[mapguide-commits] r6048 - in trunk/MgDev:
Common/MapGuideCommon/Services Common/MapGuideCommon/Util
Common/PlatformBase/MapLayer Oem/ACE/ACE_wrappers/ace
Server/src/Common Server/src/Common/Manager Server/src/Core
Web/src/mapviewerjava Web/src/mapviewernet Web/src/mapviewerphp
svn_mapguide at osgeo.org
Tue Aug 9 02:21:33 EDT 2011
Author: liuar
Date: 2011-08-08 23:21:33 -0700 (Mon, 08 Aug 2011)
New Revision: 6048
trunk/MgDev/Common/MapGuideCommon/Services/SiteInfo.cpp
trunk/MgDev/Common/MapGuideCommon/Services/SiteInfo.h
trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp
trunk/MgDev/Common/MapGuideCommon/Util/IpUtil.cpp
trunk/MgDev/Common/MapGuideCommon/Util/IpUtil.h
trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h
trunk/MgDev/Oem/ACE/ACE_wrappers/ace/config-linux.h
trunk/MgDev/Oem/ACE/ACE_wrappers/ace/config-win32.h
trunk/MgDev/Server/src/Common/Manager/SessionCache.cpp
trunk/MgDev/Server/src/Common/stdafx.h
trunk/MgDev/Server/src/Core/Server.cpp
trunk/MgDev/Web/src/mapviewerjava/common.jsp
trunk/MgDev/Web/src/mapviewerjava/quickplotgeneratepicture.jsp
trunk/MgDev/Web/src/mapviewernet/common.aspx
trunk/MgDev/Web/src/mapviewernet/quickplotgeneratepicture.aspx
trunk/MgDev/Web/src/mapviewerphp/common.php
trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php
Submit on behalf of Mars Wu
Implements RFC 118 - IPv6 Support
Ticket: http://trac.osgeo.org/mapguide/ticket/1767
Modified: trunk/MgDev/Common/MapGuideCommon/Services/SiteInfo.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/SiteInfo.cpp 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Common/MapGuideCommon/Services/SiteInfo.cpp 2011-08-09 06:21:33 UTC (rev 6048)
@@ -15,6 +15,7 @@
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include "MapGuideCommon.h"
+#include "Base64.h"
MG_IMPL_DYNCREATE(MgSiteInfo);
@@ -60,22 +61,30 @@
m_adminPort(0),
m_target(L""),
m_status(Uninitialized)
- if(hexString.length() >= HexStringLength)
- UINT32 n1, n2, n3, n4;
+ // Compose a format string to extract the target address and the ports from the hexstring
+ INT32 targetlen = (INT32) hexString.length() - HexPortsStringLength;
+ wchar_t format[20] = {0};
+ swprintf(format, 20, L"%%%ds%%4X%%4X%%4X", targetlen);
- // Read the IP parts into their variables
- if(::swscanf(hexString.c_str(), L"%2X%2X%2X%2X%4X%4X%4X", &n1, &n2, &n3, &n4, &m_sitePort, &m_clientPort, &m_adminPort) == 7)
+ wchar_t targetHex[100] = {0};
+ if (::swscanf(hexString.c_str(), format, targetHex, &m_sitePort, &m_clientPort, &m_adminPort) == 4)
- // Write the 4 'n' values into an IP string
- wchar_t buffer[20];
- swprintf(buffer, 20, L"%u.%u.%u.%u", n1, n2, n3, n4);
- m_target = buffer;
+ char buffer[100] = {0};
+ INT32 hexLength = targetlen;
+ STRING targetHexOriginal = targetHex;
+ // There were alignment "=" removed. They should be appended back to do decoding
+ if (0 != targetlen % 4)
+ targetHexOriginal.append(L"===");
+ hexLength = 4 * (targetlen / 4 + 1);
+ Base64::Decode((unsigned char*)buffer, ACE_Wide_To_Ascii(targetHexOriginal.c_str()).char_rep(), hexLength);
+ m_target = ACE_Ascii_To_Wide(buffer).wchar_rep();
m_status = Ok;
/// <summary>
@@ -141,15 +150,20 @@
/// </summary>
STRING MgSiteInfo::ToHexString()
- STRING hexString;
- wchar_t buffer[30];
- if (4 == ::swscanf(m_target.c_str(), L"%u.%u.%u.%u", &n1, &n2, &n3, &n4))
+ char buf[100] = {0};
+ Base64::Encode(buf, (unsigned char*)ACE_Wide_To_Ascii(m_target.c_str()).char_rep(), (unsigned long) m_target.length());
+ // Remove the alignment "="
+ STRING targetHex = ACE_Ascii_To_Wide(buf).wchar_rep();
+ if (targetHex.find(L"=") != targetHex.npos)
- swprintf(buffer, 30, L"%.2X%.2X%.2X%.2X%.4X%.4X%.4X", n1, n2, n3, n4, m_sitePort, m_clientPort, m_adminPort);
- hexString = buffer;
+ targetHex = targetHex.substr(0, targetHex.find(L"="));
- return hexString;
+ wchar_t buffer[100] = {0};
+ swprintf(buffer, 100, L"%s%.4X%.4X%.4X", targetHex.c_str(), m_sitePort, m_clientPort, m_adminPort);
