[mapguide-commits] r6379 - in
	trunk/MgDev/Doc/samples/dotnetsamples: analyzing_features
	modifying_maps_and_layers
    svn_mapguide at osgeo.org
    Thu Dec 29 06:45:05 EST 2011
Author: jng
Date: 2011-12-29 03:45:05 -0800 (Thu, 29 Dec 2011)
New Revision: 6379
Added:
   trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/bufferfunctions.aspx
   trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/createbuffer.aspx
   trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/selectfeaturesinbuffer.aspx
   trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/task_pane.aspx
   trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/layer_functions.aspx
Dev Guide: Add buffering example (.net)
Added: trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/bufferfunctions.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/bufferfunctions.aspx	                        (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/bufferfunctions.aspx	2011-12-29 11:45:05 UTC (rev 6379)
@@ -0,0 +1,200 @@
+  Copyright (C) 2004-2011 by Autodesk, Inc.
+  This library is free software; you can redistribute it and/or
+  modify it under the terms of version 2.1 of the GNU Lesser
+  General Public License as published by the Free Software Foundation.
+  This library is distributed in the hope that it will be useful,
+  but WITHOUT ANY WARRANTY; without even the implied warranty of
+  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+  Lesser General Public License for more details.
+  You should have received a copy of the GNU Lesser General Public
+  License along with this library; if not, write to the Free Software
+  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+<%@ Import Namespace="System" %>
+<%@ Import Namespace="System.Xml" %>
+<%@ Import Namespace="OSGeo.MapGuide" %>
+<!-- #Include File="../common/common.aspx" -->
+<script language="C#" runat="server">
+    public class BufferHelper
+        private HttpServerUtility _server;
+        public BufferHelper(HttpServerUtility server)
+            _server = server;
+        HttpServerUtility Server { get { return _server; } }
+        public void CreateBufferFeatureSource(MgFeatureService featureService, String wkt, MgResourceIdentifier bufferFeatureResId)
+            MgClassDefinition bufferClass = new MgClassDefinition();
+            bufferClass.SetName("BufferClass");
+            MgPropertyDefinitionCollection properties = bufferClass.GetProperties();
+            MgDataPropertyDefinition idProperty = new MgDataPropertyDefinition("ID");
+            idProperty.SetDataType(MgPropertyType.Int32);
+            idProperty.SetReadOnly(true);
+            idProperty.SetNullable(false);
+            idProperty.SetAutoGeneration(true);
+            properties.Add(idProperty);
+            MgGeometricPropertyDefinition polygonProperty = new MgGeometricPropertyDefinition("BufferGeometry");
+            polygonProperty.SetGeometryTypes(MgFeatureGeometricType.Surface);
+            polygonProperty.SetHasElevation(false);
+            polygonProperty.SetHasMeasure(false);
+            polygonProperty.SetReadOnly(false);
+            polygonProperty.SetSpatialContextAssociation("defaultSrs");
+            properties.Add(polygonProperty);
+            MgPropertyDefinitionCollection idProperties = bufferClass.GetIdentityProperties();
+            idProperties.Add(idProperty);
+            bufferClass.SetDefaultGeometryPropertyName("BufferGeometry");
+            MgFeatureSchema bufferSchema = new MgFeatureSchema("BufferLayerSchema", "temporary schema to hold a buffer");
+            bufferSchema.GetClasses().Add(bufferClass);
+            MgCreateSdfParams sdfParams = new MgCreateSdfParams("defaultSrs", wkt, bufferSchema);
+            featureService.CreateFeatureSource(bufferFeatureResId, sdfParams);
+        public MgLayer CreateBufferLayer(MgResourceService resourceService, MgResourceIdentifier bufferFeatureResId, String sessionId)
+            // Load the layer definition template into
+            // a XmlDocument object, find the "ResourceId" element, and
+            // modify its content to reference the temporary
+            // feature source.
+            XmlDocument doc = new XmlDocument();
+            doc.Load(Server.MapPath("bufferlayerdefinition.xml"));
+            XmlNode featureSourceNode = doc.GetElementsByTagName("ResourceId")[0];
+            featureSourceNode.InnerText = bufferFeatureResId.ToString();
+            // Get the updated layer definition from the XmlDocument
+            // and save it to the session repository using the
+            // ResourceService object.
