[mapguide-commits] r5185 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Thu Sep 23 23:35:43 EDT 2010
Author: waltweltonlair
Date: 2010-09-24 03:35:43 +0000 (Fri, 24 Sep 2010)
New Revision: 5185
trunk/MgDev/Common/Stylization/StylizationEngine.cpp
Cleanup StylizationEngine::StylizeWatermark
* fix warnings
* fix lousy formatting
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2010-09-23 23:28:17 UTC (rev 5184)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2010-09-24 03:35:43 UTC (rev 5185)
@@ -236,15 +236,10 @@
-// THIS METHOD NEEDS TO BE CLEANED UP
-// ** unnecessary object creation using new (allocated n the stack instead)
-// ** compiler warnings being generated
void StylizationEngine::StylizeWatermark(SE_Renderer* se_renderer,
WatermarkDefinition* watermark,
- int drawWidth,
- int drawHeight,
- int saveWidth,
- int saveHeight)
+ int drawWidth, int drawHeight,
+ int saveWidth, int saveHeight)
m_serenderer = se_renderer;
m_reader = NULL;
@@ -262,7 +257,8 @@
SE_Rule rule;
// Translate watermark source into SE_SymbolInstance list.
- // As the source is adopted into symbol, we need to detach them after the rendering is done.
+ // As the source is adopted into symbol, we need to detach them after
+ // the rendering is done.
CompositeSymbolization symbols;
std::auto_ptr<SymbolInstance> instance(new SymbolInstance());
@@ -273,13 +269,12 @@
m_visitor->Convert(rule.symbolInstances, &symbols);
_ASSERT(rule.symbolInstances.size() == 1u);
- // Translate appearance (transparency / rotation) into symbol instance
- // Prepare values
+ // translate appearance (transparency / rotation) into symbol instance
double transparency = watermark->GetAppearance()->GetTransparency();
- transparency = (transparency < 0) ? 0 : ((transparency > 100) ? 100 : transparency);
- double opacity = 1 - transparency / 100;
+ transparency = (transparency < 0.0)? 0.0 : ((transparency > 100.0)? 100.0 : transparency);
+ double opacity = 1.0 - 0.01*transparency;
double rotation = watermark->GetAppearance()->GetRotation();
- rotation = (rotation < 0) ? 0 : ((rotation > 360) ? 360 : rotation);
+ rotation = (rotation < 0.0)? 0.0 : ((rotation > 360.0)? 360.0 : rotation);
SE_SymbolInstance* sym = rule.symbolInstances[0];
size_t nStyles = sym->styles.size();
@@ -287,9 +282,12 @@
SE_PointStyle* style = (SE_PointStyle*)(sym->styles[styleIx]);
style->angleDeg.value = style->angleDeg.defValue = style->angleDeg.defValue + rotation;
- if(style->symbol.size() == 0) continue;
+ if (style->symbol.size() == 0)
+ continue;
- if(1 - opacity < 0.0001) continue; //The opaque is 1.
+ if (opacity > 0.9999) // opaque is 1
+ continue;
size_t nPrimitives = style->symbol.size();
for (size_t primitiveIx=0; primitiveIx<nPrimitives; ++primitiveIx)
@@ -298,36 +296,28 @@
SE_Polygon* polygonPri = dynamic_cast<SE_Polygon*>(primitive);
SE_Polyline* linePri = dynamic_cast<SE_Polyline*>(primitive);
SE_Raster* rasterPri = dynamic_cast<SE_Raster*>(primitive);
- if(textPri)
+ if (textPri)
- //Text need to change color
- textPri->textColor.value.argb = textPri->textColor.defValue.argb
- = TransparentColor(textPri->textColor.defValue.argb, opacity);
- textPri->ghostColor.value.argb = textPri->ghostColor.defValue.argb
- = TransparentColor(textPri->ghostColor.defValue.argb, opacity);
- textPri->frameLineColor.value.argb = textPri->frameLineColor.defValue.argb
- = TransparentColor(textPri->frameLineColor.defValue.argb, opacity);
- textPri->frameFillColor.value.argb = textPri->frameFillColor.defValue.argb
- = TransparentColor(textPri->frameFillColor.defValue.argb, opacity);
+ // text needs to change color
+ textPri->textColor.value.argb = textPri->textColor.defValue.argb = TransparentColor(textPri->textColor.defValue.argb, opacity);
+ textPri->ghostColor.value.argb = textPri->ghostColor.defValue.argb = TransparentColor(textPri->ghostColor.defValue.argb, opacity);
+ textPri->frameLineColor.value.argb = textPri->frameLineColor.defValue.argb = TransparentColor(textPri->frameLineColor.defValue.argb, opacity);
