space="preserve">
+ <value>An error occured while validating the restore path: {0}\nIt should have the format: \"Libray://folder/folder/\".</value>
+ <comment>A message that is displayed when the restore path does not validate</comment>
</data>
- <data name="ColumnValueError" xml:space="preserve">
- <value>An error occured while reading column values: {0}</value>
- <comment>An error message that is displayed when the column values could not be read</comment>
+ <data name="NoFolderSelected" xml:space="preserve">
+ <value>You have not selected a starting folder, do you want to back up the entire site?</value>
+ <comment>A message that is displayed when the user has not selected a folder to create a folder from</comment>
</data>
- <data name="drive-download" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\drive-download.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_measure_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_measure_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="sql-join-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\sql-join-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="DeleteConfirmation" xml:space="preserve">
+ <value>Do you want to remove the selected item?</value>
+ <comment>A confirmation message displayed when deleting a resource</comment>
</data>
- <data name="database--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\database--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_fitwindow" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_fitwindow.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="script--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\script--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="SaveResource" xml:space="preserve">
+ <value>Save Resource</value>
</data>
- <data name="folder_horizontal" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\folder-horizontal.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_popupscrollup" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_popupscrollup.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FindNothing" xml:space="preserve">
- <value>Could not find specified string or end of document reached</value>
+ <data name="icon_panright_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_panright_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="document--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\document--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="RdbmsFeatureSource" xml:space="preserve">
+ <value>RDBMS Feature Source</value>
</data>
- <data name="table--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\table--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="EmptyText" xml:space="preserve">
+ <value>None</value>
+ <comment>The text used for rendering examples with no text data</comment>
</data>
- <data name="folder--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\folder--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="TestConnectionNoErrors" xml:space="preserve">
+ <value>Provider reported no errors</value>
</data>
- <data name="layers-stack-arrange-back" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\layers-stack-arrange-back.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_zoomrect" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomrect.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="funnel" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\funnel.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_selectpolygon" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_selectpolygon.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FiniteDisplayScales" xml:space="preserve">
- <value>Finite Display Scales</value>
+ <data name="FileDownloaded" xml:space="preserve">
+ <value>File Downloaded</value>
</data>
- <data name="PropertyTooltip" xml:space="preserve">
- <value>Property: {0}
-Type: {1}</value>
- <comment>The tooltip displayed in the text editor when the cursor is over a property</comment>
+ <data name="NoTypesSelected" xml:space="preserve">
+ <value>You must select at least one type</value>
+ <comment>A message that is displayed when the user has not selected any resource types</comment>
</data>
- <data name="sql-join-inner" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\sql-join-inner.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="application-search-result" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\application-search-result.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="grid" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\grid.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
- <data name="ruler" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\ruler.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
- <data name="ExtendedClassTooltip" xml:space="preserve">
- <value>Extended class based on: {0}</value>
- </data>
- <data name="CommandTypesDataset" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\CommandTypesDataset.xml;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;utf-8</value>
- </data>
<data name="GeometryStyleComboDataset" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\GeometryStyleComboDataset.xml;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
</data>
- <data name="ExpressionItem" xml:space="preserve">
- <value>Expression...</value>
- <comment>A value displayed in the combobox to activate the expression builder</comment>
+ <data name="globe--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\globe--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="EmptyText" xml:space="preserve">
- <value>None</value>
- <comment>The text used for rendering examples with no text data</comment>
+ <data name="icon_plotdwf" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_plotdwf.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="ColorCountError" xml:space="preserve">
- <value>Failed to read {0} color(s) in line {1}</value>
- <comment>An error message that is displayed if the expected color count does not match the actual count</comment>
+ <data name="UnknownResourceTypes" xml:space="preserve">
+ <value>Unknown types</value>
+ <comment>The list entry that represents unknown resource types</comment>
</data>
- <data name="DivergingName" xml:space="preserve">
- <value>Diverging</value>
- <comment>A display name for the Diverging data type</comment>
+ <data name="icon_panright" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_panright.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="InvalidColorComponent" xml:space="preserve">
- <value>Invalid {0} color component {1} in line {2}</value>
- <comment>An error message that is displayed if a color component is outside the [0-255] range.
-{0} is the color component, eg. R, G or B
-{1} is the value read
-{2} is the line where the error was encountered</comment>
+ <data name="PackageCreationFailedError" xml:space="preserve">
+ <value>Failed to create package, error message: {0}</value>
+ <comment>A message displayed when the package creation fails</comment>
</data>
- <data name="InvalidFieldCountError" xml:space="preserve">
- <value>Invalid field count in line {0}</value>
- <comment>An error message that is displayed if the file has an invalid field count</comment>
+ <data name="icon_home" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_home.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="InvalidRecordCountError" xml:space="preserve">
- <value>Invalid record count in line {0}</value>
- <comment>An error message that is displayed if the file has an invalid error count</comment>
+ <data name="icon_restorecenter_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_restorecenter_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="MissingColumnError" xml:space="preserve">
- <value>Missing column "{0}"</value>
- <comment>An error message that is displayed if the file is missing a required column</comment>
+ <data name="icon_tasks_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_tasks_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="QualitativeName" xml:space="preserve">
- <value>Qualitative</value>
- <comment>A display name for the Qualitative data type</comment>
+ <data name="icon_zoomout" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomout.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="SequentialName" xml:space="preserve">
- <value>Sequential</value>
- <comment>A display name for the Sequential data type</comment>
+ <data name="ExtendedClassTooltip" xml:space="preserve">
+ <value>Extended class based on: {0}</value>
</data>
- <data name="BetweenLabel" xml:space="preserve">
- <value>Between {0} and {1}</value>
- <comment>The label used for all "between" values in the graduated theme set</comment>
- </data>
- <data name="ColumnHasNoValidDataError" xml:space="preserve">
- <value>The selected column had no non-null values and cannot be used.</value>
- <comment>An error message that is displayed if the user selects a column with no valid data</comment>
- </data>
- <data name="DataReadError" xml:space="preserve">
- <value>Unable to read data from the selected column: {0}</value>
- <comment>An error message that is displayed when the column read fails</comment>
- </data>
<data name="GenericError" xml:space="preserve">
<value>An error occured: {0}</value>
<comment>An error message that is displayed when an unexpected error occurs</comment>
</data>
- <data name="InvalidColumnNameError" xml:space="preserve">
- <value>Invalid column name</value>
- <comment>An error message that is displayed when the column selected does not exist</comment>
+ <data name="icon_pan" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_pan.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="LessThanLabel" xml:space="preserve">
- <value>Less than {0}</value>
- <comment>The label used for the lowest value in the graduated theme set</comment>
+ <data name="icon_viewoptions" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_viewoptions.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="MoreThanLabel" xml:space="preserve">
- <value>More than {0}</value>
- <comment>The label used for the highest value in the graduated theme set</comment>
+ <data name="icon_zoomselect" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomselect.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="SelectColumnPlaceholder" xml:space="preserve">
- <value><Select column></value>
- <comment>A placeholder message displayed when the user has not yet selected a column</comment>
+ <data name="FailEnumDataStores" xml:space="preserve">
+ <value>Failed to enumerate data stores. Reason: {0}</value>
</data>
- <data name="TooManyIndiviualValuesError" xml:space="preserve">
- <value>The selected column contains more than {0} different values, and thus cannot be used for theming with individual values</value>
- <comment>An error message that is displayed if the selected column has too many distinct values</comment>
+ <data name="drive-upload" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\drive-upload.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="TooManyRulesWarning" xml:space="preserve">
- <value>You are creating a large number of rules, this will likely result in Maestro becoming unresponsive.
-Do you want to continue?</value>
- <comment>A warning message that is displayed if the user has selected options that will generate a very large number of rules</comment>
+ <data name="application-import" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\application-import.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="TooManyValuesError" xml:space="preserve">
- <value>The selected column contains more than {0} different values, and thus cannot be used for theming</value>
+ <data name="MoreColorsName" xml:space="preserve">
+ <value>More colors...</value>
</data>
- <data name="TooMuchDataWarning" xml:space="preserve">
- <value>The selected column contains more than {0} different values.
