[mapguide-commits] r5306 - in sandbox/maestro-3.0: Maestro.Base/Editor Maestro.Base/Properties Maestro.Base/Templates Maestro.Editors Maestro.Editors/FeatureSource Maestro.Editors/FeatureSource/Extensions Maestro.Editors/Properties OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Oct 20 10:50:30 EDT 2010
Author: jng
Date: 2010-10-20 07:50:30 -0700 (Wed, 20 Oct 2010)
New Revision: 5306
Added:
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.Designer.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.resx
   sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.cs
   sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
   sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
   sandbox/maestro-3.0/Maestro.Base/Templates/RasterLayerDefinitionItemTemplate.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.Designer.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.resx
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.cs
   sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
   sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
   sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSourceInterfaces.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
3.0 sandbox changes:
 - Fix the broken join editor. The lesson learned here is: Chained comboboxes + databinding = trouble!
 - Fix non-functional delete button in Feature Source Extensions editor
 - Disable raster layer template creation as raster support is yet to be ported over from 2.x
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.cs	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.cs	2010-10-20 14:50:30 UTC (rev 5306)
@@ -76,7 +76,7 @@
             else
-                throw new NotSupportedException("Could not determine the sub-layer type"); //LOCALIZE
+                throw new NotSupportedException(Properties.Resources.LayerSubTypeNotSupported);
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs	2010-10-20 14:50:30 UTC (rev 5306)
@@ -590,6 +590,15 @@
+        /// <summary>
+        ///   Looks up a localized string similar to Could not determine the sub-layer type or this type is not currently supported.
+        /// </summary>
+        internal static string LayerSubTypeNotSupported {
+            get {
+                return ResourceManager.GetString("LayerSubTypeNotSupported", resourceCulture);
         internal static System.Drawing.Bitmap loading {
             get {
                 object obj = ResourceManager.GetObject("loading", resourceCulture);
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx	2010-10-20 14:50:30 UTC (rev 5306)
@@ -724,4 +724,7 @@
   <data name="XmlResHandlerAction" xml:space="preserve">
     <value>Load this resource into the Site Repository</value>
   </data>
+  <data name="LayerSubTypeNotSupported" xml:space="preserve">
+    <value>Could not determine the sub-layer type or this type is not currently supported</value>
+  </data>
 </root>
\ No newline at end of file
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/RasterLayerDefinitionItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/RasterLayerDefinitionItemTemplate.cs	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/RasterLayerDefinitionItemTemplate.cs	2010-10-20 14:50:30 UTC (rev 5306)
@@ -38,6 +38,15 @@
             ResourceType = ResourceTypes.LayerDefinition.ToString();
+        //temp disable as raster support is still being ported from 2.x
+        public override Version MinimumSiteVersion
+            get
+                return new Version(99, 0);
         public override IResource CreateItem(IServerConnection conn)
             return ObjectFactory.CreateDefaultLayer(conn, OSGeo.MapGuide.ObjectModels.LayerDefinition.LayerType.Raster, new Version(1, 0, 0));
Modified: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.Designer.cs	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.Designer.cs	2010-10-20 14:50:30 UTC (rev 5306)
@@ -34,7 +34,6 @@
             this.txtFeatureSource = new System.Windows.Forms.TextBox();
             this.btnBrowse = new System.Windows.Forms.Button();
             this.label3 = new System.Windows.Forms.Label();
-            this.cmbFeatureClass = new System.Windows.Forms.ComboBox();
             this.label4 = new System.Windows.Forms.Label();
             this.rdAssociation = new System.Windows.Forms.RadioButton();
             this.rdInner = new System.Windows.Forms.RadioButton();
@@ -42,17 +41,17 @@
             this.rdLeftOuter = new System.Windows.Forms.RadioButton();
             this.chkForceOneToOne = new System.Windows.Forms.CheckBox();
             this.grdJoinKeys = new System.Windows.Forms.DataGridView();
-            this.groupBox1 = new System.Windows.Forms.GroupBox();
-            this.lnkDelete = new System.Windows.Forms.LinkLabel();
-            this.lnkAdd = new System.Windows.Forms.LinkLabel();
-            this.cmbSecondary = new System.Windows.Forms.ComboBox();
-            this.cmbPrimary = new System.Windows.Forms.ComboBox();
-            this.label6 = new System.Windows.Forms.Label();
-            this.label5 = new System.Windows.Forms.Label();
             this.COL_PRIMARY = new System.Windows.Forms.DataGridViewTextBoxColumn();
             this.COL_SECONDARY = new System.Windows.Forms.DataGridViewTextBoxColumn();
+            this.groupBox1 = new System.Windows.Forms.GroupBox();
+            this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+            this.btnAddKey = new System.Windows.Forms.ToolStripButton();
+            this.btnDeleteKey = new System.Windows.Forms.ToolStripButton();
+            this.btnBrowseSecondaryClass = new System.Windows.Forms.Button();
+            this.txtSecondaryClass = new System.Windows.Forms.TextBox();
             ((System.ComponentModel.ISupportInitialize)(this.grdJoinKeys)).BeginInit();
