[mapguide-commits] r6364 - in trunk/Tools/Maestro: . Maestro SignMapGuideApi SignMapGuideApi/Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Dec 25 05:51:36 EST 2011
Author: jng
Date: 2011-12-25 02:51:36 -0800 (Sun, 25 Dec 2011)
New Revision: 6364
Added:
   trunk/Tools/Maestro/SignMapGuideApi/
   trunk/Tools/Maestro/SignMapGuideApi/Program.cs
   trunk/Tools/Maestro/SignMapGuideApi/Properties/
   trunk/Tools/Maestro/SignMapGuideApi/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/SignMapGuideApi/SignMapGuideApi.csproj
   trunk/Tools/Maestro/Maestro/Maestro_All.sln
Add a utility to assist in signing of the official MapGuide API assemblies. Original source code provided by Hans Milling.
Modified: trunk/Tools/Maestro/Maestro/Maestro_All.sln
--- trunk/Tools/Maestro/Maestro/Maestro_All.sln	2011-12-24 14:20:28 UTC (rev 6363)
+++ trunk/Tools/Maestro/Maestro/Maestro_All.sln	2011-12-25 10:51:36 UTC (rev 6364)
@@ -93,6 +93,8 @@
 EndProject
 Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "LocalConfigure", "..\LocalConfigure\LocalConfigure.csproj", "{6EE16FFD-296E-42FF-B994-8902C27AA0F4}"
 EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "SignMapGuideApi", "..\SignMapGuideApi\SignMapGuideApi.csproj", "{D24F724A-1CBF-4EB6-A48B-92C08353C4CC}"
+EndProject
 Global
 	GlobalSection(SolutionConfigurationPlatforms) = preSolution
 		Debug|Any CPU = Debug|Any CPU
@@ -227,6 +229,10 @@
 		{6EE16FFD-296E-42FF-B994-8902C27AA0F4}.Debug|Any CPU.Build.0 = Debug|Any CPU
 		{6EE16FFD-296E-42FF-B994-8902C27AA0F4}.Release|Any CPU.ActiveCfg = Release|Any CPU
 		{6EE16FFD-296E-42FF-B994-8902C27AA0F4}.Release|Any CPU.Build.0 = Release|Any CPU
+		{D24F724A-1CBF-4EB6-A48B-92C08353C4CC}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+		{D24F724A-1CBF-4EB6-A48B-92C08353C4CC}.Debug|Any CPU.Build.0 = Debug|Any CPU
+		{D24F724A-1CBF-4EB6-A48B-92C08353C4CC}.Release|Any CPU.ActiveCfg = Release|Any CPU
+		{D24F724A-1CBF-4EB6-A48B-92C08353C4CC}.Release|Any CPU.Build.0 = Release|Any CPU
 	EndGlobalSection
 	GlobalSection(SolutionProperties) = preSolution
 		HideSolutionNode = FALSE
Property changes on: trunk/Tools/Maestro/SignMapGuideApi
___________________________________________________________________
Added: svn:ignore
   + bin
obj
Added: trunk/Tools/Maestro/SignMapGuideApi/Program.cs
--- trunk/Tools/Maestro/SignMapGuideApi/Program.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SignMapGuideApi/Program.cs	2011-12-25 10:51:36 UTC (rev 6364)
@@ -0,0 +1,233 @@
+using System;
+using System.Collections.Generic;
+using System.Text;
+using System.IO;
+using System.Diagnostics;
+namespace SignMapGuideApi
+    class Program
+        static string[] files = { "MapGuideDotNetApi", "OSGeo.MapGuide.Foundation", "OSGeo.MapGuide.Geometry", "OSGeo.MapGuide.MapGuideCommon", "OSGeo.MapGuide.PlatformBase", "OSGeo.MapGuide.Web" };
+        static string[] ildasm32 = { "C:\\Program Files\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\ildasm.exe",
+                                 "C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\ildasm.exe",
+                                 "C:\\Program Files\\Microsoft SDKs\\Windows\\v7.0A\\Bin\\ildasm.exe",
+                                 "C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\Bin\\ildasm.exe" };
+        static string[] ildasm64 = { "C:\\Program Files\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\x64\\ildasm.exe",
+                                 "C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\x64\\ildasm.exe",
+                                 "C:\\Program Files\\Microsoft SDKs\\Windows\\v7.0A\\Bin\\x64\\ildasm.exe",
+                                 "C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\Bin\\x64\\ildasm.exe" };
+        static string[] ilasm32 = { "C:\\Windows\\Microsoft.NET\\Framework\\v2.0.50727\\ilasm.exe", "C:\\Windows\\Microsoft.NET\\Framework\\v4.0.30319\\ilasm.exe" };
+        static string[] ilasm64 = { "C:\\Windows\\Microsoft.NET\\Framework64\\v2.0.50727\\ilasm.exe", "C:\\Windows\\Microsoft.NET\\Framework64\\v4.0.30319\\ilasm.exe" };
+        //TODO: Allow for custom key and infer public key token from it
+        static string _keyFile = "maestroapi.key";
+        static string _publicKeyToken = "F5 26 C4 89 29 FD A8 56";
+        static bool Is64BitProcess()
+            return IntPtr.Size == 8;