+ return STRING(buffer);
@@ -208,3 +222,4 @@
Modified: trunk/MgDev/Common/MapGuideCommon/Services/SiteInfo.h
--- trunk/MgDev/Common/MapGuideCommon/Services/SiteInfo.h 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Common/MapGuideCommon/Services/SiteInfo.h 2011-08-09 06:21:33 UTC (rev 6048)
@@ -15,6 +15,7 @@
#ifndef MG_SITEINFO_H_
#define MG_SITEINFO_H_
@@ -81,7 +82,8 @@
// Retrieve a hex string that encodes the site info connection params
STRING ToHexString();
- static const INT32 HexStringLength = 20;
+ // The length of the hexstring where the port numbers of admin, client and site are encoded
+ static const INT32 HexPortsStringLength = 12;
protected:
Modified: trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp 2011-08-09 06:21:33 UTC (rev 6048)
@@ -322,23 +322,19 @@
size_t length = sessionId.length();
- if (length > MgSiteInfo::HexStringLength)
+ STRING siteHexString = sessionId.substr(sessionId.rfind(L"_") + 1);
+ Ptr<MgSiteInfo> siteInfo = GetSiteInfo(siteHexString);
+ if ((NULL != siteInfo.p) && (MgSiteInfo::Ok == siteInfo->GetStatus()))
- STRING siteHexString = sessionId.substr(
- length - MgSiteInfo::HexStringLength, MgSiteInfo::HexStringLength);
- Ptr<MgSiteInfo> siteInfo = GetSiteInfo(siteHexString);
+ connProps = GetConnectionProperties(userInfo, siteInfo, portType);
+ else
+ // This site is not currently working
- if ((NULL != siteInfo.p) && (MgSiteInfo::Ok == siteInfo->GetStatus()))
- connProps = GetConnectionProperties(userInfo, siteInfo, portType);
- else
- // This site is not currently working
- // We have a session, but it will not exist on any other machine so we force the session exception
- throw new MgSessionExpiredException(L"MgSiteManager.GetConnectionProperties",__LINE__,__WFILE__, NULL, L"", NULL);
+ // We have a session, but it will not exist on any other machine so we force the session exception
+ throw new MgSessionExpiredException(L"MgSiteManager.GetConnectionProperties",__LINE__,__WFILE__, NULL, L"", NULL);
else
@@ -503,35 +499,44 @@
Ptr<MgSiteInfo> matchingSiteInfo;
- if(hexString.length() >= MgSiteInfo::HexStringLength)
+ INT32 sitePort, clientPort, adminPort;
+ STRING target;
+ INT32 targetlen = (INT32) hexString.length() - MgSiteInfo::HexPortsStringLength;
+ if (::swscanf(hexString.c_str(), format, targetHex, &sitePort, &clientPort, &adminPort) == 4)
- INT32 sitePort, clientPort, adminPort;
- STRING target;
- if(::swscanf(hexString.c_str(), L"%2X%2X%2X%2X%4X%4X%4X", &n1, &n2, &n3, &n4, &sitePort, &clientPort, &adminPort) == 7)
+ // There were alignment "=" removed during encoding. They should be appended back to do decoding
- target = buffer;
- ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, m_mutex, NULL));
+ target = ACE_Ascii_To_Wide(buffer).wchar_rep();
- for (INT32 i = 0; i < (INT32)m_sites.size(); i++)
+ ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, m_mutex, NULL));
+ for (INT32 i = 0; i < (INT32)m_sites.size(); i++)
+ MgSiteInfo* siteInfo = m_sites.at(i);
+ if (siteInfo->GetTarget() == target
+ && (siteInfo->GetPort(MgSiteInfo::Site) == sitePort ||
+ siteInfo->GetPort(MgSiteInfo::Client) == clientPort ||
+ siteInfo->GetPort(MgSiteInfo::Admin) == adminPort))
- MgSiteInfo* siteInfo = m_sites.at(i);
- if (siteInfo->GetTarget() == target
- && (siteInfo->GetPort(MgSiteInfo::Site) == sitePort ||
- siteInfo->GetPort(MgSiteInfo::Client) == clientPort ||
- siteInfo->GetPort(MgSiteInfo::Admin) == adminPort))
- matchingSiteInfo = SAFE_ADDREF(siteInfo);
- break;
+ matchingSiteInfo = SAFE_ADDREF(siteInfo);
+ break;
Modified: trunk/MgDev/Common/MapGuideCommon/Util/IpUtil.cpp
--- trunk/MgDev/Common/MapGuideCommon/Util/IpUtil.cpp 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Common/MapGuideCommon/Util/IpUtil.cpp 2011-08-09 06:21:33 UTC (rev 6048)
@@ -42,7 +42,7 @@
/// <summary>
-/// Detemines whether or not the specified host is an IP address.
