[mapguide-commits] r5303 - in sandbox/maestro-3.0: Maestro.Base Maestro.Base/Properties Maestro.Base/Services Maestro.Base/Services/DragDropHandlers Maestro.Base/UI MaestroAPITests OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/ObjectModels OSGeo.MapGuide.MaestroAPI/Resource
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Oct 20 08:14:34 EDT 2010
Author: jng
Date: 2010-10-20 05:14:34 -0700 (Wed, 20 Oct 2010)
New Revision: 5303
Added:
   sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlerService.cs
   sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/
   sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/SdfFileHandler.cs
   sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/ShpFileHandler.cs
   sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/SltFileHandler.cs
   sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/XmlResFileHandler.cs
   sandbox/maestro-3.0/Maestro.Base/Services/IDragDropHandler.cs
   sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorerDragDropHandler.cs
   sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
   sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
   sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
   sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
   sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs
   sandbox/maestro-3.0/MaestroAPITests/ResourceTests.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceContentVersionChecker.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceTypeDescriptor.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs
3.0 sandbox changes:
 - Port the Object Explorer drag handler functionality from FDO Toolbox.
 - Tweak the xml content version inspection to use the xsi:noNamespaceSchemaLocation attribute as this has all the required information needed to construct a ResourceTypeDescriptor instance.
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin	2010-10-20 08:55:48 UTC (rev 5302)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin	2010-10-20 12:14:34 UTC (rev 5303)
@@ -28,6 +28,14 @@
         <Class id="GeneralPrefs" class="Maestro.Base.UI.Preferences.GeneralPreferencesCtrl" />
     </Path>
+    <!-- Registered drop handlers -->
+    <Path name="/Maestro/DragDropHandlers">
+        <Class id="SdfHandler" class="Maestro.Base.Services.DragDropHandlers.SdfFileHandler" />
+        <Class id="ShpHandler" class="Maestro.Base.Services.DragDropHandlers.ShpFileHandler" />
+        <Class id="SltHandler" class="Maestro.Base.Services.DragDropHandlers.SltFileHandler" />
+        <Class id="XmlResHandler" class="Maestro.Base.Services.DragDropHandlers.XmlResFileHandler" />
+    </Path>
     <!-- Registered editors -->
     <Path name="/Maestro/Editors">
         <Class id="DrawingSourceEditor100" class="Maestro.Base.Editor.DrawingSourceEditorFactory" />
@@ -169,6 +177,7 @@
     <!-- Application-level services -->
     <Path name="/Maestro/ApplicationServices">
+        <Class id="DragDropHandlerService" class="Maestro.Base.Services.DragDropHandlerService" />
         <Class id="ClipboardService" class="Maestro.Base.Services.ClipboardService" />
         <Class id="ServerConnectionManager" class="Maestro.Base.Services.ServerConnectionManager" />
         <Class id="UrlLauncher" class="Maestro.Base.Services.UrlLauncherService" />
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj	2010-10-20 08:55:48 UTC (rev 5302)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj	2010-10-20 12:14:34 UTC (rev 5303)
@@ -171,6 +171,12 @@
       <DependentUpon>Resources.resx</DependentUpon>
     </Compile>
     <Compile Include="Services\ClipboardService.cs" />
+    <Compile Include="Services\DragDropHandlerService.cs" />
+    <Compile Include="Services\DragDropHandlers\SltFileHandler.cs" />
+    <Compile Include="Services\DragDropHandlers\SdfFileHandler.cs" />
+    <Compile Include="Services\DragDropHandlers\ShpFileHandler.cs" />
+    <Compile Include="Services\DragDropHandlers\XmlResFileHandler.cs" />
+    <Compile Include="Services\IDragDropHandler.cs" />
     <Compile Include="Services\NewItemTemplateService.cs" />
     <Compile Include="Services\OpenResourceManager.cs" />
     <Compile Include="Services\ServerConnectionManager.cs" />
@@ -275,6 +281,7 @@
       <DependentUpon>SiteExplorer.cs</DependentUpon>
     </Compile>
     <Compile Include="TabFactory.cs" />
+    <Compile Include="UI\SiteExplorerDragDropHandler.cs" />
     <Compile Include="UI\ValidationResultsDialog.cs">
       <SubType>Form</SubType>
     </Compile>
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs	2010-10-20 08:55:48 UTC (rev 5302)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -1100,6 +1100,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Create a SDF Feature Source.
