[mapguide-commits] r5674 - in trunk/Tools/Maestro/Maestro.Editors:
FeatureSource/Providers/Odbc Properties
svn_mapguide at osgeo.org
Mon Apr 4 10:30:25 EDT 2011
Author: jng
Date: 2011-04-04 07:30:25 -0700 (Mon, 04 Apr 2011)
New Revision: 5674
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
#1640: Ensure that a valid connection is set (via testing) before configuring the schema or resetting the configuration document.
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs 2011-04-04 14:12:34 UTC (rev 5673)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs 2011-04-04 14:30:25 UTC (rev 5674)
@@ -208,6 +208,12 @@
private void btnEditSchema_Click(object sender, EventArgs e)
+ if (string.IsNullOrEmpty(_fs.ConnectionString))
+ MessageBox.Show(Properties.Resources.NoConnectionSet);
+ return;
if (string.IsNullOrEmpty(_defaultSchemaName))
var names = _fs.GetSchemaNames();
@@ -274,6 +280,12 @@
private void btnReset_Click(object sender, EventArgs e)
+ return;
_fs.SetConfigurationContent(null);
_fs.ConfigurationDocument = null;
_service.SyncSessionCopy();
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-04-04 14:12:34 UTC (rev 5673)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-04-04 14:30:25 UTC (rev 5674)
@@ -1852,6 +1852,15 @@
/// <summary>
+ /// Looks up a localized string similar to Could not determine the validity of this feature source. Please test the connection first to ensure a valid connection..
+ /// </summary>
+ internal static string NoConnectionSet {
+ get {
+ return ResourceManager.GetString("NoConnectionSet", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to You have not selected a starting folder, do you want to back up the entire site?.
/// </summary>
internal static string NoFolderSelected {
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-04-04 14:12:34 UTC (rev 5673)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-04-04 14:30:25 UTC (rev 5674)
@@ -1154,4 +1154,7 @@
<data name="TitleNewFeatureClass" xml:space="preserve">
<value>New Feature Class</value>
</data>
+ <data name="NoConnectionSet" xml:space="preserve">
+ <value>Could not determine the validity of this feature source. Please test the connection first to ensure a valid connection.</value>
+ </data>
</root>
\ No newline at end of file
More information about the mapguide-commits
