[mapguide-commits] r5155 - in trunk/Tools/Maestro:
Maestro/ResourceEditors MaestroAPI/Generated
svn_mapguide at osgeo.org
Mon Sep 20 02:03:53 EDT 2010
Author: jng
Date: 2010-09-20 06:03:53 +0000 (Mon, 20 Sep 2010)
New Revision: 5155
trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.resx
trunk/Tools/Maestro/MaestroAPI/Generated/WebLayout-1.0.0.cs
Fix #1444: Support Web Layout v1.1.0
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs 2010-09-20 03:33:17 UTC (rev 5154)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs 2010-09-20 06:03:53 UTC (rev 5155)
@@ -139,6 +139,9 @@
private ToolStripMenuItem AddSeperatorItem;
private ContextMenuStrip CreateCommandMenu;
private ImageList FixedImages;
+ private Label label13;
+ private ComboBox cmbVersion;
+ private CheckBox chkPingServer;
private string m_tempResource;
private enum ListViewColumns : int
@@ -263,6 +266,15 @@
else
browserURL.Text = "";
+ cmbVersion.SelectedIndex = cmbVersion.FindStringExact(m_layout.GetVersion());
+ Version ver = new Version(cmbVersion.SelectedItem.ToString());
+ chkPingServer.Enabled = (ver > BASE_VERSION);
+ if (chkPingServer.Enabled)
+ chkPingServer.Checked = Convert.ToBoolean(m_layout.EnablePingServer);
finally
@@ -557,6 +569,9 @@
this.AddSeperatorItem = new System.Windows.Forms.ToolStripMenuItem();
this.CreateCommandMenu = new System.Windows.Forms.ContextMenuStrip(this.components);
this.FixedImages = new System.Windows.Forms.ImageList(this.components);
+ this.label13 = new System.Windows.Forms.Label();
+ this.cmbVersion = new System.Windows.Forms.ComboBox();
+ this.chkPingServer = new System.Windows.Forms.CheckBox();
this.overriddenMapExtents.SuspendLayout();
this.groupBox2.SuspendLayout();
this.groupBox3.SuspendLayout();
@@ -1210,26 +1225,52 @@
this.FixedImages.Images.SetKeyName(0, "FolderOpen.ico");
this.FixedImages.Images.SetKeyName(1, "Seperator.ico");
+ // label13
+ resources.ApplyResources(this.label13, "label13");
+ this.label13.Name = "label13";
+ // cmbVersion
+ this.cmbVersion.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+ this.cmbVersion.FormattingEnabled = true;
+ this.cmbVersion.Items.AddRange(new object[] {
+ resources.GetString("cmbVersion.Items"),
+ resources.GetString("cmbVersion.Items1")});
+ resources.ApplyResources(this.cmbVersion, "cmbVersion");
+ this.cmbVersion.Name = "cmbVersion";
+ this.cmbVersion.SelectedIndexChanged += new System.EventHandler(this.cmbVersion_SelectedIndexChanged);
+ // chkPingServer
+ resources.ApplyResources(this.chkPingServer, "chkPingServer");
+ this.chkPingServer.Name = "chkPingServer";
+ this.chkPingServer.UseVisualStyleBackColor = true;
+ this.chkPingServer.CheckedChanged += new System.EventHandler(this.chkPingServer_CheckedChanged);
// LayoutEditor
resources.ApplyResources(this, "$this");
+ this.Controls.Add(this.chkPingServer);
+ this.Controls.Add(this.cmbVersion);
+ this.Controls.Add(this.label13);
+ this.Controls.Add(this.MenuBox);
+ this.Controls.Add(this.SelectMapButton);
this.Controls.Add(this.ShowInBrowser);
this.Controls.Add(this.browserURL);
this.Controls.Add(this.label12);
- this.Controls.Add(this.MenuBox);
+ this.Controls.Add(this.MapResource);
this.Controls.Add(this.FeatureLinkTargetType);
this.Controls.Add(this.FeatureLinkTarget);
this.Controls.Add(this.HomePageURL);
- this.Controls.Add(this.SelectMapButton);
- this.Controls.Add(this.MapResource);
+ this.Controls.Add(this.TitleText);
+ this.Controls.Add(this.OverrideDisplayExtents);
this.Controls.Add(this.groupBox2);
- this.Controls.Add(this.OverrideDisplayExtents);
+ this.Controls.Add(this.label2);
this.Controls.Add(this.overriddenMapExtents);
- this.Controls.Add(this.TitleText);
- this.Controls.Add(this.label2);
this.Controls.Add(this.label1);
+ this.Controls.Add(this.label11);
this.Controls.Add(this.label10);
- this.Controls.Add(this.label11);
this.Name = "LayoutEditor";
this.overriddenMapExtents.ResumeLayout(false);
this.overriddenMapExtents.PerformLayout();
@@ -2169,5 +2210,31 @@
public bool SupportsPreview { get { return m_editor.CurrentConnection.SupportsResourcePreviews; } }
public bool SupportsValidate { get { return true; } }
public bool SupportsProfiling { get { return false; } }
+ static readonly Version BASE_VERSION = new Version(1, 0, 0);
+ private void cmbVersion_SelectedIndexChanged(object sender, EventArgs e)
+ if (m_isUpdating || cmbVersion.SelectedIndex < 0)
+ return;
+ m_layout.ConvertToVersion(ver);
+ m_editor.HasChanged();
+ private void chkPingServer_CheckedChanged(object sender, EventArgs e)
+ m_layout.EnablePingServer = (chkPingServer.Checked).ToString();
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.resx 2010-09-20 03:33:17 UTC (rev 5154)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.resx 2010-09-20 06:03:53 UTC (rev 5155)
@@ -141,7 +141,7 @@
<value>$this</value>
</data>
<data name=">>label1.ZOrder" xml:space="preserve">
- <value>16</value>
+ <value>19</value>
</data>
<data name="label2.Location" type="System.Drawing.Point, System.Drawing">
<value>0, 24</value>
@@ -165,12 +165,120 @@
</data>
<data name=">>label2.ZOrder" xml:space="preserve">
- <value>15</value>
+ <value>17</value>
</data>
<assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="overriddenMapExtents.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Left, Right</value>
</data>
+ <data name=">>label6.Name" xml:space="preserve">
+ <value>label6</value>
+ </data>
+ <data name=">>label6.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>label6.Parent" xml:space="preserve">
+ <value>overriddenMapExtents</value>
+ </data>
+ <data name=">>label6.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>overrideScale.Name" xml:space="preserve">
+ <value>overrideScale</value>
+ </data>
+ <data name=">>overrideScale.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>overrideScale.Parent" xml:space="preserve">
+ </data>
+ <data name=">>overrideScale.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>overrideY.Name" xml:space="preserve">
+ <value>overrideY</value>
+ </data>
+ <data name=">>overrideY.Type" xml:space="preserve">
+ </data>
+ <data name=">>overrideY.Parent" xml:space="preserve">
+ </data>
+ <data name=">>overrideY.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name=">>overrideX.Name" xml:space="preserve">
+ <value>overrideX</value>
+ </data>
+ <data name=">>overrideX.Type" xml:space="preserve">
+ </data>
+ <data name=">>overrideX.Parent" xml:space="preserve">
+ </data>
+ <data name=">>overrideX.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name=">>label5.Name" xml:space="preserve">
