[mapguide-commits] r5226 - in trunk/MgDev:
Common/MapGuideCommon/Services Common/PlatformBase/Services
Server/src/Services/Feature Server/src/Wfs Web/src/HttpHandler
svn_mapguide at osgeo.org
Thu Sep 30 09:46:14 EDT 2010
Author: liuar
Date: 2010-09-30 13:46:14 +0000 (Thu, 30 Sep 2010)
New Revision: 5226
trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h
trunk/MgDev/Common/PlatformBase/Services/FeatureService.h
trunk/MgDev/Server/src/Services/Feature/OpGetWfsFeature.cpp
trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h
trunk/MgDev/Server/src/Wfs/1.1.0.xml.awd
trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp
Ticket #1450 Enhance the GetWfsFeature API to support customized namespaceUrl and namespacePrefix
In order to pass the OGC CITE test, MapGuide need to have its !GetWfsFeature API extended to support user defined namespaceUrl and namespacePrefix.
Two more parameters added in the the new interface: namespacePrefix and namespaceUrl
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp 2010-09-30 13:11:10 UTC (rev 5225)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp 2010-09-30 13:46:14 UTC (rev 5226)
@@ -1407,13 +1407,15 @@
INT32 maxFeatures,
CREFSTRING wfsVersion,
CREFSTRING outputFormat,
- CREFSTRING sortCriteria)
+ CREFSTRING sortCriteria,
+ CREFSTRING namespacePrefix,
+ CREFSTRING namespaceUrl)
MgCommand cmd;
cmd.ExecuteCommand(m_connProp, // Connection
MgCommand::knObject, // Return type expected
MgFeatureServiceOpId::GetWfsFeature_Id, // Command Code
- 9, // No of arguments
+ 11, // No of arguments
Feature_Service, // Service Id
BUILD_VERSION(2,3,0), // Operation version
MgCommand::knObject, featureSourceId, // Argument#1
@@ -1425,6 +1427,8 @@
MgCommand::knString, &wfsVersion, // Argument#7
MgCommand::knString, &outputFormat, // Argument#8
MgCommand::knString, &sortCriteria, // Argument#9
+ MgCommand::knString, &namespacePrefix, // Argument#10
+ MgCommand::knString, &namespaceUrl, // Argument#11
MgCommand::knNone); // End of argument
SetWarning(cmd.GetWarningObject());
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h 2010-09-30 13:11:10 UTC (rev 5225)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h 2010-09-30 13:46:14 UTC (rev 5226)
@@ -1106,13 +1106,13 @@
/// <!-- Syntax in .Net, Java, and PHP -->
/// \htmlinclude DotNetSyntaxTop.html
- /// virtual MgByteReader GetWfsFeature(MgResourceIdentifier featureSourceId, string featureClass, MgStringCollection requiredProperties, string srs, string filter, int maxFeatures, string wfsVersion, string outputFormat, string sortCriteria);
+ /// virtual MgByteReader GetWfsFeature(MgResourceIdentifier featureSourceId, string featureClass, MgStringCollection requiredProperties, string srs, string filter, int maxFeatures, string wfsVersion, string outputFormat, string sortCriteria, string namespacePrefix, string namespaceUrl);
/// \htmlinclude SyntaxBottom.html
/// \htmlinclude JavaSyntaxTop.html
/// \htmlinclude PHPSyntaxTop.html
/// \param featureSourceId (MgResourceIdentifier)
@@ -1140,6 +1140,10 @@
/// http://portal.opengeospatial.org/files/?artifact_id=8339
/// \param sortCriteria (String/string)
/// A string identifying the sort criteria
+ /// \param namespacePrefix (String/string)
+ /// A string identifying the namespace prefix in the output xml
+ /// \param namespaceUrl (String/string)
+ /// A string idenyifying the namespace url in the output xml
/// \return
/// Returns an MgByteReader containing the requested feature information.