+        static string getILDASMEXE()
+            if (Is64BitProcess())
+                foreach (string f in ildasm64)
+                    if (File.Exists(f))
+                        return f;
+            else
+                foreach (string f in ildasm32)
+                        return f;
+            return null;
+        static string getILASMEXE()
+                foreach (string f in ilasm64)
+                        return f;
+            else
+                foreach (string f in ilasm32)
+                        return f;
+            return null;
+        static void backup()
+            Console.Write("Creating Backup folder...");
+            Directory.CreateDirectory("Backup");
+            Console.WriteLine("Done");
+            Console.WriteLine("Backing up original DLL files.");
+            foreach (string f in files)
+                string file = f + ".dll";
+                if (!File.Exists(file))
+                    Console.WriteLine("[WARNING]: Could not find file to backup (" + file + ")");
+                    continue;
+                Console.Write("Copying " + file + "...");
+                File.Copy(file, "Backup\\" + file, true);
+        static void decompile(string decompiler)
+                    Console.WriteLine("[WARNING]: Could not find file to decompilation (" + file + ")");
+                    continue;
+                Console.Write("Decompiling: " + file + "...");
+                Process p = Process.Start(decompiler, "/all /out=" + f + ".il " + file);
+                p.WaitForExit();
+                p.Dispose();
+        static void cleandll()
+                Console.Write("Deleting " + file + "...");
+                File.Delete(file);
+                Console.WriteLine("done");
+        static void compile(string compiler, string file)
+            if (!File.Exists(file + ".il"))
+                Console.WriteLine("[WARNING]: No IL file to compile (" + file + ".il)");
+                return;
+            Console.Write("Compiling: " + file + ".il...");
+            Process p = Process.Start(compiler, "/dll /key=" + _keyFile + " " + file + ".il");
+            p.WaitForExit();
+            p.Dispose();
+        static bool assemblyLine(string line)
+            string l = line.ToLower();
+            if (l.StartsWith(".assembly extern"))
+                bool ends = false;
+                    if (l.EndsWith(f.ToLower()))
+                        ends = true;
+                        Console.WriteLine("  Added key to section: " + l);
+                        break;
+                return ends;
+            return false;
+        static void fixKey(string file)
+            string ilfile = file + ".il";
+            if (!File.Exists(ilfile))
+                Console.WriteLine("[WARNING]: Cannot find IL file to fix (" + ilfile + ")");
+                return;
+            string tempfile = file + ".temp";
+            File.Move(ilfile, tempfile); // rename file to .temp
+            System.IO.StreamReader fin = new System.IO.StreamReader(tempfile); // open file for read
+            System.IO.StreamWriter fout = new System.IO.StreamWriter(ilfile, false); // open file for write
+            string line;
+            Console.WriteLine("Fixing: " + ilfile);
+            int count = 0;
+            while ((line = fin.ReadLine()) != null) // read line by line
+                fout.WriteLine(line); // copy line to new file
+                if (assemblyLine(line)) // if line starts with .assembly extern and ends with one in file names
+                    line = fin.ReadLine(); // Copy next line containing: {
+                    fout.WriteLine("  .publickeytoken = (" + _publicKeyToken + " )"); // Write .publickeytoken line
+                count++;
+            fout.Close();
+            fin.Close();
+        static void cleanup()
+            Console.Write("Cleanup...");
+                if (File.Exists(f + ".temp"))
+                    File.Delete(f + ".temp");
+                if (File.Exists(f + ".il"))
+                    File.Delete(f + ".il");
+                if (File.Exists(f + ".res"))
+                    File.Delete(f + ".res");
+        static void Main(string[] args)
+            try
+                if (File.Exists(_keyFile))
+                    Console.Write("Detecting tools...");