+ <value>label5</value>
+ </data>
+ <data name=">>label5.Type" xml:space="preserve">
+ </data>
+ <data name=">>label5.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label5.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name=">>label4.Name" xml:space="preserve">
+ <value>label4</value>
+ </data>
+ <data name=">>label4.Type" xml:space="preserve">
+ </data>
+ <data name=">>label4.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label4.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name=">>label3.Name" xml:space="preserve">
+ <value>label3</value>
+ </data>
+ <data name=">>label3.Type" xml:space="preserve">
+ </data>
+ <data name=">>label3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label3.ZOrder" xml:space="preserve">
+ <value>6</value>
+ </data>
+ <data name="overriddenMapExtents.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="overriddenMapExtents.Location" type="System.Drawing.Point, System.Drawing">
+ <value>-1, 87</value>
+ </data>
+ <data name="overriddenMapExtents.Size" type="System.Drawing.Size, System.Drawing">
+ <value>544, 56</value>
+ </data>
+ <data name="overriddenMapExtents.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name=">>overriddenMapExtents.Name" xml:space="preserve">
+ </data>
+ <data name=">>overriddenMapExtents.Type" xml:space="preserve">
+ <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>overriddenMapExtents.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>overriddenMapExtents.ZOrder" xml:space="preserve">
+ <value>18</value>
+ </data>
<data name="label6.Location" type="System.Drawing.Point, System.Drawing">
<value>336, 24</value>
</data>
@@ -204,9 +312,6 @@
<data name="overrideScale.TabIndex" type="System.Int32, mscorlib">
<value>5</value>
</data>
- <data name="overrideScale.Text" xml:space="preserve">
- <value></value>
- </data>
</data>
@@ -228,9 +333,6 @@
<data name="overrideY.TabIndex" type="System.Int32, mscorlib">
<value>4</value>
</data>
- <data name="overrideY.Text" xml:space="preserve">
- <value></value>
- </data>
</data>
@@ -252,9 +354,6 @@
<data name="overrideX.TabIndex" type="System.Int32, mscorlib">
<value>3</value>
</data>
- <data name="overrideX.Text" xml:space="preserve">
- <value></value>
- </data>
</data>
@@ -339,35 +438,11 @@
<value>6</value>
</data>
- <data name="overriddenMapExtents.Enabled" type="System.Boolean, mscorlib">
- <value>False</value>
- </data>
- <data name="overriddenMapExtents.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 56</value>
- </data>
- <data name="overriddenMapExtents.Size" type="System.Drawing.Size, System.Drawing">
- <value>544, 56</value>
- </data>
- <data name="overriddenMapExtents.TabIndex" type="System.Int32, mscorlib">
- <value>2</value>
- </data>
- <data name=">>overriddenMapExtents.Name" xml:space="preserve">
- <value>overriddenMapExtents</value>
- </data>
- <data name=">>overriddenMapExtents.Type" xml:space="preserve">
- <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>overriddenMapExtents.Parent" xml:space="preserve">
- <value>$this</value>
- </data>
- <data name=">>overriddenMapExtents.ZOrder" xml:space="preserve">
- <value>13</value>
- </data>
<data name="OverrideDisplayExtents.FlatStyle" type="System.Windows.Forms.FlatStyle, System.Windows.Forms">
<value>System</value>
</data>
<data name="OverrideDisplayExtents.Location" type="System.Drawing.Point, System.Drawing">
- <value>8, 56</value>
+ <value>7, 87</value>
</data>
<data name="OverrideDisplayExtents.Size" type="System.Drawing.Size, System.Drawing">
<value>216, 16</value>
@@ -388,11 +463,143 @@
</data>
<data name=">>OverrideDisplayExtents.ZOrder" xml:space="preserve">
- <value>12</value>
+ <value>15</value>
</data>
<data name="groupBox2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
+ <data name=">>groupBox3.Name" xml:space="preserve">
+ <value>groupBox3</value>
+ </data>
+ <data name=">>groupBox3.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.Parent" xml:space="preserve">
+ <value>groupBox2</value>
+ </data>
+ <data name=">>groupBox3.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>groupBox4.Name" xml:space="preserve">
+ <value>groupBox4</value>
+ </data>
+ <data name=">>groupBox4.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox4.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox4.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>groupBox5.Name" xml:space="preserve">
+ <value>groupBox5</value>
+ </data>
+ <data name=">>groupBox5.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox5.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox5.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="groupBox2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>-1, 151</value>
+ </data>
+ <data name="groupBox2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>544, 184</value>
+ </data>
+ <data name="groupBox2.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="groupBox2.Text" xml:space="preserve">
+ <value>Items visible in viewer</value>
+ </data>
+ <data name=">>groupBox2.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.ZOrder" xml:space="preserve">
+ <value>16</value>
+ </data>
+ <data name=">>LeftPaneWidth.Name" xml:space="preserve">
+ <value>LeftPaneWidth</value>
+ </data>
+ <data name=">>LeftPaneWidth.Type" xml:space="preserve">
+ </data>
+ <data name=">>LeftPaneWidth.Parent" xml:space="preserve">
+ </data>
+ <data name=">>LeftPaneWidth.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>label7.Name" xml:space="preserve">
+ <value>label7</value>
+ </data>
+ <data name=">>label7.Type" xml:space="preserve">
+ </data>
+ <data name=">>label7.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label7.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>ItemPropertiesCheck.Name" xml:space="preserve">
+ <value>ItemPropertiesCheck</value>
+ </data>
+ <data name=">>ItemPropertiesCheck.Type" xml:space="preserve">
+ <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>ItemPropertiesCheck.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ItemPropertiesCheck.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name=">>LayerControlCheck.Name" xml:space="preserve">
+ <value>LayerControlCheck</value>
+ </data>
+ <data name=">>LayerControlCheck.Type" xml:space="preserve">
+ </data>
+ <data name=">>LayerControlCheck.Parent" xml:space="preserve">
+ </data>
+ <data name=">>LayerControlCheck.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="groupBox3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 16</value>
