[mapguide-commits] r5349 - branches/2.2/MgDev/Web/src/mapviewerphp
svn_mapguide at osgeo.org
Thu Oct 28 07:13:32 EDT 2010
Author: jng
Date: 2010-10-28 04:13:32 -0700 (Thu, 28 Oct 2010)
New Revision: 5349
branches/2.2/MgDev/Web/src/mapviewerphp/taskframe.php
Let's try this again. Fix #1501, this time without using the unreliable parse_url() function!
Modified: branches/2.2/MgDev/Web/src/mapviewerphp/taskframe.php
--- branches/2.2/MgDev/Web/src/mapviewerphp/taskframe.php 2010-10-28 10:09:19 UTC (rev 5348)
+++ branches/2.2/MgDev/Web/src/mapviewerphp/taskframe.php 2010-10-28 11:13:32 UTC (rev 5349)
@@ -53,16 +53,27 @@
//If there is an initial url, it will be encoded, so parse the decoded url.
- $comp = parse_url(urldecode($taskPaneUrl));
- $baseUrl = urldecode($taskPaneUrl);
- if(strncasecmp($taskPaneUrl, "http://", 7) != 0) //Is relative
- $baseUrl = $vpath . $comp["path"];
+ $tpDecodedUrl = urldecode($taskPaneUrl);
+ $baseUrl = $tpDecodedUrl;
+ $query = "";
+ //Is relative?
+ if (strncasecmp($tpDecodedUrl, "http://", 7) != 0)
+ $baseUrl = $vpath . $tpDecodedUrl;
+ //Strip query string component off of base url (if there is any) and assign to query component
+ $tokens = explode("?", $baseUrl);
+ if (count($tokens) == 2)
+ $query = $tokens[1];
+ $baseUrl = $tokens[0];
//If there is a query component to the initial url, append it to the end of the full url string
- if(!isset($comp["query"]) || strlen($comp["query"]) == 0)
+ if (strlen($query) == 0)
$url = sprintf("%s?SESSION=%s&WEBLAYOUT=%s&DWF=%s&LOCALE=%s", $baseUrl, $sessionId, urlencode($webLayoutId), $dwf, $locale);
else
- $url = sprintf("%s?SESSION=%s&WEBLAYOUT=%s&DWF=%s&LOCALE=%s&%s", $baseUrl, $sessionId, urlencode($webLayoutId), $dwf, $locale, $comp["query"]);
+ $url = sprintf("%s?SESSION=%s&WEBLAYOUT=%s&DWF=%s&LOCALE=%s&%s", $baseUrl, $sessionId, urlencode($webLayoutId), $dwf, $locale, $query);
$templ = file_get_contents("../viewerfiles/taskframe.templ");
print sprintf($templ, $vpath ."tasklist.php", $locale, $url);
More information about the mapguide-commits