             this.groupBox1.SuspendLayout();
+            this.toolStrip1.SuspendLayout();
             this.SuspendLayout();
             // label1
@@ -112,24 +111,10 @@
             this.label3.TabIndex = 5;
             this.label3.Text = "Feature Class";
-            // cmbFeatureClass
-            this.cmbFeatureClass.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
-                        | System.Windows.Forms.AnchorStyles.Right)));
-            this.cmbFeatureClass.DisplayMember = "Fullname";
-            this.cmbFeatureClass.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
-            this.cmbFeatureClass.FormattingEnabled = true;
-            this.cmbFeatureClass.Location = new System.Drawing.Point(144, 65);
-            this.cmbFeatureClass.Name = "cmbFeatureClass";
-            this.cmbFeatureClass.Size = new System.Drawing.Size(296, 21);
-            this.cmbFeatureClass.TabIndex = 6;
-            this.cmbFeatureClass.ValueMember = "Fullname";
-            this.cmbFeatureClass.SelectionChangeCommitted += new System.EventHandler(this.cmbFeatureClass_SelectedIndexChanged);
             // label4
             this.label4.AutoSize = true;
-            this.label4.Location = new System.Drawing.Point(7, 99);
+            this.label4.Location = new System.Drawing.Point(7, 98);
             this.label4.Name = "label4";
             this.label4.Size = new System.Drawing.Size(65, 13);
             this.label4.TabIndex = 7;
@@ -138,7 +123,7 @@
             // rdAssociation
             this.rdAssociation.Image = global::Maestro.Editors.Properties.Resources.databases_relation;
-            this.rdAssociation.Location = new System.Drawing.Point(243, 115);
+            this.rdAssociation.Location = new System.Drawing.Point(243, 114);
             this.rdAssociation.Name = "rdAssociation";
             this.rdAssociation.Size = new System.Drawing.Size(105, 24);
             this.rdAssociation.TabIndex = 11;
@@ -151,7 +136,7 @@
             // rdInner
             this.rdInner.Image = global::Maestro.Editors.Properties.Resources.sql_join_inner;
-            this.rdInner.Location = new System.Drawing.Point(144, 115);
+            this.rdInner.Location = new System.Drawing.Point(144, 114);
             this.rdInner.Name = "rdInner";
             this.rdInner.Size = new System.Drawing.Size(75, 24);
             this.rdInner.TabIndex = 10;
@@ -164,7 +149,7 @@
             // rdRightOuter
             this.rdRightOuter.Image = global::Maestro.Editors.Properties.Resources.sql_join_right;
-            this.rdRightOuter.Location = new System.Drawing.Point(243, 92);
+            this.rdRightOuter.Location = new System.Drawing.Point(243, 91);
             this.rdRightOuter.Name = "rdRightOuter";
             this.rdRightOuter.Size = new System.Drawing.Size(105, 24);
             this.rdRightOuter.TabIndex = 9;
@@ -178,7 +163,7 @@
             this.rdLeftOuter.Checked = true;
             this.rdLeftOuter.Image = global::Maestro.Editors.Properties.Resources.sql_join_left;
-            this.rdLeftOuter.Location = new System.Drawing.Point(144, 92);
+            this.rdLeftOuter.Location = new System.Drawing.Point(144, 91);
             this.rdLeftOuter.Name = "rdLeftOuter";
             this.rdLeftOuter.Size = new System.Drawing.Size(98, 24);
             this.rdLeftOuter.TabIndex = 8;
@@ -191,7 +176,7 @@
             // chkForceOneToOne
             this.chkForceOneToOne.AutoSize = true;
-            this.chkForceOneToOne.Location = new System.Drawing.Point(10, 122);
+            this.chkForceOneToOne.Location = new System.Drawing.Point(10, 121);
             this.chkForceOneToOne.Name = "chkForceOneToOne";
             this.chkForceOneToOne.Size = new System.Drawing.Size(83, 17);
             this.chkForceOneToOne.TabIndex = 12;
@@ -202,124 +187,108 @@
             this.grdJoinKeys.AllowUserToAddRows = false;
             this.grdJoinKeys.AllowUserToDeleteRows = false;
-            this.grdJoinKeys.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
-                        | System.Windows.Forms.AnchorStyles.Left)
             this.grdJoinKeys.ColumnHeadersHeightSizeMode = System.Windows.Forms.DataGridViewColumnHeadersHeightSizeMode.AutoSize;
             this.grdJoinKeys.Columns.AddRange(new System.Windows.Forms.DataGridViewColumn[] {
             this.COL_PRIMARY,
             this.COL_SECONDARY});
-            this.grdJoinKeys.Location = new System.Drawing.Point(6, 76);
+            this.grdJoinKeys.Dock = System.Windows.Forms.DockStyle.Fill;
+            this.grdJoinKeys.Location = new System.Drawing.Point(3, 41);
             this.grdJoinKeys.Name = "grdJoinKeys";
             this.grdJoinKeys.ReadOnly = true;
-            this.grdJoinKeys.Size = new System.Drawing.Size(418, 138);
+            this.grdJoinKeys.Size = new System.Drawing.Size(424, 177);
             this.grdJoinKeys.TabIndex = 14;
             this.grdJoinKeys.CellClick += new System.Windows.Forms.DataGridViewCellEventHandler(this.grdJoinKeys_CellClick);
             this.grdJoinKeys.CellContentClick += new System.Windows.Forms.DataGridViewCellEventHandler(this.grdJoinKeys_CellClick);
+            // COL_PRIMARY
+            this.COL_PRIMARY.DataPropertyName = "FeatureClassProperty";
+            this.COL_PRIMARY.HeaderText = "Primary";
+            this.COL_PRIMARY.Name = "COL_PRIMARY";
+            this.COL_PRIMARY.ReadOnly = true;
+            this.COL_PRIMARY.Width = 130;
+            // COL_SECONDARY
+            this.COL_SECONDARY.AutoSizeMode = System.Windows.Forms.DataGridViewAutoSizeColumnMode.Fill;
+            this.COL_SECONDARY.DataPropertyName = "AttributeClassProperty";
+            this.COL_SECONDARY.HeaderText = "Secondary";
