[mapguide-commits] r5344 - in sandbox/maestro-3.0: . Maestro.Base
Maestro.Base/Commands Maestro.Base/Commands/Conditions
Maestro.Base/Commands/SiteExplorer Maestro.Base/Editor
Maestro.Base/Properties Maestro.Base/Resources
Maestro.Base/Services Maestro.Base/UI SDK
svn_mapguide at osgeo.org
Thu Oct 28 05:02:19 EDT 2010
Author: jng
Date: 2010-10-28 02:02:19 -0700 (Thu, 28 Oct 2010)
New Revision: 5344
Added:
sandbox/maestro-3.0/Maestro.Base/Commands/CloseAllDocumentsCommand.cs
sandbox/maestro-3.0/Maestro.Base/Commands/Conditions/NonZeroDocumentConditionEvaluator.cs
sandbox/maestro-3.0/Maestro.Base/Commands/SaveAllCommand.cs
sandbox/maestro-3.0/Maestro.Base/Resources/disks.png
Removed:
sandbox/maestro-3.0/Maestro.Base/Commands/ValidateResourceCommand.cs
sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/ValidateCommand.cs
sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs
sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.cs
sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.resx
sandbox/maestro-3.0/SDK/
sandbox/maestro-3.0/build.bat
3.0 sandbox changes:
- Tweak the unsaved changes confirmation prompt to include the name of the resource
- Update build.bat to build both SDK and Maestro solutions
- #1508: Add close all and save all documents command with a zero document condition evaluator to enable/disable them
- #1508: Add missing shortcuts for Save, Save All, Close and Close All commands
- #1500: Make validation results dialog non-modal and remove a redundant validation command
Added: sandbox/maestro-3.0/Maestro.Base/Commands/CloseAllDocumentsCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/CloseAllDocumentsCommand.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/CloseAllDocumentsCommand.cs 2010-10-28 09:02:19 UTC (rev 5344)
@@ -0,0 +1,39 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using ICSharpCode.Core;
+using Maestro.Base.Services;
+namespace Maestro.Base.Commands
+ internal class CloseAllDocumentsCommand : AbstractMenuCommand
+ public override void Run()
+ var omgr = ServiceRegistry.GetService<OpenResourceManager>();
+ foreach (var ed in omgr.OpenEditors)
+ ed.Close(false);
Added: sandbox/maestro-3.0/Maestro.Base/Commands/Conditions/NonZeroDocumentConditionEvaluator.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/Conditions/NonZeroDocumentConditionEvaluator.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/Conditions/NonZeroDocumentConditionEvaluator.cs 2010-10-28 09:02:19 UTC (rev 5344)
@@ -0,0 +1,36 @@
+#endregion
+using System;
+using System.Text;
+namespace Maestro.Base.Commands.Conditions
+ internal class NonZeroDocumentConditionEvaluator : IConditionEvaluator
+ public bool IsValid(object caller, Condition condition)
+ return omgr.OpenEditors.Length > 0;
Added: sandbox/maestro-3.0/Maestro.Base/Commands/SaveAllCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/SaveAllCommand.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/SaveAllCommand.cs 2010-10-28 09:02:19 UTC (rev 5344)
@@ -0,0 +1,42 @@
+#endregion
+using System;
+using System.Text;
+ internal class SaveAllCommand : AbstractMenuCommand
+ if (ed.IsDirty)
+ ed.EditorService.Save();
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/ValidateCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/ValidateCommand.cs 2010-10-28 00:53:04 UTC (rev 5343)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/ValidateCommand.cs 2010-10-28 09:02:19 UTC (rev 5344)
@@ -29,6 +29,7 @@
using OSGeo.MapGuide.MaestroAPI.Exceptions;
using OSGeo.MapGuide.ObjectModels.Common;
using OSGeo.MapGuide.MaestroAPI.Resource.Validation;
+using Maestro.Base.UI;
namespace Maestro.Base.Commands.SiteExplorer
@@ -82,7 +83,7 @@
var resDlg = new ValidationResultsDialog(groupedIssues);
- resDlg.ShowDialog(wb);
+ resDlg.Show();
else
Deleted: sandbox/maestro-3.0/Maestro.Base/Commands/ValidateResourceCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/ValidateResourceCommand.cs 2010-10-28 00:53:04 UTC (rev 5343)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/ValidateResourceCommand.cs 2010-10-28 09:02:19 UTC (rev 5344)
@@ -1,149 +0,0 @@
-#region Disclaimer / License
-// Copyright (C) 2010, Jackie Ng
-// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of the GNU Lesser General Public
-// License as published by the Free Software Foundation; either
-// version 2.1 of the License, or (at your option) any later version.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
-#endregion
-using System;
-using System.Collections.Generic;
-using System.Text;
-using ICSharpCode.Core;
-using Maestro.Base.Services;
-using OSGeo.MapGuide.MaestroAPI.Resource;
-using OSGeo.MapGuide.ObjectModels.Common;
-using System.ComponentModel;
-using Maestro.Shared.UI;
-using OSGeo.MapGuide.MaestroAPI;
-using OSGeo.MapGuide.MaestroAPI.Exceptions;
-using OSGeo.MapGuide.MaestroAPI.Resource.Validation;
-namespace Maestro.Base.Commands
- internal class ValidateResourceCommand : AbstractMenuCommand
- private IServerConnection _conn;
- public override void Run()
- var wb = Workbench.Instance;
- var ed = wb.ActiveEditor;
- var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
- //TODO: Will need to look at this again, when we decide to support
- //multiple connections to different sites from the same session. Right
- //now this is fine as we can only connect to one site at any time.
- _conn = connMgr.GetConnection(wb.ActiveSiteExplorer.ConnectionName);
- if (ed != null)
- var pdlg = new ProgressDialog();
- pdlg.CancelAbortsThread = true;
- ed.SyncSessionCopy();
- var issues = (ValidationIssue[])pdlg.RunOperationAsync(wb, new ProgressDialog.DoBackgroundWork(BackgroundValidate), ed.Resource.ResourceID);
- if (issues != null)
- if (issues.Length > 0)
- //Sigh! LINQ would've made this code so simple...