+ </data>
+ <data name="groupBox3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>160, 152</value>
+ </data>
+ <data name="groupBox3.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="groupBox3.Text" xml:space="preserve">
+ <value>Left side</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
<data name="LeftPaneWidth.Location" type="System.Drawing.Point, System.Drawing">
<value>8, 120</value>
</data>
@@ -402,9 +609,6 @@
<data name="LeftPaneWidth.TabIndex" type="System.Int32, mscorlib">
<value>3</value>
</data>
- <data name="LeftPaneWidth.Text" xml:space="preserve">
- <value></value>
- </data>
</data>
@@ -495,29 +699,89 @@
<value>3</value>
</data>
- <data name="groupBox3.Location" type="System.Drawing.Point, System.Drawing">
- <value>16, 16</value>
+ <data name=">>label9.Name" xml:space="preserve">
+ <value>label9</value>
</data>
- <data name="groupBox3.Size" type="System.Drawing.Size, System.Drawing">
- <value>160, 152</value>
+ <data name=">>label9.Type" xml:space="preserve">
</data>
- <data name="groupBox3.TabIndex" type="System.Int32, mscorlib">
+ <data name=">>label9.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label9.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <data name="groupBox3.Text" xml:space="preserve">
- <value>Left side</value>
+ <data name=">>ZoomControlCheck.Name" xml:space="preserve">
+ <value>ZoomControlCheck</value>
</data>
- <data name=">>groupBox3.Name" xml:space="preserve">
- <value>groupBox3</value>
+ <data name=">>ZoomControlCheck.Type" xml:space="preserve">
</data>
- <data name=">>groupBox3.Type" xml:space="preserve">
+ <data name=">>ZoomControlCheck.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ZoomControlCheck.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>StatusBarCheck.Name" xml:space="preserve">
+ <value>StatusBarCheck</value>
+ </data>
+ <data name=">>StatusBarCheck.Type" xml:space="preserve">
+ </data>
+ <data name=">>StatusBarCheck.Parent" xml:space="preserve">
+ </data>
+ <data name=">>StatusBarCheck.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name=">>ContextMenuCheck.Name" xml:space="preserve">
+ <value>ContextMenuCheck</value>
+ </data>
+ <data name=">>ContextMenuCheck.Type" xml:space="preserve">
+ </data>
+ <data name=">>ContextMenuCheck.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ContextMenuCheck.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name=">>ToolbarCheck.Name" xml:space="preserve">
+ <value>ToolbarCheck</value>
+ </data>
+ <data name=">>ToolbarCheck.Type" xml:space="preserve">
+ </data>
+ <data name=">>ToolbarCheck.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ToolbarCheck.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="groupBox4.Location" type="System.Drawing.Point, System.Drawing">
+ <value>184, 16</value>
+ </data>
+ <data name="groupBox4.Size" type="System.Drawing.Size, System.Drawing">
+ <value>168, 152</value>
+ </data>
+ <data name="groupBox4.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="groupBox4.Text" xml:space="preserve">
+ <value>Map / middle</value>
+ </data>
+ </data>
</data>
- <data name=">>groupBox3.Parent" xml:space="preserve">
</data>
- <data name=">>groupBox3.ZOrder" xml:space="preserve">
- <value>0</value>
+ <value>1</value>
</data>
<data name="label9.Location" type="System.Drawing.Point, System.Drawing">
<value>24, 112</value>
@@ -651,29 +915,89 @@
<value>4</value>
</data>
- <data name="groupBox4.Location" type="System.Drawing.Point, System.Drawing">
- <value>184, 16</value>
+ <data name=">>label8.Name" xml:space="preserve">
+ <value>label8</value>
</data>
- <data name="groupBox4.Size" type="System.Drawing.Size, System.Drawing">
+ <data name=">>label8.Type" xml:space="preserve">
+ </data>
+ <data name=">>label8.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label8.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>EditTaskBarBtn.Name" xml:space="preserve">
+ <value>EditTaskBarBtn</value>
+ </data>
+ <data name=">>EditTaskBarBtn.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>EditTaskBarBtn.Parent" xml:space="preserve">
+ </data>
+ <data name=">>EditTaskBarBtn.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>RightPaneWidth.Name" xml:space="preserve">
+ <value>RightPaneWidth</value>
+ </data>
+ <data name=">>RightPaneWidth.Type" xml:space="preserve">
+ </data>
+ <data name=">>RightPaneWidth.Parent" xml:space="preserve">
+ </data>
+ <data name=">>RightPaneWidth.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name=">>TaskBarCheck.Name" xml:space="preserve">
+ <value>TaskBarCheck</value>
+ </data>
+ <data name=">>TaskBarCheck.Type" xml:space="preserve">
+ </data>
+ <data name=">>TaskBarCheck.Parent" xml:space="preserve">
+ </data>
+ <data name=">>TaskBarCheck.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name=">>TaskPaneCheck.Name" xml:space="preserve">
+ <value>TaskPaneCheck</value>
+ </data>
+ <data name=">>TaskPaneCheck.Type" xml:space="preserve">
+ </data>
+ <data name=">>TaskPaneCheck.Parent" xml:space="preserve">
+ </data>
+ <data name=">>TaskPaneCheck.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="groupBox5.Location" type="System.Drawing.Point, System.Drawing">
+ <value>368, 16</value>
+ </data>
+ <data name="groupBox5.Size" type="System.Drawing.Size, System.Drawing">
</data>
- <data name="groupBox4.TabIndex" type="System.Int32, mscorlib">
+ <data name="groupBox5.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
</data>
- <data name="groupBox4.Text" xml:space="preserve">
- <value>Map / middle</value>
+ <data name="groupBox5.Text" xml:space="preserve">
+ <value>Right side</value>
</data>
- <data name=">>groupBox4.Name" xml:space="preserve">
- <value>groupBox4</value>
</data>
- <data name=">>groupBox4.Type" xml:space="preserve">
</data>
- <data name=">>groupBox4.Parent" xml:space="preserve">
</data>
- <data name=">>groupBox4.ZOrder" xml:space="preserve">
- <value>1</value>
+ <value>2</value>
</data>
<data name="label8.Location" type="System.Drawing.Point, System.Drawing">
<value>8, 104</value>
@@ -735,9 +1059,6 @@
<data name="RightPaneWidth.TabIndex" type="System.Int32, mscorlib">
<value>5</value>
</data>
- <data name="RightPaneWidth.Text" xml:space="preserve">
- <value></value>
- </data>
</data>
@@ -804,54 +1125,6 @@
<value>4</value>
</data>
- <data name="groupBox5.Location" type="System.Drawing.Point, System.Drawing">
- <value>368, 16</value>
- </data>
- <data name="groupBox5.Size" type="System.Drawing.Size, System.Drawing">
- <value>168, 152</value>