+            this.COL_SECONDARY.Name = "COL_SECONDARY";
+            this.COL_SECONDARY.ReadOnly = true;
             // groupBox1
             this.groupBox1.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
-            this.groupBox1.Controls.Add(this.lnkDelete);
-            this.groupBox1.Controls.Add(this.lnkAdd);
-            this.groupBox1.Controls.Add(this.cmbSecondary);
-            this.groupBox1.Controls.Add(this.cmbPrimary);
-            this.groupBox1.Controls.Add(this.label6);
-            this.groupBox1.Controls.Add(this.label5);
             this.groupBox1.Controls.Add(this.grdJoinKeys);
-            this.groupBox1.Location = new System.Drawing.Point(10, 145);
+            this.groupBox1.Controls.Add(this.toolStrip1);
+            this.groupBox1.Location = new System.Drawing.Point(10, 144);
             this.groupBox1.Name = "groupBox1";
-            this.groupBox1.Size = new System.Drawing.Size(430, 220);
+            this.groupBox1.Size = new System.Drawing.Size(430, 221);
             this.groupBox1.TabIndex = 15;
             this.groupBox1.TabStop = false;
             this.groupBox1.Text = "Join Properties (Must specify at least one)";
-            // lnkDelete
+            // toolStrip1
-            this.lnkDelete.BackColor = System.Drawing.Color.Transparent;
-            this.lnkDelete.Enabled = false;
-            this.lnkDelete.Location = new System.Drawing.Point(61, 49);
-            this.lnkDelete.Name = "lnkDelete";
-            this.lnkDelete.Size = new System.Drawing.Size(60, 13);
-            this.lnkDelete.TabIndex = 20;
-            this.lnkDelete.TabStop = true;
-            this.lnkDelete.Text = "Delete Pair";
-            this.lnkDelete.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkDelete_LinkClicked);
+            this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+            this.btnAddKey,
+            this.btnDeleteKey});
+            this.toolStrip1.Location = new System.Drawing.Point(3, 16);
+            this.toolStrip1.Name = "toolStrip1";
+            this.toolStrip1.Size = new System.Drawing.Size(424, 25);
+            this.toolStrip1.TabIndex = 15;
+            this.toolStrip1.Text = "toolStrip1";
-            // lnkAdd
+            // btnAddKey
-            this.lnkAdd.BackColor = System.Drawing.Color.Transparent;
-            this.lnkAdd.Enabled = false;
-            this.lnkAdd.Location = new System.Drawing.Point(7, 49);
-            this.lnkAdd.Name = "lnkAdd";
-            this.lnkAdd.Size = new System.Drawing.Size(48, 13);
-            this.lnkAdd.TabIndex = 19;
-            this.lnkAdd.TabStop = true;
-            this.lnkAdd.Text = "Add Pair";
-            this.lnkAdd.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkAdd_LinkClicked);
+            this.btnAddKey.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+            this.btnAddKey.Image = global::Maestro.Editors.Properties.Resources.plus_circle;
+            this.btnAddKey.ImageTransparentColor = System.Drawing.Color.Magenta;
+            this.btnAddKey.Name = "btnAddKey";
+            this.btnAddKey.Size = new System.Drawing.Size(23, 22);
+            this.btnAddKey.ToolTipText = "Add a new property join";
+            this.btnAddKey.Click += new System.EventHandler(this.btnAddKey_Click);
-            // cmbSecondary
+            // btnDeleteKey
-            this.cmbSecondary.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
-            this.cmbSecondary.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
-            this.cmbSecondary.FormattingEnabled = true;
-            this.cmbSecondary.Location = new System.Drawing.Point(311, 17);
-            this.cmbSecondary.Name = "cmbSecondary";
-            this.cmbSecondary.Size = new System.Drawing.Size(113, 21);
-            this.cmbSecondary.TabIndex = 18;
-            this.cmbSecondary.SelectedIndexChanged += new System.EventHandler(this.CheckAddStatus);
+            this.btnDeleteKey.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+            this.btnDeleteKey.Enabled = false;
+            this.btnDeleteKey.Image = global::Maestro.Editors.Properties.Resources.cross_script;
+            this.btnDeleteKey.ImageTransparentColor = System.Drawing.Color.Magenta;
+            this.btnDeleteKey.Name = "btnDeleteKey";
+            this.btnDeleteKey.Size = new System.Drawing.Size(23, 22);
+            this.btnDeleteKey.ToolTipText = "Delete the selected property join";
+            this.btnDeleteKey.Click += new System.EventHandler(this.btnDeleteKey_Click);
-            // cmbPrimary
+            // btnBrowseSecondaryClass
-            this.cmbPrimary.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
-            this.cmbPrimary.FormattingEnabled = true;
-            this.cmbPrimary.Location = new System.Drawing.Point(95, 17);
-            this.cmbPrimary.Name = "cmbPrimary";
-            this.cmbPrimary.Size = new System.Drawing.Size(104, 21);
-            this.cmbPrimary.TabIndex = 17;
-            this.cmbPrimary.SelectedIndexChanged += new System.EventHandler(this.CheckAddStatus);
+            this.btnBrowseSecondaryClass.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+            this.btnBrowseSecondaryClass.Location = new System.Drawing.Point(413, 63);
+            this.btnBrowseSecondaryClass.Name = "btnBrowseSecondaryClass";
+            this.btnBrowseSecondaryClass.Size = new System.Drawing.Size(27, 23);
+            this.btnBrowseSecondaryClass.TabIndex = 17;
+            this.btnBrowseSecondaryClass.Text = "...";
+            this.btnBrowseSecondaryClass.UseVisualStyleBackColor = true;
+            this.btnBrowseSecondaryClass.Click += new System.EventHandler(this.btnBrowseSecondaryClass_Click);
-            // label6
+            // txtSecondaryClass
-            this.label6.AutoSize = true;
