[mapguide-commits] r6077 - trunk/MgDev/Common/MapGuideCommon/System
svn_mapguide at osgeo.org
Tue Aug 16 02:52:43 EDT 2011
Author: hubu
Date: 2011-08-15 23:52:43 -0700 (Mon, 15 Aug 2011)
New Revision: 6077
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
Fix break build of MapGuide Web.
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2011-08-16 06:43:59 UTC (rev 6076)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2011-08-16 06:52:43 UTC (rev 6077)
@@ -483,7 +483,7 @@
const INT32 MgConfigProperties::DefaultDBPageSizeParameters = 32;
const STRING MgConfigProperties::DBXMLPageSizeParameters = L"DBXMLPageSize";
const INT32 MgConfigProperties::DefaultDBXMLPageSizeParameters = 32;
-const STRING MgConfigProperties::LibraryLogBufferSizeParameters = L"LibraryLogBufferSize";
+const STRING MgConfigProperties::LibraryLogBufferSizeParameters = L"LibraryLogBufferSize";
const INT32 MgConfigProperties::DefaultLibraryLogBufferSizeParameters = 12;
const STRING MgConfigProperties::SessionLogBufferSizeParameters = L"SessionLogBufferSize";
const INT32 MgConfigProperties::DefaultSessionLogBufferSizeParameters = 1;
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2011-08-16 06:43:59 UTC (rev 6076)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2011-08-16 06:52:43 UTC (rev 6077)
@@ -842,20 +842,20 @@
static const INT32 DefaultDBMaxTransactionsParamters; /// value(1000)
/// The size for session DB page in KB
- static const STRING SessionDBPageSizeParameters; // value("SessionDBPageSize")
- static const INT32 DefaultSessionDBPageSizeParameters; // value(2)
+ static const STRING SessionDBPageSizeParameters; /// value("SessionDBPageSize")
+ static const INT32 DefaultSessionDBPageSizeParameters; /// value(2)
/// The size for session DBXML page in KB
- static const STRING SessionDBXMLPageSizeParameters; // value("SessionDBXMLPageSize")
- static const double DefaultSessionDBXMLPageSizeParameters; // value(0.5)
+ static const STRING SessionDBXMLPageSizeParameters; /// value("SessionDBXMLPageSize")
+ static const double DefaultSessionDBXMLPageSizeParameters; /// value(0.5)
/// The time out for lock and transaction in second
- static const STRING DBTimeoutParameters; // value("DBTimeout")
- static const double DefaultDBTimeoutParameters; // value(0.2)
+ static const STRING DBTimeoutParameters; /// value("DBTimeout")
+ static const double DefaultDBTimeoutParameters; /// value(0.2)
/// The max number of DB lockers
- static const STRING DBMaxLockersParameters; // value("DBMaxLockers")
- static const INT32 DefaultDBMaxLockersParameters; // value(1000)
+ static const STRING DBMaxLockersParameters; /// value("DBMaxLockers")
+ static const INT32 DefaultDBMaxLockersParameters; /// value(1000)
INTERNAL_API:
More information about the mapguide-commits