- var sort = new Dictionary<string, List<ValidationIssue>>();
- foreach (var issue in issues)
- string resId = issue.Resource.ResourceID;
- if (!sort.ContainsKey(resId))
- sort[resId] = new List<ValidationIssue>();
- sort[resId].Add(issue);
- var groupedIssues = new List<KeyValuePair<string, ValidationIssue[]>>();
- foreach (var kvp in sort)
- groupedIssues.Add(
- new KeyValuePair<string, ValidationIssue[]>(
- kvp.Key,
- kvp.Value.ToArray()));
- var resDlg = new ValidationResultsDialog(groupedIssues);
- else
- MessageService.ShowMessage(Properties.Resources.ValidationNoIssues);
- private object BackgroundValidate(BackgroundWorker worker, DoWorkEventArgs e, params object[] args)
- //Collect all documents to be validated. Some of these selected items
- //may be folders.
- var documents = new List<string>();
- foreach (object a in args)
- string rid = a.ToString();
- if (ResourceIdentifier.Validate(rid))
- var resId = new ResourceIdentifier(rid);
- if (resId.IsFolder)
- foreach (IRepositoryItem o in _conn.ResourceService.GetRepositoryResources((string)args[0]).Children)
- if (!o.IsFolder)
- documents.Add(o.ResourceId);
- else
- documents.Add(rid);
- worker.ReportProgress(0);
- var issues = new List<ValidationIssue>();
- int i = 0;
- foreach (string s in documents)
- worker.ReportProgress((int)((i / (double)documents.Count) * 100), s);
- IResource item = null;
- try
- //TODO: This will validate resources multiple times, if they are referenced by
- //resources inside the folder
- item = _conn.ResourceService.GetResource(s);
- issues.AddRange(ResourceValidatorSet.Validate(item, true));
- catch (Exception ex)
- string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
- issues.Add(new ValidationIssue(item, ValidationStatus.Error, string.Format(Properties.Resources.ValidationResourceLoadFailed, msg)));
- i++;
- return issues.ToArray();
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs 2010-10-28 00:53:04 UTC (rev 5343)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs 2010-10-28 09:02:19 UTC (rev 5344)
@@ -29,6 +29,7 @@
using Maestro.Editors;
namespace Maestro.Base.Editor
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-10-28 00:53:04 UTC (rev 5343)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-10-28 09:02:19 UTC (rev 5344)
@@ -20,6 +20,7 @@
<ConditionEvaluator name="CanPaste" class="Maestro.Base.Commands.Conditions.PasteConditionEvaluator" />
<ConditionEvaluator name="CanCutOrCopy" class="Maestro.Base.Commands.Conditions.CutCopyConditionEvaluator" />
<ConditionEvaluator name="MultipleSelected" class="Maestro.Base.Commands.Conditions.MultipleSelectedItemConditionEvaluator" />
+ <ConditionEvaluator name="HasDocuments" class="Maestro.Base.Commands.Conditions.NonZeroDocumentConditionEvaluator" />
</Import>
</Runtime>
@@ -71,15 +72,43 @@
<MenuItem id="Menu_File"
type="Menu"
label="${res:Menu_File}">
- <MenuItem id="Connect"
- label="${res:Menu_File_Connect}"
- icon="plug__plus"
- class="Maestro.Base.Commands.LoginCommand" />
- <MenuItem id="NewItem"
- label="${res:Menu_File_NewResource}"
- icon="document__plus"
- class="Maestro.Base.Commands.NewItemCommand" />
+ <Condition action="Disable" name="IsConnected">
+ <MenuItem id="Connect"
+ label="${res:Menu_File_Connect}"
+ icon="plug__plus"
+ class="Maestro.Base.Commands.LoginCommand" />
+ </Condition>
+ <Condition action="Disable" name="NotConnected">
+ <MenuItem id="NewItem"
+ label="${res:Menu_File_NewResource}"
+ icon="document__plus"
+ class="Maestro.Base.Commands.NewItemCommand" />
+ </Condition>
<MenuItem type="Separator" />
+ <Condition action="Disable" name="EditorFunction">
+ <Condition action="Disable" name="EditorFunction" property="CanSave">
+ <MenuItem id="Save"
+ icon="disk"
+ label="${res:Menu_File_SaveResource}"
+ tooltip="${res:Menu_File_SaveResource}"
+ shortcut="Control|S"
+ class="Maestro.Base.Commands.SaveResourceCommand" />
+ </Condition>
+ <MenuItem id="SaveAs"
+ icon="disk__arrow"
+ label="${res:Menu_File_SaveResourceAs}"
+ tooltip="${res:Menu_File_SaveResourceAs}"
+ class="Maestro.Base.Commands.SaveResourceAsCommand" />
+ <Condition action="Disable" name="HasDocuments">
+ <MenuItem id="SaveAll"
+ icon="disks"
+ label="${res:Menu_File_SaveAll}"
+ tooltip="${res:Menu_File_SaveAll}"
+ shortcut="Control|Shift|S"
+ class="Maestro.Base.Commands.SaveAllCommand" />
+ </Condition>
+ </Condition>
+ <MenuItem type="Separator" />
<MenuItem id="Menu_File_Quit"
label="${res:Menu_File_Quit}"
class="Maestro.Base.Commands.QuitCommand" />
@@ -92,10 +121,12 @@
<MenuItem id="CopyItem"
icon="document_copy"
label="${res:Menu_Edit_Copy}"
+ shortcut="Control|C"
class="Maestro.Base.Commands.CopyCommand" />
<MenuItem id="CutItem"
label="${res:Menu_Edit_Cut}"
icon="scissors_blue"
+ shortcut="Control|X"
class="Maestro.Base.Commands.CutCommand" />
</Condition>
</Condition>
@@ -103,6 +134,7 @@
<MenuItem id="PasteItem"
label="${res:Menu_Edit_Paste}"
icon="clipboard_paste"
+ shortcut="Control|V"
class="Maestro.Base.Commands.PasteCommand" />
</Condition>
</MenuItem>
@@ -162,6 +194,26 @@
icon="application_task"
class="Maestro.Base.Commands.OptionsCommand"/>
</MenuItem>
+ <MenuItem id="Menu_Window"
+ type="Menu"
+ label="${res:Menu_Window}">
+ <Condition action="Disable" name="CanClose">
+ <MenuItem id="CloseDocument"