-            this.label6.Location = new System.Drawing.Point(205, 20);
-            this.label6.Name = "label6";
-            this.label6.Size = new System.Drawing.Size(100, 13);
-            this.label6.TabIndex = 16;
-            this.label6.Text = "Secondary Property";
+            this.txtSecondaryClass.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+                        | System.Windows.Forms.AnchorStyles.Right)));
+            this.txtSecondaryClass.Location = new System.Drawing.Point(144, 65);
+            this.txtSecondaryClass.Name = "txtSecondaryClass";
+            this.txtSecondaryClass.ReadOnly = true;
+            this.txtSecondaryClass.Size = new System.Drawing.Size(263, 20);
+            this.txtSecondaryClass.TabIndex = 16;
-            // label5
-            this.label5.AutoSize = true;
-            this.label5.Location = new System.Drawing.Point(6, 20);
-            this.label5.Name = "label5";
-            this.label5.Size = new System.Drawing.Size(83, 13);
-            this.label5.TabIndex = 15;
-            this.label5.Text = "Primary Property";
-            // COL_PRIMARY
-            this.COL_PRIMARY.DataPropertyName = "FeatureClassProperty";
-            this.COL_PRIMARY.HeaderText = "Primary";
-            this.COL_PRIMARY.Name = "COL_PRIMARY";
-            this.COL_PRIMARY.ReadOnly = true;
-            this.COL_PRIMARY.Width = 130;
-            // COL_SECONDARY
-            this.COL_SECONDARY.AutoSizeMode = System.Windows.Forms.DataGridViewAutoSizeColumnMode.Fill;
-            this.COL_SECONDARY.DataPropertyName = "AttributeClassProperty";
-            this.COL_SECONDARY.HeaderText = "Secondary";
-            this.COL_SECONDARY.Name = "COL_SECONDARY";
-            this.COL_SECONDARY.ReadOnly = true;
             // JoinSettings
             this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
             this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.Controls.Add(this.btnBrowseSecondaryClass);
+            this.Controls.Add(this.txtSecondaryClass);
             this.Controls.Add(this.groupBox1);
             this.Controls.Add(this.chkForceOneToOne);
             this.Controls.Add(this.rdAssociation);
@@ -327,7 +296,6 @@
             this.Controls.Add(this.rdRightOuter);
             this.Controls.Add(this.rdLeftOuter);
             this.Controls.Add(this.label4);
-            this.Controls.Add(this.cmbFeatureClass);
             this.Controls.Add(this.label3);
             this.Controls.Add(this.btnBrowse);
             this.Controls.Add(this.txtFeatureSource);
@@ -339,6 +307,8 @@
             ((System.ComponentModel.ISupportInitialize)(this.grdJoinKeys)).EndInit();
             this.groupBox1.ResumeLayout(false);
             this.groupBox1.PerformLayout();
+            this.toolStrip1.ResumeLayout(false);
+            this.toolStrip1.PerformLayout();
             this.ResumeLayout(false);
             this.PerformLayout();
@@ -352,7 +322,6 @@
         private System.Windows.Forms.TextBox txtFeatureSource;
         private System.Windows.Forms.Button btnBrowse;
         private System.Windows.Forms.Label label3;
-        private System.Windows.Forms.ComboBox cmbFeatureClass;
         private System.Windows.Forms.Label label4;
         private System.Windows.Forms.RadioButton rdLeftOuter;
         private System.Windows.Forms.RadioButton rdRightOuter;
@@ -361,13 +330,12 @@
         private System.Windows.Forms.CheckBox chkForceOneToOne;
         private System.Windows.Forms.DataGridView grdJoinKeys;
         private System.Windows.Forms.GroupBox groupBox1;
-        private System.Windows.Forms.LinkLabel lnkDelete;
-        private System.Windows.Forms.LinkLabel lnkAdd;
-        private System.Windows.Forms.ComboBox cmbSecondary;
-        private System.Windows.Forms.ComboBox cmbPrimary;
-        private System.Windows.Forms.Label label6;
-        private System.Windows.Forms.Label label5;
         private System.Windows.Forms.DataGridViewTextBoxColumn COL_PRIMARY;
         private System.Windows.Forms.DataGridViewTextBoxColumn COL_SECONDARY;
+        private System.Windows.Forms.ToolStrip toolStrip1;
+        private System.Windows.Forms.ToolStripButton btnAddKey;
+        private System.Windows.Forms.ToolStripButton btnDeleteKey;
+        private System.Windows.Forms.Button btnBrowseSecondaryClass;
+        private System.Windows.Forms.TextBox txtSecondaryClass;
Modified: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.cs	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.cs	2010-10-20 14:50:30 UTC (rev 5306)
@@ -28,6 +28,7 @@
 using Maestro.Shared.UI;
 using OSGeo.MapGuide.MaestroAPI.Resource;
 using OSGeo.MapGuide.MaestroAPI;
+using Maestro.Editors.Common;
 namespace Maestro.Editors.FeatureSource.Extensions
@@ -36,47 +37,43 @@
         private JoinSettings()
             InitializeComponent();
+            _propertyJoins = new BindingList<IRelateProperty>();
+            grdJoinKeys.DataSource = _propertyJoins;
         private bool _init = false;
         private IAttributeRelation _rel;
-        public JoinSettings(FeatureSetColumn[] primaryColumns, IAttributeRelation rel)
+        private ClassDefinition _primaryClass;
+        private ClassDefinition[] _secondaryClasses;
+        private ClassDefinition _secondaryClass;
+        private BindingList<IRelateProperty> _propertyJoins;
+        public JoinSettings(ClassDefinition primaryClass, IAttributeRelation rel)
             : this()
             Check.NotNull(rel, "rel");
+            Check.NotNull(primaryClass, "primaryClass");
+            _primaryClass = primaryClass;
-            //FIXME: Everything :( This control is currently broken. I have learned the hard way that dependent comboboxes + Automated databinding = Recipe for trouble!