+                    string ildasmexe = getILDASMEXE(); // Detect 32 or 64 bit versions of decompiler and compiler
+                    string ilasmexe = getILASMEXE();
+                    Console.WriteLine("Compiler: " + ilasmexe);
+                    Console.WriteLine("Decompiler: " + ildasmexe);
+                    backup(); // make backup copy of dll
+                    decompile(ildasmexe); // decompile dll files
+                    cleandll();
+                    for (int i = files.Length - 1; i >= 0; i--) // Compile the il files back to dll, fixing any missing key tokens in the references
+                        fixKey(files[i]);
+                        compile(ilasmexe, files[i]);
+                    cleanup();
+                    Console.WriteLine("All OSGeo files has been signed.");
+                else
+                    Console.WriteLine("Error: The file '" + _keyFile + "' is missing. This is required to sign the DLL files.");
+            catch (Exception ex)
+                Console.WriteLine("Error:\r\n" + ex.ToString());
Added: trunk/Tools/Maestro/SignMapGuideApi/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/SignMapGuideApi/Properties/AssemblyInfo.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SignMapGuideApi/Properties/AssemblyInfo.cs	2011-12-25 10:51:36 UTC (rev 6364)
@@ -0,0 +1,36 @@
+using System.Reflection;
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("SignMapGuideApi")]
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("")]
+[assembly: AssemblyProduct("SignMapGuideApi")]
+[assembly: AssemblyCopyright("Copyright ©  2011")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components.  If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+[assembly: Guid("eb96b48e-b456-4715-ae7c-b73522414bf9")]
+// Version information for an assembly consists of the following four values:
+//      Major Version
+//      Minor Version
+//      Build Number
+//      Revision
+// You can specify all the values or you can default the Build and Revision Numbers
+// by using the '*' as shown below:
+// [assembly: AssemblyVersion("1.0.*")]
+[assembly: AssemblyVersion("1.0.0.0")]
+[assembly: AssemblyFileVersion("1.0.0.0")]
Added: trunk/Tools/Maestro/SignMapGuideApi/SignMapGuideApi.csproj
--- trunk/Tools/Maestro/SignMapGuideApi/SignMapGuideApi.csproj	                        (rev 0)
+++ trunk/Tools/Maestro/SignMapGuideApi/SignMapGuideApi.csproj	2011-12-25 10:51:36 UTC (rev 6364)
@@ -0,0 +1,50 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project ToolsVersion="3.5" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+  <PropertyGroup>
+    <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+    <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
+    <ProductVersion>9.0.30729</ProductVersion>
+    <SchemaVersion>2.0</SchemaVersion>
+    <ProjectGuid>{D24F724A-1CBF-4EB6-A48B-92C08353C4CC}</ProjectGuid>
+    <OutputType>Exe</OutputType>
+    <AppDesignerFolder>Properties</AppDesignerFolder>
+    <RootNamespace>SignMapGuideApi</RootNamespace>
+    <AssemblyName>SignMapGuideApi</AssemblyName>
+    <TargetFrameworkVersion>v2.0</TargetFrameworkVersion>
+    <FileAlignment>512</FileAlignment>
+  </PropertyGroup>
+  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
+    <DebugSymbols>true</DebugSymbols>
+    <DebugType>full</DebugType>
+    <Optimize>false</Optimize>
+    <OutputPath>..\SDK\bin\</OutputPath>
+    <DefineConstants>DEBUG;TRACE</DefineConstants>
+    <ErrorReport>prompt</ErrorReport>
+    <WarningLevel>4</WarningLevel>
+  </PropertyGroup>
+  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
+    <DebugType>pdbonly</DebugType>
+    <Optimize>true</Optimize>
+    <DefineConstants>TRACE</DefineConstants>
+  </PropertyGroup>
+  <ItemGroup>
+    <Reference Include="System" />
+    <Reference Include="System.Data" />
+    <Reference Include="System.Xml" />
+  </ItemGroup>
+  <ItemGroup>
+    <Compile Include="Program.cs" />
+    <Compile Include="Properties\AssemblyInfo.cs" />
+  </ItemGroup>
+  <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
+  <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+       Other similar extension points exist, see Microsoft.Common.targets.
+  <Target Name="BeforeBuild">
+  </Target>
+  <Target Name="AfterBuild">
+  </Target>
+</Project>
\ No newline at end of file
More information about the mapguide-commits mailing list