+ label="${res:Menu_File_CloseActiveDocument}"
+ tooltip="${res:Menu_File_CloseActiveDocument}"
+ shortcut="Control|F4"
+ icon="cross"
+ class="Maestro.Base.Commands.CloseActiveDocumentCommand" />
+ </Condition>
+ <MenuItem id="CloseAll"
+ label="${res:Menu_File_CloseAll}"
+ tooltip="${res:Menu_File_CloseAll}"
+ icon="cross"
+ shortcut="Control|Shift|F4"
+ class="Maestro.Base.Commands.CloseAllDocumentsCommand" />
+ </Condition>
+ </MenuItem>
<MenuItem id="Menu_Package"
type="Menu"
label="${res:Menu_Package}">
@@ -256,7 +308,14 @@
icon="disk__arrow"
+ <ToolbarItem id="SaveAll"
+ icon="disks"
+ </Condition>
</Condition>
+ <ToolbarItem type="Separator" />
<Condition action="Disable" name="EditorFunction" property="CanPreview">
<ToolbarItem id="Preview"
icon="document_search_result"
@@ -279,7 +338,7 @@
<ToolbarItem id="Validate"
icon="tick"
tooltip="${res:Menu_File_ValidateResource}"
- class="Maestro.Base.Commands.ValidateResourceCommand" />
+ class="Maestro.Base.Commands.SiteExplorer.ValidateCommand" />
</Condition>
Only needed if our custom drawn close buttons don't appear on document
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-10-28 00:53:04 UTC (rev 5343)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-10-28 09:02:19 UTC (rev 5344)
@@ -68,6 +68,7 @@
</Compile>
<Compile Include="Commands\AboutCommand.cs" />
<Compile Include="Commands\CloseActiveDocumentCommand.cs" />
+ <Compile Include="Commands\CloseAllDocumentsCommand.cs" />
<Compile Include="Commands\Conditions\ActiveEditorConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\CloseableDocumentConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\CutCopyConditionEvaluator.cs" />
@@ -78,6 +79,7 @@
<Compile Include="Commands\Conditions\PasteConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\SelectedItemConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\SelectedRootItemConditionEvaluator.cs" />
+ <Compile Include="Commands\Conditions\NonZeroDocumentConditionEvaluator.cs" />
<Compile Include="Commands\CopyCommand.cs" />
<Compile Include="Commands\CreatePackageCommand.cs" />
<Compile Include="Commands\CutCommand.cs" />
@@ -94,6 +96,7 @@
<Compile Include="Commands\PreviewResourceCommand.cs" />
<Compile Include="Commands\ProfileResourceCommand.cs" />
<Compile Include="Commands\QuitCommand.cs" />
+ <Compile Include="Commands\SaveAllCommand.cs" />
<Compile Include="Commands\SaveResourceAsCommand.cs" />
<Compile Include="Commands\SaveResourceCommand.cs" />
<Compile Include="Commands\ServerMonitorCommand.cs" />
@@ -115,7 +118,6 @@
<Compile Include="Commands\Test\OpenUnmanagedResourceCommand.cs" />
<Compile Include="Commands\Test\SelectFdoProviderCommand.cs" />
<Compile Include="Commands\Test\TestCommands.cs" />
- <Compile Include="Commands\ValidateResourceCommand.cs" />
<Compile Include="Commands\XmlEditCommand.cs" />
<Compile Include="Editor\DrawingSourceEditor.cs">
<SubType>UserControl</SubType>
@@ -317,7 +319,7 @@
<Compile Include="UI\ValidationResultsDialog.cs">
<SubType>Form</SubType>
</Compile>
- <Compile Include="UI\ValidationResultsDialog.designer.cs">
+ <Compile Include="UI\ValidationResultsDialog.Designer.cs">
<DependentUpon>ValidationResultsDialog.cs</DependentUpon>
</Compile>
<Compile Include="UI\WelcomeScreen.cs">
@@ -348,6 +350,7 @@
</ItemGroup>
<ItemGroup>
<Content Include="Maestro.Base.addin" />
+ <None Include="Resources\disks.png" />
<None Include="Resources\box--plus.png" />
<None Include="Resources\box--arrow.png" />
<None Include="Resources\folder--plus.png" />
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-10-28 00:53:04 UTC (rev 5343)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-10-28 09:02:19 UTC (rev 5344)
@@ -283,7 +283,7 @@
/// <summary>
- /// Looks up a localized string similar to This resource has unsaved changes. Close and discard these changes?.
+ /// Looks up a localized string similar to This resource {0} has unsaved changes. Close and discard these changes?.
/// </summary>
internal static string CloseUnsavedResource {
get {
@@ -437,6 +437,13 @@
+ internal static System.Drawing.Bitmap disks {
+ get {
+ object obj = ResourceManager.GetObject("disks", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
internal static System.Drawing.Bitmap document {
get {
object obj = ResourceManager.GetObject("document", resourceCulture);
@@ -747,6 +754,15 @@
/// <summary>
+ /// Looks up a localized string similar to Close All Documents.
+ /// </summary>
+ internal static string Menu_File_CloseAll {
+ get {
+ return ResourceManager.GetString("Menu_File_CloseAll", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Connect.
/// </summary>
internal static string Menu_File_Connect {
@@ -819,6 +835,15 @@
/// <summary>
+ /// Looks up a localized string similar to Save All.
+ /// </summary>
+ internal static string Menu_File_SaveAll {
+ get {
+ return ResourceManager.GetString("Menu_File_SaveAll", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Save Resource.
/// </summary>
internal static string Menu_File_SaveResource {
@@ -918,6 +943,15 @@
/// <summary>
+ /// Looks up a localized string similar to Window.
+ /// </summary>
+ internal static string Menu_Window {
+ get {
+ return ResourceManager.GetString("Menu_Window", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to MgCooker.