- </data>
- <data name="groupBox5.TabIndex" type="System.Int32, mscorlib">
- <value>1</value>
- </data>
- <data name="groupBox5.Text" xml:space="preserve">
- <value>Right side</value>
- </data>
- <data name=">>groupBox5.Name" xml:space="preserve">
- <value>groupBox5</value>
- </data>
- <data name=">>groupBox5.Type" xml:space="preserve">
- </data>
- <data name=">>groupBox5.Parent" xml:space="preserve">
- <value>groupBox2</value>
- </data>
- <data name=">>groupBox5.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
- <data name="groupBox2.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 120</value>
- </data>
- <data name="groupBox2.Size" type="System.Drawing.Size, System.Drawing">
- <value>544, 184</value>
- </data>
- <data name="groupBox2.TabIndex" type="System.Int32, mscorlib">
- <value>4</value>
- </data>
- <data name="groupBox2.Text" xml:space="preserve">
- <value>Items visible in viewer</value>
- </data>
- <data name=">>groupBox2.Name" xml:space="preserve">
- </data>
- <data name=">>groupBox2.Type" xml:space="preserve">
- </data>
- <data name=">>groupBox2.Parent" xml:space="preserve">
- </data>
- <data name=">>groupBox2.ZOrder" xml:space="preserve">
- <value>11</value>
- </data>
<data name="TitleText.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
@@ -864,9 +1137,6 @@
<data name="TitleText.TabIndex" type="System.Int32, mscorlib">
<value>4</value>
</data>
- <data name="TitleText.Text" xml:space="preserve">
- <value></value>
- </data>
<data name=">>TitleText.Name" xml:space="preserve">
<value>TitleText</value>
</data>
@@ -891,9 +1161,6 @@
<data name="MapResource.TabIndex" type="System.Int32, mscorlib">
<value>5</value>
</data>
- <data name="MapResource.Text" xml:space="preserve">
- <value></value>
- </data>
<data name=">>MapResource.Name" xml:space="preserve">
<value>MapResource</value>
</data>
@@ -934,7 +1201,7 @@
</data>
<data name=">>SelectMapButton.ZOrder" xml:space="preserve">
- <value>9</value>
+ <value>6</value>
</data>
<data name="FeatureLinkTarget.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -943,7 +1210,7 @@
</data>
<data name="FeatureLinkTarget.Location" type="System.Drawing.Point, System.Drawing">
- <value>280, 336</value>
+ <value>279, 367</value>
</data>
<data name="FeatureLinkTarget.Size" type="System.Drawing.Size, System.Drawing">
<value>264, 20</value>
@@ -951,9 +1218,6 @@
<data name="FeatureLinkTarget.TabIndex" type="System.Int32, mscorlib">
<value>11</value>
</data>
- <data name="FeatureLinkTarget.Text" xml:space="preserve">
- <value></value>
- </data>
<data name=">>FeatureLinkTarget.Name" xml:space="preserve">
<value>FeatureLinkTarget</value>
</data>
@@ -964,10 +1228,10 @@
</data>
<data name=">>FeatureLinkTarget.ZOrder" xml:space="preserve">
- <value>7</value>
+ <value>12</value>
</data>
<data name="label10.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 336</value>
+ <value>-1, 367</value>
</data>
<data name="label10.Size" type="System.Drawing.Size, System.Drawing">
<value>144, 16</value>
@@ -988,10 +1252,10 @@
</data>
<data name=">>label10.ZOrder" xml:space="preserve">
- <value>17</value>
+ <value>21</value>
</data>
<data name="label11.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 312</value>
+ <value>-1, 343</value>
</data>
<data name="label11.Size" type="System.Drawing.Size, System.Drawing">
@@ -1012,13 +1276,13 @@
</data>
<data name=">>label11.ZOrder" xml:space="preserve">
- <value>18</value>
+ <value>20</value>
</data>
<data name="HomePageURL.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
<data name="HomePageURL.Location" type="System.Drawing.Point, System.Drawing">
- <value>160, 312</value>
+ <value>159, 343</value>
</data>
<data name="HomePageURL.Size" type="System.Drawing.Size, System.Drawing">
<value>384, 20</value>
@@ -1026,9 +1290,6 @@
<data name="HomePageURL.TabIndex" type="System.Int32, mscorlib">
<value>10</value>
</data>
- <data name="HomePageURL.Text" xml:space="preserve">
- <value></value>
- </data>
<data name=">>HomePageURL.Name" xml:space="preserve">
<value>HomePageURL</value>
</data>
@@ -1039,7 +1300,7 @@
</data>
<data name=">>HomePageURL.ZOrder" xml:space="preserve">
- <value>8</value>
+ <value>13</value>
</data>
<data name="FeatureLinkTargetType.Items" xml:space="preserve">
<value>Task pane</value>
@@ -1051,7 +1312,7 @@
<value>Named frame</value>
</data>
<data name="FeatureLinkTargetType.Location" type="System.Drawing.Point, System.Drawing">
- <value>160, 336</value>
+ <value>159, 367</value>
</data>
<data name="FeatureLinkTargetType.Size" type="System.Drawing.Size, System.Drawing">
<value>112, 21</value>
@@ -1069,7 +1330,7 @@
</data>
<data name=">>FeatureLinkTargetType.ZOrder" xml:space="preserve">
- <value>6</value>
+ <value>11</value>
</data>
<metadata name="CommandTypesDataset.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>131, 17</value>
@@ -1077,6 +1338,66 @@
<data name="MenuBox.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Bottom, Left, Right</value>
</data>
+ <data name=">>commandEditor.Name" xml:space="preserve">
+ <value>commandEditor</value>
+ </data>
+ <data name=">>commandEditor.Type" xml:space="preserve">
+ <value>OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.CommandEditor, OSGeo.MapGuide.Maestro.ResourceEditors, Version=2.1.1.5078, Culture=neutral, PublicKeyToken=null</value>
+ </data>
+ <data name=">>commandEditor.Parent" xml:space="preserve">
+ <value>MenuBox</value>
+ </data>
+ <data name=">>commandEditor.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>splitter2.Name" xml:space="preserve">
+ <value>splitter2</value>
+ </data>
+ <data name=">>splitter2.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Splitter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>splitter2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>splitter2.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>MenuTabs.Name" xml:space="preserve">
+ <value>MenuTabs</value>
+ </data>
+ <data name=">>MenuTabs.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TabControl, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>MenuTabs.Parent" xml:space="preserve">
+ </data>
+ <data name=">>MenuTabs.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="MenuBox.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 414</value>
+ </data>
+ <data name="MenuBox.Size" type="System.Drawing.Size, System.Drawing">
+ <value>552, 293</value>
+ </data>
+ <data name="MenuBox.TabIndex" type="System.Int32, mscorlib">
+ <value>14</value>
+ </data>
+ <data name="MenuBox.Text" xml:space="preserve">
