[mapguide-commits] r5521 - sandbox/adsk/2.3r/Common/Stylization
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Feb 4 18:50:29 EST 2011
Author: waltweltonlair
Date: 2011-02-04 15:50:28 -0800 (Fri, 04 Feb 2011)
New Revision: 5521
   sandbox/adsk/2.3r/Common/Stylization/LineBuffer.cpp
This submission simply corrects an ASSERT condition in LineBuffer.cpp.  The LoadFromAgf method has:
    for (int q=0; q<num_geoms; ++q)
        // skip past geometry type of subgeometry
        // we know it is LineString or Polygon or Point respectively
        if (is_multi) *ireader++;
        // read cordinate typeB
        FdoDimensionality dim = (FdoDimensionality)*ireader++;
        // ensure that all dimensionalities of each geometry are the same
        _ASSERT(q==0 || m_dimensionality == dim);
        m_dimensionality = dim & ~FdoDimensionality_M; //LineBuffer doesn't support M
In the case where you have a multi-linestring of XYM data, the first pass (q==0)
will skip the assert and m_dimensionality is set to FdoDimensionality_XY (M bit
is supressed).  In the second pass (q==1), dim will be FdoDimensionality_XYM,
but m_dimensionality will be FdoDimensionality_XY and the assert will fire.
Modified: sandbox/adsk/2.3r/Common/Stylization/LineBuffer.cpp
--- sandbox/adsk/2.3r/Common/Stylization/LineBuffer.cpp	2011-02-04 23:48:03 UTC (rev 5520)
+++ sandbox/adsk/2.3r/Common/Stylization/LineBuffer.cpp	2011-02-04 23:50:28 UTC (rev 5521)
@@ -903,13 +903,14 @@
-                if (is_multi) *ireader++;
+                if (is_multi)
+                    *ireader++;
-                _ASSERT(q==0 || m_dimensionality == dim);
+                _ASSERT(q==0 || m_dimensionality == (dim & ~FdoDimensionality_M));
                 m_bProcessZ = (m_dimensionality & FdoDimensionality_Z) && !m_bIgnoreZ;
More information about the mapguide-commits mailing list