/// </summary>
internal static string MgCooker {
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-10-28 00:53:04 UTC (rev 5343)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-10-28 09:02:19 UTC (rev 5344)
@@ -674,7 +674,7 @@
<value>New Resource</value>
</data>
<data name="CloseUnsavedResource" xml:space="preserve">
- <value>This resource has unsaved changes. Close and discard these changes?</value>
+ <value>This resource {0} has unsaved changes. Close and discard these changes?</value>
</data>
<data name="FixErrorsBeforeSaving" xml:space="preserve">
<value>Validation detected errors in your resource, please fix them before saving this resource</value>
@@ -787,4 +787,16 @@
<data name="XmlEditor" xml:space="preserve">
<value>XML Editor:</value>
</data>
+ <data name="disks" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\disks.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="Menu_File_SaveAll" xml:space="preserve">
+ <value>Save All</value>
+ </data>
+ <data name="Menu_File_CloseAll" xml:space="preserve">
+ <value>Close All Documents</value>
+ </data>
+ <data name="Menu_Window" xml:space="preserve">
+ <value>Window</value>
+ </data>
</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Base/Resources/disks.png
(Binary files differ)
Property changes on: sandbox/maestro-3.0/Maestro.Base/Resources/disks.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs 2010-10-28 00:53:04 UTC (rev 5343)
+++ sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs 2010-10-28 09:02:19 UTC (rev 5344)
@@ -129,7 +129,8 @@
if (ed.IsDirty && !ed.DiscardChangesOnClose)
- if (!MessageService.AskQuestion(Properties.Resources.CloseUnsavedResource))
+ string name = ed.IsNew ? string.Empty : "(" + ResourceIdentifier.GetName(ed.EditorService.ResourceID) + ")";
+ if (!MessageService.AskQuestion(string.Format(Properties.Resources.CloseUnsavedResource, name)))
e.Cancel = true;
Modified: sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs 2010-10-28 00:53:04 UTC (rev 5343)
+++ sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs 2010-10-28 09:02:19 UTC (rev 5344)
@@ -467,20 +467,8 @@
private void trvResources_KeyUp(object sender, KeyEventArgs e)
- if (e.Control && e.KeyCode == Keys.C) //Copy
+ if (e.KeyCode == Keys.Delete)
- new CopyCommand().Run();
- else if (e.Control && e.KeyCode == Keys.X) //Cut
- new CutCommand().Run();
- else if (e.Control && e.KeyCode == Keys.V) //Paste
- new PasteCommand().Run();
- else if (e.KeyCode == Keys.Delete)
new DeleteSelectedItemsCommand().Run();
Modified: sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.cs 2010-10-28 00:53:04 UTC (rev 5343)
+++ sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.cs 2010-10-28 09:02:19 UTC (rev 5344)
@@ -1,4 +1,4 @@
// Copyright (C) 2009, Kenneth Skovhede
// http://www.hexad.dk, opensource at hexad.dk
Modified: sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.designer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.designer.cs 2010-10-28 00:53:04 UTC (rev 5343)
+++ sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.designer.cs 2010-10-28 09:02:19 UTC (rev 5344)
@@ -1,4 +1,4 @@
partial class ValidationResultsDialog
@@ -91,20 +91,23 @@
this.imageList1.Images.SetKeyName(1, "Warning.ico");
this.imageList1.Images.SetKeyName(2, "Error.ico");
- // saveFileDialog1
+ // saveFileDialog
this.saveFileDialog.DefaultExt = "txt";
- resources.ApplyResources(this.saveFileDialog, "saveFileDialog1");
+ resources.ApplyResources(this.saveFileDialog, "saveFileDialog");
- // ValidationResults
+ // ValidationResultsDialog
- resources.ApplyResources(this, "$this");
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
this.CancelButton = this.CancelBtn;
+ resources.ApplyResources(this, "$this");
this.Controls.Add(this.listView1);
this.Controls.Add(this.panel1);
- this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.SizableToolWindow;