+/// Determines whether or not the specified host is an IP address.
/// </summary>
/// <param name="address">
@@ -55,21 +55,204 @@
/// EXCEPTIONS:
/// MgNullArgumentException
-/// MgInvalidArgumentException
/// MgInvalidIpAddressException
bool MgIpUtil::IsIpAddress(CREFSTRING address, bool strict)
- ValidateAddress(address, strict);
+ return IsIpv4Address(address, strict) || IsIpv6Address(address, strict);
+/// <summary>
+/// Determines whether or not the specified host is an IP address in IPv4 format.
+/// </summary>
+/// <param name="address">
+/// IP address (or host name).
+/// </param>
+/// </param>
+/// <param name="strict">
+/// Flag indicating if the specified address must be looked up.
+/// </param>
+/// EXCEPTIONS:
+/// MgNullArgumentException
+/// MgInvalidIpAddressException
+bool MgIpUtil::IsIpv4Address(CREFSTRING address, bool strict)
+ if (address.empty())
+ throw new MgNullArgumentException(L"MgIpUtil.IsIpv4Address",
+ __LINE__, __WFILE__, NULL, L"", NULL);
unsigned int n1, n2, n3, n4;
+ bool isv4Address = 4 == ::swscanf(address.c_str(), L"%u.%u.%u.%u", &n1, &n2, &n3, &n4);
- return (4 == ::swscanf(address.c_str(), L"%u.%u.%u.%u", &n1, &n2, &n3, &n4));
+ if (isv4Address && strict)
+ ACE_INET_Addr inetAddr;
+ if (0 != inetAddr.set((u_short)0, address.c_str()) ||
+ NULL == inetAddr.get_host_name())
+ MgStringCollection arguments;
+ arguments.Add(address);
+ throw new MgInvalidIpAddressException(L"MgIpUtil.IsIpv4Address",
+ __LINE__, __WFILE__, &arguments, L"", NULL);
+ isv4Address = AF_INET == inetAddr.get_type();
+ return isv4Address;
/// <summary>
+/// Determines whether or not the specified host is an IP address in IPv6 format.
+/// </summary>
+/// </param>
+/// </param>
+/// </param>
+/// EXCEPTIONS:
+bool MgIpUtil::IsIpv6Address(CREFSTRING address, bool strict)
+ throw new MgNullArgumentException(L"MgIpUtil.IsIpv6Address",
+ // An valid IPv6 address must have ":"
+ bool isv6Address = address.find(L":") != -1;
+ if (isv6Address)
+ // Check if the address is expressed
+ int expressed = (int) address.find(L"::");
+ if (address.rfind(L"::") != expressed)
+ // There are more than 1 "::", it's an invalid address
+ return false;
+ expressed = expressed == -1 ? 0 : 1;
+ int conlonNumber = 0;
+ const wchar_t *addr = address.c_str();
+ int len = (int) wcslen(addr);
+ if (addr[len] == L':')
+ // If the last char is :, it's an invalid address
+ return false;
+ if (addr[0] == L':' && addr[1] != L':')
+ // Single ":" cannot be the leading character for an valid IPv6 address
+ return false;
+ // Check how many ":" the address has
+ for (int i = 0; i < len; ++i)
+ if (addr[i] == L':')
+ ++conlonNumber;
+ if (conlonNumber > 7 || conlonNumber < 1)
+ // If there are more than 8 groups or less than 1 group, it's an invalid address
+ return false;
+ int totalGroups = 8;
+ // Get how many groups are expressed as ::
+ // It's possible that "::" is the leading character, then 1 more group is expressed
+ int compressedGroups = totalGroups - conlonNumber + (addr[0] == L':' ? 1 : 0);
+ wchar_t fullAddress[40] = {0};
+ wcscpy(fullAddress, L"0000:0000:0000:0000:0000:0000:0000:0000");
+ int digits = 0;
+ int index = (int) wcslen(fullAddress) - 1;
+ wchar_t lastChar = L' ';
+ for (int i = len - 1; i >= 0 && index >= 0; --i, --index)
+ if (lastChar == L':')
+ // Restore the compressed groups
+ index -= compressedGroups * 5 - 1;
+ else
+ // Restore the addtional leading 0s
+ index -= 4 - digits;
+ // A new group will start, then reset the digits counter
+ digits = 0;
+ else
+ fullAddress[index] = addr[i];
+ // The max number of digits in a group is 4
+ if (++digits > 4)
+ return false;
+ lastChar = addr[i];
+ // Check if the digits in each group are valid hex numbers
+ int n1, n2, n3, n4, n5, n6, n7, n8;
+ isv6Address = 8 == ::swscanf(fullAddress, L"%4X:%4X:%4X:%4X:%4X:%4X:%4X:%4X:", &n1, &n2, &n3, &n4, &n5, &n6, &n7, &n8);
+ if (isv6Address & strict)
+ throw new MgInvalidIpAddressException(L"MgIpUtil.IsIpv6Address",
+ isv6Address = AF_INET6 == inetAddr.get_type();
+ return isv6Address;
+/// <summary>
/// Detemines whether or not the specified host is local.