-The calculated averages only accounts for the first {0} distinct values.</value>
- <comment>A warning message that is displayed if the dataset is too large</comment>
+ <data name="globe--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\globe--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="OutputFileMissing" xml:space="preserve">
+ <value>You must enter a full path to the output file</value>
+ <comment>A message that is displayed when the user has not entered an output file</comment>
+ </data>
<data name="FontPreviewError" xml:space="preserve">
<value>Cannot Preview Font "{0}"</value>
<comment>An error message that is displayed when the rendering fails, using the specified font</comment>
</data>
- <data name="InsertionPointYError" xml:space="preserve">
- <value>You have entered a non-numeric value in the Reference Y field. Due to a bug in MapGuide, this will likely give an error when saving.</value>
- <comment>An error message that is displayed if the user attempts to use an expression as the InsertionPointY value (caused by an xsd bug in MapGuide)</comment>
+ <data name="ExpressionItem" xml:space="preserve">
+ <value>Expression...</value>
+ <comment>A value displayed in the combobox to activate the expression builder</comment>
</data>
- <data name="SymbolTypeNotSupported" xml:space="preserve">
- <value>Only symbols of type "Mark" and "Font" are currently supported</value>
- <comment>A message that is displayed when the user attempts to modify an item with an unsupported type</comment>
+ <data name="databases-relation" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\databases-relation.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="ColorBrewer" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\ColorBrewer.csv;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ <data name="icon_zoomnext" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomnext.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="InvokeScriptCmdDescription" xml:space="preserve">
- <value>Invoke Script Command</value>
+ <data name="arrow-curve-180-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-curve-180-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="InvokeUrlCmdDescription" xml:space="preserve">
- <value>Invoke URL command</value>
+ <data name="icon_refreshmap" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_refreshmap.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="SearchCmdDescription" xml:space="preserve">
- <value>Search Command</value>
+ <data name="SequentialName" xml:space="preserve">
+ <value>Sequential</value>
+ <comment>A display name for the Sequential data type</comment>
</data>
- <data name="DeleteCommand" xml:space="preserve">
- <value>Delete Command</value>
- </data>
<data name="PromptDeleteCommand" xml:space="preserve">
<value>This command is referenced in the following menus: {0}. Do you want to delete this command and all menu items referencing it?</value>
</data>
- <data name="ui_menu" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\ui-menu.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="InsertionPointYError" xml:space="preserve">
+ <value>You have entered a non-numeric value in the Reference Y field. Due to a bug in MapGuide, this will likely give an error when saving.</value>
+ <comment>An error message that is displayed if the user attempts to use an expression as the InsertionPointY value (caused by an xsd bug in MapGuide)</comment>
</data>
- <data name="ui_splitter_horizontal" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\ui-splitter-horizontal.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="NewFolder" xml:space="preserve">
+ <value>New folder</value>
+ <comment>The default name of a new folder</comment>
</data>
- <data name="icon_back" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_back.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_copy_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_copy_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="ColumnHasNoValidDataError" xml:space="preserve">
+ <value>The selected column had no non-null values and cannot be used.</value>
+ <comment>An error message that is displayed if the user selects a column with no valid data</comment>
+ </data>
+ <data name="FiletypeZip" xml:space="preserve">
+ <value>Zip files ({0})</value>
+ <comment>The text displayed when browsing for zip files</comment>
+ </data>
+ <data name="PropertyTooltip" xml:space="preserve">
+ <value>Property: {0}
+Type: {1}</value>
+ <comment>The tooltip displayed in the text editor when the cursor is over a property</comment>
+ </data>
+ <data name="icon_help" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_help.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="icon_back_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_back_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_buffer" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_buffer.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FileCopyError" xml:space="preserve">
+ <value>An error occured while copying file: {0}</value>
+ <comment>A message displayed when a file copy fails</comment>
</data>
- <data name="icon_buffer_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_buffer_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_measure" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_measure.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_clearselect" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_clearselect.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="RepositoryWipeWarning" xml:space="preserve">
+ <value>You have selected to restore the package at the root.
+You have also selected to delete the target before restoring.
+This will result in the entire repository being deleted and replaced with this package.
+Are you absolutely sure that is what you want?</value>
+ <comment>A confirmation message displayed to the user, when creating a package that will completely wipe a repository</comment>
</data>
- <data name="icon_clearselect_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_clearselect_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_panup_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_panup_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_copy" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_copy.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_pan_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_pan_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_copy_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_copy_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="folder--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\folder--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_ctxarrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_ctxarrow.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="arrow-curve" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-curve.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_fitwindow" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_fitwindow.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="folder--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\folder--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_fitwindow_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_fitwindow_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FindReplaceNothing" xml:space="preserve">
+ <value>Nothing to replace</value>
</data>
- <data name="icon_forward" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_forward.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_buffer" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_buffer.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_forward_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_forward_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="control-stop-square" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\control-stop-square.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_help" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_help.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="ColumnValueError" xml:space="preserve">
+ <value>An error occured while reading column values: {0}</value>
+ <comment>An error message that is displayed when the column values could not be read</comment>
</data>
- <data name="icon_help_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_help_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_viewoptions_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_viewoptions_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_home" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_home.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
- <data name="icon_home_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_home_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="icon_invokescript" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_invokescript.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_invokescript_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_invokescript_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_buffer_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_buffer_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_invokeurl" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_invokeurl.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_pandown_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_pandown_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_invokeurl_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_invokeurl_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="TransparentName" xml:space="preserve">
+ <value>Transparent</value>
</data>
- <data name="icon_measure" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_measure.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="NoColumnValuesError" xml:space="preserve">
+ <value>No values found in selected column</value>
+ <comment>A message displayed when the column has no values</comment>
</data>
- <data name="icon_measure_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_measure_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="InvalidRecordCountError" xml:space="preserve">
+ <value>Invalid record count in line {0}</value>
+ <comment>An error message that is displayed if the file has an invalid error count</comment>
</data>
- <data name="icon_null" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_null.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="NoRestorePathWarning" xml:space="preserve">
+ <value>You have selected to restore the package at another location, but not entered one.
+This will cause the package to be restored a the root of the resource tree.
+Are you sure this is what you want?</value>
+ <comment>A message displayed when the user has not entered a restore path</comment>
</data>
- <data name="icon_pan" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_pan.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="cross-script" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\cross-script.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_pandown" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_pandown.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FiletypeMGP" xml:space="preserve">
+ <value>MapGuide Packages ({0})</value>
+ <comment>The text displayed when browsing for MGP files</comment>
</data>
- <data name="icon_pandown_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_pandown_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="SymbolTypeNotSupported" xml:space="preserve">
+ <value>Only symbols of type "Mark" and "Font" are currently supported</value>
+ <comment>A message that is displayed when the user attempts to modify an item with an unsupported type</comment>
</data>
- <data name="icon_panleft" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_panleft.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="clipboard-paste" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\clipboard-paste.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_panleft_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_panleft_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="MissingColumnError" xml:space="preserve">
+ <value>Missing column "{0}"</value>
+ <comment>An error message that is displayed if the file is missing a required column</comment>
</data>
- <data name="icon_panright" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_panright.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="PackageBuildError" xml:space="preserve">
+ <value>An error occured while building package: {0}</value>
</data>
- <data name="icon_panright_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_panright_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="BetweenLabel" xml:space="preserve">
+ <value>Between {0} and {1}</value>
+ <comment>The label used for all "between" values in the graduated theme set</comment>
</data>
- <data name="icon_panup" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_panup.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="script--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\script--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_panup_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_panup_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="sql-join" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\sql-join.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_pan_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_pan_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_zoomrect_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomrect_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_plotdwf" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_plotdwf.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FiletypeAll" xml:space="preserve">
+ <value>All files ({0})</value>
+ <comment>The text displayed when browsing for all file types</comment>
</data>
- <data name="icon_plotdwf_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_plotdwf_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="NoActiveDataFile" xml:space="preserve">
+ <value>No active resource data file selected</value>
</data>
- <data name="icon_popupscrolldown" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_popupscrolldown.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_zoomprev_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomprev_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_popupscrolldown_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_popupscrolldown_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_home_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_home_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_popupscrollup" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_popupscrollup.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="arrow-270" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-270.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_popupscrollup_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_popupscrollup_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="AlternateNameMissing" xml:space="preserve">
+ <value>You must enter a alternate name, or remove the checkmark</value>
+ <comment>A message displayed when the user has not entered an alternate name for a resource</comment>
</data>
- <data name="icon_print" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_print.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="globe--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\globe--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_printablepage" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_printablepage.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="DeleteCommand" xml:space="preserve">
+ <value>Delete Command</value>
</data>
