[mapguide-commits] r5329 - in sandbox/maestro-3.0: Maestro.Base
Maestro.Base/Commands Maestro.Base/Commands/Test
Maestro.Base/Editor Maestro.Base/Services Maestro.Base/UI
Maestro.Editors Maestro.Editors/Common Maestro.Editors/Properties
svn_mapguide at osgeo.org
Tue Oct 26 04:57:42 EDT 2010
Author: jng
Date: 2010-10-26 01:57:42 -0700 (Tue, 26 Oct 2010)
New Revision: 5329
sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs
sandbox/maestro-3.0/Maestro.Base/Commands/SaveResourceAsCommand.cs
sandbox/maestro-3.0/Maestro.Base/Commands/Test/OpenResourceCommand.cs
sandbox/maestro-3.0/Maestro.Base/Editor/ResourceEditorService.cs
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs
sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.cs
sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.resx
sandbox/maestro-3.0/Maestro.Editors/IEditorService.cs
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
3.0 sandbox changes:
- #1500: Use vanilla TreeView in ResourcePicker.
- Productivity enhancements
- Also add a SetStartingPoint() API to allow auto-drilldown to the specified folder
- Add a SuggestedSaveFolder property to IEditorService that specifies where the ResourcePicker should start from when prompting for save.
- Thus a "Save As" command on a new resource will display the resource picker starting from where they right clicked when they chose "New Resource"
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs 2010-10-26 07:59:20 UTC (rev 5328)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs 2010-10-26 08:57:42 UTC (rev 5329)
@@ -39,12 +39,12 @@
var nits = ServiceRegistry.GetService<NewItemTemplateService>();
NewResourceDialog dlg = null;
+ string startPoint = null;
if (exp.SelectedItems.Length == 1)
var item = exp.SelectedItems[0];
if (item.IsFolder)
- dlg = new NewResourceDialog(conn.ResourceService, conn.SiteVersion, nits, item.ResourceId);
+ startPoint = item.ResourceId;
if (dlg == null)
@@ -60,7 +60,9 @@
res.ResourceID = "Session:" + conn.SessionID + "//" + Guid.NewGuid().ToString() + "." + res.ResourceType.ToString();
conn.ResourceService.SaveResource(res);
- orm.Open(res.ResourceID, conn, false, exp);
+ var ed = orm.Open(res.ResourceID, conn, false, exp);
+ if (!string.IsNullOrEmpty(startPoint))
+ ed.EditorService.SuggestedSaveFolder = startPoint;
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/SaveResourceAsCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/SaveResourceAsCommand.cs 2010-10-26 07:59:20 UTC (rev 5328)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/SaveResourceAsCommand.cs 2010-10-26 08:57:42 UTC (rev 5329)
@@ -43,6 +43,9 @@
using (var picker = new ResourcePicker(conn.ResourceService, ed.Resource.ResourceType, ResourcePickerMode.SaveResource))
+ if (!string.IsNullOrEmpty(ed.EditorService.SuggestedSaveFolder))
+ picker.SetStartingPoint(ed.EditorService.SuggestedSaveFolder);
if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
using (new WaitCursor(wb))
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/Test/OpenResourceCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/Test/OpenResourceCommand.cs 2010-10-26 07:59:20 UTC (rev 5328)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/Test/OpenResourceCommand.cs 2010-10-26 08:57:42 UTC (rev 5329)
@@ -47,6 +47,28 @@
+ public class OpenResourceFromStartingPointCommand : AbstractMenuCommand
+ public override void Run()
+ var wb = Workbench.Instance;
+ var exp = wb.ActiveSiteExplorer;