/// </summary>
@@ -90,7 +273,8 @@
bool isLocalHost = false;
if (0 == ::wcscmp(address.c_str(), L"127.0.0.1")
- || 0 == _wcsnicmp(address.c_str(), L"localhost", ::wcslen(L"localhost")))
+ || 0 == ::wcscmp(address.c_str(), L"::1")
+ || 0 == _wcsnicmp(address.c_str(), L"localhost", ::wcslen(L"localhost")))
isLocalHost = true;
@@ -217,7 +401,6 @@
/// EXCEPTIONS:
@@ -229,20 +412,6 @@
- if (STRING::npos != address.rfind(L':'))
- MgStringCollection arguments;
- arguments.Add(L"1");
- arguments.Add(address);
- MgStringCollection whyArguments;
- whyArguments.Add(L":");
- throw new MgInvalidArgumentException(L"MgIpUtil.ValidateAddress",
- __LINE__, __WFILE__, &arguments,
- L"MgStringContainsReservedCharacters", &whyArguments);
if (strict)
@@ -469,12 +638,6 @@
ValidateAddress(address1, !IsLocalHost(address1, false));
ValidateAddress(address2, !IsLocalHost(address2, false));
- else if (IsIpAddress(address1, false) && IsIpAddress(address2, false) &&
- !IsLocalHost(address1, false) && !IsLocalHost(address2, false))
- ValidateAddress(address1);
- ValidateAddress(address2);
else
ACE_INET_Addr inetAddr1((u_short)0, address1.c_str());
@@ -509,6 +672,32 @@
compareFlag = 0;
+ // If one of the addresses is IPv6 and the other one is IPv4, then even the two addresses
+ // are for a same host, inetAddr1 == inetAddr2 is still false.
+ // And the case of both addresses are IPv6 and for a same host are already handled before
+ else if (inetAddr1.get_type() == AF_INET6 || inetAddr2.get_type() == AF_INET6)
+ // Convert them to addresses first then convert them to names.
+ // This is a workaround for the special case where the domain and the
+ // DNS suffix are different, e.g.:
+ // name1 = calpc220.amer.ads.autodesk.com
+ // name2 = calpc220.ads.autodesk.com
+ STRING addr1, addr2;
+ if (HostNameToAddress(address1, addr1) &&
+ HostNameToAddress(address2, addr2))
+ STRING name1, name2;
+ if (HostAddressToName(addr1, name1) &&
+ HostAddressToName(addr2, name2))
+ compareFlag = _wcsnicmp(name1.c_str(), name2.c_str(),
+ ACE_MIN(name1.length(), name2.length()));
+ // else, MgInvalidIpAddressException will be thrown
else if (inetAddr1 < inetAddr2)
compareFlag = -1;
Modified: trunk/MgDev/Common/MapGuideCommon/Util/IpUtil.h
--- trunk/MgDev/Common/MapGuideCommon/Util/IpUtil.h 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Common/MapGuideCommon/Util/IpUtil.h 2011-08-09 06:21:33 UTC (rev 6048)
@@ -51,7 +51,6 @@
/// \exception MgNullArgumentException
- /// \exception MgInvalidArgumentException
/// \exception MgInvalidIpAddressException
@@ -60,6 +59,36 @@
/// \brief
+ /// Determines whether or not the specified host is an IP address in IPv4 format.
+ /// \param address
+ /// IP address (or host name).
+ /// \param strict
+ /// Flag indicating if the specified address must be looked up.
+ /// \exception MgNullArgumentException
+ /// \exception MgInvalidIpAddressException
+ static bool IsIpv4Address(CREFSTRING address, bool strict = true);
+ /// \brief
+ /// Determines whether or not the specified host is an IP address in IPv6 format.
+ /// \param strict
+ static bool IsIpv6Address(CREFSTRING address, bool strict = true);
+ /// \brief
/// Determines whether or not the specified host is local.