- <data name="icon_printablepage_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_printablepage_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_selectradius" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_selectradius.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_print_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_print_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="application-export" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\application-export.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_refreshmap" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_refreshmap.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_select_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_select_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_refreshmap_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_refreshmap_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="TitleError" xml:space="preserve">
+ <value>Error</value>
</data>
- <data name="icon_restorecenter" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_restorecenter.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_plotdwf_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_plotdwf_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_restorecenter_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_restorecenter_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FilterAll" xml:space="preserve">
+ <value>All File Types (*.*)|*.*</value>
</data>
- <data name="icon_search" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_search.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="ui_splitter_horizontal" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\ui-splitter-horizontal.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_search_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_search_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="folder_horizontal" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\folder-horizontal.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_select" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_select.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_ctxarrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_ctxarrow.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_selectpolygon" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_selectpolygon.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="InvalidResourceIdFolder" xml:space="preserve">
+ <value>Must be valid resource id. Cannot be a folder</value>
</data>
- <data name="icon_selectpolygon_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_selectpolygon_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="ColorBrewer" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\ColorBrewer.csv;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
</data>
- <data name="icon_selectradius" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_selectradius.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FilenameValidationError" xml:space="preserve">
+ <value>Failed to validate the filenames: {0}</value>
+ <comment>A message displayed when the user enters an invalid filename</comment>
</data>
- <data name="icon_selectradius_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_selectradius_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="table" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\table.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_selectwithin" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_selectwithin.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="exclamation" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\exclamation.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_selectwithin_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_selectwithin_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FindNothing" xml:space="preserve">
+ <value>Could not find specified string or end of document reached</value>
</data>
- <data name="icon_select_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_select_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_panup" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_panup.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_tasks" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_tasks.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="TooManyValuesError" xml:space="preserve">
+ <value>The selected column contains more than {0} different values, and thus cannot be used for theming</value>
+ <comment>An error message that is displayed if the selected column has too many distinct values</comment>
</data>
- <data name="icon_tasks_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_tasks_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_print_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_print_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_viewoptions" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_viewoptions.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="HeaderFileMissing" xml:space="preserve">
+ <value>The header file does not exist</value>
+ <comment>A message displayed when the user selects a non-existing file</comment>
</data>
- <data name="icon_viewoptions_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_viewoptions_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_search" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_search.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_zoom" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoom.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="MgCooker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAHrSURBVDhPhZLtS1NhGMb9T/rQx6ACyUVDyQjDaKAGQYOB
+ Ew2K9ilifrA+LDAMablFb1IM03DbMXMwj4O15VZ5iPly2Go0yzCzF0iwr4OdX3seOxK1owcunofzPPfv
+ vq77nLo6i2d44j0Xb8elgk90rO7VfN80dB13coLmyUFalCMcHjvJ+fBnHkdLu4Psty5wKhZgz9022tUw
+ 9oiHpuQy+1IG7umNnQGdfkV2bA4fq3ZtpCP+EI9u4NAM6mMJDkaDuPoj1pCGgUt/LDfiSYV4sFzGm6/g
+ zBkcGOtj/4gTm/+cNeBqvIBttIeexDDqlwqhjxX6ixVcc1/lHITawn5rwBVlVRa0x4ZoVc7i1V5JBx3p
+ nIwk4wU6rQG+e3m8ehlnMrodxaGOc+K1gS21waHRMzh6B3cepHDRrf2UHe3jp2mZXaf+hcHeRBnxeXf9
+ H4L3Z3HfnOJoyMVxtUSD+ovW55t03SnguzZNOp2xhiws6GjaPJPPXnLDn8Hnn6NvIMvl3qcEApHq2Rsp
+ SxcCUHj7QUrsTaAo0vUSi0vv5JklxCwUl0Wxuf4NE3vLGCuf1rdtii7Z7JZlASoWV1G6uslEpsjlFmvH
+ WFv7wcxM6j8JZ9++bzL/aISV/Ja7mnNYqmY07YouQubg/l1NwG/XLb2y/7oFegAAAABJRU5ErkJggg==
+</value>
</data>
- <data name="icon_zoomin" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomin.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_restorecenter" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_restorecenter.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_zoomin_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomin_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="SelectPackageFile" xml:space="preserve">
+ <value>Select the package file to edit</value>
+ <comment>The title of the dialog that the is used to pick the package file to edit</comment>
</data>
- <data name="icon_zoomnext" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomnext.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_zoomprev" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomprev.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_zoomnext_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomnext_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_fitwindow_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_fitwindow_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_zoomout" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomout.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="InvalidColumnNameError" xml:space="preserve">
+ <value>Invalid column name</value>
+ <comment>An error message that is displayed when the column selected does not exist</comment>
</data>
- <data name="icon_zoomout_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomout_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="SearchCmdDescription" xml:space="preserve">
+ <value>Search Command</value>
</data>
- <data name="icon_zoomprev" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomprev.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FilterShp" xml:space="preserve">
+ <value>ESRI Shape File (*.shp)|*.*</value>
</data>
- <data name="icon_zoomprev_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomprev_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="XmlEditorCursorTemplate" xml:space="preserve">
+ <value>Line {0}, Column {1}</value>
</data>
- <data name="icon_zoomrect" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomrect.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FilterSdf" xml:space="preserve">
+ <value>Autodesk SDF (*.sdf)|*.*</value>
</data>
- <data name="icon_zoomrect_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomrect_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="SelectFolder" xml:space="preserve">
+ <value>Select Folder</value>
</data>
- <data name="icon_zoomselect" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomselect.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="application--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\application--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_zoomselect_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomselect_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FsPostgreSql" xml:space="preserve">
+ <value>PostgreSQL/PostGIS Feature Source</value>
</data>
+ <data name="DivergingName" xml:space="preserve">
+ <value>Diverging</value>
+ <comment>A display name for the Diverging data type</comment>
+ </data>
+ <data name="arrow-circle-135" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-circle-135.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="icon_zoom_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_zoom_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="question" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\question.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_invokeurl" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_invokeurl.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="LoadProcedureVersionExecutionNotSupported" xml:space="preserve">
- <value>This connection does not support executing this type of Load Procedure</value>
+ <data name="FunctionTooltip" xml:space="preserve">
+ <value>Function: {1}({2})
+Description: {3}
+Returns: {0}</value>
+ <comment>The tooltip displayed in the text editor when the cursor is over a function name</comment>
</data>
- <data name="OperationCancelled" xml:space="preserve">
- <value>Operation Cancelled</value>
+ <data name="SQLQuery" xml:space="preserve">
+ <value>SQL Query</value>
</data>
- <data name="OperationCompleted" xml:space="preserve">
- <value>Operation Completed</value>
+ <data name="InvalidFieldCountError" xml:space="preserve">
+ <value>Invalid field count in line {0}</value>
+ <comment>An error message that is displayed if the file has an invalid field count</comment>
</data>
- <data name="FilterAll" xml:space="preserve">
- <value>All File Types (*.*)|*.*</value>
+ <data name="LessThanLabel" xml:space="preserve">
+ <value>Less than {0}</value>
+ <comment>The label used for the lowest value in the graduated theme set</comment>
</data>
- <data name="FilterSdf" xml:space="preserve">
- <value>Autodesk SDF (*.sdf)|*.*</value>
- </data>
- <data name="FilterShp" xml:space="preserve">
- <value>ESRI Shape File (*.shp)|*.*</value>
- </data>
<data name="AllResourceTypes" xml:space="preserve">
<value>All types</value>
<comment>The list entry that represents all resource types</comment>
</data>
- <data name="AlternateNameMissing" xml:space="preserve">
- <value>You must enter a alternate name, or remove the checkmark</value>
- <comment>A message displayed when the user has not entered an alternate name for a resource</comment>
+ <data name="icon_forward" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_forward.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="ContentFileMissing" xml:space="preserve">
- <value>The content file does not exist</value>
- <comment>A message displayed when the user selects a non-existing file</comment>
+ <data name="InvokeUrlCmdDescription" xml:space="preserve">
+ <value>Invoke URL command</value>
</data>
- <data name="DeleteConfirmation" xml:space="preserve">
- <value>Do you want to remove the selected item?</value>
- <comment>A confirmation message displayed when deleting a resource</comment>
+ <data name="icon_pandown" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_pandown.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FileCopyError" xml:space="preserve">
- <value>An error occured while copying file: {0}</value>
- <comment>A message displayed when a file copy fails</comment>
+ <data name="PropEnumNoValues" xml:space="preserve">
+ <value>Could not find possible values for enumerable property</value>
</data>
- <data name="FilenameValidationError" xml:space="preserve">
- <value>Failed to validate the filenames: {0}</value>
- <comment>A message displayed when the user enters an invalid filename</comment>
+ <data name="ModeNotAllowed" xml:space="preserve">
+ <value>Mode not allowed: {0}</value>
</data>
- <data name="FiletypeAll" xml:space="preserve">
- <value>All files ({0})</value>
- <comment>The text displayed when browsing for all file types</comment>
+ <data name="icon_zoomselect_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomselect_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FiletypeMGP" xml:space="preserve">
- <value>MapGuide Packages ({0})</value>
- <comment>The text displayed when browsing for MGP files</comment>
+ <data name="icon_zoomnext_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomnext_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FiletypeZip" xml:space="preserve">
- <value>Zip files ({0})</value>
- <comment>The text displayed when browsing for zip files</comment>
+ <data name="icon_null" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_null.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FolderMissingPrefix" xml:space="preserve">
- <value>The folder must start with \"Library://\", do you want the starting folder to become:\n {0} ?</value>
- <comment>A message that is displayed when the user has not entered a folder starting with Library://</comment>
+ <data name="icon_panleft_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_panleft_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="HeaderFileMissing" xml:space="preserve">
- <value>The header file does not exist</value>
+ <data name="function" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\function.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="InvalidRestorePathError" xml:space="preserve">
- <value>An error occured while validating the restore path: {0}\nIt should have the format: \"Libray://folder/folder/\".</value>
- <comment>A message that is displayed when the restore path does not validate</comment>
+ <data name="icon_zoom" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoom.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="NewFolder" xml:space="preserve">
- <value>New folder</value>
- <comment>The default name of a new folder</comment>
+ <data name="OverwriteResource" xml:space="preserve">
+ <value>This resource already exists, continue with save?</value>
+ <comment>Question similar to the standard response of saving to an exisiting file using the regular save file dialog</comment>
</data>
- <data name="NoFolderSelected" xml:space="preserve">
- <value>You have not selected a starting folder, do you want to back up the entire site?</value>
- <comment>A message that is displayed when the user has not selected a folder to create a folder from</comment>
+ <data name="icon_clearselect_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_clearselect_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="NoRestorePathWarning" xml:space="preserve">
- <value>You have selected to restore the package at another location, but not entered one.