@@ -1148,7 +1152,7 @@
/// \exception MgInvalidArgumentException
MgByteReader* GetWfsFeature(MgResourceIdentifier* featureSourceId, CREFSTRING featureClass,
- MgStringCollection* requiredProperties, CREFSTRING srs, CREFSTRING filter, INT32 maxFeatures,CREFSTRING wfsVersion, CREFSTRING outputFormat, CREFSTRING sortCriteria);
+ MgStringCollection* requiredProperties, CREFSTRING srs, CREFSTRING filter, INT32 maxFeatures,CREFSTRING wfsVersion, CREFSTRING outputFormat, CREFSTRING sortCriteria, CREFSTRING namespacePrefix, CREFSTRING namespaceUrl);
/// \brief
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureService.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureService.h 2010-09-30 13:11:10 UTC (rev 5225)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureService.h 2010-09-30 13:46:14 UTC (rev 5226)
@@ -1610,13 +1610,13 @@
@@ -1644,6 +1644,10 @@
/// \return
@@ -1651,7 +1655,7 @@
virtual MgByteReader* GetWfsFeature(MgResourceIdentifier* featureSourceId, CREFSTRING featureClass,
- MgStringCollection* requiredProperties, CREFSTRING srs, CREFSTRING filter, INT32 maxFeatures,CREFSTRING wfsVersion, CREFSTRING outputFormat, CREFSTRING sortCriteria) = 0;
+ MgStringCollection* requiredProperties, CREFSTRING srs, CREFSTRING filter, INT32 maxFeatures,CREFSTRING wfsVersion, CREFSTRING outputFormat, CREFSTRING sortCriteria, CREFSTRING namespacePrefix, CREFSTRING namespaceUrl) = 0;
/// \brief
Modified: trunk/MgDev/Server/src/Services/Feature/OpGetWfsFeature.cpp
--- trunk/MgDev/Server/src/Services/Feature/OpGetWfsFeature.cpp 2010-09-30 13:11:10 UTC (rev 5225)
+++ trunk/MgDev/Server/src/Services/Feature/OpGetWfsFeature.cpp 2010-09-30 13:46:14 UTC (rev 5226)
@@ -111,7 +111,7 @@
// Write the response
EndExecution(byteReader);
- else if (9 == m_packet.m_NumArguments)
+ else if (11 == m_packet.m_NumArguments)
// Get the feature source
Ptr<MgResourceIdentifier> featureSourceId = (MgResourceIdentifier*)m_stream->GetObject();
@@ -147,6 +147,14 @@
STRING sortCriteria;
m_stream->GetString(sortCriteria);
+ // Get the namespace prefix
+ STRING namespacePrefix;
+ m_stream->GetString(namespacePrefix);
+ // Get the namespace url
+ STRING namespaceUrl;
+ m_stream->GetString(namespaceUrl);
BeginExecution();
MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
@@ -167,13 +175,17 @@
MG_LOG_OPERATION_MESSAGE_ADD_STRING(outputFormat.c_str());
MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
MG_LOG_OPERATION_MESSAGE_ADD_STRING(sortCriteria.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(namespacePrefix.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(namespaceUrl.c_str());
MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
Validate();
// Execute the operation
Ptr<MgByteReader> byteReader = m_service->GetWfsFeature(featureSourceId, featureClass,
- requiredProperties, srs, filter, maxFeatures, wfsVersion, outputFormat, sortCriteria);
+ requiredProperties, srs, filter, maxFeatures, wfsVersion, outputFormat, sortCriteria, namespacePrefix, namespaceUrl);
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp 2010-09-30 13:11:10 UTC (rev 5225)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp 2010-09-30 13:46:14 UTC (rev 5226)
@@ -1700,13 +1700,13 @@
-/// virtual MgByteReader GetWfsFeature(MgResourceIdentifier featureSourceId, string featureClass, MgStringCollection requiredProperties, string srs, string filter, int maxFeatures, string wfsVersion, string outputFormat, string sortCriteria);
+/// virtual MgByteReader GetWfsFeature(MgResourceIdentifier featureSourceId, string featureClass, MgStringCollection requiredProperties, string srs, string filter, int maxFeatures, string wfsVersion, string outputFormat, string sortCriteria, string namespacePrefix, string namespaceUrl);
@@ -1734,6 +1734,10 @@
+/// \param namespacePrefix (String/string)
+/// A string identifying the namespace prefix in the output xml
+/// \param namespaceUrl (String/string)