+ <value>Menus</value>
+ </data>
+ <data name=">>MenuBox.Name" xml:space="preserve">
+ </data>
+ <data name=">>MenuBox.Type" xml:space="preserve">
+ </data>
+ <data name=">>MenuBox.Parent" xml:space="preserve">
+ </data>
+ <data name=">>MenuBox.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
<data name="commandEditor.AutoScroll" type="System.Boolean, mscorlib">
<value>True</value>
</data>
@@ -1090,7 +1411,7 @@
<value>267, 16</value>
</data>
<data name="commandEditor.Size" type="System.Drawing.Size, System.Drawing">
- <value>282, 269</value>
+ <value>282, 274</value>
</data>
<data name="commandEditor.TabIndex" type="System.Int32, mscorlib">
<value>2</value>
@@ -1102,7 +1423,7 @@
</data>
- <value>OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.CommandEditor, OSGeo.MapGuide.Maestro.ResourceEditors, Version=1.1.0.4358, Culture=neutral, PublicKeyToken=null</value>
</data>
@@ -1114,7 +1435,7 @@
<value>259, 16</value>
</data>
<data name="splitter2.Size" type="System.Drawing.Size, System.Drawing">
- <value>8, 269</value>
+ <value>8, 274</value>
</data>
<data name="splitter2.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
@@ -1131,6 +1452,117 @@
<value>1</value>
</data>
+ <data name=">>ToolbarTab.Name" xml:space="preserve">
+ <value>ToolbarTab</value>
+ </data>
+ <data name=">>ToolbarTab.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TabPage, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>ToolbarTab.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ToolbarTab.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>ContextMenuTab.Name" xml:space="preserve">
+ <value>ContextMenuTab</value>
+ </data>
+ <data name=">>ContextMenuTab.Type" xml:space="preserve">
+ </data>
+ <data name=">>ContextMenuTab.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ContextMenuTab.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>TaskFrameTab.Name" xml:space="preserve">
+ <value>TaskFrameTab</value>
+ </data>
+ <data name=">>TaskFrameTab.Type" xml:space="preserve">
+ </data>
+ <data name=">>TaskFrameTab.Parent" xml:space="preserve">
+ </data>
+ <data name=">>TaskFrameTab.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="MenuTabs.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Left</value>
+ </data>
+ <data name="MenuTabs.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 16</value>
+ </data>
+ <data name="MenuTabs.Size" type="System.Drawing.Size, System.Drawing">
+ <value>256, 274</value>
+ </data>
+ <data name="MenuTabs.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>2</value>
+ </data>
+ <metadata name="ToolbarToolstrip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>0, 0</value>
+ </metadata>
+ <data name=">>ToolbarTree.Name" xml:space="preserve">
+ <value>ToolbarTree</value>
+ </data>
+ <data name=">>ToolbarTree.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TreeView, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>ToolbarTree.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ToolbarTree.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>ToolbarToolstrip.Name" xml:space="preserve">
+ <value>ToolbarToolstrip</value>
+ </data>
+ <data name=">>ToolbarToolstrip.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>ToolbarToolstrip.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ToolbarToolstrip.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="ToolbarTab.Location" type="System.Drawing.Point, System.Drawing">
+ <value>4, 22</value>
+ </data>
+ <data name="ToolbarTab.Size" type="System.Drawing.Size, System.Drawing">
+ <value>248, 248</value>
+ </data>
+ <data name="ToolbarTab.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="ToolbarTab.Text" xml:space="preserve">
+ <value>Toolbar</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
<data name="ToolbarTree.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
@@ -1138,7 +1570,7 @@
<value>0, 25</value>
</data>
<data name="ToolbarTree.Size" type="System.Drawing.Size, System.Drawing">
- <value>248, 218</value>
+ <value>248, 223</value>
</data>
<data name="ToolbarTree.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
@@ -1156,8 +1588,29 @@
<value>0</value>
</data>
- <value>583, 17</value>
</metadata>
+ <data name="ToolbarToolstrip.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="ToolbarToolstrip.Size" type="System.Drawing.Size, System.Drawing">
+ <value>248, 25</value>
+ </data>
+ <data name="ToolbarToolstrip.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
<data name="ToolbarAddButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
@@ -1277,50 +1730,56 @@
<data name="ToolbarCreateButton.ToolTipText" xml:space="preserve">
<value>Create a new item</value>
</data>
- <data name="ToolbarToolstrip.Location" type="System.Drawing.Point, System.Drawing">
+ <metadata name="ContextToolstrip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>0, 0</value>
+ </metadata>
+ <data name=">>ContextTree.Name" xml:space="preserve">
+ <value>ContextTree</value>
</data>
- <data name="ToolbarToolstrip.Size" type="System.Drawing.Size, System.Drawing">
- <value>248, 25</value>
+ <data name=">>ContextTree.Type" xml:space="preserve">
</data>
- <data name="ToolbarToolstrip.TabIndex" type="System.Int32, mscorlib">
- <value>2</value>
+ <data name=">>ContextTree.Parent" xml:space="preserve">
</data>
- <data name=">>ToolbarToolstrip.Name" xml:space="preserve">
- <value>ToolbarToolstrip</value>
+ <data name=">>ContextTree.ZOrder" xml:space="preserve">
+ <value>0</value>
</data>
- <data name=">>ToolbarToolstrip.Type" xml:space="preserve">
+ <data name=">>ContextToolstrip.Name" xml:space="preserve">
+ <value>ContextToolstrip</value>
+ </data>
+ <data name=">>ContextToolstrip.Type" xml:space="preserve">
</data>
- <data name=">>ToolbarToolstrip.Parent" xml:space="preserve">
- <value>ToolbarTab</value>
+ <data name=">>ContextToolstrip.Parent" xml:space="preserve">
</data>
- <data name=">>ToolbarToolstrip.ZOrder" xml:space="preserve">
+ <data name=">>ContextToolstrip.ZOrder" xml:space="preserve">
<value>1</value>
</data>
- <data name="ToolbarTab.Location" type="System.Drawing.Point, System.Drawing">
+ <data name="ContextMenuTab.Location" type="System.Drawing.Point, System.Drawing">
</data>
- <data name="ToolbarTab.Size" type="System.Drawing.Size, System.Drawing">
- <value>248, 243</value>
+ <data name="ContextMenuTab.Size" type="System.Drawing.Size, System.Drawing">
</data>
- <data name="ToolbarTab.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
