[mapguide-commits] r5118 - in trunk/MgDev: . Server/src/Core
svn_mapguide at osgeo.org
Mon Sep 6 22:22:40 EDT 2010
Author: waltweltonlair
Date: 2010-09-07 02:22:40 +0000 (Tue, 07 Sep 2010)
New Revision: 5118
trunk/MgDev/Server/src/Core/Makefile.am
trunk/MgDev/configure
trunk/MgDev/configure.in
Update FDO version reference to 3.6.0
Modified: trunk/MgDev/Server/src/Core/Makefile.am
--- trunk/MgDev/Server/src/Core/Makefile.am 2010-09-07 01:26:17 UTC (rev 5117)
+++ trunk/MgDev/Server/src/Core/Makefile.am 2010-09-07 02:22:40 UTC (rev 5118)
@@ -96,7 +96,7 @@
-ldwftk \
-ldwfemap \
-lexpat \
- -lFDO-3.5.0 \
+ -lFDO-3.6.0 \
-lExpressionEngine \
-lxalanMsg \
-lxalan-c \
Modified: trunk/MgDev/configure
--- trunk/MgDev/configure 2010-09-07 01:26:17 UTC (rev 5117)
+++ trunk/MgDev/configure 2010-09-07 02:22:40 UTC (rev 5118)
@@ -20088,10 +20088,10 @@
fi;
if test $custom_inc = "DEFAULT"; then
- map_fdo_include="/usr/local/fdo-3.5.0/include"
+ map_fdo_include="/usr/local/fdo-3.6.0/include"
if test -d $map_fdo_include; then
- { echo "$as_me:$LINENO: Building with default location of FDO include files at /usr/local/fdo-3.5.0/include" >&5
-echo "$as_me: Building with default location of FDO include files at /usr/local/fdo-3.5.0/include" >&6;}
+ { echo "$as_me:$LINENO: Building with default location of FDO include files at /usr/local/fdo-3.6.0/include" >&5
+echo "$as_me: Building with default location of FDO include files at /usr/local/fdo-3.6.0/include" >&6;}
else
{ { echo "$as_me:$LINENO: error: the default FDO include path $map_fdo_include is not a valid directory. Please use the custom option" >&5
echo "$as_me: error: the default FDO include path $map_fdo_include is not a valid directory. Please use the custom option" >&2;}
@@ -20119,10 +20119,10 @@
fi;
if test $custom_lib = "DEFAULT"; then
- map_fdo_lib="/usr/local/fdo-3.5.0/lib"
+ map_fdo_lib="/usr/local/fdo-3.6.0/lib"
if test -d $map_fdo_lib; then
- { echo "$as_me:$LINENO: Building with default location of FDO libraries at /usr/local/fdo-3.5.0/lib" >&5
-echo "$as_me: Building with default location of FDO libraries at /usr/local/fdo-3.5.0/lib" >&6;}
+ { echo "$as_me:$LINENO: Building with default location of FDO libraries at /usr/local/fdo-3.6.0/lib" >&5
+echo "$as_me: Building with default location of FDO libraries at /usr/local/fdo-3.6.0/lib" >&6;}
else
{ { echo "$as_me:$LINENO: error: the default FDO lib path $map_fdo_lib is not a valid directory. Please use the custom option" >&5
echo "$as_me: error: the default FDO lib path $map_fdo_lib is not a valid directory. Please use the custom option" >&2;}
Modified: trunk/MgDev/configure.in
--- trunk/MgDev/configure.in 2010-09-07 01:26:17 UTC (rev 5117)
+++ trunk/MgDev/configure.in 2010-09-07 02:22:40 UTC (rev 5118)
@@ -54,7 +54,7 @@
fi
dnl *******************************************************
-dnl FDO 3.5.0 Configuration
+dnl FDO 3.6.0 Configuration
dnl Include / lib paths
# custom Fdo path specification
@@ -65,9 +65,9 @@
[custom_inc=DEFAULT])
- AC_MSG_NOTICE([Building with default location of FDO include files at /usr/local/fdo-3.5.0/include])
+ AC_MSG_NOTICE([Building with default location of FDO include files at /usr/local/fdo-3.6.0/include])
else
AC_MSG_ERROR([the default FDO include path $map_fdo_include is not a valid directory. Please use the custom option])
fi
@@ -87,9 +87,9 @@
[custom_lib=DEFAULT])
- AC_MSG_NOTICE([Building with default location of FDO libraries at /usr/local/fdo-3.5.0/lib])
+ AC_MSG_NOTICE([Building with default location of FDO libraries at /usr/local/fdo-3.6.0/lib])
else
AC_MSG_ERROR([the default FDO lib path $map_fdo_lib is not a valid directory. Please use the custom option])
fi
More information about the mapguide-commits
