[mapguide-commits] r5707 - in trunk/Tools/Maestro: Maestro Maestro.Editors/FeatureSource/Providers/Odbc Maestro.Editors/Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Apr 19 07:37:07 EDT 2011
Author: jng
Date: 2011-04-19 04:37:07 -0700 (Tue, 19 Apr 2011)
New Revision: 5707
   trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
   trunk/Tools/Maestro/Maestro/changelog.txt
ODBC Editor: Remove the stopgap measure of requiring a manual connection test before editing the schema or resetting it. This submission makes the connection test automatic, aborting the schema edit/reset if the connection does not check out
Also update the changelog
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt	2011-04-19 06:28:35 UTC (rev 5706)
+++ trunk/Tools/Maestro/Maestro/changelog.txt	2011-04-19 11:37:07 UTC (rev 5707)
@@ -1,4 +1,19 @@
- - Add F2 keybinding to rename selected item in Site Explorer
+3.0 RC1
+ - Fix: Automatically test the connection first before editing or resetting an ODBC configuration document. Abort the process if connection test fails.
+ - Add an option to determine whether to validate resources on save
+ - Fix: Web Layout and Fusion editors didn't show the generated publish URL
+ - Fix: Layer Definition editor did not update the underlying XML content when deleting a vector scale range.
+ - Fix: Adding a new vector scale range in the Layer Definition editor did not create a default area/line/point rule
+ - Fix: When the "Show Area/Line/Point style checkbox is ticked, the Layer Definition editor would always create a new default rule
+ - Fix: Add missing coordinate system override functionality from 2.x
+ - Fix: Editors not re-initializing themselves properly after saving, when using Edit As XML command.
+ - Added more labels for main toolbar commands
+ - XML Editor: Add support for validating XML content against local XSD files
+ - Inactive document tabs are now colored differently to distinguish between active/inactive tabs
+ - Fix: Add missing find/replace in XML content functionality
+ - Add F2 keybinding to rename selected item in Site Explorer
  - Fix: Added missing duplicate resource command from 2.x
  - Fix: Added missing profiling feature from 2.x
  - Fix: UI layout changes for Generic Feature Source Editor
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs	2011-04-19 06:28:35 UTC (rev 5706)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs	2011-04-19 11:37:07 UTC (rev 5707)
@@ -206,52 +206,73 @@
         //This is ODBC, so there will only be one
         private string _defaultSchemaName;
-        private void btnEditSchema_Click(object sender, EventArgs e)
+        private bool CheckValidConnection()
             if (string.IsNullOrEmpty(_fs.ConnectionString))
-                MessageBox.Show(Properties.Resources.NoConnectionSet);
-                return;
-            if (string.IsNullOrEmpty(_defaultSchemaName))
-                var names = _fs.GetSchemaNames();
-                if (names.Length == 1)
+                if (this.ChildEditor != null)
-                    _defaultSchemaName = names[0];
+                    var props = this.ChildEditor.ConnectionProperties;
+                    _fs.ApplyConnectionProperties(props);
-                else
-                    MessageBox.Show(Properties.Resources.NoSchemasInFeatureSource);
-                    return;
-            string xml = _fs.GetConfigurationContent();
-            if (!string.IsNullOrEmpty(xml))
+            //Flush back to session before testing
+            _service.SyncSessionCopy();
+            string result = _fs.TestConnection();
+            if (!result.ToLower().Equals("true"))
-                _doc = (OdbcConfigurationDocument)ConfigurationDocument.LoadXml(xml);
+                MessageBox.Show(string.Format(Properties.Resources.InvalidConnection, result), Properties.Resources.TitleError);
+                return false;
-            else
+            return true;
+        private void btnEditSchema_Click(object sender, EventArgs e)
+            if (CheckValidConnection())
-                if (_doc == null)
+                if (string.IsNullOrEmpty(_defaultSchemaName))
-                    BuildDefaultDocument();
+                    var names = _fs.GetSchemaNames();