+            MgByteSource byteSource = null;
+            using (MemoryStream ms = new MemoryStream())
+                doc.Save(ms);
+                ms.Position = 0L;
+                //Note we do this to ensure our XML content is free of any BOM characters
+                byte [] layerDefinition = ms.ToArray();
+                Encoding utf8 = Encoding.UTF8;
+                String layerDefStr = new String(utf8.GetChars(layerDefinition));
+                layerDefinition = new byte[layerDefStr.Length-1];
+                int byteCount = utf8.GetBytes(layerDefStr, 1, layerDefStr.Length-1, layerDefinition, 0);
+                byteSource = new MgByteSource(layerDefinition, layerDefinition.Length);
+                byteSource.SetMimeType(MgMimeType.Xml);
+            MgResourceIdentifier tempLayerResId = new MgResourceIdentifier("Session:" + sessionId + "//Buffer.LayerDefinition");
+            resourceService.SetResource(tempLayerResId, byteSource.GetReader(), null);
+            // Create an MgLayer object based on the new layer definition
+            // and return it to the caller.
+            MgLayer bufferLayer = new MgLayer(tempLayerResId, resourceService);
+            bufferLayer.SetName("Buffer");
+            bufferLayer.SetLegendLabel("Buffer");
+            bufferLayer.SetDisplayInLegend(true);
+            bufferLayer.SetSelectable(false);
+            return bufferLayer;
+        public void CreateParcelMarkerFeatureSource(MgFeatureService featureService, String wkt, MgResourceIdentifier parcelMarkerDataResId)
+            MgClassDefinition parcelClass = new MgClassDefinition();
+            parcelClass.SetName("ParcelMarkerClass");
+            MgPropertyDefinitionCollection properties = parcelClass.GetProperties();
+            MgGeometricPropertyDefinition pointProperty = new MgGeometricPropertyDefinition("ParcelLocation");
+            pointProperty.SetGeometryTypes(MgGeometryType.Point);
+            pointProperty.SetHasElevation(false);
+            pointProperty.SetHasMeasure(false);
+            pointProperty.SetReadOnly(false);
+            pointProperty.SetSpatialContextAssociation("defaultSrs");
+            properties.Add(pointProperty);
+            MgPropertyDefinitionCollection idProperties = parcelClass.GetIdentityProperties();
+            parcelClass.SetDefaultGeometryPropertyName("ParcelLocation");
+            MgFeatureSchema parcelSchema = new MgFeatureSchema("ParcelLayerSchema", "temporary schema to hold parcel markers");
+            parcelSchema.GetClasses().Add(parcelClass);
+            MgCreateSdfParams sdfParams = new MgCreateSdfParams("defaultSrs", wkt, parcelSchema);
+            featureService.CreateFeatureSource(parcelMarkerDataResId, sdfParams);
+        public MgLayer CreateParcelMarkerLayer(MgResourceService resourceService, MgResourceIdentifier parcelMarkerDataResId, String sessionId)
+            // Load the ParcelMarker layer definition template into
+            doc.Load(Server.MapPath("parcelmarker.xml"));
+            featureSourceNode.InnerText = parcelMarkerDataResId.ToString();
+            // Get the updated layer definition from the DOM object
+                doc.Save(ms);
+                ms.Position = 0L;
+            MgResourceIdentifier tempLayerResId = new MgResourceIdentifier("Session:" + sessionId + "//ParcelMarker.LayerDefinition");
+            MgLayer parcelMarkerLayer = new MgLayer(tempLayerResId, resourceService);
+            parcelMarkerLayer.SetName("ParcelMarker");
+            parcelMarkerLayer.SetLegendLabel("ParcelMarker");
+            parcelMarkerLayer.SetDisplayInLegend(true);
+            parcelMarkerLayer.SetSelectable(false);
+            return parcelMarkerLayer;
+</script>
\ No newline at end of file
Added: trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/createbuffer.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/createbuffer.aspx	                        (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/createbuffer.aspx	2011-12-29 11:45:05 UTC (rev 6379)
@@ -0,0 +1,200 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+//  Copyright (C) 2004-2011 by Autodesk, Inc.
+//  This library is free software; you can redistribute it and/or
+//  modify it under the terms of version 2.1 of the GNU Lesser
+//  General Public License as published by the Free Software Foundation.
+//  This library is distributed in the hope that it will be useful,
+//  but WITHOUT ANY WARRANTY; without even the implied warranty of
+//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+//  Lesser General Public License for more details.
