[mapguide-commits] r5296 - trunk/MgDev/Common/CoordinateSystem
svn_mapguide at osgeo.org
Tue Oct 19 12:34:45 EDT 2010
Author: brucedechant
Date: 2010-10-19 09:34:45 -0700 (Tue, 19 Oct 2010)
New Revision: 5296
trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoid.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp
Fix for trac ticket 1468 - Unset the EPSG code when cloning a Coordinate System entity
http://trac.osgeo.org/mapguide/ticket/1468
Notes:
Submitted on behalf of Andr?\195?\169 Barth
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2010-10-19 16:32:00 UTC (rev 5295)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2010-10-19 16:34:45 UTC (rev 5296)
@@ -1650,6 +1650,10 @@
pNew->m_csprm = m_csprm;
pNew->m_bEncrypted = m_bEncrypted;
+ //unset the EPSG code; we've an editable instance now where we neither can guarantee the correctness of the EPSG code
+ //nor is it currently supported by CsMap's NameMapper anyway
+ pNew->m_csprm.csdef.epsgNbr = 0;
if (m_pDatum)
Ptr<MgCoordinateSystemDatum> pDtClone=m_pDatum->CreateClone();
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.cpp 2010-10-19 16:32:00 UTC (rev 5295)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.cpp 2010-10-19 16:34:45 UTC (rev 5296)
@@ -450,7 +450,14 @@
pNew->m_datum = m_datum;
pNew->m_DtDef = m_DtDef;
+ pNew->m_DtDef.epsgNbr = 0;
pNew->m_ElDef = m_ElDef;
+ //don't unset the EPSG code of the ellipsoid this datum refers to
MG_CATCH_AND_THROW(L"MgCoordinateSystemDatum.CreateClone")
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoid.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoid.cpp 2010-10-19 16:32:00 UTC (rev 5295)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoid.cpp 2010-10-19 16:34:45 UTC (rev 5296)
@@ -306,6 +306,10 @@
//data members are added to CCoordinateSystemEllipsoid, this will
//need to be updated.
pDef->m_def = m_def;
+ pDef->m_def.epsgNbr = 0;
pDef->m_bEncrypted = m_bEncrypted;
MG_CATCH_AND_THROW(L"MgCoordinateSystemEllipsoid.CreateClone")
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp 2010-10-19 16:32:00 UTC (rev 5295)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp 2010-10-19 16:34:45 UTC (rev 5296)
@@ -82,6 +82,10 @@
Ptr<CCoordinateSystemGeodeticPath> clonedPath = new CCoordinateSystemGeodeticPath(this->catalog);
clonedPath->Initialize(*this->pathDefinition);
+ clonedPath->pathDefinition->epsgCode = 0;
clonedPath->pathDefinition->protect = 0; //unset the protection flag; otherwise the caller wouldn't be able to change any values
return clonedPath.Detach();
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp 2010-10-19 16:32:00 UTC (rev 5295)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp 2010-10-19 16:34:45 UTC (rev 5296)
@@ -194,6 +194,11 @@
Ptr<CCoordinateSystemGeodeticTransformDef> clonedTransformDef = new CCoordinateSystemGeodeticTransformDef(this->catalog.p);
clonedTransformDef->Initialize(*this->transformDefinition);
+ clonedTransformDef->transformDefinition->epsgCode = 0;
+ clonedTransformDef->transformDefinition->epsgVariation = 0;
clonedTransformDef->transformDefinition->protect = 0; //unset the protection flag; otherwise the caller wouldn't be able to change any values
return clonedTransformDef.Detach();
More information about the mapguide-commits