+ textPri->frameFillColor.value.argb = textPri->frameFillColor.defValue.argb = TransparentColor(textPri->frameFillColor.defValue.argb, opacity);
- else if(linePri)
+ else if (linePri)
- linePri->color.value.argb = linePri->color.defValue.argb
- = TransparentColor(linePri->color.defValue.argb, opacity);
- if(polygonPri)
- polygonPri->fill.value.argb = polygonPri->fill.defValue.argb
- = TransparentColor(polygonPri->fill.defValue.argb, opacity);
+ linePri->color.value.argb = linePri->color.defValue.argb = TransparentColor(linePri->color.defValue.argb, opacity);
+ if (polygonPri)
+ polygonPri->fill.value.argb = polygonPri->fill.defValue.argb = TransparentColor(polygonPri->fill.defValue.argb, opacity);
- else if(rasterPri)
+ else if (rasterPri)
rasterPri->opacity = opacity;
- //Prepare some rendering context variable
+ // prepare some rendering context variable
double mm2sud = m_serenderer->GetScreenUnitsPerMillimeterDevice();
double mm2suw = m_serenderer->GetScreenUnitsPerMillimeterWorld();
double px2su = m_serenderer->GetScreenUnitsPerPixel();
@@ -336,46 +326,43 @@
// the factor to convert screen units to mapping units
double su2wu = 0.001 / (mm2suw * m_serenderer->GetMetersPerUnit());
- //Prepare the position list
+ // prepare the position list
XYWatermarkPosition* xyPosition = dynamic_cast<XYWatermarkPosition*>(watermark->GetPosition());
TileWatermarkPosition* tilePosition = dynamic_cast<TileWatermarkPosition*>(watermark->GetPosition());
WatermarkXOffset::HorizontalAlignment hAlignment = WatermarkXOffset::Center;
WatermarkYOffset::VerticalAlignment vAlignment = WatermarkYOffset::Center;
- WatermarkOffset::WatermarkOffsetUnit hUnit, vUnit;
- double suPerhUnit, suPervUnit, xOffset, yOffset;
- if(xyPosition)
+ WatermarkOffset::WatermarkOffsetUnit hUnit = WatermarkOffset::Pixels;
+ WatermarkOffset::WatermarkOffsetUnit vUnit = WatermarkOffset::Pixels;
+ double xOffset = 0.0;
+ double yOffset = 0.0;
+ if (xyPosition)
hAlignment = xyPosition->GetXPosition()->GetAlignment();
vAlignment = xyPosition->GetYPosition()->GetAlignment();
hUnit = xyPosition->GetXPosition()->GetUnit();
vUnit = xyPosition->GetYPosition()->GetUnit();
- xOffset = xyPosition->GetXPosition()->GetOffset(); //In watermark unit
- yOffset = xyPosition->GetYPosition()->GetOffset(); //In watermark unit
+ xOffset = xyPosition->GetXPosition()->GetOffset(); // in watermark units
+ yOffset = xyPosition->GetYPosition()->GetOffset(); // in watermark units
- else if(tilePosition)
+ else if (tilePosition)
hAlignment = tilePosition->GetHorizontalPosition()->GetAlignment();
vAlignment = tilePosition->GetVerticalPosition()->GetAlignment();
hUnit = tilePosition->GetHorizontalPosition()->GetUnit();
vUnit = tilePosition->GetVerticalPosition()->GetUnit();
- xOffset = tilePosition->GetHorizontalPosition()->GetOffset(); //In watermark unit
- yOffset = tilePosition->GetVerticalPosition()->GetOffset(); //In watermark unit
+ xOffset = tilePosition->GetHorizontalPosition()->GetOffset(); // in watermark units
+ yOffset = tilePosition->GetVerticalPosition()->GetOffset(); // in watermark units
- double pixelPerMeterDevice = 1000*mm2sud/px2su;
- suPerhUnit = ((hUnit == WatermarkOffset::Pixels)
- ? 1
- : pixelPerMeterDevice / GetUnitPerMeter(hUnit)) * px2su;
- suPervUnit = ((vUnit == WatermarkOffset::Pixels)
- ? 1
- : pixelPerMeterDevice / GetUnitPerMeter(vUnit)) * px2su;
- xOffset *= suPerhUnit; //In screen unit
- yOffset *= suPervUnit; //In screen unit
+ double pixelPerMeterDevice = 1000.0 * mm2sud / px2su;
+ double suPerhUnit = ((hUnit == WatermarkOffset::Pixels)? 1.0 : pixelPerMeterDevice / GetUnitPerMeter(hUnit)) * px2su;
+ double suPervUnit = ((vUnit == WatermarkOffset::Pixels)? 1.0 : pixelPerMeterDevice / GetUnitPerMeter(vUnit)) * px2su;
+ xOffset *= suPerhUnit; // in screen units
+ yOffset *= suPervUnit; // in screen units
std::vector<double> watermarkPosList;
- if(xyPosition)
+ if (xyPosition)
- switch(hAlignment)
+ switch (hAlignment)