- this.Name = "ValidationResults";
+ this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedSingle;
+ this.MaximizeBox = false;
+ this.MinimizeBox = false;
+ this.Name = "ValidationResultsDialog";
+ this.ShowIcon = false;
this.panel1.ResumeLayout(false);
this.ResumeLayout(false);
Modified: sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.resx
--- sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.resx 2010-10-28 00:53:04 UTC (rev 5343)
+++ sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.resx 2010-10-28 09:02:19 UTC (rev 5344)
@@ -119,11 +119,11 @@
</resheader>
<assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="SaveReportBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- <value>Bottom, Right</value>
+ <value>Bottom, Left</value>
</data>
<assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="SaveReportBtn.Location" type="System.Drawing.Point, System.Drawing">
- <value>488, 8</value>
+ <value>12, 8</value>
</data>
<data name="SaveReportBtn.Size" type="System.Drawing.Size, System.Drawing">
<value>91, 23</value>
@@ -148,10 +148,10 @@
<value>0</value>
</data>
<data name="CancelBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- <value>Bottom</value>
+ <value>Bottom, Right</value>
</data>
<data name="CancelBtn.Location" type="System.Drawing.Point, System.Drawing">
- <value>256, 8</value>
+ <value>508, 8</value>
</data>
<data name="CancelBtn.Size" type="System.Drawing.Size, System.Drawing">
<value>75, 23</value>
@@ -220,77 +220,77 @@
<value>595, 232</value>
</data>
<metadata name="imageList1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 17</value>
+ <value>146, 17</value>
</metadata>
<data name="imageList1.ImageStream" mimetype="application/x-microsoft.net.object.binary.base64">
<value>
AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
- ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADy
- DgAAAk1TRnQBSQFMAgEBAwEAAQwBAAEMAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
- AwABEAMAAQEBAAEgBgABEC4AAwwBEAMVAR0kAAEQAg8BFQMRARcDEQEXAxEBFwMRARcDEQEXAxEBFwMR
- ARcDEQEXAxEBFwMRARcDFQEdHAADCQEMAxYBHwMWAR8DFgEfAxYBHwMWAR9kAAMSARgBgAEsARoB9wHE
- AUcBLgH/Ac0BSwExAf8BzgFLATEB/wHKAUoBMAH/AaQBOwEmAf8BSQI0AYYUAAFNATMBNgHNAQIBuwHr
- Af8BAgG9AewB/wECAcEB7gH/AQIBxAHwAf8BAgHFAfAB/wECAcUB8AH/AQIBxQHwAf8BAgHFAfAB/wEC
- AcUB8AH/AQIBwwHvAf8BAgG/Ae0B/wECAbsB6wH/AQYBlwG+Af8UAAFSATABMwGrASoBPAG2Af8BLAE/
- AcAB/wEtAUEBxgH/AS0BQQHHAf8BLAFAAcMB/wErAT4BuwH/ASMBKgGBAf9cAAFKAjQBigHGAUgBLwH/
- AdcBTgEzAf8B4wFSATYB/wHpAVQBNwH/AeoBVAE3Af8B5gFTATYB/wHdAVABNAH/Ac8BSwExAf8BhQEr
- ASIB/BAAAQgBggGjAf8BAgG8AewB/wECAcUB8AH/AQIBywHzAf8BAgHOAfUB/wECAdAB9gH/AQIB0AH2
- Af8BAgHQAfYB/wECAdAB9gH/AQIBzwH2Af8BAgHNAfQB/wECAcgB8gH/AQIBwAHuAf8BAgG7AesB/wMS
- ARgMAAFSATABMwGrASwBQAHBAf8BLwFEAdAB/wExAUcB2QH/ATIBSQHeAf8BMgFJAd8B/wEyAUgB3AH/
- ATABRgHVAf8BLQFCAcgB/wEkASwBhAH/VAABOwIyAWMBygFJATAB/wHfAVEBNQH/Ae8BVgE5Af8B+wHx
- Ae8B/wH9AvkB/wHhAWcBUAH/AfwBWwE8Af8B9QFYAToB/wHnAVMBNwH/AdMBTQEyAf8BhQErASIB/AwA
- AT4CMwFrAQIBvwHtAf8BAgHJAfIB/wECAdAB9gH/AQIB1AH5Af8BAgHUAfcB/wGFAdwB6wH/AYEB2wHq
- Af8BAgHQAfMB/wECAdYB+gH/AQIB0gH4Af8BAgHNAfQB/wECAcMB7wH/AQkBgAGdAf8MAAFSATABMwGr
- ASwBQAHDAf8BMQFGAdYB/wE0AUsB5AH/ATUBTQHsAf8BNgFOAe8B/wE2AU8B8AH/ATYBTgHuAf8BNAFM
- AeYB/wEyAUkB3QH/AS4BQwHMAf8BJAEsAYQB/1AAAbcBQgErAf8B3QFQATQB/wHyAVcBOQH/Af4BXgFA
- Cf8B4wGJAXkB/wHoAZsBjQL/AWIBRAH/AfkBWgE7Af8B5wFTATcB/wHPAUsBMQH/AUkCNAGGDAABEgGO
- Aa4B/wE9AdYB9QH/AUMB3QH5Af8BOQHgAfsB/wEeAc0B6Qn/ASwBygHjAf8BAgHZAfsB/wECAdQB+QH/
- AQIBzQH1Af8BAgHDAe8B/wEvAisBSQgAAVABMQEzAZ8BKwE/Ab0B/wEwAUYB1QH/ATQBTAHmAf8BqgGz
- AesB/wGcAaYB6QH/ATkBUgH6Af8BOQFSAfsB/wFZAWsB4AH/AeUB6AH4Af8BNQFMAegB/wEyAUkB3QH/
- AS0BQgHIAf8BIwEqAYEB/0gAAUcCNAGBAdEBTAEyAf8B6wFUATgB/wH+AVwBPgL/AWgBSwH/AewBsQGl
- Bf8B8wHMAcQB/wHhAXIBWwH/AfwBagFOAv8BYgFEAf8B9QFYAToB/wHdAVABNAH/AaQBOwEmAf8MAAE9
