[mapguide-commits] r5715 - in trunk/Tools/Maestro/Maestro.Base: .
	Editor
    svn_mapguide at osgeo.org
    Thu Apr 21 09:57:00 EDT 2011
Author: jng
Date: 2011-04-21 06:57:00 -0700 (Thu, 21 Apr 2011)
New Revision: 5715
Added:
   trunk/Tools/Maestro/Maestro.Base/Editor/UnsupportedEditorControl.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/UnsupportedEditorControl.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/UnsupportedEditorControl.resx
   trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
#1668: Show a placeholder prompting to use the XML editor when opening a DWG or Raster load procedure
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.cs	2011-04-21 06:45:58 UTC (rev 5714)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.cs	2011-04-21 13:57:00 UTC (rev 5715)
@@ -25,6 +25,7 @@
 using System.Text;
 using System.Windows.Forms;
 using Maestro.Editors.LoadProcedure;
+using OSGeo.MapGuide.ObjectModels.LoadProcedure;
 namespace Maestro.Base.Editor
@@ -38,12 +39,23 @@
         protected override void Bind(Maestro.Editors.IEditorService service)
             panelBody.Controls.Clear();
+            var lp = (ILoadProcedure)service.GetEditedResource();
+            //DWG and Raster load procedures cannot be edited with this editor so load placeholder
+            if (lp.SubType.Type == LoadType.Dwg ||
+                lp.SubType.Type == LoadType.Raster)
+                var ctrl = new UnsupportedEditorControl();
+                ctrl.Dock = DockStyle.Fill;
+                panelBody.Controls.Add(ctrl);
+            else
+                var lpEditor = new LoadProcedureEditorCtrl();
+                lpEditor.Dock = DockStyle.Fill;
+                panelBody.Controls.Add(lpEditor);
-            var lpEditor = new LoadProcedureEditorCtrl();
-            lpEditor.Dock = DockStyle.Fill;
-            panelBody.Controls.Add(lpEditor);
-            lpEditor.Bind(service);
+                lpEditor.Bind(service);
Added: trunk/Tools/Maestro/Maestro.Base/Editor/UnsupportedEditorControl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/UnsupportedEditorControl.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/UnsupportedEditorControl.Designer.cs	2011-04-21 13:57:00 UTC (rev 5715)
@@ -0,0 +1,54 @@
+namespace Maestro.Base.Editor
+    partial class UnsupportedEditorControl
+        /// <summary>
+        /// Required designer variable.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Clean up any resources being used.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing && (components != null))
+                components.Dispose();
+            base.Dispose(disposing);
+        #region Component Designer generated code
+        /// <summary>
+        /// Required method for Designer support - do not modify
+        /// the contents of this method with the code editor.
+        /// </summary>
+        private void InitializeComponent()
+            System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(UnsupportedEditorControl));
+            this.label1 = new System.Windows.Forms.Label();
+            this.SuspendLayout();
+            // label1
+            resources.ApplyResources(this.label1, "label1");
+            this.label1.Name = "label1";
+            // UnsupportedEditorControl
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+            this.Controls.Add(this.label1);
+            this.Name = "UnsupportedEditorControl";
+            resources.ApplyResources(this, "$this");
+            this.ResumeLayout(false);
+        #endregion
+        private System.Windows.Forms.Label label1;
Added: trunk/Tools/Maestro/Maestro.Base/Editor/UnsupportedEditorControl.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/UnsupportedEditorControl.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/UnsupportedEditorControl.cs	2011-04-21 13:57:00 UTC (rev 5715)
@@ -0,0 +1,40 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Text;
+using System.Windows.Forms;
+    /// <summary>
+    /// A placeholder control for resource sub-types that cannot be edited with a specialized editor
+    /// </summary>
+    public partial class UnsupportedEditorControl : UserControl
+        public UnsupportedEditorControl()
+            InitializeComponent();
Added: trunk/Tools/Maestro/Maestro.Base/Editor/UnsupportedEditorControl.resx
--- trunk/Tools/Maestro/Maestro.Base/Editor/UnsupportedEditorControl.resx	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/UnsupportedEditorControl.resx	2011-04-21 13:57:00 UTC (rev 5715)
@@ -0,0 +1,165 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="label1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+    <value>Fill</value>
+  </data>
+  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+    <value>0, 0</value>
+  </data>
+  <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+    <value>454, 189</value>
+  </data>
+  <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="label1.TabIndex" type="System.Int32, mscorlib">
+    <value>0</value>
+  </data>
+  <data name="label1.Text" xml:space="preserve">
+    <value>This specialized editor does not support editing this type of resource. If you wish to edit this resource, use the "Open Resource with XML editor" command from the Site Explorer</value>
+  </data>
+  <data name="label1.TextAlign" type="System.Drawing.ContentAlignment, System.Drawing">
+    <value>MiddleCenter</value>
+  </data>
+  <data name=">>label1.Name" xml:space="preserve">
+    <value>label1</value>
+  </data>
+  <data name=">>label1.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>label1.Parent" xml:space="preserve">
+    <value>$this</value>
+  </data>
+  <data name=">>label1.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
+  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+    <value>True</value>
+  </metadata>
+  <data name="$this.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name=">>$this.Name" xml:space="preserve">
+    <value>UnsupportedEditorControl</value>
+  </data>
+  <data name=">>$this.Type" xml:space="preserve">
+    <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj	2011-04-21 06:45:58 UTC (rev 5714)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj	2011-04-21 13:57:00 UTC (rev 5715)
@@ -191,6 +191,12 @@
     <Compile Include="Editor\SymbolDefinitionEditor.Designer.cs">
       <DependentUpon>SymbolDefinitionEditor.cs</DependentUpon>
     </Compile>
+    <Compile Include="Editor\UnsupportedEditorControl.cs">
+      <SubType>UserControl</SubType>
+    </Compile>
+    <Compile Include="Editor\UnsupportedEditorControl.Designer.cs">
+      <DependentUpon>UnsupportedEditorControl.cs</DependentUpon>
+    </Compile>
     <Compile Include="Editor\WebLayoutEditor.cs">
     </Compile>
@@ -458,6 +464,9 @@
     <EmbeddedResource Include="Editor\SymbolDefinitionEditor.resx">
     </EmbeddedResource>
+    <EmbeddedResource Include="Editor\UnsupportedEditorControl.resx">
+    </EmbeddedResource>
     <EmbeddedResource Include="Editor\WebLayoutEditor.resx">
       <DependentUpon>WebLayoutEditor.cs</DependentUpon>
     </EmbeddedResource>
More information about the mapguide-commits