+        /// </summary>
+        internal static string SdfHandlerAction {
+            get {
+                return ResourceManager.GetString("SdfHandlerAction", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Select FDO Provider.
         /// </summary>
         internal static string SelectFdoProvider {
@@ -1161,6 +1170,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Create a SHP Feature Source.
+        /// </summary>
+        internal static string ShpHandlerAction {
+            get {
+                return ResourceManager.GetString("ShpHandlerAction", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Resource Name: {1}{0}Resource Type: {2}{0}Created: {3}{0}Last Modified: {4}{0}Owner: {5}.
         /// </summary>
         internal static string SITE_EXPLORER_TOOLTIP_TEMPLATE {
@@ -1286,6 +1304,15 @@
+        /// <summary>
+        ///   Looks up a localized string similar to Create a SQLite Feature Source.
+        /// </summary>
+        internal static string SltHandlerAction {
+            get {
+                return ResourceManager.GetString("SltHandlerAction", resourceCulture);
         internal static System.Drawing.Bitmap tick {
             get {
                 object obj = ResourceManager.GetObject("tick", resourceCulture);
@@ -1634,5 +1661,14 @@
                 return ResourceManager.GetString("ValidationValidating", resourceCulture);
+        /// <summary>
+        ///   Looks up a localized string similar to Load this resource into the Site Repository.
+        /// </summary>
+        internal static string XmlResHandlerAction {
+            get {
+                return ResourceManager.GetString("XmlResHandlerAction", resourceCulture);
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx	2010-10-20 08:55:48 UTC (rev 5302)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx	2010-10-20 12:14:34 UTC (rev 5303)
@@ -712,4 +712,16 @@
   <data name="ConfirmMove" xml:space="preserve">
     <value>Are you sure you want to move the following resources?</value>
   </data>
+  <data name="SdfHandlerAction" xml:space="preserve">
+    <value>Create a SDF Feature Source</value>
+  </data>
+  <data name="ShpHandlerAction" xml:space="preserve">
+    <value>Create a SHP Feature Source</value>
+  </data>
+  <data name="SltHandlerAction" xml:space="preserve">
+    <value>Create a SQLite Feature Source</value>
+  </data>
+  <data name="XmlResHandlerAction" xml:space="preserve">
+    <value>Load this resource into the Site Repository</value>
+  </data>
 </root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlerService.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlerService.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlerService.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -0,0 +1,87 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using System.IO;
+using ICSharpCode.Core;
+namespace Maestro.Base.Services
+    public class DragDropHandlerService : ServiceBase
+        public override void Initialize()
+            base.Initialize();
+            _handlers = new Dictionary<string, List<IDragDropHandler>>();
+            //Find and register drag and drop handlers
+            List<IDragDropHandler> handlers = AddInTree.BuildItems<IDragDropHandler>("/Maestro/DragDropHandlers", this);
+            if (handlers != null)
+                foreach (IDragDropHandler h in handlers)
+                    RegisterHandler(h);
+        private Dictionary<string, List<IDragDropHandler>> _handlers;
+        /// <summary>
+        /// Registers a drag and drop handler.