/// \param address
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h
--- trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h 2011-08-09 06:21:33 UTC (rev 6048)
@@ -440,10 +440,30 @@
/// \return
/// Returns the number of dots per inch of the map display.
- virtual INT32 GetDisplayDpi(); /// __get
+ virtual INT32 GetDisplayDpi(); /// __get, __set
/// \brief
+ /// Sets the number of dots per inch of the map display.
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// void SetDisplayDpi(int dpi);
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \param dpi (int)
+ /// Number of dots per inch of the map display
+ virtual void SetDisplayDpi(INT32 dpi);
+ /// \brief
/// Returns the current width of the map display in pixels.
/// \remarks
@@ -540,17 +560,28 @@
virtual double GetFiniteDisplayScaleAt(INT32 index);
-EXTERNAL_API:
/// \brief
/// Returns the background color for the map
+ /// string GetBackgroundColor();
/// \return
/// Background color.
virtual STRING GetBackgroundColor();
+EXTERNAL_API:
INTERNAL_API:
static MdfModel::MapDefinition* GetMapDefinition(MgResourceService* svcResource, MgResourceIdentifier* resId);
@@ -636,15 +667,6 @@
virtual void SetDataExtent(MgEnvelope* extent);
/// \brief
- /// Sets the number of dots per inch of the map display
- /// This method is for use by the viewers and should not be called directly
- /// \param dpi
- /// Number of dots per inch of the map display
- virtual void SetDisplayDpi(INT32 dpi);
- /// \brief
/// Sets the current width of the map display in pixels
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/config-linux.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/config-linux.h 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/config-linux.h 2011-08-09 06:21:33 UTC (rev 6048)
@@ -8,6 +8,7 @@
#ifndef ACE_CONFIG_LINUX_H
#define ACE_CONFIG_LINUX_H
#include /**/ "ace/pre.h"
+#define ACE_HAS_IPV6
#define ACE_PLATFORM_CONFIG config-linux.h
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/config-win32.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/config-win32.h 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/config-win32.h 2011-08-09 06:21:33 UTC (rev 6048)
@@ -18,6 +18,7 @@
#ifndef ACE_CONFIG_WIN32_H
#define ACE_CONFIG_WIN32_H
// NOTE: Please do not add anything besides #include's here. Put other stuff
// (definitions, etc.) in the included headers
Modified: trunk/MgDev/Server/src/Common/Manager/SessionCache.cpp
--- trunk/MgDev/Server/src/Common/Manager/SessionCache.cpp 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Server/src/Common/Manager/SessionCache.cpp 2011-08-09 06:21:33 UTC (rev 6048)
@@ -150,7 +150,7 @@
// Session Affinity: Check that the session was created by this server
if(!session.empty())
- STRING hexString = session.substr(session.length() - MgSiteInfo::HexStringLength);
+ STRING hexString = session.substr(session.rfind(L"_") + 1);
Ptr<MgSiteInfo> sessionSiteInfo = new MgSiteInfo(hexString);
if(sessionSiteInfo->GetStatus() == MgSiteInfo::Ok)
Modified: trunk/MgDev/Server/src/Common/stdafx.h
--- trunk/MgDev/Server/src/Common/stdafx.h 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Server/src/Common/stdafx.h 2011-08-09 06:21:33 UTC (rev 6048)
@@ -20,8 +20,6 @@
#ifndef STDAFX_H
#define STDAFX_H
-#define _WIN32_WINNT 0x0400
#define WIN32_LEAN_AND_MEAN // Exclude rarely-used stuff from Windows headers
// Windows Header Files:
#include <windows.h>
Modified: trunk/MgDev/Server/src/Core/Server.cpp
--- trunk/MgDev/Server/src/Core/Server.cpp 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Server/src/Core/Server.cpp 2011-08-09 06:21:33 UTC (rev 6048)
@@ -523,9 +523,12 @@
pServerManager->SetClientMessageQueue(clientThreads.msg_queue_);
pServerManager->SetSiteMessageQueue(siteThreads.msg_queue_);
- ACE_INET_Addr clientAddr((u_short)pServerManager->GetClientPort());
- ACE_INET_Addr adminAddr((u_short)pServerManager->GetAdminPort());
- ACE_INET_Addr siteAddr((u_short)pServerManager->GetSitePort());
+ // For IPv4, always listen to 0.0.0.0 so that the server could be connected through any valid v4 addresess