+/// A string idenyifying the namespace url in the output xml
/// \return
@@ -1748,7 +1752,9 @@
INT32 maxFeatures,
MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetWfsFeature()");
@@ -1920,9 +1926,22 @@
// default namespace schema location
flags->SetSchemaLocation(L"http://www.mynamespace.com/myns", L"http://www.mynamespace.com/myns/myns.xsd");
// set the default namespace
- flags->SetDefaultNamespace(L"http://www.mynamespace.com/myns");
+ if(!namespacePrefix.empty())
+ STRING defaultNamespace(L"http://fdo.osgeo.org/schemas/feature/");
+ defaultNamespace += namespacePrefix;
+ flags->SetDefaultNamespace(defaultNamespace.c_str());
+ else
+ flags->SetDefaultNamespace(L"http://www.mynamespace.com/myns");
//create the FDO xml serializer stack and write out the features
FdoPtr<FdoXmlWriter> xmlWriter = FdoXmlWriter::Create(fileName.c_str(), false);
FdoPtr<FdoXmlFeaturePropertyWriter> propWriter = FdoXmlFeaturePropertyWriter::Create(xmlWriter,flags);
@@ -1960,7 +1979,7 @@
CREFSTRING wfsFilter,
INT32 maxFeatures)
- return GetWfsFeature(fs, featureClass, propNames, srs, wfsFilter, maxFeatures, L"1.0.0", L"text/xml; subtype=gml/2.1.2",L"");
+ return GetWfsFeature(fs, featureClass, propNames, srs, wfsFilter, maxFeatures, L"1.0.0", L"text/xml; subtype=gml/2.1.2", L"", L"", L"");
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h 2010-09-30 13:11:10 UTC (rev 5225)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h 2010-09-30 13:46:14 UTC (rev 5226)
@@ -915,6 +915,12 @@
/// <param name="sortCriteria">Input
/// </param>
+ /// <param name="namespacePrefix">Input
+ /// </param>
+ /// <param name="namespaceUrl">Input
+ /// A string identifying the namespace url in the output xml
+ /// </param>
/// <returns>
/// </returns>
@@ -922,7 +928,7 @@
/// EXCEPTIONS:
/// MgInvalidArgumentException
- MgStringCollection* requiredProperties, CREFSTRING srs, CREFSTRING filter, INT32 maxFeatures, CREFSTRING wfsVersion, CREFSTRING outputFormat, CREFSTRING sortCriteria);
+ MgStringCollection* requiredProperties, CREFSTRING srs, CREFSTRING filter, INT32 maxFeatures, CREFSTRING wfsVersion, CREFSTRING outputFormat, CREFSTRING sortCriteria, CREFSTRING namespacePrefix, CREFSTRING namespaceUrl);
/// This method has been deprecated. Use the above method.
Modified: trunk/MgDev/Server/src/Wfs/1.1.0.xml.awd
--- trunk/MgDev/Server/src/Wfs/1.1.0.xml.awd 2010-09-30 13:11:10 UTC (rev 5225)
+++ trunk/MgDev/Server/src/Wfs/1.1.0.xml.awd 2010-09-30 13:46:14 UTC (rev 5226)
@@ -91,13 +91,9 @@
</Define>
<Define item="DescribeFeature.Import.xml">
- <xs:import schemaLocation="&Url.DescribeFeatureType;?OPERATION=DESCRIBEFEATURESCHEMA&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library://&Enum.item;.FeatureSource&SCHEMA="/>
+ <xs:import schemaLocation="&Url.DescribeFeatureType;?request=DescribeFeatureType&service=WFS&version=1.1.0&typeName=&Feature.Prefix;:&Enum.item;"/>
</Define>
- <Define item="DescribeFeature.Import.xml">
- </Define>
<Define item="GetFeature.xml">
<!-- Feature &Feature.iteration; -->
&Feature.OuterXml;
Modified: trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp 2010-09-30 13:11:10 UTC (rev 5225)
+++ trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp 2010-09-30 13:46:14 UTC (rev 5226)
@@ -234,7 +234,7 @@
// Call the C++ API
Ptr<MgByteReader> resultReader = featureService->GetWfsFeature(featureSourceId, ((sSchemaHash.size()==0) ? sClass : sSchemaHash + _(":") + sClass),
- requiredProperties, m_getFeatureParams->GetSrs(), filter, numFeaturesToRetrieve, sVersion, sOutputFormat,sSortCriteria);
+ requiredProperties, m_getFeatureParams->GetSrs(), filter, numFeaturesToRetrieve, sVersion, sOutputFormat, sSortCriteria, sPrefix, L"");
// TODO How to determine number of features retrieved...?
// Note: for now, maxFeatures is managed by the MgWfsFeatures object. - TMT 2006-3-20
More information about the mapguide-commits