+ <data name="ContextMenuTab.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
</data>
- <data name="ToolbarTab.Text" xml:space="preserve">
- <value>Toolbar</value>
+ <data name="ContextMenuTab.Text" xml:space="preserve">
+ <value>Context menu</value>
</data>
- <data name=">>ToolbarTab.Name" xml:space="preserve">
</data>
- <data name=">>ToolbarTab.Type" xml:space="preserve">
</data>
- <data name=">>ToolbarTab.Parent" xml:space="preserve">
</data>
- <data name=">>ToolbarTab.ZOrder" xml:space="preserve">
- <value>0</value>
+ <value>1</value>
</data>
<data name="ContextTree.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
@@ -1329,7 +1788,7 @@
</data>
<data name="ContextTree.Size" type="System.Drawing.Size, System.Drawing">
</data>
<data name="ContextTree.TabIndex" type="System.Int32, mscorlib">
<value>3</value>
@@ -1349,6 +1808,30 @@
<value>0, 0</value>
</metadata>
+ <data name="ContextToolstrip.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="ContextToolstrip.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="ContextToolstrip.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="ContextToolstrip.Text" xml:space="preserve">
+ <value>toolStrip2</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
<data name="ContextAddButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1468,53 +1951,56 @@
<data name="ContextCreateButton.ToolTipText" xml:space="preserve">
</data>
- <data name="ContextToolstrip.Location" type="System.Drawing.Point, System.Drawing">
+ <metadata name="TaskToolstrip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>0, 0</value>
+ </metadata>
+ <data name=">>TaskTree.Name" xml:space="preserve">
+ <value>TaskTree</value>
</data>
- <data name="ContextToolstrip.Size" type="System.Drawing.Size, System.Drawing">
+ <data name=">>TaskTree.Type" xml:space="preserve">
</data>
- <data name="ContextToolstrip.TabIndex" type="System.Int32, mscorlib">
- <value>4</value>
+ <data name=">>TaskTree.Parent" xml:space="preserve">
</data>
- <data name="ContextToolstrip.Text" xml:space="preserve">
- <value>toolStrip2</value>
+ <data name=">>TaskTree.ZOrder" xml:space="preserve">
+ <value>0</value>
</data>
- <data name=">>ContextToolstrip.Name" xml:space="preserve">
- <value>ContextToolstrip</value>
+ <data name=">>TaskToolstrip.Name" xml:space="preserve">
+ <value>TaskToolstrip</value>
</data>
- <data name=">>ContextToolstrip.Type" xml:space="preserve">
+ <data name=">>TaskToolstrip.Type" xml:space="preserve">
</data>
- <data name=">>ContextToolstrip.Parent" xml:space="preserve">
- <value>ContextMenuTab</value>
+ <data name=">>TaskToolstrip.Parent" xml:space="preserve">
</data>
- <data name=">>ContextToolstrip.ZOrder" xml:space="preserve">
+ <data name=">>TaskToolstrip.ZOrder" xml:space="preserve">
<value>1</value>
</data>
- <data name="ContextMenuTab.Location" type="System.Drawing.Point, System.Drawing">
+ <data name="TaskFrameTab.Location" type="System.Drawing.Point, System.Drawing">
</data>
- <data name="ContextMenuTab.Size" type="System.Drawing.Size, System.Drawing">
+ <data name="TaskFrameTab.Size" type="System.Drawing.Size, System.Drawing">
</data>
- <data name="ContextMenuTab.TabIndex" type="System.Int32, mscorlib">
- <value>1</value>
+ <data name="TaskFrameTab.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
</data>
- <data name="ContextMenuTab.Text" xml:space="preserve">
- <value>Context menu</value>
+ <data name="TaskFrameTab.Text" xml:space="preserve">
+ <value>Task frame menu</value>
</data>
- <data name=">>ContextMenuTab.Name" xml:space="preserve">
</data>
- <data name=">>ContextMenuTab.Type" xml:space="preserve">
</data>
- <data name=">>ContextMenuTab.Parent" xml:space="preserve">
</data>
- <data name=">>ContextMenuTab.ZOrder" xml:space="preserve">
- <value>1</value>
+ <value>2</value>
</data>
<data name="TaskTree.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
@@ -1523,7 +2009,7 @@
</data>
<data name="TaskTree.Size" type="System.Drawing.Size, System.Drawing">
</data>
<data name="TaskTree.TabIndex" type="System.Int32, mscorlib">
<value>4</value>
@@ -1543,6 +2029,30 @@
<value>0, 0</value>
</metadata>
+ <data name="TaskToolstrip.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="TaskToolstrip.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="TaskToolstrip.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name="TaskToolstrip.Text" xml:space="preserve">
+ <value>toolStrip3</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
<data name="TaskAddButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1662,107 +2172,11 @@
<data name="TaskCreateButton.ToolTipText" xml:space="preserve">
</data>
- <data name="TaskToolstrip.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 0</value>
- </data>
- <data name="TaskToolstrip.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="TaskToolstrip.TabIndex" type="System.Int32, mscorlib">
- <value>5</value>
- </data>
- <data name="TaskToolstrip.Text" xml:space="preserve">
- <value>toolStrip3</value>
- </data>
- <data name=">>TaskToolstrip.Name" xml:space="preserve">
- <value>TaskToolstrip</value>
- </data>
- <data name=">>TaskToolstrip.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>TaskToolstrip.Parent" xml:space="preserve">
- <value>TaskFrameTab</value>
- </data>
- <data name=">>TaskToolstrip.ZOrder" xml:space="preserve">
- <value>1</value>
- </data>
- <data name="TaskFrameTab.Location" type="System.Drawing.Point, System.Drawing">
- <value>4, 22</value>
- </data>
- <data name="TaskFrameTab.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="TaskFrameTab.TabIndex" type="System.Int32, mscorlib">
- <value>2</value>
- </data>
- <data name="TaskFrameTab.Text" xml:space="preserve">
- <value>Task frame menu</value>
- </data>
- <data name=">>TaskFrameTab.Name" xml:space="preserve">
- </data>
- <data name=">>TaskFrameTab.Type" xml:space="preserve">
- <value>System.Windows.Forms.TabPage, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>TaskFrameTab.Parent" xml:space="preserve">
- <value>MenuTabs</value>
- </data>
- <data name=">>TaskFrameTab.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
- <data name="MenuTabs.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
- <value>Left</value>
- </data>
- <data name="MenuTabs.Location" type="System.Drawing.Point, System.Drawing">
- <value>3, 16</value>
- </data>
- <data name="MenuTabs.Size" type="System.Drawing.Size, System.Drawing">
- <value>256, 269</value>
- </data>
- <data name="MenuTabs.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