+ // For IPv6, always listen to :: so that the server could be connected through any valid v6 addresess
+ STRING listenToAddress = MgIpUtil::IsIpv4Address(pServerManager->GetLocalServerAddress()) ? L"0.0.0.0" : L"::";
+ ACE_INET_Addr clientAddr((u_short)pServerManager->GetClientPort(), listenToAddress.c_str());
+ ACE_INET_Addr adminAddr((u_short)pServerManager->GetAdminPort(), listenToAddress.c_str());
+ ACE_INET_Addr siteAddr((u_short)pServerManager->GetSitePort(), listenToAddress.c_str());
MgClientAcceptor clientAcceptor(clientAddr, ACE_Reactor::instance(), clientThreads.msg_queue_);
nResult = clientAcceptor.Initialize();
Modified: trunk/MgDev/Web/src/mapviewerjava/common.jsp
--- trunk/MgDev/Web/src/mapviewerjava/common.jsp 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Web/src/mapviewerjava/common.jsp 2011-08-09 06:21:33 UTC (rev 6048)
@@ -203,10 +203,11 @@
String ValidateSessionId(String proposedSessionId)
- // 00000000-0000-0000-0000-000000000000_aa_00000000000000000000
+ // 00000000-0000-0000-0000-000000000000_aa_[aaaaaaaaaaaaa]000000000000
+ // the [aaaaaaaaaaaaa] is a based64 string and in variant length
String validSessionId = "";
if(proposedSessionId != null &&
- Pattern.matches("^[A-Fa-f0-9]{8}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{12}_[A-Za-z]{2}_[A-Fa-f0-9]{20}$", proposedSessionId))
+ Pattern.matches("^[A-Fa-f0-9]{8}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{12}_[A-Za-z]{2}_\\w+[A-Fa-f0-9]{12}$", proposedSessionId))
validSessionId = proposedSessionId;
Modified: trunk/MgDev/Web/src/mapviewerjava/quickplotgeneratepicture.jsp
--- trunk/MgDev/Web/src/mapviewerjava/quickplotgeneratepicture.jsp 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Web/src/mapviewerjava/quickplotgeneratepicture.jsp 2011-08-09 06:21:33 UTC (rev 6048)
@@ -46,9 +46,18 @@
- GetRequestParameters(request);
- response.setContentType("image/png");
- ImageIO.write(GenerateMap(printSize), "png", response.getOutputStream());
+ try
+ GetRequestParameters(request);
+ response.setContentType("image/png");
+ ImageIO.write(GenerateMap(printSize), "png", response.getOutputStream());
+ catch (MgException e)
+ response.setContentType("text/html");
+ out.write ("ERROR:" + e.GetExceptionMessage() + "<br />");
+ out.write (e.GetStackTrace() + "<br />");
@@ -96,6 +105,8 @@
BufferedImage GenerateMap(Size<Integer> size) throws MgException, IOException
+ InitializeWebTier();
MgUserInformation userInfo = new MgUserInformation(sessionId);
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
@@ -116,23 +127,26 @@
Size<Double> toSize = new Size<Double>(size1.width / size2.width * size.width, size1.height / size2.height * size.height);
MgCoordinate center = captureBox.GetCentroid().GetCoordinate();
- // Get the map agent url
- // Get the correct http protocol
- StringBuilder mapAgent = new StringBuilder(mapAgentPath);
- String encodeMapName = URLEncoder.encode(mapName,"UTF-8");
- mapAgent.append("?VERSION=1.0.0&OPERATION=GETMAPIMAGE")
- .append("&SESSION=").append(sessionId)
- .append("&MAPNAME=").append(encodeMapName)
- .append("&FORMAT=PNG")
- .append("&SETVIEWCENTERX=").append(center.GetX())
- .append("&SETVIEWCENTERY=").append(center.GetY())
- .append("&SETVIEWSCALE=").append(scaleDenominator)
- .append("&SETDISPLAYDPI=").append(printDpi)
- .append("&SETDISPLAYWIDTH=").append(String.valueOf(toSize.width))
- .append("&SETDISPLAYHEIGHT=").append(String.valueOf(toSize.height))
- .append("&CLIP=0");
- BufferedImage image = ImageIO.read(new URL(mapAgent.toString()));
+ map.SetDisplayDpi(printDpi);
+ String colorString = map.GetBackgroundColor();
+ // The returned color string is in AARRGGBB format. But the constructor of MgColor needs a string in RRGGBBAA format
+ colorString = colorString.substring(2, 8) + colorString.substring(0, 2);
+ MgColor color = new MgColor(colorString);
+ MgByteReader mgReader = renderingService.RenderMap(map,
+ selection,
+ center,
+ scaleDenominator,
+ (int) Math.ceil(toSize.width),