+        /// </summary>
+        /// <param name="handler">The handler.</param>
+        public void RegisterHandler(IDragDropHandler handler)
+            foreach (string fileExt in handler.FileExtensions)
+                string ext = fileExt.ToUpper();
+                if (!_handlers.ContainsKey(ext))
+                    _handlers[ext] = new List<IDragDropHandler>();
+                _handlers[ext].Add(handler);
+        /// <summary>
+        /// Gets the registered handlers for this particular file type
+        /// </summary>
+        /// <param name="file">The file being dropped</param>
+        /// <returns>A list of registered handlers</returns>
+        public IList<IDragDropHandler> GetHandlersForFile(string file)
+            string ext = Path.GetExtension(file).ToUpper();
+            if (_handlers.ContainsKey(ext))
+                return _handlers[ext];
+            return new List<IDragDropHandler>();
+        /// <summary>
+        /// Gets the list of file extensions being handled
+        /// </summary>
+        /// <returns></returns>
+        public ICollection<string> GetHandledExtensions()
+            return _handlers.Keys;
Added: sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/SdfFileHandler.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/SdfFileHandler.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/SdfFileHandler.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -0,0 +1,81 @@
+#endregion
+using System;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI.ObjectModels;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using System.IO;
+namespace Maestro.Base.Services.DragDropHandlers
+    public class SdfFileHandler : IDragDropHandler
+        public string HandlerAction
+            get { return Properties.Resources.SdfHandlerAction; }
+        string[] extensions = { ".sdf" };
+        public string[] FileExtensions
+            get { return extensions; }
+        public bool HandleDrop(string file, string folderId)
+            try
+                var wb = Workbench.Instance;
+                var exp = wb.ActiveSiteExplorer;
+                var mgr = ServiceRegistry.GetService<ServerConnectionManager>();
+                var conn = mgr.GetConnection(exp.ConnectionName);
+                var fs = ObjectFactory.CreateFeatureSource(conn, "OSGeo.SDF");
+                string fileName = Path.GetFileName(file);
+                string resName = Path.GetFileNameWithoutExtension(file);
+                int counter = 0;
+                string resId = folderId + resName + ".FeatureSource";
+                while (conn.ResourceService.ResourceExists(resId))
+                    counter++;
+                    resId = folderId + resName + " (" + counter + ").FeatureSource";
+                fs.ResourceID = resId;
+                fs.SetConnectionProperty("File", "%MG_DATA_FILE_PATH%" + fileName);
+                conn.ResourceService.SaveResource(fs);
+                using (var stream = File.Open(file, FileMode.Open))
+                    fs.SetResourceData(fileName, OSGeo.MapGuide.ObjectModels.Common.ResourceDataType.File, stream);
+                return true;
+            catch (Exception ex)
+                MessageService.ShowError(ex);
+                return false;
Added: sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/ShpFileHandler.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/ShpFileHandler.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/ShpFileHandler.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -0,0 +1,99 @@
+#endregion
+using System;
+using System.Text;
+using System.IO;
+    public class ShpFileHandler : IDragDropHandler
+            get { return Properties.Resources.ShpHandlerAction; }
+        private string[] extensions = { ".shp" };
+            try
+                var fs = ObjectFactory.CreateFeatureSource(conn, "OSGeo.SHP");
+                int counter = 0;
+                    counter++;
+                fs.SetConnectionProperty("DefaultFileLocation", "%MG_DATA_FILE_PATH%" + fileName);
+                //As we all know, the term shape file is deceptive...
+                string[] files = new string[]
+                    file,
+                    file.Substring(0, file.LastIndexOf(".")) + ".shx",
+                    file.Substring(0, file.LastIndexOf(".")) + ".dbf",
+                    file.Substring(0, file.LastIndexOf(".")) + ".idx",
+                    file.Substring(0, file.LastIndexOf(".")) + ".prj",
+                    file.Substring(0, file.LastIndexOf(".")) + ".cpg"
+                foreach (string fn in files)
+                    if (File.Exists(fn))
+                        using (var stream = File.Open(fn, FileMode.Open))
+                            string dataName = Path.GetFileName(fn);
+                            fs.SetResourceData(dataName, OSGeo.MapGuide.ObjectModels.Common.ResourceDataType.File, stream);
+                return true;
+                return false;
Added: sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/SltFileHandler.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/SltFileHandler.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/SltFileHandler.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -0,0 +1,81 @@
+#endregion
+using System;
+using System.Text;
+using System.IO;
+    public class SltFileHandler : IDragDropHandler
+        string[] extensions = { ".sqlite", ".db", ".slt" };
+            try
+                var fs = ObjectFactory.CreateFeatureSource(conn, "OSGeo.SQLite");
+                int counter = 0;
+                    counter++;
+                return true;
+                return false;