-            //So re-design this control to *not* use comboboxes for such cases.
             _init = true;
             grdJoinKeys.AutoGenerateColumns = false;
             _rel = rel;
-            TextBoxBinder.BindText(txtJoinName, _rel, "Name");
-            //TextBoxBinder.BindText(txtFeatureSource, _rel, "ResourceId");
-            txtFeatureSource.TextChanged += new EventHandler(txtFeatureSource_TextChanged);
-            //rb.ReadValue();
-            UpdateJoinClass();
-            //CheckBoxBinder.BindChecked(chkForceOneToOne, _rel, "ForceOneToOne");
-            //CheckBoxBinder is failing me here, so let's do it manually
-            chkForceOneToOne.Checked = _rel.ForceOneToOne;
-            chkForceOneToOne.CheckedChanged += (s, e) => { _rel.ForceOneToOne = chkForceOneToOne.Checked; };
-            var bin = ComboBoxBinder.BindSelectedIndexChanged(cmbFeatureClass, "SelectedValue", _rel, "AttributeClass");
-            bin.ReadValue();
-            //UpdateSecondary();
-            _rel.PropertyChanged += (sender, e) => { OnResourceChanged(); };
-            cmbPrimary.DisplayMember = "Name";
-            cmbPrimary.ValueMember = "Name";
-            cmbPrimary.DataSource = primaryColumns;
-            UpdateJoinKeyList(rel);
+        void OnPropertyJoinListChanged(object sender, ListChangedEventArgs e)
+            switch (e.ListChangedType)
+                case ListChangedType.ItemAdded:
+                    _rel.AddRelateProperty(_propertyJoins[e.NewIndex]);
+                    break;
+                case ListChangedType.Reset:
+                    _rel.RemoveAllRelateProperties();
+                    break;
         private void UpdateJoinKeyList(IAttributeRelation rel)
@@ -84,42 +81,44 @@
             grdJoinKeys.DataSource = new List<IRelateProperty>(rel.RelateProperty);
-        void txtFeatureSource_TextChanged(object sender, EventArgs e)
+        private void btnBrowse_Click(object sender, EventArgs e)
-            _rel.ResourceId = txtFeatureSource.Text;
+            string resId = _edSvc.SelectResource(OSGeo.MapGuide.MaestroAPI.ResourceTypes.FeatureSource);
+            if (!string.IsNullOrEmpty(resId))
+                txtFeatureSource.Text = resId;
+                var schema = _edSvc.FeatureService.DescribeFeatureSource(txtFeatureSource.Text);
+                _secondaryClasses = schema.Classes;
+                //Invalidate existing secondary class
+                txtSecondaryClass.Text = string.Empty;
+                _secondaryClass = null;
+                //Clear existing property joins
+                ClearPropertyJoins();
+                CheckAddStatus();
-        private void UpdateJoinClass()
+        private void btnBrowseSecondaryClass_Click(object sender, EventArgs e)
-            try
+            if (string.IsNullOrEmpty(txtFeatureSource.Text))
-                var rt = ResourceIdentifier.GetResourceType(txtFeatureSource.Text);
-                if (rt == ResourceTypes.FeatureSource)
-                    var fs = _edSvc.FeatureService.DescribeFeatureSource(txtFeatureSource.Text);
-                    cmbFeatureClass.DataSource = fs.Classes;
+                MessageBox.Show(Properties.Resources.SpecifySecondaryFeatureSource);
+                return;
-                    if (fs.Classes.Length > 0)
-                        cmbFeatureClass.SelectedIndex = 0;
-                        UpdateSecondary();
-            catch
+            var selClass = GenericItemSelectionDialog.SelectItem(Properties.Resources.SelectFeatureClass, Properties.Resources.SelectFeatureClass, _secondaryClasses, "QualifiedNameDecoded", "QualifiedNameDecoded");
+            if (selClass != null)
+                _secondaryClass = selClass;
+                txtSecondaryClass.Text = _secondaryClass.QualifiedNameDecoded;
+                CheckAddStatus();
-        private void btnBrowse_Click(object sender, EventArgs e)
+        private void ClearPropertyJoins()
-            string resId = _edSvc.SelectResource(OSGeo.MapGuide.MaestroAPI.ResourceTypes.FeatureSource);
-            if (!string.IsNullOrEmpty(resId))
-                txtFeatureSource.Text = resId;
+            _propertyJoins.Clear();
         private IEditorService _edSvc;
@@ -128,6 +127,58 @@
             _edSvc = service;
             _edSvc.RegisterCustomNotifier(this);
+            TextBoxBinder.BindText(txtJoinName, _rel, "Name");
+            TextBoxBinder.BindText(txtFeatureSource, _rel, "ResourceId");
+            TextBoxBinder.BindText(txtSecondaryClass, _rel, "AttributeClass");
+            //Init selected classes
+            if (!string.IsNullOrEmpty(_rel.ResourceId))
+                var schema = _edSvc.FeatureService.DescribeFeatureSource(_rel.ResourceId);
+                if (!string.IsNullOrEmpty(_rel.AttributeClass))
+                    foreach (var cls in _secondaryClasses)
+                        if (cls.QualifiedNameDecoded.Equals(_rel.AttributeClass))
+                            _secondaryClass = cls;
+                            break;
+            //CheckBoxBinder.BindChecked(chkForceOneToOne, _rel, "ForceOneToOne");
+            //CheckBoxBinder is failing me here, so let's do it manually