- </data>
- <data name=">>MenuTabs.Name" xml:space="preserve">
- </data>
- <data name=">>MenuTabs.Type" xml:space="preserve">
- <value>System.Windows.Forms.TabControl, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>MenuTabs.Parent" xml:space="preserve">
- <value>MenuBox</value>
- </data>
- <data name=">>MenuTabs.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
- <data name="MenuBox.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 384</value>
- </data>
- <data name="MenuBox.Size" type="System.Drawing.Size, System.Drawing">
- <value>552, 288</value>
- </data>
- <data name="MenuBox.TabIndex" type="System.Int32, mscorlib">
- <value>14</value>
- </data>
- <data name="MenuBox.Text" xml:space="preserve">
- <value>Menus</value>
- </data>
- <data name=">>MenuBox.Name" xml:space="preserve">
- </data>
- <data name=">>MenuBox.Type" xml:space="preserve">
- </data>
- <data name=">>MenuBox.Parent" xml:space="preserve">
- </data>
- <data name=">>MenuBox.ZOrder" xml:space="preserve">
- <value>5</value>
- </data>
<data name="browserURL.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
<data name="browserURL.Location" type="System.Drawing.Point, System.Drawing">
- <value>160, 360</value>
+ <value>159, 391</value>
</data>
<data name="browserURL.Size" type="System.Drawing.Size, System.Drawing">
<value>240, 20</value>
@@ -1780,10 +2194,10 @@
</data>
<data name=">>browserURL.ZOrder" xml:space="preserve">
- <value>3</value>
+ <value>8</value>
</data>
<data name="label12.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 360</value>
+ <value>-1, 391</value>
</data>
<data name="label12.Size" type="System.Drawing.Size, System.Drawing">
@@ -1804,13 +2218,13 @@
</data>
<data name=">>label12.ZOrder" xml:space="preserve">
- <value>4</value>
+ <value>9</value>
</data>
<data name="ShowInBrowser.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Right</value>
</data>
<data name="ShowInBrowser.Location" type="System.Drawing.Point, System.Drawing">
- <value>408, 360</value>
+ <value>407, 391</value>
</data>
<data name="ShowInBrowser.Size" type="System.Drawing.Size, System.Drawing">
<value>136, 20</value>
@@ -1831,11 +2245,20 @@
</data>
<data name=">>ShowInBrowser.ZOrder" xml:space="preserve">
- <value>2</value>
+ <value>7</value>
</data>
<metadata name="AddItemMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>300, 17</value>
</metadata>
+ <data name="AddItemMenu.Size" type="System.Drawing.Size, System.Drawing">
+ <value>160, 92</value>
+ </data>
+ <data name=">>AddItemMenu.Name" xml:space="preserve">
+ <value>AddItemMenu</value>
+ </data>
+ <data name=">>AddItemMenu.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ContextMenuStrip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
<data name="AddBuiltInFunctionMenu.Size" type="System.Drawing.Size, System.Drawing">
<value>159, 22</value>
</data>
@@ -1880,15 +2303,6 @@
<data name="AddSeperatorItem.Text" xml:space="preserve">
<value>Seperator</value>
</data>
- <data name="AddItemMenu.Size" type="System.Drawing.Size, System.Drawing">
- <value>160, 92</value>
- </data>
- <data name=">>AddItemMenu.Name" xml:space="preserve">
- <value>AddItemMenu</value>
- </data>
- <data name=">>AddItemMenu.Type" xml:space="preserve">
- <value>System.Windows.Forms.ContextMenuStrip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
<metadata name="CreateCommandMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>421, 17</value>
</metadata>
@@ -1908,35 +2322,119 @@
<value>
AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
- ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAAE
- BgAAAk1TRnQBSQFMAgEBAgEAARQBAAEUAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
- AwABEAMAAQEBAAEgBgABEP8AFwABTAJDAZIBTAJDAZMBTAJDAZMBTAJDAZMBTAJDAZMBTAJDAZMBTAJD
- AZMBTAJDAZMBTAJDAZMBTAJDAZMBTAJDAZMBTAJDAZIDBAEFyAADMQFPAZQByQH6Af8BMAHQAv8BLgHP
- Av8BLAHOAv8BKgHNAv8BJwHMAv8BJQHLAv8BIwHKAv8BIQHJAv8BHwHHAv8BHAHGAv8BGgHFAf4B/wFc
- ATYBOwHUyAADMQFPAVgBqQH0Af8BTgHdAv8BRAHbAv8BQwHaAv8BQQHZAv8BPwHYAv8BPQHXAv8BOwHW
- Av8BOQHVAv8BNwHUAv8BNQHSAv8BMwHRAf4B/wFeATcBOgHayAADMQFPAWgBzAH5Af8BvgH0Af4B/wFZ
- AeQC/wFXAeMC/wFVAeIC/wFUAeIC/wFSAeEC/wFQAeAC/wFOAd8C/wFMAd4C/wFKAd0C/wFJAdwB/gH/
- AVkCPgG/AyEBMMQAAzEBTwFkAdMC/wGQAccB+QH/AWgB7AL/AWcB6wL/AWYB6wL/AWQB6gL/AWMB6gL/
- AWIB6QL/AWAB6AL/AV8B6AL/AV4B5wL/AVwB5gH+Af8BWQI+Ab8BXAE2ATsB1AgAAVcCPwG4AVgCPwG5
- AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5
- AVgCPwG5AVgCPwG5ATwCOgFmgAADMQFPAW4B2QL/ASkBnwH1Af8BhwHwAv8BgQHwAv8BgAHwAv8BewHw
- Av8BeAHwAv8BdQHwAv8BcwHwAv8BcQHvAv8BbwHvAv8BbgHvAf4B/wFZAj4BvwFeAjoB2ggAA4EB/wOh
- Af8DqgH/A7EB/wOzAf8DrAH/A6IB/wOeAf8DngH/A54B/wOeAf8DngH/A54B/wOhAf8BWwI6AcaAAAMx
- AU8BgQHjAv8BNAHKAfoB/wHhAfQB/gH/AdsB9wH+Af8B2wH3Af4B/wHaAfcB/gH/AdgB+QH+Af8BmQH0
- Av8BlgH0Av8BkwH0Av8BkAH0Av8BjQHzAf4B/wFZAj4BvwFZAj4BvwMjATQEAAOBAf8DgQH/A5AB/wOj
- Af8DsQH/A7EB/wOhAf8DjAH/A4cB/wOHAf8DhwH/A4cB/wOHAf8DnAH/AVsCOgHGgAADMQFPAZIB7gL/
- AVYB5AL/AVYB5AL/AVYB5AL/AVYB5AL/AVYB5AL/AUcBxgH3Af8B6gH5Af4B/wHmAfkB/gH/AeUB+QH+
- Af8B5AH5Af4B/wHjAfkB/gH/AYwCZQHvAYwCZQHvAV0BNQE5AdcEAAOBAf8DgQH/A4MB/wOUAf8DpgH/
- A7IB/wOwAf8DnwH/A4wB/wOIAf8DiAH/A4gB/wOIAf8DnAH/AVsCOgHGgAADMQFPAacB+AL/AXgB9QL/
- AXgB9QL/AXgB9QL/AXgB9QL/AXgB9QL/AXgB9QL/AXgB9QL/AXgB9QL/AXgB9QL/AXgB9QL/AXUB8QH+
- Af8QAAOAAf8DgQH/A4EB/wOCAf8DgwH/A4MB/wOCAf8DgQH/A4EB/wOBAf8DfQH/A3sB/wN5Af8DdgH/
- AVsCOgHGgAADMQFPAcED/wGcA/8BnAP/AZwD/wHWAf0B/gH/Ad8B+QH+Af8B3wH5Af4B/wHfAfkB/gH/
- Ad8B+QH+Af8B3wH5Af4B/wHfAfkB/gH/AdAB8gH9Af/MAAMxAU8B6QP/AdwD/wHcA/8B3QP/AVgCQQG5
- 7AABQAI9AW8BQAI9AW8BQAI9AW8BQAI9AW8DCAEL/wD/AP8A6wABQgFNAT4HAAE+AwABKAMAAUADAAEQ
- AwABAQEAAQEFAAGAFwAD/wEABP8EAAGAAQMC/wUAAQMC/wUAAQMC/wUAAQEC/wUAAQEBgAYAAQEBgAcA
- AYAHAAGABgABBwGABgABBwL/BAABAwP/BAABgwP/BAAE/wQABP8EAAT/BAAL
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADs
+ BQAAAk1TRnQBSQFMAgEBAgEAASQBAAEkAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+ AwABEAMAAQEBAAEgBgABEP8AFwABTAJLAZIDTAGTA0wBkwNMAZMDTAGTA0wBkwNMAZMDTAGTA0wBkwNM
+ AZMDTAGTAUwCSwGSAwQBBcgAAzEBTwGUAckB+gH/AS4B0AL/ASwBzwL/ASoBzgL/ASgBzQL/ASUBzAL/
+ ASMBywL/ASEBygL/AR8ByQL/AR0BxwL/ARoBxgL/ARgBxQH+Af8BXAFMAU0B1MgAAzEBTwFWAakB9AH/
+ AUwB3QL/AUIB2wL/AUEB2gL/AT8B2QL/AT0B2AL/ATsB1wL/ATkB1gL/ATcB1QL/ATUB1AL/ATMB0gL/
+ ATEB0QH+Af8BXgJKAdrIAAMxAU8BZgHMAfkB/wG+AfQB/gH/AVcB5AL/AVUB4wL/AVMB4gL/AVIB4gL/
+ AVAB4QL/AU4B4AL/AUwB3wL/AUoB3gL/AUgB3QL/AUcB3AH+Af8BWQJQAb8DIQEwxAADMQFPAWIB0wL/
+ AZABxwH5Af8BZgHsAv8BZQHrAv8BZAHrAv8BYgHqAv8BYQHqAv8BYAHpAv8BXgHoAv8BXQHoAv8BXAHn
+ Av8BWgHmAf4B/wFZAlABvwFcAUwBTQHUCAABVwJQAbgBWAJQAbkBWAJQAbkBWAJQAbkBWAJQAbkBWAJQ