+ var mgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ var conn = mgr.GetConnection(exp.ConnectionName);
+ var picker = new ResourcePicker(conn.ResourceService, ResourcePickerMode.OpenResource);
+ picker.SetStartingPoint("Library://Samples/Sheboygan/");
+ if (picker.ShowDialog(wb) == System.Windows.Forms.DialogResult.OK)
+ MessageService.ShowMessage(picker.ResourceID);
+ else
+ MessageService.ShowMessage("Cancelled");
public class OpenFolderCommand : AbstractMenuCommand
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/ResourceEditorService.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/ResourceEditorService.cs 2010-10-26 07:59:20 UTC (rev 5328)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/ResourceEditorService.cs 2010-10-26 08:57:42 UTC (rev 5329)
@@ -310,5 +310,11 @@
_orm.Open(resourceId, _conn, false, _siteExp);
+ public string SuggestedSaveFolder
+ get;
+ set;
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-10-26 07:59:20 UTC (rev 5328)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-10-26 08:57:42 UTC (rev 5329)
@@ -114,6 +114,9 @@
<MenuItem id="Menu_Test_OpenResource"
label="Open Resource"
class="Maestro.Base.Commands.Test.OpenResourceCommand" />
+ <MenuItem id="Menu_Test_OpenResourceStartingPoint"
+ label="Open Resource (from starting point)"
+ class="Maestro.Base.Commands.Test.OpenResourceFromStartingPointCommand" />
<MenuItem id="Menu_Test_OpenResourceWithFilter"
label="Open Resource (with filter)"
class="Maestro.Base.Commands.Test.OpenResourceWithFilterCommand" />
Modified: sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs 2010-10-26 07:59:20 UTC (rev 5328)
+++ sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs 2010-10-26 08:57:42 UTC (rev 5329)
@@ -106,7 +106,7 @@
/// <param name="res"></param>
/// <param name="conn"></param>
/// <param name="useXmlEditor"></param>
- public void Open(IResource res, IServerConnection conn, bool useXmlEditor, ISiteExplorer siteExp)
+ public IEditorViewContent Open(IResource res, IServerConnection conn, bool useXmlEditor, ISiteExplorer siteExp)
string resourceId = res.ResourceID;
if (!_openItems.ContainsKey(resourceId))
@@ -147,6 +147,7 @@
_openItems[resourceId].Activate();
siteExp.FlagNode(resourceId, NodeFlagAction.HighlightOpen);
+ return _openItems[resourceId];
/// <summary>
@@ -158,18 +159,18 @@
/// <param name="resourceId"></param>
- public void Open(string resourceId, IServerConnection conn, bool useXmlEditor, ISiteExplorer siteExp)
+ public IEditorViewContent Open(string resourceId, IServerConnection conn, bool useXmlEditor, ISiteExplorer siteExp)
IResource res = null;
try
res = (IResource)conn.ResourceService.GetResource(resourceId);
- Open(res, conn, useXmlEditor, siteExp);
+ return Open(res, conn, useXmlEditor, siteExp);
catch (Exception ex)
MessageService.ShowError(ex);
- return;
+ return null;
Modified: sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs 2010-10-26 07:59:20 UTC (rev 5328)
+++ sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs 2010-10-26 08:57:42 UTC (rev 5329)
@@ -44,9 +44,7 @@
private IResourceService _resSvc;
private NewItemTemplateService _nits;
- public NewResourceDialog(IResourceService resSvc, Version siteVersion, NewItemTemplateService nits) : this(resSvc, siteVersion, nits, "Library://") { }
- public NewResourceDialog(IResourceService resSvc, Version siteVersion, NewItemTemplateService nits, string startPoint)
+ public NewResourceDialog(IResourceService resSvc, Version siteVersion, NewItemTemplateService nits)