+//  You should have received a copy of the GNU Lesser General Public
+//  License along with this library; if not, write to the Free Software
+//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+This sample has been updated to reflect simplified usage patterns enabled by convenience APIs
+introduced in MapGuide OS 2.0 by allowing you to query and insert features directly from
+the MgLayer objects themselves and the ability to get a MgFeatureReader directly from the MgSelection
+object
+<%@ Page Language="c#" %>
+<%@ Import Namespace="System.Collections.Specialized" %>
+<%@ Import Namespace="System.IO" %>
+<script runat="server">
+    String sessionId;
+    String mapName;
+</script>
+<!-- #Include File="bufferfunctions.aspx" -->
+<html>
+<head>
+    <title>Viewer Sample Application - Create Buffer</title>
+    <meta content="text/html; charset=utf-8" http-equiv="Content-Type">
+    <meta http-equiv="content-script-type" content="text/javascript" />
+    <meta http-equiv="content-style-type" content="text/css" />
+    <link href="../styles/globalStyles.css" rel="stylesheet" type="text/css">
+    <link href="../styles/otherStyles.css" rel="stylesheet" type="text/css">
+    <script language="javascript">
+        function OnPageLoad() {
+            parent.parent.Refresh();
+    </script>
+</head>
+<body class="AppFrame" onload="OnPageLoad()">
+    <h1 class="AppHeading">Create buffer</h1>
+        sessionId = Request.Params["SESSION"];
+        mapName = Request.Params["MAPNAME"];
+        String selectionXml = HttpUtility.UrlDecode(Request.Params["SELECTION"]);
+        try
+            // Initialize the Web Extensions and connect to the Server using
+            // the Web Extensions session identifier stored in PHP session state.
+            MapGuideApi.MgInitializeWebTier(Constants.WebConfigPath);
+            MgUserInformation userInfo = new MgUserInformation(sessionId);
+            MgSiteConnection siteConnection = new MgSiteConnection();
+            siteConnection.Open(userInfo);
+            MgResourceService resourceService = (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
+            MgFeatureService featureService = (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
+            MgFeatureQueryOptions queryOptions = new MgFeatureQueryOptions();
+            MgMap map = new MgMap(siteConnection);
+            map.Open(mapName);
+            // Check for selection data passed via HTTP POST
+            MgSelection selection = null;
+            MgReadOnlyLayerCollection selectedLayers = null;
+            if (!string.IsNullOrEmpty(selectionXml))
+                selection = new MgSelection(map, selectionXml);
+                selectedLayers = selection.GetLayers();
+            if (selectedLayers != null)
+                int bufferRingSize = 100; // measured in metres
+                int bufferRingCount = 5;
+                // Set up some objects for coordinate conversion
+                String mapWktSrs = map.GetMapSRS();
+                MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
+                MgWktReaderWriter wktReaderWriter = new MgWktReaderWriter();
+                MgCoordinateSystemFactory coordinateSystemFactory = new MgCoordinateSystemFactory();
+                MgCoordinateSystem srs = coordinateSystemFactory.Create(mapWktSrs);
+                MgMeasure srsMeasure = srs.GetMeasure();
+                BufferHelper helper = new BufferHelper(Server);
+                // Check for a buffer layer. If it exists, delete
+                // the current features.
+                // If it does not exist, create a feature source and
+                // a layer to hold the buffer.
+                MgLayer bufferLayer = null;
+                int layerIndex = map.GetLayers().IndexOf("Buffer");
+                if (layerIndex < 0)
+                    // The layer does not exist and must be created.
+                    MgResourceIdentifier bufferFeatureResId = new MgResourceIdentifier("Session:" + sessionId + "//Buffer.FeatureSource");
+                    helper.CreateBufferFeatureSource(featureService, mapWktSrs, bufferFeatureResId);
+                    bufferLayer = helper.CreateBufferLayer(resourceService, bufferFeatureResId, sessionId);
+                    map.GetLayers().Insert(0, bufferLayer);
+                else
+                    bufferLayer = (MgLayer)map.GetLayers().GetItem(layerIndex);
+                    MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
+                    commands.Add(new MgDeleteFeatures("BufferClass", "ID like '%'"));
+                    bufferLayer.UpdateFeatures(commands);
+                for (int i = 0; i < selectedLayers.GetCount(); i++)
+                    // Only check selected features in the Parcels layer.
+                    MgLayer layer = (MgLayer)selectedLayers.GetItem(i);
+                    if (layer.GetName() == "Parcels")
+                        // Get the selected features from the MgSelection object
+                        MgFeatureReader featureReader = selection.GetSelectedFeatures(layer, layer.GetFeatureClassName(), false);
+                        // Process each item in the MgFeatureReader. Get the
+                        // geometries from all the selected features and
+                        // merge them into a single geometry.