+            chkForceOneToOne.Checked = _rel.ForceOneToOne;
+            chkForceOneToOne.CheckedChanged += (s, e) => { _rel.ForceOneToOne = chkForceOneToOne.Checked; };
+            switch (_rel.RelateType)
+                case RelateTypeEnum.Association:
+                    rdAssociation.Checked = true;
+                    break;
+                case RelateTypeEnum.Inner:
+                    rdInner.Checked = true;
+                    break;
+                case RelateTypeEnum.LeftOuter:
+                    rdLeftOuter.Checked = true;
+                    break;
+                case RelateTypeEnum.RightOuter:
+                    rdRightOuter.Checked = true;
+                    break;
+            _rel.PropertyChanged += (sender, e) => { OnResourceChanged(); };
+            foreach (var join in _rel.RelateProperty)
+                _propertyJoins.Add(join);
+            _propertyJoins.ListChanged += new ListChangedEventHandler(OnPropertyJoinListChanged);
         private void OnResourceChanged()
@@ -164,63 +215,40 @@
             _rel.RelateType = GetJoinType();
-        private void cmbFeatureClass_SelectedIndexChanged(object sender, EventArgs e)
+        private void CheckAddStatus()
+            btnAddKey.Enabled = !string.IsNullOrEmpty(txtFeatureSource.Text) && !string.IsNullOrEmpty(txtSecondaryClass.Text);
-        private void UpdateSecondary()
-            //Invalidate
-            if (!_init)
-                _rel.RemoveAllRelateProperties();
-            var item = cmbFeatureClass.SelectedItem as ClassDefinition;
-            if (item != null)
-                cmbSecondary.DisplayMember = "Name";
-                cmbSecondary.ValueMember = "Name";
-                cmbSecondary.DataSource = item.Columns;
-        private void lnkClear_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
-        private void CheckAddStatus(object sender, EventArgs e)
-            lnkAdd.Enabled = cmbPrimary.SelectedIndex >= 0 && cmbSecondary.SelectedIndex >= 0;
         private void grdJoinKeys_CellClick(object sender, DataGridViewCellEventArgs e)
             if (e.RowIndex >= 0)
                 grdJoinKeys.Rows[e.RowIndex].Selected = true;
-                lnkDelete.Enabled = true;
+                btnDeleteKey.Enabled = true;
-        private void lnkAdd_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
+        private void btnAddKey_Click(object sender, EventArgs e)
-            if (cmbSecondary.SelectedIndex >= 0 && cmbSecondary.SelectedIndex >= 0)
+            if (_primaryClass != null && _secondaryClass != null)
-                string primary = ((FeatureSetColumn)cmbPrimary.SelectedItem).Name;
-                string secondary = ((FeatureSetColumn)cmbSecondary.SelectedItem).Name;
-                _rel.AddRelateProperty(primary, secondary);
-                UpdateJoinKeyList(_rel);
+                var dlg = new SelectJoinKeyDialog(_primaryClass, _secondaryClass);
+                if (dlg.ShowDialog() == DialogResult.OK)
+                    var rel = _rel.CreatePropertyJoin(dlg.PrimaryProperty, dlg.SecondaryProperty);
+                    _propertyJoins.Add(rel);
-        private void lnkDelete_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
+        private void btnDeleteKey_Click(object sender, EventArgs e)
             if (grdJoinKeys.SelectedRows.Count == 1)
-                _rel.RemoveRelateProperty((IRelateProperty)grdJoinKeys.SelectedRows[0].DataBoundItem);
+                var join = (IRelateProperty)grdJoinKeys.SelectedRows[0].DataBoundItem;
+                _rel.RemoveRelateProperty(join);
+                _propertyJoins.Remove(join);
Modified: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.resx
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.resx	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.resx	2010-10-20 14:50:30 UTC (rev 5306)
@@ -123,4 +123,16 @@
   <metadata name="COL_SECONDARY.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
     <value>True</value>
   </metadata>
+  <metadata name="COL_PRIMARY.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+    <value>True</value>
+  </metadata>
+  <metadata name="COL_SECONDARY.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+  </metadata>
+  <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>17, 17</value>
+  </metadata>
+  </metadata>
 </root>
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.Designer.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.Designer.cs	2010-10-20 14:50:30 UTC (rev 5306)
@@ -0,0 +1,176 @@
+namespace Maestro.Editors.FeatureSource.Extensions
+    partial class SelectJoinKeyDialog
+        /// <summary>
+        /// Required designer variable.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Clean up any resources being used.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing && (components != null))
+                components.Dispose();
+            base.Dispose(disposing);
+        #region Windows Form Designer generated code
+        /// <summary>
+        /// Required method for Designer support - do not modify
+        /// the contents of this method with the code editor.