: this()
_siteVersion = siteVersion;
Modified: sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.Designer.cs 2010-10-26 07:59:20 UTC (rev 5328)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.Designer.cs 2010-10-26 08:57:42 UTC (rev 5329)
@@ -30,7 +30,6 @@
this.components = new System.ComponentModel.Container();
System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(ResourcePicker));
- this.trvFolders = new Aga.Controls.Tree.TreeViewAdv();
this.nodeIcon1 = new Aga.Controls.Tree.NodeControls.NodeIcon();
this.nodeTextBox1 = new Aga.Controls.Tree.NodeControls.NodeTextBox();
this.lstResources = new System.Windows.Forms.ListView();
@@ -44,6 +43,8 @@
this.label3 = new System.Windows.Forms.Label();
this.label4 = new System.Windows.Forms.Label();
this.splitContainer1 = new System.Windows.Forms.SplitContainer();
+ this.trvFolders = new System.Windows.Forms.TreeView();
+ this.folderImageList = new System.Windows.Forms.ImageList(this.components);
this.label2 = new System.Windows.Forms.Label();
this.txtFolder = new System.Windows.Forms.TextBox();
this.label5 = new System.Windows.Forms.Label();
@@ -55,29 +56,6 @@
this.resIdComponentPanel.SuspendLayout();
this.SuspendLayout();
- // trvFolders
- this.trvFolders.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
- | System.Windows.Forms.AnchorStyles.Left)
- | System.Windows.Forms.AnchorStyles.Right)));
- this.trvFolders.BackColor = System.Drawing.SystemColors.Window;
- this.trvFolders.BorderStyle = System.Windows.Forms.BorderStyle.FixedSingle;
- this.trvFolders.DefaultToolTipProvider = null;
- this.trvFolders.DragDropMarkColor = System.Drawing.Color.Black;
- this.trvFolders.LineColor = System.Drawing.SystemColors.ControlDark;
- this.trvFolders.LoadOnDemand = true;
- this.trvFolders.Location = new System.Drawing.Point(12, 31);
- this.trvFolders.Model = null;
- this.trvFolders.Name = "trvFolders";
- this.trvFolders.NodeControls.Add(this.nodeIcon1);
- this.trvFolders.NodeControls.Add(this.nodeTextBox1);
- this.trvFolders.SelectedNode = null;
- this.trvFolders.Size = new System.Drawing.Size(160, 241);
- this.trvFolders.TabIndex = 0;
- this.trvFolders.SelectionChanged += new System.EventHandler(this.trvFolders_SelectionChanged);
- this.trvFolders.Expanding += new System.EventHandler<Aga.Controls.Tree.TreeViewAdvEventArgs>(this.trvFolders_Expanding);
- this.trvFolders.Expanded += new System.EventHandler<Aga.Controls.Tree.TreeViewAdvEventArgs>(this.trvFolders_Expanded);
// nodeIcon1
this.nodeIcon1.DataPropertyName = "Icon";
@@ -106,6 +84,7 @@
this.lstResources.TabIndex = 1;
this.lstResources.UseCompatibleStateImageBehavior = false;
this.lstResources.View = System.Windows.Forms.View.List;
+ this.lstResources.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.lstResources_MouseDoubleClick);
this.lstResources.SelectedIndexChanged += new System.EventHandler(this.lstResources_SelectedIndexChanged);
// resImageList
@@ -216,8 +195,8 @@
// splitContainer1.Panel1
- this.splitContainer1.Panel1.Controls.Add(this.label3);
this.splitContainer1.Panel1.Controls.Add(this.trvFolders);
+ this.splitContainer1.Panel1.Controls.Add(this.label3);
// splitContainer1.Panel2
@@ -227,6 +206,23 @@
this.splitContainer1.SplitterDistance = 175;
this.splitContainer1.TabIndex = 10;
+ // trvFolders
+ this.trvFolders.ImageIndex = 0;
+ this.trvFolders.ImageList = this.folderImageList;
+ this.trvFolders.Location = new System.Drawing.Point(12, 31);