+ (int) Math.ceil(toSize.height),
+ color,
+ "PNG",
+ false);
+ File tempImage = File.createTempFile(UUID.randomUUID().toString(), "png");
+ mgReader.ToFile(tempImage.getAbsolutePath());
+ BufferedImage image = ImageIO.read(tempImage);
+ tempImage.delete();
BufferedImage result = Math.abs(rotation) > Double.MIN_VALUE ? new BufferedImage(size.width, size.height, BufferedImage.TYPE_INT_RGB) : image;
Graphics2D graphics = result.createGraphics();
Modified: trunk/MgDev/Web/src/mapviewernet/common.aspx
--- trunk/MgDev/Web/src/mapviewernet/common.aspx 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Web/src/mapviewernet/common.aspx 2011-08-09 06:21:33 UTC (rev 6048)
@@ -195,10 +195,11 @@
if(proposedSessionId != null && System.Text.RegularExpressions.Regex.IsMatch(proposedSessionId,
- "^[A-Fa-f0-9]{8}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{12}_[A-Za-z]{2}_[A-Fa-f0-9]{20}$"))
+ "^[A-Fa-f0-9]{8}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{12}_[A-Za-z]{2}_\\w+[A-Fa-f0-9]{12}$"))
Modified: trunk/MgDev/Web/src/mapviewernet/quickplotgeneratepicture.aspx
--- trunk/MgDev/Web/src/mapviewernet/quickplotgeneratepicture.aspx 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Web/src/mapviewernet/quickplotgeneratepicture.aspx 2011-08-09 06:21:33 UTC (rev 6048)
@@ -42,9 +42,18 @@
Response.Charset = "utf-8";
- GetRequestParameters();
- GenerateMap(printSize);
+ try
+ GetRequestParameters();
+ GenerateMap(printSize);
+ Response.ContentType = "text/html";
+ Response.Write(string.Format("ERROR: {0} <br />", e.GetExceptionMessage()));
+ Response.Write(string.Format("{0} <br />", e.GetStackTrace()));
<script runat="server">
@@ -95,6 +104,8 @@
void GenerateMap(Size size)
MgUserInformation userInfo = new MgUserInformation(sessionID);
@@ -115,65 +126,54 @@
SizeF toSize = new SizeF(size1.Width / size2.Width * size.Width, size1.Height / size2.Height * size.Height);
- StringBuilder mapAgent = new StringBuilder(Request.IsSecureConnection ? "https://" : "http://");
- // Get the correct port number
- // Just use the 127.0.0.1 specificly to point to localhost. Because the WebExtension will
- // be always on the same server with map agent.
- mapAgent.Append("127.0.0.1").Append(":").Append(Request.ServerVariables["SERVER_PORT"]);
+ string colorString = map.GetBackgroundColor();
+ colorString = string.Format("{0}{1}", colorString.Substring(2, 6), colorString.Substring(0, 2));
- // Get the correct virtual directory
- string url = Request.ServerVariables["URL"];
- mapAgent.Append(url.Substring(0, url.IndexOf("/", 1)));
+ selection,
+ center,
+ scaleDenominator,
+ (int) toSize.Width,
+ (int) toSize.Height,
+ color,
+ "PNG",
+ false);
- mapAgent.Append("/mapagent/mapagent.fcgi?VERSION=1.0.0&OPERATION=GETMAPIMAGE")
- .AppendFormat("&SESSION={0}", sessionID)
- .AppendFormat("&MAPNAME={0}", HttpUtility.UrlEncode(mapName))
- .Append("&FORMAT=PNG")
- .AppendFormat("&SETVIEWCENTERX={0}", center.GetX())
- .AppendFormat("&SETVIEWCENTERY={0}", center.GetY())
- .AppendFormat("&SETVIEWSCALE={0}", scaleDenominator)
- .AppendFormat("&SETDISPLAYDPI={0}", printDpi)
- .AppendFormat("&SETDISPLAYWIDTH={0}", toSize.Width)
- .AppendFormat("&SETDISPLAYHEIGHT={0}", toSize.Height)
- .Append("&CLIP=0");
+ string tempImage = Path.GetTempFileName();
+ mgReader.ToFile(tempImage);
- WebRequest request = WebRequest.Create(mapAgent.ToString());
- using (HttpWebResponse response = request.GetResponse() as HttpWebResponse)
+ using (System.Drawing.Image image = Bitmap.FromFile(tempImage))
- if (response.StatusCode == HttpStatusCode.OK)
+ using (System.Drawing.Image result = Math.Abs(rotation) > double.Epsilon ? new Bitmap(size.Width, size.Height) : image)
- using (Bitmap image = new Bitmap(response.GetResponseStream()))
+ using (Graphics graphics = Graphics.FromImage(result))
- using (Bitmap result = Math.Abs(rotation) > double.Epsilon ? new Bitmap(size.Width, size.Height) : image)
+ if (Math.Abs(rotation) > double.Epsilon)
- using (Graphics graphics = Graphics.FromImage(result))
- if (Math.Abs(rotation) > double.Epsilon)