Added: sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/XmlResFileHandler.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/XmlResFileHandler.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/XmlResFileHandler.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -0,0 +1,87 @@
+#endregion
+using System;
+using System.Text;
+using System.IO;
+using OSGeo.MapGuide.MaestroAPI;
+    public class XmlResFileHandler : IDragDropHandler
+            get { return Properties.Resources.XmlResHandlerAction; }
+        private string[] extensions = { ".xml",
+                                        ".FeatureSource",
+                                        ".LayerDefinition",
+                                        ".MapDefinition",
+                                        ".WebLayout",
+                                        ".SymbolDefinition",
+                                        ".ApplicationDefinition",
+                                        ".PrintLayout",
+            try
+                //The easiest way to tell if this XML file is legit
+                var res = ResourceTypeRegistry.Deserialize(File.ReadAllText(file));
+                int counter = 0;
+                string name = Path.GetFileNameWithoutExtension(file);
+                string resId = folderId + name + "." + res.ResourceType.ToString();
+                    counter++;
+                    resId = folderId + name + " (" + counter + ")." + res.ResourceType.ToString();
+                res.ResourceID = resId;
+                conn.ResourceService.SaveResource(res);
+                return true;
+                return false;
Added: sandbox/maestro-3.0/Maestro.Base/Services/IDragDropHandler.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/IDragDropHandler.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Services/IDragDropHandler.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -0,0 +1,49 @@
+#endregion
+using System;
+using System.Text;
+    /// <summary>
+    /// Drag and Drop handler interface
+    /// </summary>
+    public interface IDragDropHandler
+        /// <summary>
+        /// Gets a description of the action this handler will take
+        /// </summary>
+        string HandlerAction { get; }
+        /// <summary>
+        /// Gets the file extensions this handler can handle
+        /// </summary>
+        string[] FileExtensions { get; }
+        /// <summary>
+        /// Handles the file drop
+        /// </summary>
+        /// <param name="folderId">The site explorer folder this drop was performed</param>
+        /// <returns>true if the drop was successfully handled</returns>
+        bool HandleDrop(string file, string folderId);
Modified: sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs	2010-10-20 08:55:48 UTC (rev 5302)
+++ sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -336,38 +336,44 @@
         private void trvResources_DragDrop(object sender, DragEventArgs e)
             var data = e.Data.GetData(typeof(ResourceIdentifier[])) as ResourceIdentifier[];
-            if (data == null || data.Length == 0)
-                return;
-            //See if the mouse is currently over a node
-            var node = trvResources.GetNodeAt(trvResources.PointToClient(new Point(e.X, e.Y)));
-            if (node == null)
-                return;
-            //Can only drop in a folder
-            var item = node.Tag as RepositoryItem;
-            if (item != null && item.IsFolder)
+            if (data == null)
-                string folderId = item.ResourceId;
-                List<string> resIds = new List<string>();
-                foreach (var n in data)
-                    resIds.Add(n.ToString());
+                //See if the mouse is currently over a node
+                var node = trvResources.GetNodeAt(trvResources.PointToClient(new Point(e.X, e.Y)));
+                SiteExplorerDragDropHandler.OnDragDrop(this, e, node);
+            else
+                if (node == null)
+                    return;
-                //I think it's nice to ask for confirmation
-                if (resIds.Count > 0)
+                //Can only drop in a folder
+                var item = node.Tag as RepositoryItem;
+                if (item != null && item.IsFolder)
-                    if (!MessageService.AskQuestion(Properties.Resources.ConfirmMove))
-                        return;
+                    string folderId = item.ResourceId;
+                    List<string> resIds = new List<string>();
+                    foreach (var n in data)
+                        resIds.Add(n.ToString());
-                string [] folders = MoveResources(resIds, folderId);
+                    //I think it's nice to ask for confirmation
+                    if (resIds.Count > 0)
+                        if (!MessageService.AskQuestion(Properties.Resources.ConfirmMove))
+                            return;
-                foreach (var fid in folders)
-                    LoggingService.Info("Refreshing: " + fid);
-                    RefreshModel(fid);
+                    string[] folders = MoveResources(resIds, folderId);
+                    foreach (var fid in folders)
+                        LoggingService.Info("Refreshing: " + fid);
+                        RefreshModel(fid);
@@ -375,30 +381,31 @@
         private void trvResources_DragOver(object sender, DragEventArgs e)
+            if (data == null)
-                e.Effect = DragDropEffects.None;
-                return;
+                SiteExplorerDragDropHandler.OnDragEnter(this, e);
-            if (node == null)
+            else
-                return;
+                if (node == null)
+                    e.Effect = DragDropEffects.None;
+                    return;
-            //Is it a folder?