+ this.trvFolders.Name = "trvFolders";
+ this.trvFolders.SelectedImageIndex = 0;
+ this.trvFolders.Size = new System.Drawing.Size(160, 241);
+ this.trvFolders.TabIndex = 9;
+ // folderImageList
+ this.folderImageList.ImageStream = ((System.Windows.Forms.ImageListStreamer)(resources.GetObject("folderImageList.ImageStream")));
+ this.folderImageList.TransparentColor = System.Drawing.Color.Transparent;
+ this.folderImageList.Images.SetKeyName(0, "server.png");
+ this.folderImageList.Images.SetKeyName(1, "folder-horizontal.png");
// label2
this.label2.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Left)));
@@ -314,7 +310,6 @@
#endregion
- private Aga.Controls.Tree.TreeViewAdv trvFolders;
private System.Windows.Forms.ListView lstResources;
private System.Windows.Forms.Button btnOK;
private System.Windows.Forms.Button btnCancel;
@@ -333,5 +328,7 @@
private System.Windows.Forms.Label label5;
private System.Windows.Forms.TextBox txtName;
private System.Windows.Forms.Panel resIdComponentPanel;
+ private System.Windows.Forms.TreeView trvFolders;
+ private System.Windows.Forms.ImageList folderImageList;
\ No newline at end of file
Modified: sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.cs
--- sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.cs 2010-10-26 07:59:20 UTC (rev 5328)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.cs 2010-10-26 08:57:42 UTC (rev 5329)
@@ -74,6 +74,8 @@
private bool _resourceMode = false;
+ private RepositoryFolderTreeModel _model;
/// <summary>
/// Constructs a new instance. Use this overload to select any resource type. If only
/// folder selection is desired, set <see cref="SelectFoldersOnly"/> to true before
@@ -84,11 +86,24 @@
: this()
_resSvc = resSvc;
- trvFolders.Model = new RepositoryFolderTreeModel(_resSvc);
+ _model = new RepositoryFolderTreeModel(_resSvc, trvFolders);
+ _model.FolderSelected += OnFolderSelected;
this.UseFilter = true;
this.Mode = mode;
+ void OnFolderSelected(object sender, EventArgs e)
+ UpdateDocumentList();
+ public void SetStartingPoint(string folderId)
+ if (!ResourceIdentifier.IsFolderResource(folderId))
+ throw new ArgumentException(string.Format(Properties.Resources.NotAFolder, folderId));
+ _model.NavigateTo(folderId);
private ResourcePickerMode _mode = ResourcePickerMode.OpenResource;
public ResourcePickerMode Mode
@@ -257,17 +272,11 @@
this.DialogResult = DialogResult.OK;
- private void trvFolders_SelectionChanged(object sender, EventArgs e)
- UpdateDocumentList();
private void UpdateDocumentList()
- var node = trvFolders.SelectedNode;
- if (node != null)
+ RepositoryFolder folder = _model.SelectedFolder;
+ if (folder != null)
- RepositoryFolder folder = node.Tag as RepositoryFolder;
txtFolder.Text = folder.ResourceId;
if (!this.SelectFoldersOnly)
@@ -351,36 +360,6 @@
- private void trvFolders_Expanding(object sender, TreeViewAdvEventArgs e)
- if (this.InvokeRequired)
- this.Invoke(new MethodInvoker(() =>
- this.Cursor = Cursors.WaitCursor;
- else
- private void trvFolders_Expanded(object sender, TreeViewAdvEventArgs e)
- this.Cursor = Cursors.Default;
- else
private void txtName_TextChanged(object sender, EventArgs e)
UpdateResourceId();
@@ -396,6 +375,20 @@
UpdateResourceId();
+ private void lstResources_MouseDoubleClick(object sender, MouseEventArgs e)
+ var item = lstResources.GetItemAt(e.X, e.Y);
+ if (item != null)
+ var doc = item.Tag as ResourceListResourceDocument;
+ if (doc != null)