- graphics.TranslateTransform(size.Width / 2, size.Height / 2);
- graphics.RotateTransform((float)rotation);
- graphics.DrawImage(image, -image.Width / 2, -image.Height / 2);
+ graphics.TranslateTransform(size.Width / 2, size.Height / 2);
+ graphics.RotateTransform((float)rotation);
+ graphics.DrawImage(image, -image.Width / 2, -image.Height / 2);
- DrawNorthArrow(result);
+ DrawNorthArrow(result);
- using (MemoryStream stream = new MemoryStream())
- result.Save(stream, System.Drawing.Imaging.ImageFormat.Png);
- Response.ContentType = "image/png";
- Response.BinaryWrite(stream.ToArray());
+ using (MemoryStream stream = new MemoryStream())
+ result.Save(stream, System.Drawing.Imaging.ImageFormat.Png);
+ Response.ContentType = "image/png";
+ Response.BinaryWrite(stream.ToArray());
+ File.Delete(tempImage);
-void DrawNorthArrow(Bitmap image)
+void DrawNorthArrow(System.Drawing.Image image)
// The north arrow image is created under this dpi
int naDpi = 300;
Modified: trunk/MgDev/Web/src/mapviewerphp/common.php
--- trunk/MgDev/Web/src/mapviewerphp/common.php 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Web/src/mapviewerphp/common.php 2011-08-09 06:21:33 UTC (rev 6048)
@@ -160,10 +160,11 @@
function ValidateSessionId($proposedSessionId)
$validSessionId = "";
if($proposedSessionId != null &&
- preg_match('/^[A-Fa-f0-9]{8}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{12}_[A-Za-z]{2}_[A-Fa-f0-9]{20}$/', $proposedSessionId))
+ preg_match('/^[A-Fa-f0-9]{8}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{4}-[A-Fa-f0-9]{12}_[A-Za-z]{2}_\\w+[A-Fa-f0-9]{12}$/', $proposedSessionId))
$validSessionId = $proposedSessionId;
Modified: trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php
--- trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php 2011-08-08 15:55:46 UTC (rev 6047)
+++ trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php 2011-08-09 06:21:33 UTC (rev 6048)
@@ -13,8 +13,17 @@
$printSize;
$paperSize;
- GetParameters();
- GenerateMap($printSize);
+ try
+ GetParameters();
+ GenerateMap($printSize);
+ catch (MgException $e)
+ header ("Content-type: text/html");
+ echo "ERROR: " . $e->GetExceptionMessage() . "<br>";
+ echo $e->GetStackTrace() . "<br>";
<?php
@@ -70,6 +79,8 @@
global $sessionID, $mapName, $captureBox, $printSize, $normalizedCapture, $rotation, $scaleDenominator, $printDpi;
$userInfo = new MgUserInformation($sessionID);
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
@@ -89,32 +100,27 @@
$toSize = new Size($size1->width / $size2->width * $size->width, $size1->height / $size2->height * $size->height);
$center = $captureBox->GetCentroid()->GetCoordinate();
- // Get the correct http protocal
- $mapAgent = "http";
- if ($_SERVER["HTTPS"] == "on")
- $mapAgent .= "s";
- $mapAgent .= "://127.0.0.1:" . $_SERVER["SERVER_PORT"];
- $mapAgent .= substr($_SERVER["REQUEST_URI"], 0, strpos($_SERVER["REQUEST_URI"], "/", 1));
- $mapAgent .="/mapagent/mapagent.fcgi?VERSION=1.0.0&OPERATION=GETMAPIMAGE" .
- "&SESSION=$sessionID" .
- "&MAPNAME=" . rawurlencode($mapName) .
- "&FORMAT=PNG" .
- "&SETVIEWCENTERX=" . $center->GetX() .
- "&SETVIEWCENTERY=" . $center->GetY() .
- "&SETVIEWSCALE=$scaleDenominator" .
- "&SETDISPLAYDPI=$printDpi" .
- "&SETDISPLAYWIDTH=$toSize->width" .
- "&SETDISPLAYHEIGHT=$toSize->height" .
- "&CLIP=0";
+ $map->SetDisplayDpi($printDpi);
+ $colorString = $map->GetBackgroundColor();
+ $colorString = substr($colorString, 2, 6) . substr($colorString, 0, 2);
+ $color = new MgColor($colorString);
- $image = imagecreatefrompng($mapAgent);
+ $mgReader = $renderingService->RenderMap($map,
+ $selection,
+ $center,
+ $scaleDenominator,
+ $toSize->width,
+ $toSize->height,
+ $color,
+ "PNG",
+ false);
+ $tempImage = sys_get_temp_dir() . uniqid();
+ $mgReader->ToFile($tempImage);
+ $image = imagecreatefrompng($tempImage);
+ unlink($tempImage);
// Rotate the picture back to be normalized
$normalizedImg = imagerotate($image, -$rotation, 0);
// Free the original image
More information about the mapguide-commits