-This will cause the package to be restored a the root of the resource tree.
-Are you sure this is what you want?</value>
- <comment>A message displayed when the user has not entered a restore path</comment>
+ <data name="LoadProcedureVersionExecutionNotSupported" xml:space="preserve">
+ <value>This connection does not support executing this type of Load Procedure</value>
</data>
- <data name="NoTypesSelected" xml:space="preserve">
- <value>You must select at least one type</value>
- <comment>A message that is displayed when the user has not selected any resource types</comment>
+ <data name="StandardQuery" xml:space="preserve">
+ <value>Standard Query</value>
</data>
- <data name="OutputFileMissing" xml:space="preserve">
- <value>You must enter a full path to the output file</value>
- <comment>A message that is displayed when the user has not entered an output file</comment>
+ <data name="InvalidColorComponent" xml:space="preserve">
+ <value>Invalid {0} color component {1} in line {2}</value>
+ <comment>An error message that is displayed if a color component is outside the [0-255] range.
+{0} is the color component, eg. R, G or B
+{1} is the value read
+{2} is the line where the error was encountered</comment>
</data>
- <data name="PackageBuildError" xml:space="preserve">
- <value>An error occured while building package: {0}</value>
- <comment>A message displayed when the package creation fails</comment>
+ <data name="TooManyIndiviualValuesError" xml:space="preserve">
+ <value>The selected column contains more than {0} different values, and thus cannot be used for theming with individual values</value>
</data>
- <data name="PackageCreationFailedError" xml:space="preserve">
- <value>Failed to create package, error message: {0}</value>
+ <data name="tick" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\tick.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="PackageReadError" xml:space="preserve">
- <value>Failed to read package. Error message was: {0}</value>
- <comment>A message displayed when the package could not be read</comment>
+ <data name="icon_invokescript_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_invokescript_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="RepositoryWipeWarning" xml:space="preserve">
- <value>You have selected to restore the package at the root.
-You have also selected to delete the target before restoring.
-This will result in the entire repository being deleted and replaced with this package.
-Are you absolutely sure that is what you want?</value>
- <comment>A confirmation message displayed to the user, when creating a package that will completely wipe a repository</comment>
+ <data name="sql-join-inner" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\sql-join-inner.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="SelectPackageFile" xml:space="preserve">
- <value>Select the package file to edit</value>
- <comment>The title of the dialog that the is used to pick the package file to edit</comment>
+ <data name="InvalidValueError" xml:space="preserve">
+ <value>Invalid value</value>
+ <comment>An error message that is displayed when the entered value is invalid</comment>
</data>
- <data name="UnknownResourceTypes" xml:space="preserve">
- <value>Unknown types</value>
- <comment>The list entry that represents unknown resource types</comment>
+ <data name="sql" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\sql.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="ValidateOutputfileError" xml:space="preserve">
<value>An error occured while validating the output file path: {0}</value>
<comment>A message that is displayed to the user when the output path is invalid</comment>
</data>
- <data name="SaveResourceFirst" xml:space="preserve">
- <value>Please save this resource first</value>
+ <data name="FsSqlServerSpatial" xml:space="preserve">
+ <value>SQL Server Spatial Feature Source</value>
</data>
- <data name="PropEnumNoValues" xml:space="preserve">
- <value>Could not find possible values for enumerable property</value>
+ <data name="layers-stack-arrange-back" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\layers-stack-arrange-back.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="NoActiveDataFile" xml:space="preserve">
- <value>No active resource data file selected</value>
+ <data name="document--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\document--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="SaveResource" xml:space="preserve">
- <value>Save Resource</value>
+ <data name="plus-circle" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\plus-circle.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="SelectFolder" xml:space="preserve">
- <value>Select Folder</value>
+ <data name="icon_popupscrolldown" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_popupscrolldown.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="ModeNotAllowed" xml:space="preserve">
- <value>Mode not allowed: {0}</value>
+ <data name="FolderMissingPrefix" xml:space="preserve">
+ <value>The folder must start with \"Library://\", do you want the starting folder to become:\n {0} ?</value>
+ <comment>A message that is displayed when the user has not entered a folder starting with Library://</comment>
</data>
- <data name="InvalidResourceId" xml:space="preserve">
- <value>Not a valid resource identifier</value>
+ <data name="property" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\property.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="InvalidResourceIdFolder" xml:space="preserve">
- <value>Must be valid resource id. Cannot be a folder</value>
+ <data name="ContentFileMissing" xml:space="preserve">
+ <value>The content file does not exist</value>
</data>
+ <data name="icon_search_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_search_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="sum" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\sum.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="SelectColumnPlaceholder" xml:space="preserve">
+ <value><Select column></value>
+ <comment>A placeholder message displayed when the user has not yet selected a column</comment>
+ </data>
+ <data name="XmlDocIsValid" xml:space="preserve">
+ <value>Document is valid</value>
+ </data>
<data name="InvalidResourceIdNotSpecifiedType" xml:space="preserve">
<value>Invalid Resource Identifier. Not the specified type</value>
</data>
- <data name="FailEnumDataStores" xml:space="preserve">
- <value>Failed to enumerate data stores. Reason: {0}</value>
+ <data name="icon_select" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_select.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="RdbmsFeatureSource" xml:space="preserve">
- <value>RDBMS Feature Source</value>
+ <data name="icon_back" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_back.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="database--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\database--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="arrow-090" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-090.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="cross" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\cross.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="CommandTypesDataset" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\CommandTypesDataset.xml;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;utf-8</value>
+ </data>
+ <data name="icon_selectradius_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_selectradius_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="edit-indent" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\edit-indent.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="FindEmptyString" xml:space="preserve">
+ <value>Cannot Find an Empty String</value>
+ </data>
<data name="FsMySql" xml:space="preserve">
<value>MySQL Feature Source</value>
</data>
- <data name="FsPostgreSql" xml:space="preserve">
- <value>PostgreSQL/PostGIS Feature Source</value>
+ <data name="icon_copy" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_copy.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FsSqlServerSpatial" xml:space="preserve">
- <value>SQL Server Spatial Feature Source</value>
+ <data name="map--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\map--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="AggregateQuery" xml:space="preserve">
- <value>Aggregate Query</value>
+ <data name="NewLayerGroup" xml:space="preserve">
+ <value>New Layer Group</value>
</data>
- <data name="SQLQuery" xml:space="preserve">
- <value>SQL Query</value>
+ <data name="NewLayer" xml:space="preserve">
+ <value>New Layer</value>
</data>
- <data name="StandardQuery" xml:space="preserve">
- <value>Standard Query</value>
+ <data name="Confirm" xml:space="preserve">
+ <value>Confirm</value>
</data>
- <data name="OverwriteResource" xml:space="preserve">
- <value>This resource already exists, continue with save?</value>
- <comment>Question similar to the standard response of saving to an exisiting file using the regular save file dialog</comment>
+ <data name="OverwriteDisplayScales" xml:space="preserve">
+ <value>Overwrite the current display scales?</value>
</data>
+ <data name="BaseLayerGroup" xml:space="preserve">
+ <value>Base Layer Group</value>
+ </data>
+ <data name="SelectSymbolLibraryFirst" xml:space="preserve">
+ <value>Please specify the symbol library first</value>
+ </data>
</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Editors/Resources/map--arrow.png
(Binary files differ)
Property changes on: sandbox/maestro-3.0/Maestro.Editors/Resources/map--arrow.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: sandbox/maestro-3.0/Maestro.ResourceValidation/ApplicationDefinitionValidator.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/ApplicationDefinitionValidator.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/ApplicationDefinitionValidator.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -61,7 +61,7 @@