+ txtName.Text = ResourceIdentifier.GetName(doc.ResourceId);
+ btnOK.PerformClick();
public enum ResourcePickerMode
@@ -441,15 +434,109 @@
- internal class RepositoryFolderTreeModel : ITreeModel
+ internal class RepositoryFolderTreeModel
+ class DummyNode : TreeNode
+ internal event EventHandler FolderSelected;
+ private TreeView _tree;
- public RepositoryFolderTreeModel(IResourceService resSvc)
+ public RepositoryFolder SelectedFolder
+ get;
+ private set;
+ private void StartUpdate()
+ _tree.BeginUpdate();
+ _tree.Cursor = Cursors.WaitCursor;
+ private void EndUpdate()
+ _tree.EndUpdate();
+ _tree.Cursor = Cursors.Default;
+ public RepositoryFolderTreeModel(IResourceService resSvc, TreeView tree)
_resSvc = resSvc;
+ _tree = tree;
+ _tree.AfterExpand += new TreeViewEventHandler(OnNodeAfterExpand);
+ _tree.AfterSelect += new TreeViewEventHandler(OnNodeAfterSelect);
+ StartUpdate();
+ foreach (RepositoryFolder folder in GetChildren(null))
+ var node = CreateNode(folder);
+ _tree.Nodes.Add(node);
+ EndUpdate();
+ void OnNodeAfterSelect(object sender, TreeViewEventArgs e)
+ RepositoryFolder folder = (RepositoryFolder)e.Node.Tag;
+ SetSelectedFolder(folder);
+ private void SetSelectedFolder(RepositoryFolder folder)
+ this.SelectedFolder = folder;
+ var handler = this.FolderSelected;
+ if (handler != null)
+ handler(this, EventArgs.Empty);
+ bool IsNodeNotPopulated(TreeNode node)
+ return node.Nodes.Count == 1 && node.Nodes[0].GetType() == typeof(DummyNode);
+ void OnNodeAfterExpand(object sender, TreeViewEventArgs e)
+ UpdateNode(e.Node);
+ private void UpdateNode(TreeNode nodeToUpdate)
+ RepositoryFolder folder = (RepositoryFolder)nodeToUpdate.Tag;
+ if (IsNodeNotPopulated(nodeToUpdate))
+ nodeToUpdate.Nodes.Clear();
+ if (folder.HasChildren && nodeToUpdate.Nodes.Count == 0)
+ StartUpdate();
+ foreach (RepositoryFolder f in GetChildren(folder))
+ var node = CreateNode(f);
+ nodeToUpdate.Nodes.Add(node);
+ EndUpdate();
+ const int IDX_SERVER = 0;
+ const int IDX_FOLDER = 1;
+ private static TreeNode CreateNode(RepositoryFolder folder)
+ var node = new TreeNode();
+ node.Name = folder.Name;
+ node.Text = folder.Name;
+ node.Tag = folder;
+ node.ImageIndex = node.SelectedImageIndex = folder.IsRoot ? IDX_SERVER : IDX_FOLDER;
+ node.Nodes.Add(new DummyNode());
+ return node;
private System.Collections.IEnumerable GetSorted(ResourceList list)
//Sort them before returning them
@@ -465,19 +552,18 @@
- public System.Collections.IEnumerable GetChildren(TreePath treePath)
+ public System.Collections.IEnumerable GetChildren(RepositoryFolder folder)
- if (treePath.IsEmpty())
+ if (folder == null)
var list = _resSvc.GetRepositoryResources("Library://", 0);
return GetSorted(list);
else
- var node = treePath.LastNode as RepositoryFolder;
- if (node.HasChildren)
+ if (folder.HasChildren)
- var list = _resSvc.GetRepositoryResources(node.ResourceId, ResourceTypes.Folder.ToString(), 1, true);
+ var list = _resSvc.GetRepositoryResources(folder.ResourceId, ResourceTypes.Folder.ToString(), 1, true);
else
@@ -487,18 +573,42 @@
- public bool IsLeaf(TreePath treePath)
+ internal void NavigateTo(string folderId)
- return !((RepositoryFolder)treePath.LastNode).HasChildren;
+ NavigateTo(folderId, null);
- public event EventHandler<TreeModelEventArgs> NodesChanged;
+ internal void NavigateTo(string folderId, TreeNode currentNode)
+ TreeNodeCollection nodeList = null;
- public event EventHandler<TreeModelEventArgs> NodesInserted;
+ if (currentNode == null)