-                e.Effect = DragDropEffects.Move;
+                //Is it a folder?
+                    e.Effect = DragDropEffects.Move;
+                else
-            else
         private void trvResources_DragEnter(object sender, DragEventArgs e)
Added: sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorerDragDropHandler.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorerDragDropHandler.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorerDragDropHandler.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -0,0 +1,97 @@
+#endregion
+using System;
+using System.Text;
+using System.Windows.Forms;
+using Maestro.Base.Services;
+using Maestro.Shared.UI;
+using Aga.Controls.Tree;
+namespace Maestro.Base.UI
+    internal sealed class SiteExplorerDragDropHandler
+        internal static void OnDragEnter(ISiteExplorer sender, DragEventArgs e)
+            if (e.Data.GetDataPresent(DataFormats.FileDrop))
+                Array a = e.Data.GetData(DataFormats.FileDrop) as Array;
+                if (a != null && a.Length > 0)
+                    e.Effect = DragDropEffects.Copy;
+                else
+            else
+        internal static void OnDragDrop(ISiteExplorer sender, DragEventArgs e, TreeNodeAdv droppedNode)
+            //If drop node specified, extract relevant folder, otherwise default to root (Library://)
+            string folderId = "Library://";
+            if (droppedNode != null)
+                var ri = droppedNode.Tag as RepositoryItem;
+                if (ri != null)
+                    if (ri.IsFolder)
+                        folderId = ri.ResourceId;
+                    else
+                        folderId = ri.Parent != null ? ri.Parent.ResourceId : "Library://";
+            bool refresh = false;
+                DragDropHandlerService handlerSvc = ServiceRegistry.GetService<DragDropHandlerService>();
+                for (int i = 0; i < a.Length; i++)
+                    string file = a.GetValue(i).ToString();
+                    IList<IDragDropHandler> handlers = handlerSvc.GetHandlersForFile(file);
+                    if (handlers.Count == 0)
+                        continue;
+                    if (handlers.Count == 1)
+                        using (new WaitCursor(Workbench.Instance))
+                            if (handlers[0].HandleDrop(file, folderId))
+                                refresh = true;
+                    if (handlers.Count > 1)
+                        //Resolve which handler to use
+            if (refresh)
+                sender.RefreshModel(folderId);
Modified: sandbox/maestro-3.0/MaestroAPITests/ResourceTests.cs
--- sandbox/maestro-3.0/MaestroAPITests/ResourceTests.cs	2010-10-20 08:55:48 UTC (rev 5302)
+++ sandbox/maestro-3.0/MaestroAPITests/ResourceTests.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -735,5 +735,45 @@
             Assert.Catch<InvalidOperationException>(() => fs.GetAliasName());
             Assert.Catch<InvalidOperationException>(() => fs.GetEmbeddedDataName());
+        [Test]
+        public void TestResourceTypeDescriptor()
+            var rtd = new ResourceTypeDescriptor(ResourceTypes.ApplicationDefinition, "1.0.0");
+            Assert.AreEqual(rtd.XsdName, "ApplicationDefinition-1.0.0.xsd");
+            rtd = new ResourceTypeDescriptor(ResourceTypes.DrawingSource, "1.0.0");
+            Assert.AreEqual(rtd.XsdName, "DrawingSource-1.0.0.xsd");
+            rtd = new ResourceTypeDescriptor(ResourceTypes.FeatureSource, "1.0.0");
+            Assert.AreEqual(rtd.XsdName, "FeatureSource-1.0.0.xsd");
+            rtd = new ResourceTypeDescriptor(ResourceTypes.LayerDefinition, "1.0.0");
+            Assert.AreEqual(rtd.XsdName, "LayerDefinition-1.0.0.xsd");
+            rtd = new ResourceTypeDescriptor(ResourceTypes.LayerDefinition, "1.1.0");
+            Assert.AreEqual(rtd.XsdName, "LayerDefinition-1.1.0.xsd");
+            rtd = new ResourceTypeDescriptor(ResourceTypes.LoadProcedure, "1.0.0");
+            Assert.AreEqual(rtd.XsdName, "LoadProcedure-1.0.0.xsd");
+            rtd = new ResourceTypeDescriptor(ResourceTypes.MapDefinition, "1.0.0");