issues.AddRange(ResourceValidatorSet.Validate(mdef, true));
- Envelope mapEnv = ObjectFactory.CreateEnvelope(mdef.Extents.MinX, mdef.Extents.MaxX, mdef.Extents.MinY, mdef.Extents.MaxY);
+ IEnvelope mapEnv = ObjectFactory.CreateEnvelope(mdef.Extents.MinX, mdef.Extents.MaxX, mdef.Extents.MinY, mdef.Extents.MaxY);
if (mapGroup.InitialView != null)
Modified: sandbox/maestro-3.0/Maestro.ResourceValidation/WebLayoutValidator.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/WebLayoutValidator.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/WebLayoutValidator.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -22,6 +22,7 @@
using System.Text;
using OSGeo.MapGuide.MaestroAPI.Resource;
using OSGeo.MapGuide.ObjectModels.WebLayout;
+using OSGeo.MapGuide.ObjectModels.Common;
using OSGeo.MapGuide.ObjectModels.MapDefinition;
using OSGeo.MapGuide.MaestroAPI.ObjectModels;
using OSGeo.MapGuide.MaestroAPI.Exceptions;
Modified: sandbox/maestro-3.0/MaestroAPITests/ObjectTests.cs
--- sandbox/maestro-3.0/MaestroAPITests/ObjectTests.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/MaestroAPITests/ObjectTests.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -36,8 +36,6 @@
public void TestEnvelope()
var env = ObjectFactory.CreateEnvelope(-.1, -.1, .1, .1);
- Assert.IsNotNull(env.LowerLeftCoordinate);
- Assert.IsNotNull(env.UpperRightCoordinate);
Assert.AreEqual(env.MinX, -.1);
Assert.AreEqual(env.MinY, -.1);
Assert.AreEqual(env.MaxX, .1);
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Check.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Check.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Check.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -77,5 +77,16 @@
if (string.IsNullOrEmpty(value))
throw new PreconditionException("string is empty: " + arg); //LOCALIZEME
+ /// <summary>
+ /// Check that the specified condition is true
+ /// </summary>
+ /// <param name="condition"></param>
+ /// <param name="msg"></param>
+ public static void Precondition(bool condition, string msg)
+ if (!condition)
+ throw new PreconditionException("Precondition failure: " + msg); //LOCALIZEME
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-10-18 07:16:47 UTC (rev 5289)
@@ -198,6 +198,7 @@
<Compile Include="ObjectModels\FeatureSource.cs" />
<Compile Include="ObjectModels\LayerFactory.cs" />
<Compile Include="ObjectModels\MapDefinitionInterfaces.cs" />
+ <Compile Include="ObjectModels\PrintLayoutInterfaces.cs" />
<Compile Include="ObjectModels\SymbolInterfaces.cs" />
<Compile Include="ObjectModels\VectorLayerDefinitionImpl.cs" />
<Compile Include="ObjectModels\LayerInterfaceExtensions.cs" />
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/Envelope.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/Envelope.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/Envelope.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -20,93 +20,130 @@
using System;
using System.Collections.Generic;
using System.Text;
+using System.ComponentModel;
namespace OSGeo.MapGuide.ObjectModels.Common
- partial class Envelope
+ public interface IEnvelope : INotifyPropertyChanged
- internal Envelope() { }
+ double MinX { get; set; }
+ double MinY { get; set; }
+ double MaxX { get; set; }
+ double MaxY { get; set; }
+ public static class EnvelopeExtensions
/// <summary>
- /// Gets or sets the lower X value
+ /// Expands this envelope to accomodate the given envelope
/// </summary>
- public double MinX
+ /// <param name="env"></param>
+ public static void ExpandToInclude(this IEnvelope env, IEnvelope e1)
- get { return this.lowerLeftCoordinateField.X; }
- set { this.lowerLeftCoordinateField.X = value; }
+ if (e1.MinX < env.MinX)
+ env.MinX = e1.MinX;
+ if (e1.MinY < env.MinY)
+ env.MinY = e1.MinY;
+ if (e1.MaxX > env.MaxX)
+ env.MaxX = e1.MaxX;
+ if (e1.MaxY > env.MaxY)
+ env.MaxY = e1.MaxY;
/// <summary>
- /// Gets or set the lower Y value
+ /// Indicates whether the specified coordinates are within this instance
/// </summary>
- public double MinY
+ /// <param name="x"></param>
+ /// <param name="y"></param>
+ /// <returns></returns>
+ public static bool Contains(this IEnvelope env, double x, double y)
- get { return this.lowerLeftCoordinateField.Y; }
- set { this.lowerLeftCoordinateField.Y = value; }
+ return env.MinX <= x &&
+ env.MaxX >= x &&
+ env.MinY <= y &&
+ env.MaxY >= y;
/// <summary>
- /// Gets or sets the upper X value
+ /// Indicates whether the specified envelope intersects this instance
/// </summary>
- public double MaxX
+ /// <param name="other"></param>
+ public static bool Intersects(this IEnvelope env, IEnvelope other)
- get { return this.upperRightCoordinateField.X; }
- set { this.upperRightCoordinateField.X = value; }
+ if (other == null)
+ return false;
+ return !(other.MinX > env.MaxX || other.MaxX < env.MinX || other.MinY > env.MaxY || other.MaxY < env.MinY);
+ partial class Envelope : IEnvelope
+ internal Envelope() { }
+ public Envelope(double minx, double miny, double maxx, double maxy)
+ this.lowerLeftCoordinateField = new EnvelopeLowerLeftCoordinate() { X = minx, Y = miny };
+ this.upperRightCoordinateField = new EnvelopeUpperRightCoordinate() { X = maxx, Y = maxy };
/// <summary>
- /// Gets or sets the upper Y value
+ /// Gets or sets the lower X value
/// </summary>
- public double MaxY
+ public double MinX
- get { return this.upperRightCoordinateField.Y; }
- set { this.upperRightCoordinateField.Y = value; }
+ get { return this.lowerLeftCoordinateField.X; }
+ set
+ this.lowerLeftCoordinateField.X = value;
+ OnPropertyChanged("MinX");
/// <summary>
- /// Expands this envelope to accomodate the given envelope
+ /// Gets or set the lower Y value
/// </summary>
- /// <param name="env"></param>
- public void ExpandToInclude(Envelope env)
+ public double MinY
- if (env.MinX < this.MinX)
- this.MinX = env.MinX;
- if (env.MinY < this.MinY)
- this.MinY = env.MinY;
- if (env.MaxX > this.MaxX)
- this.MaxX = env.MaxX;
- if (env.MaxY > this.MaxY)
- this.MaxY = env.MaxY;
+ get { return this.lowerLeftCoordinateField.Y; }
+ set
+ this.lowerLeftCoordinateField.Y = value;
+ OnPropertyChanged("MinY");
/// <summary>
- /// Indicates whether the specified coordinates are within this instance
+ /// Gets or sets the upper X value
/// </summary>
- /// <param name="x"></param>
- /// <param name="y"></param>
- /// <returns></returns>
- public bool Contains(double x, double y)
+ public double MaxX
- return this.MinX <= x &&
- this.MaxX >= x &&
- this.MinY <= y &&
- this.MaxY >= y;
+ get { return this.upperRightCoordinateField.X; }
+ set
+ this.upperRightCoordinateField.X = value;
+ OnPropertyChanged("MaxX");
/// <summary>
- /// Indicates whether the specified envelope intersects this instance
+ /// Gets or sets the upper Y value
/// </summary>
- /// <param name="other"></param>
- public bool Intersects(Envelope other)
+ public double MaxY
- if (other == null)
- return false;
- return !(other.MinX > this.MaxX || other.MaxX < this.MinX || other.MinY > this.MaxY || other.MaxY < this.MinY);
+ get { return this.upperRightCoordinateField.Y; }
+ set
+ this.upperRightCoordinateField.Y = value;
+ OnPropertyChanged("MaxY");
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSourceInterfaces.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSourceInterfaces.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSourceInterfaces.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -229,7 +229,7 @@
/// <param name="className"></param>
/// <param name="geomProperty"></param>
- public static Envelope GetSpatialExtent(this IFeatureSource fs, string className, string geomProperty)
+ public static IEnvelope GetSpatialExtent(this IFeatureSource fs, string className, string geomProperty)
Check.NotNull(fs, "fs");
return fs.CurrentConnection.FeatureService.GetSpatialExtent(fs.ResourceID, className, geomProperty);
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaceExtensions.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaceExtensions.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaceExtensions.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -175,7 +175,7 @@
/// </summary>
/// <param name="allowFallbackToContextInformation">True to allow reading spatial extents from the spatial context information, if the spatial query fails.</param>
/// <returns>The envelope for the data in the table</returns>
- public static Envelope GetSpatialExtent(this ILayerDefinition layer, bool allowFallbackToContextInformation)
+ public static IEnvelope GetSpatialExtent(this ILayerDefinition layer, bool allowFallbackToContextInformation)
Check.NotNull(layer, "layer");
if (layer.CurrentConnection == null)
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -24,6 +24,8 @@
using System.Xml.Serialization;
using OSGeo.MapGuide.MaestroAPI;
using System.Drawing;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
namespace OSGeo.MapGuide.ObjectModels.MapDefinition
@@ -120,6 +122,29 @@
get { return true; }
+ void IMapDefinition.SetExtents(double minx, double miny, double maxx, double maxy)
+ if (this.Extents == null)
+ var ext = new Box2DType()
+ MaxX = maxx,
+ MaxY = maxy,
+ MinX = minx,
+ MinY = miny
+ this.Extents = ext;
+ else
+ this.Extents.MaxX = maxx;
+ this.Extents.MaxY = maxy;
+ this.Extents.MinX = minx;
+ this.Extents.MinY = miny;
+ OnPropertyChanged("Extents");
public IMapLayerGroup AddGroup(string groupName)
if (this.MapLayerGroup == null)
@@ -132,9 +157,11 @@
LegendLabel = groupName,
Name = groupName,
ShowInLegend = true,
- Visible = true
+ Visible = true,
+ Group = string.Empty
this.MapLayerGroup.Add(group);
+ OnPropertyChanged("MapLayerGroup");
return group;
@@ -152,30 +179,42 @@
//TODO: Throw exception if adding to non-existent group?