+ AbkBWAJQAbkBWAJQAbkBWAJQAbkBWAJQAbkBWAJQAbkBWAJQAbkBWAJQAbkBWAJQAbkDPAFmgAADMQFP
+ AWwB2QL/AScBnwH1Af8BhwHwAv8BgQHwAv8BgAHwAv8BeQHwAv8BdgHwAv8BcwHwAv8BcQHwAv8BbwHv
+ Av8BbQHvAv8BbAHvAf4B/wFZAlABvwFeAkoB2ggAA4EB/wOhAf8DqgH/A7EB/wOzAf8DrAH/A6IB/wOe
+ Af8DngH/A54B/wOeAf8DngH/A54B/wOhAf8BWwJOAcaAAAMxAU8BgQHjAv8BMgHKAfoB/wHhAfQB/gH/
+ AdsB9wH+Af8B2wH3Af4B/wHaAfcB/gH/AdgB+QH+Af8BmQH0Av8BlgH0Av8BkwH0Av8BkAH0Av8BjQHz
+ Af4B/wFZAlABvwFZAlABvwMjATQEAAOBAf8DgQH/A5AB/wOjAf8DsQH/A7EB/wOhAf8DjAH/A4cB/wOH
+ Af8DhwH/A4cB/wOHAf8DnAH/AVsCTgHGgAADMQFPAZIB7gL/AVQB5AL/AVQB5AL/AVQB5AL/AVQB5AL/
+ AVQB5AL/AUUBxgH3Af8B6gH5Af4B/wHmAfkB/gH/AeUB+QH+Af8B5AH5Af4B/wHjAfkB/gH/AYICYwHv
+ AYICYwHvAV0BSQFKAdcEAAOBAf8DgQH/A4MB/wOUAf8DpgH/A7IB/wOwAf8DnwH/A4wB/wOIAf8DiAH/
+ A4gB/wOIAf8DnAH/AVsCTgHGgAADMQFPAacB+AL/AXYB9QL/AXYB9QL/AXYB9QL/AXYB9QL/AXYB9QL/
+ AXYB9QL/AXYB9QL/AXYB9QL/AXYB9QL/AXYB9QL/AXMB8QH+Af8QAAOAAf8DgQH/A4EB/wOCAf8DgwH/
+ A4MB/wOCAf8DgQH/A4EB/wOBAf8DewH/A3kB/wN3Af8DdAH/AVsCTgHGgAADMQFPAcED/wGcA/8BnAP/
+ AZwD/wHWAf0B/gH/Ad8B+QH+Af8B3wH5Af4B/wHfAfkB/gH/Ad8B+QH+Af8B3wH5Af4B/wHfAfkB/gH/
+ AdAB8gH9Af/MAAMxAU8B6QP/AdwD/wHcA/8B3QP/AVgCUAG57AABQAI/AW8BQAI/AW8BQAI/AW8BQAI/
+ AW8DCAEL/wD/AP8A6wABQgFNAT4HAAE+AwABKAMAAUADAAEQAwABAQEAAQEFAAGAFwAD/wEABP8EAAGA
+ AQMC/wUAAQMC/wUAAQMC/wUAAQEC/wUAAQEBgAYAAQEBgAcAAYAHAAGABgABBwGABgABBwL/BAABAwP/
+ BAABgwP/BAAE/wQABP8EAAT/BAAL
</value>
</data>
+ <data name="label13.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <data name="label13.Location" type="System.Drawing.Point, System.Drawing">
+ <value>-3, 53</value>
+ </data>
+ <data name="label13.Size" type="System.Drawing.Size, System.Drawing">
+ <value>103, 13</value>
+ </data>
+ <data name="label13.TabIndex" type="System.Int32, mscorlib">
+ <value>18</value>
+ </data>
+ <data name="label13.Text" xml:space="preserve">
+ <value>Web Layout Version</value>
+ </data>
+ <data name=">>label13.Name" xml:space="preserve">
+ <value>label13</value>
+ </data>
+ <data name=">>label13.Type" xml:space="preserve">
+ </data>
+ <data name=">>label13.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label13.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="cmbVersion.Items" xml:space="preserve">
+ <value>1.0.0</value>
+ </data>
+ <data name="cmbVersion.Items1" xml:space="preserve">
+ <value>1.1.0</value>
+ </data>
+ <data name="cmbVersion.Location" type="System.Drawing.Point, System.Drawing">
+ <value>160, 50</value>
+ </data>
+ <data name="cmbVersion.Size" type="System.Drawing.Size, System.Drawing">
+ <value>77, 21</value>
+ </data>
+ <data name="cmbVersion.TabIndex" type="System.Int32, mscorlib">
+ <value>19</value>
+ </data>
+ <data name=">>cmbVersion.Name" xml:space="preserve">
+ <value>cmbVersion</value>
+ </data>
+ <data name=">>cmbVersion.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ComboBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>cmbVersion.Parent" xml:space="preserve">
+ </data>
+ <data name=">>cmbVersion.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="chkPingServer.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkPingServer.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkPingServer.Location" type="System.Drawing.Point, System.Drawing">
+ <value>254, 53</value>
+ </data>
+ <data name="chkPingServer.Size" type="System.Drawing.Size, System.Drawing">
+ <value>81, 17</value>
+ </data>
+ <data name="chkPingServer.TabIndex" type="System.Int32, mscorlib">
+ <value>20</value>
+ </data>
+ <data name="chkPingServer.Text" xml:space="preserve">
+ <value>Ping Server</value>
+ </data>
+ <data name=">>chkPingServer.Name" xml:space="preserve">
+ <value>chkPingServer</value>
+ </data>
+ <data name=">>chkPingServer.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkPingServer.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkPingServer.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
@@ -1947,7 +2445,7 @@
<value>552, 672</value>
</data>
<data name="$this.Size" type="System.Drawing.Size, System.Drawing">
- <value>552, 672</value>
+ <value>552, 707</value>
</data>
<data name=">>CommandTypesDataset.Name" xml:space="preserve">
<value>CommandTypesDataset</value>
Modified: trunk/Tools/Maestro/MaestroAPI/Generated/WebLayout-1.0.0.cs
--- trunk/Tools/Maestro/MaestroAPI/Generated/WebLayout-1.0.0.cs 2010-09-20 03:33:17 UTC (rev 5154)
+++ trunk/Tools/Maestro/MaestroAPI/Generated/WebLayout-1.0.0.cs 2010-09-20 06:03:53 UTC (rev 5155)
@@ -18,6 +18,7 @@
#endregion
+using System;
namespace OSGeo.MapGuide.MaestroAPI
@@ -25,14 +26,34 @@
/// <remarks/>
[System.Xml.Serialization.XmlRootAttribute("WebLayout", Namespace="", IsNullable=false)]
public class WebLayout {
+ [System.Xml.Serialization.XmlIgnore]
public static readonly string SchemaName = "WebLayout-1.0.0.xsd";
+ public static readonly string SchemaName1_1 = "WebLayout-1.1.0.xsd";
+ public static string [] ValidSchemaNames
+ get
+ return new string[] { SchemaName, SchemaName1_1 };
+ private string _xsdSchema = SchemaName;
[System.Xml.Serialization.XmlAttribute("noNamespaceSchemaLocation", Namespace="http://www.w3.org/2001/XMLSchema-instance")]
public string XsdSchema
- get { return SchemaName; }
- set { if (value != SchemaName) throw new System.Exception("Cannot set the schema name"); }
+ get { return _xsdSchema; }
+ set
+ if (Array.IndexOf(ValidSchemaNames, value) < 0)
+ throw new System.Exception("Cannot set the schema name");
+ _xsdSchema = value;
private string m_resourceId;
@@ -57,6 +78,7 @@
private string m_title;
private MapType m_map;
+ private string m_ping;
private ToolBarType m_toolBar;
private InformationPaneType m_informationPane;
private ContextMenuType m_contextMenu;
@@ -84,6 +106,30 @@
this.m_map = value;
+ [System.Xml.Serialization.XmlElement()]
+ public string EnablePingServer
+ get
+ if (this.XsdSchema == SchemaName1_1)
+ if (string.IsNullOrEmpty(m_ping))
+ m_ping = true.ToString();
+ return m_ping.ToLower();
+ return null;
+ set
+ if (value != null)
+ m_ping = value.ToLower();
+ else
+ m_ping = value;
/// <remarks/>
public ToolBarType ToolBar {
@@ -155,6 +201,24 @@
this.m_commandSet = value;
+ public void ConvertToVersion(System.Version version)
+ string xsd = "WebLayout-" + version.ToString() + ".xsd";
+ this.XsdSchema = xsd;
+ //Remove the EnablePingServer element if 1.0.0
+ if (version == new Version(1, 0, 0))
+ this.EnablePingServer = null;
+ public string GetVersion()
+ //x.y.z = 5 characters
+ return this.XsdSchema.Substring("WebLayout-".Length, 5);
/// <remarks/>
More information about the mapguide-commits