- AjMBaAFLAdYB9QH/AVIB3gH5Af8BWAHkAfsB/wFfAegB/QH/AXQB2QHpAf8BgQHeAesB/wELAdsB+wH/
- AQIB2AH7Af8BAgHTAfgB/wECAcoB8wH/AQkBgQGeAf8MAAEkASwBgwH/AS4BQgHKAf8BMwFKAeAB/wGI
- AZQB4gn/AZwBpwHsAf8BWgFtAeQJ/wHeAeEB9wH/ATQBTAHoAf8BMAFGAdUB/wErAT4BuwH/AxYBH0QA
- AYMBJwEfAfsB2gFPATQB/wH0AVcBOQL/AWYBSgL/AXUBWgH/AewBcAFXCf8B+AF2AVsC/wF3AVwC/wFv
- AVQB/wH8AVsBPAH/AeYBUwE2Af8BygFKATAB/xAAATABlgGwAf8BYAHeAfgB/wFnAeUB+wH/AW4B6QH9
- Cf8BgQHoAfkB/wFYAeQB+wH/AQIBzwH2Af8BAgHFAfAB/wEuAioBRwwAASUBLgGJAf8BOAFNAdQB/wFG
- AVwB6QH/AVIBZwH1Af8B1wHbAfcR/wH3AfgB/QH/ATYBTwHwAf8BNgFOAe4B/wEyAUgB3AH/ASwBQAHD
- Af8DFgEfRAABngE4ASUB/wHfAVEBNQH/AfcBZwFLAv8BeQFgAf8B+AGAAWcB/wHsAXwBZQH/AfwB8wHx
- Bf8B5gGLAXsC/wGBAWoC/wF9AWUB/wH+AXIBWAH/AeoBVAE3Af8BzgFLATEB/wMVAR0MAAE8AjMBZgFv
- Ad4B9wH/AXYB5QH6Af8BfQHqAfwJ/wGPAeoB+QH/AZYB7QH8Af8BXQHdAfcB/wEJAYEBngH/EAABMQE5
- AY8B/wFMAV4B2wH/AVUBaQHtAf8BXgFzAfgB/wFmAXkB/AH/Ad8B4gH5Cf8B/AH9Af4B/wGFAZQB+QH/
- AXMBgwH8Af8BNgFPAfAB/wEyAUkB3wH/AS0BQQHHAf8DFgEfRAABlwE2ASMB/wHeAVEBNQH/AfgBgAFn
- Av8BhQFxAf8B/gGNAXkB/wH1AdgB0gH/AecBmwGNBf8B+QHnAeQC/wGOAXoC/wGJAXUB/wH+AYEBagH/
- Ae0BdgFfAf8BzQFLATEB/wMMARAQAAFAAZoBsQH/AYMB5gH5Af8BigHrAfwJ/wGeAewB+QH/AaQB7gH7
- Af8BqgHsAfoB/wEtAioBRhAAATYBPQGQAf8BVgFoAdwB/wFgAXMB7QH/AWkBfAH4Af8BhgGTAeoR/wHJ
- Ac8B9AH/AZkBpgH8Af8BoAGrAfcB/wFYAWsB5AH/AS0BQQHGAf8DFgEfRAABZQEnASMB1QHcAWgBUQH/
- AfUBjQF8Av8BkwGBAv8BmwGIAf8B/gGeAYoB/wHtAbEBpgH/AfwB9gH0Af8B7wG8AbIC/wGdAYoC/wGX
- AYQB/wH7AY8BfQH/AewBigF5Af8BxAFHAS4B/xQAATsCMgFlAZIB5gH5Af8BmQHsAfsJ/wGsAe4B+QH/
- AbIB7wH7Af8BRAGOAaIB/xQAATsBQQGPAf8BYAFwAdoB/wFrAXwB6wH/AYkBlQHmCf8B+gH7Af4B/wHk
- AecB+gn/AdMB1wH1Af8BrAG1AfcB/wGxAbkB8QH/AWMBcQHPAf8DFgEfRAABHwIeAS0B1AFrAVYB/wHx
- AZ4BjgH/AfwBogGRAv8BpwGXAv8BqwGbAv8BrQGdAf8B7wG2AasB/wH+Af0B/AH/AfEBpQGXAf8B/gGk
- AZMB/wH2AZ8BjwH/AekBmwGMAf8BgAEsARoB9xgAAVABnQGyAf8BpwHtAfsJ/wG5Ae8B+QH/Ab4B8AH7
- Af8BLQIpAUUUAAEyATUBegH/AWsBeQHWAf8BdgGDAecB/wF+AYoB6QH/A/4B/wL7Af4B/wGVAaIB+QH/
- AZ0BqQH9Af8B6QHrAfoF/wG2Ab0B8AH/AbcBvwH1Af8BvAHDAfAB/wHBAcYB6gH/AwkBDEgAAYQBLQEZ
- AfkB7AGuAaIB/wH1AbEBpAH/AfwBtAGmAv8BtgGpAv8BuAGrAf8B9wHdAdkF/wH1AdUBzwH/AfkBsgGl
- Af8B8AGwAaMB/wHeAZgBigH/AxIBGBgAATsCMgFkAbQB7QH6Cf8BxQHwAfoB/wFJAY8BogH/GAADCAEL
- AVkBYQGqAf8BgQGLAeEB/wGIAZYB7QH/AZABnAHtAf8BmQGkAfQB/wGhAa0B+wH/AagBswH7Af8BrwG5
- AfoB/wG5AcAB8QH/AbwBwwH3Af8BwQHIAfMB/wHHAcwB7gH/AVMBMAEzAatPAAEBAb4BeQFrAf8B8AHB
- AbcB/wH2AcIBuQH/AfoBxAG6Af8B/AHEAboB/wH7AcQBugH/AfIBxgG9Af8B9gHCAbkB/wHzAcIBuAH/
- AewBvgG1Af8BSgI0AYogAAFdAZ8BsgH/AcYB8QH7Af8BywHyAfwB/wHQAfMB/AH/ASwCKQFEHAADCAEL
- AWgBbwGwAf8BkwGeAeYB/wGcAacB7gH/AaUBrwHzAf8BrAG2AfYB/wGzAbwB9wH/AboBwgH3Af8BwAHH
- AfUB/wHGAcwB8wH/AcsB0AHwAf8BUwEwATMBq1cAAQEBjAE+ATYB+QHyAdAByQH/AfQB0QHKAf8B9gHS
- AcoB/wH2AdIBygH/AfUB0QHKAf8B8wHQAcoB/wHUAZ4BkwH/ATsCMgFjJAABOwIyAWQB0QHyAfsB/wHV
- AfQB/AH/AU8BkAGjAf8kAAMIAQsBdgF7AbMB/wGnAa8B5wH/Aa8BtwHtAf8BtgG+AfAB/wG9AcQB8gH/
- AcQBygHyAf8BygHPAfEB/wHPAdMB8AH/AVMBMAEzAatgAAEfAh4BLQFmAScBJAHVAakBbQFiAf8BtAF9
- AXIB/wGMAUYBNQH7AUcCNAGBMAABSQE3AUAB3AFRAZEBpAH/ARYCFQEeKAADCAELAUoBSwGBAf8BbQFv
- AZ8B/wFwAXMBogH/AXQBdgGkAf8BdwF4AaQB/wF1AXYBoAH/AVABMgEzAZ//AFEAAUIBTQE+BwABPgMA
- ASgDAAFAAwABEAMAAQEBAAEBBQABgBcAA/8BAAH+AX8BwAEDAfgBHwIAAfABDwGAAQEB8AEPAgAB4AEH
- AYABAAHgAQcCAAHAAQMBgAEBAcABAwIAAcABAQHAAQEBgAEBAgABgAEBAcABAwGAAwABgAEBAeABAwGA
- AwABgAEAAeABBwGAAwABgAEAAfABBwGAAwABgAEBAfABDwGAAwABgAEBAfgBDwGAAwABwAEBAfgBHwGA
- AQECAAHAAQMB/AEfAcABAwIAAeABBwH8AT8B4AEHAgAB+AEfAf4BPwHwAQ8CAAb/AgAL
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADi
+ DgAAAk1TRnQBSQFMAgEBAwEAARQBAAEUAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+ AwABEAMAAQEBAAEgBgABEC4AAwwBEAMVAR0kAAMQARUDEQEXAxEBFwMRARcDEQEXAxEBFwMRARcDEQEX
+ AxEBFwMRARcDEQEXAxUBHRwAAwkBDAMWAR8DFgEfAxYBHwMWAR8DFgEfZAADEgEYAX8BMAEdAfcBxAFG
+ AS0B/wHNAUoBMAH/Ac4BSgEwAf8BygFJAS8B/wGkAToBJQH/AUgCQgGGFAABUgFAAUMBzQEBAbsB6wH/
+ AQEBvQHsAf8BAQHBAe4B/wEBAcQB8AH/AQEBxQHwAf8BAQHFAfAB/wEBAcUB8AH/AQEBxQHwAf8BAQHF