+            Assert.AreEqual(rtd.XsdName, "MapDefinition-1.0.0.xsd");
+            rtd = new ResourceTypeDescriptor(ResourceTypes.PrintLayout, "1.0.0");
+            Assert.AreEqual(rtd.XsdName, "PrintLayout-1.0.0.xsd");
+            rtd = new ResourceTypeDescriptor(ResourceTypes.SymbolDefinition, "1.0.0");
+            Assert.AreEqual(rtd.XsdName, "SymbolDefinition-1.0.0.xsd");
+            rtd = new ResourceTypeDescriptor(ResourceTypes.SymbolLibrary, "1.0.0");
+            Assert.AreEqual(rtd.XsdName, "SymbolLibrary-1.0.0.xsd");
+            rtd = new ResourceTypeDescriptor(ResourceTypes.WebLayout, "1.0.0");
+            Assert.AreEqual(rtd.XsdName, "WebLayout-1.0.0.xsd");
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs	2010-10-20 08:55:48 UTC (rev 5302)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -157,7 +157,8 @@
             return new FeatureSourceType()
                 CurrentConnection = owner,
-                Provider = provider
+                Provider = provider,
+                Parameter = new System.ComponentModel.BindingList<NameValuePairType>()
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceContentVersionChecker.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceContentVersionChecker.cs	2010-10-20 08:55:48 UTC (rev 5302)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceContentVersionChecker.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -22,6 +22,7 @@
 using System.Text;
 using System.IO;
 using System.Xml;
+using OSGeo.MapGuide.MaestroAPI.Exceptions;
 namespace OSGeo.MapGuide.MaestroAPI.Resource
@@ -33,7 +34,7 @@
     public sealed class ResourceContentVersionChecker : IDisposable
         private XmlReader _reader;
-        private MemoryStream _stream;
+        private Stream _stream;
         /// <summary>
         /// Constructor
@@ -41,8 +42,10 @@
         /// <param name="stream">The resource content stream. Inspection is done on a copy of this stream</param>
         public ResourceContentVersionChecker(Stream stream)
-            _stream = new MemoryStream();
-            Utility.CopyStream(stream, _stream);
+            var ms = new MemoryStream();
+            Utility.CopyStream(stream, ms);
+            ms.Position = 0L; //Rewind
+            _stream = ms;
             _reader = new XmlTextReader(_stream);
@@ -52,7 +55,7 @@
         /// <param name="xmlContent"></param>
         public ResourceContentVersionChecker(string xmlContent)
-            _reader = new XmlTextReader(new StringReader(xmlContent));
+            _stream = new MemoryStream(Encoding.UTF8.GetBytes(xmlContent));
         private ResourceTypeDescriptor _rtd;
@@ -65,17 +68,37 @@
             if (_rtd == null)
-                _reader.Read();
+                _rtd = GetVersionFromXmlStream(_stream);
+            return _rtd;
-                if (!_reader.HasAttributes)
-                    throw new XmlException(Properties.Resources.ERR_BAD_DOCUMENT_NO_ROOT_ATTRIBUTES);
+        public static ResourceTypeDescriptor GetVersionFromXmlStream(Stream ms)
+            string version = "1.0.0";
+            using (var xr = XmlReader.Create(ms))
+                xr.MoveToContent();
+                if (!xr.HasAttributes)
+                    throw new SerializationException();
-                ResourceTypes rt = (ResourceTypes)Enum.Parse(typeof(ResourceTypes), _reader.Name);
-                string version = _reader.GetAttribute("version");
+                try
+                    //Parse version number from ResourceType-x.y.z.xsd
+                    string xsd = xr.GetAttribute("xsi:noNamespaceSchemaLocation");
+                    int start = (xsd.LastIndexOf("-"));
+                    int end = xsd.IndexOf(".xsd") - 1;
+                    version = xsd.Substring(start + 1, xsd.Length - end);
+                    string typeStr = xsd.Substring(0, start);
-                _rtd = new ResourceTypeDescriptor(rt, version);
+                    return new ResourceTypeDescriptor((ResourceTypes)Enum.Parse(typeof(ResourceTypes), typeStr), version);
+                finally