+                        MgGeometryCollection inputGeometries = new MgGeometryCollection();
+                        while (featureReader.ReadNext())
+                            MgByteReader featureGeometryData = featureReader.GetGeometry("SHPGEOM");
+                            MgGeometry featureGeometry = agfReaderWriter.Read(featureGeometryData);
+                            inputGeometries.Add(featureGeometry);
+                        MgGeometryFactory geometryFactory = new MgGeometryFactory();
+                        MgGeometry mergedGeometries = geometryFactory.CreateMultiGeometry(inputGeometries);
+                        // Add buffer features to the temporary feature source.
+                        // Create multiple concentric buffers to show area.
+                        // If the stylization for the layer draws the features
+                        // partially transparent, the concentric rings will be
+                        // progressively darker towards the center.
+                        // The stylization is set in the layer template file, which
+                        // is used in function CreateBufferLayer().
+                        for (int bufferRing = 0; bufferRing < bufferRingCount; bufferRing++)
+                            double bufferDist = srs.ConvertMetersToCoordinateSystemUnits(bufferRingSize * (bufferRing + 1));
+                            MgGeometry bufferGeometry = mergedGeometries.Buffer(bufferDist, srsMeasure);
+                            MgPropertyCollection properties = new MgPropertyCollection();
+                            properties.Add(new MgGeometryProperty("BufferGeometry", agfReaderWriter.Write(bufferGeometry)));
+                            commands.Add(new MgInsertFeatures("BufferClass", properties));
+                        bufferLayer.SetVisible(true);
+                        bufferLayer.ForceRefresh();
+                        map.Save();
+            else
+                Response.Write("No selected layers");
+            Response.Write("</p>");
+        catch (MgException e)
+            Response.Write("<p>" + e.GetExceptionMessage() + "</p>");
+            Response.Write("<p>" + e.GetDetails() + "</p>");
+    <p>The buffer has been created.</p>
+</body>
+</html>
Added: trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/selectfeaturesinbuffer.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/selectfeaturesinbuffer.aspx	                        (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/selectfeaturesinbuffer.aspx	2011-12-29 11:45:05 UTC (rev 6379)
@@ -0,0 +1,268 @@
+object.
+    String sessionId;
+    String mapName;
+</script>
+<html>
+<head>
+    <title>Viewer Sample Application - Select Within Buffer</title>
+    </script>
+</head>
+        Select within buffer area</h1>
+    try
+      MapGuideApi.MgInitializeWebTier (Constants.WebConfigPath);
+        int bufferRingSize = 500; // measured in metres
+        else
+        // Check for a parcel marker layer. If it exists, delete
+        // a layer to hold the parcel markers.
+        MgLayer parcelMarkerLayer = null;
+        layerIndex = map.GetLayers().IndexOf("ParcelMarker");
+            MgResourceIdentifier parcelFeatureResId = new MgResourceIdentifier("Session:" + sessionId + "//ParcelMarker.FeatureSource");
+            helper.CreateParcelMarkerFeatureSource(featureService, mapWktSrs, parcelFeatureResId);
+            parcelMarkerLayer = helper.CreateParcelMarkerLayer(resourceService, parcelFeatureResId, sessionId);
+            map.GetLayers().Insert(0, parcelMarkerLayer);
+        else
+            parcelMarkerLayer = (MgLayer)map.GetLayers().GetItem(layerIndex);
+            commands.Add(new MgDeleteFeatures("ParcelMarkerClass", "ID like '%'"));
+            parcelMarkerLayer.UpdateFeatures(commands);
+        // Check each layer in the selection.
+            Response.Write( "Marking all parcels inside the buffer that are of type 'MFG'");
+            // Create a buffer from the merged geometries
+            double bufferDist = srs.ConvertMetersToCoordinateSystemUnits(bufferRingSize);
+            // Create a filter to select parcels within the buffer. Combine
+            // a basic filter and a spatial filter to select all parcels
+            // within the buffer that are of type "MFG".
+            queryOptions = new MgFeatureQueryOptions();
+            queryOptions.SetFilter("RTYPE = 'MFG'");
+            queryOptions.SetSpatialFilter("SHPGEOM", bufferGeometry, MgFeatureSpatialOperations.Inside);
+            featureReader = layer.SelectFeatures(queryOptions);
+            // Get the features from the feature source,
+            // determine the centroid of each selected feature, and
+            // add a point to the ParcelMarker layer to mark the
+            // centroid.
+            // Collect all the points into an MgFeatureCommandCollection,
+            // so they can all be added in one operation.
+            MgFeatureCommandCollection parcelMarkerCommands = new MgFeatureCommandCollection();
+                MgByteReader byteReader = featureReader.GetGeometry("SHPGEOM");
+                MgGeometry geometry = agfReaderWriter.Read(byteReader);
+                MgPoint point = geometry.GetCentroid();
+                // Create an insert command for this parcel.