+ AfAB/wEBAcMB7wH/AQEBvwHtAf8BAQG7AesB/wEFAZcBvgH/FAABUwFEAUUBqwEpATsBtgH/ASsBPgHA
+ Af8BLAFAAcYB/wEsAUABxwH/ASsBPwHDAf8BKgE9AbsB/wEiASkBgQH/XAABSgJDAYoBxgFHAS4B/wHX
+ AU0BMgH/AeMBUQE1Af8B6QFTATYB/wHqAVMBNgH/AeYBUgE1Af8B3QFPATMB/wHPAUoBMAH/AYIBKwEj
+ AfwQAAEHAYIBowH/AQEBvAHsAf8BAQHFAfAB/wEBAcsB8wH/AQEBzgH1Af8BAQHQAfYB/wEBAdAB9gH/
+ AQEB0AH2Af8BAQHQAfYB/wEBAc8B9gH/AQEBzQH0Af8BAQHIAfIB/wEBAcAB7gH/AQEBuwHrAf8DEgEY
+ DAABUwFEAUUBqwErAT8BwQH/AS4BQwHQAf8BMAFGAdkB/wExAUgB3gH/ATEBSAHfAf8BMQFHAdwB/wEv
+ AUUB1QH/ASwBQQHIAf8BIwErAYQB/1QAATsCOQFjAcoBSAEvAf8B3wFQATQB/wHvAVUBOAH/AfsB8QHv
+ Af8B/QL5Af8B4QFmAU8B/wH8AVoBOwH/AfUBVwE5Af8B5wFSATYB/wHTAUwBMQH/AYIBKwEjAfwMAAE+
+ AjwBawEBAb8B7QH/AQEByQHyAf8BAQHQAfYB/wEBAdQB+QH/AQEB1AH3Af8BhQHcAesB/wGBAdsB6gH/
+ AQEB0AHzAf8BAQHWAfoB/wEBAdIB+AH/AQEBzQH0Af8BAQHDAe8B/wEIAYABnQH/DAABUwFEAUUBqwEr
+ AT8BwwH/ATABRQHWAf8BMwFKAeQB/wE0AUwB7AH/ATUBTQHvAf8BNQFOAfAB/wE1AU0B7gH/ATMBSwHm
+ Af8BMQFIAd0B/wEtAUIBzAH/ASMBKwGEAf9QAAG3AUEBKgH/Ad0BTwEzAf8B8gFWATgB/wH+AV0BPwn/
+ AeMBiQF4Af8B6AGbAY0C/wFhAUMB/wH5AVkBOgH/AecBUgE2Af8BzwFKATAB/wFIAkIBhgwAAREBjgGu
+ Af8BPAHWAfUB/wFCAd0B+QH/ATgB4AH7Af8BHQHNAekJ/wErAcoB4wH/AQEB2QH7Af8BAQHUAfkB/wEB
+ Ac0B9QH/AQEBwwHvAf8BLwIuAUkIAAFQAkQBnwEqAT4BvQH/AS8BRQHVAf8BMwFLAeYB/wGqAbMB6wH/
+ AZwBpgHpAf8BOAFRAfoB/wE4AVEB+wH/AVgBagHgAf8B5QHoAfgB/wE0AUsB6AH/ATEBSAHdAf8BLAFB
+ AcgB/wEiASkBgQH/SAABRwJCAYEB0QFLATEB/wHrAVMBNwH/Af4BWwE9Av8BZwFKAf8B7AGxAaUF/wHz
+ AcwBxAH/AeEBcQFaAf8B/AFpAU0C/wFhAUMB/wH1AVcBOQH/Ad0BTwEzAf8BpAE6ASUB/wwAAT0COwFo
+ AUoB1gH1Af8BUQHeAfkB/wFXAeQB+wH/AV4B6AH9Af8BcwHZAekB/wGBAd4B6wH/AQoB2wH7Af8BAQHY
+ AfsB/wEBAdMB+AH/AQEBygHzAf8BCAGBAZ4B/wwAASMBKwGDAf8BLQFBAcoB/wEyAUkB4AH/AYgBlAHi
+ Cf8BnAGnAewB/wFZAWwB5An/Ad4B4QH3Af8BMwFLAegB/wEvAUUB1QH/ASoBPQG7Af8DFgEfRAABggEn
+ ASEB+wHaAU4BMwH/AfQBVgE4Av8BZQFJAv8BdAFZAf8B7AFvAVYJ/wH4AXUBWgL/AXYBWwL/AW4BUwH/
+ AfwBWgE7Af8B5gFSATUB/wHKAUkBLwH/EAABLwGWAbAB/wFfAd4B+AH/AWYB5QH7Af8BbQHpAf0J/wGB
+ AegB+QH/AVcB5AH7Af8BAQHPAfYB/wEBAcUB8AH/AS4CLQFHDAABJAEtAYkB/wE3AUwB1AH/AUUBWwHp
+ Af8BUQFmAfUB/wHXAdsB9xH/AfcB+AH9Af8BNQFOAfAB/wE1AU0B7gH/ATEBRwHcAf8BKwE/AcMB/wMW
+ AR9EAAGeATcBJAH/Ad8BUAE0Af8B9wFmAUoC/wF4AV8B/wH4AYABZgH/AewBewFkAf8B/AHzAfEF/wHm
+ AYsBegL/AYEBaQL/AXwBZAH/Af4BcQFXAf8B6gFTATYB/wHOAUoBMAH/AxUBHQwAATwCOgFmAW4B3gH3
+ Af8BdQHlAfoB/wF8AeoB/An/AY8B6gH5Af8BlgHtAfwB/wFcAd0B9wH/AQgBgQGeAf8QAAEwATgBjwH/
+ AUsBXQHbAf8BVAFoAe0B/wFdAXIB+AH/AWUBeAH8Af8B3wHiAfkJ/wH8Af0B/gH/AYUBlAH5Af8BcgGD
+ AfwB/wE1AU4B8AH/ATEBSAHfAf8BLAFAAccB/wMWAR9EAAGXATUBIgH/Ad4BUAE0Af8B+AGAAWYC/wGF
+ AXAB/wH+AY0BeAH/AfUB2AHSAf8B5wGbAY0F/wH5AecB5AL/AY4BeQL/AYkBdAH/Af4BgQFpAf8B7QF1
+ AV4B/wHNAUoBMAH/AwwBEBAAAT8BmgGxAf8BgwHmAfkB/wGKAesB/An/AZ4B7AH5Af8BpAHuAfsB/wGq
+ AewB+gH/Ay0BRhAAATUBPAGQAf8BVQFnAdwB/wFfAXIB7QH/AWgBewH4Af8BhgGTAeoR/wHJAc8B9AH/
+ AZkBpgH8Af8BoAGrAfcB/wFXAWoB5AH/ASwBQAHGAf8DFgEfRAABYwE4ATQB1QHcAWcBUAH/AfUBjQF7
+ Av8BkwGBAv8BmwGIAf8B/gGeAYoB/wHtAbEBpgH/AfwB9gH0Af8B7wG8AbIC/wGdAYoC/wGXAYQB/wH7
+ AY8BfAH/AewBigF4Af8BxAFGAS0B/xQAATsCOgFlAZIB5gH5Af8BmQHsAfsJ/wGsAe4B+QH/AbIB7wH7
+ Af8BQwGOAaIB/xQAAToBQAGPAf8BXwFvAdoB/wFqAXsB6wH/AYkBlQHmCf8B+gH7Af4B/wHkAecB+gn/
+ AdMB1wH1Af8BrAG1AfcB/wGxAbkB8QH/AWIBcAHPAf8DFgEfRAADHwEtAdQBagFVAf8B8QGeAY4B/wH8
+ AaIBkQL/AacBlwL/AasBmwL/Aa0BnQH/Ae8BtgGrAf8B/gH9AfwB/wHxAaUBlwH/Af4BpAGTAf8B9gGf
+ AY8B/wHpAZsBjAH/AX8BMAEdAfcYAAFPAZ0BsgH/AacB7QH7Cf8BuQHvAfkB/wG+AfAB+wH/AS0CLAFF
+ FAABMQE0AXkB/wFqAXgB1gH/AXUBgwHnAf8BfQGKAekB/wP+Af8C+wH+Af8BlQGiAfkB/wGdAakB/QH/
+ AekB6wH6Bf8BtgG9AfAB/wG3Ab8B9QH/AbwBwwHwAf8BwQHGAeoB/wMJAQxIAAGDAS8BGwH5AewBrgGi
+ Af8B9QGxAaQB/wH8AbQBpgL/AbYBqQL/AbgBqwH/AfcB3QHZBf8B9QHVAc8B/wH5AbIBpQH/AfABsAGj
+ Af8B3gGYAYoB/wMSARgYAAE7AjoBZAG0Ae0B+gn/AcUB8AH6Af8BSAGPAaIB/xgAAwgBCwFYAWABqgH/
+ AYEBiwHhAf8BiAGWAe0B/wGQAZwB7QH/AZkBpAH0Af8BoQGtAfsB/wGoAbMB+wH/Aa8BuQH6Af8BuQHA
+ AfEB/wG8AcMB9wH/AcEByAHzAf8BxwHMAe4B/wFUAUQBRQGrTwABAQG+AXgBagH/AfABwQG3Af8B9gHC