+                    xr.Close();
-            return _rtd;
         /// <summary>
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceTypeDescriptor.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceTypeDescriptor.cs	2010-10-20 08:55:48 UTC (rev 5302)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceTypeDescriptor.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -38,6 +38,14 @@
             this.Version = ver;
+        public string XsdName
+            get
+                return ResourceType + "-" + Version + ".xsd";
         public string ResourceType { get; set; }
         public string Version { get; set; }
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs	2010-10-20 08:55:48 UTC (rev 5302)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs	2010-10-20 12:14:34 UTC (rev 5303)
@@ -37,6 +37,7 @@
 using OSGeo.MapGuide.ObjectModels.FeatureSource;
 using OSGeo.MapGuide.ObjectModels.MapDefinition;
 using OSGeo.MapGuide.ObjectModels.DrawingSource;
+using System.Diagnostics;
@@ -188,101 +189,31 @@
         public static IResource Deserialize(ResourceTypes resourceType, Stream stream)
             //UGLY: We have to peek inside the stream to determine the version number
-            //DOUBLE UGLY: WebLayout documents don't have the version attribute so we have to peek at the xsd schema name
-            if (resourceType == ResourceTypes.WebLayout)
+            //House the stream inside a rewindable memory stream
+            using (var ms = new MemoryStream())
-                //House the stream inside a rewindable memory stream
-                using (var ms = new MemoryStream())
-                    string version = "1.0.0";
-                    Utility.CopyStream(stream, ms);
-                    ms.Position = 0L; //Rewind
-                    using (var xr = XmlReader.Create(ms))
-                        xr.MoveToContent();
-                        if (!xr.HasAttributes)
-                            throw new SerializationException();
-                        try
-                            //Parse version number from WebLayout-x.y.z.xsd
-                            string xsd = xr.GetAttribute("xsi:noNamespaceSchemaLocation");
-                            int start = ("WebLayout-".Length);
-                            int end = xsd.IndexOf(".xsd") - 1;
-                            version = xsd.Substring(start, xsd.Length - end);
-                        catch
-                            version = "1.0.0";
-                        finally
-                            if (string.IsNullOrEmpty(version))
-                        xr.Close();
+                var rd = ResourceContentVersionChecker.GetVersionFromXmlStream(ms);
+                Debug.Assert(rd.ResourceType.Equals(resourceType.ToString()));
-                    var rd = new ResourceTypeDescriptor(resourceType, version);
-                    using (var reader = new StreamReader(ms))
-                        var xml = reader.ReadToEnd();
-                        if (_serializers.ContainsKey(rd))
-                            return _serializers[rd].Deserialize(xml);
-                        else
-                            return new UntypedResource(xml, resourceType, version);
-            else
+                using (var reader = new StreamReader(ms))
-                        //Resources post-1.0.0 have a version attribute, those without are assumed to be 1.0.0 version
-                        try
-                            version = xr.GetAttribute("version");
-                        catch
-                        finally
-                        xr.Close();
-                        else
+                    var xml = reader.ReadToEnd();
+                    if (_serializers.ContainsKey(rd))
+                        return _serializers[rd].Deserialize(xml);
+                    else
+                        return new UntypedResource(xml, resourceType, rd.Version);
         public static Stream Serialize(IResource res)
             var rd = res.GetResourceTypeDescriptor();
More information about the mapguide-commits mailing list
