[mapguide-commits] r5149 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Fri Sep 17 18:37:36 EDT 2010
Author: waltweltonlair
Date: 2010-09-17 22:37:36 +0000 (Fri, 17 Sep 2010)
New Revision: 5149
trunk/MgDev/Common/Stylization/StylizationEngine.cpp
More watermark cleanup - MdfModel
* Numerous member variables were not being initialized in constructors - BAD!!
* In MdfModel, member variables should be initialized to the corresponding default property value specified in the schema!
* Never include files before stdafx.h. If precompiled headers is enabled then headers included before stdafx.h are ignored.
* Renamed some class properties to be consistent with the schema. E.g. WatermarkXOffset had a Length property but in the schema it's called Offset. Now the code also uses Offset.
* Renamed WatermarkResourceID proeprty on WatermarkInstance to just ResourceId.
* New source files should have copyrights that only reference the current year.
* Adjusted formatting to match the rest of the project.
Also cleaned up some documentation in the schema.
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2010-09-17 22:23:54 UTC (rev 5148)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2010-09-17 22:37:36 UTC (rev 5149)
@@ -337,10 +337,8 @@
double su2wu = 0.001 / (mm2suw * m_serenderer->GetMetersPerUnit());
//Prepare the position list
- XYWatermarkPosition* xyPosition = dynamic_cast<XYWatermarkPosition*>(
- watermark->GetPosition());
- TileWatermarkPosition* tilePosition = dynamic_cast<TileWatermarkPosition*>(
+ XYWatermarkPosition* xyPosition = dynamic_cast<XYWatermarkPosition*>(watermark->GetPosition());
+ TileWatermarkPosition* tilePosition = dynamic_cast<TileWatermarkPosition*>(watermark->GetPosition());
WatermarkXOffset::HorizontalAlignment hAlignment = WatermarkXOffset::Center;
WatermarkYOffset::VerticalAlignment vAlignment = WatermarkYOffset::Center;
WatermarkOffset::WatermarkOffsetUnit hUnit, vUnit;
@@ -351,8 +349,8 @@
vAlignment = xyPosition->GetYPosition()->GetAlignment();
hUnit = xyPosition->GetXPosition()->GetUnit();
vUnit = xyPosition->GetYPosition()->GetUnit();
- xOffset = xyPosition->GetXPosition()->GetLength(); //In watermark unit
- yOffset = xyPosition->GetYPosition()->GetLength(); //In watermark unit
+ xOffset = xyPosition->GetXPosition()->GetOffset(); //In watermark unit
+ yOffset = xyPosition->GetYPosition()->GetOffset(); //In watermark unit
else if(tilePosition)
@@ -360,8 +358,8 @@
vAlignment = tilePosition->GetVerticalPosition()->GetAlignment();
hUnit = tilePosition->GetHorizontalPosition()->GetUnit();
vUnit = tilePosition->GetVerticalPosition()->GetUnit();
- xOffset = tilePosition->GetHorizontalPosition()->GetLength(); //In watermark unit
- yOffset = tilePosition->GetVerticalPosition()->GetLength(); //In watermark unit
+ xOffset = tilePosition->GetHorizontalPosition()->GetOffset(); //In watermark unit
+ yOffset = tilePosition->GetVerticalPosition()->GetOffset(); //In watermark unit
double pixelPerMeterDevice = 1000*mm2sud/px2su;
suPerhUnit = ((hUnit == WatermarkOffset::Pixels)
More information about the mapguide-commits