+                properties.Add(new MgGeometryProperty("ParcelLocation", agfReaderWriter.Write(point)));
+                parcelMarkerCommands.Add(new MgInsertFeatures("ParcelMarkerClass", properties));
+            featureReader.Close();
+            if (parcelMarkerCommands.GetCount() > 0)
+                parcelMarkerLayer.UpdateFeatures(parcelMarkerCommands);
+            else
+                Response.Write("</p><p>No parcels within the buffer area match.");
+            // Create a feature in the buffer feature source to show the area covered by the buffer.
+            MgPropertyCollection props = new MgPropertyCollection();
+            props.Add(new MgGeometryProperty("BufferGeometry", agfReaderWriter.Write(bufferGeometry)));
+            commands.Add(new MgInsertFeatures("BufferClass", props));
+            // Ensure that the buffer layer is visible and in the legend.
+            parcelMarkerLayer.SetVisible(true);
+            parcelMarkerLayer.ForceRefresh();
+            map.Save();
+      else
+          Response.Write( "No selected layers");
+          Response.Write( "</p>");
+      Response.Write( "<p>" + e.GetExceptionMessage() + "</p>");
+      Response.Write( "<p>" + e.GetDetails() + "</p>");
+    <p>Done.</p>
+</body>
+</html>
Copied: trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/task_pane.aspx (from rev 6363, trunk/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/task_pane.aspx)
--- trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/task_pane.aspx	                        (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/task_pane.aspx	2011-12-29 11:45:05 UTC (rev 6379)
@@ -0,0 +1,101 @@
+<%@ Page language="c#" %>
+String sessionId;
+String mapName;
+String fullPath;
+</script>
+<html>
+  <head>
+    <meta http-equiv="content-script-type" content="text/javascript">
+    <meta http-equiv="content-style-type" content="text/css">
+    <script language=javascript>
+      function submitBufferRequest(pageUrl)
+        xmlSel = parent.parent.mapFrame.GetSelectionXML();
+        if (xmlSel.length > 0)
+          params = new Array("SESSION", parent.parent.mapFrame.GetSessionId(),
+          "MAPNAME", parent.parent.mapFrame.GetMapName(),
+          "SELECTION", encodeURIComponent(xmlSel));
+          parent.parent.formFrame.Submit(pageUrl, params, "taskPaneFrame");
+        else {
+          alert ("Please select a parcel");
+         parent.parent.mapFrame.Refresh();
+         parent.parent.mapFrame.ZoomToScale(9999);
+    </script>
+  </head>
+  <body onLoad="OnPageLoad()" class="AppFrame">
+    <h1 class="AppHeading">Analyzing Features</h1>
+    <ul>
+      <li>
+        <a href="#" onClick="submitBufferRequest('../dotnetsamples/analyzing_features/createbuffer.aspx'); return false;">
+        Create buffer</a>
+        <br/>Create a buffer around a selected parcel.
+        <br/>
+            fullPath = Server.MapPath("createbuffer.aspx");
+        <a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>" >View source</a>
+      </li>
+      <li>
+        <a href="#" onClick="submitBufferRequest('../dotnetsamples/analyzing_features/selectfeaturesinbuffer.aspx'); return false;">
+        Find features in buffer</a>
+        <br/>Create a buffer around a selected parcel, then mark parcels inside the buffer that are
+        of type "MFG".
+        <br/>
+            fullPath = Server.MapPath("selectfeaturesinbuffer.aspx");
+      </li>
+    </ul>
+    <p>View source for support files:</p>
+        fullPath = Server.MapPath("task_pane.aspx");
+        String fullPath2 = Server.MapPath("bufferfunctions.aspx");
+        String fullPath3 = Server.MapPath("bufferlayerdefinition.xml");
+        String fullPath4 = Server.MapPath("parcelmarker.xml");
+    <ul>
+      <li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>">task_pane.aspx</a></li>
+      <li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath2 %>">bufferfunctions.aspx</a></li>
+      <li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath3 %>">bufferlayerdefinition.xml</a></li>
+      <li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath4 %>">parcelmarker.xml</a></li>
+    </ul>
+  </body>
+</html>
Modified: trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/layer_functions.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/layer_functions.aspx	2011-12-29 10:48:17 UTC (rev 6378)
+++ trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/layer_functions.aspx	2011-12-29 11:45:05 UTC (rev 6379)
@@ -1,4 +1,3 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
More information about the mapguide-commits