+                    if (names.Length == 1)
+                        _defaultSchemaName = names[0];
+                    else
+                        MessageBox.Show(Properties.Resources.NoSchemasInFeatureSource);
+                        return;
-            var diag = new TableConfigurationDialog(_doc, _defaultSchemaName);
-            if (diag.ShowDialog() == DialogResult.OK)
-                _doc.ClearMappings();
-                foreach (var table in diag.ConfiguredTables)
+                string xml = _fs.GetConfigurationContent();
+                if (!string.IsNullOrEmpty(xml))
-                    _doc.AddOverride(table);
+                    _doc = (OdbcConfigurationDocument)ConfigurationDocument.LoadXml(xml);
-                string updatedContent = _doc.ToXml();
-                _fs.SetConfigurationContent(updatedContent);
-                OnResourceChanged();
+                else
+                    if (_doc == null)
+                        BuildDefaultDocument();
+                var diag = new TableConfigurationDialog(_doc, _defaultSchemaName);
+                if (diag.ShowDialog() == DialogResult.OK)
+                    _doc.ClearMappings();
+                    foreach (var table in diag.ConfiguredTables)
+                        _doc.AddOverride(table);
+                    string updatedContent = _doc.ToXml();
+                    _fs.SetConfigurationContent(updatedContent);
+                    OnResourceChanged();
@@ -280,17 +301,14 @@
         private void btnReset_Click(object sender, EventArgs e)
-            if (string.IsNullOrEmpty(_fs.ConnectionString))
-                return;
+                _fs.SetConfigurationContent(null);
+                _fs.ConfigurationDocument = null;
+                MessageBox.Show(Properties.Resources.ConfigurationDocumentReset);
-            _fs.SetConfigurationContent(null);
-            _fs.ConfigurationDocument = null;
-            _service.SyncSessionCopy();
-            MessageBox.Show(Properties.Resources.ConfigurationDocumentReset);
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs	2011-04-19 06:28:35 UTC (rev 5706)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs	2011-04-19 11:37:07 UTC (rev 5707)
@@ -1568,6 +1568,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to This is not a valid connection: {0}.
+        /// </summary>
+        internal static string InvalidConnection {
+            get {
+                return ResourceManager.GetString("InvalidConnection", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Invalid field count in line {0}.
         /// </summary>
         internal static string InvalidFieldCountError {
@@ -1852,15 +1861,6 @@
         /// <summary>
-        ///   Looks up a localized string similar to Could not determine the validity of this feature source. Please test the connection first to ensure a valid connection..
-        /// </summary>
-        internal static string NoConnectionSet {
-            get {
-                return ResourceManager.GetString("NoConnectionSet", resourceCulture);
-        /// <summary>
         ///   Looks up a localized string similar to You have not selected a starting folder, do you want to back up the entire site?.
         /// </summary>
         internal static string NoFolderSelected {
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx	2011-04-19 06:28:35 UTC (rev 5706)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx	2011-04-19 11:37:07 UTC (rev 5707)
@@ -1154,9 +1154,6 @@
   <data name="TitleNewFeatureClass" xml:space="preserve">
     <value>New Feature Class</value>
   </data>
-  <data name="NoConnectionSet" xml:space="preserve">
-    <value>Could not determine the validity of this feature source. Please test the connection first to ensure a valid connection.</value>
-  </data>
   <data name="PreviewUrlNotAvailable" xml:space="preserve">
     <value>The Preview URL is not currently available</value>
   </data>
@@ -1166,4 +1163,7 @@
   <data name="TitleQuestion" xml:space="preserve">
     <value>Question</value>
   </data>
+  <data name="InvalidConnection" xml:space="preserve">
+    <value>This is not a valid connection: {0}</value>
+  </data>
 </root>
\ No newline at end of file
More information about the mapguide-commits mailing list