+        /// </summary>
+        private void InitializeComponent()
+            this.label1 = new System.Windows.Forms.Label();
+            this.label2 = new System.Windows.Forms.Label();
+            this.lblPrimary = new System.Windows.Forms.Label();
+            this.cmbPrimary = new System.Windows.Forms.ComboBox();
+            this.cmbSecondary = new System.Windows.Forms.ComboBox();
+            this.lblSecondary = new System.Windows.Forms.Label();
+            this.label5 = new System.Windows.Forms.Label();
+            this.label6 = new System.Windows.Forms.Label();
+            this.btnOK = new System.Windows.Forms.Button();
+            this.btnCancel = new System.Windows.Forms.Button();
+            this.SuspendLayout();
+            // label1
+            this.label1.AutoSize = true;
+            this.label1.Location = new System.Drawing.Point(12, 24);
+            this.label1.Name = "label1";
+            this.label1.Size = new System.Drawing.Size(108, 13);
+            this.label1.TabIndex = 0;
+            this.label1.Text = "Primary Feature Class";
+            // label2
+            this.label2.AutoSize = true;
+            this.label2.Location = new System.Drawing.Point(12, 47);
+            this.label2.Name = "label2";
+            this.label2.Size = new System.Drawing.Size(46, 13);
+            this.label2.TabIndex = 1;
+            this.label2.Text = "Property";
+            // lblPrimary
+            this.lblPrimary.AutoSize = true;
+            this.lblPrimary.Location = new System.Drawing.Point(162, 24);
+            this.lblPrimary.Name = "lblPrimary";
+            this.lblPrimary.Size = new System.Drawing.Size(35, 13);
+            this.lblPrimary.TabIndex = 2;
+            this.lblPrimary.Text = "label3";
+            // cmbPrimary
+            this.cmbPrimary.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+            this.cmbPrimary.FormattingEnabled = true;
+            this.cmbPrimary.Location = new System.Drawing.Point(165, 44);
+            this.cmbPrimary.Name = "cmbPrimary";
+            this.cmbPrimary.Size = new System.Drawing.Size(261, 21);
+            this.cmbPrimary.TabIndex = 3;
+            // cmbSecondary
+            this.cmbSecondary.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+            this.cmbSecondary.FormattingEnabled = true;
+            this.cmbSecondary.Location = new System.Drawing.Point(165, 104);
+            this.cmbSecondary.Name = "cmbSecondary";
+            this.cmbSecondary.Size = new System.Drawing.Size(261, 21);
+            this.cmbSecondary.TabIndex = 7;
+            // lblSecondary
+            this.lblSecondary.AutoSize = true;
+            this.lblSecondary.Location = new System.Drawing.Point(162, 84);
+            this.lblSecondary.Name = "lblSecondary";
+            this.lblSecondary.Size = new System.Drawing.Size(35, 13);
+            this.lblSecondary.TabIndex = 6;
+            this.lblSecondary.Text = "label4";
+            // label5
+            this.label5.AutoSize = true;
+            this.label5.Location = new System.Drawing.Point(12, 107);
+            this.label5.Name = "label5";
+            this.label5.Size = new System.Drawing.Size(46, 13);
+            this.label5.TabIndex = 5;
+            this.label5.Text = "Property";
+            // label6
+            this.label6.AutoSize = true;
+            this.label6.Location = new System.Drawing.Point(12, 84);
+            this.label6.Name = "label6";
+            this.label6.Size = new System.Drawing.Size(125, 13);
+            this.label6.TabIndex = 4;
+            this.label6.Text = "Secondary Feature Class";
+            // btnOK
+            this.btnOK.Location = new System.Drawing.Point(270, 143);
+            this.btnOK.Name = "btnOK";
+            this.btnOK.Size = new System.Drawing.Size(75, 23);
+            this.btnOK.TabIndex = 8;
+            this.btnOK.Text = "OK";
+            this.btnOK.UseVisualStyleBackColor = true;
+            this.btnOK.Click += new System.EventHandler(this.btnOK_Click);
+            // btnCancel
+            this.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+            this.btnCancel.Location = new System.Drawing.Point(351, 143);
+            this.btnCancel.Name = "btnCancel";
+            this.btnCancel.Size = new System.Drawing.Size(75, 23);
+            this.btnCancel.TabIndex = 9;
+            this.btnCancel.Text = "Cancel";
+            this.btnCancel.UseVisualStyleBackColor = true;
+            this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+            // SelectJoinKeyDialog
+            this.AcceptButton = this.btnOK;
+            this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.CancelButton = this.btnCancel;
+            this.ClientSize = new System.Drawing.Size(450, 181);
+            this.ControlBox = false;
+            this.Controls.Add(this.btnCancel);
+            this.Controls.Add(this.btnOK);
+            this.Controls.Add(this.cmbSecondary);
+            this.Controls.Add(this.lblSecondary);
+            this.Controls.Add(this.label5);
+            this.Controls.Add(this.label6);
+            this.Controls.Add(this.cmbPrimary);
+            this.Controls.Add(this.lblPrimary);
+            this.Controls.Add(this.label2);
+            this.Controls.Add(this.label1);
+            this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog;
+            this.Name = "SelectJoinKeyDialog";
+            this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
+            this.Text = "Add Property Join";
+            this.ResumeLayout(false);
+            this.PerformLayout();
+        #endregion
+        private System.Windows.Forms.Label label1;
+        private System.Windows.Forms.Label label2;
+        private System.Windows.Forms.Label lblPrimary;
+        private System.Windows.Forms.ComboBox cmbPrimary;
+        private System.Windows.Forms.ComboBox cmbSecondary;
+        private System.Windows.Forms.Label lblSecondary;
+        private System.Windows.Forms.Label label5;
+        private System.Windows.Forms.Label label6;
+        private System.Windows.Forms.Button btnOK;
+        private System.Windows.Forms.Button btnCancel;
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.cs	2010-10-20 14:50:30 UTC (rev 5306)
@@ -0,0 +1,86 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide.MaestroAPI;
+    public partial class SelectJoinKeyDialog : Form
+        internal SelectJoinKeyDialog()
+            InitializeComponent();
+        public SelectJoinKeyDialog(ClassDefinition primary, ClassDefinition secondary)
+            : this()
+            lblPrimary.Text = primary.QualifiedNameDecoded;
+            lblSecondary.Text = secondary.QualifiedNameDecoded;