layer.Group = string.IsNullOrEmpty(groupName) ? string.Empty : groupName;
+ this.MapLayer.Add(layer);
+ OnPropertyChanged("MapLayer");
- this.MapLayer.Add(layer);
+ if (this.MapLayer.Count == 1) //First one
+ var ldf = (ILayerDefinition)this.CurrentConnection.ResourceService.GetResource(layer.ResourceId);
+ if (string.IsNullOrEmpty(this.CoordinateSystem))
+ this.CoordinateSystem = ldf.GetCoordinateSystemWkt();
+ if (IsEmpty(this.Extents))
+ var env = ldf.GetSpatialExtent(true);
+ ((IMapDefinition)this).SetExtents(env.MinX, env.MinY, env.MaxX, env.MaxY);
return layer;
+ private static bool IsEmpty(Box2DType box2DType)
+ return box2DType == null ||
+ (box2DType.MaxX == 0.0 &&
+ box2DType.MaxY == 0.0 &&
+ box2DType.MinX == 0.0 &&
+ box2DType.MinY == 0.0);
- OSGeo.MapGuide.ObjectModels.Common.Envelope IMapDefinition.Extents
+ OSGeo.MapGuide.ObjectModels.Common.IEnvelope IMapDefinition.Extents
get
- if (this.Extents != null)
- return new OSGeo.MapGuide.ObjectModels.Common.Envelope()
- MaxX = this.Extents.MaxX,
- MaxY = this.Extents.MaxY,
- MinX = this.Extents.MinX,
- MinY = this.Extents.MinY
- else
- return null;
+ return this.Extents;
set
@@ -202,14 +241,26 @@
return (IBaseMapDefinition)this.BaseMapDefinition;
- set
+ void IMapDefinition.InitBaseMap()
+ if (this.BaseMapDefinition == null)
- this.BaseMapDefinition = (MapDefinitionTypeBaseMapDefinition)value;
- if (this.BaseMapDefinition != null)
- this.BaseMapDefinition.Parent = this;
+ this.BaseMapDefinition = new MapDefinitionTypeBaseMapDefinition()
+ Parent = (IMapDefinition)this,
+ BaseMapLayerGroup = new System.ComponentModel.BindingList<BaseMapLayerGroupCommonType>(),
+ FiniteDisplayScale = new System.ComponentModel.BindingList<double>()
+ void IMapDefinition.RemoveBaseMap()
+ this.BaseMapDefinition = null;
IEnumerable<IMapLayer> IMapDefinition.MapLayer
get
@@ -225,7 +276,10 @@
var lyr = layer as MapLayerType;
if (lyr != null)
this.MapLayer.Remove(lyr);
IEnumerable<IMapLayerGroup> IMapDefinition.MapLayerGroup
@@ -241,12 +295,122 @@
void IMapDefinition.RemoveGroup(IMapLayerGroup group)
+ Check.NotNull(group, "group");
var grp = group as MapLayerGroupType;
if (grp != null)
this.MapLayerGroup.Remove(grp);
+ int IMapDefinition.GetIndex(IMapLayer layer)
+ Check.NotNull(layer, "layer");
+ var lyr = layer as MapLayerType;
+ if (lyr != null)
+ return this.MapLayer.IndexOf(lyr);
+ return -1;
+ int IMapDefinition.MoveUp(IMapLayer layer)
+ int isrc = ((IMapDefinition)this).GetIndex(layer);
+ if (isrc > 0)
+ int idst = isrc - 1;
+ var src = this.MapLayer[isrc];
+ var dst = this.MapLayer[idst];
+ this.MapLayer[isrc] = dst;
+ this.MapLayer[idst] = src;
+ return idst;
+ return -1;
+ int IMapDefinition.MoveDown(IMapLayer layer)
+ if (isrc < this.MapLayer.Count - 1)
+ int idst = isrc + 1;
+ return idst;
+ return -1;
+ int IMapDefinition.GetIndex(IMapLayerGroup group)
+ var grp = group as MapLayerGroupType;
+ if (grp != null)
+ return this.MapLayerGroup.IndexOf(grp);
+ return -1;
+ void IMapDefinition.SetTopDrawOrder(IMapLayer layer)
+ if (isrc > 0)
+ //take everything before this and shift them up one position
+ for (int i = isrc - 1; i >= 0; i--)
+ this.MapLayer[i+1] = this.MapLayer[i];
+ this.MapLayer[0] = src;
+ void IMapDefinition.SetBottomDrawOrder(IMapLayer layer)
+ if (isrc >= 0 && isrc < this.MapLayer.Count)
+ //take everything after this and shift them down one position
+ for (int i = isrc + 1; i < this.MapLayer.Count; i++)
+ this.MapLayer[i - 1] = this.MapLayer[i];
+ this.MapLayer[this.MapLayer.Count - 1] = src;
+ partial class Box2DType : IEnvelope
partial class MapDefinitionTypeBaseMapDefinition : IBaseMapDefinition
[XmlIgnore]
@@ -277,6 +441,12 @@
this.FiniteDisplayScale.Remove(value);
+ void IBaseMapDefinition.RemoveAllScales()
+ this.FiniteDisplayScale.Clear();
+ OnPropertyChanged("FiniteDisplayScale");
IEnumerable<IBaseMapGroup> IBaseMapDefinition.BaseMapLayerGroup
get
@@ -288,14 +458,21 @@
- public void AddBaseLayerGroup(IBaseMapGroup group)
+ public IBaseMapGroup AddBaseLayerGroup(string name)
- var grp = group as BaseMapLayerGroupCommonType;
- if (grp != null)
+ var grp = new BaseMapLayerGroupCommonType()
- this.BaseMapLayerGroup.Add(grp);
- grp.Parent = this.Parent;
+ Parent = this.Parent,
+ Name = name,
+ BaseMapLayer = new System.ComponentModel.BindingList<BaseMapLayerType>(),
+ ExpandInLegend = true,
+ ShowInLegend = true,
+ LegendLabel = name,
+ Visible = true
+ this.BaseMapLayerGroup.Add(grp);
+ return grp;
public void RemoveBaseLayerGroup(IBaseMapGroup group)
@@ -364,6 +541,7 @@
Selectable = true
this.BaseMapLayer.Add(layer);
+ OnPropertyChanged("BaseMapLayer");
return layer;
@@ -371,7 +549,60 @@
var lyr = layer as BaseMapLayerType;
if (lyr != null)
this.BaseMapLayer.Remove(lyr);
+ int IBaseMapGroup.MoveUp(IBaseMapLayer layer)
+ var lyr = layer as BaseMapLayerType;
+ if (lyr != null)
+ int isrc = this.BaseMapLayer.IndexOf(lyr);
+ if (isrc > 0)
+ var src = this.BaseMapLayer[isrc];
+ var dst = this.BaseMapLayer[idst];
+ //swap
+ this.BaseMapLayer[isrc] = dst;
+ this.BaseMapLayer[idst] = src;
+ return idst;
+ return -1;
+ int IBaseMapGroup.MoveDown(IBaseMapLayer layer)
+ if (lyr != null)
+ if (isrc < this.BaseMapLayer.Count - 1)
+ //swap
+ return idst;
+ return -1;
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinitionInterfaces.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinitionInterfaces.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinitionInterfaces.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -24,6 +24,7 @@
+using OSGeo.MapGuide.MaestroAPI;
@@ -33,27 +34,200 @@
string CoordinateSystem { get; set; }
- Envelope Extents { get; set; }
+ IEnvelope Extents { get; set; }
+ void SetExtents(double minx, double miny, double maxx, double maxy);
Color BackgroundColor { get; set; }
string Metadata { get; set; }
- IBaseMapDefinition BaseMap { get; set; }
+ /// <summary>
+ /// Returns the base map section of this map definition. Ensure <see cref="InitBaseMap"/>
+ /// is called first before accessing this property
+ /// </summary>
+ IBaseMapDefinition BaseMap { get; }
+ /// <summary>
+ /// Initializes the base map section of this map definition. Subsequent calls
+ /// do nothing, unless you have cleared the section via <see cref="RemoveBaseMap"/>
+ /// </summary>
+ void InitBaseMap();
+ /// <summary>
+ /// Clears the base map section of this map definition. If you want to rebuild
+ /// this section, ensure <see cref="InitBaseMap"/> is called
+ /// </summary>
+ void RemoveBaseMap();
IEnumerable<IMapLayer> MapLayer { get; }
+ /// <summary>
+ /// Adds a layer to this map. If this is the first layer to be added, the coordinate system
+ /// of this map and its extents will be set to the coordinate system and extents of this layer
+ /// if this has not been set already.