+ nodeList = _tree.Nodes;
+ else
+ var folder = (RepositoryFolder)currentNode.Tag;
+ if (folderId.Equals(folder.ResourceId))
+ _tree.SelectedNode = currentNode;
+ return;
+ nodeList = currentNode.Nodes;
- public event EventHandler<TreeModelEventArgs> NodesRemoved;
- public event EventHandler<TreePathEventArgs> StructureChanged;
+ foreach (TreeNode node in nodeList)
+ var folder = (RepositoryFolder)node.Tag;
+ if (folderId.StartsWith(folder.ResourceId))
+ UpdateNode(node);
+ node.Expand();
+ NavigateTo(folderId, node);
+ break;
Modified: sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.resx
--- sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.resx 2010-10-26 07:59:20 UTC (rev 5328)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.resx 2010-10-26 08:57:42 UTC (rev 5329)
@@ -125,7 +125,7 @@
AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADQ
- EQAAAk1TRnQBSQFMAgEBCQEAAaABAAGgAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
+ EQAAAk1TRnQBSQFMAgEBCQEAAcABAAHAAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
AwABQAMAATADAAEBAQABCAYAAQwYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
@@ -204,6 +204,60 @@
AQABAQs=
</value>
</data>
+ <metadata name="folderImageList.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>137, 17</value>
+ </metadata>
+ <data name="folderImageList.ImageStream" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>
+ AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
+ LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAA0
+ CgAAAk1TRnQBSQFMAgEBAgEAAQgBAAEIAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+ AwABEAMAAQEBAAEgBgABEBYAAwcBCgMSARgDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMT
+ ARoDEwEaAxIBGAMIAQvIAAMOARMDMgFnAzABpAMwAaQDMAGkAzABpAMwAaQDMAGkAzABpAMwAaQDMAGk
+ AzABpAMyAWgDDwEVBAADBAEGAxABFgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMT
+ ARoDEwEaAxMBGgMQARYDBAEGiAADGgElAzUBjgOGAf8DggH/A4IB/wOCAf8DggH/A4IB/wOCAf8DhgH/
+ AzUBjgMaASUIAAEzAUoBVgGRASgBWwF2Ab0BKAFbAXYBvQEoAVsBdgG9ASgBWwF2Ab0BKAFbAXYBvQEo
+ AVsBdgG9ASgBWwF2Ab0BKAFbAXYBvQEoAVsBdgG9ASgBWwF2Ab0BKAFbAXYBvQEoAVsBdgG9ASgBWwF2
+ Ab0BKAFbAXYBvQEzAUoBVgGRjAADNAGTA2wB/wNoAf8DaAH/A2gB/wNoAf8DaAH/ATIBzAEyAf8DbAH/
+ AzQBkwwAASwBXgF2AbABhgHPAfAB/wGCAcsB7QH/AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/AYIBywHt
+ Af8BggHLAe0B/wGCAcsB7QH/AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/AYIBywHtAf8BggHLAe0B/wGG
+ Ac8B8AH/ASwBXgF2AbCMAAMvAagDVAH/A1QB/wNUAf8DVAH/A1QB/wNUAf8DVAH/A1QB/wMvAagMAAEw
+ AV4BdQGiAYYBzwHuAf8BfAHIAegB/wF8AcgB6AH/AXwByAHoAf8BfAHIAegB/wF8AcgB6AH/AXwByAHo
+ Af8BfAHIAegB/wF8AcgB6AH/AXwByAHoAf8BfAHIAegB/wF8AcgB6AH/AXwByAHoAf8BhgHPAe4B/wEw
+ AV4BdQGijAADPAF+A8cB/wO9Af8DvQH/A70B/wO9Af8DvQH/A70B/wPHAf8DPAF+DAABMQFdAXMBnQGK
+ AdMB8AH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYIBzAHr
+ Af8BggHMAesB/wGCAcwB6wH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYoB0wHwAf8BMQFdAXMBnYwA
+ Az8BeAPKAf8DwAH/A8AB/wPAAf8DwAH/A8AB/wPSAf8DygH/Az8BeAwAATIBXQFyAZkBjwHXAfIB/wGH
+ AdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGHAdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGHAdAB7QH/AYcB0AHt
+ Af8BhwHQAe0B/wGHAdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGPAdcB8gH/ATIBXQFyAZmMAAM/AXUDzQH/
+ A8MB/wPDAf8DwwH/A8MB/wPDAf8DmQH/A80B/wM/AXUMAAEzAV0BcQGVAZQB2wH0Af8BjQHVAfAB/wGN
+ AdUB8AH/AY0B1QHwAf8BjQHVAfAB/wGNAdUB8AH/AY0B1QHwAf8BjQHVAfAB/wGNAdUB8AH/AY0B1QHw
+ Af8BjQHVAfAB/wGNAdUB8AH/AY0B1QHwAf8BlAHbAfQB/wEzAV0BcQGVjAADQAFzA9YB/wPRAf8D0QH/