+ AbkB/wH6AcQBugH/AfwBxAG6Af8B+wHEAboB/wHyAcYBvQH/AfYBwgG5Af8B8wHCAbgB/wHsAb4BtQH/
+ AUoCQwGKIAABXAGfAbIB/wHGAfEB+wH/AcsB8gH8Af8B0AHzAfwB/wMsAUQcAAMIAQsBZwFuAbAB/wGT
+ AZ4B5gH/AZwBpwHuAf8BpQGvAfMB/wGsAbYB9gH/AbMBvAH3Af8BugHCAfcB/wHAAccB9QH/AcYBzAHz
+ Af8BywHQAfAB/wFUAUQBRQGrVwABAQGLAUABOAH5AfIB0AHJAf8B9AHRAcoB/wH2AdIBygH/AfYB0gHK
+ Af8B9QHRAcoB/wHzAdABygH/AdQBngGTAf8BOwI5AWMkAAE7AjoBZAHRAfIB+wH/AdUB9AH8Af8BTgGQ
+ AaMB/yQAAwgBCwF1AXoBswH/AacBrwHnAf8BrwG3Ae0B/wG2Ab4B8AH/Ab0BxAHyAf8BxAHKAfIB/wHK
+ Ac8B8QH/Ac8B0wHwAf8BVAFEAUUBq2AAAx8BLQFjATgBNQHVAakBbAFhAf8BtAF8AXEB/wGLAUYBNAH7
+ AUcCQgGBMAABTwFBAUcB3AFQAZEBpAH/AxYBHigAAwgBCwFJAUoBgQH/AWwBbgGfAf8BbwFyAaIB/wFz
+ AXUBpAH/AXYBdwGkAf8BdAF1AaAB/wFQAkQBn/8AUQABQgFNAT4HAAE+AwABKAMAAUADAAEQAwABAQEA
+ AQEFAAGAFwAD/wEAAf4BfwHAAQMB+AEfAgAB8AEPAYABAQHwAQ8CAAHgAQcBgAEAAeABBwIAAcABAwGA
+ AQEBwAEDAgABwAEBAcABAQGAAQECAAGAAQEBwAEDAYADAAGAAQEB4AEDAYADAAGAAQAB4AEHAYADAAGA
+ AQAB8AEHAYADAAGAAQEB8AEPAYADAAGAAQEB+AEPAYADAAHAAQEB+AEfAYABAQIAAcABAwH8AR8BwAED
+ AgAB4AEHAfwBPwHgAQcCAAH4AR8B/gE/AfABDwIABv8CAAs=
</value>
</data>
<data name="listView1.TabIndex" type="System.Int32, mscorlib">
@@ -308,21 +308,18 @@
<data name=">>listView1.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <metadata name="saveFileDialog1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>122, 17</value>
+ <metadata name="saveFileDialog.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
</metadata>
- <data name="saveFileDialog1.Filter" xml:space="preserve">
+ <data name="saveFileDialog.Filter" xml:space="preserve">
<value>Text files (*.txt)|*.txt|All files (*.*)|*.*</value>
</data>
- <data name="saveFileDialog1.Title" xml:space="preserve">
+ <data name="saveFileDialog.Title" xml:space="preserve">
<value>Select the filename to write the report to</value>
</data>
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
- <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
- <value>6, 13</value>
- </data>
<data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
<value>595, 274</value>
</data>
@@ -350,14 +347,14 @@
<data name=">>imageList1.Type" xml:space="preserve">
<value>System.Windows.Forms.ImageList, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
- <data name=">>saveFileDialog1.Name" xml:space="preserve">
- <value>saveFileDialog1</value>
+ <data name=">>saveFileDialog.Name" xml:space="preserve">
+ <value>saveFileDialog</value>
</data>
- <data name=">>saveFileDialog1.Type" xml:space="preserve">
+ <data name=">>saveFileDialog.Type" xml:space="preserve">
<value>System.Windows.Forms.SaveFileDialog, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>$this.Name" xml:space="preserve">
- <value>ValidationResults</value>
+ <value>ValidationResultsDialog</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
<value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
Property changes on: sandbox/maestro-3.0/SDK
Modified: svn:ignore
- SDK.suo
bin
+ SDK.suo
bin
*.cache
Modified: sandbox/maestro-3.0/build.bat
--- sandbox/maestro-3.0/build.bat 2010-10-28 00:53:04 UTC (rev 5343)
+++ sandbox/maestro-3.0/build.bat 2010-10-28 09:02:19 UTC (rev 5344)
@@ -3,9 +3,9 @@
SET TYPEBUILD=Release
SET PLATFORM=Any CPU
SET RELEASE_VERSION=Trunk
+SET OLDPATH=%PATH%
+SET PATH=%PATH%;%CD%\Thirdparty\NSIS;C:\Windows\Microsoft.NET\Framework\v3.5
-SET PATH=%PATH%;%CD%\Thirdparty\NSIS
:study_params
if (%1)==() goto start_build
@@ -71,6 +71,9 @@
if "%TYPEACTION%"=="clean" goto clean
:build
+pushd SDK
+%MSBUILD% SDK.sln
+popd
pushd Maestro
%MSBUILD% Maestro.sln
popd
@@ -80,6 +83,9 @@
goto quit
:clean
+pushd SDK
+%MSBUILD% /t:clean SDK.sln
+popd
pushd Maestro
%MSBUILD% /t:clean Maestro.sln
popd
@@ -104,4 +110,5 @@
echo Action: -a[ction]=build(default),
echo clean
echo ************************************************************************
-:quit
+:quit
+SET PATH=%OLDPATH%
More information about the mapguide-commits