+ /// </summary>
+ /// <param name="groupName"></param>
+ /// <param name="layerName"></param>
+ /// <param name="resourceId"></param>
IMapLayer AddLayer(string groupName, string layerName, string resourceId);
void RemoveLayer(IMapLayer layer);
+ int GetIndex(IMapLayer layer);
+ int MoveUp(IMapLayer layer);
+ int MoveDown(IMapLayer layer);
IEnumerable<IMapLayerGroup> MapLayerGroup { get; }
IMapLayerGroup AddGroup(string groupName);
void RemoveGroup(IMapLayerGroup group);
+ int GetIndex(IMapLayerGroup group);
+ void SetTopDrawOrder(IMapLayer layer);
+ void SetBottomDrawOrder(IMapLayer layer);
+ public static class BaseMapDefinitionExtensions
+ public static bool HasGroups(this IBaseMapDefinition map)
+ Check.NotNull(map, "map");
+ return new List<IBaseMapGroup>(map.BaseMapLayerGroup).Count > 0;
+ public static IBaseMapGroup GetFirstGroup(this IBaseMapDefinition map)
+ var list = new List<IBaseMapGroup>(map.BaseMapLayerGroup);
+ if (list.Count > 0)
+ return list[0];
+ return null;
+ public static bool LayerExists(this IBaseMapDefinition map, string layerName)
+ Check.NotEmpty(layerName, "layerName");
+ foreach (var group in map.BaseMapLayerGroup)
+ foreach (var layer in group.BaseMapLayer)
+ if (layerName.Equals(layer.Name))
+ return true;
+ return false;
+ public static IBaseMapGroup GetGroup(this IBaseMapDefinition map, string groupName)
+ Check.NotEmpty(groupName, "groupName");
+ if (groupName.Equals(group.Name))
+ return group;
+ return null;
+ public static bool GroupExists(this IBaseMapDefinition map, string groupName)
+ return true;
+ return false;
+ public static IEnumerable<IBaseMapLayer> GetLayersForGroup(this IBaseMapDefinition map, string groupName)
+ return group.BaseMapLayer;
+ return new IBaseMapLayer[0];
+ public static class MapDefinitionExtensions
+ public static IMapLayer GetLayerByName(this IMapDefinition map, string name)
+ Check.NotEmpty(name, "name");
+ foreach (var layer in map.MapLayer)
+ if (name.Equals(layer.Name))
+ return layer;
+ return null;
+ public static IMapLayerGroup GetGroupByName(this IMapDefinition map, string name)
+ foreach (var group in map.MapLayerGroup)
+ if (name.Equals(group.Name))
+ return group;
+ return null;
+ public static int GetLayerCount(this IMapDefinition map)
+ return new List<IMapLayer>(map.MapLayer).Count;
+ public static int GetGroupCount(this IMapDefinition map)
+ return new List<IMapLayerGroup>(map.MapLayerGroup).Count;
+ public static IEnumerable<IMapLayer> GetLayersForGroup(this IMapDefinition map, string name)
+ if (name.Equals(layer.Group))
+ yield return layer;
+ public static IEnumerable<IMapLayer> GetLayersWithoutGroups(this IMapDefinition map)
+ if (string.IsNullOrEmpty(layer.Group))
public interface IBaseMapDefinition
IEnumerable<double> FiniteDisplayScale { get; }
@@ -64,9 +238,11 @@
IEnumerable<IBaseMapGroup> BaseMapLayerGroup { get; }
- void AddBaseLayerGroup(IBaseMapGroup group);
+ IBaseMapGroup AddBaseLayerGroup(string name);
void RemoveBaseLayerGroup(IBaseMapGroup group);
+ void RemoveAllScales();
public interface IMapLegendElementBase : INotifyPropertyChanged
@@ -85,8 +261,6 @@
string ResourceId { get; set; }
bool Selectable { get; set; }
- IMapDefinition Parent { get; }
public interface IBaseMapGroup : IMapLegendElementBase
@@ -98,6 +272,10 @@
IBaseMapLayer AddLayer(string layerName, string resourceId);
void RemoveBaseMapLayer(IBaseMapLayer layer);
+ int MoveUp(IBaseMapLayer layer);
+ int MoveDown(IBaseMapLayer layer);
public interface IMapLayer : IBaseMapLayer
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -118,12 +118,14 @@
return fs;
- public static MapDefinition CreateMapDefinition(IServerConnection owner, string name)
+ public static IMapDefinition CreateMapDefinition(IServerConnection owner, string name)
Check.NotNull(owner, "owner");
return new MapDefinition() {
CurrentConnection = owner,
+ CoordinateSystem = string.Empty,
+ Extents = new Box2DType() { MaxX = 0.0, MaxY = 0.0, MinX = 0.0, MinY = 0.0 },
Name = name,
BackgroundColor = Color.White,
MapLayer = new System.ComponentModel.BindingList<MapLayerType>(),
@@ -131,7 +133,7 @@
- public static MapDefinition CreateMapDefinition(IServerConnection owner, string name, string coordinateSystemWkt)
+ public static IMapDefinition CreateMapDefinition(IServerConnection owner, string name, string coordinateSystemWkt)
var map = CreateMapDefinition(owner, name);
map.CoordinateSystem = coordinateSystemWkt;
@@ -139,10 +141,10 @@
return map;
- public static MapDefinition CreateMapDefinition(IServerConnection owner, string name, string coordinateSystemWkt, Envelope env)
+ public static IMapDefinition CreateMapDefinition(IServerConnection owner, string name, string coordinateSystemWkt, IEnvelope env)
var map = CreateMapDefinition(owner, name, coordinateSystemWkt);
- map.Extents = new Box2DType() { MinX = env.MinX, MaxX = env.MaxX, MinY = env.MinY, MaxY = env.MaxY };
+ map.Extents = env;
return map;
@@ -668,11 +670,23 @@
return appDef;
- public static PrintLayout CreatePrintLayout(IServerConnection owner)
+ public static IPrintLayout CreatePrintLayout(IServerConnection owner)
- return new PrintLayout() { CurrentConnection = owner };
+ return new PrintLayout()
+ CurrentConnection = owner,
+ CustomLogos = new System.ComponentModel.BindingList<PrintLayoutLogo>(),
+ CustomText = new System.ComponentModel.BindingList<PrintLayoutText>(),
+ LayoutProperties = new PrintLayoutLayoutProperties(),
+ PageProperties = new PrintLayoutPageProperties()
+ BackgroundColor = new PrintLayoutPagePropertiesBackgroundColor()
const string ARBITRARY_XYM = "LOCAL_CS[\"Non-Earth (Meter)\", LOCAL_DATUM[\"Local Datum\", 0], UNIT[\"Meter\", 1], AXIS[\"X\", EAST], AXIS[\"Y\", NORTH]]";
@@ -766,7 +780,7 @@
/// <param name="maxx"></param>
/// <param name="maxy"></param>
- public static Envelope CreateEnvelope(double minx, double miny, double maxx, double maxy)
+ public static IEnvelope CreateEnvelope(double minx, double miny, double maxx, double maxy)
if (minx > maxx)
throw new ArgumentException("minx > maxx", "minx");
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/PrintLayout.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/PrintLayout.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/PrintLayout.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -26,7 +26,7 @@
namespace OSGeo.MapGuide.ObjectModels.PrintLayout
- partial class PrintLayout : IResource
+ partial class PrintLayout : IPrintLayout
internal PrintLayout() { }
@@ -97,5 +97,219 @@
+ IPrintLayoutPageProperties IPrintLayout.PageProperties
+ get { return this.PageProperties; }
+ IPrintLayoutProperties IPrintLayout.LayoutProperties
+ get { return this.LayoutProperties; }
+ IEnumerable<ILogo> IPrintLayout.CustomLogos
+ get
+ foreach (var logo in this.CustomLogos)
+ yield return logo;
+ void IPrintLayout.RemoveLogo(ILogo logo)
+ var l = logo as PrintLayoutLogo;
+ if (l != null)
+ this.CustomLogos.Remove(l);
+ OnPropertyChanged("CustomLogos");
+ IEnumerable<IText> IPrintLayout.CustomText
+ get
+ foreach (var text in this.CustomText)
+ yield return text;
+ void IPrintLayout.AddText(IText text)
+ var t = text as PrintLayoutText;
+ if (t != null)
+ this.CustomText.Add(t);
+ OnPropertyChanged("CustomText");
+ void IPrintLayout.RemoveText(IText text)
+ if (t != null)
+ this.CustomText.Remove(t);
+ ISize IPrintLayout.CreateLogoSize(float width, float height, string units)
+ return new PrintLayoutLogoSize() { Width = width, Height = height, Units = units };
+ IPosition IPrintLayout.CreateLogoPosition(float left, float bottom, string units)
+ return new PrintLayoutLogoPosition() { Left = left, Bottom = bottom, Units = units };
+ IPosition IPrintLayout.CreateTextPosition(float left, float bottom, string units)