case WatermarkXOffset::Right:
xOffset = saveWidth - xOffset;
@@ -383,21 +370,23 @@
case WatermarkXOffset::Left:
break;
default:
- xOffset += saveWidth/2;
+ xOffset += 0.5*saveWidth;
break;
- switch(vAlignment)
+ switch (vAlignment)
case WatermarkYOffset::Bottom:
- yOffset = yUp ? yOffset : saveHeight - yOffset;
+ yOffset = yUp? yOffset : saveHeight - yOffset;
break;
case WatermarkYOffset::Top:
- yOffset = yUp ? saveHeight - yOffset : yOffset;
+ yOffset = yUp? saveHeight - yOffset : yOffset;
break;
default:
- yOffset = saveHeight/2 + (yUp ? yOffset : (-yOffset));
+ yOffset = 0.5*saveHeight + (yUp? yOffset : -yOffset);
break;
xOffset *= drawWidth / saveWidth;
yOffset *= drawHeight / saveHeight;
double mapPosX, mapPosY;
@@ -405,11 +394,12 @@
watermarkPosList.push_back(mapPosX);
watermarkPosList.push_back(mapPosY);
- double tileWidth = tilePosition->GetTileWidth()*px2su,
- tileHeight = tilePosition->GetTileHeight()*px2su;
+ double tileWidth = tilePosition->GetTileWidth()*px2su;
+ double tileHeight = tilePosition->GetTileHeight()*px2su;
xOffset = tileWidth - xOffset;
@@ -417,28 +407,30 @@
break;
default:
- xOffset += tileWidth/2;
+ xOffset += 0.5*tileWidth;
break;
- yOffset = yUp ? yOffset : tileHeight - yOffset;
+ yOffset = yUp? yOffset : tileHeight - yOffset;
break;
- yOffset = yUp ? tileHeight - yOffset : yOffset;
+ yOffset = yUp? tileHeight - yOffset : yOffset;
break;
default:
- yOffset = tileHeight/2 + (yUp ? yOffset : (-yOffset));
+ yOffset = 0.5*tileHeight + (yUp? yOffset : -yOffset);
break;
double drawPosX, drawPosY, mapPosX, mapPosY;
- for(int i = 0; i<= (int)(saveWidth/tileWidth); i++)
+ for (int i=0; i<=(int)(saveWidth/tileWidth); ++i)
- for(int j = 0; j <= (int)(saveHeight/tileHeight); j++)
+ for (int j=0; j<=(int)(saveHeight/tileHeight); ++j)
drawPosX = i*tileWidth+xOffset;
- drawPosY = yUp ? (saveHeight-(j+1)*tileHeight+yOffset) : j*tileHeight+yOffset;
+ drawPosY = yUp? (saveHeight-(j+1)*tileHeight+yOffset) : j*tileHeight+yOffset;
m_serenderer->ScreenToWorldPoint(drawPosX, drawPosY, mapPosX, mapPosY);
@@ -470,8 +462,7 @@
for (size_t posIx=0; posIx<nPos; posIx+=2)
//Get geometry
- LineBuffer* lb = LineBufferPool::NewLineBuffer(
- m_pool, 8, FdoDimensionality_Z);
+ LineBuffer* lb = LineBufferPool::NewLineBuffer(m_pool, 8, FdoDimensionality_Z);
spLB.reset(lb);
lb->MoveTo(watermarkPosList[posIx], watermarkPosList[posIx+1]);
// tell line buffer the current drawing scale (used for arc tessellation)
@@ -604,41 +595,36 @@
bounds[2].y = bounds[3].y = rs_max(bounds[2].y, pt.y);
// bounds[0].x is left, bounds[1].x is right
- sym->absOffset[0].value = sym->absOffset[0].defValue
- = -bounds[1].x / mm2suX;
+ sym->absOffset[0].value = sym->absOffset[0].defValue = -bounds[1].x / mm2suX;
break;
- = -bounds[0].x / mm2suX;
+ sym->absOffset[0].value = sym->absOffset[0].defValue = -bounds[0].x / mm2suX;
break;
default:
- = -(bounds[0].x + bounds[1].x) / 2 / mm2suX;
+ sym->absOffset[0].value = sym->absOffset[0].defValue = -0.5*(bounds[0].x + bounds[1].x) / mm2suX;
break;
// bounds[1].y is bottom, bounds[2].y is top
- sym->absOffset[1].value = sym->absOffset[1].defValue
- = (yUp ? (-bounds[1].y) : bounds[1].y) / mm2suY;
+ sym->absOffset[1].value = sym->absOffset[1].defValue = (yUp? -1.0: 1.0) * bounds[1].y / mm2suY;
break;
- = (yUp ? (-bounds[2].y) : bounds[2].y) / mm2suY;
+ sym->absOffset[1].value = sym->absOffset[1].defValue = (yUp? -1.0: 1.0) * bounds[2].y / mm2suY;
break;
default:
- = (yUp ? -1: 1)*((bounds[1].y + bounds[2].y) / 2 / mm2suY);
+ sym->absOffset[1].value = sym->absOffset[1].defValue = (yUp? -1.0: 1.0) * 0.5*(bounds[1].y + bounds[2].y) / mm2suY;
break;
// prepare the geometry on which we will apply the styles
if (bClip)
// compute offset to apply to the clipping bounds
@@ -742,6 +728,7 @@
if(spLB.get())
LineBufferPool::FreeLineBuffer(m_pool, spLB.release());
// switch to the next symbol rendering pass
symbolRenderingPass = nextSymbolRenderingPass;
nextSymbolRenderingPass = -1;
More information about the mapguide-commits