+ A9EB/wPRAf8D0QH/A9EB/wPWAf8DQAFzDAABMwFcAXABkgGZAeAB9gH/AZIB2gHzAf8BkgHaAfMB/wGS
+ AdoB8wH/AZIB2gHzAf8BkgHaAfMB/wGSAdoB8wH/AZIB2gHzAf8BkgHaAfMB/wGSAdoB8wH/AZIB2gHz
+ Af8BkgHaAfMB/wGSAdoB8wH/AZkB4AH2Af8BMwFcAXABkowAA0ABcQO3Af8DuwH/A7sB/wO7Af8DuwH/
+ A7sB/wO7Af8DtwH/A0ABcQwAATQBXAFuAY4BnwHlAfkB/wGYAd8B9gH/AZgB3wH2Af8BmAHfAfYB/wGY
+ Ad8B9gH/AZgB3wH2Af8BmAHfAfYB/wGYAd8B9gH/AZgB3wH2Af8BmAHfAfYB/wGYAd8B9gH/AZgB3wH2
+ Af8BmAHfAfYB/wGfAeUB+QH/ATQBXAFuAY6MAANAAW8D2QH/A88B/wPPAf8DzwH/A88B/wPPAf8DzwH/
+ A9kB/wNAAW8MAAE0AVoBbQGLAaMB6QH7Af8BnQHjAfkB/wGdAeMB+QH/AZ0B4wH5Af8BnQHjAfkB/wGd
+ AeMB+QH/AZ0B4wH5Af8BowHpAfoB/wGjAekB+gH/AaMB6QH6Af8BowHpAfoB/wGjAekB+gH/AaMB6QH6
+ Af8BpgHsAfsB/wE0AVoBbQGLjAADQAFtA+EB/wPcAf8D3AH/A9wB/wPcAf8D3AH/A9wB/wPhAf8DQAFt
+ DAABNAFZAWwBiAGoAe0B/QH/AaIB5wH7Af8BogHnAfsB/wGiAecB+wH/AaIB5wH7Af8BogHnAfsB/wGr
+ AfAB/QH/AYUBygHmAf8BdwG8Ad4B/wF3AbwB3gH/AXcBvAHeAf8BdwG8Ad4B/wF3AbwB3gH/AXcBvAHe
+ Af8BNAFZAWwBiIwAA0ABawPBAf8DxgH/A8YB/wPGAf8DxgH/A8YB/wPGAf8DwQH/A0ABawwAATQBWAFr
+ AYUBrgHzAv8BqwHwAf4B/wGrAfAB/gH/AasB8AH+Af8BqwHwAf4B/wGuAfMC/wGJAc0B6QH/AYkBzQHp
+ Af8BqwHwAf4B/wGrAfAB/gH/AasB8AH+Af8BqwHwAf4B/wGrAfAB/gH/Aa4B8wL/ATQBWAFrAYWMAANA
+ AWkD4wH/A9oB/wPaAf8D2gH/A9oB/wPaAf8D2gH/A+MB/wNAAWkMAAEyAUYBUAFjATQBWAFqAYMBNAFY
+ AWoBgwE0AVgBagGDATQBWAFqAYMBNAFYAWoBgwE0AVgBagGDATQBWAFqAYMC/gH9Af8C+AHzAf8C8AHm
+ Af8C6QHbAf8B/gHJAUAB/wH0AbYBLQH/ATQBWAFqAYMBMgFGAVABY4wAA0ABaAPqAf8D5QH/A+UB/wPl
+ Af8D5QH/A+UB/wPlAf8D6gH/A0ABaCgAAR8BIwElAS4BNAFXAWgBgQE0AVcBaAGBATQBVwFoAYEBNAFX
+ AWgBgQE0AVcBaAGBATQBVwFoAYEBHwEjASUBLpAAAzQBTQNAAWcDQAFnA0ABZwNAAWcDQAFnA0ABZwNA
+ AWcDQAFnAzQBTcwAAUIBTQE+BwABPgMAASgDAAFAAwABEAMAAQEBAAEBBQABgBcAA/8BAAGAAQEC/wQA
+ AYABAQYAAcABAwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYA
+ AeABBwYAAeABBwYAAeABBwYAAeABBwH+AQEEAAHgAQcC/wQACw==
+</value>
+ </data>
<assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="$this.Icon" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
Modified: sandbox/maestro-3.0/Maestro.Editors/IEditorService.cs
--- sandbox/maestro-3.0/Maestro.Editors/IEditorService.cs 2010-10-26 07:59:20 UTC (rev 5328)
+++ sandbox/maestro-3.0/Maestro.Editors/IEditorService.cs 2010-10-26 08:57:42 UTC (rev 5329)
@@ -65,6 +65,10 @@
/// </summary>
string SessionID { get; }
/// <summary>
+ /// Gets the suggested save folder for a "save as" operation
+ /// </summary>
+ string SuggestedSaveFolder { get; set; }
+ /// <summary>
/// Registers a custom notifier
/// </summary>
/// <param name="irc"></param>
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-10-26 07:59:20 UTC (rev 5328)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-10-26 08:57:42 UTC (rev 5329)
@@ -1647,6 +1647,15 @@
/// <summary>
+ /// Looks up a localized string similar to Not a folder: {0}.
+ /// </summary>
+ internal static string NotAFolder {
+ get {
+ return ResourceManager.GetString("NotAFolder", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to You must select at least one type.
/// </summary>
internal static string NoTypesSelected {
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-10-26 07:59:20 UTC (rev 5328)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-10-26 08:57:42 UTC (rev 5329)
@@ -986,4 +986,7 @@
<data name="NoSiteService" xml:space="preserve">
<value>No site service available</value>
</data>
+ <data name="NotAFolder" xml:space="preserve">
+ <value>Not a folder: {0}</value>
+ </data>
</root>
More information about the mapguide-commits