+ return new PrintLayoutTextPosition() { Left = left, Bottom = bottom, Units = units };
+ IFont IPrintLayout.CreateFont(string name, float height, string units)
+ return new PrintLayoutTextFont() { Name = name, Height = height, Units = units };
+ ILogo IPrintLayout.CreateLogo(string symbolLibraryId, string symbolName, ISize size, IPosition position)
+ var logo = new PrintLayoutLogo()
+ Name = symbolName,
+ ResourceId = symbolLibraryId,
+ Position = (PrintLayoutLogoPosition)position,
+ Size = (PrintLayoutLogoSize)size
+ return logo;
+ void IPrintLayout.AddLogo(ILogo logo)
+ if (l != null)
+ this.CustomLogos.Add(l);
+ IText IPrintLayout.CreateText(string value, IFont font, IPosition pos)
+ var text = new PrintLayoutText()
+ Font = (PrintLayoutTextFont)font,
+ Position = (PrintLayoutTextPosition)pos,
+ Value = value
+ return text;
+ partial class PrintLayoutPageProperties : IPrintLayoutPageProperties
+ System.Drawing.Color IPrintLayoutPageProperties.BackgroundColor
+ get
+ int r;
+ int g;
+ int b;
+ if (int.TryParse(this.BackgroundColor.Red, out r) &&
+ int.TryParse(this.BackgroundColor.Green, out g) &&
+ int.TryParse(this.BackgroundColor.Blue, out b))
+ return System.Drawing.Color.FromArgb(r, g, b);
+ return new System.Drawing.Color();
+ set
+ this.BackgroundColor.Red = value.R.ToString();
+ this.BackgroundColor.Green = value.G.ToString();
+ this.BackgroundColor.Blue = value.B.ToString();
+ partial class PrintLayoutLayoutProperties : IPrintLayoutProperties
+ partial class PrintLayoutLogo : ILogo
+ IPosition ILogo.Position
+ get { return this.Position; }
+ ISize ILogo.Size
+ get { return this.Size; }
+ float? ILogo.Rotation
+ get
+ return this.RotationSpecified ? new Nullable<float>(this.Rotation) : null;
+ set
+ if (value.HasValue)
+ this.Rotation = value.Value;
+ this.RotationSpecified = true;
+ else
+ this.RotationSpecified = false;
+ partial class PrintLayoutLogoPosition : IPosition
+ partial class PrintLayoutLogoSize : ISize
+ partial class PrintLayoutText : IText
+ IPosition IText.Position
+ IFont IText.Font
+ get { return this.Font; }
+ partial class PrintLayoutTextFont : IFont
+ partial class PrintLayoutTextPosition : IPosition
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/PrintLayoutInterfaces.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/PrintLayoutInterfaces.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/PrintLayoutInterfaces.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -0,0 +1,114 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using System.Drawing;
+namespace OSGeo.MapGuide.ObjectModels.PrintLayout
+ public interface IPrintLayout : IResource
+ IPrintLayoutPageProperties PageProperties { get; }
+ IPrintLayoutProperties LayoutProperties { get; }
+ ISize CreateLogoSize(float width, float height, string units);
+ IFont CreateFont(string name, float height, string units);
+ IPosition CreateLogoPosition(float left, float bottom, string units);
+ IPosition CreateTextPosition(float left, float bottom, string units);
+ IEnumerable<ILogo> CustomLogos { get; }
+ ILogo CreateLogo(string symbolLibraryId, string symbolName, ISize size, IPosition position);
+ void AddLogo(ILogo logo);
+ void RemoveLogo(ILogo logo);
+ IEnumerable<IText> CustomText { get; }
+ IText CreateText(string value, IFont font, IPosition text);
+ void AddText(IText text);
+ void RemoveText(IText text);
+ public interface IPrintLayoutPageProperties : INotifyPropertyChanged
+ Color BackgroundColor { get; set; }
+ public interface IPrintLayoutProperties : INotifyPropertyChanged
+ bool ShowTitle { get; set; }
+ bool ShowLegend { get; set; }
+ bool ShowScaleBar { get; set; }
+ bool ShowNorthArrow { get; set; }
+ bool ShowURL { get; set; }
+ bool ShowDateTime { get; set; }
+ bool ShowCustomLogos { get; set; }
+ bool ShowCustomText { get; set; }
+ public interface IPosition : INotifyPropertyChanged
+ float Left { get; set; }
+ float Bottom { get; set; }
+ string Units { get; set; }
+ public interface ISize : INotifyPropertyChanged
+ float Width { get; set; }
+ float Height { get; set; }
+ public interface ILogo : INotifyPropertyChanged
+ IPosition Position { get; }
+ string ResourceId { get; set; }
+ string Name { get; set; }
+ ISize Size { get; }
+ float? Rotation { get; set; }
+ public interface IFont : INotifyPropertyChanged
+ public interface IText : INotifyPropertyChanged
+ IFont Font { get; }
+ string Value { get; set; }
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ServerConnectionBase.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ServerConnectionBase.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ServerConnectionBase.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -1529,22 +1529,22 @@
/// <returns>A FeatureSetReader with the aggregated values</returns>
public abstract FeatureSetReader AggregateQueryFeatureSource(string resourceID, string schema, string filter, System.Collections.Specialized.NameValueCollection aggregateFunctions);
- public virtual OSGeo.MapGuide.ObjectModels.Common.Envelope GetSpatialExtent(string resourceID, string schema, string geometry)
+ public virtual OSGeo.MapGuide.ObjectModels.Common.IEnvelope GetSpatialExtent(string resourceID, string schema, string geometry)
return GetSpatialExtent(resourceID, schema, geometry, null, false);
- public virtual OSGeo.MapGuide.ObjectModels.Common.Envelope GetSpatialExtent(string resourceID, string schema, string geometry, string filter)
+ public virtual OSGeo.MapGuide.ObjectModels.Common.IEnvelope GetSpatialExtent(string resourceID, string schema, string geometry, string filter)
return GetSpatialExtent(resourceID, schema, geometry, filter, false);
- public virtual OSGeo.MapGuide.ObjectModels.Common.Envelope GetSpatialExtent(string resourceID, string schema, string geometry, bool allowFallbackToContextInformation)
+ public virtual OSGeo.MapGuide.ObjectModels.Common.IEnvelope GetSpatialExtent(string resourceID, string schema, string geometry, bool allowFallbackToContextInformation)
return GetSpatialExtent(resourceID, schema, geometry, null, allowFallbackToContextInformation);
- protected virtual OSGeo.MapGuide.ObjectModels.Common.Envelope GetSpatialExtent(string resourceID, string schema, string geometry, string filter, bool allowFallbackToContextInformation)
+ protected virtual OSGeo.MapGuide.ObjectModels.Common.IEnvelope GetSpatialExtent(string resourceID, string schema, string geometry, string filter, bool allowFallbackToContextInformation)
try
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs 2010-10-15 17:10:52 UTC (rev 5288)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs 2010-10-18 07:16:47 UTC (rev 5289)
@@ -81,9 +81,9 @@
FeatureSetReader AggregateQueryFeatureSource(string resourceID, string schema, string filter, string[] columns);
FeatureSetReader AggregateQueryFeatureSource(string resourceID, string schema, string filter, NameValueCollection aggregateFunctions);
- ObjCommon.Envelope GetSpatialExtent(string resourceID, string schema, string geometry);
- ObjCommon.Envelope GetSpatialExtent(string resourceID, string schema, string geometry, string filter);
- ObjCommon.Envelope GetSpatialExtent(string resourceID, string schema, string geometry, bool allowFallbackToContextInformation);
+ ObjCommon.IEnvelope GetSpatialExtent(string resourceID, string schema, string geometry);
+ ObjCommon.IEnvelope GetSpatialExtent(string resourceID, string schema, string geometry, string filter);
+ ObjCommon.IEnvelope GetSpatialExtent(string resourceID, string schema, string geometry, bool allowFallbackToContextInformation);
FeatureSourceDescription DescribeFeatureSource(string resourceID);
FeatureSourceDescription DescribeFeatureSource(string resourceID, string schema);
More information about the mapguide-commits
