[mapguide-commits] r5324 -
trunk/MgDev/Common/Geometry/CoordinateSystem
svn_mapguide at osgeo.org
Mon Oct 25 03:07:22 EDT 2010
Author: hubu
Date: 2010-10-25 00:07:22 -0700 (Mon, 25 Oct 2010)
New Revision: 5324
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h
Fix ticket #1499.
When open site administrator(www\mapadmin\login.php) by browser, we get below error: PHP errors: syntax error,unexpected "(" on www\mapadmin\Constants.php Ln1907.
This is caused by Revision #5270?\239?\188?\140which export the const classes "MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod?" and "MgCoordinateSystemGeodeticTransformGridFileFormat?". However this 2 classes have some syntax, which will result in php syntax errors when browse the Login.php.
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h 2010-10-25 06:57:06 UTC (rev 5323)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h 2010-10-25 07:07:22 UTC (rev 5324)
@@ -36,16 +36,16 @@
static const INT32 None = 0;
- static const INT32 ThreeParameter = (8192 + 1); //cs_DTCMTH_3PARM
- static const INT32 Molodensky = (8192 + 2); //cs_DTCMTH_MOLOD
- static const INT32 AbridgedMolodensky = (8192 + 3); //cs_DTCMTH_AMOLO
- static const INT32 Geocentric = (8192 + 4); //cs_DTCMTH_GEOCT
- static const INT32 FourParameter = (8192 + 5); //cs_DTCMTH_4PARM
- static const INT32 SixParameter = (8192 + 6); //cs_DTCMTH_6PARM
- static const INT32 Bursa = (8192 + 7); //cs_DTCMTH_BURSA
- static const INT32 Frame = (8192 + 8); //cs_DTCMTH_FRAME
- static const INT32 SevenParameter = (8192 + 9); //cs_DTCMTH_7PARM
- static const INT32 MolodenskyBadekas = (8192 + 10); //cs_DTCMTH_BDKAS
+ static const INT32 ThreeParameter = 8193; //cs_DTCMTH_3PARM
+ static const INT32 Molodensky = 8194; //cs_DTCMTH_MOLOD
+ static const INT32 AbridgedMolodensky = 8195; //cs_DTCMTH_AMOLO
+ static const INT32 Geocentric = 8196; //cs_DTCMTH_GEOCT
+ static const INT32 FourParameter = 8197; //cs_DTCMTH_4PARM
+ static const INT32 SixParameter = 8198; //cs_DTCMTH_6PARM
+ static const INT32 Bursa = 8199; //cs_DTCMTH_BURSA
+ static const INT32 Frame = 8200; //cs_DTCMTH_FRAME
+ static const INT32 SevenParameter = 8201; //cs_DTCMTH_7PARM
+ static const INT32 MolodenskyBadekas = 8202; //cs_DTCMTH_BDKAS
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h 2010-10-25 06:57:06 UTC (rev 5323)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h 2010-10-25 07:07:22 UTC (rev 5324)
@@ -36,8 +36,8 @@
- static const INT32 MultipleRegression = (20480 + 1); //cs_DTCMTH_MULRG
- static const INT32 GeneralPolynomialEpsg = (20480 + 2); //cs_DTCMTH_PLYNM
+ static const INT32 MultipleRegression = 20481; //cs_DTCMTH_MULRG
+ static const INT32 GeneralPolynomialEpsg = 20482; //cs_DTCMTH_PLYNM
More information about the mapguide-commits