+            cmbPrimary.DisplayMember = "Name";
+            cmbSecondary.DisplayMember = "Name";
+            cmbPrimary.DataSource = primary.Columns;
+            cmbSecondary.DataSource = secondary.Columns;
+            cmbPrimary.SelectedIndex = 0;
+            cmbSecondary.SelectedIndex = 0;
+        public string PrimaryProperty
+            get
+                var col = cmbPrimary.SelectedItem as FeatureSetColumn;
+                if (col != null)
+                    return col.Name;
+                return string.Empty;
+        public string SecondaryProperty
+            get
+                var col = cmbSecondary.SelectedItem as FeatureSetColumn;
+                if (col != null)
+                    return col.Name;
+        private void btnCancel_Click(object sender, EventArgs e)
+            this.DialogResult = DialogResult.Cancel;
+        private void btnOK_Click(object sender, EventArgs e)
+            this.DialogResult = DialogResult.OK;
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.resx
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.resx	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.resx	2010-10-20 14:50:30 UTC (rev 5306)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.cs	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.cs	2010-10-20 14:50:30 UTC (rev 5306)
@@ -334,6 +334,7 @@
                 splitContainer1.Panel2.Controls.Clear();
                 splitContainer1.Panel2.Controls.Add(ctl);
+                btnDelete.Enabled = true;
                 btnNewCalculation.Enabled = btnNewJoin.Enabled = IsValidExtension(ext);
@@ -354,11 +355,12 @@
                     if (cls != null)
-                        var ctl = new JoinSettings(cls.Columns, join);
+                        var ctl = new JoinSettings(cls, join);
                         ctl.Bind(_edSvc);
                         ctl.Dock = DockStyle.Fill;
@@ -383,6 +385,7 @@
Modified: sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
--- sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj	2010-10-20 14:50:30 UTC (rev 5306)
@@ -160,6 +160,12 @@
     <Compile Include="FeatureSource\Extensions\JoinSettings.Designer.cs">
       <DependentUpon>JoinSettings.cs</DependentUpon>
     </Compile>
+    <Compile Include="FeatureSource\Extensions\SelectJoinKeyDialog.cs">
+      <SubType>Form</SubType>
+    </Compile>
+    <Compile Include="FeatureSource\Extensions\SelectJoinKeyDialog.Designer.cs">
+      <DependentUpon>SelectJoinKeyDialog.cs</DependentUpon>
+    </Compile>
     <Compile Include="FeatureSource\FeatureSourceEditorCtrl.cs">
       <SubType>UserControl</SubType>
     </Compile>
@@ -650,6 +656,9 @@
       <SubType>Designer</SubType>
     </EmbeddedResource>
+    <EmbeddedResource Include="FeatureSource\Extensions\SelectJoinKeyDialog.resx">
+    </EmbeddedResource>
     <EmbeddedResource Include="FeatureSource\FeatureSourceEditorCtrl.resx">
       <DependentUpon>FeatureSourceEditorCtrl.cs</DependentUpon>
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs	2010-10-20 14:50:30 UTC (rev 5306)
@@ -1855,6 +1855,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Select Feature Class.
+        /// </summary>
+        internal static string SelectFeatureClass {
+            get {
+                return ResourceManager.GetString("SelectFeatureClass", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Select Folder.
         /// </summary>
         internal static string SelectFolder {
@@ -1922,6 +1931,15 @@
+        /// <summary>
+        ///   Looks up a localized string similar to Please specify the secondary feature source.
+        /// </summary>
+        internal static string SpecifySecondaryFeatureSource {
+            get {
+                return ResourceManager.GetString("SpecifySecondaryFeatureSource", resourceCulture);
         internal static System.Drawing.Bitmap sql {
             get {
                 object obj = ResourceManager.GetObject("sql", resourceCulture);
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx	2010-10-20 14:50:30 UTC (rev 5306)
@@ -965,4 +965,10 @@
   <data name="SelectLayer" xml:space="preserve">
     <value>Select Layer</value>
   </data>
+  <data name="SelectFeatureClass" xml:space="preserve">
+    <value>Select Feature Class</value>
+  </data>
+  <data name="SpecifySecondaryFeatureSource" xml:space="preserve">
+    <value>Please specify the secondary feature source</value>
+  </data>
 </root>
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs	2010-10-20 14:50:30 UTC (rev 5306)
@@ -256,6 +256,7 @@
+        [XmlIgnore]
         IEnumerable<ISpatialContextInfo> IFeatureSource.SupplementalSpatialContextInfo
             get
@@ -370,6 +371,12 @@
     partial class AttributeRelateType : IAttributeRelation
+        IRelateProperty IAttributeRelation.CreatePropertyJoin(string primaryProperty, string secondaryProperty)
+            return new RelatePropertyType() { FeatureClassProperty = primaryProperty, AttributeClassProperty = secondaryProperty };
+        [XmlIgnore]
         bool IAttributeRelation.ForceOneToOne
             get
@@ -388,6 +395,18 @@
             this.RelateProperty.Clear();
+        [XmlIgnore]
+        RelateTypeEnum IAttributeRelation.RelateType
+            get { return this.RelateType; }
+            set
+                this.RelateType = value;
+                this.RelateTypeSpecified = true;
+        [XmlIgnore]
         IEnumerable<IRelateProperty> IAttributeRelation.RelateProperty
             get
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSourceInterfaces.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSourceInterfaces.cs	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSourceInterfaces.cs	2010-10-20 14:50:30 UTC (rev 5306)
@@ -163,6 +163,8 @@
         IEnumerable<IRelateProperty> RelateProperty { get; }
+        IRelateProperty CreatePropertyJoin(string primaryProperty, string secondaryProperty);
         void AddRelateProperty(IRelateProperty prop);
         void RemoveRelateProperty(IRelateProperty prop);
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs	2010-10-20 13:45:01 UTC (rev 5305)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs	2010-10-20 14:50:30 UTC (rev 5306)
@@ -440,10 +440,13 @@
         public static IAttributeRelation CreateAttributeRelation()
-            return new AttributeRelateType()
+            IAttributeRelation rel = new AttributeRelateType()
                 RelateProperty = new System.ComponentModel.BindingList<RelatePropertyType>(),
+            rel.RelateType = RelateTypeEnum.LeftOuter;
+            rel.ForceOneToOne = false;
+            return rel;
More information about the mapguide-commits mailing list
